Quick heads up: Anti-Spam does not appear to be working after this update (works on fresh install of beta 21 with stable updates).
Downgrading gnome-calls from 42beta1+55+g3fe9765-1
to 42beta1+10+g12ac809-0
restores anti-spam functionality.
opened issue
Hi,
Today the Odroid C4 became this update, the device rebooted, no issue.
[nlc4@c4 ~]$ sudo pacman -Syu
[sudo] password for nlc4:
:: Synchronising package databases...
core 258,4 KiB 374 KiB/s 00:01 [##########################################] 100%
extra 2,4 MiB 874 KiB/s 00:03 [##########################################] 100%
community 6,4 MiB 897 KiB/s 00:07 [##########################################] 100%
:: Some packages should be upgraded first...
resolving dependencies...
Packages (1) manjaro-system-20220215-1
Total Download Size: 0,01 MiB
Total Installed Size: 0,00 MiB
Net Upgrade Size: 0,00 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
manjaro-system-20220215-1-any 7,7 KiB 22,6 KiB/s 00:00 [##########################################] 100%
(1/1) checking keys in keyring [##########################################] 100%
(1/1) checking package integrity [##########################################] 100%
(1/1) loading package files [##########################################] 100%
(1/1) checking for file conflicts [##########################################] 100%
(1/1) checking available disk space [##########################################] 100%
(1/1) upgrading manjaro-system [##########################################] 100%
==> Uninstalling redundant TLP...
Unlocking pacman database...
checking dependencies...
Packages (1) tlp-1.5.0-4
Total Removed Size: 0,44 MiB
:: Do you want to remove these packages? [Y/n]
removing tlp...
(1/3) Reloading system manager configuration...
(2/3) Reloading device manager configuration...
(3/3) Arming ConditionNeedsUpdate...
==> Switching system to use ModemManager...
Failed to disable unit: Unit file ofono.service does not exist.
==> Fixing file conflicts for 'zn_poly' update...
Packages (1) zn_poly-0.9.2-2
Total Download Size: 0,04 MiB
Total Installed Size: 0,12 MiB
zn_poly-0.9.2-2-aarch64 downloading...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing zn_poly...
(1/1) Arming ConditionNeedsUpdate...
==> Fixing file conflicts for 'hplip' update...
Packages (18) cups-filters-1.28.11-1 foomatic-db-engine-4:20200206-1 liblouis-3.20.0-2 perl-alien-build-2.46-1 perl-alien-libxml2-0.17-2 perl-capture-tiny-0.48-5 perl-dbi-1.643-3 perl-ffi-checklib-0.28-2 perl-file-chdir-0.1011-4 perl-file-which-1.27-1 perl-path-tiny-0.122-1 perl-xml-libxml-2.0207-2 perl-xml-namespacesupport-1.12-4 perl-xml-sax-1.02-1 perl-xml-sax-base-1.09-4 python-distro-1.6.0-4 qpdf-10.5.0-1 hplip-1:3.21.12-1
Total Download Size: 25,36 MiB
Total Installed Size: 54,55 MiB
hplip-1:3.21.12-1-aarch64 downloading...
liblouis-3.20.0-2-aarch64 downloading...
qpdf-10.5.0-1-aarch64 downloading...
cups-filters-1.28.11-1-aarch64 downloading...
perl-dbi-1.643-3-aarch64 downloading...
perl-alien-build-2.46-1-any downloading...
perl-xml-libxml-2.0207-2-aarch64 downloading...
foomatic-db-engine-4:20200206-1-aarch64 downloading...
perl-path-tiny-0.122-1-any downloading...
perl-xml-sax-1.02-1-any downloading...
python-distro-1.6.0-4-any downloading...
perl-xml-sax-base-1.09-4-any downloading...
perl-capture-tiny-0.48-5-any downloading...
perl-ffi-checklib-0.28-2-any downloading...
perl-file-which-1.27-1-any downloading...
perl-xml-namespacesupport-1.12-4-any downloading...
perl-file-chdir-0.1011-4-any downloading...
perl-alien-libxml2-0.17-2-any downloading...
checking keyring...
installing python-distro...
installing qpdf...
installing liblouis...
installing cups-filters...
Optional dependencies for cups-filters
ghostscript: for non-PostScript printers to print with CUPS to convert PostScript to raster images [installed]
foomatic-db: drivers use Ghostscript to convert PostScript to a printable form directly
foomatic-db-engine: drivers use Ghostscript to convert PostScript to a printable form directly [pending]
foomatic-db-nonfree: drivers use Ghostscript to convert PostScript to a printable form directly
antiword: to convert MS Word documents
docx2txt: to convert Microsoft OOXML text from DOCX files
installing perl-capture-tiny...
installing perl-ffi-checklib...
installing perl-file-chdir...
installing perl-file-which...
installing perl-path-tiny...
installing perl-alien-build...
installing perl-alien-libxml2...
installing perl-xml-sax-base...
installing perl-xml-namespacesupport...
installing perl-xml-sax...
installing perl-xml-libxml...
:: Installing SAX XML Parsers
installing perl-dbi...
installing foomatic-db-engine...
Optional dependencies for foomatic-db-engine
foomatic-db: linuxprinting.org xml files database to create ppd driver files
installing hplip...
Optional dependencies for hplip
cups: for printing support
sane: for scanner support [installed]
xsane: sane scanner frontend
python-pillow: for commandline scanning support
python-reportlab: for pdf output in hp-scan
rpcbind: for network support
python-pyqt5: for running GUI and hp-toolbox [installed]
libusb: for advanced usb support [installed]
wget: for network support [installed]
(1/6) Reloading system manager configuration...
(2/6) Reloading device manager configuration...
(3/6) Arming ConditionNeedsUpdate...
(4/6) Warn about old perl modules
(5/6) Updating the info directory file...
(6/6) Updating the desktop file MIME type cache...
warning: lock file missing /var/lib/pacman/db.lck
there is nothing to do
[nlc4@c4 ~]$ reboot
Should I modify the arm profiles build process or not ?
I mean, is $ sudo getarmprofiles -f
a new one ?
tlp stay or not ? wich package replace it
the KDE build file is looking so
# Other packages
openresolv
wget
tlp < = = ? it stay or not ? wich package replace it
flameshot
Strit
24
I always do a -f
once in a while, just to get the new stuff.
tlp
should be removed and replaced with power-profiles-daemon
when you update the profile.
Thanks for your reply, I try it now…
it’s ok, I confirm for KDE and LXQt arm profiles
# Other packages
openresolv
wget
flameshot
xdg-user-dirs
networkmanager-openvpn
firewalld
[nls@lap ~]$ sudo buildarmimg -d oc2 -e kde-plasma -v 2022.02.15-1 -b testing -n
power-profiles-daemon-0.10.1-2 powerdevil-5.23.5-1
Total Download Size: 0.02 MiB
Total Installed Size: 4623.87 MiB
Net Upgrade Size: 4621.39 MiB
power-profiles-d... 24.3 KiB 229 KiB/s 00:00 [######################] 100%
Odroid N2 LXQt up to date, so far it works.
VNC and samba are working well
I’m waiting on the next LXQt 1.1.0 release :-)
