Hello ARM community.
Lots of Plasma stuff and new PlaMo Gear.
New incoming call screen in Plasma Dialer 22.11
Some highlights:
- Most of our kernels got updated
- Firefox updated to 107.0.1
- Plasma updated to 5.26.4
- Plasma Mobile Gear updated to 22.11
- Electron updated to 22.0.0
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Mon Dec 5 20:58:40 CET 2022)
- arm-testing community aarch64: 543 new and 525 removed package(s)
- arm-testing core aarch64: 50 new and 54 removed package(s)
- arm-testing extra aarch64: 381 new and 391 removed package(s)
- arm-testing kde-unstable aarch64: 389 new and 389 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-11-26 2022-12-05
alligator 22.09-1 22.11-1
angelfish 22.09-1 22.11-1
audiotube 22.09-1 22.11-1
bitwarden 2022.10.1-1 2022.11.0-1
buteo-sync-plugins-social 0.4.17-1 0.4.18-1
calindori 22.09-1 22.11-1
chatty 0.7.0rc3-1 0.7.0rc4-1
contactsd 1.4.10-1 1.4.13-1
dino-mobile 0.2.1-4 0.2.1-5
electron 21.3.1-1 22.0.0-1
electron19 19.1.7-1 19.1.8-1
gradience 0.3.2-1 0.3.3-1
kalk 22.09-1 22.11-1
kasts 22.09.2-1 22.11-1
kclock 22.09-1 22.11-1
koko 22.09-1 22.11-1
kongress 22.09-1 22.11-1
krecorder 22.09-1 22.11-1
ktrip 22.09-1 22.11-1
kweather 22.09-1 22.11-1
libgbinder 1.1.29-1 1.1.30-1
libpackagekit-glib 1.2.5-2 1.2.6-1
libqofono-qt5 0.113-1 0.115-1
lipstick-glacier-home 0.37.7-2 0.37.8-2
mce 1.112.0-1 1.113.0-1
mce-headers 1.31.0-1 1.32.0-1
megapixels-ppp 1.5.2-4 1.5.2-5
mkcal 0.6.9-1 0.6.11-1
nemo-qml-plugin-systemsettings 0.9.0-3 0.10.0-2
ohm 1.3.1-1 1.3.1-2
packagekit 1.2.5-2 1.2.6-1
phoc 0.21.1-3 0.21.1-4
phosh 0.22.0-10.22.0+11+gb1fc33d9-1
phosh-antispam 2.1.1-1 3.0.0-1
plasma-dialer 22.09-3 22.11-1
plasma-phonebook 22.09-1 22.11-1
plasmatube 22.09-1 22.11-1
pulseaudio-module-keepalive 1.0.1.r0.g3102ee5-3 1.1.0-4
pulseaudio-modules-nemo14.2.30.r0.gd0dfdc3-1 16.1-1
pulsecore-headers 15.0-3 16.1-1
python-cssutils 2.6.0-1 -
qmlkonsole 22.09-1 22.11-1
qt5-lipstick 0.45.3-1 0.46.2-1
qtdocgallery 5.3.0+git4-1 5.3.0+git5-1
rpi-eeprom 20221125-1 20221205-1
spacebar 22.09-1 22.11-1
squeekboard 1.20.0-2 1.20.0+36+gf4c03ce-1
tokodon 22.09-1 -
topgrade 10.1.2-1 10.2.1-2
tzdata-timed 2021a+git1-1 2021a+git3-1
usb-moded 0.86.0+mer59-1 0.86.0+mer62-1
vakzination 22.09-1 22.11-1
voicecall 0.7.14-1 0.8.0-1
vvmplayer 1.5-2 2.0.0-1
waydroid-image 17.1_20220723-1 18.1_20221111-1
dsme - 0.84.0-1
electron21 - 21.3.1-1
ffmpeg-rk - 1:4.4.1-3
kodi-rk - 20.0b1-1
kodi-rk-dev - 20.0b1-1
kodi-rk-eventclients - 20.0b1-1
kodi-rk-tools-texturepacker - 20.0b1-1
mpv-rk - 1:0.35.0-3
pulseaudio-policy-enforcement - 14.2.47-1
:: Different sync package(s) in repository community aarch64
aliyun-cli 3.0.136-1 3.0.139-1
ansible-lint 6.9.0-1 6.9.1-1
arch-repro-status 1.3.2-1 1.3.3-1
arduino-cli 0.27.1-1 0.29.0-1
argocd 2.5.2-1 2.5.3-1
arrow 10.0.0-1 10.0.1-1
autopep8 1:1.7.1-1 1:2.0.0-1
awxkit 21.9.0-1 21.10.0-1
b3sum 1.3.2-1 1.3.3-1
babel-core 7.20.2-1 7.20.5-1
bash-language-server 3.2.0-1 3.3.1-1
bitsery 5.2.2-1 5.2.3-1
bitwarden-cli 2022.10.0-1 2022.11.0-1
blueprint-compiler 0.4.0-1 0.6.0-1
boinc 7.20.2-2 7.20.3-1
boinc-nox 7.20.2-2 7.20.3-1
budgie-desktop 10.6.4-4 10.6.4-5
buho 2.2.0-1 2.2.1-1
buildah 1.28.0-1 1.28.2-1
cargo-auditable 0.5.4-1 0.5.5-1
cargo-depgraph 1.3.0-1 1.4.0-1
cargo-nextest 0.9.43-1 0.9.44-1
cargo-pgx 0.5.6-2 0.6.0-1
cargo-release 0.23.1-1 0.24.0-1
cargo-tauri 1.1.2-1 1.2.1-1
cargo-zigbuild 0.14.1-1 0.14.2-1
certbot 1.32.0-1 2.0.0-1
certbot-apache 1.32.0-1 2.0.0-1
certbot-dns-cloudflare 1.32.0-1 2.0.0-1
certbot-dns-digitalocean 1.32.0-1 2.0.0-1
certbot-dns-dnsimple 1.32.0-1 2.0.0-1
certbot-dns-dnsmadeeasy 1.32.0-1 2.0.0-1
certbot-dns-gehirn 1.32.0-1 2.0.0-1
certbot-dns-google 1.32.0-1 2.0.0-1
certbot-dns-linode 1.32.0-1 2.0.0-1
certbot-dns-luadns 1.32.0-1 2.0.0-1
certbot-dns-nsone 1.32.0-1 2.0.0-1
certbot-dns-ovh 1.32.0-1 2.0.0-1
certbot-dns-rfc2136 1.32.0-1 2.0.0-1
certbot-dns-route53 1.32.0-1 2.0.0-1
certbot-dns-sakuracloud 1.32.0-1 2.0.0-1
certbot-nginx 1.32.0-1 2.0.0-1
chezmoi 2.27.2-1 2.27.3-1
cinnamon 5.6.1-1 5.6.4-1
cinnamon-screensaver 5.6.1-1 5.6.2-1
clash 1.11.12-1 1.12.0-1
cloudflared 2022.11.0-1 2022.11.1-1
cockpit 280-1 281-1
cockpit-machines 278-1 279-1
cockpit-packagekit 280-1 281-1
cockpit-pcp 280-1 281-1
cockpit-podman 57-1 58-1
cockpit-storaged 280-1 281-1
codespell 2.2.2-2 2.2.2-3
communicator 2.2.0-1 2.2.1-1
cosign 1.13.1-1 1.13.1-2
crun 1.7.1-1 1.7.2-1
cxxbridge 1.0.82-1 1.0.83-1
dagger 0.3.2-1 0.3.7-1
danmaq 0.2.3.1-1 0.2.3.2-1
dart 2.18.4-1 2.18.5-1
datovka 4.21.0-3 4.21.1-1
deepin-qt5platform-plugins 5.0.68-1 5.0.70-1
deja-dup 43.4-1 44.0-1
diffoscope 224-1 228-1
docker-scan 0.22.0-1 0.23.0-1
dpkg 1.21.9-1 1.21.11-1
dra 0.4.1-1 0.4.2-1
duplicity 1.0.1-2 1.2.1-1
emscripten 3.1.25-1 3.1.26-1
faudio 22.11-1 22.12-1
fcitx5-bamboo 1.0.1-1 1.0.2-1
fcitx5-pinyin-zhwiki 1:0.2.4.20221029-1 1:0.2.4.20221128-1
fcron 3.3.0-1 3.3.1-1
featherpad 1.3.3-1 1.3.4-1
firecracker 1.1.3-1 1.2.0-1
firecracker-docs 1.1.3-1 1.2.0-1
firefox-tridactyl 1.22.1-1 1.23.0-1
firewalld 1.2.1-1 1.2.2-1
flake8 1:5.0.4-2 1:6.0.0-1
flashgbx 3.19-1 3.20-1
fq 0.0.10-1 0.1.0-1
ft2-clone 1.61-1 1.62-1
fuse-overlayfs 1.9-1 1.10-1
gajim 1.5.3-1 1.5.4-2
gcolor2 0.4-9 -
gdal 3.6.0-2 3.6.0-4
geos 3.11.0-1 3.11.1-1
gerbv 2.9.4-1 2.9.5-1
git-delta 0.14.0-2 0.15.1-1
glacier-calc 0.3.2-1 0.3.3-1
go-yq 4.30.4-1 4.30.5-1
goaurrpc 1.2.0-1 1.2.2-1
gopass 1.14.10-1 1.14.11-1
gpg-tui 0.9.1-1 0.9.2-1
gpxsee 11.9-1 11.10-1
grpc 1.51.0-1 1.51.1-1
grpc-cli 1.51.0-1 1.51.1-1
hamlib 4.5-1 4.5-2
haproxy 2.6.6-2 2.7.0-1
hid-tools 0.2-7 0.3.1-1
home-assistant 1:2022.11.3-1 1:2022.11.5-1
hotdoc 0.13.7-3 0.14.0-1
hugo 0.105.0-1 0.107.0-1
iaito 5.7.0-2 5.7.8-1
index-fm 2.2.0-1 2.2.1-1
ipython 8.6.0-1 8.7.0-1
jacktrip 1:1.6.6-1 1:1.6.7-1
jenkins 2.379-1 2.380-1
jupyter-nbclient 0.7.0-1 0.7.2-1
just 1.8.0-1 1.9.0-1
keysmith 22.09-2 22.11-1
kiwix-desktop 2.3.0-1 2.3.1-1
kiwix-tools 3.3.0-2 3.4.0-1
klayout 0.27.12-1 0.27.13-1
kstars 1:3.6.1-2 1:3.6.2-1
kvantum 1.0.6-1 1.0.7-1
latte-dock 0.10.8-2 0.10.9-1
lego 4.9.0-1 4.9.1-1
libabigail 2.1-2 2.2-1
libblastrampoline 5.2.0-1 5.3.0-1
libdeflate 1.14-1 1.15-1
libdwarf 1:0.4.0-1 1:0.5.0-1
libffado 2.4.6-1 2.4.7-1
libglacierapp 0.8.2-1 0.9-1
libime 1.0.15-1 1.0.16-1
libindi 1.9.8-2 1.9.9-1
libkiwix 11.0.0-3 12.0.0-1
liblscp 0.9.6-1 0.9.7-1
libnewt 0.52.22-1 0.52.23-1
libsemigroups 2.3.2-1 2.4.0-1
libvirt 1:8.9.0-1 1:8.10.0-1
libvirt-python 1:8.9.0-1 1:8.10.0-1
libvirt-storage-gluster 1:8.9.0-1 1:8.10.0-1
libvirt-storage-iscsi-direct 1:8.9.0-1 1:8.10.0-1
libzim 8.0.1-2 8.1.0-1
lightdm-webkit-theme-litarvan 3.1.0-1 3.2.0-1
lua-language-server 3.6.3-1 3.6.4-1
lua-luautf8 0.1.4-4 0.1.5-1
lua51-luautf8 0.1.4-4 0.1.5-1
lua52-luautf8 0.1.4-4 0.1.5-1
lua53-luautf8 0.1.4-4 0.1.5-1
luajit2.1.0.beta3.r455.g46aa45dc-12.1.0.beta3.r457.g637721d0-1
lutris 0.5.11-2 0.5.12-1
mame 0.249-2 0.250-1
mame-tools 0.249-2 0.250-1
marked-man 1.2.3-1 1.3.0-1
maturin 0.14.2-1 0.14.3-1
maui-clip 2.2.0-1 2.2.1-1
maui-nota 2.2.0-1 2.2.1-1
maui-pix 2.2.0-1 2.2.1-1
maui-shelf 2.2.0-1 2.2.1-1
maui-station 2.2.0-1 2.2.1-1
mauikit 2.2.0-1 2.2.1-1
mauikit-accounts 2.2.0-1 2.2.1-1
mauikit-filebrowsing 2.2.0-1 2.2.1-1
mauikit-imagetools 2.2.0-1 2.2.1-1
mauikit-texteditor 2.2.0-1 2.2.1-1
mauiman 1.0.0-1 1.0.1-1
mdbook 0.4.21-1 0.4.22-1
mdcat 0.29.0-1 0.30.3-1
mediawiki 1.38.4-1 1.39.0-1
mg 20220614-1 20221112-1
miller 6.4.0-1 6.5.0-1
mopidy 3.3.0-1 3.4.0-1
muffin 5.6.0-1 5.6.1-1
mujs 1.3.1-1 1.3.2-1
mympd 10.1.2-1 10.1.3-1
n2n 3.1.0-1 3.1.1-1
ncnn 20220729-1 20221128-1
nemo-qml-plugin-notifications 1.0.12-1 1.1.0-1
neochat 22.09-1 22.11-1
netdata 1.36.1-2 1.37.0-1
nextcloud-app-mail 2.1.0-1 2.1.2-1
nextcloud-app-news 19.0.0-1 19.0.1-1
nickle 2.86-1 2.90-1
nicotine+ 3.2.6-1 3.2.7-1
nodejs 19.1.0-1 19.2.0-1
nodejs-lts-fermium 14.20.0-2 14.21.0-1
npm-check-updates 16.3.23-1 16.4.2-1
nsjail 3.1-3 3.2-1
nuitka 1.2-1 1.2.1-1
nushell 0.71.0-1 0.72.0-1
onefetch 2.13.2-2 2.14.2-1
opensearch-dashboards 2.3.0-1 2.4.0-1
opensearch-dashboards-alerting-plugin 2.3.0.0-1 2.4.0.0-1
opensearch-dashboards-anomaly-detection-plugin 2.3.0.0-1 2.4.0.0-1
opensearch-dashboards-gantt-chart-plugin 2.3.0.0-1 2.4.0.0-1
opensearch-dashboards-index-management-plugin 2.3.0.0-1 2.4.0.0-1
opensearch-dashboards-notifications-plugin 2.3.0.0-1 2.4.0.0-1
opensearch-dashboards-observability-plugin 2.3.0.0-1 2.4.0.0-1
opensearch-dashboards-query-workbench-plugin 2.3.0.0-1 2.4.0.0-1
opensearch-dashboards-reports-plugin 2.3.0.0-1 2.4.0.0-1
opensearch-dashboards-security-plugin 2.3.0.0-1 2.4.0.0-1
openvdb 10.0.0-1 10.0.1-1
osinfo-db 20221018-1 20221130-1
owncloud-client 2.11.1.8946-1 3.0.0.9215-1
oxyromon 0.9.0-2 0.13.0-1
p2pool 2.5-1 2.6-1
packagekit-qt5 1.0.2-1 1.1.0-1
pan 0.151-1 0.153-1
pantheon-screenshot 6.0.2-2 6.0.3-1
papirus-icon-theme 20221101-1 20221201-1
pdfarranger 1.9.1-1 1.9.2-1
pdfjs 3.0.279-1 3.1.81-1
pdfjs-legacy 3.0.279-1 3.1.81-1
perl-log-any 1.710-2 1.711-1
perl-par-packer 1.056-1 1.057-1
perl-term-readline-gnu 1.42-2 1.45-1
php-grpc 1.51.0-1 1.51.1-1
php7-grpc 1.51.0-1 1.51.1-1
poedit 1:3.2.1-1 1:3.2.2-1
pyenv 2.3.6-1 2.3.7-1
pyright 1.1.281-1 1.1.282-1
pysolfc 2.16.0-1 2.18.0-1
python-acme 1.32.0-1 2.0.0-1
python-aiobotocore 2.4.0-1 2.4.1-1
python-ansible-compat 2.2.5-1 2.2.6-1
python-asttokens 2.1.0-1 2.2.0-1
python-auditwheel 5.1.2-1 5.3.0-1
python-awkward 1.10.1-1 1.10.2-1
python-binaryornot 0.4.4-6 0.4.4-7
python-biopython 1.79-3 1.80-1
python-cbor2 5.4.3-2 5.4.5-1
python-cftime 1.6.1-1 1.6.2-1
python-cheroot 8.6.0-2 9.0.0-1
python-cherrypy 18.8.0-1 18.8.0-2
python-cloudflare 2.10.5-1 2.11.1-1
python-cryptography-vectors 38.0.3-1 38.0.4-1
python-dask 2022.10.2-1 2022.11.1-1
python-database-knotinfo 2022.11.1-1 2022.12.1-1
python-databases 0.6.1-1 0.6.2-1
python-debugpy 1.6.3-1 1.6.4-1
python-deepdiff 5.8.2-1 6.0.0-1
python-diff-cover 7.0.2-1 7.2.0-1
python-distributed 2022.10.2-1 2022.11.1-1
python-django-classy-tags 3.0.1-1 4.0.0-1
python-docstring-to-markdown 0.10-1 0.11-1
python-edalize 0.3.0-1 0.4.0-1
python-faker 12.3.0-1 13.1.0-1
python-fakeredis 2.0.0-2 2.2.0-1
python-falcon 3.1.0-1 3.1.1-1
python-fastapi 0.87.0-1 0.88.0-1
python-filetype 1.0.10-1 1.2.0-1
python-gdal 3.6.0-2 3.6.0-4
python-gdstk 0.9.3-1 0.9.5-1
python-geopandas 0.11.1-1 0.12.1-1
python-gitdb 1:4.0.9-1 1:4.0.10-1
python-gitlab 3.11.0-1 3.12.0-1
python-google-auth 2.10.0-1 2.12.0-1
python-grpcio 1.51.0-1 1.51.1-1
python-grpcio-tools 1.51.0-1 1.51.1-1
python-hachoir 3.1.3-1 3.2.0-1
python-httpcore 0.16.1-1 0.16.2-1
python-husl 4.0.3-9 4.0.3-10
python-hypothesis 6.54.4-3 6.59.0-1
python-hypothesmith 0.2.0-1 0.2.1-1
python-ipykernel 6.18.0-1 6.18.1-1
python-jinja-time 0.2.0-7 0.2.0-8
python-jsonschema 4.17.1-1 4.17.3-1
python-jupyter_core 5.0.0-1 5.1.0-1
python-keyrings-alt 1:4.1.1-1 1:4.2.0-1
python-kikit 1.1.1-1 1.1.2-1
python-kubernetes 24.2.0-1 25.3.0-1
python-libcst 0.3.20-4 0.4.9-2
python-litedram 2021.04-1 2021.08-1
python-liteeth 2021.04-1 2021.08-1
python-liteiclink 2021.04-1 2021.08-1
python-litejesd204b 2021.04-1 2021.08-1
python-litepcie 2021.04-1 2021.08-1
python-litesata 2021.04-1 2021.08-1
python-litescope 2021.04-1 2021.08-1
python-litesdcard 2021.04-1 2021.08-1
python-litevideo 2021.04-1 2021.08-1
python-litex 2021.04-1 2021.08-1
python-litex-boards 2021.04-1 2021.08-1
python-lsp-server 1.6.0-1 1.6.0-2
python-mss 6.1.0-2 7.0.1-1
python-mt-940 4.26.0-1 4.27.0-1
python-netcdf4 1.6.1-1 1.6.2-1
python-openstacksdk 0.102.0-2 0.103.0-1
python-orderedmultidict 1.0.1-8 1.0.1-9
python-orjson 3.8.2-1 3.8.3-1
python-oslo-utils 6.0.1-1 6.1.0-1
python-path 16.5.0-1 16.6.0-1
python-persistent 4.9.2-1 4.9.3-1
python-pgpy 0.5.4-3 0.6.0-1
python-phonenumbers 8.13.0-1 8.13.1-1
python-phpserialize 1.3-9 1.3-10
python-pikepdf 6.2.4-1 6.2.5-1
python-pipenv 2022.11.11-1 2022.11.30-1
python-pkginfo 1.8.3-1 1.9.2-1
python-poetry-plugin-export 1.1.2-1 1.2.0-1
python-psycopg2 2.9.3-2 2.9.5-1
python-pycapnp 1.2.1-1 1.2.2-1
python-pycryptodome 3.15.0-3 3.16.0-1
python-pyflakes 2.5.0-1 3.0.1-1
python-pygeos 0.12.0-2 0.13-1
python-pyglet 2.0.0-2 2.0.1-1
python-pylint 2.15.6-1 2.15.7-1
python-pymediainfo 5.1.0-3 6.0.1-1
python-pynitrokey 0.4.30-1 0.4.31-1
python-pyocd 0.34.2-1 0.34.3-1
python-pyphen 0.13.1-1 0.13.2-1
python-pyspnego 0.6.2-1 0.6.3-1
python-pystemmer 2.0.1-4 2.2.0-1
python-pytest-enabler 1.3.1-1 2.0.0-1
python-pytest-mypy 0.10.1-1 0.10.2-1
python-pytest-testinfra 6.8.0-2 7.0.0-1
python-pytest-xdist 3.0.2-1 3.1.0-1
python-pytest-xprocess 0.20.0-1 0.21.0-1
python-qt.py 1.2.6-1 1.3.7-1
python-qtpy 2.2.1-2 2.3.0-1
python-rope 1.4.0-1 1.5.1-1
python-rpyc 5.2.3-1 5.3.0-1
python-seaborn 0.11.2-3 0.12.1-1
python-smbprotocol 1.9.0-1 1.10.1-1
python-sphinx-autodoc-typehints 1.13.1-1 1.19.5-1
python-sphinx_rtd_theme 1.0.0-5 1.1.1-1
python-sphobjinv 2.3-1 2.3.1-1
python-sqlalchemy 1.4.43-2 1.4.44-1
python-sqlalchemy-continuum 1.3.12-1 1.3.13-1
python-sqlitedict 2.0.0-1 2.1.0-1
python-sshtunnel 0.4.0-3 0.4.0-4
python-stack-data 0.6.1-1 0.6.2-1
python-statsmodels 0.13.2-3 0.13.5-1
python-subprocess-tee 0.3.5-4 0.4.0-1
python-subunit 1.4.0-5 1.4.1-1
python-sword 1.9.0-6 1.9.0-7
python-tempora 5.0.2-1 5.1.0-1
python-termcolor 2.1.0-1 2.1.1-1
python-texttable 1.6.5-1 1.6.7-1
python-traitlets 5.5.0-1 5.6.0-1
python-tzdata 2022.6-1 2022.7-1
python-ujson 5.5.0-1 5.6.0-1
python-vistir 0.7.4-1 0.7.5-1
python-w3lib 2.0.1-1 2.1.0-1
python-whatthepatch 1.0.2-1 1.0.3-1
python-wxpython 1:4.1.1-3 1:4.2.0-3
python-xarray 2022.06.0-1 2022.10.0-1
python-xattr 0.10.0-1 0.10.1-1
python-zipp 3.10.0-1 3.11.0-1
python-zope-copy 4.2-7 4.3-1
python-zope-location 4.2-8 4.3-1
python-zope-security 5.7-1 5.8-1
qbittorrent 4.4.5-2 4.5.0-1
qbittorrent-nox 4.4.5-2 4.5.0-1
qt5-quickcontrols-nemo 5.7-1 5.7.2-1
r2ghidra 5.6.2.r1.ga4ba1ddc-1 5.7.8-1
radare2 5.6.6-3 5.7.8-1
rathole 0.4.5-1 0.4.7-1
rawtherapee 1:5.8-3 1:5.9-1
reaper 6.70-1 6.71-1
redmine 5.0.3-1 5.0.4-1
rekor 1.0.1-1 1.0.1-2
remmina 1:1.4.27-4 1:1.4.28-1
rgbds 0.6.0-1 0.6.1-1
rime-pinyin-zhwiki 1:0.2.4.20221029-1 1:0.2.4.20221128-1
rnote 0.5.7-1 0.5.8-1
rubberband 3.1.1-1 3.1.2-1
ruby-abbrev 0.1.0-3 0.1.0-4
ruby-base64 0.1.1-3 0.1.1-4
ruby-benchmark 0.2.0-3 0.2.0-4
ruby-bigdecimal 3.1.2-3 3.1.2-4
ruby-bundler 2.3.23-1 2.3.25-1
ruby-cgi 0.3.3-1 0.3.6-1
ruby-covered 0.18.3-1 0.18.4-1
ruby-csv 3.2.5-3 3.2.5-4
ruby-cucumber-compatibility-kit 11.0.1-2 11.0.1-3
ruby-cucumber-cucumber-expressions 16.0.1-1 16.1.0-1
ruby-date 3.2.2-3 3.2.2-4
ruby-delegate 0.2.0-3 0.2.0-4
ruby-did_you_mean 1.6.1-3 1.6.1-4
ruby-digest 3.1.0-5 3.1.0-6
ruby-drb 2.1.0-4 2.1.0-5
ruby-english 0.7.1-3 0.7.1-5
ruby-erb 2.2.3-4 4.0.2-1
ruby-etc 1.3.0-5 1.3.0-6
ruby-fcntl 1.0.1-3 1.0.1-4
ruby-fiddle 1.1.0-3 1.1.0-4
ruby-fileutils 1.6.0-3 1.6.0-4
ruby-find 0.1.1-3 0.1.1-4
ruby-forwardable 1.3.2-5 1.3.2-6
ruby-getoptlong 0.1.1-2 0.1.1-3
ruby-io-console 0.5.11-2 0.5.11-3
ruby-io-nonblock 0.1.0-2 0.1.0-3
ruby-io-wait 0.2.3-3 0.2.3-4
ruby-ipaddr 1.2.4-2 1.2.4-3
ruby-logger 1.5.1-2 1.5.1-3
ruby-mutex_m 0.1.1-2 0.1.1-3
ruby-nats-pure 2.2.0-1 2.2.1-1
ruby-parser 3.1.2.1-1 3.1.3.0-1
ruby-parslet 1.8.2-1 2.0.0-1
ruby-pg 1.4.4-1 1.4.5-1
ruby-puppet_metadata 1.8.0-1 1.9.0-1
ruby-sequel 5.62.0-1 5.63.0-1
ruby-sus 0.15.0-2 0.15.1-1
ruby-sys-proctable 1.2.6-3 1.2.7-1
ruby-timecop 0.9.5-1 0.9.6-1
rust-analyzer 20221121-1 20221128-1
rust-bindgen 0.62.0-1 0.63.0-1
scaleway-cli 2.6.1-1 2.6.2-1
schismtracker 20221020-1 20221201-1
scrapy 2.7.0-1 2.7.1-1
scribus 1.5.8-11 1.5.8-12
serverless 3.25.0-1 3.25.1-1
shim 15.6-1 15.7-1
shotcut 22.10.25-1 22.11.25-1
slurm-llnl 22.05.3.1-2 22.05.4.1-1
smartdns 38.1-2 39-1
smb4k 3.1.4-1 3.1.5-1
sox14.4.2+r182+g42b3557e-114.4.2+r182+g42b3557e-2
streamlink 5.1.1-1 5.1.2-1
stylelint 14.15.0-1 14.16.0-1
swaylock 1.6-2 1.7-1
sz 2.1.12-4 2.1.12.5-1
tcsh 6.24.02-1 6.24.05-1
terminology 1.12.1-1 1.13.0-1
terraform 1.3.5-1 1.3.6-1
texstudio 4.4.0-1 4.4.1-1
tokodon 22.09-1 22.11-1
trivy 0.34.0-1 0.35.0-1
tt-rss 2:r11392.9a0dcdd6c-1 2:r11406.292ca8666-1
ttc-iosevka 16.4.0-1 16.6.0-1
ttc-iosevka-aile 16.4.0-1 16.6.0-1
ttc-iosevka-curly 16.4.0-1 16.6.0-1
ttc-iosevka-curly-slab 16.4.0-1 16.6.0-1
ttc-iosevka-etoile 16.4.0-1 16.6.0-1
ttc-iosevka-slab 16.4.0-1 16.6.0-1
ttc-iosevka-ss01 16.4.0-1 16.6.0-1
ttc-iosevka-ss02 16.4.0-1 16.6.0-1
ttc-iosevka-ss03 16.4.0-1 16.6.0-1
ttc-iosevka-ss04 16.4.0-1 16.6.0-1
ttc-iosevka-ss05 16.4.0-1 16.6.0-1
ttc-iosevka-ss06 16.4.0-1 16.6.0-1
ttc-iosevka-ss07 16.4.0-1 16.6.0-1
ttc-iosevka-ss08 16.4.0-1 16.6.0-1
ttc-iosevka-ss09 16.4.0-1 16.6.0-1
ttc-iosevka-ss10 16.4.0-1 16.6.0-1
ttc-iosevka-ss11 16.4.0-1 16.6.0-1
ttc-iosevka-ss12 16.4.0-1 16.6.0-1
ttc-iosevka-ss13 16.4.0-1 16.6.0-1
ttc-iosevka-ss14 16.4.0-1 16.6.0-1
ttc-iosevka-ss15 16.4.0-1 16.6.0-1
ttc-iosevka-ss16 16.4.0-1 16.6.0-1
ttc-iosevka-ss17 16.4.0-1 16.6.0-1
ttc-iosevka-ss18 16.4.0-1 16.6.0-1
typos 1.13.0-1 1.13.3-1
ufmt 2.0.0-1 2.0.1-1
v2ray-domain-list-community 20221124015645-1 20221205040509-1
v2ray-geoip 202211240054-1 202212010055-1
vaultwarden-web 2022.10.2-1 2022.11.1-1
vdirsyncer 0.18.0-4 0.19.0-1
virt-firmware 1.6-1 1.7-1
vvave 2.2.0-1 2.2.1-1
warpinator 1.2.15-1 1.4.2-1
wasmer 3.0.0-1 3.0.2-1
wasmtime 3.0.0-1 3.0.1-1
waybar 0.9.16-1 0.9.16-2
web-ext 7.3.1-1 7.4.0-1
websvn 2.8.0-1 2.8.1-1
xapp 2.4.1-1 2.4.2-1
xdot 1.2-1 1.2-2
xournalpp 1.1.2-1 1.1.3-1
xplr 0.20.0-1 0.20.1-1
xsimd 9.0.1-1 10.0.0-1
yosys 0.22-1 0.23-1
zim-tools 3.1.2-1 3.1.3-1
libre-graph-api - 1.0.0-2
packagekit-qt6 - 1.1.0-1
prometheus-smokeping-prober - 0.6.1-1
python-aiohttp-oauthlib - 0.1.0-2
python-aiostream - 0.4.5-2
python-attrdict - 2.0.1-5
python-awkward-docs - 1.10.2-1
python-nptyping - 2.4.1-1
python-pyproject-hooks - 1.0.0-1
python-pyudev - 0.24.0-2.1
python-sphinxcontrib-apidoc - 0.3.0-2
python-tlv8 - 0.10.0-1
:: Different overlay package(s) in repository core aarch64
linux 6.0.9-1 6.0.11-1
linux-aml 5.13.rc5-1 6.0.10-1
linux-aml-headers 5.13.rc5-1 6.0.10-1
linux-headers 6.0.9-1 6.0.11-1
linux-khadas 5.19.17-1 -
linux-khadas-headers 5.19.17-1 -
linux-lts 5.15.79-1 5.15.81-1
linux-lts-headers 5.15.79-1 5.15.81-1
linux-odroid 6.0.8-1 6.0.9-1
linux-odroid-headers 6.0.8-1 6.0.9-1
linux-opi 6.0.9-4 6.0.11-1
linux-opi-headers 6.0.9-4 6.0.11-1
linux-pinephone 6.0.8-1 6.1.0rc8-1
linux-pinephone-headers 6.0.8-1 6.1.0rc8-1
linux-pinephonepro 6.0.8-1 6.1.0rc8-1
linux-pinephonepro-headers 6.0.8-1 6.1.0rc8-1
linux-rc 6.1.rc6-1 6.1.rc8-1
linux-rc-headers 6.1.rc6-1 6.1.rc8-1
linux-rpi4 5.15.79-1 5.15.80-1
linux-rpi4-headers 5.15.79-1 5.15.80-1
linux-rpi4-mainline 6.0.9-1 6.0.10-1
linux-rpi4-mainline-headers 6.0.9-1 6.0.10-1
linux-rpi4-rc 6.1.rc5-1 6.1.rc7-1
linux-rpi4-rc-headers 6.1.rc5-1 6.1.rc7-1
linux515 5.15.79-3 5.15.81-1
linux515-headers 5.15.79-3 5.15.81-1
linux519 5.19.17-1 -
linux519-headers 5.19.17-1 -
linux60 6.0.9-3 6.0.11-1
linux60-headers 6.0.9-3 6.0.11-1
manjaro-release 22.11-1 22.12-1
:: Different sync package(s) in repository core aarch64
btrfs-progs 6.0.1-1 6.0.2-1
cryptsetup 2.5.0-4 2.6.0-1
debuginfod 0.187-2 0.188-1
elfutils 0.187-2 0.188-1
glib2 2.74.1-1 2.74.3-1
glib2-docs 2.74.1-1 2.74.3-1
iputils 20211215-1 20221126-1
lemon 3.40.0-1 3.40.0-2
libelf 0.187-2 0.188-1
libnftnl 1.2.3-1 1.2.4-1
mpfr 4.1.1-1 4.1.1.p1-1
sed 4.8-1 4.9-1
sqlite 3.40.0-1 3.40.0-2
sqlite-analyzer 3.40.0-1 3.40.0-2
sqlite-doc 3.40.0-1 3.40.0-2
sqlite-tcl 3.40.0-1 3.40.0-2
systemd 252.2-1 252.2-3
systemd-libs 252.2-1 252.2-3
systemd-resolvconf 252.2-1 252.2-3
systemd-sysvcompat 252.2-1 252.2-3
tzdata 2022f-1 2022g-1
usbutils 015-1 015-2
xz 5.2.8-1 5.2.9-1
:: Different overlay package(s) in repository extra aarch64
libva-mesa-driver 22.2.4-0.2 22.2.4-0.3
mesa 22.2.4-0.2 22.2.4-0.3
mesa-git23.0.0_devel.163208.cee2c4624d0-1 -
mesa-vdpau 22.2.4-0.2 22.2.4-0.3
opencl-mesa 22.2.4-0.2 22.2.4-0.3
plasma-mobile 5.26.3-1 5.26.4-1
plasma-mobile-nm 5.26.3-1 5.26.4-1
plasma-wayland-session 5.26.3-0.2 -
plasma-workspace 5.26.3-0.2 -
qqc2-breeze-style 5.26.3-1 5.26.4-1
qt5-es2-base 5.15.7+kde+r175-1 5.15.7+kde+r176-1
qt5-es2-xcb-private-headers 5.15.7+kde+r174-1 5.15.7+kde+r176-1
snapd 2.57.5-1 2.58-1
vulkan-broadcom 22.2.4-0.2 22.2.4-0.3
vulkan-mesa-layers 22.2.4-0.2 22.2.4-0.3
vulkan-panfrost 22.2.4-0.2 22.2.4-0.3
vulkan-radeon 22.2.4-0.2 22.2.4-0.3
vulkan-swrast 22.2.4-0.2 22.2.4-0.3
wireplumber 0.4.12-1.1 0.4.12-2.1
wireplumber-docs 0.4.12-1.1 0.4.12-2.1
libwireplumber - 0.4.12-2.1
:: Different sync package(s) in repository extra aarch64
389-ds-base 2.3.0-2 2.3.1-1
adwaita-icon-theme 43-1 43-2
alsa-card-profiles 1:0.3.60-3 1:0.3.61-1
aura-browser 5.26.3-1 5.26.4-1
beanshell 2.1.0-1 2.1.1-1
bind 9.18.8-2 9.18.9-1
bluedevil 1:5.26.3-1 1:5.26.4-1
breeze 5.26.3.1-1 5.26.4-1
breeze-grub 5.26.3-1 5.26.4-1
breeze-gtk 5.26.3-1 5.26.4-1
calligra 3.2.1-38 3.2.1-39
cmake 3.25.0-1 3.25.1-1
digikam 7.8.0-2 7.9.0-1
discover 5.26.3-1 5.26.4-1
dleyna 0.8.1-1 0.8.2-1
dleyna-docs 0.8.1-1 0.8.2-1
dnsmasq 2.87-3 2.88-1
drkonqi 5.26.3-1 5.26.4-1
evolution 3.46.1-1 3.46.2-1
evolution-bogofilter 3.46.1-1 3.46.2-1
evolution-data-server 3.46.1-2 3.46.2-1
evolution-ews 3.46.1-1 3.46.2-1
evolution-spamassassin 3.46.1-1 3.46.2-1
firefox 107.0-1 107.0.1-1
firefox-i18n-ach 107.0-1 107.0.1-1
firefox-i18n-af 107.0-1 107.0.1-1
firefox-i18n-an 107.0-1 107.0.1-1
firefox-i18n-ar 107.0-1 107.0.1-1
firefox-i18n-ast 107.0-1 107.0.1-1
firefox-i18n-az 107.0-1 107.0.1-1
firefox-i18n-be 107.0-1 107.0.1-1
firefox-i18n-bg 107.0-1 107.0.1-1
firefox-i18n-bn 107.0-1 107.0.1-1
firefox-i18n-br 107.0-1 107.0.1-1
firefox-i18n-bs 107.0-1 107.0.1-1
firefox-i18n-ca 107.0-1 107.0.1-1
firefox-i18n-ca-valencia 107.0-1 107.0.1-1
firefox-i18n-cak 107.0-1 107.0.1-1
firefox-i18n-cs 107.0-1 107.0.1-1
firefox-i18n-cy 107.0-1 107.0.1-1
firefox-i18n-da 107.0-1 107.0.1-1
firefox-i18n-de 107.0-1 107.0.1-1
firefox-i18n-dsb 107.0-1 107.0.1-1
firefox-i18n-el 107.0-1 107.0.1-1
firefox-i18n-en-ca 107.0-1 107.0.1-1
firefox-i18n-en-gb 107.0-1 107.0.1-1
firefox-i18n-en-us 107.0-1 107.0.1-1
firefox-i18n-eo 107.0-1 107.0.1-1
firefox-i18n-es-ar 107.0-1 107.0.1-1
firefox-i18n-es-cl 107.0-1 107.0.1-1
firefox-i18n-es-es 107.0-1 107.0.1-1
firefox-i18n-es-mx 107.0-1 107.0.1-1
firefox-i18n-et 107.0-1 107.0.1-1
firefox-i18n-eu 107.0-1 107.0.1-1
firefox-i18n-fa 107.0-1 107.0.1-1
firefox-i18n-ff 107.0-1 107.0.1-1
firefox-i18n-fi 107.0-1 107.0.1-1
firefox-i18n-fr 107.0-1 107.0.1-1
firefox-i18n-fy-nl 107.0-1 107.0.1-1
firefox-i18n-ga-ie 107.0-1 107.0.1-1
firefox-i18n-gd 107.0-1 107.0.1-1
firefox-i18n-gl 107.0-1 107.0.1-1
firefox-i18n-gn 107.0-1 107.0.1-1
firefox-i18n-gu-in 107.0-1 107.0.1-1
firefox-i18n-he 107.0-1 107.0.1-1
firefox-i18n-hi-in 107.0-1 107.0.1-1
firefox-i18n-hr 107.0-1 107.0.1-1
firefox-i18n-hsb 107.0-1 107.0.1-1
firefox-i18n-hu 107.0-1 107.0.1-1
firefox-i18n-hy-am 107.0-1 107.0.1-1
firefox-i18n-ia 107.0-1 107.0.1-1
firefox-i18n-id 107.0-1 107.0.1-1
firefox-i18n-is 107.0-1 107.0.1-1
firefox-i18n-it 107.0-1 107.0.1-1
firefox-i18n-ja 107.0-1 107.0.1-1
firefox-i18n-ka 107.0-1 107.0.1-1
firefox-i18n-kab 107.0-1 107.0.1-1
firefox-i18n-kk 107.0-1 107.0.1-1
firefox-i18n-km 107.0-1 107.0.1-1
firefox-i18n-kn 107.0-1 107.0.1-1
firefox-i18n-ko 107.0-1 107.0.1-1
firefox-i18n-lij 107.0-1 107.0.1-1
firefox-i18n-lt 107.0-1 107.0.1-1
firefox-i18n-lv 107.0-1 107.0.1-1
firefox-i18n-mk 107.0-1 107.0.1-1
firefox-i18n-mr 107.0-1 107.0.1-1
firefox-i18n-ms 107.0-1 107.0.1-1
firefox-i18n-my 107.0-1 107.0.1-1
firefox-i18n-nb-no 107.0-1 107.0.1-1
firefox-i18n-ne-np 107.0-1 107.0.1-1
firefox-i18n-nl 107.0-1 107.0.1-1
firefox-i18n-nn-no 107.0-1 107.0.1-1
firefox-i18n-oc 107.0-1 107.0.1-1
firefox-i18n-pa-in 107.0-1 107.0.1-1
firefox-i18n-pl 107.0-1 107.0.1-1
firefox-i18n-pt-br 107.0-1 107.0.1-1
firefox-i18n-pt-pt 107.0-1 107.0.1-1
firefox-i18n-rm 107.0-1 107.0.1-1
firefox-i18n-ro 107.0-1 107.0.1-1
firefox-i18n-ru 107.0-1 107.0.1-1
firefox-i18n-sco 107.0-1 107.0.1-1
firefox-i18n-si 107.0-1 107.0.1-1
firefox-i18n-sk 107.0-1 107.0.1-1
firefox-i18n-sl 107.0-1 107.0.1-1
firefox-i18n-son 107.0-1 107.0.1-1
firefox-i18n-sq 107.0-1 107.0.1-1
firefox-i18n-sr 107.0-1 107.0.1-1
firefox-i18n-sv-se 107.0-1 107.0.1-1
firefox-i18n-szl 107.0-1 107.0.1-1
firefox-i18n-ta 107.0-1 107.0.1-1
firefox-i18n-te 107.0-1 107.0.1-1
firefox-i18n-th 107.0-1 107.0.1-1
firefox-i18n-tl 107.0-1 107.0.1-1
firefox-i18n-tr 107.0-1 107.0.1-1
firefox-i18n-trs 107.0-1 107.0.1-1
firefox-i18n-uk 107.0-1 107.0.1-1
firefox-i18n-ur 107.0-1 107.0.1-1
firefox-i18n-uz 107.0-1 107.0.1-1
firefox-i18n-vi 107.0-1 107.0.1-1
firefox-i18n-xh 107.0-1 107.0.1-1
firefox-i18n-zh-cn 107.0-1 107.0.1-1
firefox-i18n-zh-tw 107.0-1 107.0.1-1
flatpak-builder 1.2.2-3 1.2.3-1
gnome-builder 43.3-1 43.4-1
gnome-maps 43.1-1 43.2-1
gnome-remote-desktop 43.1-1 43.2-1
gnome-shell 1:43.1-21:43.1+r6+g92e9689a4-1
gnome-software 43.1-2 43.2-1
gnome-software-packagekit-plugin 43.1-2 43.2-1
gnome-terminal 3.46.6-1 3.46.7-1
graphviz 7.0.2-1 7.0.4-1
gssdp 1.6.1-1 1.6.2-1
gssdp-docs 1.6.1-1 1.6.2-1
gst-plugin-libcamera 0.0.1-3 0.0.2-1
gst-plugin-pipewire 1:0.3.60-3 1:0.3.61-1
gucharmap 15.0.1-1 15.0.2-1
gupnp 1:1.6.1-1 1:1.6.2-1
gupnp-docs 1:1.6.1-1 1:1.6.2-1
hwdetect 2022.09-4 2022.11-1
ibus-typing-booster 2.19.8-1 2.19.10-1
imagemagick 7.1.0.52-1 7.1.0.53-1
imagemagick-doc 7.1.0.52-1 7.1.0.53-1
inkscape 1.2.1-8 1.2.2-2
ipset 7.15-1 7.16-1
java-commons-daemon 1.3.2-1 1.3.3-1
java-jsvc 1.3.2-1 1.3.3-1
kactivitymanagerd 5.26.3-1 5.26.4-1
kde-cli-tools 5.26.3-1 5.26.4-1
kde-gtk-config 5.26.3-1 5.26.4-1
kdecoration 5.26.3-1 5.26.4-1
kdeplasma-addons 5.26.3-1 5.26.4-1
kgamma5 5.26.3-1 5.26.4-1
khealthcertificate 22.09-2 22.11-1
khotkeys 5.26.3-1 5.26.4-1
kinfocenter 5.26.3-1 5.26.4-1
kirigami-addons 0.5-1 0.6.1-1
kitinerary 22.08.3-2 22.08.3-3
kmenuedit 5.26.3-1 5.26.4-1
kpipewire 5.26.3-1 5.26.4-1
kscreen 5.26.3-1 5.26.4-1
kscreenlocker 5.26.3-1 5.26.4-1
ksshaskpass 5.26.3-1 5.26.4-1
ksystemstats 5.26.3-1 5.26.4-1
kwallet-pam 5.26.3-1 5.26.4-1
kwayland-integration 5.26.3-1 5.26.4-1
kwin 5.26.3-1 5.26.4-1
kwrited 5.26.3-1 5.26.4-1
layer-shell-qt 5.26.3-1 5.26.4-1
lib2geom 1.2-2 1.2.2-1
libass 0.16.0-1 0.17.0-1
libbluray 1.3.3-1 1.3.4-1
libcamera-docs 0.0.1-3 0.0.2-1
libcamera-tools 0.0.1-3 0.0.2-1
libice 1.0.10-4 1.1.0-1
libkscreen 5.26.3-1 5.26.4-1
libksysguard 5.26.3-1 5.26.4-1
libnautilus-extension 43.0-1 43.1-1
libnautilus-extension-docs 43.0-1 43.1-1
libreoffice-fresh 7.4.3-1 7.4.3-2
libreoffice-fresh-sdk 7.4.3-1 7.4.3-2
libreoffice-still 7.3.7-1 7.3.7-2
libreoffice-still-sdk 7.3.7-1 7.3.7-2
libshumate 1.0.2-1 1.0.3-1
libshumate-docs 1.0.2-1 1.0.3-1
libteam 1.31-5 1.31-7
libva-mesa-driver 22.2.3-1 -
libxcomposite 0.4.5-4 0.4.6-1
libxcursor 1.2.1-2 1.2.1-3
libxdamage 1.1.5-5 1.1.6-1
libxres 1.2.1-1 1.2.2-1
libxv 1.0.11-5 1.0.12-1
live-media 2022.10.01-1 2022.12.01-1
mencoder 38359-1 38407-1
mesa 22.2.3-1 -
mesa-vdpau 22.2.3-1 -
milou 5.26.3-1 5.26.4-1
mkinitcpio-archiso 65-1 66-1
mm-common 1.0.4-1 1.0.5-1
mpd 0.23.10-2 0.23.11-1
mplayer 38359-1 38407-1
mutter 43.1-1 43.1+r2+g6a962803e-2
mutter-docs 43.1-1 43.1+r2+g6a962803e-2
nautilus 43.0-1 43.1-1
netpbm 10.73.37-2 10.73.41-1
nginx-prometheus-exporter 0.10.0-3 0.11.0-1
opencl-mesa 22.2.3-1 -
ostree 2022.6-4 2022.7-1
oxygen 5.26.3-1 5.26.4-1
oxygen-sounds 5.26.3-1 5.26.4-1
pappl 1.2.3-2 1.3.0-1
perl-alien-build 2.72-1 2.73-1
perl-exporter-tiny 1.004004-2 1.006000-1
perl-net-server 2.010-3 2.013-1
pipewire-alsa 1:0.3.60-3 1:0.3.61-1
pipewire-audio 1:0.3.60-3 1:0.3.61-1
pipewire-docs 1:0.3.60-3 1:0.3.61-1
pipewire-jack 1:0.3.60-3 1:0.3.61-1
pipewire-pulse 1:0.3.60-3 1:0.3.61-1
pipewire-v4l2 1:0.3.60-3 1:0.3.61-1
pipewire-x11-bell 1:0.3.60-3 1:0.3.61-1
pipewire-zeroconf 1:0.3.60-3 1:0.3.61-1
plank-player 5.26.3-1 5.26.4-1
plasma-bigscreen 5.26.3-1 5.26.4-1
plasma-browser-integration 5.26.3-1 5.26.4-1
plasma-desktop 5.26.3-1 5.26.4-1
plasma-disks 5.26.3-1 5.26.4-1
plasma-firewall 5.26.3-1 5.26.4-1
plasma-integration 5.26.3-1 5.26.4-1
plasma-nano 5.26.3-1 5.26.4-1
plasma-nm 5.26.3-1 5.26.4-1
plasma-pa 5.26.3-1 5.26.4-1
plasma-remotecontrollers 5.26.3-1 5.26.4-1
plasma-sdk 5.26.3-1 5.26.4-1
plasma-settings 22.09-1 22.11-1
plasma-systemmonitor 5.26.3-1 5.26.4-1
plasma-thunderbolt 5.26.3-1 5.26.4-1
plasma-vault 5.26.3-1 5.26.4-1
plasma-wayland-session 5.26.3-1 5.26.4.1-1
plasma-workspace 5.26.3-1 5.26.4.1-1
plasma-workspace-wallpapers 5.26.3-1 5.26.4-1
polkit-kde-agent 5.26.3-1 5.26.4-1
poppler 22.11.0-1 22.12.0-1
poppler-glib 22.11.0-1 22.12.0-1
poppler-qt5 22.11.0-1 22.12.0-1
poppler-qt6 22.11.0-1 22.12.0-1
powerdevil 5.26.3-1 5.26.4-1
prometheus 2.40.3-1 2.40.4-1
protobuf 21.9-1 21.10-1
python-cairo 1.22.0-1 1.23.0-2
python-chardet 5.0.0-1 5.1.0-1
python-cryptography 38.0.3-1 38.0.4-1
python-protobuf 21.9-1 21.10-1
python-retrying 1.3.3-13 1.3.3-14
python-setuptools 1:65.6.1-1 1:65.6.3-1
python-trove-classifiers 2022.10.19-1 2022.12.1-1
python-virtualenv 20.16.7-1 20.17.0-1
qpdf 11.1.1-2 11.2.0-1
qpdf-docs 11.1.1-2 11.2.0-1
sbcl 2.2.9-1 2.2.11-1
sddm-kcm 5.26.3-1 5.26.4-1
systemsettings 5.26.3-1 5.26.4-1
thunderbird 102.5.0-1 102.5.1-1
thunderbird-i18n-af 102.5.0-1 102.5.1-1
thunderbird-i18n-ar 102.5.0-1 102.5.1-1
thunderbird-i18n-ast 102.5.0-1 102.5.1-1
thunderbird-i18n-be 102.5.0-1 102.5.1-1
thunderbird-i18n-bg 102.5.0-1 102.5.1-1
thunderbird-i18n-br 102.5.0-1 102.5.1-1
thunderbird-i18n-ca 102.5.0-1 102.5.1-1
thunderbird-i18n-cak 102.5.0-1 102.5.1-1
thunderbird-i18n-cs 102.5.0-1 102.5.1-1
thunderbird-i18n-cy 102.5.0-1 102.5.1-1
thunderbird-i18n-da 102.5.0-1 102.5.1-1
thunderbird-i18n-de 102.5.0-1 102.5.1-1
thunderbird-i18n-dsb 102.5.0-1 102.5.1-1
thunderbird-i18n-el 102.5.0-1 102.5.1-1
thunderbird-i18n-en-gb 102.5.0-1 102.5.1-1
thunderbird-i18n-en-us 102.5.0-1 102.5.1-1
thunderbird-i18n-es-ar 102.5.0-1 102.5.1-1
thunderbird-i18n-es-es 102.5.0-1 102.5.1-1
thunderbird-i18n-et 102.5.0-1 102.5.1-1
thunderbird-i18n-eu 102.5.0-1 102.5.1-1
thunderbird-i18n-fi 102.5.0-1 102.5.1-1
thunderbird-i18n-fr 102.5.0-1 102.5.1-1
thunderbird-i18n-fy-nl 102.5.0-1 102.5.1-1
thunderbird-i18n-ga-ie 102.5.0-1 102.5.1-1
thunderbird-i18n-gd 102.5.0-1 102.5.1-1
thunderbird-i18n-gl 102.5.0-1 102.5.1-1
thunderbird-i18n-he 102.5.0-1 102.5.1-1
thunderbird-i18n-hr 102.5.0-1 102.5.1-1
thunderbird-i18n-hsb 102.5.0-1 102.5.1-1
thunderbird-i18n-hu 102.5.0-1 102.5.1-1
thunderbird-i18n-hy-am 102.5.0-1 102.5.1-1
thunderbird-i18n-id 102.5.0-1 102.5.1-1
thunderbird-i18n-is 102.5.0-1 102.5.1-1
thunderbird-i18n-it 102.5.0-1 102.5.1-1
thunderbird-i18n-ja 102.5.0-1 102.5.1-1
thunderbird-i18n-ka 102.5.0-1 102.5.1-1
thunderbird-i18n-kab 102.5.0-1 102.5.1-1
thunderbird-i18n-kk 102.5.0-1 102.5.1-1
thunderbird-i18n-ko 102.5.0-1 102.5.1-1
thunderbird-i18n-lt 102.5.0-1 102.5.1-1
thunderbird-i18n-ms 102.5.0-1 102.5.1-1
thunderbird-i18n-nb-no 102.5.0-1 102.5.1-1
thunderbird-i18n-nl 102.5.0-1 102.5.1-1
thunderbird-i18n-nn-no 102.5.0-1 102.5.1-1
thunderbird-i18n-pa-in 102.5.0-1 102.5.1-1
thunderbird-i18n-pl 102.5.0-1 102.5.1-1
thunderbird-i18n-pt-br 102.5.0-1 102.5.1-1
thunderbird-i18n-pt-pt 102.5.0-1 102.5.1-1
thunderbird-i18n-rm 102.5.0-1 102.5.1-1
thunderbird-i18n-ro 102.5.0-1 102.5.1-1
thunderbird-i18n-ru 102.5.0-1 102.5.1-1
thunderbird-i18n-sk 102.5.0-1 102.5.1-1
thunderbird-i18n-sl 102.5.0-1 102.5.1-1
thunderbird-i18n-sq 102.5.0-1 102.5.1-1
thunderbird-i18n-sr 102.5.0-1 102.5.1-1
thunderbird-i18n-sv-se 102.5.0-1 102.5.1-1
thunderbird-i18n-th 102.5.0-1 102.5.1-1
thunderbird-i18n-tr 102.5.0-1 102.5.1-1
thunderbird-i18n-uk 102.5.0-1 102.5.1-1
thunderbird-i18n-uz 102.5.0-1 102.5.1-1
thunderbird-i18n-vi 102.5.0-1 102.5.1-1
thunderbird-i18n-zh-cn 102.5.0-1 102.5.1-1
thunderbird-i18n-zh-tw 102.5.0-1 102.5.1-1
tomcat10 10.1.2-1 10.1.3-1
tomcat9 9.0.69-1 9.0.70-1
vlc 3.0.17.4-11 3.0.18-4
vte-common 0.70.1-1 0.70.2-1
vte-docs 0.70.1-1 0.70.2-1
vte3 0.70.1-1 0.70.2-1
vte4 0.70.1-1 0.70.2-1
vulkan-broadcom 22.2.3-1 -
vulkan-mesa-layers 22.2.3-1 -
vulkan-panfrost 22.2.3-1 -
vulkan-radeon 22.2.3-1 -
vulkan-swrast 22.2.3-1 -
wavpack 5.5.0-1 5.6.0-1
wayland 1.21.0-1 1.21.0-2
wayland-docs 1.21.0-1 1.21.0-2
wayland-protocols 1.28-1 1.31-1
webkit2gtk 2.38.2-1 2.38.2-2
webkit2gtk-4.1 2.38.2-1 2.38.2-2
webkit2gtk-4.1-docs 2.38.2-1 2.38.2-2
webkit2gtk-5.0 2.38.2-1 2.38.2-2
webkit2gtk-5.0-docs 2.38.2-1 2.38.2-2
webkit2gtk-docs 2.38.2-1 2.38.2-2
wireplumber 0.4.12-1 -
wireplumber-docs 0.4.12-1 -
wpewebkit 2.38.2-1 2.38.2-2
wpewebkit-docs 2.38.2-1 2.38.2-2
xdg-desktop-portal-gtk 1.14.0-1 1.14.1-1
xdg-desktop-portal-kde 5.26.3-1 5.26.4-1
xmlsec 1.2.36-2 1.2.37-1
xorg-xcursorgen 1.0.7-3 1.0.8-1
xorg-xdm 1.1.13-1 1.1.14-1
xorg-xfd 1.1.3-3 1.1.4-1
xorg-xgamma 1.0.6-4 1.0.7-1
xorg-xinit 1.4.1-3 1.4.2-1
xorg-xprop 1.2.5-1 1.2.6-1
xorg-xrandr 1.5.1-2 1.5.2-1
xorg-xset 1.2.4-3 1.2.5-1
xorg-xvinfo 1.1.4-3 1.1.5-1
xterm 376-1 377-1
zabbix-agent 6.2.3-3 6.2.4-1
zabbix-agent2 6.2.3-3 6.2.4-1
zabbix-frontend-php 6.2.3-3 6.2.4-1
zabbix-proxy 6.2.3-3 6.2.4-1
zabbix-server 6.2.3-3 6.2.4-1
adwaita-cursors - 43-2
default-cursors - 1-1
libteam-docs - 1.31-7
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.08.3.r12856.g9c5056e2b-122.08.3.r12861.gb3a9cc197-1
akonadi-calendar22.08.3.r2213.g01df474-122.08.3.r2221.gd08e969-1
akonadi-calendar-tools22.08.3.r983.g2c9acbd-122.08.3.r984.gee5527a-1
akonadi-contacts22.08.3.r3298.g5807e4de-122.08.3.r3305.g7d7d2474-1
akonadi-import-wizard22.08.3.r1869.g3f698b5-122.08.3.r1870.ge99121d-1
akonadi-mime22.08.3.r1787.gbaf7d71-122.08.3.r1790.ge69387b-1
akonadi-notes22.08.3.r1108.ga0522fa-122.08.3.r1109.g81ba069-1
akonadi-search22.08.3.r1300.g09a2696-122.08.3.r1302.g6f239be-1
akonadiconsole22.08.3.r1634.g3de5fdb-122.08.3.r1635.gdc537cb-1
akregator22.08.3.r6513.g355e117d-122.08.3.r6520.g3b957f18-1
alligator 22.09.r20.g308421b-1 22.11.r3.gc492339-1
analitza22.08.3.r2368.ge431a229-122.08.3.r2369.g5215178c-1
angelfish 22.09.r26.g5f8bb2e-1 22.11.r8.ga755784-1
ark22.08.3.r4947.gac8a66d6-122.08.3.r4960.gce6fc6ab-1
artikulate22.08.3.r1464.g0c79f10-122.08.3.r1470.g363a25e-1
attica5.100.0.r892.g3fdc288-15.100.0.r893.g07ff076-1
audiocd-kio22.08.3.r1129.g30b3d27-122.08.3.r1133.g40c7dd2-1
audiotube 22.09.r55.gc56bbb6-1 22.11.r5.ge494a6f-1
aura-browser5.26.0.r139.g00a7283-15.26.0.r143.g782311e-1
baloo5.100.0.r3098.g78b7a39e-15.100.0.r3111.g03246908-1
baloo-widgets22.08.3.r785.g4e76c0a-122.08.3.r786.gc1eb617-1
blinken22.08.3.r700.g96b4d97-122.08.3.r702.ge5ff13a-1
bluedevil1:5.26.3.r2496.g25a9ddd0-11:5.26.4.r2503.gd93dafe3-1
bluez-qt5.100.0.r729.g1ab1fed-15.100.0.r731.g8be1800-1
bomber22.08.3.r593.ga14a222-122.08.3.r598.g9b798a9-1
bovo22.08.3.r807.g33e1d0e-122.08.3.r813.g2b5d417-1
breeze5.26.3.r2510.geb97f1de-15.26.4.r2527.g0eca3350-1
breeze-grub5.26.3.r11.g63136a9-15.26.4.r11.g63136a9-1
breeze-gtk5.26.3.r493.g4a1108c-15.26.4.r493.g4a1108c-1
breeze-icons5.100.0.r1933.gcad586e2-15.100.0.r1938.g5b546af3-1
buho 2.2.0.r20.g803f159-1 2.2.1.r1.geb79374-1
calendarsupport22.08.3.r755.g47269a5-122.08.3.r757.gb555ea7-1
calindori 22.09.r15.gdfca85f-1 22.11.r5.gc7593d3-1
cask-server r9.gda27892-1 r10.g60bb378-1
cervisia22.08.3.r1722.g26ac466-122.08.3.r1727.g0c4030e-1
discover5.26.3.r9031.g814e3abc6-15.26.4.r9065.gacd1d8051-1
dolphin22.08.3.r7170.g9811eb803-122.08.3.r7186.g0c4688095-1
dolphin-plugins22.08.3.r705.g9ff6dd5-122.08.3.r709.gbc35b8d-1
dragon22.08.3.r1093.g922b52b-122.08.3.r1112.gc940980-1
drkonqi5.26.3.r860.g8e6e4ed7-15.26.4.r864.gf4719076-1
elisa22.08.3.r3078.g62c8ad3b-122.08.3.r3086.gbbee37da-1
elisa-qtmm22.08.3.r3078.g62c8ad3b-122.08.3.r3086.gbbee37da-1
eventviews22.08.3.r909.g6731395-122.08.3.r911.g202267f-1
extra-cmake-modules5.100.0.r3536.g0a80daff-15.100.0.r3537.gf0ff8c0f-1
ffmpegthumbs22.08.3.r241.g3a78605-122.08.3.r242.g08c3a2c-1
filelight22.08.3.r1243.gd8a5a22-122.08.3.r1267.g589b75c-1
frameworkintegration5.100.0.r662.gdc53d24-15.100.0.r663.g07b398a-1
granatier22.08.3.r1007.g5350363-122.08.3.r1012.g0f5c19e-1
grantlee-editor22.08.3.r870.g46a3d18-122.08.3.r876.gc40c8c2-1
grantleetheme22.08.3.r442.g8f13c34-122.08.3.r443.g9f9e3f2-1
gwenview22.08.3.r6973.gfde46325-122.08.3.r6980.gd1fe74a3-1
incidenceeditor22.08.3.r965.gaf7e564-122.08.3.r967.g842d24e-1
index-fm 2.2.0.r30.g4cefa20-1 2.2.1.r4.g62b2103-1
itinerary22.08.3.r2099.g63497fc-122.08.3.r2166.ge4605ed-1
juk22.08.3.r3209.g05d6c79b-122.08.3.r3212.gfb8c6664-1
kaccounts-integration22.08.3.r1305.gb7bfd85-122.08.3.r1306.g0af02c8-1
kaccounts-providers22.08.3.r411.ga25a055-122.08.3.r412.g983e737-1
kactivities5.100.0.r1416.g5b270191-15.100.0.r1418.g5f64f871-1
kactivities-stats5.100.0.r424.gda603f9-15.100.0.r425.gb9e496f-1
kactivitymanagerd5.26.3.r1431.g399a77b-15.26.4.r1435.gb902153-1
kaddressbook22.08.3.r6275.g1663db7a-122.08.3.r6277.g9fc231fe-1
kajongg22.08.3.r4372.g8f471606-122.08.3.r4375.gb8a5b892-1
kalarm22.08.3.r8108.gc04a22bb-122.08.3.r8127.ga2db6656-1
kalgebra22.08.3.r2101.g94448d8-122.08.3.r2104.gaae93e8-1
kalk 22.09.r26.gea6ac17-1 22.11.r5.gc7123b0-1
kalzium22.08.3.r4437.g9945ed98-122.08.3.r4441.g297c7302-1
kamera22.08.3.r750.g667c9cc-122.08.3.r753.gccccf05-1
kamoso22.08.3.r1499.g5e4b68b-122.08.3.r1503.g744da94-1
kanagram22.08.3.r1351.g65ae9b8-122.08.3.r1354.g1302996-1
kapman22.08.3.r688.g7ec6435-122.08.3.r691.g24e429b-1
kapptemplate22.08.3.r1023.g287a776-122.08.3.r1028.gbec630a-1
karchive5.100.0.r582.g2f8c47b-15.100.0.r586.g66ea812-1
kasts22.09.2.r36.g7adaa85-1 22.11.r15.g6ad2aca-1
kate22.08.3.r19909.ge7c159a52-122.08.3.r19974.g4cb4ada11-1
katomic22.08.3.r991.g20eb7bc-122.08.3.r997.gb873894-1
kauth5.100.0.r525.gb868566-15.100.0.r527.gd77c7d9-1
kbackup22.08.3.r476.g81cd131-122.08.3.r479.gd5cf742-1
kblackbox22.08.3.r801.g6cd4985-122.08.3.r803.g041b183-1
kblocks22.08.3.r773.g11f59ce-122.08.3.r777.g8ad6c24-1
kbookmarks5.100.0.r490.g2ea6806-15.100.0.r492.g2798719-1
kbounce22.08.3.r878.g9862230-122.08.3.r883.g2c69c97-1
kbreakout22.08.3.r957.g181e435-122.08.3.r961.gdc4e139-1
kbruch22.08.3.r912.g9d5adfb-122.08.3.r914.g43adc0d-1
kcachegrind22.08.3.r1214.ge4f32fc-122.08.3.r1218.g7eac263-1
kcachegrind-common22.08.3.r1214.ge4f32fc-122.08.3.r1218.g7eac263-1
kcalc22.08.3.r1658.g466384f-122.08.3.r1662.gef98182-1
kcalendarcore5.100.0.r1353.g474f60383-15.100.0.r1354.g232a1b887-1
kcalutils22.08.3.r1014.gbad778153-122.08.3.r1015.g9880a3724-1
kcharselect22.08.3.r572.gceecc87-122.08.3.r575.gdd9b95c-1
kclock 22.09.r36.g2559c97-1 22.11.r4.g032962e-1
kcmutils5.100.0.r685.gdcb2ef5-15.100.0.r688.ga94c1c8-1
kcodecs5.100.0.r451.g541163c-15.100.0.r454.g7903af6-1
kcolorchooser22.08.3.r294.g29628cd-122.08.3.r297.gea1ba86-1
kcompletion5.100.0.r528.g2350986-15.100.0.r530.g716fe00-1
kconfig5.100.0.r1010.g62cb8e29-15.100.0.r1012.g7a1c0087-1
kconfigwidgets5.100.0.r813.g28d355e3-15.100.0.r819.g926189c3-1
kcontacts1:5.100.0.r3366.ga7e50968-11:5.100.0.r3368.gbb417707-1
kcoreaddons5.100.0.r1614.g0d7a10a1-15.100.0.r1618.gea5e8b46-1
kcrash5.100.0.r462.g53e9335-15.100.0.r463.gfbbdfff-1
kcron22.08.3.r863.gf73596a-122.08.3.r867.g2bc0af8-1
kdav1:5.100.0.r1373.gd8929ad-11:5.100.0.r1375.g557bf2f-1
kdbusaddons5.100.0.r446.g634ef1f-15.100.0.r448.ge19a1fe-1
kde-cli-tools5.26.3.r2005.g2a9fc27-15.26.4.r2010.gbf0c5af-1
kde-dev-utils22.08.3.r616.gd9ede57-122.08.3.r620.g3478628-1
kde-gtk-config5.26.3.r954.g769c6c6-15.26.4.r955.g380682d-1
kdebugsettings22.08.3.r1038.gec5400c-122.08.3.r1040.gf4917a7-1
kdeclarative5.100.0.r1072.gf5d8e30-15.100.0.r1078.ga0b07d4-1
kdeconnect22.08.3.r3600.g960530f6-122.08.3.r3605.gb823e044-1
kdecoration5.26.3.r312.g0a2a546-15.26.4.r314.g4bafed0-1
kded5.100.0.r483.g2663ef4-15.100.0.r484.g135ad0e-1
kdelibs4support5.100.0.r1127.g8eb8f8f0-15.100.0.r1130.g126b7925-1
kdenetwork-filesharing22.08.3.r1005.gc2542d6-122.08.3.r1008.ge65ebfb-1
kdenlive22.08.3.r17066.g8dec8d652-122.08.3.r17125.ga029c4bca-1
kdepim-addons22.08.3.r4936.gd108409ef-122.08.3.r4945.g1b68151ef-1
kdepim-runtime22.08.3.r15659.gcc11186ba-122.08.3.r15662.g5fc06452d-1
kdeplasma-addons5.26.3.r9165.g8522fd7e6-15.26.4.r9193.ge28bee051-1
kdesdk-thumbnailers22.08.3.r109.g61ea611-122.08.3.r110.gd586f08-1
kdesignerplugin5.100.0.r377.ge6cbe8c-15.100.0.r379.gf6e7e95-1
kdesu5.100.0.r533.g4d338be-15.100.0.r536.g0dfa805-1
kdf22.08.3.r901.g73e054b-122.08.3.r907.g9fb1cd3-1
kdialog22.08.3.r1264.g8a5789210-122.08.3.r1274.g46cc1f546-1
kdiamond22.08.3.r754.ge8ac5b1-122.08.3.r757.g07d3383-1
kdnssd5.100.0.r376.g103a6da-15.100.0.r378.ga54e7cc-1
kdoctools5.100.0.r696.g6027da4-15.100.0.r698.gc3903a5-1
keditbookmarks22.08.3.r2788.geeeadcddf-122.08.3.r2791.ga9a60f637-1
kemoticons5.100.0.r431.g230adfc-15.100.0.r432.gedd549d-1
keysmith 22.09.r19.ga5ff479-1 22.11.r4.ga5ecb8d-1
kfilemetadata5.100.0.r900.g59be59b-15.100.0.r902.gc49b152-1
kfind22.08.3.r2752.g5a5c884b3-122.08.3.r2758.g168f50272-1
kfloppy22.08.3.r821.g58b0671-122.08.3.r824.ga0b408d-1
kfourinline22.08.3.r1059.g9afdd55-122.08.3.r1062.ga47da92-1
kgamma55.26.3.r497.gfc2d4c8-15.26.4.r499.g40ac727-1
kgeography22.08.3.r1203.gad059d7-122.08.3.r1206.g68fb02d-1
kget22.08.3.r3259.g23261221-122.08.3.r3264.g7dad7da3-1
kglobalaccel5.100.0.r596.g091ac4e-15.100.0.r606.gb2f7d86-1
kgoldrunner22.08.3.r1326.g092bb5a-122.08.3.r1328.ga2c7c17-1
kguiaddons5.100.0.r515.g15f0a0b-15.100.0.r517.g1588ce0-1
khangman22.08.3.r1643.g593464a-122.08.3.r1647.gf94ba9e-1
khealthcertificate 22.09.r1.g9825106-1 22.11.r0.g4738376-1
khelpcenter22.08.3.r2822.gaa82b2f3-122.08.3.r2833.gab3106b6-1
kholidays1:5.100.0.r1082.gcb69faf-11:5.100.0.r1085.ge5902ff-1
khotkeys5.26.3.r2180.g5ef685d-15.26.4.r2183.gbb898f9-1
khtml5.100.0.r620.gf07c71a-15.100.0.r624.g173f783-1
ki18n5.100.0.r599.gd74fd22-15.100.0.r601.gd21057f-1
kiconthemes5.100.0.r652.g2626f88-15.100.0.r655.g9450e0f-1
kidentitymanagement22.08.3.r3929.ga641faf0-122.08.3.r3930.g9b44b2e7-1
kidletime5.100.0.r379.gb86c8b7-15.100.0.r385.g24f7b32-1
kig22.08.3.r3257.ga10805d7-122.08.3.r3261.gb98c89ec-1
kigo22.08.3.r608.g079c8c8-122.08.3.r610.g4abae49-1
killbots22.08.3.r829.gafc571f-122.08.3.r832.g51eb2c6-1
kimageformats5.100.0.r468.g3b1e8f7-15.100.0.r470.g7af4eea-1
kimagemapeditor22.08.3.r541.g3d21036-122.08.3.r544.gd0f5332-1
kimap22.08.3.r1227.g94edb2b-122.08.3.r1229.g525a6fa-1
kinfocenter5.26.3.r2229.g11ed1778-15.26.4.r2236.g4de1770d-1
kinit5.100.0.r463.g7da05e3-15.100.0.r465.g5aa7ca2-1
kio5.100.0.r5884.g7555aa8ef-15.100.0.r5937.g8b1cf149f-1
kio-extras22.08.3.r7400.g91b1dff25-122.08.3.r7423.g1691b576d-1
kio-gdrive22.08.3.r672.g3302166-122.08.3.r678.gb1f9769-1
kirigami-addons 1:0.5.r68.g8280a8b-1 1:0.6.r5.g6be6cda-1
kirigami-gallery22.08.3.r297.g313cef1-122.08.3.r300.g848ae29-1
kirigami25.100.0.r3472.ga8cc3f8e-15.100.0.r3504.g822c396c-1
kiriki22.08.3.r482.g1675a7e-122.08.3.r498.g7ec669a-1
kitemmodels5.100.0.r631.g3b318e2-15.100.0.r634.g117764e-1
kitemviews5.100.0.r401.gadef181-15.100.0.r403.gf755ad1-1
kiten22.08.3.r1229.gf88b2ae-122.08.3.r1234.gc40435d-1
kitinerary22.08.3.r2527.g5daf4a39-122.08.3.r2553.g82732e82-1
kjobwidgets5.100.0.r448.g76d8ce0-15.100.0.r451.g8029991-1
kjs5.100.0.r381.gc4157f8-15.100.0.r382.g3c89acf-1
kjsembed5.100.0.r348.gae5d788-15.100.0.r350.g71331f1-1
kjumpingcube22.08.3.r874.ge785f62-122.08.3.r876.g7e786cb-1
kldap22.08.3.r993.g7d7cb02-122.08.3.r996.g6d4b9f7-1
kleopatra22.08.3.r6938.g90f3a220-122.08.3.r6976.gae8984db-1
klettres22.08.3.r995.g2291e9d-122.08.3.r997.g6cfd602-1
klickety22.08.3.r727.gbf48aa9-122.08.3.r734.ge03cf1f-1
klines22.08.3.r852.g5e73614-122.08.3.r854.gaa3aad3-1
kmag22.08.3.r766.gb0280d2-122.08.3.r770.g4a4ab97-1
kmahjongg22.08.3.r1594.gfea0b37-122.08.3.r1596.g3095f0e-1
kmail22.08.3.r26631.gf8ee27240-122.08.3.r26643.gc14882228-1
kmail-account-wizard22.08.3.r918.g8683978-122.08.3.r919.gd9bffc6-1
kmailtransport22.08.3.r1813.g4141653-122.08.3.r1827.g7568ad2-1
kmediaplayer5.100.0.r329.g2ed223b-15.100.0.r330.g51d88cd-1
kmenuedit5.26.3.r1108.g7ef8b33-15.26.4.r1112.g871f202-1
kmime22.08.3.r1562.ge4466dd-122.08.3.r1563.g44cc391-1
kmines22.08.3.r1798.g4834c81-122.08.3.r1804.g1fedfe8-1
kmix22.08.3.r2480.g941c459c-122.08.3.r2483.gf735b657-1
kmousetool22.08.3.r472.g4c1d738-122.08.3.r474.g4612e7d-1
kmouth22.08.3.r774.ga18dfb0-122.08.3.r777.g4259fa8-1
kmplot22.08.3.r1545.gf4cba73-122.08.3.r1548.gf4d6ddb-1
knavalbattle22.08.3.r1465.g9c5c759-122.08.3.r1470.g2c515cf-1
knetwalk22.08.3.r745.g34fbc65-122.08.3.r750.gdf31d1d-1
knewstuff5.100.0.r1429.g9c0a2f8b-15.100.0.r1433.gf64baa30-1
knights22.08.3.r1186.gf024c7c-122.08.3.r1190.g368506d-1
knotes22.08.3.r3743.gccbd2311-122.08.3.r3749.g5e265a68-1
knotifications5.100.0.r780.g1c9ca10-15.100.0.r786.gbb4b97c-1
knotifyconfig5.100.0.r409.geb06760-15.100.0.r411.g93db1db-1
koko 22.09.r19.gbeec0df-1 22.11.r1.g7884903-1
kolf22.08.3.r1560.g72b7fce-122.08.3.r1563.gbd9e6be-1
kollision22.08.3.r561.g0b61940-122.08.3.r569.gfd01cbe-1
kolourpaint22.08.3.r2464.gbad4d9f5-122.08.3.r2467.gcb82406b-1
kompare22.08.3.r1202.g098f37a-122.08.3.r1207.g002651e-1
kongress 22.09.r18.g7621e60-1 22.11.r1.g4d195ec-1
konqueror22.08.3.r15234.g45f44aeb2-122.08.3.r15245.g88a568819-1
konquest22.08.3.r978.g9edf326-122.08.3.r982.ge9393c4-1
konsole22.08.3.r8750.gb534bcc6-122.08.3.r8771.g088b7b55-1
kontact22.08.3.r5603.g47908bc8-122.08.3.r5611.gdde8fcfa-1
kontactinterface22.08.3.r723.g547d217-122.08.3.r726.gbb797c6-1
kontrast22.08.3.r262.gd06135f-122.08.3.r267.g88c120c-1
konversation22.08.3.r9201.gfc592914-122.08.3.r9210.gf115d1cc-1
kopeninghours22.08.3.r349.gdfa928f-122.08.3.r350.gaf2798b-1
korganizer22.08.3.r11886.ge128226de-122.08.3.r11892.g56f6bd5d1-1
kosmindoormap22.08.3.r801.gb44bfe2-122.08.3.r848.g6d0321b-1
kpackage5.100.0.r791.g242f4aa-15.100.0.r795.geb3b53d-1
kparts5.100.0.r636.g962c908-15.100.0.r638.g00be60b-1
kpat22.08.3.r2653.gb685978a-122.08.3.r2670.gfe0b254d-1
kpeople5.100.0.r1402.gfc02e54-15.100.0.r1404.ge6c47d3-1
kpeoplevcard 0.1.r49.ga62ff5a-1 0.1.r51.ge568b90-1
kpimtextedit22.08.3.r1680.gc8d3504-122.08.3.r1729.g679c211-1
kpipewire5.26.3.r172.g3d7758f-15.26.4.r174.g7e42055-1
kplotting5.100.0.r340.g69ab40c-15.100.0.r341.g465de2c-1
kpmcore22.08.3.r1328.g5324e85-122.08.3.r1329.g4b73a2e-1
kpty5.100.0.r399.g48ca9d5-15.100.0.r401.g156edc2-1
kquickcharts5.100.0.r547.gf2d2a05-15.100.0.r548.g69885d6-1
krdc22.08.3.r1644.gc09dffd-122.08.3.r1646.g4b9a32c-1
krecorder 22.09.r55.gf8fea3d-1 22.11.r6.g0532782-1
kreversi22.08.3.r1310.g9fc6d29-122.08.3.r1313.g5a4de8f-1
krfb22.08.3.r1529.g21763fe-122.08.3.r1531.gab13b9a-1
kross5.100.0.r379.gede70e0-15.100.0.r382.gbdb0fcb-1
kruler22.08.3.r767.g2b93a4e-122.08.3.r772.g0893d01-1
krunner5.100.0.r799.gc196cb3-15.100.0.r800.gb11d2f7-1
ksanecore r652.g5a57acf-1 r654.g9ef2abe-1
kscreen5.26.3.r1602.g4719e4a-15.26.4.r1611.g7bc9e4f-1
kscreenlocker5.26.3.r1015.g2d9d548-15.26.4.r1023.g21df920-1
kservice5.100.0.r1052.ge4c06fd-15.100.0.r1055.gff4e834-1
kshisen22.08.3.r1272.g1088461-122.08.3.r1274.g1ce34e2-1
ksirk22.08.3.r1081.gb665e4a-122.08.3.r1084.gff9f9d9-1
ksmtp22.08.3.r477.g0928530-122.08.3.r478.geae5f75-1
ksnakeduel22.08.3.r883.g320a8a0-122.08.3.r886.g4d7b68e-1
kspaceduel22.08.3.r701.g9ab2c91-122.08.3.r705.g30581ef-1
ksquares22.08.3.r604.gc86a666-122.08.3.r618.gdddbf49-1
ksshaskpass5.26.3.r226.g7423b6e-15.26.4.r227.g91ebc05-1
ksudoku22.08.3.r1152.g84fd086-122.08.3.r1154.gd3c110e-1
ksysguard5.26.3.r3562.gaa6517ce-15.26.4.r3564.ge452ad75-1
ksystemlog22.08.3.r779.g1c3993e-122.08.3.r783.gfa1c421-1
ksystemstats5.26.3.r256.g6ab8074-15.26.4.r258.gd651d8f-1
kteatime22.08.3.r783.g6a2d5bb-122.08.3.r786.g0b9a973-1
ktexteditor5.100.0.r3641.gcceb37eb-15.100.0.r3654.gfbbb3e65-1
ktextwidgets5.100.0.r478.g8065f83-15.100.0.r480.gc0eddfb-1
ktimer22.08.3.r552.g99df5a1-122.08.3.r555.ga225dcc-1
ktnef22.08.3.r753.gf5efb32-122.08.3.r754.g65da72f-1
ktorrent22.08.3.r2919.g3cc687c7-122.08.3.r2922.g48e97b13-1
ktouch22.08.3.r2221.gbe05bf1-122.08.3.r2223.g5ecdb1d-1
ktrip 22.09.r13.g9cb0b48-1 22.11.r4.gf3b0c89-1
ktuberling22.08.3.r1111.g559351b-122.08.3.r1115.g748f78b-1
kturtle22.08.3.r1206.gb906fd1-122.08.3.r1210.g6f53357-1
kubrick22.08.3.r452.g526f1ce-122.08.3.r454.g92e28fe-1
kunitconversion5.100.0.r456.ge670ee3-15.100.0.r458.gd31c56a-1
kwallet5.100.0.r1203.g74bcf00-15.100.0.r1207.g81b6a23-1
kwallet-pam5.26.3.r278.gd2f3ec9-15.26.4.r278.gd2f3ec9-1
kwalletmanager22.08.3.r1342.gd397952-122.08.3.r1348.g797f02e-1
kwave22.08.3.r3830.g482f3d0c-122.08.3.r3834.g8162336b-1
kwayland5.100.0.r1198.gb5ed59c-15.100.0.r1199.g1d0d344-1
kwayland-integration5.26.3.r221.g8eb1f9b-15.26.4.r222.g796b104-1
kweather 22.09.r39.g0ffdf7a-1 22.11.r7.g4e39724-1
kweathercore 0.7.r15.ga7ae7c2-1 0.7.r16.g3117947-1
kwidgetsaddons5.100.0.r1022.geea17ba8-15.100.0.r1028.g4a289489-1
kwin5.26.3.r23619.gf70caec4b-15.26.4.r23670.gebafdc440-1
kwindowsystem5.100.0.r719.gcf5da72-15.100.0.r727.g97e7c07-1
kwordquiz22.08.3.r1243.g272e526-122.08.3.r1246.gfa9adf6-1
kwrite22.08.3.r19909.ge7c159a52-122.08.3.r19974.g4cb4ada11-1
kwrited5.26.3.r520.g5ddc413-15.26.4.r520.g5ddc413-1
kxmlgui5.100.0.r933.g9feac22e-15.100.0.r936.g006ec5c7-1
kxmlrpcclient5.100.0.r500.g763c12314-15.100.0.r502.g7dd0a05bc-1
layer-shell-qt5.26.3.r68.g70dc87f-15.26.4.r68.g70dc87f-1
libakonadi22.08.3.r12856.g9c5056e2b-122.08.3.r12861.gb3a9cc197-1
libgravatar22.08.3.r453.gfb7dd43-122.08.3.r454.g858409f-1
libkcddb22.08.3.r779.g7fd5971-122.08.3.r780.ge8e759a-1
libkcompactdisc22.08.3.r406.g8aa81d2-122.08.3.r408.g9ebfaf4-1
libkdegames22.08.3.r2277.g14784879-122.08.3.r2282.ge81034a8-1
libkdepim22.08.3.r941.g770c32b-122.08.3.r942.g4a07e38-1
libkeduvocdocument22.08.3.r1824.g427b94b-122.08.3.r1826.ge887964-1
libkgapi22.08.3.r1394.gd154844-122.08.3.r1404.gb135c60-1
libkleo22.08.3.r1313.gc79ef23-122.08.3.r1337.g730a1ce-1
libkmahjongg22.08.3.r505.g4b36950-122.08.3.r506.g5f4d3cc-1
libkomparediff222.08.3.r370.gf9766b1-122.08.3.r371.g040a9d9-1
libksane22.08.3.r619.gb9e5583-122.08.3.r624.g7542013-1
libkscreen5.26.3.r1686.gbdc44a8-15.26.4.r1689.gcf559ce-1
libksieve22.08.3.r1778.g427dc520-122.08.3.r1782.g32f8a3eb-1
libksysguard5.26.3.r2484.gfef9dbd-15.26.4.r2488.gafa2bda-1
libktorrent22.08.3.r576.g8e2753a-122.08.3.r578.g5f160b8-1
lokalize22.08.3.r1876.g9bcd9b6b-122.08.3.r1880.g05d7b5fc-1
lskat22.08.3.r886.ged80748-122.08.3.r889.g315f411-1
mailcommon22.08.3.r1338.g4e2aa9c-122.08.3.r1342.g9e584b5-1
mailimporter22.08.3.r562.g8bb4d6c-122.08.3.r563.gcaf8517-1
marble22.08.3.r13510.ga4244d046-122.08.3.r13520.g6cc492bf7-1
marble-common22.08.3.r13510.ga4244d046-122.08.3.r13520.g6cc492bf7-1
marble-qt22.08.3.r13510.ga4244d046-122.08.3.r13520.g6cc492bf7-1
markdownpart22.08.3.r150.g26bb968-122.08.3.r154.g410dd08-1
maui-clip 2.2.0.r33.g5c8fa48-1 2.2.1.r3.g59cd59d-1
maui-core r8.gca24d8e-1 r9.gb298165-1
maui-nota 2.2.0.r24.g5335440-1 2.2.1.r2.geab6fb6-1
maui-pix 2.2.0.r37.gfe08be8-1 2.2.1.r6.g5e4c24b-1
maui-shell 0.5.5.r22.g3f4826c-1 0.5.6.r1.gf0531a4-1
mauikit2.2.0.r77.gdc4c5c42-12.2.1.r13.g11c6aa1b-1
mauikit-accounts 2.2.0.r15.g2d1fe90-1 2.2.1.r3.g3ce2ae2-1
mauikit-filebrowsing 2.2.0.r22.gdd88716-1 2.2.0.r27.ge0ff0a5-1
mauikit-imagetools 2.2.0.r15.gf120fa6-1 2.2.1.r3.gccd337e-1
mauikit-texteditor 2.2.0.r17.g23948dd-1 2.2.1.r3.g1f35d31-1
mauiman r34.7a65fa5-1 r35.a53a589-1
mbox-importer22.08.3.r597.g33f7050-122.08.3.r598.ged1d679-1
messagelib22.08.3.r6779.gac2dd59f9-122.08.3.r6801.ga25f94bc3-1
milou5.26.3.r797.g5e267c0-15.26.4.r798.ga6b052d-1
minuet22.08.3.r644.gc6647da-122.08.3.r646.ga57a4f5-1
modemmanager-qt5.100.0.r568.ge1b39d1-15.100.0.r569.g7f54587-1
neochat22.09.r222.gd647bae1-1 22.11.r8.g71661621-1
networkmanager-qt5.100.0.r1173.g11e0a5e-15.100.0.r1174.g9da6510-1
okular22.08.3.r9891.ge3920241f-122.08.3.r9906.g1f6f332dd-1
oxygen5.26.3.r4525.g628cd2d9-15.26.4.r4529.g6fc5f190-1
palapeli22.08.3.r1343.gab77616-122.08.3.r1345.g14cd1f2-1
parley22.08.3.r4565.g63279288-122.08.3.r4568.gb3a0f818-1
partitionmanager22.08.3.r1682.g3ba8726-122.08.3.r1687.g78024d8-1
picmi22.08.3.r604.ge413c75-122.08.3.r606.gf01a2ed-1
pim-data-exporter22.08.3.r2825.gca882357-122.08.3.r2829.g9dfc56c5-1
pim-sieve-editor22.08.3.r1692.gb8a6152-122.08.3.r1696.gb884165-1
pimcommon22.08.3.r1690.gab3d518c-122.08.3.r1756.g9fd7191b-1
plank-player5.26.0.r99.g72d5644-15.26.0.r102.ga67876b-1
plasma-bigscreen5.26.0.r570.g0212ca7-15.26.0.r575.ga1d0b9a-1
plasma-browser-integration5.26.3.r1385.g393ad005-15.26.4.r1392.g35645c10-1
plasma-camera 1.0.r141.gaec6806-1 1.0.r142.g175ddeb-1
plasma-desktop5.26.3.r9832.gc910673c0-15.26.4.r9881.g02522145c-1
plasma-dialer 22.09.r61.gdff085f-1 22.11.r5.g26b9fff-1
plasma-disks5.26.3.r312.g19bfd1d-15.26.4.r314.g638f408-1
plasma-firewall5.26.3.r682.g92fa5e9-15.26.4.r684.g2176bb5-1
plasma-framework5.100.0.r16528.g60294f9fa-15.100.0.r16553.g1335fe7e3-1
plasma-integration5.26.3.r603.g8e42038-15.26.4.r607.g702143f-1
plasma-mobile5.26.3.r2067.g56342d15b-15.26.4.r2075.g662d01231-1
plasma-mobile-nm5.26.3.r3429.g0cc6d1af-15.26.4.r3438.ged87f52b-1
plasma-nano5.26.3.r208.gbf64b9c-15.26.4.r209.g5eb043f-1
plasma-nm5.26.3.r3429.g0cc6d1af-15.26.4.r3438.ged87f52b-1
plasma-pa5.26.3.r1142.ga1113ce-15.26.4.r1151.g5af911d-1
plasma-phonebook 22.09.r10.ge3b2f94-1 22.11.r2.ge5a24db-1
plasma-remotecontrollers5.26.0.r191.g630d542-15.26.0.r199.g8f37d27-1
plasma-sdk5.26.3.r2433.gedb7739b-15.26.4.r2441.g0c211f32-1
plasma-settings 22.09.r43.ge1911ba-1 22.11.r1.g9b39ee0-1
plasma-systemmonitor5.26.3.r657.g74878d3-15.26.4.r661.g90b19ef-1
plasma-thunderbolt5.26.3.r210.g1202636-15.26.4.r211.gf677e3a-1
plasma-vault5.26.3.r406.g6fac1d8-15.26.4.r409.g89d7e72-1
plasma-wayland-session5.26.3.r12708.g3004a2aa0-15.26.4.r12783.g8cd3c8658-1
plasma-workspace5.26.3.r12708.g3004a2aa0-15.26.4.r12783.g8cd3c8658-1
plasma-workspace-wallpapers5.26.3.r400.g82fdc0d-15.26.4.r401.g0bb54a1-1
plasmatube 22.09.r14.gaf49c26-1 22.11.r2.gcb838ae-1
polkit-kde-agent5.26.3.r548.gdfec6d5-15.26.4.r549.g020c2c5-1
powerdevil5.26.3.r2626.g7b926707-15.26.4.r2637.ge3184d0d-1
print-manager22.08.3.r1200.g92282ea-122.08.3.r1203.g495c408-1
prison5.100.0.r412.g3391404-15.100.0.r413.g5eb99ca-1
purpose5.100.0.r1035.g865d5b7-15.100.0.r1038.gb0c8e4f-1
qcachegrind22.08.3.r1214.ge4f32fc-122.08.3.r1218.g7eac263-1
qmlkonsole 22.09.r29.gb9cdc9f-1 22.11.r2.g9e23416-1
qqc2-breeze-style5.26.3.r257.g4b93c28-15.26.4.r260.g6e00e57-1
qqc2-desktop-style5.100.0.r688.ge4df7e7-15.100.0.r694.g0cf33c5-1
rocs22.08.3.r3152.g95ce6ef5-122.08.3.r3154.g2a82913e-1
sddm0.19.0.r169.gebe6110-10.19.0.r170.g3e48649-1
sddm-kcm5.26.3.r705.g7a8e25b-15.26.4.r706.g30665d9-1
solid5.100.0.r823.g596d188-15.100.0.r828.g08825c7-1
sonnet5.100.0.r732.gfe576a4-15.100.0.r735.gecc9949-1
spacebar 22.09.r11.g8cb2c8a-1 22.11.r2.gc46ed5a-1
spectacle22.08.3.r1425.g908a305-122.08.3.r1428.gcaf7e17-1
step22.08.3.r1277.gd6890c3-122.08.3.r1281.g2c848cf-1
svgpart22.08.3.r251.g0621cf7-122.08.3.r254.gc8535af-1
sweeper22.08.3.r605.g51118f2-122.08.3.r609.g3e84d44-1
syndication5.100.0.r891.gcb95aa4-15.100.0.r892.g37b2cec-1
systemsettings5.26.3.r2774.g0f01b7e6-15.26.4.r2778.g6554f2c9-1
telepathy-kde-accounts-kcm22.08.3.r1231.g9093a80-122.08.3.r1232.g10ab4d3-1
telepathy-kde-approver22.08.3.r316.gf8ede79-122.08.3.r317.g8394cdf-1
telepathy-kde-auth-handler22.08.3.r295.g8b2828f-122.08.3.r296.ga842d5c-1
telepathy-kde-call-ui22.08.3.r461.gfd46554-122.08.3.r463.g9ef5091-1
telepathy-kde-common-internals22.08.3.r2037.g988694a-122.08.3.r2038.gc8b2cde-1
telepathy-kde-contact-list22.08.3.r1106.gc7ed4ce-122.08.3.r1108.g6efb8b0-1
telepathy-kde-contact-runner22.08.3.r276.g3090aa6-122.08.3.r278.g9bfe4e8-1
telepathy-kde-desktop-applets22.08.3.r1018.gb7c017b-122.08.3.r1019.ge3b074b-1
telepathy-kde-filetransfer-handler22.08.3.r238.gd8d3894-122.08.3.r239.gc96a51b-1
telepathy-kde-integration-module22.08.3.r414.g1f6eba6-122.08.3.r415.gd338d2c-1
telepathy-kde-send-file22.08.3.r248.gcfe98b2-122.08.3.r249.g3a0a7db-1
telepathy-kde-text-ui22.08.3.r2063.gdb02e924-122.08.3.r2066.g85f16e84-1
threadweaver5.100.0.r560.gc3a28aa-15.100.0.r561.gd4afa61-1
tokodon 22.09.r65.gac30161-1 22.11.r37.gf61f5a7-1
vakzination 22.09.r24.gd2adbbe-1 22.11.r2.gc5a4848-1
vvave 2.2.0.r27.ge1dc21b-1 2.2.1.r7.g2dc9de9-1
xdg-desktop-portal-kde5.26.3.r563.gce90e78-15.26.4.r577.gf5979ed-1
yakuake22.08.3.r850.g4bdc1c1-122.08.3.r859.gd94682d-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
