[ARM Testing Update] 2022-12-31 - Handbrake, U-boot, Manjaro ARM Installer and kernels
Happy New Year everyone!
2022 was a good year for us and we hope that 2023 will continue that trend!
Some highlights:
  • Most of our kernels got updated
  • U-boot for most devices have been updated to 2022.10
  • Handbrake updated to 1.6.0
  • Mesa got a point update to 22.3.2
  • Manjaro ARM Installer updated to 1.5.2
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Sat Dec 31 13:15:38 CET 2022)
  • arm-testing community aarch64: 193 new and 183 removed package(s)
  • arm-testing core aarch64: 23 new and 23 removed package(s)
  • arm-testing extra aarch64: 129 new and 129 removed package(s)
  • arm-testing kde-unstable aarch64: 358 new and 358 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2022-12-24         2022-12-31
                firmware-raspberrypi                7.1-1           20221219-1
                           handbrake              1.5.1-1              1.6.0-1
                       handbrake-cli              1.5.1-1              1.6.0-1
               manjaro-arm-installer             1.4.11-1              1.5.2-1
               mobile-config-firefox              3.0.0-1              3.2.0-1
                               phosh0.22.0+36+ge5995917-1             0.23.0-1
               phosh-mobile-settings             0.22.0-1             0.23.0-2
    raspberrypi-userland-aarch64-git       r833.c4fd1b8-1       r834.54fd97a-1
                          rpi-eeprom           20221205-1           20221207-1
:: Different sync package(s) in repository community aarch64
                              acpica           20220331-1           20221020-1
                                 age              1.0.0-5              1.1.1-1
                             ansible              7.1.0-1              7.1.0-2
                        ansible-lint             6.10.0-2             6.10.0-4
                       atomicparsley20210715.151551.e7ad03a-120221229.172126.d813aa6-1
                                atop              2.7.1-2              2.8.0-1
                            audacity            1:3.2.2-1            1:3.2.3-1
                       audacity-docs            1:3.2.2-1            1:3.2.3-1
                            autopep8            1:2.0.0-1            1:2.0.1-1
                           babel-cli             7.19.3-1             7.20.7-1
                          babel-core             7.20.5-1             7.20.7-1
                             blender           17:3.4.0-4           17:3.4.1-1
                             calibre             6.10.0-1             6.10.0-2
                       cargo-release             0.24.0-1             0.24.1-1
                         cargo-watch              8.1.2-1              8.2.1-1
                      cargo-zigbuild             0.14.2-1             0.14.3-1
                                clap              1.1.3-2              1.1.4-1
                              datree             1.6.19-1              1.8.8-1
                          diffoscope                228-1                230-1
                          difftastic             0.39.0-1             0.40.0-1
                                 din                 55-1                 56-1
                                dpkg            1.21.12-1            1.21.13-1
                             drumkv1             0.9.27-1             0.9.28-1
                             duktape              2.7.0-4              2.7.0-5
                              elinks             0.15.1-2             0.16.0-1
                fcitx5-pinyin-zhwiki   1:0.2.4.20221128-1   1:0.2.4.20221230-1
                             furnace          0.6pre1.5-1            0.6pre2-1
                           git-cliff             0.10.0-1              1.0.0-1
                          goreleaser             1.12.3-1             1.13.1-1
                            helmfile            0.147.0-1            0.149.0-1
                               hugin           2021.0.0-6           2022.0.0-1
                jedi-language-server             0.39.0-1             0.40.0-1
                             jenkins              2.383-1              2.384-1
                             klayout               0.28-1             0.28.2-1
                             kompose             1.26.1-1             1.27.0-1
                               kooha              2.2.2-1              2.2.3-1
                              kotlin             1.7.22-1              1.8.0-1
                             kubeone              1.5.1-1              1.5.4-1
                            kubeseal             0.19.1-1             0.19.3-1
                                  lf                 27-2                 28-1
                             liblscp              0.9.7-1              0.9.8-1
                          libopenraw              0.3.2-1              0.3.3-1
                         lua-luautf8              0.1.5-1              0.1.5-2
                       lua51-luautf8              0.1.5-1              0.1.5-2
                       lua52-luautf8              0.1.5-1              0.1.5-2
                       lua53-luautf8              0.1.5-1              0.1.5-2
                            luarocks              3.9.1-1              3.9.2-1
                              marked              4.2.4-1              4.2.5-1
               matrix-appservice-irc             0.35.1-1             0.36.0-1
                            mimalloc              2.0.7-1              2.0.9-1
                                mold              1.6.0-2              1.8.0-1
                               mympd             10.1.6-1             10.1.7-1
                              neovim              0.8.1-2              0.8.2-1
                            newsboat               2.29-1             2.30.1-1
              nextcloud-app-calendar            1:4.1.1-1            1:4.1.2-1
                  nodejs-lts-gallium            16.18.0-1            16.19.0-1
                 nodejs-lts-hydrogen            18.12.1-1            18.12.1-2
                   npm-check-updates             16.5.3-1             16.5.6-1
                              nuitka              1.2.6-1              1.3.2-1
                              oxipng              7.0.0-1              8.0.0-1
                             padthv1             0.9.27-1             0.9.28-1
                               pdfpc              4.5.0-2              4.6.0-1
                  perl-finance-quote             1.5301-1               1.54-1
                    perl-perl-critic              1.140-3              1.142-1
                       perl-sys-virt              8.9.0-1             8.10.0-1
                             plumber              1.8.0-1             1.15.0-1
                             pyright            1.1.285-1            1.1.286-1
                  python-aiobotocore              2.4.1-1              2.4.2-1
                     python-aiosmtpd              1.4.2-3              1.4.3-1
                     python-billiard              4.0.2-1              4.1.0-1
                       python-btrees             4.11.2-1             4.11.3-1
                     python-cheetah3              3.3.0-1              3.3.1-1
                python-cheetah3-docs              3.3.0-1              3.3.1-1
                  python-cloudpickle              2.1.0-1              2.2.0-2
           python-cmsis-pack-manager              0.5.0-1              0.5.1-1
  python-coverage-conditional-plugin              0.7.0-1              0.8.0-1
                      python-cytoolz             0.12.0-1             0.12.1-1
               python-django-allauth             0.51.0-2             0.52.0-1
                      python-esbonio             0.15.0-2             0.15.0-3
               python-exceptiongroup              1.0.4-1              1.1.0-1
                        python-faker             13.3.4-1             13.9.0-1
                    python-fakeredis              2.3.0-1              2.4.0-1
                        python-gdstk              0.9.8-1             0.9.10-1
                    python-html2text          2020.1.16-5          2020.1.16-6
                     python-httpcore             0.16.2-1             0.16.3-1
                    python-icalendar              5.0.3-1              5.0.4-1
          python-importlib_resources             5.10.1-1             5.10.2-1
                        python-isort             5.10.1-6             5.11.4-1
                  python-jaraco.test              5.1.0-2              5.2.0-1
                   python-jsonpickle              3.0.0-1              3.0.1-1
               python-jsonrpc-server              0.4.0-5                    -
                 python-latex2mathml             3.75.0-1             3.75.1-1
                  python-levenshtein             0.20.8-1             0.20.9-1
                      python-libtmux             0.16.1-1             0.18.1-1
                       python-pandas              1.5.1-1              1.5.2-1
                        python-param             1.12.2-1             1.12.3-1
                     python-pdfminer           20220524-1           20221105-1
                      python-pip-run              9.1.0-1              9.2.1-1
                     python-pwntools              4.8.0-1              4.9.0-1
                     python-pydantic             1.10.2-1             1.10.4-1
                        python-pygls             0.13.1-1              1.0.0-1
                      python-pyquery              1.4.3-3              2.0.0-1
                      python-pytools          2022.1.13-1          2022.1.14-1
                        python-redis              4.3.5-2              4.4.0-1
                         python-rich             12.6.0-2             13.0.0-1
                      python-selinux              0.2.1-8              0.3.0-1
      python-sphinxcontrib-towncrier            0.3.1a3-1            0.3.2a0-1
                        python-sybil              3.0.1-1              4.0.0-1
                       python-xarray          2022.10.0-1          2022.12.0-1
                       python-xcffib             0.12.1-1              1.0.0-1
                   python-zope-event              4.5.0-6              4.5.1-1
                                pyzo             4.12.3-1             4.12.4-1
                            qjackctl              0.9.8-1              0.9.9-1
                            qmidictl              0.9.7-1              0.9.8-1
                            qmidinet              0.9.7-1              0.9.8-1
                              qsynth              0.9.8-1              0.9.9-1
                            qtractor             0.9.29-3             0.9.30-1
                             qxgedit              0.9.7-1              0.9.8-1
                              rclone             1.61.0-1             1.61.1-1
                              reaper               6.72-1               6.73-1
                              recoll             1.33.2-1             1.34.0-1
                  rime-pinyin-zhwiki   1:0.2.4.20221128-1   1:0.2.4.20221230-1
                             ripgrep             13.0.0-2             13.0.0-3
                               rnote             0.5.10-1             0.5.12-1
                            rofimoji              6.0.0-1              6.1.0-1
                          rosegarden              22.12-1            22.12.1-1
                        ruby-bundler             2.3.25-1              2.4.1-1
                        ruby-covered             0.18.4-1             0.18.5-1
     ruby-cucumber-compatibility-kit             11.0.1-3             11.2.0-1
                  ruby-cucumber-core             11.0.0-1             11.1.0-1
               ruby-cucumber-gherkin             26.0.1-1             26.0.2-1
                         ruby-digest              3.1.0-6              3.1.1-1
                  ruby-sys-proctable              1.2.7-1              1.3.0-1
                                ruff            0.0.192-1            0.0.203-1
                       rust-analyzer           20221219-1           20221226-1
                             samplv1             0.9.27-1             0.9.28-1
                              scrcpy               1.24-1               1.25-1
             sequoia-chameleon-gnupg              0.1.0-1              0.1.1-1
                            sh4d0wup              0.4.0-1              0.5.0-1
                             shotcut           22.11.25-1           22.12.21-1
                                sile             0.14.6-1             0.14.7-1
                       speedtest-cli              2.1.3-2              2.1.3-3
                            starship             1.12.0-1             1.12.0-2
                         stratis-cli              3.3.0-1              3.4.0-1
                           stylelint            14.16.0-1            14.16.1-1
                          supervisor              4.2.4-2              4.2.5-1
                          swi-prolog              9.0.0-3              9.0.3-1
                                syft             0.60.3-1             0.64.0-1
                             synthv1             0.9.27-1             0.9.28-1
                         timescaledb              2.9.0-1              2.9.1-1
                    timescaledb-tune             0.14.2-1             0.14.3-1
                               tmuxp             1.19.1-1             1.22.1-1
      ttf-nerd-fonts-symbols-1000-em              2.2.2-4              2.2.2-5
 ttf-nerd-fonts-symbols-1000-em-mono              2.2.2-4              2.2.2-5
      ttf-nerd-fonts-symbols-2048-em              2.2.2-4              2.2.2-5
 ttf-nerd-fonts-symbols-2048-em-mono              2.2.2-4              2.2.2-5
       ttf-nerd-fonts-symbols-common              2.2.2-4              2.2.2-5
          typescript-language-server              2.2.0-1              3.0.1-1
                               ugrep              3.9.2-1              3.9.3-2
                          unrealircd            6.0.4.2-1              6.0.5-1
         v2ray-domain-list-community     20221222065944-1     20221230165246-1
                         v2ray-geoip       202212220043-1       202212290044-1
                         vaultwarden             1.26.0-2             1.27.0-1
                            vbam-sdl2.1.4.r637.ea2a929f-1              2.1.5-1
                             vbam-wx2.1.4.r637.ea2a929f-1              2.1.5-1
                                vice              3.6.1-2                3.7-1
                             vim-ale              3.2.0-1              3.3.0-1
                               wails              2.2.0-1              2.3.1-1
                              wasmer              3.0.2-1              3.1.0-2
                                woob                3.0-6                3.1-1
                    woodpecker-agent             0.15.5-1             0.15.6-1
                      woodpecker-cli             0.15.5-1             0.15.6-1
                   woodpecker-server             0.15.5-1             0.15.6-1
                                  wt              4.8.2-1              4.9.0-1
                  age-plugin-yubikey                    -              0.3.0-1
                              blosc2                    -              2.6.1-1
                           mididings                    -           20221230-1
                      mididings-docs                    -           20221230-1
                    python-github3py                    -              3.2.0-1
                   python-lsprotocol                    -         2022.0.0a9-1
                        python-pysmf                    -              0.1.1-2
                       python-seedir                    -              0.4.2-1
        python-sphinxcontrib-fulltoc                    -                1.2-2
                            ruff-lsp                    -             0.0.12-1
                               xmake                    -              2.7.4-1
:: Different overlay package(s) in repository core aarch64
                            linux-rc            6.1.rc8-1            6.2.rc1-1
                    linux-rc-headers            6.1.rc8-1            6.2.rc1-1
                       pacman-static              6.0.2-1              6.0.2-4
                     uboot-nanopc-t4            2021.10-2            2022.10-1
                      uboot-pine-h64            2021.10-2            2022.10-1
                        uboot-pine64            2022.04-2            2022.10-1
                    uboot-pine64-lts            2022.04-2            2022.10-1
                      uboot-pinebook            2022.04-2            2022.10-1
                   uboot-pinebookpro            2022.04-4            2022.10-1
                        uboot-roc-cc            2021.10-3            2022.10-1
                        uboot-rock64            2022.04-2            2022.10-1
                      uboot-rockpi4b            2022.04-1            2022.10-1
                      uboot-rockpi4c            2022.04-1            2022.10-1
                     uboot-rockpro64            2022.04-2            2022.10-1
                         uboot-tools            2022.07-3            2022.10-1
:: Different sync package(s) in repository core aarch64
                         btrfs-progs              6.0.2-1                6.1-2
                       device-mapper            2.03.17-1            2.03.18-1
                                file               5.43-1               5.44-1
                                lvm2            2.03.17-1            2.03.18-1
                              python             3.10.8-3             3.10.9-1
                        python-tests             3.10.8-3             3.10.9-1
                             texinfo              7.0.1-1            7.0.1-1.1
                      wpa_supplicant             2:2.10-7             2:2.10-8
:: Different overlay package(s) in repository extra aarch64
                   libva-mesa-driver           22.3.1-0.1           22.3.2-0.2
                                mesa           22.3.1-0.1           22.3.2-0.2
                          mesa-vdpau           22.3.1-0.1           22.3.2-0.2
                         opencl-mesa           22.3.1-0.1           22.3.2-0.2
                     qt5-es2-wayland     5.15.7+kde+r56-1     5.15.7+kde+r58-1
                     vulkan-broadcom           22.3.1-0.1           22.3.2-0.2
                  vulkan-mesa-layers           22.3.1-0.1           22.3.2-0.2
                     vulkan-panfrost           22.3.1-0.1           22.3.2-0.2
                       vulkan-radeon           22.3.1-0.1           22.3.2-0.2
                       vulkan-swrast           22.3.1-0.1           22.3.2-0.2
:: Different sync package(s) in repository extra aarch64
                                a2ps              4.14-12              4.14-13
                              a52dec             0.7.4-11             0.7.4-12
                               aalib            1.4rc5-14            1.4rc5-15
                        alertmanager             0.24.0-2             0.25.0-1
                  alsa-card-profiles           1:0.3.63-1           1:0.3.63-3
                           aspell-fr             0.50.3-9            0.50.3-10
                           aspell-nl             0.50.2-6             0.50.2-7
                           asymptote               2.83-1               2.83-2
                        autoconf2.13               2.13-6               2.13-7
                              chmlib               0.40-6               0.40-7
                                 cln              1.3.6-2              1.3.6-3
                              convmv               2.05-2               2.05-3
                                cpio               2.13-2               2.13-3
                               dmapi             2.2.12-4             2.2.12-5
                             dotconf                1.3-6                1.3-7
                            enscript              1.6.6-4              1.6.6-5
                             ethtool              1:6.0-1              1:6.0-2
                              facile              1.1.4-2              1.1.4-3
                          fsarchiver              0.8.6-1              0.8.6-2
                      geoip-database           20221118-1           20221227-1
                geoip-database-extra           20221118-1           20221227-1
                               glade             3.40.0-13.40.0+r14+g1fbca367-1
                          gnu-netcat              0.7.1-8              0.7.1-9
                               gperf                3.1-3                3.1-4
                            graphviz              7.0.4-1              7.0.5-1
                gst-plugin-libcamera              0.0.2-1              0.0.3-1
                 gst-plugin-pipewire           1:0.3.63-1           1:0.3.63-3
                           hyphen-nl           20050617-5           20050617-6
                             ifplugd              0.28-16              0.28-17
                          java-jline                1.0-6                1.0-7
                      libcamera-docs              0.0.2-1              0.0.3-1
                     libcamera-tools              0.0.2-1              0.0.3-1
                         libieee1284            0.2.11-13            0.2.11-14
                            libirman              0.5.2-3              0.5.2-4
                       libkeybinder3              0.3.2-3              0.3.2-4
                          libmodplug            0.8.9.0-3            0.8.9.0-4
                          libnss_nis                3.1-3                3.1-4
                   libomxil-bellagio              0.9.3-3              0.9.3-4
                            libproxy             0.4.18-1             0.4.18-2
                     libproxy-webkit             0.4.18-1             0.4.18-2
                          libsigsegv               2.14-1               2.14-2
                            libtiger              0.3.4-6              0.3.4-7
                              libwmf             0.2.12-2             0.2.12-3
                           linux-atm              2.5.2-7              2.5.2-8
                                lirc           1:0.10.2-1           1:0.10.2-2
                                 lua              5.4.4-2              5.4.4-3
                  mkinitcpio-archiso                 66-1                 67-1
                                 moc            1:2.5.2-7            1:2.5.2-8
                               ncftp              3.2.6-4              3.2.6-5
                           npapi-sdk             0.27.2-3             0.27.2-4
                                 ntp          4.2.8.p15-2          4.2.8.p15-3
                           pacrunner               0.18-1               0.19-2
                    perl-alien-build               2.74-1               2.76-1
                      perl-appconfig               1.71-9              1.71-10
                     perl-bit-vector               7.4-13               7.4-14
                      perl-carp-clan               6.08-5               6.08-6
                  perl-config-simple              4.59-14              4.59-15
                 perl-convert-binhex             1.125-10             1.125-11
                   perl-crypt-ssleay            0.73_06-2            0.73_06-3
                      perl-date-calc                6.4-9               6.4-10
                perl-digest-nilsimsa              0.06-22              0.06-23
                    perl-digest-sha1              2.13-17              2.13-18
                  perl-encode-locale               1.05-9              1.05-10
                 perl-event-execflow               0.64-7               0.64-8
            perl-extutils-libbuilder               0.08-9              0.08-10
             perl-extutils-pkgconfig               1.16-9              1.16-10
              perl-file-desktopentry               0.22-9              0.22-10
                          perl-guard             1.023-13             1.023-14
                    perl-html-tagset              3.20-12              3.20-13
                      perl-http-date               6.05-5               6.05-6
                 perl-http-negotiate              6.01-10              6.01-11
                 perl-image-exiftool              12.50-1              12.50-2
                   perl-libintl-perl               1.32-3               1.33-1
                 perl-locale-gettext              1.07-12              1.07-13
                 perl-lwp-mediatypes               6.04-2               6.04-3
                       perl-mail-spf              2.9.0-9             2.9.0-10
                     perl-math-round               0.07-4               0.07-5
                     perl-mime-types               2.22-2               2.24-1
                         perl-net-ip              1.26-10              1.26-11
                     perl-netaddr-ip             4.079-12             4.079-13
              perl-string-shellquote               1.04-6               1.04-7
              perl-sys-hostname-long                1.5-9               1.5-10
                     perl-text-iconv               1.7-21               1.7-22
                     perl-text-patch               1.8-10               1.8-11
                 perl-www-robotrules              6.02-10              6.02-11
           perl-xml-namespacesupport               1.12-4               1.12-5
                   perl-xml-sax-base               1.09-4               1.09-5
                       perl-xml-twig               3.52-9              3.52-10
                       pipewire-alsa           1:0.3.63-1           1:0.3.63-3
                      pipewire-audio           1:0.3.63-1           1:0.3.63-3
                       pipewire-docs           1:0.3.63-1           1:0.3.63-3
                       pipewire-jack           1:0.3.63-1           1:0.3.63-3
                      pipewire-pulse           1:0.3.63-1           1:0.3.63-3
                       pipewire-v4l2           1:0.3.63-1           1:0.3.63-3
                   pipewire-x11-bell           1:0.3.63-1           1:0.3.63-3
                   pipewire-zeroconf           1:0.3.63-1           1:0.3.63-3
                        python-attrs             22.1.0-1             22.2.0-1
                        python-geoip             1.3.2-12             1.3.2-13
                     python-retrying             1.3.3-14             1.3.3-15
                            qrencode              4.1.1-1              4.1.1-2
                               razor              2.85-17              2.85-18
                                re2c                3.0-1                3.0-2
                          sdl2_mixer              2.6.2-1              2.6.2-2
                               slang              2.3.3-1              2.3.3-2
                               snarf                7.0-8                7.0-9
                              strace                6.1-1                6.1-2
                          subversion             1.14.2-5             1.14.2-6
                         suitesparse              6.0.2-1              6.0.3-1
                            testdisk                7.1-4                7.1-5
                            tftp-hpa                5.2-9               5.2-10
                                tree              2.0.4-1              2.1.0-1
                  ttf-bitstream-vera              1.10-14              1.10-15
                               whois             5.5.14-1             5.5.15-1
                           wpewebkit             2.38.2-2             2.38.3-1
                      wpewebkit-docs             2.38.2-2             2.38.3-1
                            xerces-c              3.2.4-1              3.2.4-2
                                yasm              1.3.0-5              1.3.0-6
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi22.12.0.r12866.g3c9d75b18-122.12.0.r12871.g80723ac9c-1
                    akonadi-calendar22.12.0.r2238.g9fa16a3-122.12.0.r2244.gbef82a8-1
              akonadi-calendar-tools22.12.0.r989.g38ec37f-122.12.0.r991.gf6997a5-1
                    akonadi-contacts22.12.0.r3311.gbb1737d8-122.12.0.r3315.g79bc8286-1
               akonadi-import-wizard22.12.0.r1874.g5f4a9d5-122.12.0.r1877.g5c0a4a2-1
                        akonadi-mime22.12.0.r1794.gfe85873-122.12.0.r1797.gef41a2f-1
                       akonadi-notes22.12.0.r1114.g96e3758-122.12.0.r1116.gf4007a0-1
                      akonadi-search22.12.0.r1310.g8f5fdd4-122.12.0.r1313.gb35904e-1
                      akonadiconsole22.12.0.r1639.g1402f67-122.12.0.r1640.g584e3dc-1
                           akregator22.12.0.r6531.g64fdf372-122.12.0.r6535.g2a206b3a-1
                           alligator 22.11.r15.gcde14df-1 22.11.r21.g3ec1c34-1
                            analitza22.12.0.r2374.g56367297-122.12.0.r2375.g2c0c3fdc-1
                           angelfish 22.11.r18.g5841cdc-1 22.11.r24.gc9fc66c-1
                                 ark22.12.0.r4969.g1165b92b-122.12.0.r4973.g53cc21e6-1
                          artikulate22.12.0.r1477.gd5ff3d7-122.12.0.r1478.gee021a3-1
                         audiocd-kio22.12.0.r1135.g0587367-122.12.0.r1138.g00c1bc1-1
                           audiotube 22.11.r16.gd14e118-1 22.11.r39.g1faa7a1-1
                        aura-browser5.26.0.r153.gb17567e-15.26.0.r155.g1db9758-1
                               baloo5.101.0.r3115.gb48e8177-15.101.0.r3118.g010d98b3-1
                       baloo-widgets22.12.0.r799.g8e59e92-122.12.0.r801.g485e2d4-1
                             blinken22.12.0.r704.g022a1d8-122.12.0.r705.g310062e-1
                           bluedevil1:5.26.4.r2534.gd989999c-11:5.26.4.r2545.g9b28f161-1
                              bomber22.12.0.r599.g79f34c2-122.12.0.r600.gbf5cd5a-1
                                bovo22.12.0.r816.g7492106-122.12.0.r817.g163ff4d-1
                              breeze5.26.4.r2534.g417e68bf-15.26.4.r2536.g306f2740-1
                        breeze-icons5.101.0.r1941.g6cc0aad2-15.101.0.r1942.g76ba10aa-1
                                buho  2.2.1.r7.g38d1ef1-1  2.2.1.r8.g6a48d97-1
                     calendarsupport22.08.3.r762.g6edf3a4-122.08.3.r770.gb7f4303-1
                           calindori  22.11.r7.g090dc21-1  22.11.r8.g93b925c-1
                            cervisia22.12.0.r1729.ga5e9e7c-122.12.0.r1730.g5af9da2-1
                            discover5.26.4.r9097.gab37017a9-15.26.4.r9111.g009875b6e-1
                             dolphin22.12.0.r7200.gb508215d3-122.12.0.r7210.g414311b8c-1
                     dolphin-plugins22.12.0.r710.g7d5cdcb-122.12.0.r711.g0a086e0-1
                              dragon22.12.0.r1120.g217276b-122.12.0.r1121.gcfa7368-1
                             drkonqi5.26.4.r865.gd0df3d98-15.26.4.r867.g63e246b7-1
                               elisa22.12.0.r3093.g0325f35c-122.12.0.r3100.g8084fec7-1
                          elisa-qtmm22.12.0.r3093.g0325f35c-122.12.0.r3100.g8084fec7-1
                          eventviews22.08.3.r915.ge7f6bbe-122.08.3.r917.gf28d4b8-1
                           filelight22.12.0.r1293.gf053bd5-122.12.0.r1297.gfd6d68f-1
                           granatier22.12.0.r1013.gdbf5fd0-122.12.0.r1016.gd4857fb-1
                     grantlee-editor22.12.0.r879.gf3230e1-122.12.0.r881.g140c5fe-1
                       grantleetheme22.12.0.r449.gef5406c-122.12.0.r451.gdeac8c2-1
                            gwenview22.12.0.r6989.g017195b2-122.12.0.r6999.gc2e14313-1
                     incidenceeditor22.12.0.r970.gd46a161-122.12.0.r972.gb4c507f-1
                            index-fm  2.2.1.r5.gedf78ba-1  2.2.1.r6.gec811a3-1
                           itinerary22.12.0.r2186.ge5b5e11-122.12.0.r2196.g3ae1405-1
                                 juk22.12.0.r3214.g5825badf-122.12.0.r3215.g43094cd9-1
                                 k3b1:22.08.3.r6863.gdd77a2cac-11:22.12.0.r6880.gfc3c87782-1
               kaccounts-integration22.12.0.r1311.g58341ac-122.12.0.r1316.ge4f4d4f-1
                 kaccounts-providers22.12.0.r413.g0aa5195-122.12.0.r416.g5331a6e-1
                   kactivitymanagerd5.26.4.r1436.gd22a22b-15.26.4.r1439.g32713b5-1
                        kaddressbook22.12.0.r6282.g4ce9bf3c-122.12.0.r6284.g9798c8a6-1
                             kajongg22.12.0.r4377.gd783b9f2-122.12.0.r4378.g61c0f6bd-1
                              kalarm22.12.0.r8175.g4235c257-122.12.0.r8208.ge89af958-1
                            kalgebra22.12.0.r2108.g8f6eab2-122.12.0.r2109.g724d862-1
                                kalk 22.11.r15.gb55f58f-1 22.11.r17.g696c750-1
                             kalzium22.12.0.r4446.g5c1ab74b-122.12.0.r4447.g46ff2165-1
                              kamera22.12.0.r756.gf4a5229-122.12.0.r757.gc86bfe4-1
                              kamoso22.12.0.r1512.g5d60346-122.12.0.r1514.gc130685-1
                            kanagram22.12.0.r1357.ga9676e8-122.12.0.r1361.gc85deab-1
                              kapman22.12.0.r693.g76f7974-122.12.0.r694.g7304eec-1
                        kapptemplate22.12.0.r1029.g898de5f-122.12.0.r1030.g4f5f60a-1
                            karchive5.101.0.r594.g75b7d07-15.101.0.r595.gac198e1-1
                               kasts 22.11.r48.g2633a4c-1 22.11.r52.gcc10ce8-1
                                kate22.12.0.r20047.gf486848c7-122.12.0.r20068.g3f9fa9170-1
                             katomic22.12.0.r999.g38c1214-122.12.0.r1000.g7616cec-1
                               kauth5.101.0.r529.g2f5ad09-15.101.0.r531.g2127ed5-1
                             kbackup22.12.0.r489.g35e6e55-122.12.0.r490.g5bb3771-1
                           kblackbox22.12.0.r805.g4309c91-122.12.0.r806.gfccae6e-1
                             kblocks22.12.0.r780.g6d25632-122.12.0.r781.g1820186-1
                          kbookmarks5.101.0.r494.g5000502-15.101.0.r495.gf27d39a-1
                             kbounce22.12.0.r886.g025d797-122.12.0.r890.g6fe16a4-1
                           kbreakout22.12.0.r965.g2c033a3-122.12.0.r966.ge8dca87-1
                              kbruch22.12.0.r916.gfb21760-122.12.0.r917.g827bcf3-1
                         kcachegrind22.12.0.r1222.g7fd89e1-122.12.0.r1223.gdc25eb3-1
                  kcachegrind-common22.12.0.r1222.g7fd89e1-122.12.0.r1223.gdc25eb3-1
                               kcalc22.12.0.r1666.g614ba88-122.12.0.r1668.ge6a50d3-1
                           kcalutils22.12.0.r1020.g3500b3f62-122.12.0.r1022.g41d9da087-1
                         kcharselect22.12.0.r577.g821033d-122.12.0.r578.g347df1c-1
                              kclock 22.11.r16.g5283d2f-1 22.11.r25.g7888695-1
                            kcmutils5.101.0.r694.g05bcc7f-15.101.0.r696.gf042181-1
                             kcodecs5.101.0.r461.g7d0dc3e-15.101.0.r462.gf11dcb0-1
                       kcolorchooser22.12.0.r298.ga281134-122.12.0.r300.ge014fe4-1
                         kcompletion5.101.0.r532.g5890dcf-15.101.0.r533.g9bc7944-1
                             kconfig5.101.0.r1016.g9f0e5ce6-15.101.0.r1017.g138f6663-1
                      kconfigwidgets5.101.0.r832.g5f7788dc-15.101.0.r835.g00403f73-1
                           kcontacts1:5.101.0.r3378.gc0f92be2-11:5.101.0.r3381.g35ee15e3-1
                         kcoreaddons5.101.0.r1631.g8ad66b2f-15.101.0.r1636.g9911c9a2-1
                               kcron22.12.0.r870.g796020f-122.12.0.r871.g2b6f5cb-1
                                kdav1:5.101.0.r1377.g5bc20a4-11:5.101.0.r1378.gef417cf-1
                         kdbusaddons5.101.0.r450.gdd34487-15.101.0.r451.g7296991-1
                       kde-cli-tools5.26.4.r2028.g05bc19b-15.26.4.r2031.g2c27c4e-1
                     kde-dev-scripts22.12.0.r4170.gf586109-122.12.0.r4172.g33fdd2f-1
                       kde-dev-utils22.12.0.r621.g7af7ed9-122.12.0.r622.gb052652-1
                      kdebugsettings22.12.0.r1047.g433dc5d-122.12.0.r1048.g42c9af4-1
                        kdeclarative5.101.0.r1084.g9b5d427-15.101.0.r1085.gcbd9a19-1
                          kdeconnect22.12.0.r3632.g29f56dcc-122.12.0.r3641.g8e3202a6-1
                         kdecoration5.26.4.r316.gdfa74e6-15.26.4.r317.g1ca9b1f-1
                     kdelibs4support5.101.0.r1136.g80175c78-15.101.0.r1137.g07600fe3-1
              kdenetwork-filesharing22.12.0.r1011.g2dc5dab-122.12.0.r1017.g4aa5609-1
                            kdenlive22.12.0.r17255.g02cea77f4-122.12.0.r17261.g7b36bc885-1
                       kdepim-addons22.12.0.r4963.gd2fa125dc-122.12.0.r4967.g9c6320846-1
                      kdepim-runtime22.12.0.r15669.gc730636e0-122.12.0.r15671.g994a54d89-1
                    kdeplasma-addons5.26.4.r9222.g4d96e53bd-15.26.4.r9236.g837decf70-1
                 kdesdk-thumbnailers22.12.0.r111.gb9864b7-122.12.0.r112.geaab26d-1
                     kdesignerplugin5.101.0.r381.g8c156b5-15.101.0.r382.g0c9b089-1
                               kdesu5.101.0.r540.g6c5f2c2-15.101.0.r541.gac16d06-1
                                 kdf22.12.0.r909.g99acef1-122.12.0.r910.gda13cc1-1
                             kdialog22.12.0.r1278.g7d76838d3-122.12.0.r1279.g8ab0b4e8d-1
                            kdiamond22.12.0.r760.g4052c89-122.12.0.r761.g77eeff3-1
                              kdnssd5.101.0.r380.gbf70b39-15.101.0.r381.gd623e99-1
                           kdoctools5.101.0.r702.g6ea04e8-15.101.0.r703.g2afe1dc-1
                      keditbookmarks22.12.0.r2793.g42f4c9e0e-122.12.0.r2794.g08829f456-1
                            keysmith  22.11.r5.g1efe214-1  22.11.r6.g2376b93-1
                       kfilemetadata5.101.0.r907.g60d4dad-15.101.0.r908.g378e049-1
                               kfind22.12.0.r2762.g661d71b93-122.12.0.r2763.gfb108916e-1
                             kfloppy22.12.0.r828.g99778b5-122.12.0.r830.g6056883-1
                         kfourinline22.12.0.r1065.gfc5bdde-122.12.0.r1066.ga00bfe6-1
                             kgamma55.26.4.r500.g7a72b99-15.26.4.r501.g2435a49-1
                          kgeography22.12.0.r1212.g6473f18-122.12.0.r1214.gc7f9cf2-1
                                kget22.12.0.r3274.g88500f1d-122.12.0.r3286.g46cb90e8-1
                        kglobalaccel5.101.0.r616.gcaea207-15.101.0.r617.g3990cb7-1
                         kgoldrunner22.12.0.r1332.gf2adf8b-122.12.0.r1333.g01ca51b-1
                            khangman22.12.0.r1655.g72689de-122.12.0.r1656.g157889b-1
                         khelpcenter22.12.0.r2838.g291d35b3-122.12.0.r2840.g31ffb209-1
                           kholidays1:5.101.0.r1092.g8ceca1b-11:5.101.0.r1094.g3578ca6-1
                            khotkeys5.26.4.r2187.g998c0a5-15.26.4.r2195.gedc99c1-1
                               khtml5.101.0.r634.g50a89a2-15.101.0.r637.ga08c672-1
                               ki18n5.101.0.r604.g1812519-15.101.0.r605.g4ef9f1e-1
                         kiconthemes5.101.0.r657.g1be3e63-15.101.0.r660.g1f8d312-1
                 kidentitymanagement22.12.0.r3934.gb85a62a9-122.12.0.r3936.g58606b86-1
                                 kig22.12.0.r3265.g8e5d726f-122.12.0.r3268.gf68c9275-1
                                kigo22.12.0.r612.g87967bd-122.12.0.r613.g707c419-1
                            killbots22.12.0.r835.gb3a966d-122.12.0.r837.gc91bfb8-1
                     kimagemapeditor22.12.0.r546.geea2916-122.12.0.r550.g7536bc7-1
                               kimap22.12.0.r1232.g1143a48-122.12.0.r1234.g0bddf48-1
                         kinfocenter5.26.4.r2250.gf066b1a6-15.26.4.r2260.gcf59ddb4-1
                               kinit5.101.0.r469.g1bdab6f-15.101.0.r470.g266d194-1
                                 kio5.101.0.r5970.g36b9540dc-15.101.0.r5981.gda081e8bd-1
                          kio-extras22.12.0.r7444.g964714b97-122.12.0.r7454.ga941c6051-1
                          kio-gdrive22.12.0.r680.g5061f5e-122.12.0.r682.gb0b4bdb-1
                     kirigami-addons1:0.6.1.r9.g339fd5b-11:0.6.1.r13.gbcd35a3-1
                    kirigami-gallery22.12.0.r304.gef7ade2-122.12.0.r306.g1a9080a-1
                           kirigami25.101.0.r3540.g14724a13-15.101.0.r3549.g608c7601-1
                              kiriki22.12.0.r502.g6cb570b-122.12.0.r503.g17cff1c-1
                          kitemviews5.101.0.r405.g927f6c5-15.101.0.r406.g3a4078c-1
                               kiten22.12.0.r1237.g930dcf8-122.12.0.r1241.g26cd666-1
                          kitinerary22.12.0.r2585.g6c2b3ae9-122.12.0.r2587.g340a60e7-1
                         kjobwidgets5.101.0.r453.g2b12cfe-15.101.0.r454.gd9a0b66-1
                            kjsembed5.101.0.r352.gcc55cd3-15.101.0.r354.g2fadd55-1
                        kjumpingcube22.12.0.r879.g68aa0e1-122.12.0.r880.gc2b73c7-1
                               kldap22.12.0.r1001.g42d9cc1-122.12.0.r1003.g7eecc09-1
                           kleopatra22.12.0.r7032.g9f839740-122.12.0.r7038.gfde8f45d-1
                            klettres22.12.0.r1006.g1b4e268-122.12.0.r1007.g7b203ac-1
                            klickety22.12.0.r737.g24f94cf-122.12.0.r738.gba209b9-1
                              klines22.12.0.r856.g7fdf013-122.12.0.r857.g2e5584b-1
                                kmag22.12.0.r773.gd8e6757-122.12.0.r774.gcfd59f6-1
                           kmahjongg22.12.0.r1598.gb3225d7-122.12.0.r1599.g38ee0d3-1
                               kmail22.12.0.r26700.gb35b1d520-122.12.0.r26709.g87b1a93d6-1
                kmail-account-wizard22.12.0.r927.g7713319-122.12.0.r929.g28c7225-1
                      kmailtransport22.12.0.r1835.g024d640-122.12.0.r1837.g30e059f-1
                               kmbox22.12.0.r621.g9d10be1-122.12.0.r622.g2186fc6-1
                           kmenuedit5.26.4.r1123.ge8c6290-15.26.4.r1127.gb39434e-1
                               kmime22.12.0.r1566.g2bd2208-122.12.0.r1568.g39267bc-1
                              kmines22.12.0.r1806.g7a817e1-122.12.0.r1807.g51d3d68-1
                                kmix22.12.0.r2488.gc52a2142-122.12.0.r2489.gc4e463ed-1
                          kmousetool22.12.0.r477.gfc3e4c4-122.12.0.r478.g29459a3-1
                              kmouth22.12.0.r782.gf43bc73-122.12.0.r783.g97e9e17-1
                              kmplot22.12.0.r1551.g15a102d-122.12.0.r1553.g62accba-1
                        knavalbattle22.12.0.r1471.g45f40c0-122.12.0.r1477.g0bf5ab0-1
                            knetwalk22.12.0.r752.gde765db-122.12.0.r753.gf5ffc6a-1
                           knewstuff5.101.0.r1446.g8f2b7dc3-15.101.0.r1448.g1cfd2b17-1
                             knights22.12.0.r1194.g0f3db93-122.12.0.r1195.g0571596-1
                              knotes22.12.0.r3757.g9f4bc8bc-122.12.0.r3761.g93115eea-1
                      knotifications5.101.0.r790.gb456b7a-15.101.0.r791.g6aae729-1
                       knotifyconfig5.101.0.r414.g0bc02c0-15.101.0.r415.g7ac5959-1
                                koko  22.11.r5.g1549184-1  22.11.r6.g5d2fb9e-1
                                kolf22.12.0.r1565.gcf1266e-122.12.0.r1566.gdb2ff7c-1
                           kollision22.12.0.r572.g9cc9d47-122.12.0.r573.ga7bc2f0-1
                         kolourpaint22.12.0.r2469.ga2946697-122.12.0.r2471.g8d548c9c-1
                             kompare22.12.0.r1210.gbcb18d5-122.12.0.r1211.g214b21f-1
                            kongress  22.11.r3.gc7b321e-1  22.11.r4.g05110a8-1
                           konqueror22.12.0.r15256.ga07fc894f-122.12.0.r15266.g9f3b036b5-1
                            konquest22.12.0.r985.g96167de-122.12.0.r986.ga32b380-1
                             konsole22.12.0.r8802.g031ca6f7-122.12.0.r8812.gb63d989c-1
                             kontact22.12.0.r5624.g482d1417-122.12.0.r5626.g8f1ff379-1
                    kontactinterface22.12.0.r733.g3624848-122.12.0.r735.g905d664-1
                            kontrast22.12.0.r271.gf066b15-122.12.0.r272.gb58e6fa-1
                        konversation22.12.0.r9218.g47a339f9-122.12.0.r9219.g43289332-1
                       kopeninghours22.12.0.r357.gac48b0a-122.12.0.r358.gb3b8fdb-1
                              kopete22.08.3.r16477.g3daf2de9a-122.12.0.r16507.g735fe12e0-1
                          korganizer22.12.0.r11901.g1303454a3-122.12.0.r11903.g228e40c99-1
                       kosmindoormap22.12.0.r870.gfe03c05-122.12.0.r871.gcc4b323-1
                            kpackage5.101.0.r799.g685f236-15.101.0.r800.gbb0d701-1
                              kparts5.101.0.r642.g475401e-15.101.0.r643.g1c39f36-1
                                kpat22.12.0.r2672.g311d420b-122.12.0.r2673.g5e4d4a8f-1
                             kpeople5.101.0.r1408.ga1c11f0-15.101.0.r1409.g2a06726-1
                        kpeoplevcard   0.1.r57.g847df8a-1   0.1.r58.g513d6f9-1
                        kpimtextedit22.12.0.r1736.g10e0f90-122.12.0.r1739.g67797d4-1
                           kpipewire5.26.4.r181.g3f09496-15.26.4.r182.g968ce31-1
                             kpkpass22.12.0.r319.ga90c94a-122.12.0.r320.g17a6622-1
                             kpmcore22.12.0.r1332.g3d08bb0-122.12.0.r1333.g36b5603-1
                                kpty5.101.0.r403.gc293405-15.101.0.r404.g90cc02d-1
                    kpublictransport22.12.0.r2070.g1ef36fdc-122.12.0.r2078.gb70d4b6a-1
                                krdc22.12.0.r1657.g879a73f-122.12.0.r1662.g7670bbb-1
                           krecorder 22.11.r23.g78a332a-1 22.11.r24.g01d2d40-1
                            kreversi22.12.0.r1315.gc5dd5a2-122.12.0.r1316.g526b9e5-1
                                krfb22.12.0.r1532.gf97f9a7-122.12.0.r1533.g462c729-1
                               kross5.101.0.r384.gd8842d9-15.101.0.r385.g09f7b52-1
                              kruler22.12.0.r776.g2ab4d97-122.12.0.r777.g6ca53f2-1
                           ksanecore      r660.g1b80e58-1      r661.gc1683ca-1
                             kscreen5.26.4.r1636.gdbb98be-15.26.4.r1643.g43205c2-1
                       kscreenlocker5.26.4.r1043.g4b19732-15.26.4.r1047.g99ad475-1
                            kservice5.101.0.r1063.g3c2ce08-15.101.0.r1064.g8771932-1
                             kshisen22.12.0.r1280.g2895137-122.12.0.r1282.g4370db6-1
                               ksirk22.12.0.r1091.g8f83d99-122.12.0.r1092.gcd4b6e9-1
                               ksmtp22.12.0.r481.gcfaaaa0-122.12.0.r483.g3241fe1-1
                          ksnakeduel22.12.0.r892.g1ac71c5-122.12.0.r893.g525ee09-1
                          kspaceduel22.12.0.r708.ge8d4ba4-122.12.0.r712.g38ce9ab-1
                            ksquares22.12.0.r620.gbea4de7-122.12.0.r621.gb9472ce-1
                         ksshaskpass5.26.4.r235.gab04982-15.26.4.r238.g1dc6565-1
                             ksudoku22.12.0.r1158.gc288555-122.12.0.r1159.gf7ac07a-1
                           ksysguard5.26.4.r3569.ge44ce920-15.26.4.r3570.g04455414-1
                          ksystemlog22.12.0.r789.ga9d0a80-122.12.0.r790.g257a4e2-1
                        ksystemstats5.26.4.r260.gab269a1-15.26.4.r262.g99e8d57-1
                            kteatime22.12.0.r788.ged435e4-122.12.0.r789.g5f25181-1
                         ktexteditor5.101.0.r3686.gfa426486-15.101.0.r3696.g19716559-1
                        ktextwidgets5.101.0.r485.g694595f-15.101.0.r486.g6f23dd2-1
                              ktimer22.12.0.r557.g0b0ad46-122.12.0.r558.gd6e8556-1
                               ktnef22.12.0.r762.gccba639-122.12.0.r765.g32f790c-1
                            ktorrent22.12.0.r2930.g8994ce70-122.12.0.r2931.g19cf74c4-1
                              ktouch22.12.0.r2227.gc7065f4-122.12.0.r2231.gcdf22f2-1
                               ktrip  22.11.r5.g51f9ec1-1  22.11.r6.gf0f62cc-1
                          ktuberling22.12.0.r1117.g4715cfc-122.12.0.r1118.g40d5b04-1
                             kturtle22.12.0.r1213.g64327a7-122.12.0.r1217.gcdfba0c-1
                             kubrick22.12.0.r455.g8fad814-122.12.0.r456.g54d1d88-1
                     kunitconversion5.101.0.r463.g80f0d48-15.101.0.r464.g8067928-1
                             kwallet5.101.0.r1214.g85ee8a9-15.101.0.r1215.g63a067b-1
                      kwalletmanager22.12.0.r1357.gbfc0d8c-122.12.0.r1361.g742af57-1
                               kwave22.12.0.r3837.gf1aaf8f5-122.12.0.r3838.g290737eb-1
                kwayland-integration5.26.4.r223.g0eb853b-15.26.4.r224.ge771883-1
                            kweather 22.11.r14.g31b5819-1 22.11.r16.gfcb699f-1
                        kweathercore   0.7.r18.gf587bc1-1   0.7.r21.g348f1cb-1
                      kwidgetsaddons5.101.0.r1035.g79660287-15.101.0.r1037.g2e99e3b1-1
                                kwin5.26.4.r23812.g8c5f8e2fa-15.26.4.r23835.g39612ade1-1
                       kwindowsystem5.101.0.r730.gc01039b-15.101.0.r731.g4533d33-1
                           kwordquiz22.12.0.r1257.gfa2ea69-122.12.0.r1258.ge25edf9-1
                              kwrite22.12.0.r20047.gf486848c7-122.12.0.r20068.g3f9fa9170-1
                             kwrited5.26.4.r521.g21190ee-15.26.4.r522.g848d720-1
                             kxmlgui5.101.0.r941.g4f3cdf47-15.101.0.r944.g398524a1-1
                       kxmlrpcclient5.101.0.r504.g7aa32398d-15.101.0.r505.gccd4485b9-1
                      layer-shell-qt5.26.4.r68.g70dc87f-15.26.4.r69.gb95910c-1
                          libakonadi22.12.0.r12866.g3c9d75b18-122.12.0.r12871.g80723ac9c-1
                         libgravatar22.12.0.r457.gb7a672d-122.12.0.r459.g55dd162-1
                            libkcddb22.12.0.r782.g7602302-122.12.0.r783.g9e64054-1
                     libkcompactdisc22.12.0.r409.g35ad14a-122.12.0.r410.g8908999-1
                         libkdegames22.12.0.r2285.gc83b55ab-122.12.0.r2286.g01a8829e-1
                           libkdepim22.12.0.r946.gbb57a93-122.12.0.r948.gd080fc2-1
                  libkeduvocdocument22.12.0.r1828.ge1dc392-122.12.0.r1830.g0de205b-1
                            libkgapi22.12.0.r1407.g8186ced-122.12.0.r1409.g91d1b01-1
                             libkleo22.12.0.r1353.gd866af3-122.12.0.r1355.g9c8b264-1
                        libkmahjongg22.12.0.r510.g7edd616-122.12.0.r511.g3b76a4f-1
                     libkomparediff222.12.0.r372.ga623f3d-122.12.0.r373.gf1e1b51-1
                            libksane22.12.0.r626.ge287409-122.12.0.r627.gf4f960b-1
                          libkscreen5.26.4.r1709.ge84d610-15.26.4.r1712.g1986392-1
                           libksieve22.12.0.r1791.g44d761d6-122.12.0.r1794.g478db276-1
                        libksysguard5.26.4.r2498.gf9579bd-15.26.4.r2504.gd014b31-1
                         libktorrent22.12.0.r580.g89df5fb-122.12.0.r581.g4e033e5-1
                            lokalize22.12.0.r1884.g6d476156-122.12.0.r1889.g428d142b-1
                               lskat22.12.0.r893.gaba26d3-122.12.0.r894.g706c1b9-1
                          mailcommon22.12.0.r1352.g62683ab-122.12.0.r1355.g60b6f4a-1
                        mailimporter22.12.0.r569.g1cf5013-122.12.0.r571.g231e8ed-1
                              marble22.12.0.r13533.g0f289d578-122.12.0.r13540.gc94802d40-1
                       marble-common22.12.0.r13533.g0f289d578-122.12.0.r13540.gc94802d40-1
                           marble-qt22.12.0.r13533.g0f289d578-122.12.0.r13540.gc94802d40-1
                        markdownpart22.12.0.r158.ge18f125-122.12.0.r159.g7561bfd-1
                           maui-clip  2.2.1.r6.gcf6be76-1  2.2.1.r7.g1c00c46-1
                           maui-nota  2.2.1.r5.gd73a29a-1  2.2.1.r6.gd1f2b3e-1
                          maui-shell  0.5.6.r2.ge7d580f-1  0.5.6.r3.g70edfbe-1
                             mauikit2.2.1.r23.g67aadca4-12.2.1.r26.g39e2def4-1
                    mauikit-accounts  2.2.1.r9.g60d88a6-1 2.2.1.r10.g4ba2434-1
                mauikit-filebrowsing 2.2.0.r35.geb16ddf-1 2.2.0.r37.g84022f5-1
                  mauikit-texteditor  2.2.1.r9.g86889d0-1 2.2.1.r10.gd636813-1
                       mbox-importer22.12.0.r601.g261770e-122.12.0.r603.g7f3993e-1
                          messagelib22.12.0.r6826.ga030bcf6e-122.12.0.r6830.ge736531a2-1
                               milou5.26.4.r799.g7709474-15.26.4.r800.gf2b42a6-1
                              minuet22.12.0.r652.gb2ee1fb-122.12.0.r653.g1bc667c-1
                             neochat22.11.r52.gcdbf5ea8-122.11.r80.g4c9f062a-1
                              okular22.12.0.r9917.g38438b00b-122.12.0.r9927.g6e93f019a-1
                              oxygen5.26.4.r4535.g1d2d1d5e-15.26.4.r4536.gf6143515-1
                            palapeli22.12.0.r1349.g0748237-122.12.0.r1350.gd59f438-1
                              parley22.12.0.r4572.g690cda7b-122.12.0.r4573.gf632c7ef-1
                    partitionmanager22.12.0.r1705.g76bf9e0-122.12.0.r1706.gc0e531a-1
                               picmi22.12.0.r610.g136a999-122.12.0.r611.gb812303-1
                   pim-data-exporter22.12.0.r2840.g0f155ccc-122.12.0.r2843.gb5218d54-1
                    pim-sieve-editor22.12.0.r1701.g7ec512d-122.12.0.r1705.gc21e785-1
                           pimcommon22.08.3.r1841.geb2c2f10-122.08.3.r1861.g2e7647d5-1
                        plank-player5.26.0.r107.g28f0581-15.26.0.r116.g755939f-1
                    plasma-bigscreen5.26.0.r590.g63c6f89-15.26.0.r601.g6eb288b-1
          plasma-browser-integration5.26.4.r1402.g7d6e0d80-15.26.4.r1406.g45b092df-1
                       plasma-camera  1.0.r145.g873e33c-1  1.0.r146.gb88157c-1
                      plasma-desktop5.26.4.r9936.g97b0957c0-15.26.4.r9965.g6323f662d-1
                       plasma-dialer 22.11.r18.gc7b9512-1 22.11.r28.gf7f9db1-1
                        plasma-disks5.26.4.r316.ge943051-15.26.4.r318.g656834e-1
                     plasma-firewall5.26.4.r697.gffac520-15.26.4.r699.g9caaf78-1
                    plasma-framework5.101.0.r16569.gdd61557a2-15.101.0.r16571.gcf86a9df7-1
                  plasma-integration5.26.4.r614.g62e323b-15.26.4.r617.g0b93c2e-1
                       plasma-mobile5.26.4.r2100.ge38df038c-15.26.4.r2112.g119e750d9-1
                    plasma-mobile-nm5.26.4.r3479.g4654501e-15.26.4.r3490.g97462c6b-1
                         plasma-nano5.26.4.r213.g184864d-15.26.4.r215.gaa3e099-1
                           plasma-nm5.26.4.r3479.g4654501e-15.26.4.r3490.g97462c6b-1
                           plasma-pa5.26.4.r1156.gd02243f-15.26.4.r1160.gf4383f8-1
                    plasma-phonebook 22.11.r11.g374ba0e-1 22.11.r12.g6298c91-1
            plasma-remotecontrollers5.26.0.r206.g2faf02f-15.26.0.r207.g3271cec-1
                          plasma-sdk5.26.4.r2454.g482ff1fe-15.26.4.r2455.gd34c2b83-1
                     plasma-settings 22.11.r11.gd81b4f2-1 22.11.r13.g9307c0b-1
                plasma-systemmonitor5.26.4.r665.ga2bebfa-15.26.4.r669.g63a8dbb-1
                  plasma-thunderbolt5.26.4.r212.g4e31b17-15.26.4.r214.ga968818-1
                        plasma-vault5.26.4.r412.gb177181-15.26.4.r415.g2e12640-1
              plasma-wayland-session5.26.4.r13028.geb2428ffc-15.26.4.r13047.g168d1eb45-1
                    plasma-workspace5.26.4.r13028.geb2428ffc-15.26.4.r13047.g168d1eb45-1
         plasma-workspace-wallpapers5.26.4.r401.g0bb54a1-15.26.4.r402.gbca35f1-1
                          plasmatube 22.11.r24.g37dd9f3-1 22.11.r30.g5bd65d2-1
                    polkit-kde-agent5.26.4.r550.gd5b5cbf-15.26.4.r552.gf87f69b-1
                          powerdevil5.26.4.r2653.g7128c087-15.26.4.r2657.ga002ab47-1
                       print-manager22.12.0.r1215.gc5a4ddf-122.12.0.r1218.g6b19614-1
                             purpose5.101.0.r1045.g1ce2b97-15.101.0.r1048.g745cf08-1
                         qcachegrind22.12.0.r1222.g7fd89e1-122.12.0.r1223.gdc25eb3-1
                          qmlkonsole 22.11.r12.g3682f46-1 22.11.r25.g8051547-1
                                rocs22.12.0.r3156.g0ed95000-122.12.0.r3157.gdc1bff71-1
                            sddm-kcm5.26.4.r708.g71a0175-15.26.4.r710.gade4afc-1
            signon-kwallet-extension22.12.0.r83.ga3e7eac-122.12.0.r84.g98ae2e2-1
                               solid5.101.0.r836.g37f697f-15.101.0.r837.g44421b2-1
                              sonnet5.101.0.r743.g04b5ff7-15.101.0.r744.g04d99c3-1
                            spacebar 22.11.r13.ge80a227-1 22.11.r22.g61ddec9-1
                           spectacle22.12.0.r1458.ge576fd8-122.12.0.r1461.gf357420-1
                                step22.12.0.r1283.gda14d24-122.12.0.r1284.g227e6bf-1
                             svgpart22.12.0.r260.gc11d2f6-122.12.0.r261.g9517d84-1
                             sweeper22.12.0.r611.g51ca057-122.12.0.r612.gecb6448-1
                 syntax-highlighting5.101.0.r2052.g10fe5c3b-15.101.0.r2055.ga9ebf4be-1
                      systemsettings5.26.4.r2788.gcddeecd9-15.26.4.r2794.g247343c0-1
          telepathy-kde-accounts-kcm22.12.0.r1237.g2d15da5-122.12.0.r1238.g94ca9d8-1
              telepathy-kde-approver22.12.0.r318.ge894903-122.12.0.r319.g7bc29cc-1
          telepathy-kde-auth-handler22.12.0.r299.geb5d165-122.12.0.r300.g30a7703-1
               telepathy-kde-call-ui22.12.0.r465.g3de3665-122.12.0.r466.gdce9c76-1
      telepathy-kde-common-internals22.12.0.r2039.ga57e7bd-122.12.0.r2044.g786ca0d-1
          telepathy-kde-contact-list22.12.0.r1112.gd99e30d-122.12.0.r1113.g8e0856f-1
        telepathy-kde-contact-runner22.12.0.r279.g508c050-122.12.0.r280.g0e398be-1
       telepathy-kde-desktop-applets22.12.0.r1020.g2acdfb1-122.12.0.r1021.gd8ceb5e-1
  telepathy-kde-filetransfer-handler22.12.0.r241.g793bde1-122.12.0.r242.gd8794cf-1
    telepathy-kde-integration-module22.12.0.r419.g2361e9e-122.12.0.r420.ge875723-1
             telepathy-kde-send-file22.12.0.r250.g36a11a1-122.12.0.r251.gf58b27e-1
               telepathy-kde-text-ui22.12.0.r2076.g34addf43-122.12.0.r2078.g9aba0159-1
                             tokodon22.11.2.r26.gad34600-122.11.2.r81.g8dea9e4-1
                         vakzination  22.11.r7.ga1c54f4-1  22.11.r8.g600e430-1
                               vvave 2.2.1.r16.g360ca19-1 2.2.1.r37.g9167db9-1
              xdg-desktop-portal-kde5.26.4.r589.g8f2ab1d-15.26.4.r592.g0657878-1
                             yakuake22.12.0.r894.g24dc69a-122.12.0.r895.g441aa7e-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
2022-11-20
OpenSSL 1.1 library not found
Some applications might still be looking for openssl 1.1.
Solution: Install openssl-1.1 package with sudo pacman -S openssl-1.1.
2022-10-31
Firefox shows wrong colors when playing video on Raspberry Pi 4
Since Mesa 22.2, Firefox has been showing weird colors when playing video on the Raspberry Pi 4. This is caused by an issue in upstream mesa, which was recently fixed.
Fix: Update to mesa 22.2.3-0.1 in the repository, which includes this fix.
Chromium in Wayland crashes with --in-process-gpu
Since Mesa 22.2.0, Chromium running in wayland sessions seems to crash when running with the --in-process-gpu option. Running in X11 seems fine, although it’s slow.
Fix: Update to Mesa 22.3.2 was reported to work here.
2022-10-21
Plasma Mobile Dialer seems to be unreliable
Plasma Dialer 22.09 seems to have issues switching audio profiles and as such might require manual switching. Sometimes audio is completely missing.
Reduced video performance on youtube
Some may encounter reduced video playback performance on YouTube in Firefox with the new Mesa 22.2 drivers.
No workaround at this time.
Old Issues
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
[Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
mesa build ahead of Alarm, so can we have this patches for sway in next build?
Is sway broken without this on the raspberry pi?
If it is, maybe ALARM should patch it in too?
It’s not even merged yet. And it has a comment saying it should wait, so I think we should wait for it to get merged.
for wlroots/sway, WLR_RENDERER=vulkan.
the patches was 6 months ago, they forgot, maybe.
Maybe you should poke them on the MR in that case, if it does fix something broken.
But, if it’s just fixing a specific use case (like wlroots with vulken on raspberry pi only) then it might not be enough for them to hurry it.
Bonne et heureuse année 2023.
happy new year, I wish you all the best :slight_smile:
All arm devices are up to date, kernel 6.1.2 installed, what a reactivity for the kernel up date !
Congratulation.
Unfortunately the new mobile-config-firefox does not seem to fix the problem of no touch input being registered on webpages in firefox 108. At least not on pinephone. 107.1 works.
@Strit and @spikerguy,
GT King Pro Manjaro-Arm-Gnome up to date on Arm-Testing-2022-12-31.
Would like to point out there is an issue with kernel-linux-6.1.2-1.
When you Power Up GT King Pro without ethernet cable, WIFI will be lost withing 1 minute of boot up to desktop environment. “Gnome Settings” will report NO WIFI or Network. Inserting Ethernet cable after power will NOT make ethernet or Network Available. Message:
Oops, something has gone wrong. Please contact your software vendor.
NetworkManager needs to be running.
sudo systemctl start NetworkManager --now
Will NOT start NetworkManager. Reboot will just hang at “Manjaro Logo”. Need to Power Cycle to Reboot.
If you boot up with Ethernet Cable connected to GT King Pro during Power Up to boot, Ethernet is available but when you ideal for a while and Screen Lock kicks in on wake up from Screen Lock, Ethernet can be loss and cannot be regain unless Power Cycle to restart with Ethernet Cable connected.
For your info, kernel linux-6.0.y, linux-odroid-6.0.11-1 or linux-aml-6.0.13-1 all NO issues. Prior to switching to linux-aml, i have been using linux-6.0.y before which works well on GT King Pro.
Wishing Manjaro-Arm Team A Happy New Year!
Happy New Year!
I’m using both Bluetooth BLE and WiFi on a Raspi 4. With the new version of the firmware-raspberrypi package BLE is more reliable than before but stops working as soon as WiFi is used (hostapd started).
The error is org.bluez.Error.Failed,le-connection-abort-by-local and can be well reproduced.
Downgrading to 7.1-1 fixes it, both BLE and WiFi work pretty well. Except the Bluetooth adapter is not always found on reboot, which is probably a known issue fixed in the current version.
Hello, happy new year 2023 to everyone, and above all a year full of updates!! :tada: :confetti_ball: :fireworks:
I also encounter a problem with the kernel-linux-6.1.2-1, under kde after a short time, internet hangs and plasma freezes completely.
We have similar device (S922X) and I face the same issue with linux-6.1.2-1 on Gnome where the WIFI is available for only around a minute after boot up and then disappear and plugin Ethernet cable after boot up will NOT regain Ethernet connection. Shutdown or Reboot will just stuck at Manjaro Logo spinning.
geeqie (picture viewer from repository) does not work anymore, due to an update of libraw (0.20.2-3 → 0.21.0-2) introduced in Testing update from 22-12-24.
Downgrading libraw restores functionality.
Hi @Strit and @spikerguy,
For your info, I just tested kernel linux-6.1.4-3 from Unstable Repo, it still have the same issue of WIFI will disappeared/loss in a minute or so. Shutdown and Reboot will stuck at Manjaro Logo just like kernel linux-6.1.2-1 reported earlier.
Hello, could you tell me if it’s possible to specifically download the latest version of Linux 6.0.y (I don’t know which one it is) via pacman ?
cordially
