[ARM Testing Update] 2022-12-16 - XFCE, Firefox, KDE Gear, Mesa, Thunderbird and kernels
Hello ARM community.
Big update for XFCE and updates to lots of system stuff like mesa, kernels and systemd.
XFCE got a major update to 4.18
Some highlights:
  • Most of our kernels got updated to 6.1
  • Thunderbird updated to 102.6.0
  • XFCE updated to 4.18.0
  • Pipewire updated to 0.3.63
  • KDE Gear applications updated to 22.12.0
  • KDE Frameworks updated to 5.101
  • Firefox updated to 108.0
  • Mesa updated to 22.3.1
  • SystemD updated to 252.3
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Fri Dec 16 16:10:06 CET 2022)
  • arm-testing community aarch64: 309 new and 327 removed package(s)
  • arm-testing core aarch64: 46 new and 43 removed package(s)
  • arm-testing extra aarch64: 665 new and 666 removed package(s)
  • arm-testing kde-unstable aarch64: 396 new and 397 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2022-12-05         2022-12-16
                           bitwarden          2022.11.0-1          2022.12.0-1
                          callaudiod   0.1.4+9+g7f2c637-2              0.1.6-1
                             cor-git 0.1.21.r0.g9b06f7b-1                    -
                     libhybris-glvnd       1569.03c5ec6-1       1583.21faf7a-1
                             libuser               0.63-1                    -
                         lxc-android                0.1-7               11.0-1
                                m1n1              1.2.2-1              1.2.3-1
mapplauncherd-booster-qtcomponents-git  0.2.0.r2.g22a307e-1                    -
                   mapplauncherd-git  4.2.3.r0.g3f37ded-1                    -
                mapplauncherd-qt-git 1.1.17.r0.g944f07e-1                    -
                  meego-resource-git 0.24.1.r0.g7d2e812-1                    -
                          megapixels              1.5.2-1              1.6.0-1
                      megapixels-ppp              1.5.2-5                    -
             mesa-apple-silicon-edge 23.0.0_pre20221205-1 23.0.0_pre20221214-1
   nemo-qml-plugin-contentaction-git  0.4.1.r0.g4c870ce-1                    -
 nemo-qml-plugin-sortfiltermodel-git         r1.da3ed1d-1                    -
       pico-wizard-bigscreen-scripts 0.1.0.r178.5462eaa-1 0.1.0.r181.3557ff3-1
                     pico-wizard-git 0.1.0.r178.5462eaa-1 0.1.0.r181.3557ff3-1
           pico-wizard-plamo-scripts 0.1.0.r178.5462eaa-1 0.1.0.r181.3557ff3-1
                   python-ytmusicapi             0.22.0-1             0.24.0-1
                      qt5-around-git 0.2.11.r0.g41126fa-1                    -
                     qt5-connman-git   20210114.f5b49d8-1                    -
                      qt5-iodata-git0.19.11+git1.r0.g9c9c84b-1                    -
                     qt5-mlocale-git 0.7.4.r0.gfcb7a926-1                    -
                       qt5-mpris-git  1.0.6.r0.gade1b9a-1                    -
                        qt5-ngfd-git  0.7.0.r0.gac87734-1                    -
       qt5-ofono-nemo-extensions-git 1.0.27.r0.gebe45e0-4                    -
                     qt5-profile-git 0.35.5.r0.gd10d69c-1                    -
                    qt5-resource-git 1.30.6.r0.g22c940c-1                    -
                       qt5-timed-git 3.6.13.r0.g19cbb69-1                    -
                   qt5-usb-moded-git    1.9.r0.g0544b73-1                    -
         sailfish-access-control-git  0.0.5.r0.gf858fed-1                    -
          sailfish-user-managerd-git  0.5.5.r0.g71f211f-1                    -
                      signal-desktop             5.63.0-1              6.0.1-1
                     ssu-sysinfo-git  1.3.0.r0.g17ee5f5-1                    -
                             tut-git  0.0.5.r0.ge9ee8f0-1                    -
    vulkan-swrast-apple-silicon-edge 23.0.0_pre20221205-1 23.0.0_pre20221214-1
                            waydroid              1.3.3-1              1.3.4-1
                      waydroid-image      18.1_20221111-1      18.1_20221210-1
       pico-wizard-bigscreen-configs                    -         r7.a3393d7-5
:: Different sync package(s) in repository community aarch64
                       android-tools             33.0.3-2             33.0.3-3
                        ansible-lint              6.9.1-2             6.10.0-2
                           apptainer              1.1.3-1              1.1.4-1
                   archlinux-contrib           20210710-2           20221211-1
                              ardour                7.1-1                7.2-1
                              augeas             1.13.0-1             1.14.0-1
                          aws-cli-v2              2.8.5-1              2.9.6-1
                              awxkit            21.10.0-1            21.10.1-1
                          babeltrace              1.5.8-1             1.5.11-1
                               bacon              2.2.5-1              2.2.7-1
                bash-language-server              4.0.1-1              4.1.2-1
                             bchoppr             1.12.2-1             1.12.6-1
                         bitcoin-cli               24.0-1               24.0-2
                      bitcoin-daemon               24.0-1               24.0-2
                          bitcoin-qt               24.0-1               24.0-2
                          bitcoin-tx               24.0-1               24.0-2
                               broot             1.16.2-1             1.17.1-1
                       capnet-assist              2.4.2-2              2.4.3-1
                          cargo-fuzz             0.11.0-1             0.11.1-1
                      cargo-generate             0.17.3-1             0.17.4-1
                       cargo-nextest             0.9.45-1             0.9.47-1
                 certbot-dns-hetzner              1.0.5-5              2.0.0-1
                          cherrytree            0.99.52-1            0.99.53-1
                          containerd             1.6.10-1             1.6.12-1
                                 dcd           1:0.13.6-2           1:0.15.0-1
                               dcraw             9.28.0-3             9.28.0-4
                               devil              1.8.0-6              1.8.0-7
                      docker-compose             2.13.0-1             2.14.0-1
                               doctl             1.88.0-1             1.90.0-1
                              dqlite             1.12.0-1             1.13.0-1
                              dsniff             2.4b1-31             2.4b1-32
                             dua-cli             2.18.0-1             2.18.1-1
                       feeluown-kuwo              0.1.6-1              0.1.6-2
                      feeluown-local                0.3-1                0.3-2
                    feeluown-qqmusic              0.4.1-1              0.4.1-2
                           filezilla             3.62.2-1             3.62.2-2
                    firefox-noscript            11.4.11-1            11.4.13-1
                              fluidd             1.21.1-1             1.22.1-1
                         gimp-nufraw             0.43.3-5             0.43.3-6
                             git-lfs              3.2.0-1              3.3.0-1
                              global              6.6.8-2              6.6.9-1
                            gnucobol              3.1.2-1              3.1.2-2
                            go-tools            4:0.3.0-1            4:0.4.0-1
                              gopass            1.14.11-1             1.15.0-1
                               gpgit            1:1.5.0-1            1:1.5.0-2
                               gping              1.5.1-1              1.6.1-1
                               gsoap            2.8.123-2            2.8.124-1
                                gxkb              0.9.3-2              0.9.4-1
                      home-assistant        1:2022.11.5-1        1:2022.12.3-1
                                 inn              2.7.0-3              2.7.0-4
                               isync              1.4.4-3              1.4.4-4
                             jenkins              2.381-1              2.382-1
                             jnettop             0.13.0-7             0.13.0-9
                               khard             0.17.0-7             0.18.0-1
                               kicad              6.0.9-2              6.0.9-3
                               lapce              0.2.0-1              0.2.5-1
                        libfilezilla           1:0.39.2-1           1:0.40.0-1
                             libicns              0.8.1-9             0.8.1-10
                            libmupdf             1.21.0-1             1.21.1-1
                  libretro-core-info             1.13.0-1             1.14.0-1
                       libsemigroups              2.4.1-1              2.5.0-1
                       libtraceevent            1:1.6.3-1            1:1.7.0-1
                  libtraceevent-docs            1:1.6.3-1            1:1.7.0-1
                          libtracefs              1.6.1-1              1.6.3-1
                     libtracefs-docs              1.6.1-1              1.6.3-1
                         libunibreak                5.0-2                5.1-1
                              libxdp              1.2.8-2              1.2.9-1
                              logcli              2.7.0-1              2.7.1-1
                                loki              2.7.0-1              2.7.1-1
                         loki-canary              2.7.0-1              2.7.1-1
                                 lxd                5.8-1                5.9-1
                              marked              4.2.3-1              4.2.4-1
                             maturin             0.14.5-1             0.14.6-1
                               mcfly              0.6.1-1              0.7.0-1
                              mdbook             0.4.22-1             0.4.24-1
                              memray              1.4.1-1              1.5.0-1
                               mimir              2.4.0-1              2.5.0-1
                            miniflux             2.0.40-1             2.0.41-1
                              mopidy              3.4.0-1              3.4.1-1
                              muffin              5.6.1-1              5.6.2-1
                            mupdf-gl             1.21.0-1             1.21.1-1
                         mupdf-tools             1.21.0-1             1.21.1-1
                           musescore              3.6.2-7                4.0-1
                               mympd             10.1.5-1             10.1.6-1
                                nemo              5.6.0-1              5.6.1-1
                             neomutt           20220429-1           20220429-3
                             nerdctl              1.0.0-1              1.1.0-1
             nextcloud-app-bookmarks           1:11.0.4-1           1:12.0.0-1
              nextcloud-app-calendar            1:4.1.0-1            1:4.1.1-1
              nextcloud-app-contacts              5.0.1-1              5.0.2-1
                  nextcloud-app-mail              2.2.0-1              2.2.1-1
                  nextcloud-app-news             19.0.1-1             20.0.0-1
                      nginx-mainline             1.23.2-3             1.23.3-1
                  nginx-mainline-src             1.23.2-3             1.23.3-1
                              nuitka              1.2.1-1              1.2.6-1
                             nushell             0.72.1-1             0.72.1-2
                          onionshare                2.5-2                2.6-1
                              opencc              1.1.4-1              1.1.5-1
                          opencc-doc              1.1.4-1              1.1.5-1
                            opendkim         2.11.0beta-4         2.11.0beta-5
                         openimageio            2.4.6.0-1            2.4.6.1-1
                              opensc             0.22.0-2             0.23.0-1
                      openscenegraph             3.6.5-15             3.6.5-16
                          opensearch              2.4.0-1              2.4.1-1
          opensearch-alerting-plugin            2.4.0.0-1            2.4.1.0-1
      opensearch-analysis-icu-plugin              2.4.0-1              2.4.1-1
 opensearch-analysis-kuromoji-plugin              2.4.0-1              2.4.1-1
     opensearch-analysis-nori-plugin              2.4.0-1              2.4.1-1
 opensearch-analysis-phonetic-plugin              2.4.0-1              2.4.1-1
  opensearch-analysis-smartcn-plugin              2.4.0-1              2.4.1-1
  opensearch-analysis-stempel-plugin              2.4.0-1              2.4.1-1
opensearch-analysis-ukrainian-plugin              2.4.0-1              2.4.1-1
 opensearch-anomaly-detection-plugin            2.4.0.0-1            2.4.1.0-1
opensearch-asynchronous-search-plugin            2.4.0.0-1            2.4.1.0-1
opensearch-cross-cluster-replication-plugin            2.4.0.0-1            2.4.1.0-1
               opensearch-dashboards              2.4.0-1              2.4.1-1
opensearch-dashboards-alerting-plugin            2.4.0.0-1            2.4.1.0-1
opensearch-dashboards-anomaly-detection-plugin            2.4.0.0-1            2.4.1.0-1
opensearch-dashboards-gantt-chart-plugin            2.4.0.0-1            2.4.1.0-2
opensearch-dashboards-index-management-plugin            2.4.0.0-1            2.4.1.0-1
opensearch-dashboards-notifications-plugin            2.4.0.0-1            2.4.1.0-1
opensearch-dashboards-observability-plugin            2.4.0.0-1            2.4.1.0-1
opensearch-dashboards-query-workbench-plugin            2.4.0.0-1            2.4.1.0-1
opensearch-dashboards-reports-plugin            2.4.0.0-1            2.4.1.0-1
opensearch-dashboards-security-plugin            2.4.0.0-1            2.4.1.0-1
opensearch-discovery-azure-classic-plugin              2.4.0-1              2.4.1-1
     opensearch-discovery-ec2-plugin              2.4.0-1              2.4.1-1
     opensearch-discovery-gce-plugin              2.4.0-1              2.4.1-1
        opensearch-geospatial-plugin            2.4.0.0-1            2.4.1.0-1
  opensearch-index-management-plugin            2.4.0.0-1            2.4.1.0-1
 opensearch-ingest-attachment-plugin              2.4.0-1              2.4.1-1
     opensearch-job-scheduler-plugin            2.4.0.0-1            2.4.1.0-1
               opensearch-knn-plugin            2.4.0.0-1            2.4.1.0-1
opensearch-mapper-annotated-text-plugin              2.4.0-1              2.4.1-1
    opensearch-mapper-murmur3-plugin              2.4.0-1              2.4.1-1
       opensearch-mapper-size-plugin              2.4.0-1              2.4.1-1
     opensearch-neural-search-plugin            2.4.0.0-1            2.4.1.0-1
     opensearch-notifications-plugin            2.4.0.0-1            2.4.1.0-1
     opensearch-observability-plugin            2.4.0.0-1            2.4.1.0-1
opensearch-performance-analyzer-plugin            2.4.0.0-1            2.4.1.0-1
 opensearch-reports-scheduler-plugin            2.4.0.0-1            2.4.1.0-1
  opensearch-repository-azure-plugin              2.4.0-1              2.4.1-1
    opensearch-repository-gcs-plugin              2.4.0-1              2.4.1-1
   opensearch-repository-hdfs-plugin              2.4.0-1              2.4.1-1
     opensearch-repository-s3-plugin              2.4.0-1              2.4.1-1
          opensearch-security-plugin            2.4.0.0-1            2.4.1.0-1
               opensearch-sql-plugin            2.4.0.0-1            2.4.1.0-1
         opensearch-store-smb-plugin              2.4.0-1              2.4.1-1
     opensearch-transport-nio-plugin              2.4.0-1              2.4.1-1
                         openvswitch              3.0.1-2              3.0.2-1
                       otter-browser             1.0.03-2                    -
                 pantheon-calculator              2.0.0-1              2.0.1-1
           pantheon-default-settings              7.0.0-1              7.0.1-1
                      pantheon-music              7.0.0-1              7.0.1-1
                     pantheon-videos              2.8.4-1              2.9.0-1
                                  pd             0.53.0-1             0.53.1-1
                               pdftk              3.3.3-1              3.3.3-2
             perl-cpan-perl-releases         5.20221020-1         5.20221120-1
                         perl-curses               1.41-1               1.43-1
                 perl-list-someutils               0.58-1               0.59-1
                        perl-log-any              1.711-1              1.712-1
                      perl-path-tiny              0.142-1              0.144-1
                           php-geoip              1.1.1-7              1.1.1-8
                        php-memcache                8.0-2                8.0-3
                          php7-geoip              1.1.1-7              1.1.1-8
                       php7-memcache                8.0-2                8.0-3
                          phppgadmin             7.13.0-2             7.13.0-3
                       piping-server             0.14.1-1             0.15.0-1
                         pmbootstrap             1.50.0-1             1.50.1-1
                            polymake                4.7-1                4.7-2
                   powerdns-recursor              4.7.4-1              4.8.0-1
                            promtail              2.7.0-1              2.7.1-1
                             prosody           1:0.12.1-2           1:0.12.2-1
                               psalm             4.30.0-1              5.2.0-1
                           pt2-clone               1.54-1               1.55-1
                               pueue              2.1.0-1              3.0.0-1
                             pyright            1.1.283-1            1.1.284-1
                     python-argparse             1.4.0-12             1.4.0-13
           python-aws-sam-translator             1.54.0-1             1.55.0-1
                        python-black            22.10.0-1            22.12.0-1
                        python-bsddb              6.2.9-3              6.2.9-4
                     python-cfn-lint             0.72.0-1             0.72.2-1
                    python-dbus-fast             1.14.0-1             1.82.0-1
                   python-diff-cover              7.2.0-1              7.3.0-1
               python-discogs-client                2.5-1                2.6-1
                        python-faker             13.2.0-1             13.3.1-1
                         python-fire              0.4.0-3              0.5.0-1
                        python-gdstk              0.9.6-1              0.9.7-1
                  python-google-auth             2.14.0-1             2.14.1-1
                     python-graphene              3.1.1-1              3.2.1-1
        python-hatch-jupyter-builder              0.8.1-1              0.8.2-1
                    python-hatch-vcs              0.2.1-1              0.3.0-1
                   python-ipywidgets              8.0.3-1              8.0.3-2
                  python-lark-parser              1.1.4-1              1.1.5-1
                         python-ldap              3.4.3-1              3.4.3-2
                      python-libtmux            0.15.10-1             0.16.1-1
                    python-multidict              6.0.3-1              6.0.3-2
                     python-pathspec             0.10.2-1             0.10.3-1
                      python-pikepdf              6.2.5-1              6.2.6-1
                       python-pipenv         2022.11.30-1         2022.11.30-2
                       python-poetry              1.2.2-2              1.3.1-1
               python-prompt_toolkit             3.0.33-1             3.0.36-1
                      python-pycares              4.2.2-1              4.3.0-1
                     python-pyflakes              3.0.1-1              3.0.1-2
                       python-pygame              2.1.2-2              2.1.2-3
                      python-pymupdf             1.21.0-1             1.21.1-1
                     python-pynamodb              5.3.2-1              5.3.4-1
                     python-pyroute2             0.6.13-1              0.7.3-1
                        python-pywal              3.3.0-5              3.3.0-7
                        python-quart             0.18.0-1             0.18.3-1
                    python-rapidfuzz             2.13.3-1             2.13.5-1
                    python-reportlab             3.6.12-1             3.6.12-2
                    python-softlayer              6.1.2-2              6.1.3-1
                      python-srcinfo              0.0.8-7              0.1.1-1
                    python-starlette             0.23.0-1             0.23.1-1
                   python-tldextract              3.4.0-1              3.4.0-2
                    python-traitlets              5.7.0-1              5.7.1-1
         python-voluptuous-serialize              2.5.0-2              2.5.0-3
                        python-w3lib              2.1.0-1              2.1.1-1
                         python-xlib               0.31-3               0.31-4
                   python-zabbix-api              0.5.4-3              0.5.5-1
              python-zope-testrunner              5.5.1-1                5.6-1
                              rclone             1.60.1-1             1.60.1-2
                               redis              7.0.5-3              7.0.6-1
                                repo               2.30-1               2.31-1
                            reprepro              5.4.1-1              5.4.1-3
                           retroarch             1.13.0-2             1.14.0-1
                     ruby-async-http             0.59.3-1             0.59.4-1
                         ruby-rbtree              0.4.5-2              0.4.6-1
                      ruby-test-unit              3.5.5-1              3.5.7-1
                       rust-analyzer           20221205-1           20221212-1
                         rust-script             0.21.0-1             0.22.0-1
                               sbctl                0.9-1               0.10-1
                        scaleway-cli              2.6.2-1              2.7.0-1
                             sccache              0.3.0-2              0.3.3-1
                             schroot            1.6.10-32             1.6.13-1
                            sh4d0wup              0.2.0-1              0.4.0-1
                                sile             0.14.5-1             0.14.6-1
                            singular           4.3.1.p2-3           4.3.1.p3-1
                            skktools              1.3.4-3              1.3.4-4
                               smb4k              3.1.5-1              3.1.6-1
                            spotifyd              0.3.3-2              0.3.4-1
                            sqlfluff              1.4.2-1              1.4.4-1
                            starship             1.11.0-1             1.12.0-1
                          swi-prolog              9.0.0-1              9.0.0-3
                           tailscale             1.32.3-1             1.34.1-1
                                tcsh            6.24.05-1            6.24.06-1
                               tilix              1.9.5-3              1.9.5-4
                          timidity++             2.15.0-7             2.15.0-9
                               tmuxp             1.18.2-1             1.19.1-1
                                 tor           0.4.7.11-1           0.4.7.12-1
                           trace-cmd              3.1.4-1              3.1.5-1
                         ttc-iosevka             16.6.0-1             16.7.0-1
                    ttc-iosevka-aile             16.6.0-1             16.7.0-1
                   ttc-iosevka-curly             16.6.0-1             16.7.0-1
              ttc-iosevka-curly-slab             16.6.0-1             16.7.0-1
                  ttc-iosevka-etoile             16.6.0-1             16.7.0-1
                    ttc-iosevka-slab             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss01             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss02             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss03             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss04             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss05             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss06             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss07             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss08             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss09             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss10             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss11             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss12             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss13             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss14             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss15             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss16             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss17             16.6.0-1             16.7.0-1
                    ttc-iosevka-ss18             16.6.0-1             16.7.0-1
                   ttf-sarasa-gothic             0.37.4-1             0.38.0-1
                          typescript              4.9.3-1              4.9.4-1
          typescript-language-server              2.1.0-1              2.2.0-1
         v2ray-domain-list-community     20221207075621-1     20221212022004-1
                     vaultwarden-web          2022.11.1-1          2022.11.2-1
                            web-news              1.6.4-9             1.6.4-10
                           xdp-tools              1.2.8-2              1.2.9-1
                                 yad               12.1-1               12.2-1
                              zellij             0.34.3-1             0.34.4-1
                         zigbee2mqtt             1.28.2-2             1.28.4-1
                             ziproxy              3.3.2-3              3.3.2-4
                         cameractrls                    -             0.4.12-2
                               crane                    -             0.12.1-1
                            gitoxide                    -             0.19.0-2
              neovim-nvim-treesitter                    -              0.8.1-1
                         osv-scanner                    -              1.0.0-1
                                ruff                    -            0.0.182-1
:: Different overlay package(s) in repository core aarch64
                               linux             6.0.12-1              6.1.0-1
                           linux-aml             6.0.11-1             6.0.12-1
                   linux-aml-headers             6.0.11-1             6.0.12-1
                 linux-apple-silicon             6.1rc8-1                6.1-1
            linux-apple-silicon-edge             6.1rc8-1                6.1-1
         linux-apple-silicon-headers             6.1rc8-1                6.1-1
                       linux-headers             6.0.12-1              6.1.0-1
                           linux-lts            5.15.82-1            5.15.83-1
                   linux-lts-headers            5.15.82-1            5.15.83-1
                        linux-odroid              6.0.9-1             6.0.11-1
                linux-odroid-headers              6.0.9-1             6.0.11-1
                           linux-opi             6.0.11-1             6.0.12-1
                   linux-opi-headers             6.0.11-1             6.0.12-1
                     linux-pinephone           6.1.0rc8-1              6.1.0-2
             linux-pinephone-headers           6.1.0rc8-1              6.1.0-2
                  linux-pinephonepro           6.1.0rc8-2              6.1.0-1
          linux-pinephonepro-headers           6.1.0rc8-2              6.1.0-1
                          linux-rpi4            5.15.82-1            5.15.83-1
                  linux-rpi4-headers            5.15.82-1            5.15.83-1
                 linux-rpi4-mainline             6.0.12-1             6.0.13-1
         linux-rpi4-mainline-headers             6.0.12-1             6.0.13-1
                            linux515            5.15.82-1            5.15.83-1
                    linux515-headers            5.15.82-1            5.15.83-1
                             linux60             6.0.12-1             6.0.13-1
                     linux60-headers             6.0.12-1             6.0.13-1
              raspberrypi-bootloader           20221206-1           20221214-1
            raspberrypi-bootloader-x           20221206-1           20221214-1
                             linux61                    -              6.1.0-1
                     linux61-headers                    -              6.1.0-1
:: Different sync package(s) in repository core aarch64
                   archlinux-keyring           20221123-1           20221213-1
             ca-certificates-mozilla               3.85-1               3.86-1
                                  db             5.3.28-5             6.2.32-1
                            iproute2              6.0.0-1              6.1.0-3
                          libarchive              3.6.1-5              3.6.2-2
                              libmpc              1.2.1-2              1.3.0-2
                           logrotate             3.20.1-1             3.21.0-2
                          mkinitcpio                 33-1                 34-2
                                nano                7.0-1                7.1-1
                                 nss               3.85-1               3.86-1
                              psmisc               23.5-1               23.6-1
                             systemd              252.2-4              252.3-1
                        systemd-libs              252.2-4              252.3-1
                  systemd-resolvconf              252.2-4              252.3-1
                  systemd-sysvcompat              252.2-4              252.3-1
                                  xz              5.2.9-1              5.4.0-1
                               db5.3                    -             5.3.28-2
:: Different overlay package(s) in repository extra aarch64
                            chromium      108.0.5359.98-2                    -
                             ckbcomp              1.208-1              1.212-1
                          elisa-qtmm            22.08.3-1            22.12.0-1
                   libva-mesa-driver           22.2.4-0.3           22.3.1-0.1
                      libwireplumber           0.4.12-2.1           0.4.13-0.1
                                mesa           22.2.4-0.3           22.3.1-0.1
                          mesa-vdpau           22.2.4-0.3           22.3.1-0.1
                              okular            22.08.3-1            22.12.0-1
                         opencl-mesa           22.2.4-0.3           22.3.1-0.1
                        qt5-es2-base    5.15.7+kde+r176-1    5.15.7+kde+r177-1
                 qt5-es2-declarative     5.15.7+kde+r24-1     5.15.7+kde+r25-1
                     qt5-es2-wayland     5.15.7+kde+r55-1     5.15.7+kde+r56-1
         qt5-es2-xcb-private-headers    5.15.7+kde+r176-1    5.15.7+kde+r177-1
                     vulkan-broadcom           22.2.4-0.3           22.3.1-0.1
                  vulkan-mesa-layers           22.2.4-0.3           22.3.1-0.1
                     vulkan-panfrost           22.2.4-0.3           22.3.1-0.1
                       vulkan-radeon           22.2.4-0.3           22.3.1-0.1
                       vulkan-swrast           22.2.4-0.3           22.3.1-0.1
                    wireplumber-docs           0.4.12-2.1           0.4.13-0.1
:: Different sync package(s) in repository extra aarch64
                         389-ds-base              2.3.1-1              2.3.1-3
                             akonadi            22.08.3-1            22.12.0-1
                    akonadi-calendar            22.08.3-1            22.12.0-1
              akonadi-calendar-tools            22.08.3-1            22.12.0-1
                    akonadi-contacts            22.08.3-1            22.12.0-1
               akonadi-import-wizard            22.08.3-1            22.12.0-1
                        akonadi-mime            22.08.3-1            22.12.0-1
                       akonadi-notes            22.08.3-1            22.12.0-1
                      akonadi-search            22.08.3-1            22.12.0-1
                      akonadiconsole            22.08.3-1            22.12.0-1
                           akregator            22.08.3-1            22.12.0-1
                  alsa-card-profiles           1:0.3.61-1           1:0.3.63-1
                         amf-headers             1.4.26-1             1.4.28-1
                            analitza            22.08.3-1            22.12.0-1
                            apr-util             1.6.1-10             1.6.1-11
            archlinux-appstream-data           20221014-1           20221210-1
                                 ark            22.08.3-1            22.12.0-1
                          artikulate            22.08.3-1            22.12.0-1
                              attica            5.100.0-1            5.101.0-1
                         audiocd-kio            22.08.3-1            22.12.0-1
                               baloo            5.100.0-1            5.101.0-1
                       baloo-widgets            22.08.3-1            22.12.0-1
                                bird             2.0.10-1             2.0.11-1
                             blinken            22.08.3-1            22.12.0-1
                            bluez-qt            5.100.0-1            5.101.0-1
                              bomber            22.08.3-1            22.12.0-1
                                bovo            22.08.3-1            22.12.0-1
                        breeze-icons            5.100.0-1            5.101.0-1
                     calendarsupport            22.08.3-1            22.12.0-1
                              cantor            22.08.3-1            22.12.0-1
                            cervisia            22.08.3-1            22.12.0-1
                              cheese43alpha+r8+g1de47dbc-1               43.0-1
                            chromium     107.0.5304.121-1     108.0.5359.124-1
                          colord-kde              0.5.0-3            22.12.0-1
                            composer              2.4.4-1              2.4.4-3
                             digikam              7.9.0-1              7.9.0-2
                                dkms              3.0.8-1              3.0.9-1
                             dolphin            22.08.3-1            22.12.0-1
                     dolphin-plugins            22.08.3-1            22.12.0-1
                              dragon            22.08.3-1            22.12.0-1
                           dump_syms              2.1.0-1              2.1.1-1
                               elisa            22.08.3-1            22.12.0-1
                         erofs-utils                1.5-2                1.5-3
                          eventviews            22.08.3-1            22.12.0-1
               evolution-data-server             3.46.2-1             3.46.2-3
                              exempi              2.6.2-1              2.6.3-1
                                 exo             4.16.4-1             4.18.0-1
                 extra-cmake-modules            5.100.0-1            5.101.0-1
                              falkon            22.08.3-2            22.12.0-1
                        ffmpegthumbs            22.08.3-1            22.12.0-1
                           filelight            22.08.3-1            22.12.0-1
                             firefox            107.0.1-1              108.0-1
                    firefox-i18n-ach            107.0.1-1              108.0-1
                     firefox-i18n-af            107.0.1-1              108.0-1
                     firefox-i18n-an            107.0.1-1              108.0-1
                     firefox-i18n-ar            107.0.1-1              108.0-1
                    firefox-i18n-ast            107.0.1-1              108.0-1
                     firefox-i18n-az            107.0.1-1              108.0-1
                     firefox-i18n-be            107.0.1-1              108.0-1
                     firefox-i18n-bg            107.0.1-1              108.0-1
                     firefox-i18n-bn            107.0.1-1              108.0-1
                     firefox-i18n-br            107.0.1-1              108.0-1
                     firefox-i18n-bs            107.0.1-1              108.0-1
                     firefox-i18n-ca            107.0.1-1              108.0-1
            firefox-i18n-ca-valencia            107.0.1-1              108.0-1
                    firefox-i18n-cak            107.0.1-1              108.0-1
                     firefox-i18n-cs            107.0.1-1              108.0-1
                     firefox-i18n-cy            107.0.1-1              108.0-1
                     firefox-i18n-da            107.0.1-1              108.0-1
                     firefox-i18n-de            107.0.1-1              108.0-1
                    firefox-i18n-dsb            107.0.1-1              108.0-1
                     firefox-i18n-el            107.0.1-1              108.0-1
                  firefox-i18n-en-ca            107.0.1-1              108.0-1
                  firefox-i18n-en-gb            107.0.1-1              108.0-1
                  firefox-i18n-en-us            107.0.1-1              108.0-1
                     firefox-i18n-eo            107.0.1-1              108.0-1
                  firefox-i18n-es-ar            107.0.1-1              108.0-1
                  firefox-i18n-es-cl            107.0.1-1              108.0-1
                  firefox-i18n-es-es            107.0.1-1              108.0-1
                  firefox-i18n-es-mx            107.0.1-1              108.0-1
                     firefox-i18n-et            107.0.1-1              108.0-1
                     firefox-i18n-eu            107.0.1-1              108.0-1
                     firefox-i18n-fa            107.0.1-1              108.0-1
                     firefox-i18n-ff            107.0.1-1              108.0-1
                     firefox-i18n-fi            107.0.1-1              108.0-1
                     firefox-i18n-fr            107.0.1-1              108.0-1
                  firefox-i18n-fy-nl            107.0.1-1              108.0-1
                  firefox-i18n-ga-ie            107.0.1-1              108.0-1
                     firefox-i18n-gd            107.0.1-1              108.0-1
                     firefox-i18n-gl            107.0.1-1              108.0-1
                     firefox-i18n-gn            107.0.1-1              108.0-1
                  firefox-i18n-gu-in            107.0.1-1              108.0-1
                     firefox-i18n-he            107.0.1-1              108.0-1
                  firefox-i18n-hi-in            107.0.1-1              108.0-1
                     firefox-i18n-hr            107.0.1-1              108.0-1
                    firefox-i18n-hsb            107.0.1-1              108.0-1
                     firefox-i18n-hu            107.0.1-1              108.0-1
                  firefox-i18n-hy-am            107.0.1-1              108.0-1
                     firefox-i18n-ia            107.0.1-1              108.0-1
                     firefox-i18n-id            107.0.1-1              108.0-1
                     firefox-i18n-is            107.0.1-1              108.0-1
                     firefox-i18n-it            107.0.1-1              108.0-1
                     firefox-i18n-ja            107.0.1-1              108.0-1
                     firefox-i18n-ka            107.0.1-1              108.0-1
                    firefox-i18n-kab            107.0.1-1              108.0-1
                     firefox-i18n-kk            107.0.1-1              108.0-1
                     firefox-i18n-km            107.0.1-1              108.0-1
                     firefox-i18n-kn            107.0.1-1              108.0-1
                     firefox-i18n-ko            107.0.1-1              108.0-1
                    firefox-i18n-lij            107.0.1-1              108.0-1
                     firefox-i18n-lt            107.0.1-1              108.0-1
                     firefox-i18n-lv            107.0.1-1              108.0-1
                     firefox-i18n-mk            107.0.1-1              108.0-1
                     firefox-i18n-mr            107.0.1-1              108.0-1
                     firefox-i18n-ms            107.0.1-1              108.0-1
                     firefox-i18n-my            107.0.1-1              108.0-1
                  firefox-i18n-nb-no            107.0.1-1              108.0-1
                  firefox-i18n-ne-np            107.0.1-1              108.0-1
                     firefox-i18n-nl            107.0.1-1              108.0-1
                  firefox-i18n-nn-no            107.0.1-1              108.0-1
                     firefox-i18n-oc            107.0.1-1              108.0-1
                  firefox-i18n-pa-in            107.0.1-1              108.0-1
                     firefox-i18n-pl            107.0.1-1              108.0-1
                  firefox-i18n-pt-br            107.0.1-1              108.0-1
                  firefox-i18n-pt-pt            107.0.1-1              108.0-1
                     firefox-i18n-rm            107.0.1-1              108.0-1
                     firefox-i18n-ro            107.0.1-1              108.0-1
                     firefox-i18n-ru            107.0.1-1              108.0-1
                    firefox-i18n-sco            107.0.1-1              108.0-1
                     firefox-i18n-si            107.0.1-1              108.0-1
                     firefox-i18n-sk            107.0.1-1              108.0-1
                     firefox-i18n-sl            107.0.1-1              108.0-1
                    firefox-i18n-son            107.0.1-1              108.0-1
                     firefox-i18n-sq            107.0.1-1              108.0-1
                     firefox-i18n-sr            107.0.1-1              108.0-1
                  firefox-i18n-sv-se            107.0.1-1              108.0-1
                    firefox-i18n-szl            107.0.1-1              108.0-1
                     firefox-i18n-ta            107.0.1-1              108.0-1
                     firefox-i18n-te            107.0.1-1              108.0-1
                     firefox-i18n-th            107.0.1-1              108.0-1
                     firefox-i18n-tl            107.0.1-1              108.0-1
                     firefox-i18n-tr            107.0.1-1              108.0-1
                    firefox-i18n-trs            107.0.1-1              108.0-1
                     firefox-i18n-uk            107.0.1-1              108.0-1
                     firefox-i18n-ur            107.0.1-1              108.0-1
                     firefox-i18n-uz            107.0.1-1              108.0-1
                     firefox-i18n-vi            107.0.1-1              108.0-1
                     firefox-i18n-xh            107.0.1-1              108.0-1
                  firefox-i18n-zh-cn            107.0.1-1              108.0-1
                  firefox-i18n-zh-tw            107.0.1-1              108.0-1
                frameworkintegration            5.100.0-1            5.101.0-1
                             freetds             1.3.15-1             1.3.16-1
                              garcon             4.16.1-1             4.18.0-1
                                gegl             0.4.40-1             0.4.40-2
                                 git             2.38.1-2             2.39.0-1
                 gnome-bluetooth-3.0               42.4-1               42.5-1
                           granatier            22.08.3-1            22.12.0-1
                     grantlee-editor            22.08.3-1            22.12.0-1
                       grantleetheme            22.08.3-1            22.12.0-1
                      graphicsmagick             1.3.38-5             1.3.38-6
                 gst-plugin-pipewire           1:0.3.61-1           1:0.3.63-1
                                gvim           9.0.0910-1           9.0.1046-1
                            gwenview            22.08.3-2            22.12.0-1
                         imagemagick           7.1.0.53-1           7.1.0.54-1
                     imagemagick-doc           7.1.0.53-1           7.1.0.54-1
                     incidenceeditor            22.08.3-1            22.12.0-1
                           itinerary            22.08.3-1            22.12.0-1
                               jack2             1.9.21-1             1.9.21-3
                          jack2-dbus             1.9.21-1             1.9.21-3
                          jack2-docs             1.9.21-1             1.9.21-3
                              jasper              3.0.6-1              4.0.0-1
                          jasper-doc              3.0.6-1              4.0.0-1
                                 juk            22.08.3-1            22.12.0-1
                                 k3b          1:22.08.3-2          1:22.12.0-1
               kaccounts-integration            22.08.3-1            22.12.0-1
                 kaccounts-providers            22.08.3-1            22.12.0-1
                         kactivities            5.100.0-1            5.101.0-1
                   kactivities-stats            5.100.0-1            5.101.0-1
                        kaddressbook            22.08.3-1            22.12.0-1
                             kajongg            22.08.3-1            22.12.0-1
                              kalarm            22.08.3-1            22.12.0-1
                            kalendar            22.08.3-1            22.12.0-1
                            kalgebra            22.08.3-1            22.12.0-1
                             kalzium            22.08.3-1            22.12.0-1
                              kamera            22.08.3-1            22.12.0-1
                              kamoso            22.08.3-1            22.12.0-1
                            kanagram            22.08.3-1            22.12.0-1
                             kapidox            5.100.0-1            5.101.0-1
                              kapman            22.08.3-1            22.12.0-1
                        kapptemplate            22.08.3-1            22.12.0-1
                            karchive            5.100.0-1            5.101.0-1
                                kate            22.08.3-1            22.12.0-1
                             katomic            22.08.3-1            22.12.0-1
                               kauth            5.100.0-1            5.101.0-1
                             kbackup            22.08.3-1            22.12.0-1
                           kblackbox            22.08.3-1            22.12.0-1
                             kblocks            22.08.3-1            22.12.0-1
                          kbookmarks            5.100.0-1            5.101.0-1
                             kbounce            22.08.3-1            22.12.0-1
                           kbreakout            22.08.3-1            22.12.0-1
                              kbruch            22.08.3-1            22.12.0-1
                         kcachegrind            22.08.3-1            22.12.0-1
                  kcachegrind-common            22.08.3-1            22.12.0-1
                               kcalc            22.08.3-1            22.12.0-1
                       kcalendarcore            5.100.0-1            5.101.0-1
                           kcalutils            22.08.3-1            22.12.0-1
                         kcharselect            22.08.3-1            22.12.0-1
                            kcmutils            5.100.0-1            5.101.0-1
                             kcodecs            5.100.0-1            5.101.0-1
                       kcolorchooser            22.08.3-1            22.12.0-1
                         kcompletion            5.100.0-1            5.101.0-1
                             kconfig            5.100.1-1            5.101.0-1
                      kconfigwidgets            5.100.0-1            5.101.0-1
                           kcontacts          1:5.100.0-1          1:5.101.0-1
                         kcoreaddons            5.100.0-1            5.101.0-1
                              kcrash            5.100.0-1            5.101.0-1
                               kcron            22.08.3-1            22.12.0-1
                                kdav          1:5.100.0-1          1:5.101.0-1
                         kdbusaddons            5.100.0-1            5.101.0-1
              kde-accessibility-meta              22.08-2              22.12-1
               kde-applications-meta              22.08-2              22.12-1
                     kde-dev-scripts            22.08.3-1            22.12.0-1
                       kde-dev-utils            22.08.3-1            22.12.0-1
                  kde-education-meta              22.08-2              22.12-1
                      kde-games-meta              22.08-2              22.12-1
                   kde-graphics-meta              22.08-2              22.12-1
                 kde-multimedia-meta              22.08-2              22.12-1
                    kde-network-meta              22.08-2              22.12-1
                        kde-pim-meta              22.08-2              22.12-1
                        kde-sdk-meta              22.08-2              22.12-1
                     kde-system-meta              22.08-2              22.12-1
                  kde-utilities-meta              22.08-2              22.12-1
                      kdebugsettings            22.08.3-1            22.12.0-1
                        kdeclarative            5.100.0-1            5.101.0-1
                          kdeconnect            22.08.3-1            22.12.0-1
                                kded            5.100.0-1            5.101.0-1
                         kdeedu-data            22.08.3-1            22.12.0-1
              kdegraphics-mobipocket            22.08.3-1            22.12.0-1
            kdegraphics-thumbnailers            22.08.3-1            22.12.0-1
                     kdelibs4support            5.100.0-1            5.101.0-1
              kdenetwork-filesharing            22.08.3-1            22.12.0-1
                            kdenlive            22.08.3-1            22.12.0-1
                       kdepim-addons            22.08.3-1            22.12.0-1
                      kdepim-runtime            22.08.3-1            22.12.0-1
                          kdesdk-kio            22.08.3-1            22.12.0-1
                 kdesdk-thumbnailers            22.08.3-1            22.12.0-1
                     kdesignerplugin            5.100.0-1            5.101.0-1
                               kdesu            5.100.0-1            5.101.0-1
                            kdevelop            22.08.3-1            22.12.0-1
                       kdevelop-meta              22.08-2              22.12-1
                        kdevelop-php            22.08.3-1            22.12.0-1
                     kdevelop-python              5.6.2-1            22.12.0-1
                                 kdf            22.08.3-1            22.12.0-1
                             kdialog            22.08.3-1            22.12.0-1
                            kdiamond            22.08.3-1            22.12.0-1
                              kdnssd            5.100.0-1            5.101.0-1
                           kdoctools            5.100.0-1            5.101.0-1
                      keditbookmarks            22.08.3-1            22.12.0-1
                          kemoticons            5.100.0-1            5.101.0-1
                       kfilemetadata            5.100.0-1            5.101.0-1
                               kfind            22.08.3-1            22.12.0-1
                             kfloppy            22.08.3-1            22.12.0-1
                         kfourinline            22.08.3-1            22.12.0-1
                          kgeography            22.08.3-1            22.12.0-1
                                kget            22.08.3-1            22.12.0-1
                        kglobalaccel            5.100.0-1            5.101.0-1
                         kgoldrunner            22.08.3-1            22.12.0-1
                                kgpg            22.08.3-1            22.12.0-1
                          kguiaddons            5.100.0-1            5.101.0-1
                            khangman            22.08.3-1            22.12.0-1
                         khelpcenter            22.08.3-1            22.12.0-1
                           kholidays          1:5.100.0-1          1:5.101.0-1
                               khtml            5.100.0-1            5.101.0-1
                               ki18n            5.100.0-1            5.101.0-1
                         kiconthemes            5.100.0-1            5.101.0-1
                 kidentitymanagement            22.08.3-1            22.12.0-1
                           kidletime            5.100.0-1            5.101.0-1
                                 kig            22.08.3-1            22.12.0-1
                                kigo            22.08.3-1            22.12.0-1
                            killbots            22.08.3-1            22.12.0-1
                       kimageformats            5.100.0-1            5.101.0-1
                     kimagemapeditor            22.08.3-1            22.12.0-1
                               kimap            22.08.3-1            22.12.0-1
                               kinit            5.100.0-1            5.101.0-1
                                 kio            5.100.0-1            5.101.0-1
                          kio-extras            22.08.3-1            22.12.0-1
                          kio-gdrive            22.08.3-1            22.12.0-1
                        kio-zeroconf            22.08.3-1            22.12.0-1
                    kirigami-gallery            22.08.3-1            22.12.0-1
                           kirigami2            5.100.0-1            5.101.0-1
                              kiriki            22.08.3-1            22.12.0-1
                         kitemmodels            5.100.0-1            5.101.0-1
                          kitemviews            5.100.0-1            5.101.0-1
                               kiten            22.08.3-1            22.12.0-1
                          kitinerary            22.08.3-3            22.12.0-1
                         kjobwidgets            5.100.0-1            5.101.0-1
                                 kjs            5.100.0-1            5.101.0-1
                        kjumpingcube            22.08.3-1            22.12.0-1
                               kldap            22.08.3-1            22.12.0-1
                           kleopatra            22.08.3-1            22.12.0-1
                            klettres            22.08.3-1            22.12.0-1
                            klickety            22.08.3-1            22.12.0-1
                              klines            22.08.3-1            22.12.0-1
                                kmag            22.08.3-1            22.12.0-1
                           kmahjongg            22.08.3-1            22.12.0-1
                               kmail            22.08.3-1            22.12.0-1
                kmail-account-wizard            22.08.3-1            22.12.0-1
                      kmailtransport            22.08.3-1            22.12.0-1
                               kmbox            22.08.3-1            22.12.0-1
                               kmime            22.08.3-1            22.12.0-1
                              kmines            22.08.3-1            22.12.0-1
                                kmix            22.08.3-1            22.12.0-1
                          kmousetool            22.08.3-1            22.12.0-1
                              kmouth            22.08.3-1            22.12.0-1
                              kmplot            22.08.3-1            22.12.0-1
                        knavalbattle            22.08.3-1            22.12.0-1
                            knetwalk            22.08.3-1            22.12.0-1
                           knewstuff            5.100.0-1            5.101.0-1
                             knights            22.08.3-1            22.12.0-1
                              knotes            22.08.3-1            22.12.0-1
                      knotifications            5.100.0-1            5.101.0-1
                       knotifyconfig            5.100.0-1            5.101.0-1
                                kolf            22.08.3-1            22.12.0-1
                           kollision            22.08.3-1            22.12.0-1
                         kolourpaint            22.08.3-1            22.12.0-1
                             kompare            22.08.3-1            22.12.0-1
                           konqueror            22.08.3-1            22.12.0-1
                            konquest            22.08.3-1            22.12.0-1
                             konsole            22.08.3-1            22.12.0-1
                             kontact            22.08.3-1            22.12.0-1
                    kontactinterface            22.08.3-1            22.12.0-1
                            kontrast            22.08.3-1            22.12.0-1
                        konversation            22.08.3-1            22.12.0-1
                       kopeninghours            22.08.3-1            22.12.0-1
                              kopete            22.08.3-3            22.12.0-1
                          korganizer            22.08.3-1            22.12.0-1
                       kosmindoormap            22.08.3-1            22.12.0-1
                            kpackage            5.100.0-1            5.101.0-1
                              kparts            5.100.0-1            5.101.0-1
                                kpat            22.08.3-1            22.12.0-1
                             kpeople            5.100.0-1            5.101.0-1
                        kpimtextedit            22.08.3-1            22.12.0-1
                             kpkpass            22.08.3-1            22.12.0-1
                           kplotting            5.100.0-1            5.101.0-1
                             kpmcore            22.08.3-1            22.12.0-1
                                kpty            5.100.0-1            5.101.0-1
                    kpublictransport            22.08.3-1            22.12.0-1
                      kqtquickcharts            22.08.3-1            22.12.0-1
                        kquickcharts            5.100.0-1            5.101.0-1
                                krdc            22.08.3-1            22.12.0-1
                            kreversi            22.08.3-1            22.12.0-1
                                krfb            22.08.3-1            22.12.0-1
                               krita              5.1.3-1              5.1.4-1
                               kross            5.100.0-1            5.101.0-1
                              kruler            22.08.3-1            22.12.0-1
                             krunner            5.100.0-1            5.101.0-1
                           ksanecore            22.08.3-1            22.12.0-1
                            kservice            5.100.0-1            5.101.0-1
                             kshisen            22.08.3-1            22.12.0-1
                               ksirk            22.08.3-1            22.12.0-1
                               ksmtp            22.08.3-1            22.12.0-1
                          ksnakeduel            22.08.3-1            22.12.0-1
                          kspaceduel            22.08.3-1            22.12.0-1
                            ksquares            22.08.3-1            22.12.0-1
                             ksudoku            22.08.3-1            22.12.0-1
                          ksystemlog            22.08.3-1            22.12.0-1
                            kteatime            22.08.3-1            22.12.0-1
                         ktexteditor            5.100.0-1            5.101.0-1
                        ktextwidgets            5.100.0-1            5.101.0-1
                              ktimer            22.08.3-1            22.12.0-1
                               ktnef            22.08.3-1            22.12.0-1
                            ktorrent            22.08.3-1            22.12.0-1
                              ktouch            22.08.3-1            22.12.0-1
                          ktuberling            22.08.3-1            22.12.0-1
                             kturtle            22.08.3-1            22.12.0-1
                             kubrick            22.08.3-1            22.12.0-1
                     kunitconversion            5.100.0-1            5.101.0-1
                             kwallet            5.100.0-1            5.101.0-1
                      kwalletmanager            22.08.3-1            22.12.0-1
                               kwave            22.08.3-1            22.12.0-1
                            kwayland            5.100.0-1            5.101.0-1
                      kwidgetsaddons            5.100.0-1            5.101.0-1
                       kwindowsystem            5.100.0-1            5.101.0-1
                           kwordquiz            22.08.3-1            22.12.0-1
                             kxmlgui            5.100.0-1            5.101.0-1
                             leafpad           0.8.18.1-9             0.8.19-2
                          libakonadi            22.08.3-1            22.12.0-1
                           libcheese43alpha+r8+g1de47dbc-1               43.0-1
                            libglvnd              1.5.0-1              1.6.0-1
                         libgravatar            22.08.3-1            22.12.0-1
                             libical             3.0.16-2             3.0.16-4
                            libkcddb            22.08.3-1            22.12.0-1
                     libkcompactdisc            22.08.3-1            22.12.0-1
                           libkdcraw            22.08.3-1            22.12.0-1
                         libkdegames            22.08.3-1            22.12.0-1
                           libkdepim            22.08.3-1            22.12.0-1
                  libkeduvocdocument            22.08.3-1            22.12.0-1
                           libkexiv2            22.08.3-1            22.12.0-1
                            libkgapi            22.08.3-1            22.12.0-1
                             libkleo            22.08.3-1            22.12.0-1
                        libkmahjongg            22.08.3-1            22.12.0-1
                     libkomparediff2            22.08.3-1            22.12.0-1
                            libksane            22.08.3-1            22.12.0-1
                           libksieve            22.08.3-1            22.12.0-1
                         libktorrent            22.08.3-1            22.12.0-1
                              libraw             0.20.2-2             0.20.2-3
                   libreoffice-fresh              7.4.3-2              7.4.3-3
               libreoffice-fresh-sdk              7.4.3-2              7.4.3-3
                            libspnav                1.0-1                1.1-1
                       libusb-compat              0.1.7-1              0.1.8-1
                          libxfce4ui             4.16.1-1             4.18.0-1
                        libxfce4util             4.16.0-1             4.18.0-1
                            lokalize            22.08.3-1            22.12.0-1
                               lskat            22.08.3-1            22.12.0-1
                          mailcommon            22.08.3-1            22.12.0-1
                        mailimporter            22.08.3-1            22.12.0-1
                            man2html              3.0.1-8              3.0.1-9
                              marble            22.08.3-1            22.12.0-1
                       marble-common            22.08.3-1            22.12.0-1
                         marble-maps            22.08.3-1            22.12.0-1
                           marble-qt            22.08.3-1            22.12.0-1
                        markdownpart            22.08.3-1            22.12.0-1
                       mbox-importer            22.08.3-1            22.12.0-1
                          messagelib            22.08.3-1            22.12.0-1
                              minuet            22.08.3-1            22.12.0-1
                     modemmanager-qt            5.100.0-1            5.101.0-1
                   networkmanager-qt            5.100.0-1            5.101.0-1
                        oxygen-icons          1:5.100.0-1          1:5.101.0-1
                    oxygen-icons-svg          1:5.100.0-1          1:5.101.0-1
                            palapeli            22.08.3-1            22.12.0-1
                              parley            22.08.3-1            22.12.0-1
                    partitionmanager            22.08.3-1            22.12.0-1
                    perl-alien-build               2.73-1               2.74-1
                                 php             8.1.13-1             8.1.13-4
                          php-apache             8.1.13-1             8.1.13-4
                            php-apcu             5.1.22-1             5.1.22-2
                             php-cgi             8.1.13-1             8.1.13-4
                           php-dblib             8.1.13-1             8.1.13-4
                           php-embed             8.1.13-1             8.1.13-4
                         php-enchant             8.1.13-1             8.1.13-4
                             php-fpm             8.1.13-1             8.1.13-4
                              php-gd             8.1.13-1             8.1.13-4
                            php-imap             8.1.13-1             8.1.13-4
                            php-intl             8.1.13-1             8.1.13-4
                            php-odbc             8.1.13-1             8.1.13-4
                           php-pgsql             8.1.13-1             8.1.13-4
                          php-phpdbg             8.1.13-1             8.1.13-4
                          php-pspell             8.1.13-1             8.1.13-4
                            php-snmp             8.1.13-1             8.1.13-4
                          php-sodium             8.1.13-1             8.1.13-4
                          php-sqlite             8.1.13-1             8.1.13-4
                            php-tidy             8.1.13-1             8.1.13-4
                             php-xsl             8.1.13-1             8.1.13-4
                                php7             7.4.33-2             7.4.33-4
                         php7-apache             7.4.33-2             7.4.33-4
                           php7-apcu             5.1.22-1             5.1.22-2
                            php7-cgi             7.4.33-2             7.4.33-4
                          php7-dblib             7.4.33-2             7.4.33-4
                          php7-embed             7.4.33-2             7.4.33-4
                        php7-enchant             7.4.33-2             7.4.33-4
                            php7-fpm             7.4.33-2             7.4.33-4
                             php7-gd             7.4.33-2             7.4.33-4
                           php7-imap             7.4.33-2             7.4.33-4
                           php7-intl             7.4.33-2             7.4.33-4
                           php7-odbc             7.4.33-2             7.4.33-4
                          php7-pgsql             7.4.33-2             7.4.33-4
                         php7-phpdbg             7.4.33-2             7.4.33-4
                         php7-pspell             7.4.33-2             7.4.33-4
                           php7-snmp             7.4.33-2             7.4.33-4
                         php7-sodium             7.4.33-2             7.4.33-4
                         php7-sqlite             7.4.33-2             7.4.33-4
                           php7-tidy             7.4.33-2             7.4.33-4
                            php7-xsl             7.4.33-2             7.4.33-4
                               picmi            22.08.3-1            22.12.0-1
                   pim-data-exporter            22.08.3-1            22.12.0-1
                    pim-sieve-editor            22.08.3-1            22.12.0-1
                           pimcommon            22.08.3-1            22.12.0-1
                       pipewire-alsa           1:0.3.61-1           1:0.3.63-1
                      pipewire-audio           1:0.3.61-1           1:0.3.63-1
                       pipewire-docs           1:0.3.61-1           1:0.3.63-1
                       pipewire-jack           1:0.3.61-1           1:0.3.63-1
                      pipewire-pulse           1:0.3.61-1           1:0.3.63-1
                       pipewire-v4l2           1:0.3.61-1           1:0.3.63-1
                   pipewire-x11-bell           1:0.3.61-1           1:0.3.63-1
                   pipewire-zeroconf           1:0.3.61-1           1:0.3.63-1
                            pkgstats              3.2.6-1              3.2.7-2
                    plasma-framework            5.100.1-1            5.101.0-1
                             postfix              3.7.3-3              3.7.3-4
                         postfix-cdb              3.7.3-3              3.7.3-4
                        postfix-ldap              3.7.3-3              3.7.3-4
                        postfix-lmdb              3.7.3-3              3.7.3-4
                       postfix-mysql              3.7.3-3              3.7.3-4
                        postfix-pcre              3.7.3-3              3.7.3-4
                       postfix-pgsql              3.7.3-3              3.7.3-4
                      postfix-sqlite              3.7.3-3              3.7.3-4
                               poxml            22.08.3-1            22.12.0-1
                       print-manager            22.08.3-1            22.12.0-1
                              prison            5.100.0-1            5.101.0-1
                          prometheus             2.40.4-1             2.40.5-1
                            protobuf              21.11-1              21.12-1
                             purpose            5.100.0-1            5.101.0-1
                       python-django              4.1.3-1              4.1.4-1
                         python-lxml              4.9.1-1              4.9.2-1
                    python-lxml-docs              4.9.1-1              4.9.2-1
                 python-patiencediff             0.2.10-1             0.2.11-1
                 python-platformdirs              2.5.4-1              2.6.0-1
                     python-protobuf              21.11-1              21.12-1
                         qcachegrind            22.08.3-1            22.12.0-1
                  qqc2-desktop-style            5.100.0-1            5.101.0-1
                            qt5-base    5.15.7+kde+r176-1    5.15.7+kde+r177-1
                    qt5-imageformats      5.15.7+kde+r6-1      5.15.7+kde+r6-2
                         qt5-wayland     5.15.7+kde+r55-1     5.15.7+kde+r56-1
             qt5-xcb-private-headers    5.15.7+kde+r176-1    5.15.7+kde+r177-1
                    qt6-imageformats              6.4.1-1              6.4.1-2
                                 re2         1:20221201-1         1:20221201-2
                                rocs            22.08.3-1            22.12.0-1
            signon-kwallet-extension            22.08.3-1            22.12.0-1
                            skanlite            22.08.3-1            22.12.0-1
                            skanpage            22.08.3-1            22.12.0-1
                        sof-firmware              2.2.2-1              2.2.3-1
                           sof-tools              2.2.2-1              2.2.3-1
                               solid            5.100.0-1            5.101.0-1
                              sonnet            5.100.0-1            5.101.0-1
                           spectacle            22.08.3-1            22.12.0-1
                                step            22.08.3-1            22.12.0-1
                          subversion             1.14.2-1             1.14.2-3
                         suitesparse              6.0.1-1              6.0.2-1
                             svgpart            22.08.3-1            22.12.0-1
                             sweeper            22.08.3-1            22.12.0-1
                         syndication            5.100.0-1            5.101.0-1
                 syntax-highlighting            5.100.0-1            5.101.0-1
          telepathy-kde-accounts-kcm            22.08.3-1            22.12.0-1
              telepathy-kde-approver            22.08.3-1            22.12.0-1
          telepathy-kde-auth-handler            22.08.3-1            22.12.0-1
               telepathy-kde-call-ui            22.08.3-1            22.12.0-1
      telepathy-kde-common-internals            22.08.3-1            22.12.0-1
          telepathy-kde-contact-list            22.08.3-1            22.12.0-1
        telepathy-kde-contact-runner            22.08.3-1            22.12.0-1
       telepathy-kde-desktop-applets            22.08.3-1            22.12.0-1
  telepathy-kde-filetransfer-handler            22.08.3-1            22.12.0-1
    telepathy-kde-integration-module            22.08.3-1            22.12.0-1
                  telepathy-kde-meta              22.08-2              22.12-1
             telepathy-kde-send-file            22.08.3-1            22.12.0-1
               telepathy-kde-text-ui            22.08.3-1            22.12.0-1
                        threadweaver            5.100.0-1            5.101.0-1
                              thunar            4.16.11-2             4.18.0-1
                       thunar-volman             4.16.0-1             4.18.0-1
                         thunderbird            102.5.1-1            102.6.0-1
                 thunderbird-i18n-af            102.5.1-1            102.6.0-1
                 thunderbird-i18n-ar            102.5.1-1            102.6.0-1
                thunderbird-i18n-ast            102.5.1-1            102.6.0-1
                 thunderbird-i18n-be            102.5.1-1            102.6.0-1
                 thunderbird-i18n-bg            102.5.1-1            102.6.0-1
                 thunderbird-i18n-br            102.5.1-1            102.6.0-1
                 thunderbird-i18n-ca            102.5.1-1            102.6.0-1
                thunderbird-i18n-cak            102.5.1-1            102.6.0-1
                 thunderbird-i18n-cs            102.5.1-1            102.6.0-1
                 thunderbird-i18n-cy            102.5.1-1            102.6.0-1
                 thunderbird-i18n-da            102.5.1-1            102.6.0-1
                 thunderbird-i18n-de            102.5.1-1            102.6.0-1
                thunderbird-i18n-dsb            102.5.1-1            102.6.0-1
                 thunderbird-i18n-el            102.5.1-1            102.6.0-1
              thunderbird-i18n-en-gb            102.5.1-1            102.6.0-1
              thunderbird-i18n-en-us            102.5.1-1            102.6.0-1
              thunderbird-i18n-es-ar            102.5.1-1            102.6.0-1
              thunderbird-i18n-es-es            102.5.1-1            102.6.0-1
                 thunderbird-i18n-et            102.5.1-1            102.6.0-1
                 thunderbird-i18n-eu            102.5.1-1            102.6.0-1
                 thunderbird-i18n-fi            102.5.1-1            102.6.0-1
                 thunderbird-i18n-fr            102.5.1-1            102.6.0-1
              thunderbird-i18n-fy-nl            102.5.1-1            102.6.0-1
              thunderbird-i18n-ga-ie            102.5.1-1            102.6.0-1
                 thunderbird-i18n-gd            102.5.1-1            102.6.0-1
                 thunderbird-i18n-gl            102.5.1-1            102.6.0-1
                 thunderbird-i18n-he            102.5.1-1            102.6.0-1
                 thunderbird-i18n-hr            102.5.1-1            102.6.0-1
                thunderbird-i18n-hsb            102.5.1-1            102.6.0-1
                 thunderbird-i18n-hu            102.5.1-1            102.6.0-1
              thunderbird-i18n-hy-am            102.5.1-1            102.6.0-1
                 thunderbird-i18n-id            102.5.1-1            102.6.0-1
                 thunderbird-i18n-is            102.5.1-1            102.6.0-1
                 thunderbird-i18n-it            102.5.1-1            102.6.0-1
                 thunderbird-i18n-ja            102.5.1-1            102.6.0-1
                 thunderbird-i18n-ka            102.5.1-1            102.6.0-1
                thunderbird-i18n-kab            102.5.1-1            102.6.0-1
                 thunderbird-i18n-kk            102.5.1-1            102.6.0-1
                 thunderbird-i18n-ko            102.5.1-1            102.6.0-1
                 thunderbird-i18n-lt            102.5.1-1            102.6.0-1
                 thunderbird-i18n-ms            102.5.1-1            102.6.0-1
              thunderbird-i18n-nb-no            102.5.1-1            102.6.0-1
                 thunderbird-i18n-nl            102.5.1-1            102.6.0-1
              thunderbird-i18n-nn-no            102.5.1-1            102.6.0-1
              thunderbird-i18n-pa-in            102.5.1-1            102.6.0-1
                 thunderbird-i18n-pl            102.5.1-1            102.6.0-1
              thunderbird-i18n-pt-br            102.5.1-1            102.6.0-1
              thunderbird-i18n-pt-pt            102.5.1-1            102.6.0-1
                 thunderbird-i18n-rm            102.5.1-1            102.6.0-1
                 thunderbird-i18n-ro            102.5.1-1            102.6.0-1
                 thunderbird-i18n-ru            102.5.1-1            102.6.0-1
                 thunderbird-i18n-sk            102.5.1-1            102.6.0-1
                 thunderbird-i18n-sl            102.5.1-1            102.6.0-1
                 thunderbird-i18n-sq            102.5.1-1            102.6.0-1
                 thunderbird-i18n-sr            102.5.1-1            102.6.0-1
              thunderbird-i18n-sv-se            102.5.1-1            102.6.0-1
                 thunderbird-i18n-th            102.5.1-1            102.6.0-1
                 thunderbird-i18n-tr            102.5.1-1            102.6.0-1
                 thunderbird-i18n-uk            102.5.1-1            102.6.0-1
                 thunderbird-i18n-uz            102.5.1-1            102.6.0-1
                 thunderbird-i18n-vi            102.5.1-1            102.6.0-1
              thunderbird-i18n-zh-cn            102.5.1-1            102.6.0-1
              thunderbird-i18n-zh-tw            102.5.1-1            102.6.0-1
                             tumbler             4.16.1-3             4.18.0-1
                            umbrello            22.08.3-2            22.12.0-1
                         vim-runtime           9.0.0910-1           9.0.1046-1
                       virglrenderer              0.9.1-1             0.10.3-1
                  xdg-desktop-portal             1.15.0-1             1.16.0-1
                     xf86-video-vesa              2.5.0-3              2.6.0-1
                     xfce4-appfinder             4.16.1-2             4.18.0-1
                xfce4-cpufreq-plugin              1.2.7-1              1.2.8-1
               xfce4-cpugraph-plugin              1.2.6-1              1.2.7-1
                     xfce4-dev-tools             4.16.0-1             4.18.0-1
                         xfce4-panel             4.16.5-1             4.18.0-1
                 xfce4-power-manager             4.16.0-3             4.18.0-1
                xfce4-sensors-plugin              1.4.3-1              1.4.4-1
                       xfce4-session             4.16.0-2             4.18.0-1
                      xfce4-settings             4.16.5-1             4.18.0-1
             xfce4-systemload-plugin              1.3.1-1              1.3.2-1
                              xfconf             4.16.0-2             4.18.0-1
                           xfdesktop             4.16.1-1             4.18.0-1
                               xfwm4             4.16.1-3             4.18.0-1
                         xorg-server             21.1.4-1             21.1.5-1
                  xorg-server-common             21.1.4-1             21.1.5-1
                   xorg-server-devel             21.1.4-1             21.1.5-1
                  xorg-server-xephyr             21.1.4-1             21.1.5-1
                   xorg-server-xnest             21.1.4-1             21.1.5-1
                    xorg-server-xvfb             21.1.4-1             21.1.5-1
                          xorg-xhost              1.0.8-3              1.0.9-1
                       xorg-xwayland             22.1.5-1             22.1.6-1
                        xscreensaver             6.05.1-2               6.06-1
                             yakuake            22.08.3-1            22.12.0-1
                             zanshin            22.08.3-1            22.12.0-1
                                 zsh                5.9-1                5.9-2
                             zsh-doc                5.9-1                5.9-2
                                zvbi             0.2.37-1             0.2.38-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi22.08.3.r12862.g014f92e63-122.12.0.r12865.g2b8e57846-1
                    akonadi-calendar22.08.3.r2225.gfa05a48-122.12.0.r2229.g23f871f-1
              akonadi-calendar-tools22.08.3.r985.g0906ebc-122.12.0.r988.gdfbf920-1
                    akonadi-contacts22.08.3.r3306.g3ea8472c-122.12.0.r3311.gbb1737d8-1
               akonadi-import-wizard22.08.3.r1871.g7137a7c-122.12.0.r1874.g5f4a9d5-1
                        akonadi-mime22.08.3.r1791.g45246f5-122.12.0.r1793.g273a99c-1
                       akonadi-notes22.08.3.r1110.g5ff24fb-122.12.0.r1114.g96e3758-1
                      akonadi-search22.08.3.r1305.gb7e01a5-122.12.0.r1307.g2825827-1
                      akonadiconsole22.08.3.r1636.g671d5a8-122.12.0.r1638.g623908e-1
                           akregator22.08.3.r6522.g7ee46f78-122.12.0.r6529.g3c222264-1
                           alligator  22.11.r7.g0360ec4-1 22.11.r14.g5e0aac9-1
                            analitza22.08.3.r2369.g5215178c-122.12.0.r2374.g56367297-1
                           angelfish 22.11.r14.g1e3cb6e-1 22.11.r17.g059495c-1
                                 ark22.08.3.r4963.g75f2c7f7-122.12.0.r4968.ga660fb58-1
                          artikulate22.08.3.r1470.g363a25e-122.12.0.r1475.gf29766f-1
                              attica5.100.0.r893.g07ff076-15.101.0.r894.gbf4c5da-1
                         audiocd-kio22.08.3.r1134.gbcd0118-122.12.0.r1135.g0587367-1
                           audiotube  22.11.r5.ge494a6f-1 22.11.r13.g3963eb4-1
                        aura-browser5.26.0.r144.gd88930b-15.26.0.r150.g865f072-1
                               baloo5.100.0.r3111.g03246908-15.101.0.r3115.gb48e8177-1
                       baloo-widgets22.08.3.r786.gc1eb617-122.12.0.r787.g792ca65-1
                             blinken22.08.3.r702.ge5ff13a-122.12.0.r704.g022a1d8-1
                           bluedevil1:5.26.4.r2515.g2bd96ec1-11:5.26.4.r2525.g76888dd1-1
                            bluez-qt5.100.0.r731.g8be1800-15.101.0.r732.g1b8fc40-1
                              bomber22.08.3.r598.g9b798a9-122.12.0.r599.g79f34c2-1
                                bovo22.08.3.r814.g3d9c9c0-122.12.0.r816.g7492106-1
                              breeze5.26.4.r2530.g27680445-15.26.4.r2533.gd50d9468-1
                        breeze-icons5.100.0.r1938.g5b546af3-15.101.0.r1940.gfc73eba3-1
                                buho  2.2.1.r6.g683bdd0-1  2.2.1.r7.g38d1ef1-1
                     calendarsupport22.08.3.r759.g4fe3b3d-122.08.3.r762.g6edf3a4-1
                           calindori  22.11.r6.gaaac61a-1  22.11.r7.g090dc21-1
                            cervisia22.08.3.r1727.g0c4030e-122.12.0.r1729.ga5e9e7c-1
                            discover5.26.4.r9073.gce21b2077-15.26.4.r9083.gb5248576c-1
                             dolphin22.08.3.r7188.g5257231d3-122.12.0.r7195.g0e22101ac-1
                     dolphin-plugins22.08.3.r709.gbc35b8d-122.12.0.r710.g7d5cdcb-1
                              dragon22.08.3.r1114.g2de044b-122.12.0.r1118.g4af295c-1
                             drkonqi5.26.4.r864.gf4719076-15.26.4.r865.gd0df3d98-1
                               elisa22.08.3.r3087.g91513ffc-122.12.0.r3089.gc15fc54d-1
                          elisa-qtmm22.08.3.r3087.g91513ffc-122.12.0.r3089.gc15fc54d-1
                          eventviews22.08.3.r912.gd5cc086-122.08.3.r915.ge7f6bbe-1
                 extra-cmake-modules5.100.0.r3538.gbd475e48-15.101.0.r3539.gf4e1590d-1
                        ffmpegthumbs22.08.3.r242.g08c3a2c-122.12.0.r242.g08c3a2c-1
                           filelight22.08.3.r1272.g18df9b6-122.12.0.r1280.g4b51723-1
                frameworkintegration5.100.0.r663.g07b398a-15.101.0.r664.g7a093b1-1
                           granatier22.08.3.r1012.g0f5c19e-122.12.0.r1013.gdbf5fd0-1
                     grantlee-editor22.08.3.r877.gaa8b663-122.12.0.r879.gf3230e1-1
                       grantleetheme22.08.3.r444.gda48269-122.12.0.r447.g278809e-1
                            gwenview22.08.3.r6981.gf3bfb9c0-122.12.0.r6988.gb4578f37-1
                     incidenceeditor22.08.3.r968.g80a1356-122.12.0.r970.gd46a161-1
                            index-fm  2.2.1.r4.g62b2103-1  2.2.1.r5.gedf78ba-1
                           itinerary22.08.3.r2172.gd7ea5a0-122.12.0.r2184.g524574e-1
                                 juk22.08.3.r3212.gfb8c6664-122.12.0.r3214.g5825badf-1
               kaccounts-integration22.08.3.r1306.g0af02c8-122.12.0.r1309.g2df9387-1
                 kaccounts-providers22.08.3.r412.g983e737-122.12.0.r413.g0aa5195-1
                         kactivities5.100.0.r1418.g5f64f871-15.101.0.r1419.gcac1498c-1
                   kactivities-stats5.100.0.r425.gb9e496f-15.101.0.r426.gfad7ca4-1
                   kactivitymanagerd5.26.4.r1435.gb902153-15.26.4.r1436.gd22a22b-1
                        kaddressbook22.08.3.r6278.g03a9660e-122.12.0.r6281.gbd791c40-1
                             kajongg22.08.3.r4375.gb8a5b892-122.12.0.r4377.gd783b9f2-1
                              kalarm22.08.3.r8132.g1bd82bc3-122.12.0.r8158.g12aea306-1
                            kalgebra22.08.3.r2104.gaae93e8-122.12.0.r2108.g8f6eab2-1
                                kalk  22.11.r6.gbe20239-1 22.11.r11.g0ebd46a-1
                             kalzium22.08.3.r4442.g9822de7b-122.12.0.r4445.g73a2500b-1
                              kamera22.08.3.r754.g032e534-122.12.0.r756.gf4a5229-1
                              kamoso22.08.3.r1503.g744da94-122.12.0.r1506.g54d0170-1
                            kanagram22.08.3.r1354.g1302996-122.12.0.r1356.g8a7166c-1
                             kapidox5.100.0.r580.ga9f5efc-15.101.0.r581.g6e89a92-1
                              kapman22.08.3.r692.gd00a991-122.12.0.r693.g76f7974-1
                        kapptemplate22.08.3.r1028.gbec630a-122.12.0.r1029.g898de5f-1
                            karchive5.100.0.r587.g0b756df-15.101.0.r592.gdc629e2-1
                               kasts 22.11.r20.g4735176-1 22.11.r37.g3caadc0-1
                                kate22.08.3.r19989.g16a41838e-122.12.0.r20007.g086d608f1-1
                             katomic22.08.3.r998.geb06cba-122.12.0.r999.g38c1214-1
                               kauth5.100.0.r527.gd77c7d9-15.101.0.r529.g2f5ad09-1
                             kbackup22.08.3.r482.ga4b4aac-122.12.0.r488.gdf665c1-1
                           kblackbox22.08.3.r803.g041b183-122.12.0.r805.g4309c91-1
                             kblocks22.08.3.r778.g0f3247b-122.12.0.r780.g6d25632-1
                          kbookmarks5.100.0.r492.g2798719-15.101.0.r494.g5000502-1
                             kbounce22.08.3.r884.g72eba00-122.12.0.r886.g025d797-1
                           kbreakout22.08.3.r964.ge355d04-122.12.0.r965.g2c033a3-1
                              kbruch22.08.3.r914.g43adc0d-122.12.0.r916.gfb21760-1
                         kcachegrind22.08.3.r1218.g7eac263-122.12.0.r1221.g53f3c79-1
                  kcachegrind-common22.08.3.r1218.g7eac263-122.12.0.r1221.g53f3c79-1
                               kcalc22.08.3.r1664.gad52487-122.12.0.r1666.g614ba88-1
                       kcalendarcore5.100.0.r1354.g232a1b887-15.101.0.r1355.g1e8158c09-1
                           kcalutils22.08.3.r1016.gbf11d921f-122.12.0.r1020.g3500b3f62-1
                         kcharselect22.08.3.r576.gd389981-122.12.0.r577.g821033d-1
                              kclock  22.11.r5.g34d9444-1 22.11.r10.g2a42cec-1
                            kcmutils5.100.0.r691.g3402e32-15.101.0.r694.g05bcc7f-1
                             kcodecs5.100.0.r456.gef17023-15.101.0.r461.g7d0dc3e-1
                       kcolorchooser22.08.3.r297.gea1ba86-122.12.0.r298.ga281134-1
                         kcompletion5.100.0.r530.g716fe00-15.101.0.r532.g5890dcf-1
                             kconfig5.100.0.r1014.g2b0b7f4c-15.101.0.r1016.g9f0e5ce6-1
                      kconfigwidgets5.100.0.r820.gc6e4547a-15.101.0.r830.gebf18ede-1
                           kcontacts1:5.100.0.r3369.g2556919f-11:5.101.0.r3377.g29756ed5-1
                         kcoreaddons5.100.0.r1618.gea5e8b46-15.101.0.r1623.g4f35c8d7-1
                              kcrash5.100.0.r463.gfbbdfff-15.101.0.r464.g276c552-1
                               kcron22.08.3.r868.g5a6205c-122.12.0.r870.g796020f-1
                                kdav1:5.100.0.r1375.g557bf2f-11:5.101.0.r1377.g5bc20a4-1
                         kdbusaddons5.100.0.r448.ge19a1fe-15.101.0.r450.gdd34487-1
                       kde-cli-tools5.26.4.r2011.g70efc93-15.26.4.r2017.g25f1936-1
                     kde-dev-scripts22.08.3.r4169.g3eb5104-122.12.0.r4169.g3eb5104-1
                       kde-dev-utils22.08.3.r620.g3478628-122.12.0.r621.g7af7ed9-1
                      kdebugsettings22.08.3.r1041.ge826d43-122.12.0.r1045.g3a1525c-1
                        kdeclarative5.100.0.r1078.ga0b07d4-15.101.0.r1081.gf1571c3-1
                          kdeconnect22.08.3.r3609.g8a5826c5-122.12.0.r3625.gf3f580ac-1
                         kdecoration5.26.4.r314.g4bafed0-15.26.4.r315.gb9ca603-1
                                kded5.100.0.r484.g135ad0e-15.101.0.r485.g52c1d67-1
                         kdeedu-data22.08.3.r22.g793df3b-122.12.0.r22.g793df3b-1
              kdegraphics-mobipocket22.08.3.r275.g6cdb65d-122.12.0.r278.gd60821d-1
            kdegraphics-thumbnailers22.08.3.r283.g9b2007f-122.12.0.r285.g5b3b1cd-1
                     kdelibs4support5.100.0.r1130.g126b7925-15.101.0.r1135.g08168fb3-1
              kdenetwork-filesharing22.08.3.r1008.ge65ebfb-122.12.0.r1011.g2dc5dab-1
                            kdenlive22.08.3.r17147.g6179c3f1d-122.12.0.r17178.gb09b23b68-1
                       kdepim-addons22.08.3.r4949.g5d9904f88-122.12.0.r4955.gf9f78882b-1
                      kdepim-runtime22.08.3.r15664.gc6789ba3a-122.12.0.r15669.gc730636e0-1
                    kdeplasma-addons5.26.4.r9197.g8abcd1eb6-15.26.4.r9206.gc317c7518-1
                    kdesdk-kioslaves22.08.3.r505.g1f7909e-122.12.0.r505.g1f7909e-1
                 kdesdk-thumbnailers22.08.3.r110.gd586f08-122.12.0.r111.gb9864b7-1
                     kdesignerplugin5.100.0.r379.gf6e7e95-15.101.0.r381.g8c156b5-1
                               kdesu5.100.0.r536.g0dfa805-15.101.0.r540.g6c5f2c2-1
                                 kdf22.08.3.r908.g8c32cb5-122.12.0.r909.g99acef1-1
                             kdialog22.08.3.r1274.g46cc1f546-122.12.0.r1276.gc490a83e1-1
                            kdiamond22.08.3.r759.gb81ce30-122.12.0.r760.g4052c89-1
                              kdnssd5.100.0.r378.ga54e7cc-15.101.0.r380.gbf70b39-1
                           kdoctools5.100.0.r698.gc3903a5-15.101.0.r701.g5b420d0-1
                      keditbookmarks22.08.3.r2791.ga9a60f637-122.12.0.r2793.g42f4c9e0e-1
                          kemoticons5.100.0.r432.gedd549d-15.101.0.r433.gc0a05e2-1
                            keysmith  22.11.r4.ga5ecb8d-1  22.11.r5.g1efe214-1
                       kfilemetadata5.100.0.r904.g4cbdf20-15.101.0.r907.g60d4dad-1
                               kfind22.08.3.r2760.gda84f26c2-122.12.0.r2762.g661d71b93-1
                             kfloppy22.08.3.r826.g0b13fe9-122.12.0.r828.g99778b5-1
                         kfourinline22.08.3.r1063.gcaefbe4-122.12.0.r1065.gfc5bdde-1
                             kgamma55.26.4.r499.g40ac727-15.26.4.r500.g7a72b99-1
                          kgeography22.08.3.r1206.g68fb02d-122.12.0.r1211.gd06380e-1
                                kget22.08.3.r3267.g1251e7ed-122.12.0.r3269.gb57a4f2d-1
                        kglobalaccel5.100.0.r610.g599e0fa-15.101.0.r615.ge94d543-1
                         kgoldrunner22.08.3.r1329.g9636924-122.12.0.r1331.g1bb948a-1
                          kguiaddons5.100.0.r517.g1588ce0-15.101.0.r524.gccd566e-1
                            khangman22.08.3.r1649.g9662e1e-122.12.0.r1654.gb637036-1
                         khelpcenter22.08.3.r2833.gab3106b6-122.12.0.r2836.g1d62f530-1
                           kholidays1:5.100.0.r1085.ge5902ff-11:5.101.0.r1090.gc1654e3-1
                            khotkeys5.26.4.r2183.gbb898f9-15.26.4.r2184.g741bac3-1
                               khtml5.100.0.r626.g97f2ff6-15.101.0.r631.g13141d0-1
                               ki18n5.100.0.r601.gd21057f-15.101.0.r604.g1812519-1
                         kiconthemes5.100.0.r655.g9450e0f-15.101.0.r657.g1be3e63-1
                 kidentitymanagement22.08.3.r3931.g27734642-122.12.0.r3933.g36630862-1
                           kidletime5.100.0.r385.g24f7b32-15.101.0.r387.g9283df5-1
                                 kig22.08.3.r3261.gb98c89ec-122.12.0.r3264.gbbc879f1-1
                                kigo22.08.3.r611.g260668d-122.12.0.r612.g87967bd-1
                            killbots22.08.3.r833.g9edc96b-122.12.0.r835.gb3a966d-1
                       kimageformats5.100.0.r470.g7af4eea-15.101.0.r473.g05bd939-1
                     kimagemapeditor22.08.3.r544.gd0f5332-122.12.0.r546.geea2916-1
                               kimap22.08.3.r1230.gb7616ce-122.12.0.r1232.g1143a48-1
                         kinfocenter5.26.4.r2238.g0937a13b-15.26.4.r2241.g3c095b45-1
                               kinit5.100.0.r466.g0213f73-15.101.0.r469.g1bdab6f-1
                                 kio5.100.0.r5946.g07eb8ec80-15.101.0.r5961.g1d033c04c-1
                          kio-extras22.08.3.r7429.g532b8177d-122.12.0.r7438.gd34985da4-1
                          kio-gdrive22.08.3.r678.gb1f9769-122.12.0.r680.g5061f5e-1
                     kirigami-addons1:0.6.1.r2.g3203031-11:0.6.1.r5.g0e3fc8b-1
                    kirigami-gallery22.08.3.r300.g848ae29-122.12.0.r303.g407031e-1
                           kirigami25.100.0.r3515.gbb9c6eec-15.101.0.r3531.g0fbebc95-1
                              kiriki22.08.3.r499.g0c78e98-122.12.0.r501.g3b8869d-1
                         kitemmodels5.100.0.r634.g117764e-15.101.0.r635.g8344793-1
                          kitemviews5.100.0.r403.gf755ad1-15.101.0.r405.g927f6c5-1
                               kiten22.08.3.r1235.g3e49746-122.12.0.r1236.gd080868-1
                          kitinerary22.08.3.r2559.g05bf899a-122.12.0.r2579.gd6f305d3-1
                         kjobwidgets5.100.0.r451.g8029991-15.101.0.r453.g2b12cfe-1
                                 kjs5.100.0.r382.g3c89acf-15.101.0.r383.g7d6e7ad-1
                            kjsembed5.100.0.r350.g71331f1-15.101.0.r352.gcc55cd3-1
                        kjumpingcube22.08.3.r876.g7e786cb-122.12.0.r879.g68aa0e1-1
                               kldap22.08.3.r998.g56b67b3-122.12.0.r1001.g42d9cc1-1
                           kleopatra22.08.3.r6986.g848f206d-122.12.0.r7011.gf50e1900-1
                            klettres22.08.3.r997.g6cfd602-122.12.0.r1005.g8d9bc03-1
                            klickety22.08.3.r734.ge03cf1f-122.12.0.r736.gd2236e8-1
                              klines22.08.3.r855.g3b9ee69-122.12.0.r856.g7fdf013-1
                                kmag22.08.3.r771.g9ce26b0-122.12.0.r772.gc46593e-1
                           kmahjongg22.08.3.r1596.g3095f0e-122.12.0.r1597.g48a36ba-1
                               kmail22.08.3.r26646.g551b6bf41-122.12.0.r26680.g550bea1d2-1
                kmail-account-wizard22.08.3.r922.g6516961-122.12.0.r925.g6710367-1
                      kmailtransport22.08.3.r1828.g665bfa4-122.12.0.r1833.g5b6c62a-1
                               kmbox22.08.3.r620.gff1b666-122.12.0.r621.g9d10be1-1
                        kmediaplayer5.100.0.r330.g51d88cd-15.101.0.r331.geec33ec-1
                           kmenuedit5.26.4.r1114.gb9c9b60-15.26.4.r1119.g2a46d38-1
                               kmime22.08.3.r1564.ga4be9be-122.12.0.r1566.g2bd2208-1
                              kmines22.08.3.r1805.g24ddb90-122.12.0.r1806.g7a817e1-1
                                kmix22.08.3.r2483.gf735b657-122.12.0.r2487.gfafd175e-1
                          kmousetool22.08.3.r474.g4612e7d-122.12.0.r477.gfc3e4c4-1
                              kmouth22.08.3.r777.g4259fa8-122.12.0.r781.g021fce1-1
                              kmplot22.08.3.r1548.gf4d6ddb-122.12.0.r1551.g15a102d-1
                        knavalbattle22.08.3.r1470.g2c515cf-122.12.0.r1471.g45f40c0-1
                            knetwalk22.08.3.r751.g2be5668-122.12.0.r752.gde765db-1
                           knewstuff5.100.0.r1433.gf64baa30-15.101.0.r1439.g5fbeb50c-1
                             knights22.08.3.r1190.g368506d-122.12.0.r1193.g78fadcd-1
                              knotes22.08.3.r3750.g3e0fed35-122.12.0.r3753.g5f80c0a3-1
                      knotifications5.100.0.r786.gbb4b97c-15.101.0.r790.gb456b7a-1
                       knotifyconfig5.100.0.r411.g93db1db-15.101.0.r414.g0bc02c0-1
                                koko  22.11.r1.g7884903-1  22.11.r5.g1549184-1
                                kolf22.08.3.r1564.gf0005be-122.12.0.r1565.gcf1266e-1
                           kollision22.08.3.r570.ged6cd4b-122.12.0.r572.g9cc9d47-1
                         kolourpaint22.08.3.r2467.gcb82406b-122.12.0.r2469.ga2946697-1
                             kompare22.08.3.r1207.g002651e-122.12.0.r1208.g58b9290-1
                            kongress  22.11.r1.g4d195ec-1  22.11.r2.gcde56a9-1
                           konqueror22.08.3.r15247.g19ea72737-122.12.0.r15253.g4df51e7cd-1
                            konquest22.08.3.r982.ge9393c4-122.12.0.r985.g96167de-1
                             konsole22.08.3.r8775.g9494c9cc-122.12.0.r8788.g2b4b2e39-1
                             kontact22.08.3.r5617.g9939f341-122.12.0.r5619.gaf2b5a3b-1
                    kontactinterface22.08.3.r726.gbb797c6-122.12.0.r728.gfa98307-1
                            kontrast22.08.3.r268.ga436249-122.12.0.r271.gf066b15-1
                        konversation22.08.3.r9212.ga20ed2d5-122.12.0.r9216.gfe3330b8-1
                       kopeninghours22.08.3.r356.g31de413-122.12.0.r357.gac48b0a-1
                          korganizer22.08.3.r11897.g3317bb500-122.12.0.r11900.gf391f4440-1
                       kosmindoormap22.08.3.r859.gbb9550a-122.12.0.r870.gfe03c05-1
                            kpackage5.100.0.r795.geb3b53d-15.101.0.r798.ge41e01b-1
                              kparts5.100.0.r638.g00be60b-15.101.0.r641.g5df4f7d-1
                                kpat22.08.3.r2671.ga7df61c8-122.12.0.r2672.g311d420b-1
                             kpeople5.100.0.r1404.ge6c47d3-15.101.0.r1407.g01aa953-1
                        kpeoplevcard   0.1.r52.gfb1d438-1   0.1.r55.ga17d6a8-1
                        kpimtextedit22.08.3.r1730.g637853a-122.12.0.r1734.g4d57648-1
                           kpipewire5.26.4.r176.g47ebc54-15.26.4.r178.g60a4f96-1
                             kpkpass22.08.3.r318.ga8d97e6-122.12.0.r319.ga90c94a-1
                           kplotting5.100.0.r341.g465de2c-15.101.0.r342.g6d35391-1
                             kpmcore22.08.3.r1330.g50b6f27-122.12.0.r1332.g3d08bb0-1
                                kpty5.100.0.r401.g156edc2-15.101.0.r403.gc293405-1
                    kpublictransport22.08.3.r2058.gf6ad9e36-122.12.0.r2062.gdec79db8-1
                      kqtquickcharts22.08.3.r78.g22ff9c9-122.12.0.r78.g22ff9c9-1
                        kquickcharts5.100.0.r548.g69885d6-15.101.0.r549.g7e1e82f-1
                                krdc22.08.3.r1646.g4b9a32c-122.12.0.r1652.gbc58d52-1
                           krecorder 22.11.r13.g346499e-1 22.11.r21.ga17b5c1-1
                            kreversi22.08.3.r1313.g5a4de8f-122.12.0.r1314.gb02f695-1
                                krfb22.08.3.r1531.gab13b9a-122.12.0.r1532.gf97f9a7-1
                               kross5.100.0.r382.gbdb0fcb-15.101.0.r384.gd8842d9-1
                  kross-interpreters22.08.3.r725.gdef2cfe-122.12.0.r725.gdef2cfe-1
                              kruler22.08.3.r773.g6af7b6a-122.12.0.r774.g56fe588-1
                             krunner5.100.0.r800.gb11d2f7-15.101.0.r801.gd5806e7-1
                           ksanecore      r656.ga0f509a-1      r658.g58093c5-1
                             kscreen5.26.4.r1612.gcba5a44-15.26.4.r1625.g2ced020-1
                       kscreenlocker5.26.4.r1028.gae1f781-15.26.4.r1038.gf116f85-1
                            kservice5.100.0.r1055.gff4e834-15.101.0.r1057.gdcd94bf-1
                             kshisen22.08.3.r1275.ga7ef209-122.12.0.r1278.gf3869f3-1
                               ksirk22.08.3.r1084.gff9f9d9-122.12.0.r1089.g2be48fc-1
                               ksmtp22.08.3.r479.g2abbf9d-122.12.0.r481.gcfaaaa0-1
                          ksnakeduel22.08.3.r888.g9068ef3-122.12.0.r892.g1ac71c5-1
                          kspaceduel22.08.3.r706.gfa060b9-122.12.0.r708.ge8d4ba4-1
                            ksquares22.08.3.r619.gdff6880-122.12.0.r620.gbea4de7-1
                         ksshaskpass5.26.4.r229.ga32efd6-15.26.4.r234.gc2b51bf-1
                             ksudoku22.08.3.r1154.gd3c110e-122.12.0.r1156.gb5b62ed-1
                           ksysguard5.26.4.r3564.ge452ad75-15.26.4.r3568.g049afcad-1
                          ksystemlog22.08.3.r784.g42c324a-122.12.0.r787.g5890ba3-1
                        ksystemstats5.26.4.r258.gd651d8f-15.26.4.r260.gab269a1-1
                            kteatime22.08.3.r787.g7082203-122.12.0.r788.ged435e4-1
                         ktexteditor5.100.0.r3656.g87a3b48f-15.101.0.r3680.g03080ea2-1
                        ktextwidgets5.100.0.r481.gd25d2a3-15.101.0.r483.g4b4de3f-1
                              ktimer22.08.3.r556.g4447d77-122.12.0.r557.g0b0ad46-1
                               ktnef22.08.3.r755.ga721acb-122.12.0.r759.ga6a2b4f-1
                            ktorrent22.08.3.r2924.g09186a2e-122.12.0.r2928.gd6ebfb7e-1
                              ktouch22.08.3.r2223.g5ecdb1d-122.12.0.r2225.gadc1a00-1
                               ktrip  22.11.r4.gf3b0c89-1  22.11.r5.g51f9ec1-1
                          ktuberling22.08.3.r1116.g047063a-122.12.0.r1117.g4715cfc-1
                             kturtle22.08.3.r1210.g6f53357-122.12.0.r1213.g64327a7-1
                             kubrick22.08.3.r454.g92e28fe-122.12.0.r455.g8fad814-1
                     kunitconversion5.100.0.r458.gd31c56a-15.101.0.r461.gdbb9515-1
                             kwallet5.100.0.r1209.g35ae3c8-15.101.0.r1213.g4ecc347-1
                      kwalletmanager22.08.3.r1349.g1ae59d1-122.12.0.r1353.g688d924-1
                               kwave22.08.3.r3834.g8162336b-122.12.0.r3836.g608c1016-1
                            kwayland5.100.0.r1199.g1d0d344-15.101.0.r1200.ga566356-1
                            kweather 22.11.r10.g6224654-1 22.11.r13.g01c7627-1
                        kweathercore   0.7.r16.g3117947-1   0.7.r18.gf587bc1-1
                      kwidgetsaddons5.100.0.r1028.g4a289489-15.101.0.r1035.g79660287-1
                                kwin5.26.4.r23693.g35a99ec9a-15.26.4.r23744.gbf48c3b80-1
                       kwindowsystem5.100.0.r727.g97e7c07-15.101.0.r729.g65d27e2-1
                           kwordquiz22.08.3.r1248.gd7a643c-122.12.0.r1254.g90b4082-1
                              kwrite22.08.3.r19989.g16a41838e-122.12.0.r20007.g086d608f1-1
                             kxmlgui5.100.0.r936.g006ec5c7-15.101.0.r940.gca26767d-1
                       kxmlrpcclient5.100.0.r502.g7dd0a05bc-15.101.0.r504.g7aa32398d-1
                          libakonadi22.08.3.r12862.g014f92e63-122.12.0.r12865.g2b8e57846-1
                         libgravatar22.08.3.r455.g696c636-122.12.0.r457.gb7a672d-1
                            libkcddb22.08.3.r781.g91135a6-122.12.0.r782.g7602302-1
                     libkcompactdisc22.08.3.r408.g9ebfaf4-122.12.0.r409.g35ad14a-1
                           libkdcraw22.08.3.r1155.g26e8429-122.12.0.r1155.g26e8429-1
                         libkdegames22.08.3.r2283.g75e4203f-122.12.0.r2285.gc83b55ab-1
                           libkdepim22.08.3.r943.g49ef53f-122.12.0.r946.gbb57a93-1
                  libkeduvocdocument22.08.3.r1826.ge887964-122.12.0.r1828.ge1dc392-1
                           libkexiv222.08.3.r834.g9253280-122.12.0.r834.g9253280-1
                            libkgapi22.08.3.r1405.g17e01d0-122.12.0.r1407.g8186ced-1
                             libkipi22.08.3.r1282.gabe801d-122.12.0.r1282.gabe801d-1
                             libkleo22.08.3.r1340.g7dcdec9-122.12.0.r1352.g884d8b4-1
                        libkmahjongg22.08.3.r508.gd043bf0-122.12.0.r509.g9d53e9d-1
                     libkomparediff222.08.3.r371.g040a9d9-122.12.0.r372.ga623f3d-1
                            libksane22.08.3.r624.g7542013-122.12.0.r625.g99e05d6-1
                          libkscreen5.26.4.r1697.gcf92569-15.26.4.r1706.g68a389c-1
                           libksieve22.08.3.r1785.g60b55d8c-122.12.0.r1789.g6228d0d5-1
                        libksysguard5.26.4.r2490.g47e8cc8-15.26.4.r2496.gf935b77-1
                         libktorrent22.08.3.r578.g5f160b8-122.12.0.r580.g89df5fb-1
                            lokalize22.08.3.r1882.g7270831c-122.12.0.r1884.g6d476156-1
                               lskat22.08.3.r892.g06330d8-122.12.0.r893.gaba26d3-1
                          mailcommon22.08.3.r1347.g2d2221f-122.12.0.r1351.g21a88f8-1
                        mailimporter22.08.3.r564.g4ed3864-122.12.0.r568.gfb93eb2-1
                              marble22.08.3.r13522.g29d3d9515-122.12.0.r13530.g373ef623f-1
                       marble-common22.08.3.r13522.g29d3d9515-122.12.0.r13530.g373ef623f-1
                           marble-qt22.08.3.r13522.g29d3d9515-122.12.0.r13530.g373ef623f-1
                        markdownpart22.08.3.r155.gb84b25e-122.12.0.r158.ge18f125-1
                           maui-clip  2.2.1.r5.g707d59e-1  2.2.1.r6.gcf6be76-1
                           maui-nota  2.2.1.r4.gc99da16-1  2.2.1.r5.gd73a29a-1
                            maui-pix  2.2.1.r6.g5e4c24b-1  2.2.1.r7.g1d1c537-1
                             mauikit2.2.1.r15.g5a117baa-12.2.1.r20.g5e525e1a-1
                    mauikit-accounts  2.2.1.r5.g395abd2-1  2.2.1.r7.gcf46949-1
                mauikit-filebrowsing 2.2.0.r29.gf52f655-1 2.2.0.r31.g5a3b152-1
                  mauikit-imagetools  2.2.1.r5.g7a874e0-1  2.2.1.r6.g44143e8-1
                  mauikit-texteditor  2.2.1.r5.g6e638f5-1  2.2.1.r7.gd42b585-1
                       mbox-importer22.08.3.r599.gdd1a1ab-122.12.0.r601.g261770e-1
                          messagelib22.08.3.r6802.g687046353-122.12.0.r6808.gbb53e0954-1
                               milou5.26.4.r798.ga6b052d-15.26.4.r799.g7709474-1
                              minuet22.08.3.r646.ga57a4f5-122.12.0.r648.g49a9fcb-1
                     modemmanager-qt5.100.0.r569.g7f54587-15.101.0.r570.g43cf85b-1
                             neochat22.11.r23.g4bfa9c78-122.11.r42.g907d52d6-1
                   networkmanager-qt5.100.0.r1174.g9da6510-15.101.0.r1176.ge4fe52c-1
                              okular22.08.3.r9908.g3a25ff6f2-122.12.0.r9913.g048349d33-1
                              oxygen5.26.4.r4529.g6fc5f190-15.26.4.r4534.ge04d43dc-1
                        oxygen-icons1:5.100.0.r5.gbff159d-11:5.101.0.r5.gbff159d-1
                    oxygen-icons-svg1:5.100.0.r5.gbff159d-11:5.101.0.r5.gbff159d-1
                            palapeli22.08.3.r1346.g9f154d6-122.12.0.r1349.g0748237-1
                              parley22.08.3.r4568.gb3a0f818-122.12.0.r4571.gc20d236c-1
                    partitionmanager22.08.3.r1692.gd737060-122.12.0.r1700.gc615bd3-1
                               picmi22.08.3.r609.g3838545-122.12.0.r610.g136a999-1
       pico-wizard-bigscreen-configs         r7.a3393d7-2                    -
                   pim-data-exporter22.08.3.r2833.gaad951f0-122.12.0.r2836.g0fab0aa5-1
                    pim-sieve-editor22.08.3.r1698.ge14737c-122.12.0.r1701.g7ec512d-1
                           pimcommon22.08.3.r1788.g408cd4cd-122.08.3.r1830.g8fcadf93-1
                        plank-player5.26.0.r103.g0408876-15.26.0.r105.g3ad5676-1
                    plasma-bigscreen5.26.0.r577.g6654fe3-15.26.0.r585.g62d870a-1
          plasma-browser-integration5.26.4.r1397.g914283cf-15.26.4.r1401.g82816df9-1
                       plasma-camera  1.0.r144.g223ff38-1  1.0.r145.g873e33c-1
                      plasma-desktop5.26.4.r9894.g3ec1f0e8e-15.26.4.r9918.gd89d6f48f-1
                       plasma-dialer  22.11.r8.ge9f3541-1 22.11.r14.g7627469-1
                        plasma-disks5.26.4.r314.g638f408-15.26.4.r316.ge943051-1
                     plasma-firewall5.26.4.r688.g044cd8e-15.26.4.r693.g3067cb2-1
                    plasma-framework5.100.0.r16557.gf445ea0d0-15.101.0.r16568.g6b3ec4b0c-1
                  plasma-integration5.26.4.r607.g702143f-15.26.4.r613.gcb3231e-1
                       plasma-mobile5.26.4.r2079.gc34ec4eb1-15.26.4.r2092.g395f5ccdc-1
                    plasma-mobile-nm5.26.4.r3442.gce6a0cc8-15.26.4.r3462.g4e1d7d81-1
                         plasma-nano5.26.4.r209.g5eb043f-15.26.4.r212.g557ecdf-1
                           plasma-nm5.26.4.r3442.gce6a0cc8-15.26.4.r3462.g4e1d7d81-1
                           plasma-pa5.26.4.r1153.gddefa5c-15.26.4.r1155.ga01dee6-1
                    plasma-phonebook  22.11.r2.ge5a24db-1  22.11.r7.g04b3c6c-1
            plasma-remotecontrollers5.26.0.r201.gb9920cd-15.26.0.r203.ge53fcd5-1
                          plasma-sdk5.26.4.r2444.g4bbc1d0a-15.26.4.r2452.g865bdeb8-1
                     plasma-settings  22.11.r7.g520a0df-1  22.11.r9.g67a8602-1
                plasma-systemmonitor5.26.4.r662.gae55e1d-15.26.4.r664.g349dc01-1
                  plasma-thunderbolt5.26.4.r211.gf677e3a-15.26.4.r212.g4e31b17-1
                        plasma-vault5.26.4.r410.ga165177-15.26.4.r412.gb177181-1
            plasma-wayland-protocols1.4.0.r1066.gddb61e8-11.4.0.r1067.g78fc6ee-1
              plasma-wayland-session5.26.4.r12958.g7a7b92995-15.26.4.r12992.ga0e9d9e31-1
                    plasma-workspace5.26.4.r12958.g7a7b92995-15.26.4.r12992.ga0e9d9e31-1
                          plasmatube  22.11.r2.gcb838ae-1  22.11.r4.g9c9da20-1
                    polkit-kde-agent5.26.4.r549.g020c2c5-15.26.4.r550.gd5b5cbf-1
                          powerdevil5.26.4.r2638.gbb12afbd-15.26.4.r2649.g82c1045e-1
                               poxml22.08.3.r284.g47cdde8-122.12.0.r284.g47cdde8-1
                       print-manager22.08.3.r1206.gd05bfd8-122.12.0.r1214.g5e8c656-1
                              prison5.100.0.r413.g5eb99ca-15.101.0.r415.g3dc1961-1
                             purpose5.100.0.r1039.g4822006-15.101.0.r1043.gaf00a2c-1
                         qcachegrind22.08.3.r1218.g7eac263-122.12.0.r1221.g53f3c79-1
                          qmlkonsole  22.11.r7.g5ec6257-1 22.11.r12.g3682f46-1
                   qqc2-breeze-style5.26.4.r260.g6e00e57-15.26.4.r261.g86ff42e-1
                  qqc2-desktop-style5.100.0.r694.g0cf33c5-15.101.0.r700.gc6e4a13-1
                                rocs22.08.3.r3154.g2a82913e-122.12.0.r3155.g1dcae0ea-1
                            sddm-kcm5.26.4.r706.g30665d9-15.26.4.r708.g71a0175-1
            signon-kwallet-extension22.08.3.r83.ga3e7eac-122.12.0.r83.ga3e7eac-1
                               solid5.100.0.r828.g08825c7-15.101.0.r831.g4b07132-1
                              sonnet5.100.0.r735.gecc9949-15.101.0.r741.g53ab432-1
                            spacebar  22.11.r6.ge8baff4-1  22.11.r8.g2169eeb-1
                           spectacle22.08.3.r1431.g5ebca08-122.12.0.r1448.g9b51a50-1
                                step22.08.3.r1281.g2c848cf-122.12.0.r1282.gebc4e93-1
                             svgpart22.08.3.r255.g0ab7610-122.12.0.r257.g7c845bc-1
                             sweeper22.08.3.r610.g58e14bd-122.12.0.r611.g51ca057-1
                         syndication5.100.0.r892.g37b2cec-15.101.0.r893.gfd549df-1
                 syntax-highlighting5.100.0.r2030.g8c75a1d1-15.101.0.r2045.g6b969864-1
                      systemsettings5.26.4.r2781.g40b0747e-15.26.4.r2785.g74727e7a-1
          telepathy-kde-accounts-kcm22.08.3.r1232.g10ab4d3-122.12.0.r1235.ga0ea27d-1
              telepathy-kde-approver22.08.3.r317.g8394cdf-122.12.0.r318.ge894903-1
          telepathy-kde-auth-handler22.08.3.r296.ga842d5c-122.12.0.r299.geb5d165-1
               telepathy-kde-call-ui22.08.3.r464.g358a39e-122.12.0.r465.g3de3665-1
      telepathy-kde-common-internals22.08.3.r2038.gc8b2cde-122.12.0.r2039.ga57e7bd-1
          telepathy-kde-contact-list22.08.3.r1108.g6efb8b0-122.12.0.r1111.gd96a8a8-1
        telepathy-kde-contact-runner22.08.3.r278.g9bfe4e8-122.12.0.r279.g508c050-1
       telepathy-kde-desktop-applets22.08.3.r1019.ge3b074b-122.12.0.r1020.g2acdfb1-1
  telepathy-kde-filetransfer-handler22.08.3.r239.gc96a51b-122.12.0.r241.g793bde1-1
    telepathy-kde-integration-module22.08.3.r415.gd338d2c-122.12.0.r419.g2361e9e-1
             telepathy-kde-send-file22.08.3.r249.g3a0a7db-122.12.0.r250.g36a11a1-1
               telepathy-kde-text-ui22.08.3.r2067.gbccef2b1-122.12.0.r2072.g5d630da9-1
                        threadweaver5.100.0.r561.gd4afa61-15.101.0.r562.gbfbf745-1
                             tokodon22.11.1.r9.g1fd9e7f-122.11.1.r19.g8532b9c-1
                         vakzination  22.11.r3.g75a7eb4-1  22.11.r5.g5c0738e-1
                               vvave 2.2.1.r10.g44c1639-1 2.2.1.r13.g8c9f1ae-1
              xdg-desktop-portal-kde5.26.4.r578.g6d446ea-15.26.4.r582.gc53684f-1
                             yakuake22.08.3.r859.gd94682d-122.12.0.r861.g63cc5a2-1
                    zeroconf-ioslave22.08.3.r394.gd86416e-122.12.0.r394.gd86416e-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
2022-11-20
OpenSSL 1.1 library not found
Some applications might still be looking for openssl 1.1.
Solution: Install openssl-1.1 package with sudo pacman -S openssl-1.1.
2022-10-31
Firefox shows wrong colors when playing video on Raspberry Pi 4
Since Mesa 22.2, Firefox has been showing weird colors when playing video on the Raspberry Pi 4. This is caused by an issue in upstream mesa, which was recently fixed.
Fix: Update to mesa 22.2.3-0.1 in the repository, which includes this fix.
Chromium in Wayland crashes with --in-process-gpu
Since Mesa 22.2.0, Chromium running in wayland sessions seems to crash when running with the --in-process-gpu option. Running in X11 seems fine, although it’s slow.
Workaround: Downgrade to mesa 22.1.7 from cache with sudo pacman -U /var/cache/pacman/pkg/mesa-22.1.7-*, until the issue is fixed upstream.
2022-10-21
Plasma Mobile Dialer seems to be unreliable
Plasma Dialer 22.09 seems to have issues switching audio profiles and as such might require manual switching. Sometimes audio is completely missing.
Reduced video performance on youtube
Some may encounter reduced video playback performance on YouTube in Firefox with the new Mesa 22.2 drivers.
No workaround at this time.
Old Issues
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
[Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Hi,
Odroid c4, n2, m1 up to date, the devices running kde, kernel 6.1
[nlc4@c4 ~]$ screenfetch
                             nlc4@c4.test.2020.05.14
                             OS: Manjaro-ARM 22.12
                             Kernel: aarch64 Linux 6.1.0-1-MANJARO-ARM
         #####               Uptime: 4m
        #######              Packages: Unknown
        ##O#O##              Shell: bash 5.1.16
        #######              Resolution: 1920x1080
      ###########            DE: KDE 5.101.0 / Plasma 5.26.4
     #############           WM: KWin
    ###############          GTK Theme: Breeze [GTK2/3]
    ################         Icon Theme: oxygen
   #################         Disk: 12G / 59G (21%)
 #####################       CPU: Unknown @ 4x 1.908GHz
 #####################       GPU: Mali-G31 (Panfrost)
   #################         RAM: 827MiB / 3670MiB
[nlc4@c4 ~]$
Odroid c2 not up to date until now, but soon !
I hope…
Edit 2022.12.17
the beautiful and powerful Odroid C2 is up to date :slight_smile:
[nls@c2 ~]$ date -u
sam. 17 déc. 2022 17:13:57 UTC
[nls@c2 ~]$ screenfetch
                             nls@c2
                             Kernel: aarch64 Linux 5.14.10-1-MANJARO-ARM
         #####               Uptime: 3m
 #####################       CPU: 4x Unknown
 #####################       GPU: Mali450
   #################         RAM: 1045MiB / 1952MiB
[nls@c2 ~]$
Beelink GT King Pro upgraded to Arm-Testing-Update-2022-12-16 successfully.
Also installed the latest linux-aml-6.0.13-1.
Edit: With the latest mesa-22.3.1-0.1 Chromium Wayland
chromium --incognito --ozone-platform-hint=wayland
No longer have WebGL support anymore.
Does this have anything to do with mesa hwdec config?
@Strit
Hi, after finishing this update, I shutdown, waited a couple of seconds, and powered my Pinebook Pro back on. It acted normally through uboot, switching the LED from orange to green, flashing some full screen artifacts, and then got stuck at a black screen before the display manager/login screen.
Edit: at this point I tried to bring up the other tty to login to command line but there’s no response to the keyboard.
I tried to boot from an sdcard or USB stick, but that makes no difference in behavior as uboot seems to ignore them. Manjaro is on the emmc along with uboot 2022.04-4. I haven’t touched the SPI.
I opened the back and flipped the emmc switch. Then the LED stayed orange! Uh oh, I thought this was an escalation to quite a powerful strategy, but if this doesn’t work, what then?
Hi @spikerguy and @Strit
FYI, on Debian Sid with mesa-22.3.1 and Chromium-108.0.5359.124-1~deb11u1
chromium --ozone-platform-hint=wayland
Would not start properly.
With mesa-22.2.y:
WebGL is “HW Accelerated with Reduced Performance…” same as in Manjaro-Arm with Mesa 22.2.y
With mesa-22.1.3
chromium --ozone-platform-hint=wayland --no-sandbox --test-type
WebGL HW Accelerated
Same as in Manjaro-Arm mesa-22.1.7 is currently the best option for Chromium Wayland with WebGL HW Acceleration.
No idea what Chromium uses to do WebGL. Only the video codecs for AMD (as far as I know) have been disabled in Mesa.
Sounds like it’s a general Mesa issue then as it’s also happening on other distributions.
Does this means, on Manjaro-Arm the mesa still support h264/h265?
The platforms (meson, hantro and sunxi) uses different methods. So they never had it.
3 posts were split to a new topic: Schroot core dump
Manjaro-Phosh on Pinephone Original. Firefox doesn’t register swipes or presses on any webpage. In the gui (Menu, tabs) presses register but on the actual webpages you can’t do anything. No idea how to solve. Worked before update.
Can’t downgrade because firefox detects it and says that downgrading can corrupt bookmarks and doesn’t allow you to use it if downgraded.
Edit:
Managed to get around these issues by downgrading firefox from version 108 to 107 and then deleting the .mozilla folder and replacing it with a backup from a couple of days ago when I was still running 107…
