Hello ARM community.
Preparing for our next release, so here’s a bunch of updates.
Signal Desktop is now available!
Some highlights:
- Most of our kernels got updated
- LibreOffice got updated to 7.2.5 (still) and 7.3.0 (fresh)
- Our First run setup Calamares got updated to 3.2.51
- Signal Desktop is now available
- Also Telegram Desktop got updated to 3.5.0
- Element Desktop also got updated to 1.10.1
- And KDE Gear Applications have been updated to 21.12.2
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Sun Feb 6 09:29:28 CET 2022)
- arm-testing community aarch64: 469 new and 466 removed package(s)
- arm-testing core aarch64: 51 new and 47 removed package(s)
- arm-testing extra aarch64: 639 new and 638 removed package(s)
- arm-testing kde-unstable aarch64: 306 new and 312 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-01-30 2022-02-06
chatty 0.6.0-2 0.6.0+32+g1edc7e01-1
code 1.63.2-1 1.64.0-1
electron 16.0.8-1 17.0.0-1
element-desktop 1.9.9-1 1.10.1-1
element-web 1.9.9-1 1.10.1-1
feedbackd 0.0.0+git20211018-1 0.0.0+git20211018-3
foot 1.9.2-4 -
foot-terminfo 1.9.2-4 -
gnome-calls42beta1+10+g12ac809-142beta1+55+g3fe9765-1
maliit-framework 2.1.1-1.0 -
mmsd-tng 1.7+6+g3810466-1 1.8-1
phoc 0.12.0-2 0.12.0+5+ga549c53-1
phosh 0.15.0+19+g5f81a92-1 0.15.0+34+g8770ccf-1
pico-wizard-bigscreen-scripts r158.fc8d499-2 r163.52a17c8-2
pico-wizard-git r158.fc8d499-2 r163.52a17c8-2
pico-wizard-plamo-scripts r158.fc8d499-2 r163.52a17c8-2
pinephone-manjaro-tweaks 20220126-1 20220202-2
pinephone-post-install 20220116-1 20220204-1
pinephonepro-manjaro-tweaks 20220126-1 20220202-2
pinephonepro-post-install 20220122-1 20220205-1
rpi-eeprom 20220124-1 20220131-1
yt-dlp 2022.01.21-1 -
electron16 - 16.0.8-1
signal-desktop - 5.30.0-1
:: Different sync package(s) in repository community aarch64
absl-py 0.14.1-3 1.0.0-1
adriconf 2.4.1-3 2.5.0-1
aliyun-cli 3.0.101-1 3.0.107-1
ansible 5.2.0-1 5.3.0-1
ansible-core 2.12.1-1 2.12.2-1
arcus 4.13.0-1 4.13.1-1
at 3.2.2-1 3.2.4-1
atool 0.39.0-7 -
avrdude 1:6.3-7 1:6.4-1
aws-cli 1.22.38-1 1.22.47-1
bchunk 1.2.2-5 1.2.2-6
bctoolbox 5.0.66-1 5.0.67-1
beaver 0.4.1-5 -
blender 17:3.0.1-1 17:3.0.1-2
bonnie++ 2.00a-1 2.00a-2
bottom 0.6.6-1 0.6.8-1
buildah 1.24.0-1 1.24.1-1
bzrtp 5.0.66-1 5.0.67-1
calibre 5.35.0-1 5.36.0-1
camlp4 4.13+1-1 4.13+1-2
cargo-release 0.19.4-1 0.20.1-1
ccid 1.4.36-1 1.5.0-1
chezmoi 2.10.1-1 2.11.0-1
cinnamon-control-center 5.2.1-4 5.2.1-5
clojure 1.10.3.1069-1 1.10.3.1075-1
cockpit 261-1 262-1
cockpit-pcp 261-1 262-1
cockpit-podman 40-1 41-1
codec2 1:1.0.3-1 1:1.0.3-2
coin-or-asl 1.4.4-1 2.0.0-1
coin-or-cbc 2.10.7-1 2.10.7-3
coin-or-cgl 0.60.4-1 0.60.5-1
coin-or-clp 1.17.7-1 1.17.7-2
coin-or-mp 1.8.4-2 1.8.4-4
containers-common 0.47.1-1 0.47.2-1
copr-cli 1.97-1 1.98-1
cppcheck 2.6.3-1 2.7-1
cryfs 0.11.1-1 0.11.1-2
cura 4.13.0-1 4.13.1-1
cura-binary-data 4.13.0-1 4.13.1-1
curaengine 4.13.0-1 4.13.1-1
cutefish-core 0.5-1 0.7-1
dark-reader 4.9.43-1 4.9.45-1
dart-sass 1.49.0-1 1.49.6-1
dbmate 1.13.0-1 1.14.0-1
deheader 1.7-1 1.8-1
diffoscope 202-1 203-1
duf 0.7.0-1 0.8.0-1
dvgrab 3.5-9 3.5-12
erlang-cl 1.2.4-3 1.2.4-4
fcft 2.5.1-2 3.0.0-1
fcitx5 5.0.13-1 5.0.14-1
filezilla 3.57.0-1 3.57.0-2
firefox-dark-reader 4.9.43-1 4.9.45-1
firefox-decentraleyes 2.0.16-2 2.0.17-1
fishfight 0.3-2 0.4-1
fishui 0.5-1 0.7-1
flameshot 0.10.2-2 11.0.0-4
freecad 0.19.2-5 0.19.3-12
freemind 1.0.1-5 -
fuse-overlayfs 1.8.1-1 1.8.2-1
gamescope 3.11.0beta4-1 3.11.0beta6-1
gauche 0.9.11-1 0.9.11-2
gdal 3.4.0-2 3.4.0-3
gdmap 0.8.1-6 -
gif2png 3.0.0-2 3.0.0-3
gimagereader-common 3.4.0-1 3.4.0-2
gimagereader-gtk 3.4.0-1 3.4.0-2
gimagereader-qt 3.4.0-1 3.4.0-2
gitea 1.15.10-1 1.15.11-1
github-cli 2.4.0-1 2.5.0-1
go-yq 4.18.1-1 4.19.1-1
goaccess 1.5.4-1 1.5.5-1
goldendict 1.5.0RC2-9 -
gsmartcontrol 1.1.3-3 1.1.4-1
hardinfo 0.5.1.816.g877ea2b-2 -
helvum 0.3.3-1 0.3.4-1
himalaya 0.5.1-1 0.5.4-1
i3status-rust 0.21.2-1 0.21.4-1
igsc 0.2.4-2 0.2.4-3
innernet 1.5.2-1 1.5.3-1
intel-metee 3.1.2-1 3.1.2-2
intel-metee-doc 3.1.2-1 3.1.2-2
io 2017.09.06-4 2017.09.06-5
ipv6calc 4.0.0-1 4.0.1-1
iwd 1.23-1 1.24-1
jenkins 2.332-1 2.333-1
jmol 14.32.15-1 14.32.20-1
josm 18360-1 18360-2
jsmol 14.32.15-1 14.32.20-1
juce 6.1.5-1 6.1.5-2
juce-docs 6.1.5-1 6.1.5-2
jupyter-notebook 6.4.7-1 6.4.8-1
jupyter-server 1.13.4-1 1.13.5-1
jupyterlab 3.2.8-1 3.2.9-1
just 0.10.5-1 0.10.7-1
kitty 0.24.1-1 0.24.2-1
kitty-shell-integration 0.24.1-1 0.24.2-1
kitty-terminfo 0.24.1-1 0.24.2-1
kiwix-desktop 2.1.0-1 2.1.0-2
kiwix-tools 3.2.0-1 3.2.0-2
lesspipe 2.01-1 2.02-1
libblastrampoline 4.0.0-2 5.0.1-1
libcss 0.9.1-2 0.9.1-3
libfilezilla 0.35.0-1 0.36.0-1
libfreexl 1.0.6-1 1.0.6-2
libkeccak 1.3-1 1.3.1-1
libkiwix 10.0.0-1 10.0.1-1
libluv 1.42.0_1-1 1.43.0_0-1
libmodulemd 2.13.0-1 2.14.0-1
libnsbmp 0.1.6-2 0.1.6-3
libnsgif 0.2.1-4 0.2.1-5
libquicktime 1.2.4-25 -
libtg_owt 0.git10.6708e0d-2 0.git11.1fd131d-1
libvirt 1:8.0.0-1 1:8.0.0-2
libvirt-storage-gluster 1:8.0.0-1 1:8.0.0-2
libvirt-storage-iscsi-direct 1:8.0.0-1 1:8.0.0-2
lua-luv 1.42.0_1-1 1.43.0_0-1
lua51-luv 1.42.0_1-1 1.43.0_0-1
lua52-luv 1.42.0_1-1 1.43.0_0-1
lua53-lgi 0.9.2-4.1 0.9.2-7
lua53-luv 1.42.0_1-1 1.43.0_0-1
lxc 1:4.0.11-2 1:4.0.12-1
lxcfs 4.0.11-1 4.0.12-1
maliit-framework 2.1.1-1 2.1.1-2
mame 0.239-2 0.240-1
mame-tools 0.239-2 0.240-1
mate-panel 1.26.1-1 1.26.2-1
mediastreamer 5.0.66-1 5.0.67-1
minetest 5.4.1-1 5.5.0-1
minetest-common 5.4.1-1 5.5.0-1
minetest-server 5.4.1-1 5.5.0-1
minitube 3.9.2-1 3.9.3-1
mixxx 2.3.1-3 2.3.2-1
moneymanagerex 1.3.3-3 -
mosquitto 2.0.14-2 2.0.14-3
mumble 1.4.230-2 1.4.230-3
murmur 1.4.230-2 1.4.230-3
mvt 1.4.5-1 1.4.10-1
nemo-audio-tab 5.2.0-1 5.2.0-2
nemo-emblems 5.2.0-1 5.2.0-2
nemo-fileroller 5.2.0-1 5.2.0-2
nemo-image-converter 5.2.0-1 5.2.0-2
nemo-pastebin 5.2.0-1 5.2.0-2
nemo-preview 5.2.0-1 5.2.0-2
nemo-python 5.2.0-1 5.2.0-2
nemo-seahorse 5.2.0-1 5.2.0-2
nemo-share 5.2.0-1 5.2.0-2
nemo-terminal 5.2.0-1 5.2.0-2
ngspice 35-1 36-1
nodejs-lts-erbium 12.22.9-1 12.22.10-1
nodejs-lts-fermium 14.18.3-1 14.19.0-1
nomad 1.2.4-1 1.2.5-1
npm 8.4.0-1 8.4.1-1
npm-check-updates 12.2.0-1 12.2.1-1
nrpe 4.0.3-1 4.0.3-2
nuitka 0.6.19.3-1 0.6.19.6-1
nvchecker 2.5-2 2.6.1-1
ocrdesktop 3.0-2 4.0-1
openapi-generator 5.3.1-1 5.4.0-1
ortp 5.0.66-1 5.0.67-1
osbuild 46-1 47-1
papirus-icon-theme 20220101-1 20220204-1
pcp 5.3.5-2 5.3.6-1
pcp-gui 5.3.5-2 5.3.6-1
pcp-pmda-activemq 5.3.5-2 5.3.6-1
pcp-pmda-bcc 5.3.5-2 5.3.6-1
pcp-pmda-bind2 5.3.5-2 5.3.6-1
pcp-pmda-bpftrace 5.3.5-2 5.3.6-1
pcp-pmda-libvirt 5.3.5-2 5.3.6-1
pcp-pmda-mysql 5.3.5-2 5.3.6-1
pcp-pmda-nginx 5.3.5-2 5.3.6-1
pcp-pmda-nutcracker 5.3.5-2 5.3.6-1
pcp-pmda-openmetrics 5.3.5-2 5.3.6-1
pcp-pmda-podman 5.3.5-2 5.3.6-1
pcp-pmda-postgresql 5.3.5-2 5.3.6-1
pcp-pmda-snmp 5.3.5-2 5.3.6-1
plocate 1.1.14-2 1.1.15-1
powerdns-recursor 4.6.0-2 4.6.0-3
promscale 0.8.0-1 0.9.0-1
pybind11 2.9.0-1 2.9.1-1
pynac 0.7.29-4 -
pyright 1.1.216-1 1.1.218-1
python-aresponses 2.1.4-3 2.1.5-1
python-autobahn 21.11.1-3 22.1.1-1
python-boto3 1.20.38-1 1.20.47-1
python-botocore 1.23.38-1 1.23.47-1
python-breathe 4.31.0-3 4.32.0-1
python-cbor2 5.4.2-3 5.4.2.post1-1
python-cfn-lint 0.57.0-1 0.58.0-1
python-cliff 3.9.0-1 3.10.0-1
python-cmarkgfm 0.6.0-4 0.7.0-1
python-copr 1.114-3 1.115-1
python-cvxopt 1.2.7-4 1.2.8-1
python-database-knotinfo 2022.1.3-1 2022.2.1-1
python-django-allauth 0.47.0-2 0.48.0-1
python-django-classy-tags 3.0.0-1 3.0.1-1
python-django-debug-toolbar 3.2.2-3 3.2.4-1
python-django-sekizai 3.0.0-1 3.0.1-1
python-entrypoints 0.3-8 0.4-1
python-flake8-black 0.2.2-2 0.2.4-1
python-fonttools 4.29.0-1 4.29.1-1
python-gdal 3.4.0-2 3.4.0-3
python-google-api-core 2.4.0-2 2.5.0-1
python-gphoto2 2.2.4-4 2.3.2-1
python-identify 2.4.5-1 2.4.8-1
python-inflect 5.3.0-4 5.4.0-1
python-ipykernel 6.6.0-2 6.8.0-1
python-jupyter_client 7.1.0-4 7.1.2-1
python-matrix-nio 0.18.7-3 0.19.0-1
python-moto 2.3.2-1 3.0.2-1
python-natsort 8.0.2-1 8.1.0-1
python-phonenumbers 8.12.41-1 8.12.42-1
python-pillow 9.0.0-1 9.0.1-1
python-proxy.py 2.3.1-4 2.4.0-1
python-pybtex 0.24.0-3 0.24.0-4
python-pycryptodome 3.12.0-1 3.14.1-1
python-pyicu 2.8-3 2.8.1-1
python-pymupdf 1.19.4-1 1.19.5-1
python-pytest-responsemock 1.0.1-3 1.1.0-1
python-pywlroots 0.15.3-1 0.15.7-2
python-qtconsole 5.2.1-2 5.2.2-1
python-raven 6.10.0-9 6.10.0-10
python-ruamel-yaml 0.17.19-1 0.17.20-1
python-sphinx-click 3.0.3-1 3.1.0-1
python-sphobjinv 2.1-3 2.2-1
python-sqlalchemy-continuum 1.3.11-3 1.3.12-1
python-tomlkit 0.8.0-1 0.9.0-1
python-websocket-client 0.59.0-3 1.2.3-2
python-wiktionaryparser 0.0.97.20210613-2 0.0.97.20210613-3
python-xcffib 0.11.1-3 0.11.1-4
python-ziamath 0.3-3 0.4-1
python2-pycryptodome 3.12.0-1 3.14.1-1
pyzo 4.11.4-2 4.12.0-1
qtspell 0.9.0-1 1.0.1-1
radicale 3.1.3-1 3.1.4-1
rekor 0.4.0-1 0.5.0-1
reprotest 0.7.18-2 0.7.19-1
rkcommon 1.8.0-2 1.8.0-3
rnote 0.3.0-1 0.3.3-1
rofimoji 5.3.0-2 5.4.0-1
ruby-pg 1.2.3-1 1.3.1-1
rust-analyzer 20220124-1 20220131-1
scrcpy 1.21-2 1.22-1
scribus 1.5.8-1 1.5.8-2
serverless 3.0.1-1 3.1.1-1
shairport-sync 3.3.8-1 3.3.9-1
shotcut 21.12.24-1 22.01.30-2
sl 5.02-6 5.05-2
step-ca 0.18.0-1 0.18.1-1
step-cli 0.18.0-1 0.18.1-1
streamlink 2.4.0-2 3.1.1-1
syncthing 1.18.6-2 1.19.0-1
syncthing-relaysrv 1.18.6-2 1.19.0-1
teensy-loader-cli 2.1-4 2.2-1
telegram-desktop 3.4.8-1 3.5.0-1
terraform 1.1.4-1 1.1.5-1
tesseract 5.0.1-2 5.0.1-3
tesseract-data-afr 2:4.1.0-2 2:4.1.0-3
tesseract-data-amh 2:4.1.0-2 2:4.1.0-3
tesseract-data-ara 2:4.1.0-2 2:4.1.0-3
tesseract-data-asm 2:4.1.0-2 2:4.1.0-3
tesseract-data-aze 2:4.1.0-2 2:4.1.0-3
tesseract-data-aze_cyrl 2:4.1.0-2 2:4.1.0-3
tesseract-data-bel 2:4.1.0-2 2:4.1.0-3
tesseract-data-ben 2:4.1.0-2 2:4.1.0-3
tesseract-data-bod 2:4.1.0-2 2:4.1.0-3
tesseract-data-bos 2:4.1.0-2 2:4.1.0-3
tesseract-data-bre 2:4.1.0-2 2:4.1.0-3
tesseract-data-bul 2:4.1.0-2 2:4.1.0-3
tesseract-data-cat 2:4.1.0-2 2:4.1.0-3
tesseract-data-ceb 2:4.1.0-2 2:4.1.0-3
tesseract-data-ces 2:4.1.0-2 2:4.1.0-3
tesseract-data-chi_sim 2:4.1.0-2 2:4.1.0-3
tesseract-data-chi_tra 2:4.1.0-2 2:4.1.0-3
tesseract-data-chr 2:4.1.0-2 2:4.1.0-3
tesseract-data-cos 2:4.1.0-2 2:4.1.0-3
tesseract-data-cym 2:4.1.0-2 2:4.1.0-3
tesseract-data-dan 2:4.1.0-2 2:4.1.0-3
tesseract-data-dan_frak 2:4.1.0-2 2:4.1.0-3
tesseract-data-deu 2:4.1.0-2 2:4.1.0-3
tesseract-data-deu_frak 2:4.1.0-2 2:4.1.0-3
tesseract-data-div 2:4.1.0-2 2:4.1.0-3
tesseract-data-dzo 2:4.1.0-2 2:4.1.0-3
tesseract-data-ell 2:4.1.0-2 2:4.1.0-3
tesseract-data-eng 2:4.1.0-2 2:4.1.0-3
tesseract-data-enm 2:4.1.0-2 2:4.1.0-3
tesseract-data-epo 2:4.1.0-2 2:4.1.0-3
tesseract-data-equ 2:4.1.0-2 2:4.1.0-3
tesseract-data-est 2:4.1.0-2 2:4.1.0-3
tesseract-data-eus 2:4.1.0-2 2:4.1.0-3
tesseract-data-fao 2:4.1.0-2 2:4.1.0-3
tesseract-data-fas 2:4.1.0-2 2:4.1.0-3
tesseract-data-fil 2:4.1.0-2 2:4.1.0-3
tesseract-data-fin 2:4.1.0-2 2:4.1.0-3
tesseract-data-fra 2:4.1.0-2 2:4.1.0-3
tesseract-data-frk 2:4.1.0-2 2:4.1.0-3
tesseract-data-frm 2:4.1.0-2 2:4.1.0-3
tesseract-data-fry 2:4.1.0-2 2:4.1.0-3
tesseract-data-gla 2:4.1.0-2 2:4.1.0-3
tesseract-data-gle 2:4.1.0-2 2:4.1.0-3
tesseract-data-glg 2:4.1.0-2 2:4.1.0-3
tesseract-data-grc 2:4.1.0-2 2:4.1.0-3
tesseract-data-guj 2:4.1.0-2 2:4.1.0-3
tesseract-data-hat 2:4.1.0-2 2:4.1.0-3
tesseract-data-heb 2:4.1.0-2 2:4.1.0-3
tesseract-data-hin 2:4.1.0-2 2:4.1.0-3
tesseract-data-hrv 2:4.1.0-2 2:4.1.0-3
tesseract-data-hun 2:4.1.0-2 2:4.1.0-3
tesseract-data-hye 2:4.1.0-2 2:4.1.0-3
tesseract-data-iku 2:4.1.0-2 2:4.1.0-3
tesseract-data-ind 2:4.1.0-2 2:4.1.0-3
tesseract-data-isl 2:4.1.0-2 2:4.1.0-3
tesseract-data-ita 2:4.1.0-2 2:4.1.0-3
tesseract-data-ita_old 2:4.1.0-2 2:4.1.0-3
tesseract-data-jav 2:4.1.0-2 2:4.1.0-3
tesseract-data-jpn 2:4.1.0-2 2:4.1.0-3
tesseract-data-kan 2:4.1.0-2 2:4.1.0-3
tesseract-data-kat 2:4.1.0-2 2:4.1.0-3
tesseract-data-kat_old 2:4.1.0-2 2:4.1.0-3
tesseract-data-kaz 2:4.1.0-2 2:4.1.0-3
tesseract-data-khm 2:4.1.0-2 2:4.1.0-3
tesseract-data-kir 2:4.1.0-2 2:4.1.0-3
tesseract-data-kmr 2:4.1.0-2 2:4.1.0-3
tesseract-data-kor 2:4.1.0-2 2:4.1.0-3
tesseract-data-kor_vert 2:4.1.0-2 2:4.1.0-3
tesseract-data-lao 2:4.1.0-2 2:4.1.0-3
tesseract-data-lat 2:4.1.0-2 2:4.1.0-3
tesseract-data-lav 2:4.1.0-2 2:4.1.0-3
tesseract-data-lit 2:4.1.0-2 2:4.1.0-3
tesseract-data-ltz 2:4.1.0-2 2:4.1.0-3
tesseract-data-mal 2:4.1.0-2 2:4.1.0-3
tesseract-data-mar 2:4.1.0-2 2:4.1.0-3
tesseract-data-mkd 2:4.1.0-2 2:4.1.0-3
tesseract-data-mlt 2:4.1.0-2 2:4.1.0-3
tesseract-data-mon 2:4.1.0-2 2:4.1.0-3
tesseract-data-mri 2:4.1.0-2 2:4.1.0-3
tesseract-data-msa 2:4.1.0-2 2:4.1.0-3
tesseract-data-mya 2:4.1.0-2 2:4.1.0-3
tesseract-data-nep 2:4.1.0-2 2:4.1.0-3
tesseract-data-nld 2:4.1.0-2 2:4.1.0-3
tesseract-data-nor 2:4.1.0-2 2:4.1.0-3
tesseract-data-oci 2:4.1.0-2 2:4.1.0-3
tesseract-data-ori 2:4.1.0-2 2:4.1.0-3
tesseract-data-osd 2:4.1.0-2 2:4.1.0-3
tesseract-data-pan 2:4.1.0-2 2:4.1.0-3
tesseract-data-pol 2:4.1.0-2 2:4.1.0-3
tesseract-data-por 2:4.1.0-2 2:4.1.0-3
tesseract-data-pus 2:4.1.0-2 2:4.1.0-3
tesseract-data-que 2:4.1.0-2 2:4.1.0-3
tesseract-data-ron 2:4.1.0-2 2:4.1.0-3
tesseract-data-rus 2:4.1.0-2 2:4.1.0-3
tesseract-data-san 2:4.1.0-2 2:4.1.0-3
tesseract-data-sin 2:4.1.0-2 2:4.1.0-3
tesseract-data-slk 2:4.1.0-2 2:4.1.0-3
tesseract-data-slk_frak 2:4.1.0-2 2:4.1.0-3
tesseract-data-slv 2:4.1.0-2 2:4.1.0-3
tesseract-data-snd 2:4.1.0-2 2:4.1.0-3
tesseract-data-spa 2:4.1.0-2 2:4.1.0-3
tesseract-data-spa_old 2:4.1.0-2 2:4.1.0-3
tesseract-data-sqi 2:4.1.0-2 2:4.1.0-3
tesseract-data-srp 2:4.1.0-2 2:4.1.0-3
tesseract-data-srp_latn 2:4.1.0-2 2:4.1.0-3
tesseract-data-sun 2:4.1.0-2 2:4.1.0-3
tesseract-data-swa 2:4.1.0-2 2:4.1.0-3
tesseract-data-swe 2:4.1.0-2 2:4.1.0-3
tesseract-data-syr 2:4.1.0-2 2:4.1.0-3
tesseract-data-tam 2:4.1.0-2 2:4.1.0-3
tesseract-data-tat 2:4.1.0-2 2:4.1.0-3
tesseract-data-tel 2:4.1.0-2 2:4.1.0-3
tesseract-data-tgk 2:4.1.0-2 2:4.1.0-3
tesseract-data-tgl 2:4.1.0-2 2:4.1.0-3
tesseract-data-tha 2:4.1.0-2 2:4.1.0-3
tesseract-data-tir 2:4.1.0-2 2:4.1.0-3
tesseract-data-ton 2:4.1.0-2 2:4.1.0-3
tesseract-data-tur 2:4.1.0-2 2:4.1.0-3
tesseract-data-uig 2:4.1.0-2 2:4.1.0-3
tesseract-data-ukr 2:4.1.0-2 2:4.1.0-3
tesseract-data-urd 2:4.1.0-2 2:4.1.0-3
tesseract-data-uzb 2:4.1.0-2 2:4.1.0-3
tesseract-data-uzb_cyrl 2:4.1.0-2 2:4.1.0-3
tesseract-data-vie 2:4.1.0-2 2:4.1.0-3
tesseract-data-yid 2:4.1.0-2 2:4.1.0-3
tesseract-data-yor 2:4.1.0-2 2:4.1.0-3
texstudio 4.2.1-1 4.2.1-2
thunderbird-dark-reader 4.9.43-1 4.9.45-1
tipp10 3.2.1-1 3.3.0-1
transcode 1.1.7-39 1.1.7-40
translate-toolkit 3.5.1-1 3.5.1-3
tt-rss 2:r11216.56fd06d61-2 2:r11220.b59bde7b4-1
ttc-iosevka 11.2.6-1 11.2.7-1
ttc-iosevka-aile 11.2.6-1 11.2.7-1
ttc-iosevka-curly 11.2.6-1 11.2.7-1
ttc-iosevka-curly-slab 11.2.6-1 11.2.7-1
ttc-iosevka-etoile 11.2.6-1 11.2.7-1
ttc-iosevka-slab 11.2.6-1 11.2.7-1
ttc-iosevka-ss01 11.2.6-1 11.2.7-1
ttc-iosevka-ss02 11.2.6-1 11.2.7-1
ttc-iosevka-ss03 11.2.6-1 11.2.7-1
ttc-iosevka-ss04 11.2.6-1 11.2.7-1
ttc-iosevka-ss05 11.2.6-1 11.2.7-1
ttc-iosevka-ss06 11.2.6-1 11.2.7-1
ttc-iosevka-ss07 11.2.6-1 11.2.7-1
ttc-iosevka-ss08 11.2.6-1 11.2.7-1
ttc-iosevka-ss09 11.2.6-1 11.2.7-1
ttc-iosevka-ss10 11.2.6-1 11.2.7-1
ttc-iosevka-ss11 11.2.6-1 11.2.7-1
ttc-iosevka-ss12 11.2.6-1 11.2.7-1
ttc-iosevka-ss13 11.2.6-1 11.2.7-1
ttc-iosevka-ss14 11.2.6-1 11.2.7-1
ttc-iosevka-ss15 11.2.6-1 11.2.7-1
ttc-iosevka-ss16 11.2.6-1 11.2.7-1
ttc-iosevka-ss17 11.2.6-1 11.2.7-1
ttc-iosevka-ss18 11.2.6-1 11.2.7-1
tuxcmd-modules 0.6.70-6 -
udiskie 2.4.0-1 2.4.1-1
uranium 4.13.0-1 4.13.1-1
usbview 2.0-6 3.0-1
uwsgi 2.0.20-4 2.0.20-6
uwsgi-plugin-cgi 2.0.20-4 2.0.20-6
uwsgi-plugin-lua51 2.0.20-4 2.0.20-6
uwsgi-plugin-notfound 2.0.20-4 2.0.20-6
uwsgi-plugin-php 2.0.20-4 2.0.20-6
uwsgi-plugin-php7 2.0.20-4 2.0.20-6
uwsgi-plugin-psgi 2.0.20-4 2.0.20-6
uwsgi-plugin-python 2.0.20-4 2.0.20-6
uwsgi-plugin-rack 2.0.20-4 2.0.20-6
uwsgi-plugin-webdav 2.0.20-4 2.0.20-6
uwsgi-plugin-zabbix 2.0.20-4 2.0.20-6
v2ray-domain-list-community 20220124140856-1 20220201175515-1
v2ray-geoip 202201270031-1 202202030030-1
vaultwarden 1.23.1-2 1.24.0-1
vaultwarden-web 2.25.1-1 2.25.1.b-2
vim-himalaya 0.5.1-1 0.5.4-1
vscode-css-languageserver 1.63.0-2 1.64.0-1
vscode-html-languageserver 1.63.0-2 1.64.0-1
vscode-json-languageserver 1.63.0-2 1.64.0-1
watchexec 1.18.4-1 1.18.5-1
webp-pixbuf-loader 0.0.3-1 0.0.4-1
weston 9.0.0-1 10.0.0-1
xplc 0.3.13-8 0.3.13-9
xplr 0.17.1-1 0.17.2-1
yaml-language-server 1.3.0-1 1.4.0-1
yt-dlp 2022.01.21-1 2022.02.04-1
bat-extras -2021.08.21.r1.g8ad00bd-1
cargo-msrv - 0.14.1-1
foot - 1.11.0-1
foot-terminfo - 1.11.0-1
fuzzel - 1.7.0-1
kooha - 2.0.1-3
libdispatch - 5.5.0-1
lua-lgi - 0.9.2-7
luajit -2.1.0.beta3.r384.g1d7b5029-1
otf-crimson - 0.800-1
otf-crimson-pro - 1.003-1
tesseract-data-jpn_vert - 2:4.1.0-3
ttf-crimson - 0.800-1
ttf-crimson-pro - 1.003-1
ttf-crimson-pro-variable - 1.003-1
:: Different overlay package(s) in repository core aarch64
fakeroot-qemu 1.26-1 1.27-1
linux 5.16.4-1 5.16.7-1
linux-clockworkpi-a06 5.16.4-1 5.16.7-1
linux-clockworkpi-a06-headers 5.16.4-1 5.16.7-1
linux-headers 5.16.4-1 5.16.7-1
linux-lts 5.15.18-1 5.15.21-1
linux-lts-headers 5.15.18-1 5.15.21-1
linux-pinephone 5.16.4-1 5.16.5-2
linux-pinephone-headers 5.16.4-1 5.16.5-2
linux-pinephonepro 5.16.4-2 5.16.5-4
linux-pinephonepro-headers 5.16.4-2 5.16.5-4
linux-rc 5.17.rc2-1 5.17.rc2-2
linux-rc-headers 5.17.rc2-1 5.17.rc2-2
linux-rpi4 5.10.94-1 5.10.95-1
linux-rpi4-headers 5.10.94-1 5.10.95-1
linux-rpi4-mainline 5.16.3-1 5.16.4-1
linux-rpi4-mainline-headers 5.16.3-1 5.16.4-1
linux-rpi4-rc 5.17.rc1-1 5.17.rc2-1
linux-rpi4-rc-headers 5.17.rc1-1 5.17.rc2-1
boot-generic - 20220205-1
uboot-radxa-zero - 2021.07-3
uboot-radxa-zero2 - 2021.07-3
uboot-rock3-a - 2022.01.rc4-1
:: Different sync package(s) in repository core aarch64
acl 2.3.1-1 2.3.1-2
attr 2.5.1-1 2.5.1-2
audit 3.0.6-5 3.0.7-1
cryptsetup 2.4.3-1 2.4.3-2
curl 7.81.0-1 7.81.0-2
debuginfod 0.186-2 0.186-4
dosfstools 4.2-1 4.2-2
e2fsprogs 1.46.5-1 1.46.5-2
elfutils 0.186-2 0.186-4
expat 2.4.3-1 2.4.4-1
fuse2fs 1.46.5-1 1.46.5-2
json-c 0.15-2 0.15-3
kmod 29-1 29-2
libarchive 3.5.2-2 3.5.2-3
libelf 0.186-2 0.186-4
libusb 1.0.24-2 1.0.25-2
libxcrypt 4.4.27-1 4.4.28-1
popt 1.18-2 1.18-3
python-audit 3.0.6-5 3.0.7-1
readline 8.1.001-1 8.1.002-1
shadow 4.8.1-4 4.11.1-1
sudo 1.9.8.p2-3 1.9.9-2
systemd 250.3-1 250.3-2
systemd-libs 250.3-1 250.3-2
systemd-resolvconf 250.3-1 250.3-2
systemd-sysvcompat 250.3-1 250.3-2
util-linux 2.37.3-1 2.37.3-2
util-linux-libs 2.37.3-1 2.37.3-2
:: Different overlay package(s) in repository extra aarch64
calamares 3.2.48-2 3.2.51-1
mesa-git22.0.0_devel.149534.708a33d1328-122.1.0_devel.149852.945a1e0b8cd-1
okular 21.12.1-1 21.12.2-1
:: Different sync package(s) in repository extra aarch64
akonadi 21.12.1-1 21.12.2-1
akonadi-calendar 21.12.1-1 21.12.2-1
akonadi-calendar-tools 21.12.1-1 21.12.2-1
akonadi-contacts 21.12.1-1 21.12.2-1
akonadi-import-wizard 21.12.1-1 21.12.2-1
akonadi-mime 21.12.1-1 21.12.2-1
akonadi-notes 21.12.1-1 21.12.2-1
akonadi-search 21.12.1-1 21.12.2-1
akonadiconsole 21.12.1-1 21.12.2-1
akregator 21.12.1-1 21.12.2-1
alsa-card-profiles 1:0.3.44-1 1:0.3.45-1
analitza 21.12.1-1 21.12.2-1
apparmor 3.0.3-2 3.0.3-3
archboot-arm 2022.01-89 2022.02-17
archinstall 2.3.0-2 2.3.1-1
ark 21.12.1-1 21.12.2-1
artikulate 21.12.1-1 21.12.2-1
audiocd-kio 21.12.1-1 21.12.2-1
baloo-widgets 21.12.1-1 21.12.2-1
blinken 21.12.1-1 21.12.2-1
bomber 21.12.1-1 21.12.2-1
bovo 21.12.1-1 21.12.2-1
brltty 6.4-8 6.4-9
calendarsupport 21.12.1-1 21.12.2-1
calligra 3.2.1-27 3.2.1-29
cantor 21.12.1-1 21.12.2-1
cervisia 21.12.1-1 21.12.2-1
chromium 97.0.4692.99-2 98.0.4758.80-1
composer 2.2.5-1 2.2.6-1
digikam 7.5.0-1 7.5.0-3
dolphin 21.12.1-1 21.12.2-1
dolphin-plugins 21.12.1-1 21.12.2-1
dragon 21.12.1-1 21.12.2-1
efitools 1.9.2-3 1.9.2-4
elisa 21.12.1-1 21.12.2-1
eventviews 21.12.1-1 21.12.2-1
falkon 3.1.0-16 3.2.0-2
ffmpegthumbs 21.12.1-1 21.12.2-1
fftw 3.3.10-1 3.3.10-2
filelight 21.12.1-1 21.12.2-1
fontconfig 2:2.13.94-2 2:2.13.96-1
freetds 1.3.6-1 1.3.7-1
ghostpcl 9.55.0-3 9.55.0-4
ghostscript 9.55.0-3 9.55.0-4
ghostxps 9.55.0-3 9.55.0-4
gnuplot 5.4.3-1 5.4.3-2
granatier 21.12.1-1 21.12.2-1
grantlee-editor 21.12.1-1 21.12.2-1
grantleetheme 21.12.1-1 21.12.2-1
gst-plugin-pipewire 1:0.3.44-1 1:0.3.45-1
gtk-update-icon-cache 1:4.6.0-2 1:4.6.0-3
gtk4 1:4.6.0-2 1:4.6.0-3
gtk4-demos 1:4.6.0-2 1:4.6.0-3
gtk4-docs 1:4.6.0-2 1:4.6.0-3
gwenview 21.12.1-1 21.12.2-1
harfbuzz 3.2.0-1 3.3.1-1
harfbuzz-icu 3.2.0-1 3.3.1-1
imagemagick 7.1.0.21-1 7.1.0.23-1
imagemagick-doc 7.1.0.21-1 7.1.0.23-1
incidenceeditor 21.12.1-1 21.12.2-1
inkscape 1.1.1-7 1.1.1-8
itinerary 21.12.1-1 21.12.2-1
jack-example-tools 1-3 1-4
jack2 1.9.20-3 1.9.20-4
jack2-dbus 1.9.20-3 1.9.20-4
jack2-docs 1.9.20-3 1.9.20-4
juk 21.12.1-1 21.12.2-1
k3b 1:21.12.1-1 1:21.12.2-1
kaccounts-integration 21.12.1-1 21.12.2-1
kaccounts-providers 21.12.1-1 21.12.2-1
kaddressbook 21.12.1-1 21.12.2-1
kajongg 21.12.1-1 21.12.2-1
kalarm 21.12.1-1 21.12.2-1
kalarmcal 21.12.1-1 21.12.2-1
kalgebra 21.12.1-1 21.12.2-1
kalzium 21.12.1-1 21.12.2-1
kamera 21.12.1-1 21.12.2-1
kamoso 21.12.1-1 21.12.2-1
kanagram 21.12.1-1 21.12.2-1
kapman 21.12.1-1 21.12.2-1
kapptemplate 21.12.1-1 21.12.2-1
kate 21.12.1-1 21.12.2-1
katomic 21.12.1-1 21.12.2-1
kbackup 21.12.1-1 21.12.2-1
kblackbox 21.12.1-1 21.12.2-1
kblocks 21.12.1-1 21.12.2-1
kbounce 21.12.1-1 21.12.2-1
kbreakout 21.12.1-1 21.12.2-1
kbruch 21.12.1-1 21.12.2-1
kcachegrind 21.12.1-1 21.12.2-1
kcachegrind-common 21.12.1-1 21.12.2-1
kcalc 21.12.1-1 21.12.2-1
kcalutils 21.12.1-1 21.12.2-1
kcharselect 21.12.1-1 21.12.2-1
kcolorchooser 21.12.1-1 21.12.2-1
kcron 21.12.1-1 21.12.2-1
kde-dev-scripts 21.12.1-1 21.12.2-1
kde-dev-utils 21.12.1-1 21.12.2-1
kdebugsettings 21.12.1-1 21.12.2-1
kdeconnect 21.12.1-1 21.12.2-1
kdeedu-data 21.12.1-1 21.12.2-1
kdegraphics-mobipocket 21.12.1-1 21.12.2-1
kdegraphics-thumbnailers 21.12.1-1 21.12.2-1
kdenetwork-filesharing 21.12.1-1 21.12.2-1
kdenlive 21.12.1-1 21.12.2-1
kdepim-addons 21.12.1-1 21.12.2-1
kdepim-runtime 21.12.1-1 21.12.2-1
kdesdk-kioslaves 21.12.1-1 21.12.2-1
kdesdk-thumbnailers 21.12.1-1 21.12.2-1
kdevelop 21.12.1-1 21.12.2-1
kdevelop-php 21.12.1-1 21.12.2-1
kdf 21.12.1-1 21.12.2-1
kdialog 21.12.1-1 21.12.2-1
kdiamond 21.12.1-1 21.12.2-1
keditbookmarks 21.12.1-1 21.12.2-1
kfind 21.12.1-1 21.12.2-1
kfloppy 21.12.1-1 21.12.2-1
kfourinline 21.12.1-1 21.12.2-1
kgeography 21.12.1-1 21.12.2-1
kget 21.12.1-1 21.12.2-1
kgoldrunner 21.12.1-1 21.12.2-1
kgpg 21.12.1-1 21.12.2-1
khangman 21.12.1-1 21.12.2-1
khelpcenter 21.12.1-1 21.12.2-1
kidentitymanagement 21.12.1-1 21.12.2-1
kig 21.12.1-1 21.12.2-1
kigo 21.12.1-1 21.12.2-1
killbots 21.12.1-1 21.12.2-1
kimageannotator 0.5.3-1 0.5.3-2
kimagemapeditor 21.12.1-1 21.12.2-1
kimap 21.12.1-1 21.12.2-1
kio-extras 21.12.1-1 21.12.2-1
kio-gdrive 21.12.1-1 21.12.2-1
kipi-plugins 21.12.1-1 21.12.2-1
kirigami-gallery 21.12.1-1 21.12.2-1
kiriki 21.12.1-1 21.12.2-1
kiten 21.12.1-1 21.12.2-1
kitinerary 21.12.1-2 21.12.2-1
kjumpingcube 21.12.1-1 21.12.2-1
kldap 21.12.1-1 21.12.2-1
kleopatra 21.12.1-1 21.12.2-1
klettres 21.12.1-1 21.12.2-1
klickety 21.12.1-1 21.12.2-1
klines 21.12.1-1 21.12.2-1
kmag 21.12.1-1 21.12.2-1
kmahjongg 21.12.1-1 21.12.2-1
kmail 21.12.1-1 21.12.2-1
kmail-account-wizard 21.12.1-1 21.12.2-1
kmailtransport 21.12.1-1 21.12.2-1
kmbox 21.12.1-1 21.12.2-1
kmime 21.12.1-1 21.12.2-1
kmines 21.12.1-1 21.12.2-1
kmix 21.12.1-1 21.12.2-1
kmousetool 21.12.1-1 21.12.2-1
kmouth 21.12.1-1 21.12.2-1
kmplot 21.12.1-1 21.12.2-1
knavalbattle 21.12.1-1 21.12.2-1
knetwalk 21.12.1-1 21.12.2-1
knights 21.12.1-1 21.12.2-1
knotes 21.12.1-1 21.12.2-1
kolf 21.12.1-1 21.12.2-1
kollision 21.12.1-1 21.12.2-1
kolourpaint 21.12.1-1 21.12.2-1
kompare 21.12.1-1 21.12.2-1
konqueror 21.12.1-1 21.12.2-1
konquest 21.12.1-1 21.12.2-1
konsole 21.12.1-1 21.12.2-1
kontact 21.12.1-1 21.12.2-1
kontactinterface 21.12.1-1 21.12.2-1
kontrast 21.12.1-1 21.12.2-1
konversation 21.12.1-1 21.12.2-1
kopeninghours 21.12.1-1 21.12.2-1
kopete 21.12.1-1 21.12.2-1
korganizer 21.12.1-1 21.12.2-1
kosmindoormap 21.12.1-1 21.12.2-1
kpat 21.12.1-1 21.12.2-1
kpimtextedit 21.12.1-1 21.12.2-1
kpkpass 21.12.1-1 21.12.2-1
kpmcore 21.12.1-1 21.12.2-1
kpublictransport 21.12.1-1 21.12.2-1
kqtquickcharts 21.12.1-1 21.12.2-1
krdc 21.12.1-1 21.12.2-1
kreversi 21.12.1-1 21.12.2-1
krfb 21.12.1-2 21.12.2-1
krita 5.0.2-2 5.0.2-3
kruler 21.12.1-1 21.12.2-1
kshisen 21.12.1-1 21.12.2-1
ksirk 21.12.1-1 21.12.2-1
ksmtp 21.12.1-1 21.12.2-1
ksnakeduel 21.12.1-1 21.12.2-1
kspaceduel 21.12.1-1 21.12.2-1
ksquares 21.12.1-1 21.12.2-1
ksudoku 21.12.1-1 21.12.2-1
ksystemlog 21.12.1-1 21.12.2-1
kteatime 21.12.1-1 21.12.2-1
ktexteditor 5.90.0-1 5.90.0-2
ktimer 21.12.1-1 21.12.2-1
ktnef 21.12.1-1 21.12.2-1
ktorrent 21.12.1-1 21.12.2-1
ktouch 21.12.1-1 21.12.2-1
ktuberling 21.12.1-1 21.12.2-1
kturtle 21.12.1-1 21.12.2-1
kubrick 21.12.1-1 21.12.2-1
kuserfeedback 1.0.0-1 1.2.0-1
kwalletmanager 21.12.1-1 21.12.2-1
kwave 21.12.1-1 21.12.2-1
kwordquiz 21.12.1-1 21.12.2-1
kwrite 21.12.1-1 21.12.2-1
lcms2 2.12-1 2.13.1-1
ldb 2:2.4.1-4 2:2.4.2-1
libakonadi 21.12.1-1 21.12.2-1
libgravatar 21.12.1-1 21.12.2-1
libixion 0.16.1-9 0.17.0-1
libkcddb 21.12.1-1 21.12.2-1
libkcompactdisc 21.12.1-1 21.12.2-1
libkdcraw 21.12.1-1 21.12.2-1
libkdegames 21.12.1-1 21.12.2-1
libkdepim 21.12.1-1 21.12.2-1
libkeduvocdocument 21.12.1-1 21.12.2-1
libkexiv2 21.12.1-1 21.12.2-1
libkgapi 21.12.1-1 21.12.2-1
libkipi 21.12.1-1 21.12.2-1
libkleo 21.12.1-1 21.12.2-1
libkmahjongg 21.12.1-1 21.12.2-1
libkomparediff2 21.12.1-1 21.12.2-1
libksane 21.12.1-1 21.12.2-1
libksieve 21.12.1-1 21.12.2-1
libktorrent 21.12.1-1 21.12.2-1
libopenmpt 0.6.0-1 0.6.1-1
liborcus 0.16.1-10 0.17.2-1
libplacebo 4.192.0-1 4.192.1-1
libraqm 0.8.0-1 0.9.0-1
libreoffice-fresh 7.2.5-4 7.3.0-4
libreoffice-fresh-af 7.2.5-1 7.3.0-1
libreoffice-fresh-am 7.2.5-1 7.3.0-1
libreoffice-fresh-ar 7.2.5-1 7.3.0-1
libreoffice-fresh-as 7.2.5-1 7.3.0-1
libreoffice-fresh-ast 7.2.5-1 7.3.0-1
libreoffice-fresh-be 7.2.5-1 7.3.0-1
libreoffice-fresh-bg 7.2.5-1 7.3.0-1
libreoffice-fresh-bn 7.2.5-1 7.3.0-1
libreoffice-fresh-bn-in 7.2.5-1 7.3.0-1
libreoffice-fresh-bo 7.2.5-1 7.3.0-1
libreoffice-fresh-br 7.2.5-1 7.3.0-1
libreoffice-fresh-brx 7.2.5-1 7.3.0-1
libreoffice-fresh-bs 7.2.5-1 7.3.0-1
libreoffice-fresh-ca 7.2.5-1 7.3.0-1
libreoffice-fresh-ca-valencia 7.2.5-1 7.3.0-1
libreoffice-fresh-ckb 7.2.5-1 7.3.0-1
libreoffice-fresh-cs 7.2.5-1 7.3.0-1
libreoffice-fresh-cy 7.2.5-1 7.3.0-1
libreoffice-fresh-da 7.2.5-1 7.3.0-1
libreoffice-fresh-de 7.2.5-1 7.3.0-1
libreoffice-fresh-dgo 7.2.5-1 7.3.0-1
libreoffice-fresh-dsb 7.2.5-1 7.3.0-1
libreoffice-fresh-dz 7.2.5-1 7.3.0-1
libreoffice-fresh-el 7.2.5-1 7.3.0-1
libreoffice-fresh-en-gb 7.2.5-1 7.3.0-1
libreoffice-fresh-en-za 7.2.5-1 7.3.0-1
libreoffice-fresh-eo 7.2.5-1 7.3.0-1
libreoffice-fresh-es 7.2.5-1 7.3.0-1
libreoffice-fresh-et 7.2.5-1 7.3.0-1
libreoffice-fresh-eu 7.2.5-1 7.3.0-1
libreoffice-fresh-fa 7.2.5-1 7.3.0-1
libreoffice-fresh-fi 7.2.5-1 7.3.0-1
libreoffice-fresh-fr 7.2.5-1 7.3.0-1
libreoffice-fresh-fur 7.2.5-1 7.3.0-1
libreoffice-fresh-fy 7.2.5-1 7.3.0-1
libreoffice-fresh-ga 7.2.5-1 7.3.0-1
libreoffice-fresh-gd 7.2.5-1 7.3.0-1
libreoffice-fresh-gl 7.2.5-1 7.3.0-1
libreoffice-fresh-gu 7.2.5-1 7.3.0-1
libreoffice-fresh-gug 7.2.5-1 7.3.0-1
libreoffice-fresh-he 7.2.5-1 7.3.0-1
libreoffice-fresh-hi 7.2.5-1 7.3.0-1
libreoffice-fresh-hr 7.2.5-1 7.3.0-1
libreoffice-fresh-hsb 7.2.5-1 7.3.0-1
libreoffice-fresh-hu 7.2.5-1 7.3.0-1
libreoffice-fresh-id 7.2.5-1 7.3.0-1
libreoffice-fresh-is 7.2.5-1 7.3.0-1
libreoffice-fresh-it 7.2.5-1 7.3.0-1
libreoffice-fresh-ja 7.2.5-1 7.3.0-1
libreoffice-fresh-ka 7.2.5-1 7.3.0-1
libreoffice-fresh-kab 7.2.5-1 7.3.0-1
libreoffice-fresh-kk 7.2.5-1 7.3.0-1
libreoffice-fresh-km 7.2.5-1 7.3.0-1
libreoffice-fresh-kmr-latn 7.2.5-1 7.3.0-1
libreoffice-fresh-kn 7.2.5-1 7.3.0-1
libreoffice-fresh-ko 7.2.5-1 7.3.0-1
libreoffice-fresh-kok 7.2.5-1 7.3.0-1
libreoffice-fresh-ks 7.2.5-1 7.3.0-1
libreoffice-fresh-lb 7.2.5-1 7.3.0-1
libreoffice-fresh-lo 7.2.5-1 7.3.0-1
libreoffice-fresh-lt 7.2.5-1 7.3.0-1
libreoffice-fresh-lv 7.2.5-1 7.3.0-1
libreoffice-fresh-mai 7.2.5-1 7.3.0-1
libreoffice-fresh-mk 7.2.5-1 7.3.0-1
libreoffice-fresh-ml 7.2.5-1 7.3.0-1
libreoffice-fresh-mn 7.2.5-1 7.3.0-1
libreoffice-fresh-mni 7.2.5-1 7.3.0-1
libreoffice-fresh-mr 7.2.5-1 7.3.0-1
libreoffice-fresh-my 7.2.5-1 7.3.0-1
libreoffice-fresh-nb 7.2.5-1 7.3.0-1
libreoffice-fresh-ne 7.2.5-1 7.3.0-1
libreoffice-fresh-nl 7.2.5-1 7.3.0-1
libreoffice-fresh-nn 7.2.5-1 7.3.0-1
libreoffice-fresh-nr 7.2.5-1 7.3.0-1
libreoffice-fresh-nso 7.2.5-1 7.3.0-1
libreoffice-fresh-oc 7.2.5-1 7.3.0-1
libreoffice-fresh-om 7.2.5-1 7.3.0-1
libreoffice-fresh-or 7.2.5-1 7.3.0-1
libreoffice-fresh-pa-in 7.2.5-1 7.3.0-1
libreoffice-fresh-pl 7.2.5-1 7.3.0-1
libreoffice-fresh-pt 7.2.5-1 7.3.0-1
libreoffice-fresh-pt-br 7.2.5-1 7.3.0-1
libreoffice-fresh-ro 7.2.5-1 7.3.0-1
libreoffice-fresh-ru 7.2.5-1 7.3.0-1
libreoffice-fresh-rw 7.2.5-1 7.3.0-1
libreoffice-fresh-sa-in 7.2.5-1 7.3.0-1
libreoffice-fresh-sat 7.2.5-1 7.3.0-1
libreoffice-fresh-sd 7.2.5-1 7.3.0-1
libreoffice-fresh-sdk 7.2.5-4 7.3.0-4
libreoffice-fresh-si 7.2.5-1 7.3.0-1
libreoffice-fresh-sid 7.2.5-1 7.3.0-1
libreoffice-fresh-sk 7.2.5-1 7.3.0-1
libreoffice-fresh-sl 7.2.5-1 7.3.0-1
libreoffice-fresh-sq 7.2.5-1 7.3.0-1
libreoffice-fresh-sr 7.2.5-1 7.3.0-1
libreoffice-fresh-sr-latn 7.2.5-1 7.3.0-1
libreoffice-fresh-ss 7.2.5-1 7.3.0-1
libreoffice-fresh-st 7.2.5-1 7.3.0-1
libreoffice-fresh-sv 7.2.5-1 7.3.0-1
libreoffice-fresh-sw-tz 7.2.5-1 7.3.0-1
libreoffice-fresh-szl 7.2.5-1 7.3.0-1
libreoffice-fresh-ta 7.2.5-1 7.3.0-1
libreoffice-fresh-te 7.2.5-1 7.3.0-1
libreoffice-fresh-tg 7.2.5-1 7.3.0-1
libreoffice-fresh-th 7.2.5-1 7.3.0-1
libreoffice-fresh-tn 7.2.5-1 7.3.0-1
libreoffice-fresh-tr 7.2.5-1 7.3.0-1
libreoffice-fresh-ts 7.2.5-1 7.3.0-1
libreoffice-fresh-tt 7.2.5-1 7.3.0-1
libreoffice-fresh-ug 7.2.5-1 7.3.0-1
libreoffice-fresh-uk 7.2.5-1 7.3.0-1
libreoffice-fresh-uz 7.2.5-1 7.3.0-1
libreoffice-fresh-ve 7.2.5-1 7.3.0-1
libreoffice-fresh-vec 7.2.5-1 7.3.0-1
libreoffice-fresh-vi 7.2.5-1 7.3.0-1
libreoffice-fresh-xh 7.2.5-1 7.3.0-1
libreoffice-fresh-zh-cn 7.2.5-1 7.3.0-1
libreoffice-fresh-zh-tw 7.2.5-1 7.3.0-1
libreoffice-fresh-zu 7.2.5-1 7.3.0-1
libreoffice-still 7.1.8-5 7.2.5-3
libreoffice-still-af 7.1.8-1 7.2.5-1
libreoffice-still-am 7.1.8-1 7.2.5-1
libreoffice-still-ar 7.1.8-1 7.2.5-1
libreoffice-still-as 7.1.8-1 7.2.5-1
libreoffice-still-ast 7.1.8-1 7.2.5-1
libreoffice-still-be 7.1.8-1 7.2.5-1
libreoffice-still-bg 7.1.8-1 7.2.5-1
libreoffice-still-bn 7.1.8-1 7.2.5-1
libreoffice-still-bn-in 7.1.8-1 7.2.5-1
libreoffice-still-bo 7.1.8-1 7.2.5-1
libreoffice-still-br 7.1.8-1 7.2.5-1
libreoffice-still-brx 7.1.8-1 7.2.5-1
libreoffice-still-bs 7.1.8-1 7.2.5-1
libreoffice-still-ca 7.1.8-1 7.2.5-1
libreoffice-still-ca-valencia 7.1.8-1 7.2.5-1
libreoffice-still-ckb 7.1.8-1 7.2.5-1
libreoffice-still-cs 7.1.8-1 7.2.5-1
libreoffice-still-cy 7.1.8-1 7.2.5-1
libreoffice-still-da 7.1.8-1 7.2.5-1
libreoffice-still-de 7.1.8-1 7.2.5-1
libreoffice-still-dgo 7.1.8-1 7.2.5-1
libreoffice-still-dsb 7.1.8-1 7.2.5-1
libreoffice-still-dz 7.1.8-1 7.2.5-1
libreoffice-still-el 7.1.8-1 7.2.5-1
libreoffice-still-en-gb 7.1.8-1 7.2.5-1
libreoffice-still-en-za 7.1.8-1 7.2.5-1
libreoffice-still-eo 7.1.8-1 7.2.5-1
libreoffice-still-es 7.1.8-1 7.2.5-1
libreoffice-still-et 7.1.8-1 7.2.5-1
libreoffice-still-eu 7.1.8-1 7.2.5-1
libreoffice-still-fa 7.1.8-1 7.2.5-1
libreoffice-still-fi 7.1.8-1 7.2.5-1
libreoffice-still-fr 7.1.8-1 7.2.5-1
libreoffice-still-fur 7.1.8-1 7.2.5-1
libreoffice-still-fy 7.1.8-1 7.2.5-1
libreoffice-still-ga 7.1.8-1 7.2.5-1
libreoffice-still-gd 7.1.8-1 7.2.5-1
libreoffice-still-gl 7.1.8-1 7.2.5-1
libreoffice-still-gu 7.1.8-1 7.2.5-1
libreoffice-still-gug 7.1.8-1 7.2.5-1
libreoffice-still-he 7.1.8-1 7.2.5-1
libreoffice-still-hi 7.1.8-1 7.2.5-1
libreoffice-still-hr 7.1.8-1 7.2.5-1
libreoffice-still-hsb 7.1.8-1 7.2.5-1
libreoffice-still-hu 7.1.8-1 7.2.5-1
libreoffice-still-id 7.1.8-1 7.2.5-1
libreoffice-still-is 7.1.8-1 7.2.5-1
libreoffice-still-it 7.1.8-1 7.2.5-1
libreoffice-still-ja 7.1.8-1 7.2.5-1
libreoffice-still-ka 7.1.8-1 7.2.5-1
libreoffice-still-kab 7.1.8-1 7.2.5-1
libreoffice-still-kk 7.1.8-1 7.2.5-1
libreoffice-still-km 7.1.8-1 7.2.5-1
libreoffice-still-kmr-latn 7.1.8-1 7.2.5-1
libreoffice-still-kn 7.1.8-1 7.2.5-1
libreoffice-still-ko 7.1.8-1 7.2.5-1
libreoffice-still-kok 7.1.8-1 7.2.5-1
libreoffice-still-ks 7.1.8-1 7.2.5-1
libreoffice-still-lb 7.1.8-1 7.2.5-1
libreoffice-still-lo 7.1.8-1 7.2.5-1
libreoffice-still-lt 7.1.8-1 7.2.5-1
libreoffice-still-lv 7.1.8-1 7.2.5-1
libreoffice-still-mai 7.1.8-1 7.2.5-1
libreoffice-still-mk 7.1.8-1 7.2.5-1
libreoffice-still-ml 7.1.8-1 7.2.5-1
libreoffice-still-mn 7.1.8-1 7.2.5-1
libreoffice-still-mni 7.1.8-1 7.2.5-1
libreoffice-still-mr 7.1.8-1 7.2.5-1
libreoffice-still-my 7.1.8-1 7.2.5-1
libreoffice-still-nb 7.1.8-1 7.2.5-1
libreoffice-still-ne 7.1.8-1 7.2.5-1
libreoffice-still-nl 7.1.8-1 7.2.5-1
libreoffice-still-nn 7.1.8-1 7.2.5-1
libreoffice-still-nr 7.1.8-1 7.2.5-1
libreoffice-still-nso 7.1.8-1 7.2.5-1
libreoffice-still-oc 7.1.8-1 7.2.5-1
libreoffice-still-om 7.1.8-1 7.2.5-1
libreoffice-still-or 7.1.8-1 7.2.5-1
libreoffice-still-pa-in 7.1.8-1 7.2.5-1
libreoffice-still-pl 7.1.8-1 7.2.5-1
libreoffice-still-pt 7.1.8-1 7.2.5-1
libreoffice-still-pt-br 7.1.8-1 7.2.5-1
libreoffice-still-ro 7.1.8-1 7.2.5-1
libreoffice-still-ru 7.1.8-1 7.2.5-1
libreoffice-still-rw 7.1.8-1 7.2.5-1
libreoffice-still-sa-in 7.1.8-1 7.2.5-1
libreoffice-still-sat 7.1.8-1 7.2.5-1
libreoffice-still-sd 7.1.8-1 7.2.5-1
libreoffice-still-sdk 7.1.8-5 7.2.5-3
libreoffice-still-si 7.1.8-1 7.2.5-1
libreoffice-still-sid 7.1.8-1 7.2.5-1
libreoffice-still-sk 7.1.8-1 7.2.5-1
libreoffice-still-sl 7.1.8-1 7.2.5-1
libreoffice-still-sq 7.1.8-1 7.2.5-1
libreoffice-still-sr 7.1.8-1 7.2.5-1
libreoffice-still-sr-latn 7.1.8-1 7.2.5-1
libreoffice-still-ss 7.1.8-1 7.2.5-1
libreoffice-still-st 7.1.8-1 7.2.5-1
libreoffice-still-sv 7.1.8-1 7.2.5-1
libreoffice-still-sw-tz 7.1.8-1 7.2.5-1
libreoffice-still-szl 7.1.8-1 7.2.5-1
libreoffice-still-ta 7.1.8-1 7.2.5-1
libreoffice-still-te 7.1.8-1 7.2.5-1
libreoffice-still-tg 7.1.8-1 7.2.5-1
libreoffice-still-th 7.1.8-1 7.2.5-1
libreoffice-still-tn 7.1.8-1 7.2.5-1
libreoffice-still-tr 7.1.8-1 7.2.5-1
libreoffice-still-ts 7.1.8-1 7.2.5-1
libreoffice-still-tt 7.1.8-1 7.2.5-1
libreoffice-still-ug 7.1.8-1 7.2.5-1
libreoffice-still-uk 7.1.8-1 7.2.5-1
libreoffice-still-uz 7.1.8-1 7.2.5-1
libreoffice-still-ve 7.1.8-1 7.2.5-1
libreoffice-still-vec 7.1.8-1 7.2.5-1
libreoffice-still-vi 7.1.8-1 7.2.5-1
libreoffice-still-xh 7.1.8-1 7.2.5-1
libreoffice-still-zh-cn 7.1.8-1 7.2.5-1
libreoffice-still-zh-tw 7.1.8-1 7.2.5-1
libreoffice-still-zu 7.1.8-1 7.2.5-1
libxkbcommon 1.3.1-1 1.4.0-1
libxkbcommon-doc 1.3.1-1 1.4.0-1
libxkbcommon-x11 1.3.1-1 1.4.0-1
lokalize 21.12.1-1 21.12.2-1
lskat 21.12.1-1 21.12.2-1
mailcommon 21.12.1-1 21.12.2-1
mailimporter 21.12.1-1 21.12.2-1
marble 21.12.1-1 21.12.2-1
marble-common 21.12.1-1 21.12.2-1
marble-maps 21.12.1-1 21.12.2-1
marble-qt 21.12.1-1 21.12.2-1
markdownpart 21.12.1-1 21.12.2-1
mbox-importer 21.12.1-1 21.12.2-1
mdds 1.7.0-1 2.0.1-1
mercurial 6.0.1-1 6.0.2-1
mesa-demos 8.4.0-6 8.4.0-7
mesa-utils 8.4.0-6 8.4.0-7
messagelib 21.12.1-1 21.12.2-1
minuet 21.12.1-1 21.12.2-1
mkinitcpio-archiso 60-1 61-1
numactl 2.0.14-1 2.0.14-2
orca 41.1-1 41.2-1
palapeli 21.12.1-1 21.12.2-1
parley 21.12.1-1 21.12.2-1
partitionmanager 21.12.1-1 21.12.2-1
phonon-qt5 4.11.1-2 4.11.1-3
phonon-qt5-gstreamer 4.10.0-2 4.10.0-3
phonon-qt5-vlc 0.11.3-1 0.11.3-2
picmi 21.12.1-1 21.12.2-1
pim-data-exporter 21.12.1-1 21.12.2-1
pim-sieve-editor 21.12.1-1 21.12.2-1
pimcommon 21.12.1-1 21.12.2-1
pipewire-alsa 1:0.3.44-1 1:0.3.45-1
pipewire-docs 1:0.3.44-1 1:0.3.45-1
pipewire-jack 1:0.3.44-1 1:0.3.45-1
pipewire-pulse 1:0.3.44-1 1:0.3.45-1
pipewire-v4l2 1:0.3.44-1 1:0.3.45-1
pipewire-x11-bell 1:0.3.44-1 1:0.3.45-1
pipewire-zeroconf 1:0.3.44-1 1:0.3.45-1
plasma-desktop 5.23.5-1 5.23.5-2
poppler 22.01.0-1 22.02.0-2
poppler-glib 22.01.0-1 22.02.0-2
poppler-qt5 22.01.0-1 22.02.0-2
poppler-qt6 22.01.0-1 22.02.0-2
poxml 21.12.1-1 21.12.2-1
print-manager 21.12.1-1 21.12.2-1
prometheus 2.32.1-1 2.33.1-1
pyalpm 0.10.6-3 0.10.6-4
pyside6 6.2.2-2 6.2.3-1
python-pyqt5-3d 5.15.5-2 5.15.5-3
python-pyqt5 5.15.6-6 5.15.6-7
python-pyqt5-chart 5.15.5-2 5.15.5-3
python-pyqt5-datavisualization 5.15.5-2 5.15.5-3
python-pyqt5-networkauth 5.15.5-2 5.15.5-3
python-pyqt5-purchasing 5.15.5-2 5.15.5-3
python-pyqt5-sip 12.9.0-3 12.9.1-1
python-pyqt5-webengine 5.15.5-3 5.15.5-4
python-pyqt6-3d 6.2.0-2 6.2.0-3
python-pyqt6 6.2.2-3 6.2.3-1
python-pyqt6-charts 6.2.0-2 6.2.0-3
python-pyqt6-datavisualization 6.2.0-2 6.2.0-3
python-pyqt6-networkauth 6.2.0-2 6.2.0-3
python-pyqt6-sip 13.2.0-4 13.2.1-1
python-pyqt6-webengine 6.2.1-2 6.2.1-3
qca-qt5 2.3.4-2 2.3.4-3
qca-qt6 2.3.4-2 2.3.4-3
qcachegrind 21.12.1-1 21.12.2-1
qt5-base 5.15.2+kde+r295-2 5.15.2+kde+r297-1
qt5-declarative 5.15.2+kde+r43-2 5.15.2+kde+r45-1
qt5-mqtt 5.15.2-1 5.15.2-2
qt5-multimedia 5.15.2-1 5.15.2-2
qt5-networkauth 5.15.2-1 5.15.2-2
qt5-purchasing 5.15.2-1 5.15.2-2
qt5-quick3d 5.15.2+kde+r19-3 5.15.2+kde+r19-4
qt5-quickcontrols 5.15.2-1 5.15.2-2
qt5-quickcontrols2 5.15.2+kde+r10-1 5.15.2+kde+r11-2
qt5-quicktimeline 5.15.2-1 5.15.2-2
qt5-remoteobjects 5.15.2-1 5.15.2-2
qt5-script 5.15.8-2 5.15.8-3
qt5-scxml 5.15.2-1 5.15.2-2
qt5-serialbus 5.15.2-1 5.15.2-2
qt5-speech 5.15.2-1 5.15.2-2
qt5-svg 5.15.2+kde+r16-1 5.15.2+kde+r16-2
qt5-virtualkeyboard 5.15.2+kde+r6-1 5.15.2+kde+r6-2
qt5-wayland 5.15.2+kde+r46-1 5.15.2+kde+r48-1
qt5-webengine 5.15.8-3 5.15.8-7
qt5-webglplugin 5.15.2-1 5.15.2-2
qt5-webview 5.15.2-1 5.15.2-2
qt5-x11extras 5.15.2-1 5.15.2-2
qt5-xcb-private-headers 5.15.2+kde+r295-2 5.15.2+kde+r297-1
qt5-xmlpatterns 5.15.2-1 5.15.2-2
qt6-3d 6.2.3-1 6.2.3-2
qt6-5compat 6.2.3-1 6.2.3-2
qt6-base 6.2.3-1 6.2.3-4
qt6-charts 6.2.3-1 6.2.3-2
qt6-connectivity 6.2.3-1 6.2.3-2
qt6-datavis3d 6.2.3-1 6.2.3-2
qt6-declarative 6.2.3-1 6.2.3-2
qt6-imageformats 6.2.3-1 6.2.3-2
qt6-lottie 6.2.3-1 6.2.3-2
qt6-multimedia 6.2.3-1 6.2.3-2
qt6-networkauth 6.2.3-1 6.2.3-2
qt6-positioning 6.2.3-1 6.2.3-2
qt6-quick3d 6.2.3-1 6.2.3-2
qt6-quicktimeline 6.2.3-1 6.2.3-2
qt6-remoteobjects 6.2.3-1 6.2.3-2
qt6-scxml 6.2.3-1 6.2.3-2
qt6-sensors 6.2.3-1 6.2.3-2
qt6-serialbus 6.2.3-1 6.2.3-2
qt6-serialport 6.2.3-1 6.2.3-2
qt6-shadertools 6.2.3-1 6.2.3-2
qt6-svg 6.2.3-1 6.2.3-2
qt6-tools 6.2.3-1 6.2.3-3
qt6-virtualkeyboard 6.2.3-1 6.2.3-2
qt6-wayland 6.2.3-1 6.2.3-2
qt6-webchannel 6.2.3-1 6.2.3-2
qt6-webengine 6.2.3-1 6.2.3-7
qt6-websockets 6.2.3-1 6.2.3-2
qt6-webview 6.2.3-1 6.2.3-2
qtcreator 6.0.2-1 6.0.2-2
r 4.1.2-2 4.1.2-3
re2 1:20211101-1 1:20220201-1
rocs 21.12.1-1 21.12.2-1
samba 4.15.4-1 4.15.5-1
sbcl 2.1.11-1 2.2.1-1
screen 4.8.0-3 4.9.0-1
sddm 0.19.0-7 0.19.0-8
shiboken6 6.2.2-2 6.2.3-1
signon-kwallet-extension 21.12.1-1 21.12.2-1
sip 6.5.0-2 6.5.1-1
skanlite 21.12.1-1 21.12.2-1
smbclient 4.15.4-1 4.15.5-1
spectacle 21.12.1-1 21.12.2-1
step 21.12.1-1 21.12.2-1
svgpart 21.12.1-1 21.12.2-1
sweeper 21.12.1-1 21.12.2-1
tali 40.4-1 40.5-1
tdb 1.4.5-3 1.4.6-1
telepathy-kde-accounts-kcm 21.12.1-1 21.12.2-1
telepathy-kde-approver 21.12.1-1 21.12.2-1
telepathy-kde-auth-handler 21.12.1-1 21.12.2-1
telepathy-kde-call-ui 21.12.1-1 21.12.2-1
telepathy-kde-common-internals 21.12.1-1 21.12.2-1
telepathy-kde-contact-list 21.12.1-1 21.12.2-1
telepathy-kde-contact-runner 21.12.1-1 21.12.2-1
telepathy-kde-desktop-applets 21.12.1-1 21.12.2-1
telepathy-kde-filetransfer-handler 21.12.1-1 21.12.2-1
telepathy-kde-integration-module 21.12.1-1 21.12.2-1
telepathy-kde-send-file 21.12.1-1 21.12.2-1
telepathy-kde-text-ui 21.12.1-1 21.12.2-1
umbrello 21.12.1-1 21.12.2-1
varnish 7.0.2-1 7.0.2-2
vde2 2.3.2-18 2.3.2-19
wireplumber 0.4.7-1 0.4.7-2
wireplumber-docs 0.4.7-1 0.4.7-2
xfce4-cpufreq-plugin 1.2.6-1 1.2.7-1
xfce4-cpugraph-plugin 1.2.5-1 1.2.6-1
xfce4-sensors-plugin 1.4.2-1 1.4.3-1
xterm 370-1 370-2
yakuake 21.12.1-1 21.12.2-1
zanshin 21.12.1-1 21.12.2-1
zeroconf-ioslave 21.12.1-1 21.12.2-1
libcuckoo - 0.3-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.12.1.r12688.ga84cbd6c2-121.12.2.r12693.g14eba0a64-1
akonadi-calendar21.12.1.r2027.gef50a4b-121.12.2.r2027.gef50a4b-1
akonadi-calendar-tools21.12.1.r931.g2423b8e-121.12.2.r931.g2423b8e-1
akonadi-contacts21.12.1.r3113.ga5414370-121.12.2.r3132.gbdc31c2d-1
akonadi-import-wizard21.12.1.r1788.g69cf414-121.12.2.r1788.g69cf414-1
akonadi-mime21.12.1.r1692.g87bdbc2-121.12.2.r1692.g87bdbc2-1
akonadi-notes21.12.1.r1055.g00ce3a7-121.12.2.r1055.g00ce3a7-1
akonadi-search21.12.1.r1172.gd3d532b-121.12.2.r1173.g1af42a7-1
akonadiconsole21.12.1.r1567.gc9b8650-121.12.2.r1567.gc9b8650-1
akregator21.12.1.r6323.g5aaffb19-121.12.2.r6324.gcc2f284a-1
alligator 21.12.r6.g093872c-1 21.12.r7.g7e6f935-1
analitza21.12.1.r2334.g7ec50877-121.12.2.r2334.g7ec50877-1
angelfish 21.12.r43.g0d9c8e6-1 21.12.r45.gcac5b11-1
ark21.12.1.r4686.g26e97d73-121.12.2.r4690.g3897bbaf-1
artikulate21.12.1.r1403.gab06b82-121.12.2.r1404.gad00c55-1
attica5.90.0.r854.g67e78d4-15.90.0.r855.gc6430b8-1
audiocd-kio21.12.1.r1047.gfd9512f-121.12.2.r1047.gfd9512f-1
baloo5.90.0.r3031.g42130460-15.90.0.r3037.gf24e512e-1
baloo-widgets21.12.1.r726.g9c35b9e-121.12.2.r731.g8c77dc1-1
blinken21.12.1.r652.gbf33cfc-121.12.2.r653.g114a2e3-1
bomber21.12.1.r549.g2967434-121.12.2.r550.g8c645a1-1
bovo21.12.1.r765.g603fd27-121.12.2.r765.g603fd27-1
breeze5.23.5.r2338.g3d781d3d-15.23.5.r2340.g8556cb4a-1
breeze-icons5.90.0.r1878.g331b1e4d-15.90.0.r1880.g9bc16759-1
buho 2.1.0.r4.gefd07ed-1 2.1.0.r5.g68aec2e-1
calendarsupport21.12.1.r656.gbec30d7-121.12.2.r656.gbec30d7-1
calindori 21.12.r18.g383d047-1 21.12.r19.g670a13a-1
cervisia21.12.1.r1651.g61ced0d-121.12.2.r1651.g61ced0d-1
discover5.23.5.r8513.g30555031-15.23.5.r8517.gbab99702-1
disman5.23.5.r1811.gca36775-15.23.5.r1813.g1c66a4d-1
dolphin21.12.1.r6832.gd68bb06e8-121.12.2.r6832.gd68bb06e8-1
dolphin-plugins21.12.1.r637.g1f6fc2b-121.12.2.r637.g1f6fc2b-1
dragon21.12.1.r1023.g75f8df3-121.12.2.r1023.g75f8df3-1
drkonqi5.23.5.r723.g967f6b99-15.23.5.r727.g121f9354-1
elisa21.12.1.r2861.gcffdb18a-121.12.2.r2861.gcffdb18a-1
eventviews21.12.1.r784.g5994ad6-121.12.2.r784.g5994ad6-1
extra-cmake-modules5.90.0.r3434.gfffae63-15.90.0.r3437.g48313bf-1
ffmpegthumbs21.12.1.r204.gd52f1f9-121.12.2.r204.gd52f1f9-1
filelight21.12.1.r1030.g5e02df3-121.12.2.r1032.g8690759-1
granatier21.12.1.r957.g29af30f-121.12.2.r958.g2f2be66-1
grantlee-editor21.12.1.r802.g8be77aa-121.12.2.r802.g8be77aa-1
grantleetheme21.12.1.r375.g11b8caf-121.12.2.r377.g939550b-1
gwenview21.12.1.r6755.g9c21b36e-121.12.2.r6755.g9c21b36e-1
incidenceeditor21.12.1.r833.g02f6010-121.12.2.r833.g02f6010-1
index-fm 2.1.0.r23.gd06cb23-1 2.1.0.r24.g3625364-1
itinerary21.12.1.r1709.g99268b7-121.12.2.r1717.gd3f4c2a-1
juk21.12.1.r3128.ge4bb58f6-121.12.2.r3128.ge4bb58f6-1
k3b1:21.12.1.r6709.gb608f9df7-11:21.12.2.r6709.gb608f9df7-1
kaccounts-integration21.12.1.r1238.g660436a-121.12.2.r1238.g660436a-1
kaccounts-providers21.12.1.r389.ga3055df-121.12.2.r389.ga3055df-1
kaddressbook21.12.1.r6100.g35b9e166-121.12.2.r6100.g35b9e166-1
kajongg21.12.1.r4214.g133a2e27-121.12.2.r4327.g32125853-1
kalarm21.12.1.r6582.gfc354236-121.12.2.r6582.gfc354236-1
kalarmcal21.12.1.r1180.g0317927-121.12.2.r1180.g0317927-1
kalgebra21.12.1.r2052.g6e54f8c-121.12.2.r2052.g6e54f8c-1
kalk 21.12.r29.gfa02582-1 21.12.r30.g2ad2340-1
kalzium21.12.1.r4297.g06d90c49-121.12.2.r4298.gf2169c3b-1
kamoso21.12.1.r1447.g2c4940b-121.12.2.r1447.g2c4940b-1
kanagram21.12.1.r1299.ga3c8235-121.12.2.r1299.ga3c8235-1
kapman21.12.1.r636.gc15ef7a-121.12.2.r636.gc15ef7a-1
kapptemplate21.12.1.r966.g883e4ef-121.12.2.r966.g883e4ef-1
kate21.12.1.r18597.g4d9c0c59a-121.12.2.r18605.g602386d31-1
katomic21.12.1.r945.gaff8ad8-121.12.2.r946.g10dc75b-1
kbackup21.12.1.r419.ga25d29e-121.12.2.r419.ga25d29e-1
kblackbox21.12.1.r753.geb86463-121.12.2.r754.g546b0a7-1
kblocks21.12.1.r694.gcd784f9-121.12.2.r695.g65b73c7-1
kbounce21.12.1.r834.g92f4a6e-121.12.2.r835.g133f917-1
kbreakout21.12.1.r892.g1cebe24-121.12.2.r893.gd598d87-1
kbruch21.12.1.r839.g9d87897-121.12.2.r851.g0f4219a-1
kcachegrind21.12.1.r1168.g4f966d5-121.12.2.r1168.g4f966d5-1
kcachegrind-common21.12.1.r1168.g4f966d5-121.12.2.r1168.g4f966d5-1
kcalc21.12.1.r1592.gc206de1-121.12.2.r1593.g0bb4635-1
kcalutils21.12.1.r929.g6d2a5d3d6-121.12.2.r933.g8cba0d383-1
kcharselect21.12.1.r500.g4d9bdf2-121.12.2.r500.g4d9bdf2-1
kcolorchooser21.12.1.r247.g76db61b-121.12.2.r247.g76db61b-1
kconfig5.90.0.r922.g724966b6-15.90.0.r923.g4d31ec78-1
kconfigwidgets5.90.0.r674.gd3d7f7c-15.90.0.r676.g52281e5-1
kcoreaddons5.90.0.r1412.gf8337d48-15.90.0.r1413.ge799c146-1
kcron21.12.1.r820.g1b2056b-121.12.2.r828.g3cac207-1
kde-cli-tools5.23.5.r1896.g0225af6-15.23.5.r1898.gcbc363f-1
kde-dev-scripts21.12.1.r4143.gb95ec7f-121.12.2.r4143.gb95ec7f-1
kde-dev-utils21.12.1.r571.g69a71e0-121.12.2.r571.g69a71e0-1
kde-telephony-daemon21.08.2.r431.gd23a470-1 -
kde-telephony-meta21.12.1.r431.gff84b1c-1 -
kde-telephony-plugin-declarative21.12.1.r431.g0e229a0-1 -
kdebugsettings21.12.1.r889.g02603cb-121.12.2.r889.g02603cb-1
kdeclarative5.90.0.r972.gc84ca6c-15.90.0.r977.g0b5bded-1
kdeconnect21.12.1.r3389.gd97dcbb5-121.12.2.r3389.gd97dcbb5-1
kdeedu-data21.12.1.r16.g8312b2d-121.12.2.r16.g8312b2d-1
kdegraphics-mobipocket21.12.1.r265.g8e1b8b9-121.12.2.r265.g8e1b8b9-1
kdegraphics-thumbnailers21.12.1.r251.g1dffc1b-121.12.2.r251.g1dffc1b-1
kdenetwork-filesharing21.12.1.r901.g528fe25-121.12.2.r901.g528fe25-1
kdenlive21.12.1.r15574.gd38e7a11f-121.12.1.r15585.gf17aade92-1
kdepim-addons21.12.1.r4527.gb5c5d769-121.12.2.r4535.g34719d5a-1
kdepim-runtime21.12.1.r15442.g78ac82bed-121.12.2.r15442.g78ac82bed-1
kdeplasma-addons5.23.5.r8639.g5443b43c0-15.23.5.r8643.gc327dc695-1
kdesdk-kioslaves21.12.1.r501.gaf87828-121.12.2.r501.gaf87828-1
kdesdk-thumbnailers21.12.1.r87.gf6b26e6-121.12.2.r87.gf6b26e6-1
kdesu5.90.0.r492.g44dfcfb-15.90.0.r497.g010fd75-1
kdf21.12.1.r831.g398f78e-121.12.2.r831.g398f78e-1
kdialog21.12.1.r1204.g9befdc057-121.12.2.r1204.g9befdc057-1
kdiamond21.12.1.r706.g78ef219-121.12.2.r707.g6b22509-1
kdisplay5.23.4.r1460.gbec0776-15.23.4.r1462.g0dcc731-1
kdoctools5.90.0.r647.g62e9371-15.90.0.r648.g327e74b-1
keditbookmarks21.12.1.r2759.gae988d9e5-121.12.2.r2759.gae988d9e5-1
kfind21.12.1.r2666.g617386a4f-121.12.2.r2666.g617386a4f-1
kfloppy21.12.1.r784.g8933745-121.12.2.r784.g8933745-1
kfourinline21.12.1.r1008.gcc592a2-121.12.2.r1009.g9516d9d-1
kgeography21.12.1.r1136.gd55aafb-121.12.2.r1136.gd55aafb-1
kget21.12.1.r3156.g7bc2a1dd-121.12.2.r3156.g7bc2a1dd-1
kglobalaccel5.90.0.r498.g726b6a9-15.90.0.r500.g00f021c-1
kgoldrunner21.12.1.r1263.g83f7204-121.12.2.r1264.g5667c2f-1
kgpg21.12.1.r3166.g81648d39-121.12.2.r3166.g81648d39-1
kguiaddons5.90.0.r425.gb5ff055-15.90.0.r432.g7120f0f-1
khangman21.12.1.r1588.g883b9ee-121.12.2.r1588.g883b9ee-1
khealthcertificate 21.12.r1.g950d2e3-1 21.12.r3.g32e9e01-1
khelpcenter21.12.1.r2694.gc0bdf217-121.12.2.r2707.g2ffec423-1
khotkeys5.23.5.r2111.g52442ab-15.23.5.r2112.gcbe6a75-1
kiconthemes5.90.0.r583.g3fc04ac-15.90.0.r584.ga42e98d-1
kidentitymanagement21.12.1.r3862.g04ec5bb6-121.12.2.r3862.g04ec5bb6-1
kidletime5.90.0.r342.ga177fbc-15.90.0.r343.g7fb54cf-1
kig21.12.1.r3159.g5851b1f0-121.12.2.r3160.g253aa346-1
kigo21.12.1.r547.gf412f2d-121.12.2.r548.g56a33db-1
killbots21.12.1.r762.g530eb15-121.12.2.r763.g21310c0-1
kimageformats5.90.0.r375.g96836e8-15.90.0.r377.g3d2d91a-1
kimagemapeditor21.12.1.r479.g7fd3211-121.12.2.r479.g7fd3211-1
kimap21.12.1.r1170.g200a4a5-121.12.2.r1170.g200a4a5-1
kio5.90.0.r5247.ga2b271cc0-15.90.0.r5256.gef03fb852-1
kio-extras21.12.1.r7188.gb8cdf940-121.12.2.r7188.gb8cdf940-1
kio-gdrive21.12.1.r581.g28b7a2e-121.12.2.r581.g28b7a2e-1
kipi-plugins21.12.1.r12078.g6e4b49100-121.12.2.r12078.g6e4b49100-1
kirigami-gallery21.12.1.r229.g99ba6a3-121.12.2.r229.g99ba6a3-1
kirigami25.90.0.r3055.g6943a226-15.90.0.r3057.g19927f57-1
kiriki21.12.1.r437.g62feda8-121.12.2.r438.g1e4ecf2-1
kiten21.12.1.r1174.g5e2dfbf-121.12.2.r1175.g4f1ace0-1
kitinerary21.12.1.r2076.g26813cf-121.12.2.r2076.g26813cf-1
kjobwidgets5.90.0.r400.gc13609d-15.90.0.r401.g72c88fc-1
kjumpingcube21.12.1.r811.g7458aa1-121.12.2.r812.gd790191-1
kldap21.12.1.r930.g1683a9d-121.12.2.r930.g1683a9d-1
kleopatra21.12.1.r6189.gfec93520-121.12.2.r6195.g1a17bc62-1
klettres21.12.1.r948.gbbca007-121.12.2.r948.gbbca007-1
klickety21.12.1.r659.gc62801f-121.12.2.r660.g5e16b31-1
klines21.12.1.r791.g02c9e83-121.12.2.r792.g6bd8922-1
kmag21.12.1.r716.g1fcbd5f-121.12.2.r716.g1fcbd5f-1
kmahjongg21.12.1.r1511.gbddf5cb-121.12.2.r1512.ge267169-1
kmail21.12.1.r26225.gc8e7bd32a-121.12.2.r26250.g8a7cbfd72-1
kmail-account-wizard21.12.1.r860.g7a75a50-121.12.2.r860.g7a75a50-1
kmailtransport21.12.1.r1705.g31d0a5f-121.12.2.r1705.g31d0a5f-1
kmbox21.12.1.r576.g5ebc98a-121.12.2.r576.g5ebc98a-1
kmenuedit5.23.5.r995.g73dccdf-15.23.5.r997.g75dc0b4-1
kmime21.12.1.r1492.g86b92ec-121.12.2.r1492.g86b92ec-1
kmines21.12.1.r1749.ga197441-121.12.2.r1750.ge3b4c19-1
kmix21.12.1.r2415.g6101c0dc-121.12.2.r2415.g6101c0dc-1
kmousetool21.12.1.r423.gb1d0094-121.12.2.r423.gb1d0094-1
kmouth21.12.1.r703.gcfb889a-121.12.2.r703.gcfb889a-1
kmplot21.12.1.r1475.g6d86722-121.12.2.r1475.g6d86722-1
knavalbattle21.12.1.r1415.ga9bf890-121.12.2.r1415.ga9bf890-1
knetwalk21.12.1.r680.g477402f-121.12.2.r681.g14c0b16-1
knewstuff5.90.0.r1282.geb376f0a-15.90.0.r1285.g4cb8d2ce-1
knights21.12.1.r1092.gbd58c3c-121.12.2.r1093.g6ce6fcf-1
knotes21.12.1.r3583.gf4cd7977-121.12.2.r3584.g57c456df-1
kolf21.12.1.r1469.g10a1a8f-121.12.2.r1470.g39e5405-1
kollision21.12.1.r515.gf8a2aaf-121.12.2.r516.g57af848-1
kolourpaint21.12.1.r2381.gec495309-121.12.2.r2381.gec495309-1
kompare21.12.1.r1121.gec386a7-121.12.2.r1121.gec386a7-1
konqueror21.12.1.r15032.g25278ea6b-121.12.2.r15033.gac0571b07-1
konquest21.12.1.r916.g03a37df-121.12.2.r917.g0c48850-1
konsole21.12.1.r8234.g6e9f13ff-121.12.2.r8239.gc1a5d942-1
kontact21.12.1.r5461.gb0189689-121.12.2.r5473.g20b5a1a8-1
kontactinterface21.12.1.r661.gd10db89-121.12.2.r661.gd10db89-1
kontrast21.12.1.r191.gdee4c22-121.12.2.r191.gdee4c22-1
konversation21.12.1.r9069.g3cc696ae-121.12.2.r9071.ga8ac257a-1
kopeninghours21.12.1.r313.ga7c8653-121.12.2.r318.gd734ceb-1
kopete21.12.1.r16405.g69f6c3115-121.12.2.r16405.g69f6c3115-1
korganizer21.12.1.r11619.g59e837b04-121.12.2.r11619.g59e837b04-1
kosmindoormap21.12.1.r691.gb44f80a-121.12.2.r692.g8ff9e61-1
kpat21.12.1.r2594.g466db0f-121.12.2.r2595.gbd86cd4-1
kpimtextedit21.12.1.r1510.g359a2f4-121.12.2.r1511.gd5bf42c-1
kpkpass21.12.1.r267.g8be3794-121.12.2.r267.g8be3794-1
kpmcore21.12.1.r1241.ge2f097f-121.12.2.r1241.ge2f097f-1
kpublictransport21.12.1.r1975.g09e7a7a7-121.12.1.r1976.g3c4667bf-1
kqtquickcharts21.12.1.r75.g188b79d-121.12.2.r75.g188b79d-1
kquickcharts5.90.0.r493.gec6b51d-15.90.0.r495.g8d8d6ad-1
krdc21.12.1.r1558.gebc00cb-121.12.2.r1559.g13ef4e7-1
kreversi21.12.1.r1252.g2dcc3a2-121.12.2.r1253.g82b098a-1
krfb21.12.1.r1464.g18e76cf-121.12.2.r1464.g18e76cf-1
kross-interpreters21.12.1.r724.g2a6213a-121.12.2.r724.g2a6213a-1
kruler21.12.1.r722.g06a099c-121.12.2.r722.g06a099c-1
krunner5.90.0.r727.gd02eaf1-15.90.0.r728.g7fd9b32-1
kscreen5.23.5.r1423.g8bd4c09-15.23.5.r1424.gea7bcf3-1
kscreenlocker5.23.5.r902.gc050322-15.23.5.r903.gad6d802-1
kshisen21.12.1.r1222.g244f9dd-121.12.2.r1223.gb84e7e9-1
ksirk21.12.1.r1008.g79ebe6e-121.12.2.r1009.g077436d-1
ksmtp21.12.1.r419.g00a4bf4-121.12.2.r419.g00a4bf4-1
ksnakeduel21.12.1.r832.g5a7b633-121.12.2.r833.g597a312-1
kspaceduel21.12.1.r658.gc9bc7a5-121.12.2.r659.g64c2c5d-1
ksquares21.12.1.r546.g73cdc27-121.12.2.r547.ge1482d6-1
ksudoku21.12.1.r1090.g7c71d50-121.12.2.r1091.g6dcafee-1
ksystemlog21.12.1.r689.gbcba66e-121.12.2.r689.gbcba66e-1
ksystemstats5.23.5.r216.g75dad23-15.23.5.r217.g40be1b7-1
kteatime21.12.1.r739.g2bfd012-121.12.2.r739.g2bfd012-1
ktexteditor5.90.0.r3088.ge18a682d-15.90.0.r3096.g88d2adbd-1
ktimer21.12.1.r495.gf48a9a6-121.12.2.r495.gf48a9a6-1
ktnef21.12.1.r698.g0a79d4f-121.12.2.r698.g0a79d4f-1
ktorrent21.12.1.r2821.g7b61ed1b-121.12.2.r2821.g7b61ed1b-1
ktouch21.12.1.r2163.gcb23ab7-121.12.2.r2164.g9a02127-1
ktuberling21.12.1.r1030.g51ee790-121.12.2.r1030.g51ee790-1
kturtle21.12.1.r1153.ga84b574-121.12.2.r1153.ga84b574-1
kubrick21.12.1.r391.g1741ca2-121.12.2.r391.g1741ca2-1
kwalletmanager21.12.1.r1234.g98680e4-121.12.2.r1234.g98680e4-1
kwave21.12.1.r3761.gd4d48784-121.12.2.r3761.gd4d48784-1
kwidgetsaddons5.90.0.r907.gbb9a6ed4-15.90.0.r908.g26d22757-1
kwin5.23.5.r20698.g858da39fa-15.23.5.r20711.g185395caa-1
kwindowsystem5.90.0.r663.g83d6bb7-15.90.0.r664.g486d86b-1
kwinft5.23.5.r19974.g139e233e1-15.23.5.r20161.gafb49be30-1
kwordquiz21.12.1.r1166.g391df34-121.12.2.r1166.g391df34-1
kwrite21.12.1.r18597.g4d9c0c59a-121.12.2.r18605.g602386d31-1
kwrited5.23.5.r496.g532de01-15.23.5.r499.ga51e37d-1
kxmlgui5.90.0.r841.ga73a5fa6-15.90.0.r845.g8881e5e2-1
layer-shell-qt5.23.5.r53.g14982d6-15.23.5.r54.g9f8b8c9-1
libakonadi21.12.1.r12688.ga84cbd6c2-121.12.2.r12693.g14eba0a64-1
libgravatar21.12.1.r403.gbb9cdfe-121.12.2.r403.gbb9cdfe-1
libkcddb21.12.1.r751.g58c0fe3-121.12.2.r751.g58c0fe3-1
libkcompactdisc21.12.1.r391.ge62b8ec-121.12.2.r391.ge62b8ec-1
libkdcraw21.12.1.r1151.g0368098-121.12.2.r1151.g0368098-1
libkdegames21.12.1.r2213.g3d856df7-121.12.2.r2214.g41e94f99-1
libkdepim21.12.1.r886.ge14d844-121.12.2.r886.ge14d844-1
libkeduvocdocument21.12.1.r1808.g7bebaf5-121.12.2.r1808.g7bebaf5-1
libkexiv221.12.1.r818.gd8dbd19-121.12.2.r818.gd8dbd19-1
libkgapi21.12.1.r1335.g728753c-121.12.2.r1335.g728753c-1
libkipi21.12.1.r1276.gf61a329-121.12.2.r1276.gf61a329-1
libkleo21.12.1.r1064.gb49d0fb-121.12.2.r1065.gbbdc5ec-1
libkmahjongg21.12.1.r472.g2ca1196-121.12.2.r473.g46d3402-1
libkomparediff221.12.1.r341.gc0ec97e-121.12.2.r341.gc0ec97e-1
libksane21.12.1.r587.g1e8c721-121.12.2.r587.g1e8c721-1
libksieve21.12.1.r1665.g56bb61df-121.12.2.r1666.g02d1a31f-1
libksysguard5.23.5.r2349.gf901b29-15.23.5.r2354.g17c0b54-1
libktorrent21.12.1.r546.gc3d2072-121.12.2.r546.gc3d2072-1
lokalize21.12.1.r1793.gd88ca958-121.12.2.r1804.g01ed20b2-1
lskat21.12.1.r835.ge1db51b-121.12.2.r836.gaa4df19-1
mailcommon21.12.1.r1196.g7f93181-121.12.2.r1196.g7f93181-1
mailimporter21.12.1.r500.g9451fa1-121.12.2.r500.g9451fa1-1
maliit-keyboard2.1.0.r273.g4b8907de-12.1.0.r279.g2a3193f7-1
marble21.12.1.r13384.g8361c5eaf-121.12.2.r13398.gce53bf63a-1
marble-common21.12.1.r13384.g8361c5eaf-121.12.2.r13398.gce53bf63a-1
marble-qt21.12.1.r13384.g8361c5eaf-121.12.2.r13398.gce53bf63a-1
markdownpart21.12.1.r98.g090dfd8-121.12.2.r99.ge84600d-1
maui-clip 2.1.0.r5.gbb2e613-1 2.1.0.r6.gbf8a5ab-1
maui-nota 2.1.0.r8.gd528945-1 2.1.0.r9.g4a5ea66-1
maui-pix 2.1.0.r11.g127fc7a-1 2.1.0.r12.gbffcd1b-1
mauikit2.1.0.r71.ga79af5e9-12.1.0.r74.g686bc3b6-1
mauikit-accounts 2.1.0.r5.gd8608a5-1 2.1.0.r6.g30326de-1
mauikit-filebrowsing 2.1.0.r18.g5553027-1 2.1.0.r19.gaca5421-1
mauikit-texteditor 2.1.0.r6.g9f6a79c-1 2.1.0.r7.g2adcfdd-1
mbox-importer21.12.1.r549.gcfede23-121.12.2.r549.gcfede23-1
messagelib21.12.1.r6367.ga41aec6d5-121.12.1.r6377.gc428e6681-1
minuet21.12.1.r594.ga7a3284-121.12.2.r594.ga7a3284-1
neochat21.12.r53.g5a1198d2-121.12.r55.g0b7dcd70-1
okular21.12.1.r9597.g218edc6f4-121.12.2.r9601.gca5ed3488-1
palapeli21.12.1.r1262.g713174a-121.12.2.r1263.g36a515b-1
parley21.12.1.r4500.g8eebe50c-121.12.2.r4501.g70427c97-1
partitionmanager21.12.1.r1592.gfc385fd-121.12.2.r1593.gc925a91-1
picmi21.12.1.r551.g6ef67a7-121.12.2.r551.g6ef67a7-1
pico-wizard-bigscreen-configs-git r3.c10252e-1 -
pico-wizard-bigscreen-configs r3.c10252e-1 r4.51a8ea3-1
pico-wizard-bigscreen-scripts r163.52a17c8-1 -
pico-wizard-git r163.52a17c8-1 -
pim-data-exporter21.12.1.r2569.gadeeecee-121.12.2.r2569.gadeeecee-1
pim-sieve-editor21.12.1.r1576.g9eb2c20-121.12.2.r1577.g8d8ccc9-1
pimcommon21.12.1.r1186.g4842499-121.12.2.r1187.g9cb477e-1
plasma-bigscreen r445.g5519eac-1 r446.g186175e-1
plasma-desktop5.23.5.r9054.gc2b411372-15.23.5.r9059.gde8a392d2-1
plasma-framework5.90.0.r16164.g97ac87871-15.90.0.r16170.g81aeea9f7-1
plasma-integration5.23.5.r546.g99c7332-15.23.5.r547.g9b46c01-1
plasma-mobile5.23.5.r1605.gb8d096322-15.23.5.r1606.g8c22f48e5-1
plasma-mobile-nm5.23.5.r3177.geb5402d6-15.23.5.r3179.gd383ec6b-1
plasma-nm5.23.5.r3177.geb5402d6-15.23.5.r3179.gd383ec6b-1
plasma-vault5.23.5.r370.g22d69fa-15.23.5.r371.g9b2b90d-1
plasma-wayland-session5.23.5.r11346.g99d0f172e-15.23.5.r11358.ge1d1b601f-1
plasma-workspace5.23.5.r11346.g99d0f172e-15.23.5.r11358.ge1d1b601f-1
poxml21.12.1.r281.g183b2c7-121.12.2.r281.g183b2c7-1
print-manager21.12.1.r1096.g07034d5-121.12.2.r1096.g07034d5-1
qcachegrind21.12.1.r1168.g4f966d5-121.12.2.r1168.g4f966d5-1
qqc2-desktop-style5.90.0.r568.g6db6c43-15.90.0.r569.gfefd703-1
rocs21.12.1.r3057.g7d8057e3-121.12.2.r3057.g7d8057e3-1
sddm0.19.0.r129.g6b8e837-10.19.0.r130.g85cbf3f-1
signon-kwallet-extension21.12.1.r67.gdbee13b-121.12.2.r74.g36818d6-1
solid5.90.0.r745.gfe40ef2-15.90.0.r747.g32c4310-1
sonnet5.90.0.r671.ge468a47-15.90.0.r672.g40c8997-1
spectacle21.12.1.r1288.g27fc4d8-121.12.2.r1288.g27fc4d8-1
step21.12.1.r1169.gca9d6da-121.12.2.r1170.g271d980-1
svgpart21.12.1.r202.gf23c51b-121.12.2.r202.gf23c51b-1
sweeper21.12.1.r553.g975483f-121.12.2.r553.g975483f-1
systemsettings5.23.5.r2605.geceb4c53-15.23.5.r2611.g06df6b61-1
telepathy-kde-accounts-kcm21.12.1.r1206.g3ce3bd2-121.12.2.r1206.g3ce3bd2-1
telepathy-kde-approver21.12.1.r297.g2bb8456-121.12.2.r297.g2bb8456-1
telepathy-kde-auth-handler21.12.1.r279.gda5f3fe-121.12.2.r279.gda5f3fe-1
telepathy-kde-call-ui21.12.1.r446.g26d2798-121.12.2.r446.g26d2798-1
telepathy-kde-common-internals21.12.1.r1999.g8bebfc9-121.12.2.r1999.g8bebfc9-1
telepathy-kde-contact-list21.12.1.r1087.g9e69104-121.12.2.r1087.g9e69104-1
telepathy-kde-contact-runner21.12.1.r255.g9c4f404-121.12.2.r255.g9c4f404-1
telepathy-kde-desktop-applets21.12.1.r997.gccefd31-121.12.2.r997.gccefd31-1
telepathy-kde-filetransfer-handler21.12.1.r222.gd678e77-121.12.2.r222.gd678e77-1
telepathy-kde-integration-module21.12.1.r393.g8359889-121.12.2.r393.g8359889-1
telepathy-kde-send-file21.12.1.r231.ge70899f-121.12.2.r231.ge70899f-1
telepathy-kde-text-ui21.12.1.r2028.g61bd7eb-121.12.2.r2028.g61bd7eb-1
umbrello21.12.1.r8343.g4aaf3d9ba-121.12.2.r8350.g71d1bfab8-1
vvave 2.1.0.r22.g514ebe8-1 2.1.0.r27.g99ba93e-1
wrapland5.23.5.r1721.g68d65184-15.23.5.r1728.g10e55bd6-1
xdg-desktop-portal-kde5.23.5.r429.g33d8d36-15.23.5.r431.gb854798-1
yakuake21.12.1.r765.gea12c06-121.12.2.r765.gea12c06-1
zeroconf-ioslave21.12.1.r366.g06c00b7-121.12.2.r366.g06c00b7-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
