[ARM Testing Update] 2022-10-26 - ICU, SystemD, Ruby and kernels
Hello ARM community.
Here’s another pretty standard update.
iculogo_64
Some highlights:
  • Most of our kernels got updated
  • Firefox updated to 106.0.1
  • ICU updated to 72.1. Did we miss any rebuilds?
  • SystemD updated to 251.7
  • More Ruby packages added to repository
  • Lots of Mobile specific packages got updated
  • Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Wed Oct 26 20:23:47 CEST 2022)
  • arm-testing community aarch64: 414 new and 343 removed package(s)
  • arm-testing core aarch64: 31 new and 31 removed package(s)
  • arm-testing extra aarch64: 338 new and 335 removed package(s)
  • arm-testing kde-unstable aarch64: 357 new and 357 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE          2022-10-21         2022-10-26
                               box64              0.1.8-1              0.1.8-2
                    dfl-applications              0.1.0-1              0.1.1-1
                     dfl-color-utils              0.1.0-1              0.1.1-1
                   dfl-config-parser              0.1.0-1              0.1.1-1
                   dfl-gamma-effects              0.1.0-1              0.1.1-1
                         dfl-inotify              0.1.0-1              0.1.1-1
                             dfl-ipc              0.1.0-1              0.1.1-1
                         dfl-layouts              0.1.0-1              0.1.1-1
                          dfl-login1              0.1.0-1              0.1.1-1
                    dfl-notification              0.1.0-1              0.1.1-1
                           dfl-power              0.1.0-1              0.1.1-1
                        dfl-settings              0.1.0-1              0.1.1-1
                 dfl-status-notifier              0.1.0-1              0.1.1-1
                         dfl-storage              0.1.0-1              0.1.1-1
                           dfl-utils              0.1.0-1              0.1.1-1
                          dfl-volume              0.1.0-1              0.1.1-1
                           dfl-wayqt              0.1.0-1              0.1.1-1
                             dfl-xdg              0.1.0-1              0.1.1-1
                            electron             21.1.1-1             21.2.0-1
                          electron20             20.3.2-1             20.3.3-1
                     element-desktop            1.11.10-1            1.11.12-1
                         element-web            1.11.10-1            1.11.12-1
                                 mce            1.111.0-1            1.112.0-1
                         mce-headers             1.30.0-1             1.31.0-1
            nemo-qml-plugin-calendar             0.6.47-1             0.6.48-1
                opi4lts-post-install           20220630-1           20221025-1
                            topgrade              9.1.1-1             10.0.1-1
                           usb-moded       0.86.0+mer58-1       0.86.0+mer59-1
                 box64-apple-silicon                    -              0.1.8-2
                dfl-applications-qt6                    -              0.1.1-1
                 dfl-color-utils-qt6                    -              0.1.1-1
               dfl-config-parser-qt6                    -              0.1.1-1
               dfl-gamma-effects-qt6                    -              0.1.1-1
                     dfl-inotify-qt6                    -              0.1.1-1
                         dfl-ipc-qt6                    -              0.1.1-1
                     dfl-layouts-qt6                    -              0.1.1-1
                      dfl-login1-qt6                    -              0.1.1-1
                dfl-notification-qt6                    -              0.1.1-1
                       dfl-power-qt6                    -              0.1.1-1
                    dfl-settings-qt6                    -              0.1.1-1
             dfl-status-notifier-qt6                    -              0.1.1-1
                     dfl-storage-qt6                    -              0.1.1-1
                       dfl-utils-qt6                    -              0.1.1-1
                      dfl-volume-qt6                    -              0.1.1-1
                       dfl-wayqt-qt6                    -              0.1.1-1
                         dfl-xdg-qt6                    -              0.1.1-1
:: Different sync package(s) in repository community aarch64
                               acorn            1:8.8.0-1            1:8.8.1-1
                        ansible-lint              6.8.2-1              6.8.2-2
              arch-release-promotion              0.2.2-1              0.2.2-2
                             aws-cli            1.25.92-1            1.25.97-1
                          babel-core             7.19.3-1             7.19.6-1
                bash-language-server              3.1.0-1              3.1.0-2
                           bctoolbox             5.1.64-1             5.1.66-1
                               bzrtp             5.1.64-1             5.1.66-1
                             calibre              6.7.1-1              6.7.1-2
                         cargo-audit             0.17.2-1             0.17.2-2
                           cargo-pgx              0.5.3-1              0.5.6-1
                       cargo-release             0.21.4-1             0.22.1-1
                             cockpit                277-1                278-1
                    cockpit-machines                275-1                276-1
                  cockpit-packagekit                277-1                278-1
                         cockpit-pcp                277-1                278-1
                      cockpit-podman                 54-1                 55-1
                    cockpit-storaged                277-1                278-1
                           codespell              2.2.1-1              2.2.2-1
                   containers-common           1:0.49.1-2           1:0.50.1-1
                             couchdb              3.2.2-3              3.2.2-4
                           cpp-hocon             0.3.0-12             0.3.0-13
                             crystal              1.6.0-1              1.6.1-1
                   cutefish-settings                0.8-2                0.8-3
                         dark-reader             4.9.58-1             4.9.59-1
                           darktable            2:4.0.1-1            2:4.0.1-2
                              dbmate             1.15.0-2             1.16.0-1
                                dino              0.3.0-3              0.3.0-4
                              docker         1:20.10.19-1         1:20.10.20-1
                      docker-compose             2.12.0-1             2.12.2-1
                         docker-scan             0.20.0-1             0.21.0-1
                               doctl             1.84.0-1             1.84.1-1
                             dovecot           2.3.19.1-1           2.3.19.1-2
                  dovecot-fts-xapian              1.5.5-3              1.5.5-4
                           drone-cli              1.6.0-1              1.6.1-1
                              dwdiff              2.1.4-4              2.1.4-5
                             e-antic              1.2.1-2              1.2.3-1
                                 eva              0.3.0-1              0.3.0-2
                              facter            3.14.24-2            3.14.24-3
                 firefox-dark-reader             4.9.58-1             4.9.59-1
                             freeciv              3.0.3-1              3.0.3-2
               freepats-general-midi           20210329-2           20210329-3
                             freerdp            2:2.8.1-1            2:2.8.1-2
                              fuzzel              1.7.0-2              1.8.0-1
                           fwbuilder             5.3.7-11             5.3.7-12
                                 gap             4.12.0-5             4.12.1-2
                        gap-packages             4.12.0-5             4.12.1-2
                                 gdu             5.19.0-1             5.20.0-1
                               geary             1:40.0-8             1:40.0-9
                               gerbv              2.8.1-2              2.9.3-1
                                giac           1.9.0.21-2           1.9.0.25-1
                       gitlab-runner             15.4.0-1             15.5.0-1
                        gnustep-base             1.28.0-4             1.28.0-5
                         go-licenses              1.4.0-1              1.5.0-1
                            go-tools           4:0.1.12-1            4:0.2.0-1
                            goaurrpc              1.1.7-1             1.1.10-1
                                grex              1.4.0-1              1.4.1-1
                              hackrf          2021.03.1-2          2022.09.1-1
                               hiera              3.8.0-1             3.10.0-1
                      home-assistant        1:2022.10.4-1        1:2022.10.5-1
                           hypercorn             0.13.2-2             0.14.3-1
                               i3-wm               4.21-3             4.21.1-1
                               icewm              3.0.1-1              3.1.0-1
                                 imv              4.3.1-5              4.3.1-6
                                  jc             1.22.0-1             1.22.1-1
                jedi-language-server             0.37.0-1             0.37.0-2
                             jenkins              2.374-1              2.375-1
                                jmol           14.32.77-1           14.32.78-1
                               jruby            9.3.8.0-1            9.3.9.0-1
                               jsmol           14.32.77-1           14.32.78-1
                          jupyterlab              3.4.8-1              3.5.0-1
                                 k9s             0.26.6-1             0.26.7-1
                             kbibtex            1:0.9.2-7            1:0.9.2-8
                          leatherman             1.12.8-3             1.12.9-1
                            libcpuid              0.6.0-1              0.6.1-1
                          libdatovka              0.2.1-2              0.2.1-3
                            libkiwix             11.0.0-2             11.0.0-3
                      libmodsecurity            1:3.0.8-1            1:3.0.8-2
              libperconaserverclient          8.0.29_21-2          8.0.29_21-3
                  libretro-core-info             1.11.1-1             1.12.0-1
            libretro-genesis-plus-gx               1935-1               1946-1
                       libretro-mame              84794-1              84800-1
                       libretro-mgba               8596-1               8598-1
              libretro-shaders-slang               1090-1               1105-1
                         libwhereami             0.5.0-14             0.5.0-15
                              libzdb              3.2.2-2              3.2.3-1
                              libzim              8.0.1-1              8.0.1-2
                              lutris             0.5.11-1             0.5.11-2
                                 lxd                5.6-2                5.7-1
                                maim              5.7.4-4              5.7.4-5
                        makedumpfile              1.7.1-1              1.7.2-1
                              mapnik             3.1.0-13             3.1.0-14
                      matrix-synapse             1.68.0-1             1.69.0-1
                               mdcat             0.28.0-1             0.29.0-1
                       mediastreamer             5.1.64-1             5.1.66-1
                         meilisearch             0.28.1-1             0.29.1-1
                               minio         2022.08.25-1         2022.10.24-1
                        minio-client         2022.08.23-1         2022.10.22-1
                   mitmproxy2swagger              0.7.0-1              0.7.0-2
                      mongo-c-driver             1.23.0-1             1.23.1-1
                     multipath-tools              0.9.1-1              0.9.1-2
                                mypy              0.981-1              0.982-1
                             ncmpcpp              0.9.2-8              0.9.2-9
                             nerdctl             0.23.0-1              1.0.0-1
                  nextcloud-app-news             18.2.0-1             18.3.0-1
                       nginx-mod-ndk         0.33+0.3.1-3         0.33+0.3.2-3
                       nginx-mod-njs              0.7.7-1              0.7.8-1
                  nginx-mod-set-misc         0.33+0.3.1-3         0.33+0.3.2-3
                           nicotine+              3.2.5-1              3.2.6-1
                            node-gyp              9.2.0-1              9.3.0-1
                              nodejs            18.11.0-2             19.0.0-2
                  nodejs-lts-fermium            14.20.0-1            14.20.0-2
                  nodejs-lts-gallium            16.16.0-1            16.16.0-2
                   npm-check-updates            16.3.11-1            16.3.15-1
                              nuitka              1.1.5-1              1.1.6-1
                              octave              7.2.0-3              7.2.0-4
                                 oil             0.12.7-1             0.12.8-1
                            onefetch             2.12.0-2             2.13.1-1
                             opencsg              1.4.2-3              1.5.1-1
                            openrct2              0.4.2-1              0.4.2-2
                             openttd               12.2-3               12.2-4
                                ortp             5.1.64-1             5.1.66-1
             pantheon-geoclue2-agent              1.0.5-2              1.0.6-1
                 pantheon-onboarding              7.0.0-2              7.0.1-1
                            parallel           20220922-1           20221022-1
                       parallel-docs           20220922-1           20221022-1
                                  pd             0.52.2-1             0.53.0-1
                      percona-server          8.0.29_21-2          8.0.29_21-3
              percona-server-clients          8.0.29_21-2          8.0.29_21-3
             perl-cpan-perl-releases         5.20220922-1         5.20221020-1
                       perl-datetime               1.58-1               1.59-1
                perl-datetime-locale               1.36-1               1.37-1
                perl-email-messageid              1.406-4              1.407-1
           perl-email-mime-encodings              1.315-4              1.316-1
                   perl-email-sender              2.500-3              2.600-1
                perl-params-validate               1.30-3               1.31-1
                         php-mongodb             1.14.1-1             1.14.1-2
                        php7-mongodb             1.14.1-1             1.14.1-2
                         pipe-rename              1.5.0-1              1.6.0-1
                         pmbootstrap             1.47.1-1             1.48.0-1
                              podman              4.2.1-1              4.3.0-1
                       podman-docker              4.2.1-1              4.3.0-1
                              poedit            1:3.1.1-1            1:3.1.1-2
                              puppet             7.18.0-1             7.20.0-1
                     python-aiofiles             22.1.0-1             22.1.0-2
                  python-argon2_cffi             21.3.0-1             21.3.0-2
               python-awesomeversion             22.9.0-1             22.9.0-2
                     python-backcall              0.2.0-6              0.2.0-7
                        python-boto3            1.24.91-1            1.24.96-1
                     python-botocore            1.27.91-1            1.27.96-1
                    python-braintree             4.17.0-1             4.17.1-1
                       python-btrees             4.10.0-1             4.10.1-1
                        python-cachy              0.3.0-7              0.3.0-8
                       python-cattrs             22.2.0-1             22.2.0-2
                     python-cfn-lint             0.67.0-1             0.68.1-1
           python-charset-normalizer              2.1.1-1              3.0.0-1
                       python-clikit              0.6.2-7              0.6.2-8
                     python-colorama              0.4.5-1              0.4.6-1
                      python-confuse              2.0.0-1              2.0.0-2
                    python-crashtest              0.4.0-1              0.4.0-2
                python-cssbeautifier             1.14.6-2             1.14.7-1
                     python-cwcwidth              0.1.6-2              0.1.7-1
                    python-deepmerge              1.0.1-1              1.1.0-1
                     python-dict2xml              1.7.1-1              1.7.2-1
                   python-diff-cover              7.0.1-1              7.0.1-2
                     python-django-q              1.3.9-4              1.3.9-5
                        python-faker              9.6.0-1              9.7.0-1
                        python-fido2              1.0.0-1              1.0.0-2
                    python-fonttools             4.37.4-1             4.38.0-1
                python-geographiclib                2.0-1                2.0-2
                  python-google-auth              2.4.1-1              2.6.0-1
                      python-hacking              4.1.0-2              5.0.0-1
                     python-identify              2.5.6-1              2.5.7-1
                      python-inflect              6.0.1-1              6.0.2-1
                       python-invoke              1.7.1-1              1.7.2-1
                    python-ipykernel             6.16.1-1             6.16.2-1
                      python-iso8601              1.1.0-1              1.1.0-2
                        python-isort             5.10.1-5             5.10.1-6
                 python-jsbeautifier             1.14.6-2             1.14.7-1
               python-jupyter_client              7.4.3-1              7.4.4-1
                 python-latex2mathml             3.71.0-1             3.73.1-1
                  python-levenshtein             0.20.5-1             0.20.7-1
               python-more-itertools             8.14.0-1              9.0.0-1
                         python-moto              4.0.6-1              4.0.8-1
                        python-nkdfu                0.1-3                0.1-4
                       python-orjson              3.8.0-1              3.8.1-1
                      python-oslo-db             12.1.0-1             12.2.0-1
                     python-oslo-log              5.0.0-1              5.0.1-1
                       python-owslib             0.26.0-1             0.27.2-1
                       python-pastel              0.2.1-4              0.2.1-5
                          python-pbr             5.10.0-1             5.11.0-1
                   python-persistent              4.9.0-1              4.9.1-1
                 python-phonenumbers            8.12.56-1            8.12.57-1
                       python-plette              0.4.1-1              0.4.2-1
                       python-psutil              5.9.2-1              5.9.3-1
                    python-pure-eval              0.2.2-1              0.2.2-2
                      python-pycosat              0.6.3-5              0.6.4-1
                        python-pyicu                2.9-1               2.10-1
                        python-pyjwt              2.5.0-1              2.6.0-1
                        python-pyocd             0.34.1-1             0.34.2-1
                    python-pyppeteer              1.0.2-1              1.0.2-2
               python-pytest-asyncio             0.19.0-1             0.20.0-1
                 python-pytest-httpx             0.21.0-1             0.21.1-1
              python-pytest-metadata              2.0.2-1              2.0.2-2
           python-pytest-param-files              0.3.4-1              0.3.4-2
               python-pytest-twisted             1.13.4-2             1.14.0-1
                     python-pytzdata             2020.1-6             2020.1-7
                   python-quart-cors              0.5.0-3              0.5.0-4
                    python-rapidjson                1.8-1                1.9-1
                    python-reactivex              4.0.4-1              4.0.4-2
                         python-rich             12.6.0-1             12.6.0-2
                         python-rope              1.3.0-1              1.4.0-1
                        python-rtree              1.0.0-1              1.0.1-1
             python-ruamel.yaml.clib              0.2.6-3              0.2.7-1
                   python-s3transfer              0.6.0-2              0.6.0-3
                        python-spsdk              1.7.1-1              1.8.0-1
                   python-sqlalchemy             1.4.41-1             1.4.42-1
                    python-stevedore              4.0.1-1              4.1.0-1
                        python-sword              1.9.0-5              1.9.0-6
                    python-terminado             0.16.0-1             0.17.0-1
                     python-tinycss2              1.1.1-1              1.2.1-1
                      python-tomlkit             0.11.5-1             0.11.5-2
            python-typing_extensions              4.3.0-1              4.4.0-1
                       python-uvloop             0.16.0-3             0.17.0-1
                   python-weasyprint               57.0-1               57.0-2
                        python-xattr              0.9.9-1             0.10.0-1
                         python-zipp              3.9.0-1             3.10.0-1
                                   r              4.2.1-2              4.2.1-3
                              rclone             1.59.2-1             1.60.0-1
                              reaper               6.68-1               6.69-1
                             remmina           1:1.4.27-1           1:1.4.27-2
                              rlwrap             0.45.2-1               0.46-1
                              rspamd                3.3-1                3.3-2
                           rss2email               3.14-3               3.14-4
                          rubberband              3.1.0-1              3.1.1-1
                       ruby-async-io             1.33.0-1             1.34.0-1
          ruby-certificate_authority              1.1.0-1              1.1.0-2
                ruby-climate_control              1.1.1-1              1.2.0-1
                        ruby-console             1.16.0-2             1.16.2-1
        ruby-cucumber-ci-environment              9.1.0-1              9.1.0-2
                  ruby-gettext-setup               0.34-3              1.1.0-1
                    ruby-http-cookie              1.0.3-7              1.0.5-1
                    ruby-json-schema              3.0.0-1              3.0.0-2
                        ruby-msgpack              1.5.6-1              1.6.0-1
                      ruby-nats-pure              2.1.2-1              2.2.0-1
                   ruby-power_assert              2.0.1-1              2.0.2-1
            ruby-puppet-resource_api             1.8.14-1             1.8.16-1
                       rust-analyzer           20221017-1           20221024-1
                        rust-bindgen             0.60.1-1             0.61.0-1
                       schismtracker           20220905-1           20221020-1
                             scribus             1.5.8-10             1.5.8-11
                           seamonkey            2.53.14-1            2.53.14-2
                             shotcut           22.09.23-1           22.10.22-1
                                sile             0.14.3-2             0.14.3-3
                                slop                7.6-1                7.6-2
                            smartdns                 38-1               38.1-1
                               sonic              1.3.5-1              1.4.0-1
                          strawberry              1.0.9-1             1.0.10-2
                               sugar              0.118-2              0.119-1
                       sugar-artwork              0.118-1              0.119-1
                     sugar-datastore              0.118-3              0.119-1
                  sugar-toolkit-gtk3              0.118-3              0.119-1
                                suil            0.10.16-3            0.10.18-1
                           suil-docs            0.10.16-3            0.10.18-1
                            sundials              6.3.0-1              6.4.0-1
                            surge-xt              1.1.1-4              1.1.1-5
            switchboard-plug-desktop              6.3.0-1              6.3.1-1
           switchboard-plug-keyboard              3.0.0-1              3.1.0-1
            switchboard-plug-network              2.4.3-1              2.4.4-1
    switchboard-plug-online-accounts              6.5.0-1              6.5.1-1
  switchboard-plug-parental-controls              6.0.0-2              6.0.1-1
           switchboard-plug-printers              2.2.0-1              2.2.1-1
            switchboard-plug-sharing              2.1.5-2              2.1.6-1
      switchboard-plug-user-accounts              2.4.2-2              2.4.3-1
                           tailscale             1.32.0-1             1.32.1-1
                           taplo-cli              0.7.0-1              0.7.2-1
                            tealdeer              1.6.0-1              1.6.1-1
                            tectonic             0.11.0-1             0.11.0-2
                                tepl            1:6.0.2-1            1:6.0.2-2
                           tesseract              5.2.0-1              5.2.0-2
             thunderbird-dark-reader             4.9.58-1             4.9.59-1
                    timescaledb-tune             0.14.1-1             0.14.2-1
                              tt-rss 2:r11370.d47b8c849-1 2:r11390.602e86842-1
                           uglify-js             3.17.3-1             3.17.4-1
                          unarchiver             1.10.7-6             1.10.7-7
                             unbound             1.16.3-1             1.17.0-1
                             uvicorn             0.18.3-1             0.19.0-1
         v2ray-domain-list-community     20221017132030-1     20221025131054-1
                         v2ray-geoip       202210130107-1       202210200105-1
                   v4l2loopback-dkms             0.12.5-2             0.12.7-2
                  v4l2loopback-utils             0.12.5-2             0.12.7-2
                            vbam-sdl2.1.4.r573.7f1d49d3-12.1.4.r637.ea2a929f-1
                             vbam-wx2.1.4.r573.7f1d49d3-12.1.4.r637.ea2a929f-1
                           virtualgl              3.0.1-1              3.0.2-1
                              vnstat                2.9-1               2.10-1
                             vulture                2.6-1                2.6-2
                            wallabag              2.5.1-2              2.5.2-1
                          warpinator             1.2.13-1             1.2.14-1
                             weechat                3.7-1              3.7.1-1
        wingpanel-indicator-keyboard              2.4.0-2              2.4.1-1
           wingpanel-indicator-power              6.1.0-2              6.2.0-1
                                wofi                1.3-1                1.3-2
                           wvstreams             4.6.1-18             4.6.1-19
                               wxsvg             1.5.23-4             1.5.24-1
                             xalan-c             1:1.12-5             1:1.12-6
                              xiphos              4.2.1-9             4.2.1-10
                               xmrig             6.18.0-1             6.18.1-1
                                 yaz             5.32.0-1             5.32.0-2
                               ytfzf              2.5.0-2              2.5.2-1
                              zellij             0.31.4-1             0.32.0-1
                                zint             2.11.0-1             2.11.1-1
                             zint-qt             2.11.0-1             2.11.1-1
                                 znc             1.8.2-11             1.8.2-12
                          aws-cli-v2                    -              2.8.5-1
                     cargo-auditable                    -              0.5.2-2
                    j4-dmenu-desktop                    -               2.18-4
                       python-awscrt                    -             0.14.7-1
                       python-libvcs                    -             0.19.0-1
                           repro-get                    -              0.2.0-1
               ruby-async-http-cache                    -              0.4.3-1
                ruby-async-websocket                    -             0.22.1-1
                  ruby-awesome_print                    -              1.9.2-1
              ruby-build-environment                    -             1.13.0-1
                           ruby-bump                    -             0.10.0-1
                         ruby-byebug                    -             11.1.3-1
                        ruby-coderay                    -              1.1.3-2
     ruby-cucumber-compatibility-kit                    -             11.0.1-2
                  ruby-cucumber-core                    -             11.0.0-1
               ruby-cucumber-gherkin                    -             24.1.0-1
              ruby-cucumber-messages                    -           19.1.4-1.1
                         ruby-fakefs                    -              1.8.0-1
                         ruby-falcon                    -             0.42.3-1
                     ruby-formatador                    -              1.1.0-1
                         ruby-listen                    -              3.7.1-1
                       ruby-maxitest                    -              4.2.0-1
                     ruby-maxmind-db                    -              1.1.1-1
                ruby-memory_profiler                    -              1.0.0-1
                 ruby-minitest-hooks                    -              1.5.0-1
         ruby-minitest-parallel_fork                    -              1.3.0-1
                           ruby-nenv                    -              0.3.0-1
                          ruby-netrc                    -             0.11.0-2
                        ruby-octokit                    -              6.0.0-1
                ruby-process-metrics                    -              0.2.1-1
                  ruby-protocol-rack                    -              0.2.4-1
             ruby-protocol-websocket                    -              0.9.1-1
                            ruby-pry                    -             0.14.1-1
                     ruby-pry-byebug                    -             3.10.1-1
                   ruby-rake-contrib                    -     1.0.0.20210616-1
                         ruby-rbnacl                    -              7.1.1-1
                      ruby-redcarpet                    -              3.5.1-1
                            ruby-rss                    -              0.2.9-1
                  ruby-ruby_memcheck                    -              1.2.0-1
                         ruby-sawyer                    -              0.9.2-1
                         ruby-sequel                    -             5.61.0-1
                       ruby-shellany                    -              0.0.1-1
                         ruby-shindo                    -             0.3.10-1
                ruby-shoulda-context                    -              2.0.0-3
                      ruby-snowglobe                    -     0.3.0.20200907-2
        ruby-sus-fixtures-async-http                    -              0.2.3-1
                         ruby-syntax                    -              1.2.2-1
                            ruby-vcr                    -              6.1.0-1
                ruby-warnings_logger                    -              0.1.1-2
                          ruby-xpath                    -              3.2.0-1
                       ttf-hack-nerd                    -              2.2.2-2
                   ttf-terminus-nerd                    -              2.2.2-2
                 ttf-ubuntumono-nerd                    -              2.2.2-3
:: Different overlay package(s) in repository core aarch64
                                grub2:2.06.r334.g340377470-12:2.06.r334.g340377470-2
                               linux              6.0.2-3              6.0.5-1
               linux-clockworkpi-a06              6.0.2-1              6.0.5-1
       linux-clockworkpi-a06-headers              6.0.2-1              6.0.5-1
                       linux-headers              6.0.2-3              6.0.5-1
                           linux-lts            5.15.74-1            5.15.75-1
                   linux-lts-headers            5.15.74-1            5.15.75-1
                        linux-odroid              6.0.1-1              6.0.2-1
                linux-odroid-headers              6.0.1-1              6.0.2-1
                            linux-rc            6.1.rc1-4            6.1.rc2-1
                    linux-rc-headers            6.1.rc1-4            6.1.rc2-1
                 linux-rpi4-mainline              6.0.2-1              6.0.3-1
         linux-rpi4-mainline-headers              6.0.2-1              6.0.3-1
                            linux515            5.15.74-1            5.15.75-1
                    linux515-headers            5.15.74-1            5.15.75-1
                            linux519            5.19.16-1            5.19.17-1
                    linux519-headers            5.19.16-1            5.19.17-1
                             linux60              6.0.2-1              6.0.5-1
                     linux60-headers              6.0.2-1              6.0.5-1
                  uboot-pinephonepro          5:2022.04-1          5:2022.10-0
:: Different sync package(s) in repository core aarch64
                                 icu               71.1-1               72.1-1
                             libxml2             2.10.2-2             2.10.3-2
                        libxml2-docs             2.10.2-2             2.10.3-2
                          mkinitcpio                 31-3                 32-1
                             pambase           20211210-1           20221020-1
                                sudo          1.9.11.p3-1             1.9.12-1
                             systemd              251.6-2              251.7-1
                        systemd-libs              251.6-2              251.7-1
                  systemd-resolvconf              251.6-2              251.7-1
                  systemd-sysvcompat              251.6-2              251.7-1
                            xfsprogs             5.19.0-1             5.19.0-2
:: Different overlay package(s) in repository extra aarch64
                           boxit-arm             2.1.3-10             2.1.3-12
                           calamares             3.2.61-4             3.2.61-5
            manjaro-settings-manager              0.5.7-3              0.5.7-4
        manjaro-settings-manager-kcm              0.5.7-3              0.5.7-4
                            mesa-git22.3.0_devel.161196.4c7a44413a0-122.3.0_devel.161588.813d502d7c4-1
                        qt5-es2-base    5.15.6+kde+r180-1    5.15.6+kde+r181-1
         qt5-es2-xcb-private-headers    5.15.6+kde+r180-1    5.15.6+kde+r181-1
                               snapd             2.57.4-1             2.57.5-1
                          snapd-glib               1.63-1               1.63-2
                           libcamera                    -              0.0.1-0
:: Different sync package(s) in repository extra aarch64
                         389-ds-base              2.3.0-1              2.3.0-2
                                 atk             2.38.0-1                    -
                              baobab               42.0-1               43.0-1
                                bind             9.18.7-1             9.18.8-1
                               boost             1.80.0-2             1.80.0-3
                          boost-libs             1.80.0-2             1.80.0-3
                              brltty                6.5-2                6.5-3
                 brltty-udev-generic                6.5-2                6.5-3
                            chromium     106.0.5249.119-1     106.0.5249.119-2
                             devhelp               41.3-1               43.0-1
                        devhelp-docs               41.3-1               43.0-1
                             drkonqi             5.26.1-2             5.26.1-3
                             enchant              2.3.3-1              2.3.3-2
               evolution-data-server             3.44.4-1             3.44.4-2
                               faad2             2.10.0-1             2.10.1-1
                             firefox              106.0-1            106.0.1-1
                    firefox-i18n-ach              106.0-1            106.0.1-1
                     firefox-i18n-af              106.0-1            106.0.1-1
                     firefox-i18n-an              106.0-1            106.0.1-1
                     firefox-i18n-ar              106.0-1            106.0.1-1
                    firefox-i18n-ast              106.0-1            106.0.1-1
                     firefox-i18n-az              106.0-1            106.0.1-1
                     firefox-i18n-be              106.0-1            106.0.1-1
                     firefox-i18n-bg              106.0-1            106.0.1-1
                     firefox-i18n-bn              106.0-1            106.0.1-1
                     firefox-i18n-br              106.0-1            106.0.1-1
                     firefox-i18n-bs              106.0-1            106.0.1-1
                     firefox-i18n-ca              106.0-1            106.0.1-1
            firefox-i18n-ca-valencia              106.0-1            106.0.1-1
                    firefox-i18n-cak              106.0-1            106.0.1-1
                     firefox-i18n-cs              106.0-1            106.0.1-1
                     firefox-i18n-cy              106.0-1            106.0.1-1
                     firefox-i18n-da              106.0-1            106.0.1-1
                     firefox-i18n-de              106.0-1            106.0.1-1
                    firefox-i18n-dsb              106.0-1            106.0.1-1
                     firefox-i18n-el              106.0-1            106.0.1-1
                  firefox-i18n-en-ca              106.0-1            106.0.1-1
                  firefox-i18n-en-gb              106.0-1            106.0.1-1
                  firefox-i18n-en-us              106.0-1            106.0.1-1
                     firefox-i18n-eo              106.0-1            106.0.1-1
                  firefox-i18n-es-ar              106.0-1            106.0.1-1
                  firefox-i18n-es-cl              106.0-1            106.0.1-1
                  firefox-i18n-es-es              106.0-1            106.0.1-1
                  firefox-i18n-es-mx              106.0-1            106.0.1-1
                     firefox-i18n-et              106.0-1            106.0.1-1
                     firefox-i18n-eu              106.0-1            106.0.1-1
                     firefox-i18n-fa              106.0-1            106.0.1-1
                     firefox-i18n-ff              106.0-1            106.0.1-1
                     firefox-i18n-fi              106.0-1            106.0.1-1
                     firefox-i18n-fr              106.0-1            106.0.1-1
                  firefox-i18n-fy-nl              106.0-1            106.0.1-1
                  firefox-i18n-ga-ie              106.0-1            106.0.1-1
                     firefox-i18n-gd              106.0-1            106.0.1-1
                     firefox-i18n-gl              106.0-1            106.0.1-1
                     firefox-i18n-gn              106.0-1            106.0.1-1
                  firefox-i18n-gu-in              106.0-1            106.0.1-1
                     firefox-i18n-he              106.0-1            106.0.1-1
                  firefox-i18n-hi-in              106.0-1            106.0.1-1
                     firefox-i18n-hr              106.0-1            106.0.1-1
                    firefox-i18n-hsb              106.0-1            106.0.1-1
                     firefox-i18n-hu              106.0-1            106.0.1-1
                  firefox-i18n-hy-am              106.0-1            106.0.1-1
                     firefox-i18n-ia              106.0-1            106.0.1-1
                     firefox-i18n-id              106.0-1            106.0.1-1
                     firefox-i18n-is              106.0-1            106.0.1-1
                     firefox-i18n-it              106.0-1            106.0.1-1
                     firefox-i18n-ja              106.0-1            106.0.1-1
                     firefox-i18n-ka              106.0-1            106.0.1-1
                    firefox-i18n-kab              106.0-1            106.0.1-1
                     firefox-i18n-kk              106.0-1            106.0.1-1
                     firefox-i18n-km              106.0-1            106.0.1-1
                     firefox-i18n-kn              106.0-1            106.0.1-1
                     firefox-i18n-ko              106.0-1            106.0.1-1
                    firefox-i18n-lij              106.0-1            106.0.1-1
                     firefox-i18n-lt              106.0-1            106.0.1-1
                     firefox-i18n-lv              106.0-1            106.0.1-1
                     firefox-i18n-mk              106.0-1            106.0.1-1
                     firefox-i18n-mr              106.0-1            106.0.1-1
                     firefox-i18n-ms              106.0-1            106.0.1-1
                     firefox-i18n-my              106.0-1            106.0.1-1
                  firefox-i18n-nb-no              106.0-1            106.0.1-1
                  firefox-i18n-ne-np              106.0-1            106.0.1-1
                     firefox-i18n-nl              106.0-1            106.0.1-1
                  firefox-i18n-nn-no              106.0-1            106.0.1-1
                     firefox-i18n-oc              106.0-1            106.0.1-1
                  firefox-i18n-pa-in              106.0-1            106.0.1-1
                     firefox-i18n-pl              106.0-1            106.0.1-1
                  firefox-i18n-pt-br              106.0-1            106.0.1-1
                  firefox-i18n-pt-pt              106.0-1            106.0.1-1
                     firefox-i18n-rm              106.0-1            106.0.1-1
                     firefox-i18n-ro              106.0-1            106.0.1-1
                     firefox-i18n-ru              106.0-1            106.0.1-1
                    firefox-i18n-sco              106.0-1            106.0.1-1
                     firefox-i18n-si              106.0-1            106.0.1-1
                     firefox-i18n-sk              106.0-1            106.0.1-1
                     firefox-i18n-sl              106.0-1            106.0.1-1
                    firefox-i18n-son              106.0-1            106.0.1-1
                     firefox-i18n-sq              106.0-1            106.0.1-1
                     firefox-i18n-sr              106.0-1            106.0.1-1
                  firefox-i18n-sv-se              106.0-1            106.0.1-1
                    firefox-i18n-szl              106.0-1            106.0.1-1
                     firefox-i18n-ta              106.0-1            106.0.1-1
                     firefox-i18n-te              106.0-1            106.0.1-1
                     firefox-i18n-th              106.0-1            106.0.1-1
                     firefox-i18n-tl              106.0-1            106.0.1-1
                     firefox-i18n-tr              106.0-1            106.0.1-1
                    firefox-i18n-trs              106.0-1            106.0.1-1
                     firefox-i18n-uk              106.0-1            106.0.1-1
                     firefox-i18n-ur              106.0-1            106.0.1-1
                     firefox-i18n-uz              106.0-1            106.0.1-1
                     firefox-i18n-vi              106.0-1            106.0.1-1
                     firefox-i18n-xh              106.0-1            106.0.1-1
                  firefox-i18n-zh-cn              106.0-1            106.0.1-1
                  firefox-i18n-zh-tw              106.0-1            106.0.1-1
                                flac              1.4.1-2              1.4.2-1
                            flac-doc              1.4.1-2              1.4.2-1
                             fluxbox1.3.7+205+g1d19662c-11.3.7+211+g9d8202f3-1
                          fontconfig           2:2.14.0-1           2:2.14.1-2
                     gdk-pixbuf-xlib             2.40.2-1             2.40.2-2
                         gdk-pixbuf2             2.42.9-1            2.42.10-1
                    gdk-pixbuf2-docs             2.42.9-1            2.42.10-1
                                 gdm 42.0+r11+g4a52f026-1               43.0-1
                             geoclue              2.6.0-2              2.6.0-3
              gnome-epub-thumbnailer                1.6-2                1.7-1
                              gspell             1.12.0-1             1.12.0-2
               gtk-update-icon-cache            1:4.8.1-1            1:4.8.2-1
                                gtk4            1:4.8.1-1            1:4.8.2-1
                          gtk4-demos            1:4.8.1-1            1:4.8.2-1
                           gtk4-docs            1:4.8.1-1            1:4.8.2-1
                            harfbuzz              5.3.1-1              5.3.1-3
                        harfbuzz-icu              5.3.1-1              5.3.1-3
                                 kdb              3.2.0-9             3.2.0-10
                    kdeplasma-addons             5.26.1-1             5.26.1-2
                     kirigami-addons                0.4-1                0.5-1
                              libcdr              0.1.7-4              0.1.7-5
                           libe-book             0.1.3-11             0.1.3-12
                              libgdm 42.0+r11+g4a52f026-1               43.0-1
                             libical             3.0.16-1             3.0.16-2
                        libksysguard             5.26.1-1           5.26.1-1.1
                            libmspub             0.1.4-12             0.1.4-13
                      libphonenumber          1:8.12.56-1          1:8.12.57-1
                        libqalculate              4.4.0-1              4.4.0-2
                              libqxp              0.0.2-8              0.0.2-9
                   libreoffice-fresh              7.4.2-1              7.4.2-2
               libreoffice-fresh-sdk              7.4.2-1              7.4.2-2
                   libreoffice-still              7.3.6-3              7.3.6-4
               libreoffice-still-sdk              7.3.6-3              7.3.6-4
                          libsynctex         2022.62885-1         2022.62885-2
                            libunrar            1:6.1.7-1            1:6.2.1-1
                            libvisio              0.1.7-7              0.1.7-8
                          libxrender             0.9.10-5             0.9.11-1
                              libzmf             0.0.2-12             0.0.2-13
                                lsof             4.96.3-1             4.96.4-1
                            m17n-lib             1.8.0-12             1.8.0-13
                                 mpd            0.23.10-1            0.23.10-2
                              mtools           1:4.0.41-1           1:4.0.42-1
                             nuspell              5.1.2-1              5.1.2-2
                                 orc             0.4.32-1             0.4.32-2
                                orca               42.3-1               43.0-1
              perl-email-date-format              1.005-9              1.006-1
                   perl-http-message               6.39-1               6.40-1
                   perl-log-log4perl               1.56-1               1.57-1
                            perl-uri               5.15-1               5.16-1
                                 php             8.1.11-1             8.1.11-2
                          php-apache             8.1.11-1             8.1.11-2
                             php-cgi             8.1.11-1             8.1.11-2
                           php-dblib             8.1.11-1             8.1.11-2
                           php-embed             8.1.11-1             8.1.11-2
                         php-enchant             8.1.11-1             8.1.11-2
                             php-fpm             8.1.11-1             8.1.11-2
                              php-gd             8.1.11-1             8.1.11-2
                            php-imap             8.1.11-1             8.1.11-2
                            php-intl             8.1.11-1             8.1.11-2
                            php-odbc             8.1.11-1             8.1.11-2
                           php-pgsql             8.1.11-1             8.1.11-2
                          php-phpdbg             8.1.11-1             8.1.11-2
                          php-pspell             8.1.11-1             8.1.11-2
                            php-snmp             8.1.11-1             8.1.11-2
                          php-sodium             8.1.11-1             8.1.11-2
                          php-sqlite             8.1.11-1             8.1.11-2
                            php-tidy             8.1.11-1             8.1.11-2
                             php-xsl             8.1.11-1             8.1.11-2
                                php7             7.4.32-1             7.4.32-2
                         php7-apache             7.4.32-1             7.4.32-2
                            php7-cgi             7.4.32-1             7.4.32-2
                          php7-dblib             7.4.32-1             7.4.32-2
                          php7-embed             7.4.32-1             7.4.32-2
                        php7-enchant             7.4.32-1             7.4.32-2
                            php7-fpm             7.4.32-1             7.4.32-2
                             php7-gd             7.4.32-1             7.4.32-2
                           php7-imap             7.4.32-1             7.4.32-2
                           php7-intl             7.4.32-1             7.4.32-2
                           php7-odbc             7.4.32-1             7.4.32-2
                          php7-pgsql             7.4.32-1             7.4.32-2
                         php7-phpdbg             7.4.32-1             7.4.32-2
                         php7-pspell             7.4.32-1             7.4.32-2
                           php7-snmp             7.4.32-1             7.4.32-2
                         php7-sodium             7.4.32-1             7.4.32-2
                         php7-sqlite             7.4.32-1             7.4.32-2
                           php7-tidy             7.4.32-1             7.4.32-2
                            php7-xsl             7.4.32-1             7.4.32-2
                              pixman             0.40.0-2             0.42.0-1
                            pkgstats              3.2.5-1              3.2.6-1
              plasma-wayland-session             5.26.1-1             5.26.1-3
                    plasma-workspace             5.26.1-1             5.26.1-3
                             postfix              3.7.3-1              3.7.3-2
                         postfix-cdb              3.7.3-1              3.7.3-2
                        postfix-ldap              3.7.3-1              3.7.3-2
                        postfix-lmdb              3.7.3-1              3.7.3-2
                       postfix-mysql              3.7.3-1              3.7.3-2
                        postfix-pcre              3.7.3-1              3.7.3-2
                       postfix-pgsql              3.7.3-1              3.7.3-2
                      postfix-sqlite              3.7.3-1              3.7.3-2
                          postgresql               14.5-1               14.5-2
                     postgresql-docs               14.5-1               14.5-2
                     postgresql-libs               14.5-1               14.5-2
              postgresql-old-upgrade               13.8-1               13.8-2
                     python-dbusmock             0.28.4-1             0.28.6-2
                  python-incremental             21.3.0-5            22.10.0-1
                       python-merge3              0.0.9-1             0.0.10-1
                        python-numpy             1.23.3-1             1.23.4-1
                   python-setuptools           1:63.4.2-1           1:63.4.3-1
                      python-tomli-w              1.0.0-4              1.0.0-5
            python-trove-classifiers          2022.9.26-1         2022.10.19-1
                   python-virtualenv            20.16.2-1            20.16.4-1
               python-zope-interface              5.4.0-4              5.5.0-1
                                 qbs             1.23.1-1             1.23.2-1
                            qt5-base    5.15.6+kde+r180-1    5.15.6+kde+r181-1
                       qt5-webengine            5.15.10-3            5.15.10-4
                          qt5-webkit     5.212.0alpha4-16     5.212.0alpha4-17
             qt5-xcb-private-headers    5.15.6+kde+r180-1    5.15.6+kde+r181-1
                         qt6-5compat              6.4.0-2              6.4.0-3
                            qt6-base              6.4.0-1              6.4.0-2
                       qt6-webengine              6.4.0-4              6.4.0-5
                           qtcreator              8.0.1-3              8.0.2-1
                     qtcreator-devel              8.0.1-3              8.0.2-1
                              raptor            2.0.15-19            2.0.15-20
                               rsync              3.2.6-2              3.2.7-1
                               samba             4.17.1-1             4.17.2-1
                                sddm             0.19.0-8             0.19.0-9
                           smbclient             4.17.1-1             4.17.2-1
                         texlive-bin         2022.62885-1         2022.62885-2
                         thunderbird            102.4.0-1            102.4.0-2
                 thunderbird-i18n-af            102.4.0-1            102.4.0-2
                 thunderbird-i18n-ar            102.4.0-1            102.4.0-2
                thunderbird-i18n-ast            102.4.0-1            102.4.0-2
                 thunderbird-i18n-be            102.4.0-1            102.4.0-2
                 thunderbird-i18n-bg            102.4.0-1            102.4.0-2
                 thunderbird-i18n-br            102.4.0-1            102.4.0-2
                 thunderbird-i18n-ca            102.4.0-1            102.4.0-2
                thunderbird-i18n-cak            102.4.0-1            102.4.0-2
                 thunderbird-i18n-cs            102.4.0-1            102.4.0-2
                 thunderbird-i18n-cy            102.4.0-1            102.4.0-2
                 thunderbird-i18n-da            102.4.0-1            102.4.0-2
                 thunderbird-i18n-de            102.4.0-1            102.4.0-2
                thunderbird-i18n-dsb            102.4.0-1            102.4.0-2
                 thunderbird-i18n-el            102.4.0-1            102.4.0-2
              thunderbird-i18n-en-gb            102.4.0-1            102.4.0-2
              thunderbird-i18n-en-us            102.4.0-1            102.4.0-2
              thunderbird-i18n-es-ar            102.4.0-1            102.4.0-2
              thunderbird-i18n-es-es            102.4.0-1            102.4.0-2
                 thunderbird-i18n-et            102.4.0-1            102.4.0-2
                 thunderbird-i18n-eu            102.4.0-1            102.4.0-2
                 thunderbird-i18n-fi            102.4.0-1            102.4.0-2
                 thunderbird-i18n-fr            102.4.0-1            102.4.0-2
              thunderbird-i18n-fy-nl            102.4.0-1            102.4.0-2
              thunderbird-i18n-ga-ie            102.4.0-1            102.4.0-2
                 thunderbird-i18n-gd            102.4.0-1            102.4.0-2
                 thunderbird-i18n-gl            102.4.0-1            102.4.0-2
                 thunderbird-i18n-he            102.4.0-1            102.4.0-2
                 thunderbird-i18n-hr            102.4.0-1            102.4.0-2
                thunderbird-i18n-hsb            102.4.0-1            102.4.0-2
                 thunderbird-i18n-hu            102.4.0-1            102.4.0-2
              thunderbird-i18n-hy-am            102.4.0-1            102.4.0-2
                 thunderbird-i18n-id            102.4.0-1            102.4.0-2
                 thunderbird-i18n-is            102.4.0-1            102.4.0-2
                 thunderbird-i18n-it            102.4.0-1            102.4.0-2
                 thunderbird-i18n-ja            102.4.0-1            102.4.0-2
                 thunderbird-i18n-ka            102.4.0-1            102.4.0-2
                thunderbird-i18n-kab            102.4.0-1            102.4.0-2
                 thunderbird-i18n-kk            102.4.0-1            102.4.0-2
                 thunderbird-i18n-ko            102.4.0-1            102.4.0-2
                 thunderbird-i18n-lt            102.4.0-1            102.4.0-2
                 thunderbird-i18n-ms            102.4.0-1            102.4.0-2
              thunderbird-i18n-nb-no            102.4.0-1            102.4.0-2
                 thunderbird-i18n-nl            102.4.0-1            102.4.0-2
              thunderbird-i18n-nn-no            102.4.0-1            102.4.0-2
              thunderbird-i18n-pa-in            102.4.0-1            102.4.0-2
                 thunderbird-i18n-pl            102.4.0-1            102.4.0-2
              thunderbird-i18n-pt-br            102.4.0-1            102.4.0-2
              thunderbird-i18n-pt-pt            102.4.0-1            102.4.0-2
                 thunderbird-i18n-rm            102.4.0-1            102.4.0-2
                 thunderbird-i18n-ro            102.4.0-1            102.4.0-2
                 thunderbird-i18n-ru            102.4.0-1            102.4.0-2
                 thunderbird-i18n-sk            102.4.0-1            102.4.0-2
                 thunderbird-i18n-sl            102.4.0-1            102.4.0-2
                 thunderbird-i18n-sq            102.4.0-1            102.4.0-2
                 thunderbird-i18n-sr            102.4.0-1            102.4.0-2
              thunderbird-i18n-sv-se            102.4.0-1            102.4.0-2
                 thunderbird-i18n-th            102.4.0-1            102.4.0-2
                 thunderbird-i18n-tr            102.4.0-1            102.4.0-2
                 thunderbird-i18n-uk            102.4.0-1            102.4.0-2
                 thunderbird-i18n-uz            102.4.0-1            102.4.0-2
                 thunderbird-i18n-vi            102.4.0-1            102.4.0-2
              thunderbird-i18n-zh-cn            102.4.0-1            102.4.0-2
              thunderbird-i18n-zh-tw            102.4.0-1            102.4.0-2
                             tracker1:2.3.6+r7+gb27396252-11:2.3.6+r7+gb27396252-2
                      tracker-miners1:2.3.5+r3+gd9d61d87f-31:2.3.5+r3+gd9d61d87f-4
                            tracker3              3.4.0-1              3.4.0-2
                       tracker3-docs              3.4.0-1              3.4.0-2
                     tracker3-miners              3.4.0-2              3.4.0-3
                          vte-common             0.68.0-2             0.70.1-1
                                vte3             0.68.0-2             0.70.1-1
                          webkit2gtk             2.38.0-2             2.38.1-1
                      webkit2gtk-4.1             2.38.0-2             2.38.1-1
                 webkit2gtk-4.1-docs             2.38.0-2             2.38.1-1
                      webkit2gtk-5.0             2.38.0-2             2.38.1-1
                 webkit2gtk-5.0-docs             2.38.0-2             2.38.1-1
                     webkit2gtk-docs             2.38.0-2             2.38.1-1
                           wpewebkit             2.38.0-2             2.38.0-3
                      wpewebkit-docs             2.38.0-2             2.38.0-3
                            xerces-c              3.2.3-6              3.2.3-7
                       xorg-xwayland             22.1.4-1             22.1.4-2
                        xscreensaver               6.04-1             6.05.1-1
                                yelp               42.1-2               42.2-1
                               js102                    -            102.4.0-1
                            vte-docs                    -             0.70.1-1
                                vte4                    -             0.70.1-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi22.08.2.r12838.g9a6ce855c-122.08.2.r12844.gba1c1dac6-1
                    akonadi-calendar22.08.2.r2180.g59f9b9c-122.08.2.r2184.geb13fce-1
              akonadi-calendar-tools22.08.2.r972.gc76672a-122.08.2.r974.gcda7fcb-1
                    akonadi-contacts22.08.2.r3280.g3469a159-122.08.2.r3283.g5475c03f-1
               akonadi-import-wizard22.08.2.r1859.g1381663-122.08.2.r1860.g64dbc9c-1
                        akonadi-mime22.08.2.r1766.gad5881f-122.08.2.r1770.g2817b10-1
                       akonadi-notes22.08.2.r1098.g8091c0c-122.08.2.r1100.ge785277-1
                      akonadi-search22.08.2.r1289.g4a86834-122.08.2.r1291.g213761b-1
                           akregator22.08.2.r6488.g6715fd1a-122.08.2.r6490.ge96a3605-1
                           alligator  22.09.r5.ge48029e-1  22.09.r7.g41886e2-1
                            analitza22.08.2.r2362.g7a2af5ce-122.08.2.r2363.g3a4665fb-1
                           angelfish  22.09.r4.g2d7f725-1  22.09.r7.ga1ffbf5-1
                                 ark22.08.2.r4901.g6565ee45-122.08.2.r4912.g7df8b47f-1
                          artikulate22.08.2.r1440.g770ece7-122.08.2.r1441.gf0da6fe-1
                         audiocd-kio22.08.2.r1123.g1ecc308-122.08.2.r1124.ga9bfa65-1
                           audiotube 22.09.r15.geaf62c2-1 22.09.r19.ge696298-1
                        aura-browser5.26.0.r111.g84d9e3c-15.26.0.r116.gf5e81b4-1
                               baloo5.99.0.r3085.gd7633ce8-15.99.0.r3088.g4dac7c8c-1
                       baloo-widgets22.08.2.r778.g3d64b93-122.08.2.r779.gcae8dea-1
                             blinken22.08.2.r692.g3c380af-122.08.2.r694.g55e7100-1
                           bluedevil1:5.26.1.r2470.g147e0d15-11:5.26.1.r2477.g13728f1d-1
                              bomber22.08.2.r585.g57bb259-122.08.2.r587.gd5e490a-1
                                bovo22.08.2.r795.g14e1ed8-122.08.2.r796.g0cec858-1
                              breeze5.26.1.r2497.g596256fb-15.26.1.r2499.g46d194f6-1
                                buho 2.2.0.r11.g0d74844-1 2.2.0.r12.gf0b3c54-1
                     calendarsupport22.08.2.r743.g2d47cfd-122.08.2.r746.g8bb9a8c-1
                           calindori  22.09.r8.g2faa6e8-1 22.09.r10.g21cd2f8-1
                            cervisia22.08.2.r1713.g2aea41e-122.08.2.r1715.g1d3b1b6-1
                            discover5.26.1.r8919.gb13ef056a-15.26.1.r8932.g85de6c183-1
                             dolphin22.08.2.r7138.gaa140474e-122.08.2.r7142.g3d7abd232-1
                     dolphin-plugins22.08.2.r694.gb1556c4-122.08.2.r695.g308a09a-1
                              dragon22.08.2.r1073.g2b3c59a-122.08.2.r1074.g761e57b-1
                             drkonqi5.26.1.r845.ge22e3c08-15.26.1.r851.ge182ea36-1
                               elisa22.08.2.r3054.g16342a5c-122.08.2.r3061.g4cea9ce2-1
                          elisa-qtmm22.08.2.r3054.g16342a5c-122.08.2.r3061.g4cea9ce2-1
                          eventviews22.08.2.r896.gbef897d-122.08.2.r899.gd96922f-1
                        ffmpegthumbs22.08.2.r238.g5c83dcd-122.08.2.r239.ged76270-1
                           filelight22.08.2.r1199.g5ef1116-122.08.2.r1214.g9a2766a-1
                           granatier22.08.2.r998.g956c4bf-122.08.2.r1001.gb77ccca-1
                     grantlee-editor22.08.2.r852.gd4f565c-122.08.2.r856.g1e60892-1
                       grantleetheme22.08.2.r426.g62d7144-122.08.2.r429.g2ab0058-1
                            gwenview22.08.2.r6934.g3f5e63b9-122.08.2.r6939.g7f6e88e1-1
                     incidenceeditor22.08.2.r950.ge9f4946-122.08.2.r953.g87c02d3-1
                            index-fm 2.2.0.r17.gea8f929-1 2.2.0.r18.ga3c6279-1
                           itinerary22.08.2.r2037.gd9d9155-122.08.2.r2040.gc1608eb-1
                                 juk22.08.2.r3194.g8db5cab0-122.08.2.r3196.g64269cd7-1
                                 k3b1:22.08.2.r6836.g1e092904f-11:22.08.2.r6841.g7f674a698-1
               kaccounts-integration22.08.2.r1297.g1fb97e3-122.08.2.r1298.gb5866f2-1
                 kaccounts-providers22.08.2.r406.g985ba8d-122.08.2.r407.gc5d7d23-1
                   kactivitymanagerd5.26.1.r1427.g331cfd6-15.26.1.r1428.g18969b7-1
                        kaddressbook22.08.2.r6258.gc1bfdce8-122.08.2.r6262.g9a08e581-1
                             kajongg22.08.2.r4363.g37e00b3d-122.08.2.r4364.g3c1e77b7-1
                              kalarm22.08.2.r8050.g5f4da43b-122.08.2.r8055.gacfa7dc1-1
                            kalgebra22.08.2.r2091.g42d3636-122.08.2.r2093.gef5eed0-1
                                kalk  22.09.r8.g52aff32-1 22.09.r12.g5055ec6-1
                              kamera22.08.2.r741.g4422e9b-122.08.2.r742.g85ca15d-1
                              kamoso22.08.2.r1486.g72a5bd7-122.08.2.r1487.g1328be8-1
                            kanagram22.08.2.r1337.gf273dab-122.08.2.r1344.g66c4cad-1
                              kapman22.08.2.r679.g7115f78-122.08.2.r680.g122b9f0-1
                        kapptemplate22.08.2.r1016.g88d90b3-122.08.2.r1017.ga5381a4-1
                            karchive5.99.0.r561.g78d4b9d-15.99.0.r566.gef7f40c-1
                               kasts22.09.2.r12.g5965dc5-122.09.2.r19.gc094a49-1
                                kate22.08.2.r19742.ga4a4f75f7-122.08.2.r19779.g76051e136-1
                             katomic22.08.2.r984.gb605f63-122.08.2.r985.g28aaacc-1
                               kauth5.99.0.r518.gcd10914-15.99.0.r519.g3169684-1
                             kbackup22.08.2.r467.g4284171-122.08.2.r468.gb2f0033-1
                           kblackbox22.08.2.r790.gd67bbad-122.08.2.r793.g4f7de66-1
                             kblocks22.08.2.r765.g47fecfe-122.08.2.r768.g6e012ba-1
                          kbookmarks5.99.0.r482.gddd532b-15.99.0.r483.g0225991-1
                             kbounce22.08.2.r871.gf30a8db-122.08.2.r872.gef9d504-1
                           kbreakout22.08.2.r950.g1c9e80b-122.08.2.r951.g04703bb-1
                              kbruch22.08.2.r901.g0ffc982-122.08.2.r903.gd3c8594-1
                         kcachegrind22.08.2.r1203.g4a301ad-122.08.2.r1206.g0fefada-1
                  kcachegrind-common22.08.2.r1203.g4a301ad-122.08.2.r1206.g0fefada-1
                               kcalc22.08.2.r1646.g279ae0c-122.08.2.r1647.ga09af96-1
                       kcalendarcore5.99.0.r1350.g2bba6e76e-15.99.0.r1351.ge20cf893c-1
                           kcalutils22.08.2.r998.g1100e9f9d-122.08.2.r1000.g93d2fd3ae-1
                         kcharselect22.08.2.r561.ge4e4ff6-122.08.2.r562.gc71ac51-1
                              kclock 22.09.r11.g9d2931d-1 22.09.r17.g458891a-1
                            kcmutils5.99.0.r678.g70c5ed6-15.99.0.r679.g4ef377c-1
                             kcodecs5.99.0.r443.g8db595c-15.99.0.r444.gc18e66b-1
                       kcolorchooser22.08.2.r288.gef6df1c-122.08.2.r289.gffde48c-1
                         kcompletion5.99.0.r522.gacfb583-15.99.0.r523.gba2d2fa-1
                             kconfig5.99.0.r995.g58a983cd-15.99.0.r996.g9ea88f11-1
                      kconfigwidgets5.99.0.r796.gb4cb42e3-15.99.0.r799.g236d7243-1
                           kcontacts1:5.99.0.r3358.g85d295a9-11:5.99.0.r3360.gd8e3b94d-1
                         kcoreaddons5.99.0.r1585.g408d3760-15.99.0.r1590.g2a85fffd-1
                               kcron22.08.2.r859.ge118836-122.08.2.r860.g3316783-1
                                kdav1:5.99.0.r1366.gd1af04a-11:5.99.0.r1367.g8ff5c59-1
                         kdbusaddons5.99.0.r440.g26ae9ae-15.99.0.r441.gd0f57d9-1
                       kde-cli-tools5.26.1.r1975.ge1300f5-15.26.1.r1986.g4bf656d-1
                       kde-dev-utils22.08.2.r608.ga6c98cf-122.08.2.r609.ge5f815b-1
                      kdebugsettings22.08.2.r983.g271b4f2-122.08.2.r986.gdd5cf54-1
                        kdeclarative5.99.0.r1055.gec8073d-15.99.0.r1056.g0c66b79-1
                          kdeconnect22.08.2.r3566.g135d2b8e-122.08.2.r3572.g14763af8-1
                         kdecoration5.26.1.r305.g01674cf-15.26.1.r308.g98f26a8-1
                     kdelibs4support5.99.0.r1118.gcd05154f-15.99.0.r1120.gf35b2eb8-1
              kdenetwork-filesharing22.08.2.r999.gf2bd698-122.08.2.r1001.gb76d1e1-1
                            kdenlive22.08.2.r16843.g7e534c71a-122.08.2.r16887.g2a102a480-1
                       kdepim-addons22.08.2.r4885.g2b4c3eb8a-122.08.2.r4889.g0596cf59a-1
                      kdepim-runtime22.08.2.r15640.g5fb3b17e5-122.08.2.r15647.g82cedb6c0-1
                    kdeplasma-addons5.26.1.r9100.g3a9be07f6-15.26.1.r9115.g055435b09-1
                 kdesdk-thumbnailers22.08.2.r101.g5e23b4b-122.08.2.r102.g98c5310-1
                     kdesignerplugin5.99.0.r369.gc352812-15.99.0.r370.g31c0148-1
                               kdesu5.99.0.r527.g92341b3-15.99.0.r528.g8a42451-1
                                 kdf22.08.2.r891.ga0889f1-122.08.2.r892.g0a745f1-1
                             kdialog22.08.2.r1252.g8005f3352-122.08.2.r1253.g0ef4a0bbf-1
                            kdiamond22.08.2.r748.g1cd3c2d-122.08.2.r749.gc66cdb7-1
                              kdnssd5.99.0.r370.g3cd5126-15.99.0.r371.g99c680f-1
                           kdoctools5.99.0.r689.g47a2222-15.99.0.r690.ga15060c-1
                      keditbookmarks22.08.2.r2782.g8f478999c-122.08.2.r2783.g8876df351-1
                            keysmith  22.09.r8.gedb4293-1  22.09.r9.gcec6156-1
                       kfilemetadata5.99.0.r885.g67f45f7-15.99.0.r890.g719f91e-1
                               kfind22.08.2.r2741.ge03e1cf61-122.08.2.r2742.gfaf67dd02-1
                             kfloppy22.08.2.r813.gd17d8a0-122.08.2.r814.g36049f5-1
                         kfourinline22.08.2.r1050.g4b2a2ec-122.08.2.r1053.g24b3292-1
                             kgamma55.26.1.r492.g8426f5c-15.26.1.r493.g1c37c5e-1
                          kgeography22.08.2.r1179.g48ec14a-122.08.2.r1194.g447c243-1
                                kget22.08.2.r3239.g58b852fb-122.08.2.r3250.g974dad18-1
                        kglobalaccel5.99.0.r583.g899c04d-15.99.0.r584.g0b3626a-1
                         kgoldrunner22.08.2.r1311.g908d23d-122.08.2.r1314.g39b782b-1
                                kgpg22.08.2.r3216.gf0613b9f-122.08.2.r3220.gc8e868dd-1
                            khangman22.08.2.r1636.gf66e92e-122.08.2.r1637.g1f0768a-1
                         khelpcenter22.08.2.r2793.g07b63da0-122.08.2.r2797.gcb420572-1
                           kholidays1:5.99.0.r1074.gc37db5d-11:5.99.0.r1075.g5341029-1
                            khotkeys5.26.1.r2173.gbcf7b78-15.26.1.r2175.gda0741d-1
                               khtml5.99.0.r607.g1e0caad-15.99.0.r609.g7943bd1-1
                               ki18n5.99.0.r587.gf2f6185-15.99.0.r588.g17fbacd-1
                         kiconthemes5.99.0.r645.ge69a620-15.99.0.r647.gc717531-1
                 kidentitymanagement22.08.2.r3913.g07e86d20-122.08.2.r3920.g435ad5e7-1
                                 kig22.08.2.r3243.g92b83fed-122.08.2.r3246.gd41d0eb1-1
                                kigo22.08.2.r597.g1d36b48-122.08.2.r599.g4c06176-1
                            killbots22.08.2.r820.gd0550af-122.08.2.r821.g4c6a57b-1
                     kimagemapeditor22.08.2.r532.g1b93a2d-122.08.2.r533.g9c5c482-1
                               kimap22.08.2.r1216.gb0d353e-122.08.2.r1218.g74d9f3b-1
                         kinfocenter5.26.1.r2190.g286cc9f4-15.26.1.r2197.ge8a0b00d-1
                               kinit5.99.0.r455.gdf8777a-15.99.0.r456.g6e459a4-1
                                 kio5.99.0.r5778.ge0e3a6941-15.99.0.r5797.ge68dc74fc-1
                          kio-extras22.08.2.r7358.ge8f455ca-122.08.2.r7365.g851dbd3c-1
                          kio-gdrive22.08.2.r659.ge8b511c-122.08.2.r660.gfa92e3f-1
                     kirigami-addons 1:0.4.r12.g6531d14-1  1:0.5.r5.gc2525be-1
                    kirigami-gallery22.08.2.r282.g1c88669-122.08.2.r288.gfcad879-1
                           kirigami25.99.0.r3399.g7f22b210-15.99.0.r3416.gd9140e44-1
                              kiriki22.08.2.r476.g3aaa893-122.08.2.r477.g9bdc1bb-1
                          kitemviews5.99.0.r394.gd20e55a-15.99.0.r396.gde40dec-1
                               kiten22.08.2.r1220.gcb925b8-122.08.2.r1221.g7770e55-1
                          kitinerary22.08.2.r2460.g32e8446-122.08.2.r2483.g0382eb5-1
                         kjobwidgets5.99.0.r440.g2c0f23d-15.99.0.r441.gf126000-1
                            kjsembed5.99.0.r342.g95697a9-15.99.0.r343.gbc8860f-1
                        kjumpingcube22.08.2.r865.ged1fd07-122.08.2.r866.g216b517-1
                               kldap22.08.2.r976.g411bf09-122.08.2.r979.gfdfa7a0-1
                           kleopatra22.08.2.r6884.g7aa79bb2-122.08.2.r6897.g37815c17-1
                            klettres22.08.2.r988.g20f2199-122.08.2.r989.gfd0a2e1-1
                            klickety22.08.2.r720.g6b3f9ca-122.08.2.r721.g50bf69c-1
                              klines22.08.2.r845.g57709f8-122.08.2.r846.gc29651f-1
                                kmag22.08.2.r758.g4cf24e4-122.08.2.r759.g23bf280-1
                           kmahjongg22.08.2.r1585.ge6793b1-122.08.2.r1586.gb6c2f54-1
                               kmail22.08.2.r26571.g9c861f624-122.08.2.r26586.g2f44126ef-1
                kmail-account-wizard22.08.2.r908.g1b8030c-122.08.2.r910.g2bc7ff2-1
                      kmailtransport22.08.2.r1779.ga16f23d-122.08.2.r1793.g8209306-1
                               kmbox22.08.2.r613.g06f4ad0-122.08.2.r614.gb32fc7e-1
                           kmenuedit5.26.1.r1088.gdddab18-15.26.1.r1090.g671abb3-1
                               kmime22.08.2.r1550.g441f903-122.08.2.r1554.gc777680-1
                              kmines22.08.2.r1790.g3e74f08-122.08.2.r1791.geef5d2a-1
                                kmix22.08.2.r2473.gab6fbf7e-122.08.2.r2474.gfec36ab8-1
                          kmousetool22.08.2.r465.g07e5dc0-122.08.2.r466.g5c2a6ac-1
                              kmouth22.08.2.r764.gf8814fb-122.08.2.r765.g7802d5e-1
                              kmplot22.08.2.r1531.g77a519c-122.08.2.r1534.g362a9de-1
                        knavalbattle22.08.2.r1456.ge0fe0ca-122.08.2.r1459.gc7588dd-1
                            knetwalk22.08.2.r739.g2f5d315-122.08.2.r740.g6558e1f-1
                           knewstuff5.99.0.r1410.g39c31bc6-15.99.0.r1414.gaa775a66-1
                             knights22.08.2.r1169.g8f1fbc9-122.08.2.r1175.g533f9cb-1
                              knotes22.08.2.r3716.ge2f6b0d6-122.08.2.r3719.gecf65851-1
                      knotifications5.99.0.r772.g718eb1d-15.99.0.r773.gd7e5a38-1
                       knotifyconfig5.99.0.r403.gf394131-15.99.0.r404.g7adda12-1
                                koko 22.09.r11.gbaa65a2-1 22.09.r12.g41b79ae-1
                                kolf22.08.2.r1535.g7844760-122.08.2.r1536.g3337721-1
                           kollision22.08.2.r555.gd651f35-122.08.2.r556.g689904c-1
                         kolourpaint22.08.2.r2454.gffc3a650-122.08.2.r2455.g76de268c-1
                             kompare22.08.2.r1172.g5d8b52e-122.08.2.r1174.gdde013c-1
                            kongress 22.09.r10.gc90d3f2-1 22.09.r11.gf578b40-1
                           konqueror22.08.2.r15192.g86543fe78-122.08.2.r15194.g9b951ef8d-1
                            konquest22.08.2.r962.g1a02162-122.08.2.r963.gca50384-1
                             konsole22.08.2.r8677.g84d86107-122.08.2.r8694.g28d5d2ac-1
                             kontact22.08.2.r5584.gefdab191-122.08.2.r5585.gf1a27012-1
                    kontactinterface22.08.2.r714.gb2ea15d-122.08.2.r716.g10263ea-1
                            kontrast22.08.2.r248.gfaad74e-122.08.2.r254.g81bc6ca-1
                        konversation22.08.2.r9174.g94240b6a-122.08.2.r9180.g4005cbfa-1
                       kopeninghours22.08.2.r341.ge002b36-122.08.2.r343.g4642d3c-1
                              kopete22.08.2.r16465.gdc701c7d3-122.08.2.r16470.gffea9772e-1
                          korganizer22.08.2.r11853.gb8b11ac3a-122.08.2.r11856.gb98f6ff3f-1
                       kosmindoormap22.08.2.r768.g983c81b-122.08.2.r771.gb0cd136-1
                            kpackage5.99.0.r784.g1162669-15.99.0.r785.g0a1cf68-1
                              kparts5.99.0.r620.g389e23c-15.99.0.r624.gc91f1e3-1
                                kpat22.08.2.r2645.gda201cfb-122.08.2.r2646.g9e54b75d-1
                             kpeople5.99.0.r1396.g12426cd-15.99.0.r1397.g524e41c-1
                        kpeoplevcard   0.1.r33.g3e38e36-1   0.1.r36.g9d10f77-1
                        kpimtextedit22.08.2.r1641.g2064666-122.08.2.r1643.gb30885f-1
                           kpipewire5.26.1.r153.g16baad7-15.26.1.r156.gc9a602e-1
                             kpkpass22.08.2.r311.gf73f7c4-122.08.2.r313.g42c1623-1
                             kpmcore22.08.2.r1313.g6097d82-122.08.2.r1315.gbd1d291-1
                                kpty5.99.0.r393.gd384f41-15.99.0.r394.gd23fc1d-1
                      kqtquickcharts22.08.2.r77.g9b882ce-122.08.2.r78.g22ff9c9-1
                                krdc22.08.2.r1634.g3a04496-122.08.2.r1637.g7405900-1
                           krecorder  22.09.r4.ge23da23-1 22.09.r22.g52b71ad-1
                            kreversi22.08.2.r1300.g4e5a673-122.08.2.r1302.g7b338ab-1
                                krfb22.08.2.r1522.gf1014c5-122.08.2.r1524.gc131eb9-1
                               kross5.99.0.r373.g47f9596-15.99.0.r374.ga72dd22-1
                              kruler22.08.2.r760.g2363d9e-122.08.2.r761.gb241be4-1
                           ksanecore      r636.g4ed26ec-1      r639.g3487004-1
                             kscreen5.26.1.r1568.gf1f7e4d-15.26.1.r1570.g794c46f-1
                       kscreenlocker5.26.1.r999.g68811e8-15.26.1.r1004.ga4244d3-1
                            kservice5.99.0.r1041.g9151fa3-15.99.0.r1042.g02a22d3-1
                             kshisen22.08.2.r1264.g40536a3-122.08.2.r1266.g1e2fa00-1
                               ksirk22.08.2.r1061.g00ee7b1-122.08.2.r1072.g955797b-1
                               ksmtp22.08.2.r467.gd5c62f4-122.08.2.r469.gf519128-1
                          ksnakeduel22.08.2.r877.gefd97f6-122.08.2.r878.ge60e32b-1
                          kspaceduel22.08.2.r695.gffc1c15-122.08.2.r696.gc6db0a0-1
                            ksquares22.08.2.r582.g8e37be9-122.08.2.r584.ge800c99-1
                         ksshaskpass5.26.1.r222.g1bd2dbb-15.26.1.r223.g51cd59b-1
                             ksudoku22.08.2.r1145.g34269db-122.08.2.r1146.g622ca56-1
                           ksysguard5.26.1.r3554.g461f63b4-15.26.1.r3556.gda5bf17d-1
                          ksystemlog22.08.2.r767.g99fdf44-122.08.2.r770.g7604917-1
                        ksystemstats5.26.1.r247.g088cc95-15.26.1.r249.g20df919-1
                            kteatime22.08.2.r775.g8b162a8-122.08.2.r776.g872ced5-1
                         ktexteditor5.99.0.r3594.g08a408a7-15.99.0.r3599.g47371856-1
                        ktextwidgets5.99.0.r469.g3eca2dc-15.99.0.r470.gd9d6d1c-1
                              ktimer22.08.2.r546.g7b3e31f-122.08.2.r547.g8a958c8-1
                               ktnef22.08.2.r741.ga322abb-122.08.2.r745.g7d150a1-1
                            ktorrent22.08.2.r2901.g15387c14-122.08.2.r2903.g1041e576-1
                              ktouch22.08.2.r2210.g629abd0-122.08.2.r2215.g7f0c507-1
                               ktrip  22.09.r6.gf0603f7-1  22.09.r9.gac58fc9-1
                          ktuberling22.08.2.r1099.ge695f19-122.08.2.r1100.gf6b2750-1
                             kturtle22.08.2.r1198.gd18d1db-122.08.2.r1199.ge01386e-1
                             kubrick22.08.2.r442.ge6d8a68-122.08.2.r446.gec99f4b-1
                     kunitconversion5.99.0.r438.g4046f9f-15.99.0.r439.g7702681-1
                             kwallet5.99.0.r1193.g4735169-15.99.0.r1194.g9181449-1
                      kwalletmanager22.08.2.r1312.g4864743-122.08.2.r1313.g39a2988-1
                               kwave22.08.2.r3816.g04b5918d-122.08.2.r3819.g3590eba6-1
                            kwayland5.99.0.r1193.gacd4836-15.99.0.r1194.gd31d35f-1
                            kweather  22.09.r7.gdc2fcd9-1 22.09.r12.gfd92f3d-1
                        kweathercore   0.6.r31.g0c243c0-1   0.6.r34.g7f4aeff-1
                      kwidgetsaddons5.99.0.r1002.g8b741cb1-15.99.0.r1008.g2220ac37-1
                                kwin5.26.1.r23362.gf0376367b-15.26.1.r23433.ga4cb0e7fd-1
                       kwindowsystem5.99.0.r706.ga1623e0-15.99.0.r707.g7c21769-1
                           kwordquiz22.08.2.r1215.g9d4a7b8-122.08.2.r1219.g8b24f76-1
                              kwrite22.08.2.r19742.ga4a4f75f7-122.08.2.r19779.g76051e136-1
                             kxmlgui5.99.0.r918.gad11a230-15.99.0.r920.gb065cf30-1
                       kxmlrpcclient5.99.0.r494.gdd97d4a4f-15.99.0.r495.g99bf4fa22-1
                      layer-shell-qt5.26.1.r68.gad3e8a6-15.26.1.r69.g249584d-1
                          libakonadi22.08.2.r12838.g9a6ce855c-122.08.2.r12844.gba1c1dac6-1
                         libgravatar22.08.2.r443.g3f03c6a-122.08.2.r445.g82b381d-1
                            libkcddb22.08.2.r774.g211d762-122.08.2.r775.g69ab869-1
                     libkcompactdisc22.08.2.r402.gf14280f-122.08.2.r403.g826de24-1
                         libkdegames22.08.2.r2271.g18617522-122.08.2.r2272.gb6809ae6-1
                           libkdepim22.08.2.r932.gd5b6a7f-122.08.2.r934.g063f4a8-1
                  libkeduvocdocument22.08.2.r1818.ga451661-122.08.2.r1821.g6b93e3b-1
                            libkgapi22.08.2.r1385.gc0eb5d9-122.08.2.r1387.ge138fa3-1
                             libkleo22.08.2.r1291.ga4e91a0-122.08.2.r1293.g93df7af-1
                        libkmahjongg22.08.2.r499.ga5b4411-122.08.2.r500.ga621349-1
                     libkomparediff222.08.2.r349.ge17443d-122.08.2.r350.gc381f9d-1
                            libksane22.08.2.r610.g88246ec-122.08.2.r612.g29084ad-1
                          libkscreen5.26.1.r1642.gabcee25-15.26.1.r1648.g905d3f5-1
                           libksieve22.08.2.r1758.gcc977bdc-122.08.2.r1759.gadc20efe-1
                        libksysguard5.26.1.r2453.g09a4486-15.26.1.r2458.g28c8cb5-1
                         libktorrent22.08.2.r568.g7b33d5b-122.08.2.r572.g277e4d4-1
                            lokalize22.08.2.r1861.g2ce63649-122.08.2.r1864.g3938c1b5-1
                               lskat22.08.2.r878.g3009471-122.08.2.r879.g9219934-1
                          mailcommon22.08.2.r1312.g5de9abf-122.08.2.r1324.g4cd4d92-1
                        mailimporter22.08.2.r545.g74cdb89-122.08.2.r549.gdda467f-1
                     maliit-keyboard2.3.1.r26.ga833db4c-12.3.1.r28.g678e44c8-1
                              marble22.08.2.r13484.g46ece50b3-122.08.2.r13488.g08ebeeb3f-1
                       marble-common22.08.2.r13484.g46ece50b3-122.08.2.r13488.g08ebeeb3f-1
                           marble-qt22.08.2.r13484.g46ece50b3-122.08.2.r13488.g08ebeeb3f-1
                        markdownpart22.08.2.r143.g8f0f587-122.08.2.r144.g1f18c53-1
                           maui-clip 2.2.0.r13.g95d5933-1 2.2.0.r17.g77cf7e6-1
                           maui-nota 2.2.0.r12.g3461d02-1 2.2.0.r13.gfacc035-1
                            maui-pix 2.2.0.r18.g15b1699-1 2.2.0.r19.g8b1384b-1
                          maui-shell 0.5.5.r20.g353a5d0-1 0.5.5.r21.g9d84883-1
                             mauikit2.2.0.r29.g611280be-12.2.0.r33.g6f290b57-1
                       mbox-importer22.08.2.r588.g75f939d-122.08.2.r589.gd540af7-1
                          messagelib22.08.2.r6720.gcb78fe496-122.08.2.r6732.gb44a3310e-1
                               milou5.26.1.r790.g60d41ae-15.26.1.r791.gf50113e-1
                              minuet22.08.2.r634.g5fd96c1-122.08.2.r635.g9f6222d-1
                             neochat22.09.r61.g3a54088c-122.09.r86.g4443b58f-1
                              okular22.08.2.r9848.g58ec27a02-122.08.2.r9854.g6095e54c9-1
                              oxygen5.26.1.r4516.g7ca4940e-15.26.1.r4518.g161def39-1
                            palapeli22.08.2.r1328.g76e466b-122.08.2.r1331.gc0aa781-1
                              parley22.08.2.r4552.g7071f34d-122.08.2.r4553.gef1fa498-1
                    partitionmanager22.08.2.r1656.g513cc3d-122.08.2.r1673.g9eeac90-1
                               picmi22.08.2.r597.g1f8b070-122.08.2.r599.g3d94cbc-1
                   pim-data-exporter22.08.2.r2808.gc705bf10-122.08.2.r2809.ge244e397-1
                    pim-sieve-editor22.08.2.r1674.gdff9d49-122.08.2.r1677.g19d54fa-1
                           pimcommon22.08.2.r1387.gd93f302-122.08.2.r1434.gc1c279b-1
                        plank-player5.26.0.r74.g02567f7-15.26.0.r81.g63105b0-1
                    plasma-bigscreen5.26.0.r540.g34595a6-15.26.0.r547.gac2d92b-1
          plasma-browser-integration5.26.1.r1366.gc6ce52e5-15.26.1.r1369.g0e2ff528-1
                       plasma-camera  1.0.r136.gabc1b6b-1  1.0.r137.gfba7416-1
                      plasma-desktop5.26.1.r9744.gc2b452e90-15.26.1.r9760.g588745f63-1
                       plasma-dialer 22.09.r17.g290de94-1 22.09.r22.g0a95280-1
                        plasma-disks5.26.1.r304.g1ee5ba1-15.26.1.r306.g3c4e2e1-1
                     plasma-firewall5.26.1.r669.g6fcfb88-15.26.1.r673.g567cad6-1
                    plasma-framework5.99.0.r16473.g9916df4e0-15.99.0.r16491.gbaa6e3265-1
                  plasma-integration5.26.1.r588.g230b502-15.26.1.r589.g38c985d-1
                       plasma-mobile5.26.1.r2023.g45b8a8408-15.26.1.r2032.g09256d79d-1
                    plasma-mobile-nm5.26.1.r3391.gacc1716e-15.26.1.r3396.g5724b30b-1
                         plasma-nano5.26.1.r202.gfa283d5-15.26.1.r204.g7aa6572-1
                           plasma-nm5.26.1.r3393.g34fd3fae-15.26.1.r3396.g5724b30b-1
                           plasma-pa5.26.1.r1119.geb909d6-15.26.1.r1122.gf394ad5-1
                    plasma-phonebook  22.09.r3.g1221cbe-1  22.09.r4.ge38d50b-1
            plasma-remotecontrollers5.26.0.r151.gfe885f8-15.26.0.r160.gf434a96-1
                          plasma-sdk5.26.1.r2420.gff574459-15.26.1.r2424.gade4ac7b-1
                     plasma-settings 22.09.r12.g0d761d5-1 22.09.r22.g74fed6f-1
                plasma-systemmonitor5.26.1.r643.g13ebcd6-15.26.1.r646.ged9b845-1
                  plasma-thunderbolt5.26.1.r205.g87eca8d-15.26.1.r206.gb524a14-1
                        plasma-vault5.26.1.r400.gd422fed-15.26.1.r402.g7befd63-1
              plasma-wayland-session5.26.1.r12528.gf5bdbbac7-15.26.1.r12566.g16ffccf2e-1
                    plasma-workspace5.26.1.r12528.gf5bdbbac7-15.26.1.r12566.g16ffccf2e-1
                          plasmatube  22.09.r6.ga51d2b0-1  22.09.r7.g6ebffbe-1
                    polkit-kde-agent5.26.1.r542.ge9eee3e-15.26.1.r543.gf4b426f-1
                          powerdevil5.26.1.r2609.g695a0468-15.26.1.r2612.g667d3571-1
                       print-manager22.08.2.r1177.g2ff8cc8-122.08.2.r1179.g5ae5237-1
                       pulseaudio-qt 1.3.0.r25.gf6b02f2-1 1.3.0.r26.g9bba225-1
                             purpose5.99.0.r1014.g7cf4cf5-15.99.0.r1018.gfd8fcb0-1
                         qcachegrind22.08.2.r1203.g4a301ad-122.08.2.r1206.g0fefada-1
                          qmlkonsole  22.09.r6.g873a239-1 22.09.r19.g495b5ba-1
                                rocs22.08.2.r3136.g0782a2f4-122.08.2.r3139.ge997380c-1
                                sddm0.19.0.r159.g21e965a-10.19.0.r161.gfc24321-1
                            sddm-kcm5.26.1.r700.g5cbba17-15.26.1.r701.gb226d41-1
                               solid5.99.0.r811.g4f97105-15.99.0.r812.g6833959-1
                              sonnet5.99.0.r724.g9d8f5b8-15.99.0.r726.g3a116f4-1
                            spacebar  22.09.r7.g2f28fd4-1  22.09.r8.g70397ab-1
                           spectacle22.08.2.r1410.g903d5ad-122.08.2.r1412.g91531ca-1
                                step22.08.2.r1222.gf0c257e-122.08.2.r1238.g48574f8-1
                             svgpart22.08.2.r245.g6132746-122.08.2.r246.g2148a53-1
                             sweeper22.08.2.r595.g24d330b-122.08.2.r596.g10a645f-1
                 syntax-highlighting5.99.0.r1967.gacf5bc88-15.99.0.r1979.g5046517b-1
                      systemsettings5.26.1.r2744.gb8665e1f-15.26.1.r2752.gab7fb5bc-1
          telepathy-kde-accounts-kcm22.08.2.r1226.g0491f88-122.08.2.r1227.g02253dc-1
              telepathy-kde-approver22.08.2.r311.gdb4ac9e-122.08.2.r312.g95538e4-1
          telepathy-kde-auth-handler22.08.2.r290.g25d15ee-122.08.2.r291.gb0743ca-1
               telepathy-kde-call-ui22.08.2.r456.g81a6b74-122.08.2.r457.g6033b01-1
      telepathy-kde-common-internals22.08.2.r2030.ga194fe8-122.08.2.r2032.gdaa0fc0-1
          telepathy-kde-contact-list22.08.2.r1100.g21e24ce-122.08.2.r1102.g9d7c2a9-1
        telepathy-kde-contact-runner22.08.2.r271.gdf5dea1-122.08.2.r272.gc11336d-1
       telepathy-kde-desktop-applets22.08.2.r1013.g45ce02d-122.08.2.r1014.gf1b4d71-1
  telepathy-kde-filetransfer-handler22.08.2.r232.ge547ead-122.08.2.r233.g630c55d-1
    telepathy-kde-integration-module22.08.2.r408.g1eca027-122.08.2.r410.g786f87e-1
             telepathy-kde-send-file22.08.2.r242.gdb9aab9-122.08.2.r244.g9191e75-1
               telepathy-kde-text-ui22.08.2.r2058.g2da64ee-122.08.2.r2060.g50cedfa-1
                        threadweaver5.99.0.r557.g7b98dbd-15.99.0.r558.g9de2e60-1
                             tokodon  22.09.r9.g8b7caee-1 22.09.r10.g229b93e-1
                            umbrello22.08.2.r8512.g8d963fe68-122.08.2.r8515.gc4c52e935-1
                         vakzination 22.09.r10.g57be1a2-1 22.09.r14.gac2034b-1
                               vvave 2.2.0.r12.gf3331ce-1 2.2.0.r13.g115986e-1
              xdg-desktop-portal-kde5.26.1.r539.g32f1165-15.26.1.r546.g2a6df78-1
                             yakuake22.08.2.r837.gbe371af-122.08.2.r839.g1d5c3b3-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Before 2022-10-21
Plasma Mobile Dialer seems to be unreliable
Plasma Dialer 22.09 seems to have issues switching audio profiles and as such might require manual switching. Sometimes audio is completely missing.
Reduced video performance on youtube
Some may encounter reduced video playback performance on YouTube in Firefox with the new Mesa 22.2 drivers.
No workaround at this time.
Before 2022-08-23
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Before 2022-07-22
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Old Issues
Plasma Dialer cannot answer calls
Sadly Plasma Dialer 22.02 has a serious regression with no known workaround. It’s not possible to accept incoming calls. Very sorry about this. Follow the upstream bug report. We will patch the package as soon as a solution is found.
Plasma Mobile - Black screen after update
We are seeing some reports about Plasma Mobile on the PinePhone only showing a black screen after entering the PIN after this update.
Workaround: Downgrade qt5-es2-wayland to 5.15.2+kde+r41 which is now back in Stable and Testing branch repositories.
New Breath theme not applying correctly
With the update to the new Breath theme, a migration package tries to apply the new theme correctly.
However this is not getting done for Plasma’s Lockscreen and the SDDM theme.
So please go through your settings after updating to make sure the themes are correctly applied.
Fix: manjaro-system should take care of this for you.
Plasma Mobile switch to ModemManager
With the PlaMo Gear 21.12 release, Plasma Mobile is now using ModemManager as the telephony stack. So in order to use SIM capabilities, you need to switch from using oFono to ModemManager.
Fix: Run sudo systemctl disable --now ofono ofonoctl && sudo systemctl enable --now ModemManager. You might have to reboot your phone for Plasma Mobile to pick up this change.
Plasma Mobile has does not launch after update
This was caused by an error in kwin 5.23.2 which only affects installs based on openGLES (qt5-es2).
Fix: Update to kwin 5.23.2-1.2 or above.
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been fixed yet.
Fix: Update to linux-5.14.1-2 or newer.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Fix: Vivaldi 4.1.2369.21 fixed this issue.
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
just a couple of meh notifications, other than that greeeeat.
Thank you.
warning: kirigami-addons: local (1:0.3-1) is newer than extra (0.5-1)
warning: plasma-dialer: local (22.09-3) is newer than community (22.06-2)
I would “downgrade” those if I where you. Especially the kirigami-addons one. If you have no issues with the new dialer, you can keep it, but we downgraded it in the repo, because it’s worse than the old one.
angelfish-22.09-1 is getting stuck at the blue start up splash for me
firefox is fine so i’ll go with that for now.
Hi,
Odroid m1 up to date :-)
I’ll up date the other devices this week-end.
Noob question for the Odroid m1, How to install the Manjaro arm os on a sata or m2 sata ?
Flash the build image with the Manjaro arm flasher on the sata or m2 sata ?
Nothing to configure ?
Like a micro sd or emmc module ?
This is likely related to a wrongfully built qt5-webengine package on Arch Linux ARM. :frowning:
PS: A new version 5.15.11 is now in Unstable branch. It should be fixed.
Yep, should be the same procedure. I haven’t tested SATA, so not sure if t works.
Hi,
I wrote this message with the odroid m1 running with a ssd
I flashed the home build image with the manjaro arm flasher on the ssd.
m2 sata not tested.
Find below some info about the device
do you need more info about the device running with a ssd ?
[nls@m1sata ~]$ screenfetch
grep: warning: stray \ before "
                             nls@m1sata
                             OS: Manjaro-ARM 22.10
                             Kernel: aarch64 Linux 6.0.5-1-MANJARO-ARM
         #####               Uptime: 8h 48m
        #######              Packages: Unknown
        ##O#O##              Shell: bash 5.1.16
        #######              Resolution: 1920x1080
      ###########            DE: LXQt 1.1.0
     #############           WM: OpenBox
    ###############          WM Theme: Clearlooks-3.4
    ################         GTK Theme: Matcha-light-azul [GTK2/3]
   #################         Icon Theme: Papirus-Light
 #####################       Font: Noto Sans 11
 #####################       Disk: 5,0G / 462G (2%)
   #################         CPU: Unknown @ 4x 1.992GHz
                             GPU: Mali-G52 r1 (Panfrost)
                             RAM: 1572MiB / 7450MiB
[nls@m1sata ~]$ lsblk -f
NAME   FSTYPE FSVER LABEL      UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1 vfat   FAT16 BOOT_MNJRO A92C-F5F8                             412,1M    10% /boot
└─sda2 ext4   1.0   ROOT_MNJRO f2876e6e-d8a9-49a7-8355-37ec3983af70  434,3G     1% /
zram0
[nls@m1sata ~]$ inxi -F
  Host: m1sata Kernel: 6.0.5-1-MANJARO-ARM arch: aarch64 bits: 64
    Desktop: LXQt v: 1.1.0 Distro: Manjaro ARM
  Type: ARM System: Hardkernel ODROID-M1 details: N/A
  Info: quad core model: N/A variant: cortex-a55 bits: 64 type: MCP
  Speed (MHz): avg: 1608 min/max: 408/1992 cores: 1: 1608 2: 1608 3: 1608
    4: 1608
  Device-1: display-subsystem driver: rockchip_drm v: N/A
  Device-2: rk3568-mali driver: panfrost v: kernel
  Device-3: rk3568-dw-hdmi driver: dwhdmi_rockchip v: N/A
  Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: modesetting
    dri: rockchip
    gpu: cdn-dp,dw-mipi-dsi-rockchip,dwhdmi-rockchip,innohdmi-rockchip,rockchip-dp,rockchip-drm,rockchip-lvds,rockchip-vop,rockchip-vop2
    resolution: 1920x1080
  OpenGL: renderer: Mali-G52 r1 (Panfrost) v: 3.1 Mesa 22.2.1
  Device-1: rk3568-dw-hdmi driver: dwhdmi_rockchip
  Device-2: simple-audio-card driver: asoc_simple_card
  Device-3: simple-audio-card driver: asoc_simple_card
  Sound API: ALSA v: k6.0.5-1-MANJARO-ARM running: yes
  Sound Server-1: PipeWire v: 0.3.59 running: yes
  Device-1: rk3568-gmac driver: rk_gmac_dwmac
  IF: eth0 state: up speed: 1000 Mbps duplex: full mac:
  Local Storage: total: 465.76 GiB used: 4.93 GiB (1.1%)
  ID-1: /dev/sda vendor: Western Digital model: WDS500G1R0A-68A4W0
  ID-1: / size: 457.9 GiB used: 4.88 GiB (1.1%) fs: ext4 dev: /dev/sda2
  ID-2: /boot size: 457.5 MiB used: 45.3 MiB (9.9%) fs: vfat dev: /dev/sda1
  ID-1: swap-1 type: zram size: 10.91 GiB used: 0 KiB (0.0%) dev: /dev/zram0
  System Temperatures: cpu: 31.2 C mobo: N/A
  Processes: 186 Uptime: 8h 51m Memory: 7.28 GiB used: 1.49 GiB (20.5%)
  Shell: Bash inxi: 3.3.22
[nls@m1sata ~]$
Since the most recent update, Falkon will not launch. When I launch in the terminal, I get the following error:
falkon: error while loading shared libraries: libQt5WebEngineWidgets.so.5: cannot open shared object file: No such file or directory
This is likely due to the faulty qt5-webengine package Arch Linux ARM had. A working one can be found in Unstable branch, which will be getting into Testing shortly.
Should be fixed with: [ARM Testing Update] 2022-10-31 - Firefox, Readline, Plasma, Libcamera and kernels
