Hello ARM community.
Big update this time. Plasma Mobile Gear 22.09 and other cool stuff.
Plasma Mobile 22.09 has a new homescreen on Plasma 5.26
Some highlights:
- Most of our kernels got updated to 6.0
- Plasma Mobile Gear updated to 22.09
- Firefox updated to 105.0.2
- QT6 updated to 6.4.0
- Thunderbird updated to 102.3.1
- Element updated to 1.11.8
- Upstream has started to remove some Python2 based packages
- Added a new desktop framework called DFL / Desktop Framework Libraries
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Wed Oct 5 22:04:31 CEST 2022)
- arm-testing community aarch64: 437 new and 397 removed package(s)
- arm-testing core aarch64: 53 new and 46 removed package(s)
- arm-testing extra aarch64: 315 new and 310 removed package(s)
- arm-testing kde-unstable aarch64: 383 new and 383 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-09-27 2022-10-05
alligator 22.06-1 22.09-1
angelfish 22.06-1 22.09-1
audiotube 22.06-1 22.09-1
calindori 22.06-1 22.09-1
electron 21.0.0-1 21.1.0-1
electron18 18.3.13-1 18.3.15-1
electron19 19.0.17-1 19.1.2-1
electron20 20.2.0-1 20.3.1-1
element-desktop 1.11.5-1 1.11.8-1
element-web 1.11.5-1 1.11.8-1
kalk 22.06-1 22.09-1
kasts 22.06-1 22.09.2-1
kclock 22.06-1 22.09-1
keysmith 22.06-1 22.09-1
koko 22.06-1 22.09-1
kongress 22.06-1 22.09-1
krecorder 22.06-1 22.09-1
ktrip 22.06-2 22.09-1
kweather 22.06-1 22.09-1
libgpiod 1.6.3-1 -
obs-studio 27.2.4-1 28.0.3-1
phosh0.21.0+40+g2c03f935-1 0.21.1-1
phosh-mobile-settings 0.21.0-2 0.21.1-1
plasma-dialer 22.06-1 22.09-2
plasma-phonebook 22.06-1 22.09-1
plasma-settings 22.06-1 -
qmlkonsole 22.06-1 22.09-1
spacebar 22.06-1 22.09-1
tokodon 22.06-1 22.09-1
vakzination 22.06-1 22.09-1
asahi-fwextract - 0.5pre1-2
asahi-scripts - 20220918.2-4
bitwarden - 2022.9.1-2
calamares-apple-silicon-configs - 20220712-3
dfl-applications - 0.1.0alpha1-1
dfl-clipboard - 0.1.0alpha1-1
dfl-color-utils - 0.1.0alpha1-1
dfl-config-parser - 0.1.0alpha1-1
dfl-gamma-effects - 0.1.0alpha1-1
dfl-inotify - 0.1.0alpha1-1
dfl-ipc - 0.1.0alpha1-1
dfl-layouts - 0.1.0alpha2-1
dfl-login1 - 0.1.0alpha1-1
dfl-notification - 0.1.0alpha1-1
dfl-power - 0.1.0alpha1-1
dfl-settings - 0.1.0alpha2-1
dfl-status-notifier - 0.1.0alpha1-1
dfl-storage - 0.1.0alpha2-1
dfl-utils - 0.1.0alpha1-1
dfl-volume - 0.1.0alpha2-1
dfl-wayqt - 0.1.0alpha2-1
dfl-xdg - 0.1.0alpha1-1
lzfse - 1.0-1
manjaro-base-skel - 20171029-3
manjaro-kde-settings - 20220130-1
noto-fonts-compat - 20151217-1
phosh-tour - 0.21.0-1
ttf-comfortaa - 3.105-1
xkeyboard-config-asahi - 2.35.1_3-1
:: Different sync package(s) in repository community aarch64
aardvark-dns 1.1.0-1 1.2.0-1
alglib 3.18.0-1 3.19.0-1
algol68g 3.0.7-1 3.0.8-1
algol68g-doc 3.0.7-1 3.0.8-1
aliyun-cli 3.0.125-1 3.0.127-1
apptainer 1.0.3-1 1.1.0-1
aqbanking 6.5.0-2 6.5.3-1
argocd 2.4.11-1 2.4.13-1
b4 0.10.0-1 0.10.1-1
babel-cli 7.18.10-1 7.19.3-1
babel-core 7.19.1-1 7.19.3-1
balsa 2.6.3-2 2.6.4-1
baresip 2.7.0-1 2.8.1-1
bctoolbox 5.1.61-1 5.1.64-1
blender 17:3.3.0-3 17:3.3.0-4
bmake 20220726-1 20220924-1
bpython 0.22.1-3 0.23-1
brook 20220406-1 20220501-1
buildah 1.27.2-1 1.28.0-1
bzrtp 5.1.61-1 5.1.64-1
caddy 2.5.2-2 2.6.1-1
calc 2.14.0.8-2 2.14.1.0-1
calibre 6.5.0-1 6.6.1-1
cargo-c 0.9.12-1 0.9.13-1
cargo-edit 0.11.2-1 0.11.3-1
cargo-expand 1.0.31-1 1.0.32-1
cargo-nextest 0.9.36-1 0.9.37-1
cargo-release 0.21.1-2 0.21.2-1
carla 2.5.0-1 2.5.1-1
certbot 1.30.0-1 1.31.0-1
certbot-apache 1.30.0-1 1.31.0-1
certbot-dns-cloudflare 1.30.0-1 1.31.0-1
certbot-dns-digitalocean 1.30.0-1 1.31.0-1
certbot-dns-dnsimple 1.30.0-1 1.31.0-1
certbot-dns-dnsmadeeasy 1.30.0-1 1.31.0-1
certbot-dns-gehirn 1.30.0-1 1.31.0-1
certbot-dns-google 1.30.0-1 1.31.0-1
certbot-dns-linode 1.30.0-1 1.31.0-1
certbot-dns-luadns 1.30.0-1 1.31.0-1
certbot-dns-nsone 1.30.0-1 1.31.0-1
certbot-dns-ovh 1.30.0-1 1.31.0-1
certbot-dns-rfc2136 1.30.0-1 1.31.0-1
certbot-dns-route53 1.30.0-1 1.31.0-1
certbot-dns-sakuracloud 1.30.0-1 1.31.0-1
certbot-nginx 1.30.0-1 1.31.0-1
cloudflared 2022.9.1-1 2022.10.0-1
copyq 6.3.0-1 6.3.2-1
cosign 1.11.1-1 1.12.1-1
coturn 4.5.2-3 4.6.0-1
cryptominisat5 5.8.0-11 5.11.4-1
dagger 0.2.34-1 0.2.35-1
darkhttpd 1.13-1 1.14-1
dart 2.18.1-1 2.18.2-1
datovka 4.20.0-1 4.21.0-2
debugedit 5.0-2 -
deepin-qt5platform-plugins 5.0.66-1 5.0.67-1
diffoscope 222-1 223-1
docker-compose 2.11.1-1 2.11.2-1
docker-scan 0.19.0-1 0.20.0-1
doctl 1.81.0-1 1.82.2-1
drumkv1 0.9.26-2 0.9.27-1
drumstick 2.7.1-2 2.7.2-1
drupal 9.4.5-1 9.4.7-1
dub 1.29.1-1 1.29.2-1
eclib 20220621-3 20220621-4
eksctl 0.111.0-1 0.112.0-1
emscripten 3.1.20-1 3.1.23-1
endless-sky 0.9.14-1 0.9.15-1
endless-sky-high-dpi 0.9.14-1 0.9.15-1
erlang 25.0.4-1 25.1-1
erlang-nox 25.0.4-1 25.1-1
erlang-unixodbc 25.0.4-1 25.1-1
fail2ban 0.11.2-3 1.0.1-1
faudio 22.09.01-1 22.10-1
faust 2.41.1-2 2.50.6-1
fdupes 1:2.1.2-2 1:2.2.1-2
featherpad 1.3.1-1 1.3.2-1
firefox-noscript 11.4.10-1 11.4.11-1
firewalld 1.2.0-1 1.2.1-1
flatbuffers 2.0.8-1 22.9.29-1
fq 0.0.9-1 0.0.10-1
freeradius 3.2.0-2 3.2.1-1
furnace 0.6pre1-1 0.6pre1.5-1
fzf 0.33.0-1 0.34.0-1
gamescope 3.11.44-1 3.11.47-1
gap 4.12.0-2 4.12.0-3
gap-doc 4.12.0-2 4.12.0-3
gap-packages 4.12.0-2 4.12.0-3
gcin 2.9.0-4 2.9.0-5
gdu 5.18.1-1 5.19.0-1
gensio 2.5.2-1 2.5.5-1
geoipupdate 4.9.0-3 4.10.0-2
gerbera 1.11.0-2 1.11.0-3
giac 1.9.0.21-1 1.9.0.21-2
ginac 1.8.2-1 1.8.4-1
git-credential-gopass 1.14.3-1 1.14.9-1
github-cli 2.16.0-1 2.16.1-1
gitsign 0.3.0-1 0.3.1-1
gnome-appfolders-manager 0.4.6-1 0.4.7-1
gnome-shell-extension-appindicator 42-1 46-1
gnuradio 3.10.2.0-8 3.10.4.0-1
gnuradio-companion 3.10.2.0-8 3.10.4.0-1
gnuradio-iqbal 0.38.2-7 0.38.2-8
gnuradio-osmosdr 0.2.3-12 0.2.3-13
go-yq 4.27.5-1 4.28.1-1
goaccess 1.6.3-1 1.6.4-1
gopass 1.14.7-1 1.14.9-1
gqrx 2.15.9-2 2.15.9-3
grails 5.2.3-1 5.2.4-1
grails-docs 5.2.3-1 5.2.4-1
gum 0.6.0-1 0.7.0-1
gwakeonlan 0.8.4-1 0.8.5-1
haruna 0.9.1-1 0.9.2-1
helmfile 0.145.4-1 0.146.0-1
hitch 1.7.2-2 1.7.3-1
home-assistant 1:2022.9.5-1 1:2022.9.7-1
hugo 0.102.3-1 0.104.2-1
hunspell-pl 20210731-2 20220801-1
icewm 2.9.9-1 3.0.0-1
innernet 1.5.4-1 1.5.5-1
java-batik 1.14-1 1.15-1
jc 1.21.2-1 1.22.0-1
jenkins 2.370-1 2.372-1
jmol 14.32.75-1 14.32.76-1
jsmol 14.32.75-1 14.32.76-1
k9s 0.26.5-1 0.26.6-1
kicad 6.0.7-1 6.0.8-1
kicad-library-3d 6.0.7-1 6.0.8-1
kicad-library 6.0.7-1 6.0.8-1
klayout 0.27.11-1 0.27.11-2
kmon 1.6.0-1 1.6.2-1
knot 3.1.8-1 3.2.1-1
knot-resolver 5.5.2-1 5.5.2-2
kotlin 1.7.10-1 1.7.20-1
kstars 1:3.6.0-1 1:3.6.1-1
kubeone 1.4.0-1 1.5.1-1
kubo 0.15.0-1 0.16.0-1
kxstudio-lv2-extensions 2022.02.19-2 2022.09.28-2
languagetool 5.8-1 5.9-1
lcalc 2.0.5-1 2.0.5-2
lego 4.8.0-1 4.9.0-1
libcpuid 0.5.1-2 0.6.0-1
libindi 1.9.7-1 1.9.8-1
libjxl 0.7.0-2 0.7.0-3
libjxl-doc 0.7.0-2 0.7.0-3
libmaxminddb 1.6.0-3 1.7.1-1
libmediainfo 22.06-1 22.09-1
libofx 0.10.5-1 0.10.8-1
libofx-doc 0.10.5-1 0.10.8-1
libre 2.7.0-1 2.8.0-1
librem 2.7.0-1 2.8.0-1
libretro-core-info 1.10.3-1 1.11.0-1
libsemigroups 2.2.3-1 2.3.0-1
libuhd 4.2.0.0-3 4.3.0.0-1
libvolk 2:2.5.0-4 2:2.5.2-1
libvterm01 0.1.4-2 -
libxdp 1.2.8-1 1.2.8-2
lua-luautf8 0.1.3-4 0.1.4-4
lua51-luautf8 0.1.3-4 0.1.4-4
lua52-luautf8 0.1.3-4 0.1.4-4
lua53-luautf8 0.1.3-4 0.1.4-4
lxd 5.6-1 5.6-2
mage 1.13.0-2 1.14.0-1
maim 5.7.4-3 5.7.4-4
mame 0.247-2 0.248-1
mame-tools 0.247-2 0.248-1
marked 4.0.19-1 4.1.1-1
maturin 0.13.3-1 0.13.5-1
mbedtls 2.28.0-1 2.28.1-1
mediainfo 22.06-2 22.09-1
mediainfo-gui 22.06-2 22.09-1
mediastreamer 5.1.61-1 5.1.64-1
mediawiki 1.38.2-1 1.38.4-1
meson-python 0.8.1-1 0.9.0-1
mg 20210314-2 20220614-1
mimir 2.3.0-1 2.3.1-1
mmdblookup 1.6.0-3 1.7.1-1
mmtf-cpp 1.0.0-4 1.1.0-1
mod-lv2-extensions 2022.09.25-1 2022.09.28-1
mod_passenger 6.0.14-2 6.0.15-1
monitor 20220907-1 20220930-1
multitail 6.5.1-1 7.0.0-1
mypy 0.971-1 0.981-1
namazu 2.0.21-4 2.0.21-5
nawk 20220122-1 20220912-1
neochat 22.06-1 22.09-1
neovim 0.7.2-3 0.8.0-3
netavark 1.1.0-1 1.2.0-1
nethack 3.6.6-2 3.6.6-3
nextcloud-app-contacts 4.2.1-1 4.2.2-1
nextcloud-app-deck 1:1.7.0-2 1:1.7.1-1
nextcloud-app-news 18.1.1-1 18.2.0-1
nfoview 1.28.1-2 1.29-1
nginx-mod-passenger 6.0.14-2 6.0.15-1
nodejs 18.9.1-1 18.10.0-1
nodejs-yaml 2.1.1-1 2.1.2-1
npm-check-updates 16.3.2-1 16.3.5-1
nuitka 1.0.7-1 1.0.8-1
nushell 0.68.1-1 0.69.1-1
octave 7.2.0-2 7.2.0-3
open-iscsi 2.1.7-2 2.1.8-1
opensubdiv 3.4.4-11 3.5.0-1
ortp 5.1.61-1 5.1.64-1
p2pool 2.3-1 2.4-1
padthv1 0.9.26-1 0.9.27-1
pari 2.13.4-1 2.15.0-1
pcbdraw 0.6.1-3 -
perl-cpan-perl-releases 5.20220820-1 5.20220922-1
perl-datetime-timezone 2.53-1 2.54-1
perl-par 1.017-3 1.018-1
po4a 0.66-1 0.68-1
poedit 1:3.1-2 1:3.1.1-1
pop-gtk-theme 5.5.1-1 5.5.1.r2.e09de355-1
powertop 2.14-1 2.15-1
procs 0.13.1-1 0.13.2-1
pulumi 3.40.1-1 3.40.2-1
pyright 1.1.272-1 1.1.274-1
python-acme 1.30.0-1 1.31.0-1
python-aiogram 2.22.1-1 2.22.2-1
python-aiohttp-openmetrics 0.0.7-2 0.0.8-1
python-black 22.8.0-2 22.8.0-3
python-braintree 4.16.0-1 4.17.0-1
python-canonicaljson 1.6.2-1 1.6.3-1
python-cfn-lint 0.65.1-1 0.66.1-1
python-cheetah3 3.3.0a1-1 3.3.0b0-1
python-cheetah3-docs 3.3.0a1-1 3.3.0b0-1
python-cloudflare 2.10.1-1 2.10.2-1
python-curtsies 0.3.10-2 0.4.0-2
python-cypari2 2.1.2-7 2.1.2-8
python-cysignals 1.11.2-1 1.11.2-2
python-debian 0.1.44-1 0.1.48-1
python-dropbox 11.33.0-1 11.34.0-1
python-envisage 6.0.1-3 6.1.0-1
python-faker 9.5.0-1 9.5.2-1
python-flatbuffers 2.0.8-1 22.9.29-1
python-fonttools 4.37.3-1 4.37.4-1
python-gitlab 3.9.0-1 3.10.0-1
python-google-auth 2.2.0-1 2.3.2-1
python-googleapis-common-protos 1.56.3-1 1.56.4-1
python-h11 0.13.0-1 0.14.0-1
python-identify 2.5.5-1 2.5.6-1
python-invoke 1.6.0-3 1.7.0-1
python-iso8601 1.0.2-3 1.1.0-1
python-jaraco.classes 3.2.2-2 3.2.3-1
python-jaraco.functools 3.5.1-1 3.5.2-1
python-jarowinkler 1.2.1-1 1.2.3-1
python-joblib 1.1.0-3 1.2.0-1
python-latex2mathml 3.66.2-1 3.68.0-1
python-levenshtein 0.20.2-1 0.20.3-1
python-libtmux 0.15.4-1 0.15.8-1
python-matrix-common 1.2.1-1 1.3.0-2
python-minio 7.1.11-1 7.1.12-1
python-mistune1 0.8.4-4 -
python-mockito 1.3.5-1 1.4.0-1
python-nest-asyncio 1.5.5-1 1.5.6-1
python-networkx 2.8.6-1 2.8.7-1
python-nrfutil 6.1.6-1 6.1.7-1
python-openapi-core 0.15.0-1 0.16.0-1
python-path 16.4.0-2 16.5.0-1
python-pikepdf 6.0.2-1 6.2.0-1
python-pip-api 0.0.23-1 0.0.25-1
python-psycopg 3.1.2-1 3.1.3-1
python-pydyf 0.2.0-1 0.3.0-1
python-pyglet 1.5.26-2 1.5.27-1
python-pykerberos 1.2.4-1 1.3.1-1
python-pylink-square 0.14.2-1 0.14.3-1
python-pynitrokey 0.4.27-1 0.4.28-1
python-pystache 0.6.0-10 0.6.1-1
python-pytest-cov 3.0.0-1 4.0.0-1
python-pytest-mock 3.8.2-1 3.9.0-1
python-pytest-mypy 0.9.1-1 0.10.0-1
python-pythran 0.11.0-1 0.12.0-1
python-pyzmq 23.2.0-2 24.0.1-1
python-qtconsole 5.3.1-1 5.3.2-1
python-rapidfuzz 2.6.1-1 2.10.2-1
python-readme-renderer 37.1-1 37.2-1
python-requirementslib 2.0.2-1 2.0.3-1
python-rich 12.5.1-1 12.6.0-1
python-setuptools-rust 1.2.0-1 1.5.0-1
python-softlayer 6.1.1-1 6.1.2-1
python-sphinx 5.2.1-1 5.2.3-1
python-sphinx-autoapi 1.9.0-2 2.0.0-1
python-sphinx-basic-ng 0.0.1a12-1 1.0.0b1-1
python-sphinx-furo 2022.09.15-1 2022.09.29-1
python-sqlalchemy 1.4.40-1 1.4.41-1
python-termcolor 2.0.0-1 2.0.1-1
python-terminado 0.15.0-1 0.16.0-1
python-tldextract 3.3.1-1 3.4.0-1
python-tokenize-rt 4.2.1-4 5.0.0-1
python-traits 6.3.2-1 6.4.1-1
python-trio 0.21.0-1 0.22.0-1
python-uc.micro-py 1.0.1-1 -
python-unidecode 1.3.4-1 1.3.6-1
python-watchdog 2.0.1-1 2.0.2-1
python-xcffib 0.11.1-5 0.12.0-1
python-xmlschema 2.0.4-1 2.1.0-1
python-yaspin 2.1.0-4 2.2.0-1
python-zope.testing 4.7-1 -
python2-dnspython 1.16.0-3.1 -
python2-zope.testing 4.7-1 -
qcad 3.27.6.7-4 3.27.6.11-1
qgnomeplatform-qt5 0.9.0-1 0.9.0-3
qgnomeplatform-qt6 0.9.0-1 0.9.0-3
qjackctl 0.9.7-2 0.9.8-1
qmidictl 0.9.6-3 0.9.7-1
qmidinet 0.9.6-2 0.9.7-1
qsynth 0.9.7-2 0.9.8-1
qt6ct 0.5-4 0.6-2
qtractor 0.9.28-1 0.9.28-2
qxgedit 0.9.6-2 0.9.7-1
rapidfuzz-cpp 1.3.0-1 1.5.0-1
repo 2.29.2-1 2.29.3-1
reptyr 0.8.0-1 0.9.0-1
retroarch 1.10.3-3 1.11.0-1
rssguard 4.2.4-1 4.2.5-1
rssguard-nowebengine 4.2.4-1 4.2.5-1
rubberband 3.0.0-2 3.1.0-1
ruby-pkg-config 1.4.7-1 1.4.9-1
ruby-test-unit 3.5.3-1 3.5.4-1
rust-analyzer 20220926-1 20221003-1
rustypaste 0.7.1-1 0.8.2-1
rustypaste-cli 0.1.11-1 0.2.0-1
samplv1 0.9.26-1 0.9.27-1
sdl12-compat 1.2.52-2 1.2.56-1
seamonkey 2.53.13-1 2.53.14-1
ser2net 4.3.8-1 4.3.8-2
skaffold 1.36.0-1 1.39.2-1
skopeo 1.9.2-1 1.10.0-1
slop 7.5-7 7.6-1
soapyuhd 0.4.1-6 0.4.1-7
sqlcipher 4.5.1-2 4.5.2-1
sqlfluff 1.3.1-1 1.3.2-1
sqlx-cli 0.6.1-1 0.6.2-1
stern 1.21.0-3 1.22.0-3
stp 2.3.3-6 2.3.3-7
stylelint 14.12.1-1 14.13.0-1
subdl 1.1.2-2 1.1.2-3
syncthing 1.21.0-1 1.22.0-1
syncthing-relaysrv 1.21.0-1 1.22.0-1
synthv1 0.9.26-1 0.9.27-1
tealdeer 1.5.0-1 1.6.0-1
tectonic 0.9.0-1 0.11.0-1
telegram-desktop 4.2.0-1 4.2.4-1
terraform 1.3.0-1 1.3.1-1
throttled 0.9.2-2 0.10.0-1
tmuxp 1.15.2-1 1.16.1-1
translate-shell 0.9.6.12-3 0.9.7-1
typescript 4.8.3-1 4.8.4-1
typescript-language-server 1.2.0-1 2.0.0-1
unhide 20210124-1 20220611-1
unicode-emoji 14.0-1 15.0-1
unionfs-fuse 2.2-1 3.2-1
urh 2.9.3-2 2.9.3-3
uwufetch 1.7-3 2.0-1
v2ray-domain-list-community 20220926020155-1 20221005015401-1
v2ray-geoip 202209220104-1 202209290111-1
verilator 4.226-1 4.228-1
vifm 0.12-1 0.12.1-1
vim-ctrlp 1.80-3 1.81-1
wireshark-cli 3.6.8-1 4.0.0-1
wireshark-qt 3.6.8-1 4.0.0-1
wtf 20200613-2 20220320-1
xdp-tools 1.2.8-1 1.2.8-2
yt-dlp 2022.09.01-1 2022.10.04-1
zfp 0.5.5-5 1.0.0-1
zigbee2mqtt 1.27.2-2 1.28.0-1
crawl-data - 0.29.1-1
crawl-ncurses - 0.29.1-1
crawl-tiles - 0.29.1-1
faustpp - 1.0.0-1
gnucash-docs - 4.12-1
go-licenses - 1.4.0-1
go-swagger - 0.30.3-2
libgpiod - 1.6.3-2
master_me - 1.1.0-4
master_me-jack - 1.1.0-4
master_me-lv2 - 1.1.0-4
master_me-vst - 1.1.0-4
master_me-vst3 - 1.1.0-4
obsidian-icon-theme - 4.15-2
perl-ref-util - 0.204-1
perl-ref-util-xs - 0.117-1
perl-test2-tools-process - 0.06-1
sequoia-wot - 0.2.0-1
ttf-arimo-nerd - 2.2.2-1
ttf-sourcecodepro-nerd - 2.2.2-1
yank - 1.3.0-1
:: Different overlay package(s) in repository core aarch64
grub2:2.06.r322.gd9b4638c5-4.22:2.06.r322.gd9b4638c5-4.3
linux 5.19.11-3 6.0.0-1
linux-clockworkpi-a06 5.19.11-1 6.0.0-1
linux-clockworkpi-a06-headers 5.19.11-1 6.0.0-1
linux-headers 5.19.11-3 6.0.0-1
linux-lts 5.15.70-1 5.15.72-1
linux-lts-headers 5.15.70-1 5.15.72-1
linux-pinephone 5.19.11-1 5.19.12-1
linux-pinephone-headers 5.19.11-1 5.19.12-1
linux-pinephonepro 5.19.11-1 5.19.12-1
linux-pinephonepro-headers 5.19.11-1 5.19.12-1
linux-rc 6.0.rc7-1 6.0.rc7-2
linux-rc-headers 6.0.rc7-1 6.0.rc7-2
linux-rpi4 5.15.70-1 5.15.72-1
linux-rpi4-headers 5.15.70-1 5.15.72-1
linux-rpi4-mainline 5.19.11-1 5.19.14-1
linux-rpi4-mainline-headers 5.19.11-1 5.19.14-1
linux515 5.15.70-1 5.15.72-1
linux515-headers 5.15.70-1 5.15.72-1
linux519 5.19.11-2 5.19.14-1
linux519-headers 5.19.11-2 5.19.14-1
manjaro-release 22.09-1 22.10-1
raspberrypi-bootloader 20220725-1 20221005-2
raspberrypi-bootloader-x 20220725-1 20221005-2
linux-apple-silicon - 5.19.0-5
linux-apple-silicon-headers - 5.19.0-5
linux60 - 6.0-1
linux60-headers - 6.0-1
m1n1 - 1.1.5-1
uboot-apple-silicon - 2022.07-1
:: Different sync package(s) in repository core aarch64
archlinux-keyring 20220831-1 20220927-1
dbus 1.14.0-1 1.14.2-1
dbus-docs 1.14.0-1 1.14.2-1
expat 2.4.8-1 2.4.9-1
gnutls 3.7.7-3 3.7.8-1
hwdata 0.362-2 0.363-1
iproute2 5.19.0-1 6.0.0-1
krb5 1.19.3-3 1.20-1
lemon 3.39.3-1 3.39.4-1
libbpf 0.8.1-1 1.0.1-1
libffi 3.4.2-5 3.4.3-1
links 2.27-1 2.28-1
pinentry 1.2.0-1 1.2.1-1
sqlite 3.39.3-1 3.39.4-1
sqlite-analyzer 3.39.3-1 3.39.4-1
sqlite-doc 3.39.3-1 3.39.4-1
sqlite-tcl 3.39.3-1 3.39.4-1
systemd 251.4-1 251.5-1
systemd-libs 251.4-1 251.5-1
systemd-resolvconf 251.4-1 251.5-1
systemd-sysvcompat 251.4-1 251.5-1
xz 5.2.6-1 5.2.7-1
debugedit - 5.0-4
:: Different overlay package(s) in repository extra aarch64
calamares 3.2.61-2 3.2.61-4
calamares-arm-oem 20220916-1 20221003-1
kirigami-addons 1:0.3-1 -
kweathercore 0.5-1 0.6-1
mesa-git22.3.0_devel.160395.26d1b0ca022-122.3.0_devel.160808.1f0a0a46d97-1
pamac-cli 10.4.2-1 10.4.2-2
pamac-gnome-integration 10.4.2-1 10.4.2-2
pamac-gtk 10.4.2-1 10.4.2-2
snapd 2.57.2-1 2.57.4-1
:: Different sync package(s) in repository extra aarch64
apache 2.4.54-1 2.4.54-2
arch-install-scripts 26-1 27-1
cairomm 1.14.3-2 1.14.4-1
cairomm-1.16 1.16.1-2 1.16.2-1
cairomm-1.16-docs 1.16.1-2 1.16.2-1
cairomm-docs 1.14.3-2 1.14.4-1
chromium 105.0.5195.125-3 106.0.5249.91-1
clang 14.0.6-2 14.0.6-3
clang13 13.0.1-3 13.0.1-4
dconf-editor 3.38.3-2 43.0-1
dnsmasq 2.86-2 2.87-1
f2fs-tools 1.15.0-1 1.15.0-2
firefox 105.0.1-1 105.0.2-1
firefox-i18n-ach 105.0.1-1 105.0.2-1
firefox-i18n-af 105.0.1-1 105.0.2-1
firefox-i18n-an 105.0.1-1 105.0.2-1
firefox-i18n-ar 105.0.1-1 105.0.2-1
firefox-i18n-ast 105.0.1-1 105.0.2-1
firefox-i18n-az 105.0.1-1 105.0.2-1
firefox-i18n-be 105.0.1-1 105.0.2-1
firefox-i18n-bg 105.0.1-1 105.0.2-1
firefox-i18n-bn 105.0.1-1 105.0.2-1
firefox-i18n-br 105.0.1-1 105.0.2-1
firefox-i18n-bs 105.0.1-1 105.0.2-1
firefox-i18n-ca 105.0.1-1 105.0.2-1
firefox-i18n-ca-valencia 105.0.1-1 105.0.2-1
firefox-i18n-cak 105.0.1-1 105.0.2-1
firefox-i18n-cs 105.0.1-1 105.0.2-1
firefox-i18n-cy 105.0.1-1 105.0.2-1
firefox-i18n-da 105.0.1-1 105.0.2-1
firefox-i18n-de 105.0.1-1 105.0.2-1
firefox-i18n-dsb 105.0.1-1 105.0.2-1
firefox-i18n-el 105.0.1-1 105.0.2-1
firefox-i18n-en-ca 105.0.1-1 105.0.2-1
firefox-i18n-en-gb 105.0.1-1 105.0.2-1
firefox-i18n-en-us 105.0.1-1 105.0.2-1
firefox-i18n-eo 105.0.1-1 105.0.2-1
firefox-i18n-es-ar 105.0.1-1 105.0.2-1
firefox-i18n-es-cl 105.0.1-1 105.0.2-1
firefox-i18n-es-es 105.0.1-1 105.0.2-1
firefox-i18n-es-mx 105.0.1-1 105.0.2-1
firefox-i18n-et 105.0.1-1 105.0.2-1
firefox-i18n-eu 105.0.1-1 105.0.2-1
firefox-i18n-fa 105.0.1-1 105.0.2-1
firefox-i18n-ff 105.0.1-1 105.0.2-1
firefox-i18n-fi 105.0.1-1 105.0.2-1
firefox-i18n-fr 105.0.1-1 105.0.2-1
firefox-i18n-fy-nl 105.0.1-1 105.0.2-1
firefox-i18n-ga-ie 105.0.1-1 105.0.2-1
firefox-i18n-gd 105.0.1-1 105.0.2-1
firefox-i18n-gl 105.0.1-1 105.0.2-1
firefox-i18n-gn 105.0.1-1 105.0.2-1
firefox-i18n-gu-in 105.0.1-1 105.0.2-1
firefox-i18n-he 105.0.1-1 105.0.2-1
firefox-i18n-hi-in 105.0.1-1 105.0.2-1
firefox-i18n-hr 105.0.1-1 105.0.2-1
firefox-i18n-hsb 105.0.1-1 105.0.2-1
firefox-i18n-hu 105.0.1-1 105.0.2-1
firefox-i18n-hy-am 105.0.1-1 105.0.2-1
firefox-i18n-ia 105.0.1-1 105.0.2-1
firefox-i18n-id 105.0.1-1 105.0.2-1
firefox-i18n-is 105.0.1-1 105.0.2-1
firefox-i18n-it 105.0.1-1 105.0.2-1
firefox-i18n-ja 105.0.1-1 105.0.2-1
firefox-i18n-ka 105.0.1-1 105.0.2-1
firefox-i18n-kab 105.0.1-1 105.0.2-1
firefox-i18n-kk 105.0.1-1 105.0.2-1
firefox-i18n-km 105.0.1-1 105.0.2-1
firefox-i18n-kn 105.0.1-1 105.0.2-1
firefox-i18n-ko 105.0.1-1 105.0.2-1
firefox-i18n-lij 105.0.1-1 105.0.2-1
firefox-i18n-lt 105.0.1-1 105.0.2-1
firefox-i18n-lv 105.0.1-1 105.0.2-1
firefox-i18n-mk 105.0.1-1 105.0.2-1
firefox-i18n-mr 105.0.1-1 105.0.2-1
firefox-i18n-ms 105.0.1-1 105.0.2-1
firefox-i18n-my 105.0.1-1 105.0.2-1
firefox-i18n-nb-no 105.0.1-1 105.0.2-1
firefox-i18n-ne-np 105.0.1-1 105.0.2-1
firefox-i18n-nl 105.0.1-1 105.0.2-1
firefox-i18n-nn-no 105.0.1-1 105.0.2-1
firefox-i18n-oc 105.0.1-1 105.0.2-1
firefox-i18n-pa-in 105.0.1-1 105.0.2-1
firefox-i18n-pl 105.0.1-1 105.0.2-1
firefox-i18n-pt-br 105.0.1-1 105.0.2-1
firefox-i18n-pt-pt 105.0.1-1 105.0.2-1
firefox-i18n-rm 105.0.1-1 105.0.2-1
firefox-i18n-ro 105.0.1-1 105.0.2-1
firefox-i18n-ru 105.0.1-1 105.0.2-1
firefox-i18n-sco 105.0.1-1 105.0.2-1
firefox-i18n-si 105.0.1-1 105.0.2-1
firefox-i18n-sk 105.0.1-1 105.0.2-1
firefox-i18n-sl 105.0.1-1 105.0.2-1
firefox-i18n-son 105.0.1-1 105.0.2-1
firefox-i18n-sq 105.0.1-1 105.0.2-1
firefox-i18n-sr 105.0.1-1 105.0.2-1
firefox-i18n-sv-se 105.0.1-1 105.0.2-1
firefox-i18n-szl 105.0.1-1 105.0.2-1
firefox-i18n-ta 105.0.1-1 105.0.2-1
firefox-i18n-te 105.0.1-1 105.0.2-1
firefox-i18n-th 105.0.1-1 105.0.2-1
firefox-i18n-tl 105.0.1-1 105.0.2-1
firefox-i18n-tr 105.0.1-1 105.0.2-1
firefox-i18n-trs 105.0.1-1 105.0.2-1
firefox-i18n-uk 105.0.1-1 105.0.2-1
firefox-i18n-ur 105.0.1-1 105.0.2-1
firefox-i18n-uz 105.0.1-1 105.0.2-1
firefox-i18n-vi 105.0.1-1 105.0.2-1
firefox-i18n-xh 105.0.1-1 105.0.2-1
firefox-i18n-zh-cn 105.0.1-1 105.0.2-1
firefox-i18n-zh-tw 105.0.1-1 105.0.2-1
fluidsynth 2.2.9-2 2.3.0-2
foomatic-db 3:20220328-1 3:20221004-1
foomatic-db-nonfree 3:20220328-1 3:20221004-1
foomatic-db-nonfree-ppds 3:20220328-1 3:20221004-1
foomatic-db-ppds 3:20220328-1 3:20221004-1
git 2.37.3-1 2.38.0-1
gnumeric 1.12.52-2 1.12.53-1
gnuplot 5.4.4-1 5.4.5-1
gnuplot-demos 5.4.4-1 5.4.5-1
goffice 0.10.52-1 0.10.53-1
graphviz 5.0.1-3 6.0.1-1
gspell 1.10.0-2 1.12.0-1
gtk31:3.24.34+r154+g56100ab49a-11:3.24.34+r156+g812b3930d0-1
gtk3-demos1:3.24.34+r154+g56100ab49a-11:3.24.34+r156+g812b3930d0-1
gtk3-docs1:3.24.34+r154+g56100ab49a-11:3.24.34+r156+g812b3930d0-1
gucharmap 14.0.3-1 15.0.0-1
inkscape 1.2.1-6 1.2.1-7
khealthcertificate 22.06-1 22.09-1
kwayland-integration 5.25.5-1 5.25.5-2
layer-shell-qt 5.25.5-1 5.25.5-2
libdrm 2.4.113-2 2.4.113-3
libebml 1.4.2-2 1.4.3-1
libmatroska 1.6.3-2 1.7.0-1
libva 2.15.0-7 2.16.0-1
libxtst 1.2.3-5 1.2.4-1
libxxf86vm 1.1.4-5 1.1.5-1
mercurial 6.2.2-1 6.2.3-1
mkvtoolnix-cli 70.0.0-2 70.0.0-3
mkvtoolnix-gui 70.0.0-2 70.0.0-3
noto-fonts 20220607-1 20220810-1
noto-fonts-extra 20220607-1 20220810-1
numactl 2.0.15-1 2.0.16-1
nuspell 5.1.1-1 5.1.2-1
openpmix 4.2.0-1 4.2.1-1
pango 1:1.50.10-1 1:1.50.11-1
pango-docs 1:1.50.10-1 1:1.50.11-1
pangomm 2.46.2-1 2.46.3-1
pangomm-2.48 2.50.0-1 2.50.1-1
pangomm-2.48-docs 2.50.0-1 2.50.1-1
pangomm-docs 2.46.2-1 2.46.3-1
perl-exporter-tiny 1.004002-1 1.004003-1
perl-ffi-checklib 0.30-1 0.31-2
perl-xml-libxml 2.0207-3 2.0208-1
php 8.1.10-1 8.1.11-1
php-apache 8.1.10-1 8.1.11-1
php-cgi 8.1.10-1 8.1.11-1
php-dblib 8.1.10-1 8.1.11-1
php-embed 8.1.10-1 8.1.11-1
php-enchant 8.1.10-1 8.1.11-1
php-fpm 8.1.10-1 8.1.11-1
php-gd 8.1.10-1 8.1.11-1
php-imap 8.1.10-1 8.1.11-1
php-intl 8.1.10-1 8.1.11-1
php-odbc 8.1.10-1 8.1.11-1
php-pgsql 8.1.10-1 8.1.11-1
php-phpdbg 8.1.10-1 8.1.11-1
php-pspell 8.1.10-1 8.1.11-1
php-snmp 8.1.10-1 8.1.11-1
php-sodium 8.1.10-1 8.1.11-1
php-sqlite 8.1.10-1 8.1.11-1
php-tidy 8.1.10-1 8.1.11-1
php-xsl 8.1.10-1 8.1.11-1
plasma-wayland-protocols 1.8.0-1 1.9.0-1
plasma-wayland-session 5.25.5-3 5.25.5-4
plasma-workspace 5.25.5-3 5.25.5-4
prometheus 2.38.0-1 2.39.0-1
protobuf 21.6-1 21.7-1
prrte 2.0.2-1 2.0.2-2
pyqt-builder 1.13.0-1 1.14.0-1
python-fastbencode 0.0.9-1 0.0.12-1
python-protobuf 21.6-1 21.7-1
python-pyopenssl 22.0.0-1 22.1.0-1
python-pyqt6-3d 6.3.0-1 6.4.0-1
python-pyqt6 6.3.1-2 6.4.0-1
python-pyqt6-charts 6.3.1-1 6.4.0-1
python-pyqt6-datavisualization 6.3.1-1 6.4.0-1
python-pyqt6-networkauth 6.3.0-1 6.4.0-1
python-pyqt6-webengine 6.3.1-1 6.4.0-1
python-setuptools 1:62.3.4-1 1:63.1.0-1
python-trove-classifiers 2022.8.31-1 2022.9.26-1
python-virtualenv 20.14.1-1 20.16.0-1
python2 2.7.18-5.1 -
qpdf 11.1.0-1 11.1.1-1
qpdf-docs 11.1.0-1 11.1.1-1
qt5-wayland 5.15.6+kde+r49-1 5.15.6+kde+r50-1
qt6-3d 6.3.2-1 6.4.0-1
qt6-5compat 6.3.2-1 6.4.0-1
qt6-base 6.3.2-1 6.4.0-1
qt6-charts 6.3.2-1 6.4.0-1
qt6-connectivity 6.3.2-1 6.4.0-1
qt6-datavis3d 6.3.2-1 6.4.0-1
qt6-declarative 6.3.2-1 6.4.0-1
qt6-doc 6.3.2-1 6.4.0-1
qt6-examples 6.3.2-1 6.4.0-1
qt6-imageformats 6.3.2-1 6.4.0-1
qt6-languageserver 6.3.2-1 6.4.0-1
qt6-lottie 6.3.2-1 6.4.0-1
qt6-multimedia 6.3.2-1 6.4.0-2
qt6-networkauth 6.3.2-1 6.4.0-1
qt6-positioning 6.3.2-1 6.4.0-1
qt6-quick3d 6.3.2-1 6.4.0-1
qt6-quicktimeline 6.3.2-1 6.4.0-1
qt6-remoteobjects 6.3.2-1 6.4.0-1
qt6-scxml 6.3.2-1 6.4.0-1
qt6-sensors 6.3.2-1 6.4.0-1
qt6-serialbus 6.3.2-1 6.4.0-1
qt6-serialport 6.3.2-1 6.4.0-1
qt6-shadertools 6.3.2-1 6.4.0-1
qt6-svg 6.3.2-1 6.4.0-1
qt6-tools 6.3.2-1 6.4.0-1
qt6-translations 6.3.2-1 6.4.0-1
qt6-virtualkeyboard 6.3.2-1 6.4.0-1
qt6-wayland 6.3.2-1 6.4.0-1
qt6-webchannel 6.3.2-1 6.4.0-1
qt6-webengine 6.3.2-1 6.4.0-2
qt6-websockets 6.3.2-1 6.4.0-1
qt6-webview 6.3.2-1 6.4.0-1
sip 6.6.2-3 6.7.0-1
srt 1.5.0-1 1.5.1-1
thunderbird 102.3.0-1 102.3.1-1
thunderbird-i18n-af 102.3.0-1 102.3.1-1
thunderbird-i18n-ar 102.3.0-1 102.3.1-1
thunderbird-i18n-ast 102.3.0-1 102.3.1-1
thunderbird-i18n-be 102.3.0-1 102.3.1-1
thunderbird-i18n-bg 102.3.0-1 102.3.1-1
thunderbird-i18n-br 102.3.0-1 102.3.1-1
thunderbird-i18n-ca 102.3.0-1 102.3.1-1
thunderbird-i18n-cak 102.3.0-1 102.3.1-1
thunderbird-i18n-cs 102.3.0-1 102.3.1-1
thunderbird-i18n-cy 102.3.0-1 102.3.1-1
thunderbird-i18n-da 102.3.0-1 102.3.1-1
thunderbird-i18n-de 102.3.0-1 102.3.1-1
thunderbird-i18n-dsb 102.3.0-1 102.3.1-1
thunderbird-i18n-el 102.3.0-1 102.3.1-1
thunderbird-i18n-en-gb 102.3.0-1 102.3.1-1
thunderbird-i18n-en-us 102.3.0-1 102.3.1-1
thunderbird-i18n-es-ar 102.3.0-1 102.3.1-1
thunderbird-i18n-es-es 102.3.0-1 102.3.1-1
thunderbird-i18n-et 102.3.0-1 102.3.1-1
thunderbird-i18n-eu 102.3.0-1 102.3.1-1
thunderbird-i18n-fi 102.3.0-1 102.3.1-1
thunderbird-i18n-fr 102.3.0-1 102.3.1-1
thunderbird-i18n-fy-nl 102.3.0-1 102.3.1-1
thunderbird-i18n-ga-ie 102.3.0-1 102.3.1-1
thunderbird-i18n-gd 102.3.0-1 102.3.1-1
thunderbird-i18n-gl 102.3.0-1 102.3.1-1
thunderbird-i18n-he 102.3.0-1 102.3.1-1
thunderbird-i18n-hr 102.3.0-1 102.3.1-1
thunderbird-i18n-hsb 102.3.0-1 102.3.1-1
thunderbird-i18n-hu 102.3.0-1 102.3.1-1
thunderbird-i18n-hy-am 102.3.0-1 102.3.1-1
thunderbird-i18n-id 102.3.0-1 102.3.1-1
thunderbird-i18n-is 102.3.0-1 102.3.1-1
thunderbird-i18n-it 102.3.0-1 102.3.1-1
thunderbird-i18n-ja 102.3.0-1 102.3.1-1
thunderbird-i18n-ka 102.3.0-1 102.3.1-1
thunderbird-i18n-kab 102.3.0-1 102.3.1-1
thunderbird-i18n-kk 102.3.0-1 102.3.1-1
thunderbird-i18n-ko 102.3.0-1 102.3.1-1
thunderbird-i18n-lt 102.3.0-1 102.3.1-1
thunderbird-i18n-ms 102.3.0-1 102.3.1-1
thunderbird-i18n-nb-no 102.3.0-1 102.3.1-1
thunderbird-i18n-nl 102.3.0-1 102.3.1-1
thunderbird-i18n-nn-no 102.3.0-1 102.3.1-1
thunderbird-i18n-pa-in 102.3.0-1 102.3.1-1
thunderbird-i18n-pl 102.3.0-1 102.3.1-1
thunderbird-i18n-pt-br 102.3.0-1 102.3.1-1
thunderbird-i18n-pt-pt 102.3.0-1 102.3.1-1
thunderbird-i18n-rm 102.3.0-1 102.3.1-1
thunderbird-i18n-ro 102.3.0-1 102.3.1-1
thunderbird-i18n-ru 102.3.0-1 102.3.1-1
thunderbird-i18n-sk 102.3.0-1 102.3.1-1
thunderbird-i18n-sl 102.3.0-1 102.3.1-1
thunderbird-i18n-sq 102.3.0-1 102.3.1-1
thunderbird-i18n-sr 102.3.0-1 102.3.1-1
thunderbird-i18n-sv-se 102.3.0-1 102.3.1-1
thunderbird-i18n-th 102.3.0-1 102.3.1-1
thunderbird-i18n-tr 102.3.0-1 102.3.1-1
thunderbird-i18n-uk 102.3.0-1 102.3.1-1
thunderbird-i18n-uz 102.3.0-1 102.3.1-1
thunderbird-i18n-vi 102.3.0-1 102.3.1-1
thunderbird-i18n-zh-cn 102.3.0-1 102.3.1-1
thunderbird-i18n-zh-tw 102.3.0-1 102.3.1-1
ttf-croscore 20220607-1 20220810-1
unicode-character-database 14.0.0-1 15.0.0-1
wolfssl 5.5.0-1 5.5.1-1
xfce4-notifyd 0.6.4-1 0.6.4-2
xkeyboard-config 2.36+89+g382c5feb-1 2.37-1
xterm 372-2 373-1
yelp-xsl 42.0-1 42.1-1
kirigami-addons - 0.4-1
plasma-settings - 22.09-1
qt6-httpserver - 6.4.0-1
qt6-multimedia-ffmpeg - 6.4.0-2
qt6-multimedia-gstreamer - 6.4.0-2
qt6-quick3dphysics - 6.4.0-1
qt6-speech - 6.4.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.08.1.r12818.ga3c43a3d0-122.08.1.r12821.g3571efb46-1
akonadi-calendar22.08.1.r2158.gd05bd44-122.08.1.r2162.g8884500-1
akonadi-calendar-tools22.08.1.r966.g4be892e-122.08.1.r968.gf4dd424-1
akonadi-contacts22.08.1.r3243.gfa00d0f0-122.08.1.r3247.gb34eaf32-1
akonadi-import-wizard22.08.1.r1852.g1a01a6f-122.08.1.r1855.g2c26155-1
akonadi-mime22.08.1.r1757.gaa9da55-122.08.1.r1760.g0079a23-1
akonadi-notes22.08.1.r1091.gea98b0c-122.08.1.r1093.g9e85546-1
akonadi-search22.08.1.r1281.gc954204-122.08.1.r1284.g8f82b31-1
akregator22.08.1.r6470.g979b5dd4-122.08.1.r6475.g2fee635c-1
alligator 22.06.r55.gfd54bbd-1 22.09.r2.g0757403-1
analitza22.08.1.r2358.g04dd73a5-122.08.1.r2360.g8462faf1-1
angelfish 22.06.r62.gb136825-1 22.09.r1.g82f1ded-1
ark22.08.1.r4844.g68e3d95b-122.08.1.r4866.g1b6001fe-1
artikulate22.08.1.r1432.gc819306-122.08.1.r1435.gc511f3a-1
attica5.98.0.r888.gabe6e78-15.98.0.r889.g703a75b-1
audiocd-kio22.08.1.r1110.g6f34356-122.08.1.r1118.gf2ec5fe-1
audiotube 22.06.r40.g2293280-1 22.09.r9.gf99a173-1
aura-browser r89.63631dc-1 r92.0a6c10c-1
baloo5.98.0.r3067.gd421b4b6-15.98.0.r3070.g4de0d9a2-1
baloo-widgets22.08.1.r773.g48c9d69-122.08.1.r775.gcf3e2b8-1
blinken22.08.1.r685.gf7cdbef-122.08.1.r688.g86c11fc-1
bluedevil1:5.25.5.r2441.g2a9d5252-11:5.25.5.r2449.g344d7f75-1
bluez-qt5.98.0.r723.g93739fb-15.98.0.r724.g77a98ff-1
bomber22.08.1.r579.g407b742-122.08.1.r581.g4f5867c-1
bovo22.08.1.r789.g31db868-122.08.1.r793.ga8c3c39-1
breeze5.25.5.r2466.g84997dc0-15.25.5.r2474.g39f38c73-1
breeze-icons5.98.0.r1920.gcbf7f375-15.98.0.r1921.g1ba18f91-1
buho 2.2.0.r5.gd39a889-1 2.2.0.r7.gf2ef000-1
calendarsupport22.08.1.r731.ga65decc-122.08.1.r734.g0672f82-1
calindori 22.06.r21.g5d901d9-1 22.09.r6.ga8a92e4-1
cervisia22.08.1.r1704.g617b67c-122.08.1.r1706.g6ccfbca-1
discover5.25.5.r8843.g84b316a5-15.25.5.r8850.g43b8e3e8-1
dolphin22.08.1.r7094.gaa54a68e9-122.08.1.r7099.g7cb630c60-1
dolphin-plugins22.08.1.r678.g678ff40-122.08.1.r680.gcbada72-1
dragon22.08.1.r1062.g4f2df9d-122.08.1.r1066.gccb897a-1
drkonqi5.25.5.r828.gef22aade-15.25.5.r831.g6b878004-1
elisa22.08.1.r3038.g0588e7b7-122.08.1.r3046.gca7b6c21-1
elisa-qtmm22.08.1.r3038.g0588e7b7-122.08.1.r3046.gca7b6c21-1
eventviews22.08.1.r885.g4f83ca5-122.08.1.r887.gb142fad-1
extra-cmake-modules5.98.0.r3522.g5b1b9370-15.98.0.r3524.gbbcbaff7-1
filelight22.08.1.r1181.gc5c14de-122.08.1.r1185.g7ad48a4-1
frameworkintegration5.98.0.r655.gfdbc2d3-15.98.0.r657.g0554220-1
granatier22.08.1.r991.gf23f2d2-122.08.1.r993.gc7e1dbe-1
grantlee-editor22.08.1.r840.gc3bbbac-122.08.1.r842.g78a4998-1
grantleetheme22.08.1.r420.ga274fc0-122.08.1.r422.g6c8a61b-1
gwenview22.08.1.r6901.gdd82a25a-122.08.1.r6905.g4ad8c9e1-1
incidenceeditor22.08.1.r931.g2358aa2-122.08.1.r937.g95fe8d3-1
index-fm 2.2.0.r4.g67e61ac-1 2.2.0.r8.g81db8bf-1
itinerary22.08.1.r2011.g7759688-122.08.1.r2015.gc870a57-1
juk22.08.1.r3182.g16db4762-122.08.1.r3185.g402218f4-1
k3b1:22.08.1.r6823.g4e56f8909-11:22.08.1.r6825.g878b98302-1
kaccounts-integration22.08.1.r1288.g2e2510b-122.08.1.r1292.ga0260c2-1
kaccounts-providers22.08.1.r402.gba64646-122.08.1.r404.g6112db4-1
kactivities5.98.0.r1411.g6f54fb4b-15.98.0.r1412.g5266ad56-1
kactivities-stats5.98.0.r420.g4694833-15.98.0.r421.g1666b3f-1
kactivitymanagerd5.25.5.r1422.g3e55209-15.25.5.r1425.g311a7c3-1
kaddressbook22.08.1.r6243.g50ef406e-122.08.1.r6247.g4e4cf230-1
kajongg22.08.1.r4352.g3f78e423-122.08.1.r4354.gd648c255-1
kalarm22.08.1.r8007.gd3f0efc1-122.08.1.r8012.g230454d5-1
kalgebra22.08.1.r2081.ga37dc18-122.08.1.r2084.g6feccf9-1
kalk 22.06.r30.gbfa864e-1 22.09.r2.g61f87a0-1
kalzium22.08.1.r4381.g2ab2567f-122.08.1.r4384.gd53fb25f-1
kamera22.08.1.r737.g56e20df-122.08.1.r739.g0d4b282-1
kamoso22.08.1.r1478.gb1487f2-122.08.1.r1483.gdd8a237-1
kanagram22.08.1.r1328.gabb0747-122.08.1.r1332.g8aa4c95-1
kapman22.08.1.r670.g201ccba-122.08.1.r674.ga92f7d4-1
kapptemplate22.08.1.r1006.g23bf10f-122.08.1.r1008.g2bda9c1-1
karchive5.98.0.r558.g06d226d-15.98.0.r559.g44e871e-1
kasts 22.06.r60.g3ab9786-122.09.2.r3.gca3bbfb-1
kate22.08.1.r19603.g2f7a3f3b4-122.08.1.r19637.gcba740a02-1
katomic22.08.1.r977.gd4e0654-122.08.1.r981.g45dd2c9-1
kauth5.98.0.r511.g5416919-15.98.0.r515.gb31dd81-1
kbackup22.08.1.r458.g62b16d5-122.08.1.r460.g25c8a92-1
kblackbox22.08.1.r781.g4d2b8fd-122.08.1.r783.ge7eeb2d-1
kblocks22.08.1.r757.g1cefbb4-122.08.1.r761.g0f1407c-1
kbookmarks5.98.0.r471.g664adfb-15.98.0.r475.g5e8e92e-1
kbounce22.08.1.r862.gc6d4be8-122.08.1.r864.gbc96a29-1
kbreakout22.08.1.r939.g437fbce-122.08.1.r943.g5d567a7-1
kbruch22.08.1.r877.g6fefc4a-122.08.1.r880.g1c03bdf-1
kcachegrind22.08.1.r1194.g95e6bf4-122.08.1.r1196.g921ef17-1
kcachegrind-common22.08.1.r1194.g95e6bf4-122.08.1.r1196.g921ef17-1
kcalc22.08.1.r1635.g55fa699-122.08.1.r1642.gaa3aebf-1
kcalendarcore5.98.0.r1348.gaf6a43f79-15.98.0.r1349.g712e9cbdb-1
kcalutils22.08.1.r987.g36643e298-122.08.1.r990.ge9feb859f-1
kcharselect22.08.1.r544.g28c1abb-122.08.1.r546.g7a18db1-1
kclock 22.06.r45.gb44ddba-1 22.09.r3.g65ef8c0-1
kcmutils5.98.0.r666.g7d88a75-15.98.0.r669.g73f3c86-1
kcodecs5.98.0.r433.g2b15541-15.98.0.r438.g1f8a26a-1
kcolorchooser22.08.1.r283.gb247fe8-122.08.1.r285.g6c5d9d1-1
kcompletion5.98.0.r513.gea536b2-15.98.0.r518.gac876c3-1
kconfig5.98.0.r982.g11cf7268-15.98.0.r987.g5cd0f72f-1
kconfigwidgets5.98.0.r777.gfcb9672-15.98.0.r783.g27311dc3-1
kcontacts1:5.98.0.r3350.g1d757eba-11:5.98.0.r3353.ge9dafa7e-1
kcoreaddons5.98.0.r1562.gb1deba29-15.98.0.r1572.g0db20253-1
kcrash5.98.0.r457.gd2f3085-15.98.0.r458.g549e118-1
kcron22.08.1.r850.g64060da-122.08.1.r852.g975220a-1
kdav1:5.98.0.r1357.g79ca85d-11:5.98.0.r1362.g5f93e81-1
kdbusaddons5.98.0.r431.g36a9cf6-15.98.0.r437.gc385823-1
kde-cli-tools5.25.5.r1957.g3528835-15.25.5.r1962.gbeaddcd-1
kde-dev-scripts22.08.1.r4163.g659e6cc-122.08.1.r4168.gf834d92-1
kde-dev-utils22.08.1.r599.gc48d323-122.08.1.r603.g9f7336e-1
kdebugsettings22.08.1.r970.gb94389e-122.08.1.r974.ga0d5221-1
kdeclarative5.98.0.r1045.g51f62d7-15.98.0.r1049.g39f7c0d-1
kdeconnect22.08.1.r3543.gae0815ea-122.08.1.r3550.gbf2fff7f-1
kdecoration5.25.5.r300.g2c711db-15.25.5.r302.g04caee0-1
kded5.98.0.r477.gc8d2ebd-15.98.0.r479.gbea8392-1
kdelibs4support5.98.0.r1109.gd597d15f-15.98.0.r1112.gc644b09f-1
kdenetwork-filesharing22.08.1.r987.g2dc2e1c-122.08.1.r991.g75d63a8-1
kdenlive22.08.1.r16678.g3ba202fbb-122.08.1.r16743.ga6c60f7d7-1
kdepim-addons22.08.1.r4853.ga95c3d8a8-122.08.1.r4859.gaa3b8d47f-1
kdepim-runtime22.08.1.r15602.g204ae7da2-122.08.1.r15608.g16d6a6789-1
kdeplasma-addons5.25.5.r9045.gd5141154f-15.25.5.r9059.g397151117-1
kdesdk-thumbnailers22.08.1.r93.g7ff219f-122.08.1.r95.g45f6a2c-1
kdesignerplugin5.98.0.r362.g8ddd4cd-15.98.0.r365.g9220b64-1
kdesu5.98.0.r521.gbda57d5-15.98.0.r524.g373efd4-1
kdewebkit5.98.0.r309.g6a96cc9-15.98.0.r310.gc09ee91-1
kdf22.08.1.r877.g5302240-122.08.1.r880.gbfabefb-1
kdialog22.08.1.r1242.g632d35648-122.08.1.r1247.g6678a240d-1
kdiamond22.08.1.r740.g96b3ef2-122.08.1.r745.gc0e0454-1
kdnssd5.98.0.r363.g36f9a06-15.98.0.r367.g3af555a-1
kdoctools5.98.0.r683.g0f794d4-15.98.0.r686.g480b5ed-1
keditbookmarks22.08.1.r2773.ga362d4223-122.08.1.r2776.g3923f11a4-1
kemoticons5.98.0.r426.g103a043-15.98.0.r427.gc64fad2-1
keysmith 22.06.r24.g82be984-1 22.09.r1.g1c5e6eb-1
kfilemetadata5.98.0.r878.g076fde9-15.98.0.r882.gd2c9e47-1
kfind22.08.1.r2729.g4b42e460d-122.08.1.r2732.g349dc71bc-1
kfloppy22.08.1.r807.gb4c1eb2-122.08.1.r811.g1c26b99-1
kfourinline22.08.1.r1043.ga21db14-122.08.1.r1046.ge814ffb-1
kgamma55.25.5.r486.gaa07f95-15.25.5.r489.g1d67c5e-1
kgeography22.08.1.r1169.g0c690ba-122.08.1.r1171.gbf496e4-1
kget22.08.1.r3224.g4b3e7310-122.08.1.r3229.g9c94ff03-1
kglobalaccel5.98.0.r576.g6b1ab68-15.98.0.r580.ga480e54-1
kgoldrunner22.08.1.r1299.g2abb019-122.08.1.r1302.g42ac7d3-1
kgpg22.08.1.r3208.g3cb453b4-122.08.1.r3210.gf36ecf7f-1
kguiaddons5.98.0.r498.gebc9be7-15.98.0.r502.gd459cd7-1
khangman22.08.1.r1628.g3983a91-122.08.1.r1633.gd89a4a3-1
khealthcertificate 22.06.r18.gedb920b-1 22.09.r1.g9825106-1
khelpcenter22.08.1.r2780.g97eac96d-122.08.1.r2785.g16457ad3-1
kholidays1:5.98.0.r1061.g2ddf774-11:5.98.0.r1066.gfe46dbe-1
khotkeys5.25.5.r2161.ge4cd6f2-15.25.5.r2167.g8a983ed-1
khtml5.98.0.r599.g71a9ee2-15.98.0.r602.gb0be19c-1
ki18n5.98.0.r579.gda282de-15.98.0.r582.g3537b34-1
kiconthemes5.98.0.r636.g1f48af6-15.98.0.r640.ge4a2724-1
kidentitymanagement22.08.1.r3905.ga2b6587b-122.08.1.r3908.gc5ee4112-1
kidletime5.98.0.r373.g6bbee45-15.98.0.r374.gfe7a09a-1
kig22.08.1.r3231.gd903d20d-122.08.1.r3234.ge8057d40-1
kigo22.08.1.r590.g43518cb-122.08.1.r594.g8d3cd1b-1
killbots22.08.1.r809.g09ebca2-122.08.1.r816.gf35ac61-1
kimageformats5.98.0.r436.ga8a477a-15.98.0.r445.g5412981-1
kimagemapeditor22.08.1.r507.gbaf537e-122.08.1.r509.g01de575-1
kimap22.08.1.r1210.ge6b6db7-122.08.1.r1212.g3556e36-1
kinfocenter5.25.5.r2160.ga8b8b300-15.25.5.r2165.g380eea6d-1
kinit5.98.0.r448.g32fd61a-15.98.0.r451.gd8e54a5-1
kio5.98.0.r5709.gad27f0e29-15.98.0.r5722.g1b502d5b9-1
kio-extras22.08.1.r7339.g9596b7c3-122.08.1.r7343.gbeccfb3e-1
kio-gdrive22.08.1.r644.g6c8de22-122.08.1.r651.g2d91b5d-1
kirigami-addons 1:0.3.r18.gdd44157-1 1:0.4.r3.gfb4896f-1
kirigami-gallery22.08.1.r271.g0a3c38b-122.08.1.r273.g5b88b48-1
kirigami25.98.0.r3352.geca9b307-15.98.0.r3363.g1369677c-1
kiriki22.08.1.r468.g9af41d5-122.08.1.r470.gcaa40d3-1
kitemmodels5.98.0.r621.g7c5f2a2-15.98.0.r623.gf7f4cac-1
kitemviews5.98.0.r386.g0a3c806-15.98.0.r391.g3a14c1c-1
kiten22.08.1.r1212.gf92c420-122.08.1.r1215.gd516577-1
kitinerary22.08.1.r2398.gb773767-122.08.1.r2417.g0de6fc1-1
kjobwidgets5.98.0.r431.g4d2f999-15.98.0.r435.gf3f1fa4-1
kjsembed5.98.0.r336.g790fa36-15.98.0.r339.g8e224c1-1
kjumpingcube22.08.1.r839.g3247359-122.08.1.r841.g9659631-1
kldap22.08.1.r967.g8597a3c-122.08.1.r969.g21b381a-1
kleopatra22.08.1.r6852.g1dac90d9-122.08.1.r6860.g0f22dd2b-1
klettres22.08.1.r980.gabd483d-122.08.1.r982.gc8098d5-1
klickety22.08.1.r710.g7a33058-122.08.1.r712.g44fe20e-1
klines22.08.1.r836.g7834f4a-122.08.1.r841.gfafda4c-1
kmag22.08.1.r748.gc5a05bb-122.08.1.r750.g5db483a-1
kmahjongg22.08.1.r1575.g9eae5cf-122.08.1.r1577.g6dccaca-1
kmail22.08.1.r26537.gf72df796d-122.08.1.r26542.g04b5047d3-1
kmail-account-wizard22.08.1.r901.g2ff55d5-122.08.1.r904.gcf4c1b4-1
kmailtransport22.08.1.r1764.g6e5617e-122.08.1.r1767.gbf76d7b-1
kmediaplayer5.98.0.r325.gf28ed33-15.98.0.r326.g755083f-1
kmenuedit5.25.5.r1073.gb012eed-15.25.5.r1077.g88053d7-1
kmime22.08.1.r1530.g6874e72-122.08.1.r1538.g423ae7e-1
kmines22.08.1.r1782.g5acee96-122.08.1.r1784.gb671579-1
kmix22.08.1.r2462.g7f39c685-122.08.1.r2465.g4fba9f89-1
kmousetool22.08.1.r459.gfc04da4-122.08.1.r461.g4c898b9-1
kmouth22.08.1.r744.gf469bfd-122.08.1.r747.ge864243-1
kmplot22.08.1.r1508.gfb4c443-122.08.1.r1510.ga69f00b-1
knavalbattle22.08.1.r1447.gde3836e-122.08.1.r1449.gacbb420-1
knetwalk22.08.1.r728.g533eb88-122.08.1.r730.gd3685ca-1
knewstuff5.98.0.r1389.gceba876e-15.98.0.r1395.g713b435a-1
knights22.08.1.r1157.gccdf867-122.08.1.r1160.g1026e09-1
knotes22.08.1.r3698.ga423a53e-122.08.1.r3702.g0f54577c-1
knotifications5.98.0.r760.g0450e43-15.98.0.r766.gdf76333-1
knotifyconfig5.98.0.r395.gf7228f4-15.98.0.r398.g93569ac-1
koko 22.06.r26.g4ce78c2-1 22.09.r6.gf077620-1
kolf22.08.1.r1523.g2598f74-122.08.1.r1527.gafb9bf6-1
kollision22.08.1.r548.g6ab62f4-122.08.1.r552.gadf1a39-1
kolourpaint22.08.1.r2436.ga0ba712c-122.08.1.r2441.g3aa315fa-1
kompare22.08.1.r1154.gb510628-122.08.1.r1157.g67d7b12-1
kongress 22.06.r32.g68614dc-1 22.09.r6.g64a9874-1
konqueror22.08.1.r15172.gc9f3d1957-122.08.1.r15177.g961bc2ceb-1
konquest22.08.1.r952.g5143f85-122.08.1.r954.gfb771d6-1
konsole22.08.1.r8618.gf4b6cabf-122.08.1.r8632.g5d6d0b43-1
kontact22.08.1.r5572.gff3fd40c-122.08.1.r5576.g766601be-1
kontactinterface22.08.1.r710.g72681eb-122.08.1.r712.g3bce657-1
kontrast22.08.1.r237.g386d770-122.08.1.r241.gffebfab-1
konversation22.08.1.r9161.gb3d4b0e5-122.08.1.r9164.g51785fda-1
kopeninghours22.08.1.r337.gb0fd547-122.08.1.r339.ge10ec60-1
kopete22.08.1.r16452.gac28f78d7-122.08.1.r16454.g42a93e4bc-1
korganizer22.08.1.r11800.g3700df430-122.08.1.r11803.gd4c6859b0-1
kosmindoormap22.08.1.r755.ge3fe2be-122.08.1.r759.gf5f7c47-1
kpackage5.98.0.r773.geb0cc78-15.98.0.r778.gb5165db-1
kparts5.98.0.r601.gcd467a1-15.98.0.r605.g6313d58-1
kpat22.08.1.r2638.g09f30038-122.08.1.r2642.gba9df7fa-1
kpeople5.98.0.r1388.g7d10f85-15.98.0.r1391.g578ad5b-1
kpeoplevcard 0.1.r23.ga63a61d-1 0.1.r25.g8408064-1
kpimtextedit22.08.1.r1627.ga7adbdc-122.08.1.r1630.g41821cb-1
kpipewire5.25.5.r142.g88db026-15.25.5.r146.g58a5a3b-1
kplotting5.98.0.r335.g8859977-15.98.0.r337.g4c1b617-1
kpmcore22.08.1.r1297.g6d2fa58-122.08.1.r1302.gcfc921d-1
kpty5.98.0.r388.gdc2e4cb-15.98.0.r391.g4394070-1
kpublictransport22.08.1.r2048.ga806a78c-122.08.1.r2049.g3835a3cc-1
kquickcharts5.98.0.r536.gfec03c3-15.98.0.r539.gedcfb88-1
krdc22.08.1.r1624.g0760c95-122.08.1.r1629.g466c5d0-1
krecorder 22.06.r26.gbc44a47-1 22.09.r2.gcda5ffa-1
kreversi22.08.1.r1288.gcc0aee6-122.08.1.r1292.g200fb09-1
krfb22.08.1.r1516.gc59abf0-122.08.1.r1520.g085d308-1
kross5.98.0.r367.gd01acf1-15.98.0.r370.g4d86ff1-1
kruler22.08.1.r750.g927e58c-122.08.1.r754.ge8a5ea0-1
krunner5.98.0.r789.g780337b-15.98.0.r790.g81c82b8-1
ksanecore r624.gc8717a5-1 r626.g7bd5753-1
kscreen5.25.5.r1539.g1b2d0cc-15.25.5.r1549.g3ee71d6-1
kscreenlocker5.25.5.r988.g07e2e4d-15.25.5.r995.g7134bca-1
kservice5.98.0.r1033.g4f9844f-15.98.0.r1037.g906c44d-1
kshisen22.08.1.r1256.g9a87551-122.08.1.r1258.g1a46892-1
ksirk22.08.1.r1050.gd98652a-122.08.1.r1052.g6a58195-1
ksmtp22.08.1.r462.g07c44fb-122.08.1.r464.g0674767-1
ksnakeduel22.08.1.r867.g5bebcf7-122.08.1.r870.gcecdffd-1
kspaceduel22.08.1.r687.gc0e565b-122.08.1.r691.gca8b65a-1
ksquares22.08.1.r575.g8f62c7e-122.08.1.r579.g075aaed-1
ksshaskpass5.25.5.r217.g9064dd1-15.25.5.r220.g8810ba1-1
ksudoku22.08.1.r1137.gfad8a9e-122.08.1.r1139.g1ca99d8-1
ksysguard5.25.5.r3544.ga33b3673-15.25.5.r3547.ge3d7acf7-1
ksystemlog22.08.1.r755.gabb98ec-122.08.1.r761.g2643122-1
ksystemstats5.25.5.r237.g89b9c67-15.25.5.r243.g4513e06-1
kteatime22.08.1.r768.g4b94625-122.08.1.r772.g59c931d-1
ktexteditor5.98.0.r3548.gdd3bfb4d-15.98.0.r3559.gf406a880-1
ktextwidgets5.98.0.r460.gc1cb26b-15.98.0.r463.gaac9557-1
ktimer22.08.1.r536.gc59aeb9-122.08.1.r539.gce0706a-1
ktnef22.08.1.r733.g7eb5014-122.08.1.r736.gf434340-1
ktorrent22.08.1.r2883.gc8d8071e-122.08.1.r2888.g7d314656-1
ktouch22.08.1.r2200.ga56eaaf-122.08.1.r2204.g7fbec35-1
ktrip 22.06.r15.g3d5793e-1 22.09.r4.g903fcf9-1
ktuberling22.08.1.r1090.gb7ff271-122.08.1.r1094.gdb941e2-1
kturtle22.08.1.r1187.g0f7f862-122.08.1.r1190.g4dafca2-1
kubrick22.08.1.r434.gdde3286-122.08.1.r436.gbd7248b-1
kunitconversion5.98.0.r430.g73d0917-15.98.0.r433.gecdff53-1
kwallet5.98.0.r1180.g2ce5ea8-15.98.0.r1183.g36f78b6-1
kwalletmanager22.08.1.r1298.g4f8bd7b-122.08.1.r1302.g75c6537-1
kwave22.08.1.r3806.gec348d90-122.08.1.r3810.g072b98d2-1
kwayland5.98.0.r1189.gd0edf83-15.98.0.r1192.ge8d4583-1
kwayland-integration5.25.5.r218.g12a2791-15.25.5.r219.g9359066-1
kweather 22.06.r81.g8be5a2c-1 22.09.r6.g7467c41-1
kweathercore 0.6.r25.g5f915f8-1 0.6.r29.ge25a5e9-1
kwidgetsaddons5.98.0.r985.g9294cb7f-15.98.0.r989.gf083d03b-1
kwin5.25.5.r23225.ge924b1cb2-15.25.5.r23248.gae4dd73e9-1
kwindowsystem5.98.0.r697.g5618f22-15.98.0.r703.g22d30be-1
kwordquiz22.08.1.r1203.g69bf4ad-122.08.1.r1206.g8abade9-1
kwrite22.08.1.r19603.g2f7a3f3b4-122.08.1.r19637.gcba740a02-1
kxmlgui5.98.0.r908.g3726b9c3-15.98.0.r911.gf3417ab3-1
kxmlrpcclient5.98.0.r489.g6e327a026-15.98.0.r492.g2f0446e2b-1
libakonadi22.08.1.r12818.ga3c43a3d0-122.08.1.r12821.g3571efb46-1
libgravatar22.08.1.r438.g6a38a88-122.08.1.r440.g39eeabc-1
libkcddb22.08.1.r768.g7a30ef8-122.08.1.r772.g69ad624-1
libkcompactdisc22.08.1.r399.g61b5f60-122.08.1.r401.g9cd5b74-1
libkdegames22.08.1.r2263.g82613897-122.08.1.r2268.gae11a4d0-1
libkdepim22.08.1.r927.gfa3a107-122.08.1.r929.g1026ff4-1
libkeduvocdocument22.08.1.r1812.g8a1b9c7-122.08.1.r1816.gadc5265-1
libkgapi22.08.1.r1379.g0898795-122.08.1.r1381.g1a2bd5e-1
libkleo22.08.1.r1279.ge5aee11-122.08.1.r1282.g9697f54-1
libkmahjongg22.08.1.r491.g0dd8adc-122.08.1.r495.gb9bd29a-1
libkomparediff222.08.1.r346.g5e898ac-122.08.1.r348.gebda36f-1
libksane22.08.1.r606.g65ca6b1-122.08.1.r608.g0fb171a-1
libksieve22.08.1.r1745.g48999446-122.08.1.r1749.g2920a7ec-1
libksysguard5.25.5.r2435.gab3ed19-15.25.5.r2438.gbf92bd7-1
libktorrent22.08.1.r564.gc5f7928-122.08.1.r566.g2d15899-1
lokalize22.08.1.r1848.ga01091f4-122.08.1.r1850.ge4727b91-1
lskat22.08.1.r869.g0d0b4e7-122.08.1.r871.ge485dcc-1
mailcommon22.08.1.r1294.gac7ae5f-122.08.1.r1298.g04fa632-1
mailimporter22.08.1.r537.g18092bb-122.08.1.r539.g72cc021-1
marble22.08.1.r13469.g78d4ab70f-122.08.1.r13473.g905fc19b6-1
marble-common22.08.1.r13469.g78d4ab70f-122.08.1.r13473.g905fc19b6-1
marble-qt22.08.1.r13469.g78d4ab70f-122.08.1.r13473.g905fc19b6-1
markdownpart22.08.1.r136.g47c7fd1-122.08.1.r140.gb890940-1
maui-clip 2.2.0.r0.g81ee204-1 2.2.0.r3.g828dc82-1
maui-nota 2.2.0.r3.g65ca8ec-1 2.2.0.r7.g18be78f-1
maui-pix 2.2.0.r9.g7747d4a-1 2.2.0.r11.g5306134-1
mauikit2.2.0.r15.gc53db67f-12.2.0.r20.g2375fa1d-1
mauikit-filebrowsing 2.2.0.r2.gf82d491-1 2.2.0.r4.g5f3fab5-1
mauikit-texteditor 2.2.0.r2.g7f00868-1 2.2.0.r3.g58ee8b5-1
mauiman r33.6ef5b9c-1 r34.7a65fa5-1
mbox-importer22.08.1.r581.g61596b4-122.08.1.r583.g90f0018-1
messagelib22.08.1.r6675.g149fb30d1-122.08.1.r6678.geaa287974-1
milou5.25.5.r786.g28fdf01-15.25.5.r789.g701fdc9-1
minuet22.08.1.r625.gf969168-122.08.1.r627.g7e4e789-1
modemmanager-qt5.98.0.r564.g84f4ec4-15.98.0.r565.g9ea798e-1
neochat22.06.r146.g7f26651e-122.09.r15.g17a36f19-1
networkmanager-qt5.98.0.r1166.g7e4ada1-15.98.0.r1170.g09cfb91-1
okular22.08.1.r9834.g804cadfb5-122.08.1.r9837.ga40a7c217-1
oxygen5.25.5.r4508.g989fa534-15.25.5.r4512.ge0f035a5-1
palapeli22.08.1.r1314.g5915c28-122.08.1.r1317.g4fe8301-1
parley22.08.1.r4544.gcfb8d323-122.08.1.r4546.ga70b09f8-1
partitionmanager22.08.1.r1645.g923e449-122.08.1.r1648.g5214dd3-1
picmi22.08.1.r587.g1043549-122.08.1.r590.g1b069bd-1
pim-data-exporter22.08.1.r2789.gf92edde5-122.08.1.r2793.g400c2b9c-1
pim-sieve-editor22.08.1.r1655.g5e7ac13-122.08.1.r1659.gbdd4e98-1
pimcommon22.08.1.r1366.g452a4a6-122.08.1.r1369.ga1fb575-1
plank-player r59.fd116d8-1 r63.ac9f125-1
plasma-bigscreen r517.gdf84ea4-1 r522.g1fdb7da-1
plasma-browser-integration5.25.5.r1354.g9d4e7a64-15.25.5.r1358.g35864f80-1
plasma-camera 1.0.r133.gd326078-1 1.0.r135.g790eca8-1
plasma-desktop5.25.5.r9662.g2664a3a94-15.25.5.r9675.g5ccc2a438-1
plasma-dialer22.06.r123.gc064fce-1 22.09.r2.gec45dea-1
plasma-disks5.25.5.r294.g5143e85-15.25.5.r296.g58c5d33-1
plasma-firewall5.25.5.r652.gd090cf4-15.25.5.r656.gff9daa9-1
plasma-framework5.98.0.r16430.g2900b2708-15.98.0.r16437.gb7c5bb001-1
plasma-integration5.25.5.r580.g97a2a80-15.25.5.r582.gee1c0c1-1
plasma-mobile5.25.5.r1988.gf4e6d6b69-15.25.5.r1996.gf98079800-1
plasma-mobile-nm5.25.5.r3338.ga6133e39-15.25.5.r3345.g4e6bba2f-1
plasma-nano5.25.5.r197.geac37be-15.25.5.r200.gaf65672-1
plasma-nm5.25.5.r3338.ga6133e39-15.25.5.r3345.g4e6bba2f-1
plasma-pa5.25.5.r1093.gd6adfb8-15.25.5.r1097.ge75df57-1
plasma-phonebook 22.06.r21.g150891f-1 22.09.r1.gae8216f-1
plasma-remotecontrollers r134.g95b2ed3-1 r138.g12ff49f-1
plasma-sdk5.25.5.r2403.g114fccad-15.25.5.r2408.gb6aa5581-1
plasma-settings 22.06.r98.g2435afe-1 22.09.r3.ge009307-1
plasma-systemmonitor5.25.5.r629.ge0d0209-15.25.5.r635.gb44a6b6-1
plasma-thunderbolt5.25.5.r198.ge761487-15.25.5.r204.ga92febe-1
plasma-vault5.25.5.r393.g564938f-15.25.5.r396.gc8d49a0-1
plasma-wayland-protocols1.4.0.r1063.gab8fbdd-11.4.0.r1064.gbd220a1-1
plasma-wayland-session5.25.5.r12399.ge2d40b285-15.25.5.r12429.g0bbba7a7d-1
plasma-workspace5.25.5.r12399.ge2d40b285-15.25.5.r12429.g0bbba7a7d-1
plasma-workspace-wallpapers5.25.5.r382.g0f355ce-15.25.5.r383.ge9f52b5-1
plasmatube 22.06.r33.g39ba9cb-1 22.09.r1.g6dd5d7c-1
polkit-kde-agent5.25.5.r535.gf6e159c-15.25.5.r540.g89b8da8-1
powerdevil5.25.5.r2597.g0a37c1a7-15.25.5.r2602.gf45b9fb2-1
poxml22.08.1.r283.g1b8e394-122.08.1.r284.g47cdde8-1
print-manager22.08.1.r1162.gfcd9cd1-122.08.1.r1165.g18eda7f-1
prison5.98.0.r403.g3c3e1b7-15.98.0.r406.gfba5085-1
purpose5.98.0.r998.g8a0ecf4-15.98.0.r1002.ge9003b0-1
qcachegrind22.08.1.r1194.g95e6bf4-122.08.1.r1196.g921ef17-1
qmlkonsole 22.06.r48.g76ddd74-1 22.09.r1.g46c8c85-1
qqc2-breeze-style5.25.5.r252.g717d6cb-15.25.5.r254.ga2849f5-1
qqc2-desktop-style5.98.0.r676.g6cc2cf2-15.98.0.r678.ga5e1ecd-1
rocs22.08.1.r3128.g7f23a916-122.08.1.r3130.g0bd975e8-1
sddm-kcm5.25.5.r691.g3828937-15.25.5.r694.g23c5368-1
solid5.98.0.r796.g2156b5e-15.98.0.r802.g9c4df11-1
sonnet5.98.0.r714.gbad8b5d-15.98.0.r718.g96531aa-1
spacebar 22.06.r77.g3fb4b99-1 22.09.r1.g3770bac-1
spectacle22.08.1.r1389.gfbf17f3-122.08.1.r1395.g1678cdb-1
step22.08.1.r1212.g6bf7e59-122.08.1.r1215.gf8d8a74-1
svgpart22.08.1.r239.g06b4b42-122.08.1.r241.g970da0a-1
sweeper22.08.1.r587.geb9487e-122.08.1.r589.g098ecaf-1
syndication5.98.0.r886.gdadc406-15.98.0.r888.g1e6db5f-1
syntax-highlighting5.98.0.r1926.gb128085d-15.98.0.r1937.gf43626fb-1
systemsettings5.25.5.r2719.g68c53794-15.25.5.r2725.gb5379e98-1
telepathy-kde-accounts-kcm22.08.1.r1221.gf2005ff-122.08.1.r1224.g9b21a1c-1
telepathy-kde-approver22.08.1.r308.g156c44b-122.08.1.r310.g74533b1-1
telepathy-kde-auth-handler22.08.1.r286.g8ce5b15-122.08.1.r288.g3e89b76-1
telepathy-kde-call-ui22.08.1.r452.g88b3c1d-122.08.1.r454.g3492c1a-1
telepathy-kde-common-internals22.08.1.r2025.g8dd13f3-122.08.1.r2028.g8476792-1
telepathy-kde-contact-list22.08.1.r1095.g0752a93-122.08.1.r1098.gebd7ebc-1
telepathy-kde-contact-runner22.08.1.r265.g2ba5909-122.08.1.r268.g5b9b505-1
telepathy-kde-desktop-applets22.08.1.r1009.g74f8391-122.08.1.r1012.gdc3d782-1
telepathy-kde-filetransfer-handler22.08.1.r229.g203f247-122.08.1.r231.g22cf9c7-1
telepathy-kde-integration-module22.08.1.r404.g9d6c6b3-122.08.1.r407.g3f52a32-1
telepathy-kde-send-file22.08.1.r238.ga0381d5-122.08.1.r240.g1128c29-1
telepathy-kde-text-ui22.08.1.r2051.g0e0cac4-122.08.1.r2054.ga039193-1
threadweaver5.98.0.r555.gf2d78a3-15.98.0.r556.g0e5bb54-1
tokodon 22.06.r39.gfb56fe5-1 22.09.r2.g8af1206-1
umbrello22.08.1.r8504.g10ceb99e4-122.08.1.r8506.g1d2e5dcc5-1
vakzination 22.06.r50.g0857b8f-1 22.09.r3.g3f2e36b-1
vvave 2.2.0.r5.g6f2e7db-1 2.2.0.r9.g2a92e75-1
xdg-desktop-portal-kde5.25.5.r523.gdd3c2ff-15.25.5.r533.gf6a4a85-1
yakuake22.08.1.r828.gce92c38-122.08.1.r831.gcb1f154-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
