Hello ARM community.
Preparing for our next release, so here’s a bunch of updates.
Plasma 5.24 is here
Some highlights:
- Most of our kernels got updated
- Our Toolchain (gcc, glibc, binutils) have been updated. Did we miss any rebuilds?
- Plasma is now on version 5.24.2
- And KDE Frameworks updated to 5.91
- Gnome is updated to 41.4
- Firefox also got updated to 97.0.1
- And Thunderbird is updated to 91.6.1
- And Plasma Mobile Gear applications have been updated to 22.02
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Thu Feb 24 21:53:49 CET 2022)
- arm-testing community aarch64: 840 new and 795 removed package(s)
- arm-testing core aarch64: 101 new and 101 removed package(s)
- arm-testing extra aarch64: 723 new and 723 removed package(s)
- arm-testing kde-unstable aarch64: 414 new and 414 removed package(s)
See the entire package list here.
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
