With the latest schroot’s package i have
/usr/include/c++/12.1.0/bits/stl_vector.h:1123: std::vector<_Tp, _Alloc>::reference std::vector<_Tp, _Alloc>::operator[](size_type) [with _Tp = char; _Alloc = std::allocator<char>; reference = char&; size_type = long unsigned int]: Assertion '__n < this->size()' failed.
Abandon (core dumped)
I have seen the old pkgbuild and now they use cmake and i want to test if the option “dchroot” make a change : old config the differences are :
--enable-dchroot \
--with-bash-completion-dir=/usr/share/bash-completion/completions/ \
how do i enable with cmake :
dchroot=(ON|OFF) Enable dchroot compatibility`
in the new pkgbuild :
cd build
cmake \
-DCMAKE_INSTALL_PREFIX=/usr \
-DCMAKE_INSTALL_LIBEXECDIR=/usr/lib \
-DCMAKE_INSTALL_SYSCONFDIR=/etc \
make
