[ARM Testing Update] 2021-09-11 - ModemManager, MMS for PP, LibreOffice, Python
Hello ARM community.
Rather a mobile focused update this time. Enjoy!
Modemmanager 1.18.0 got released for the Pinephone
Some highlights:
  • We update ModemManager for the PinePhone to 1.18.0
  • MMS related packages got updated
  • The stable version of LibreOffice is now at 7.1.6
  • Many python packages got updated
  • Lots of Mobile specific packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Sat Sep 11 09:20:43 CEST 2021)
  • arm-testing community aarch64: 87 new and 86 removed package(s)
  • arm-testing core aarch64: 5 new and 3 removed package(s)
  • arm-testing extra aarch64: 156 new and 158 removed package(s)
  • arm-testing kde-unstable aarch64: 64 new and 64 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE           2021-09-09           2021-09-11
                      chatty 0.4.0beta3+17+ga3cec69-1 0.4.0beta3+24+gebc1efc-1
                                code             1.59.1-1             1.60.0-1
               gnome-contacts-mobile             3.38.1-3               40.0-1
                       libmm-pp-glib 1.18rc1+28+gddaa4967-1           1.18.0-1
                            mmsd-tng              1.1.1-2                1.2-1
                     modemmanager-pp 1.18rc1+28+gddaa4967-1           1.18.0-1
                            pacutils           0.11.1-1.1             0.11.1-2
                               siglo              0.9.0-1              0.9.4-1
                                vvmd              0.3.1-2                0.4-1
                           vvmplayer                1.1-1              1.2.1-1
:: Different sync package(s) in repository community aarch64
                             bchoppr             1.10.8-1            1.10.10-1
                            binaryen              1:101-1              1:102-1
                          bsequencer              1.8.8-1             1.8.10-1
                             calibre             5.26.0-1             5.27.0-1
                       cataclysm-dda              0.F.1-1              0.F.2-1
                 cataclysm-dda-tiles              0.F.1-1              0.F.2-1
                             certbot             1.18.0-1             1.19.0-1
                         cni-plugins              1.0.0-1              1.0.1-1
                              crictl             1.21.0-1             1.22.0-1
                             critest             1.21.0-1             1.22.0-1
                                dart             2.14.0-1             2.14.1-1
                            dfu-util               0.10-2               0.10-3
                      dnscrypt-proxy             2.0.45-2              2.1.0-1
                               expac                 10-4                 10-5
                          fanficfare              4.3.0-1              4.5.0-1
                            feeluown             3.7.10-1             3.7.11-1
                             gnu-apl                1.8-2                1.8-3
                                  go             2:1.17-2           2:1.17.1-1
                               gopls              0.7.1-1              0.7.2-1
                                  io         2017.09.06-2         2017.09.06-3
                             jenkins              2.309-1              2.311-1
                      jupyter-server             1.10.2-1             1.11.0-1
                            kmymoney              5.1.2-1              5.1.2-2
                             libnids               1.24-5               1.24-6
                            libressl              3.3.3-1              3.3.4-1
                             libspf2             1.2.10-5             1.2.10-6
                             libtpms              0.8.5-1              0.8.5-2
                       libtraceevent            1:1.3.3-1            1:1.4.0-1
                             libwrap             7.6.31-1             7.6.31-2
                             log4cpp              1.1.3-3              1.1.3-4
                              marked              3.0.2-1              3.0.3-1
                           miniupnpd              2.2.2-1              2.2.3-1
                  nextcloud-app-deck            1:1.5.1-1            1:1.5.2-1
                      nginx-mainline             1.21.2-1             1.21.3-1
                  nginx-mainline-src             1.21.2-1             1.21.3-1
                              nodejs             16.9.0-1             16.9.1-1
                                 npm             7.22.0-1             7.23.0-1
                     owncloud-client         2.8.2.4246-1         2.9.0.5150-1
                           partclone             0.3.17-1             0.3.17-2
                         python-acme             1.18.0-1             1.19.0-1
                        python-anyio              3.3.0-1              3.3.1-1
                     python-cfn-lint             0.53.1-1             0.54.0-1
                 python-cinderclient              8.0.0-2              8.1.0-1
                     python-compiler                1.1-2                1.1-3
                      python-debugpy              1.4.1-2              1.4.3-1
                   python-deprecated             1.2.12-1             1.2.13-1
                   python-heatclient              2.3.0-1              2.4.0-1
                     python-identify             2.2.13-1             2.2.14-1
                python-jaeger-client              4.6.1-1              4.7.0-1
                       python-josepy              1.8.0-2              1.9.0-1
             python-oslo-concurrency              4.4.0-2              4.4.1-1
                    python-oslo-i18n              5.0.1-4              5.1.0-1
                   python-osprofiler              3.4.1-1              3.4.2-1
                    python-responses             0.13.4-1             0.14.0-1
                  python-ruamel-yaml            0.17.14-1            0.17.15-1
                    python-traitlets              5.0.5-1              5.0.5-2
                       python-xmlsec             1.3.11-1             1.3.12-1
              qt5-ukui-platformtheme              1.0.6-1              1.0.7-1
                           rpm-tools           4.16.1.3-1             4.17.0-1
                            rssguard              4.0.0-1              4.0.2-1
                rssguard-nowebengine              4.0.0-1              4.0.2-1
                             stunnel               5.60-1               5.60-2
                              stylus             0.54.8-1             0.55.0-1
                         sweethome3d                6.6-1                6.6-2
                            sylpheed              3.7.0-4              3.7.0-5
                           tailscale             1.14.0-1             1.14.2-1
                        tcp-wrappers             7.6.31-1             7.6.31-2
                          terragrunt             0.31.8-1            0.31.10-1
                              tickrs             0.14.5-1           2:0.14.4-1
                           uglify-js             3.14.1-1             3.14.2-1
         v2ray-domain-list-community     20210901054852-1     20210910080130-1
                         v2ray-geoip       202109060310-1       202109090028-1
                              wimlib             1.13.4-1             1.13.4-2
                           wordpress                5.8-1              5.8.1-1
                     yubikey-manager              4.0.5-1              4.0.7-1
                              zoxide              0.7.4-2              0.7.5-1
                        lucky-commit                    -              2.0.5-1
:: Different sync package(s) in repository core aarch64
                                gdbm               1.20-1               1.21-1
                              libcap               2.53-1               2.56-1
                              libnsl              1.3.0-2              2.0.0-1
                              python                    -              3.9.7-1
                        python-tests                    -              3.9.7-1
:: Different sync package(s) in repository extra aarch64
                               finch             2.14.6-1             2.14.6-2
                         fuse-common             3.10.4-1             3.10.5-1
                               fuse3             3.10.4-1             3.10.5-1
                             geoclue              2.5.7-3              2.5.7-4
                     gnome-documents 3.34.0+6+g966b04ec-13.34.0+34+g678141fa-1
                          libnss_nis                3.1-2                3.1-3
                              libpgf             7.19.3-2             7.21.7-1
                             libpqxx              7.5.2-1              7.6.0-1
                           libpurple             2.14.6-1             2.14.6-2
                   libreoffice-still              7.1.5-2              7.1.6-1
                libreoffice-still-af              7.1.5-1              7.1.6-1
                libreoffice-still-am              7.1.5-1              7.1.6-1
                libreoffice-still-ar              7.1.5-1              7.1.6-1
                libreoffice-still-as              7.1.5-1              7.1.6-1
               libreoffice-still-ast              7.1.5-1              7.1.6-1
                libreoffice-still-be              7.1.5-1              7.1.6-1
                libreoffice-still-bg              7.1.5-1              7.1.6-1
                libreoffice-still-bn              7.1.5-1              7.1.6-1
             libreoffice-still-bn-in              7.1.5-1              7.1.6-1
                libreoffice-still-bo              7.1.5-1              7.1.6-1
                libreoffice-still-br              7.1.5-1              7.1.6-1
               libreoffice-still-brx              7.1.5-1              7.1.6-1
                libreoffice-still-bs              7.1.5-1              7.1.6-1
                libreoffice-still-ca              7.1.5-1              7.1.6-1
       libreoffice-still-ca-valencia              7.1.5-1              7.1.6-1
               libreoffice-still-ckb              7.1.5-1              7.1.6-1
                libreoffice-still-cs              7.1.5-1              7.1.6-1
                libreoffice-still-cy              7.1.5-1              7.1.6-1
                libreoffice-still-da              7.1.5-1              7.1.6-1
                libreoffice-still-de              7.1.5-1              7.1.6-1
               libreoffice-still-dgo              7.1.5-1              7.1.6-1
               libreoffice-still-dsb              7.1.5-1              7.1.6-1
                libreoffice-still-dz              7.1.5-1              7.1.6-1
                libreoffice-still-el              7.1.5-1              7.1.6-1
             libreoffice-still-en-gb              7.1.5-1              7.1.6-1
             libreoffice-still-en-za              7.1.5-1              7.1.6-1
                libreoffice-still-eo              7.1.5-1              7.1.6-1
                libreoffice-still-es              7.1.5-1              7.1.6-1
                libreoffice-still-et              7.1.5-1              7.1.6-1
                libreoffice-still-eu              7.1.5-1              7.1.6-1
                libreoffice-still-fa              7.1.5-1              7.1.6-1
                libreoffice-still-fi              7.1.5-1              7.1.6-1
                libreoffice-still-fr              7.1.5-1              7.1.6-1
               libreoffice-still-fur              7.1.5-1              7.1.6-1
                libreoffice-still-fy              7.1.5-1              7.1.6-1
                libreoffice-still-ga              7.1.5-1              7.1.6-1
                libreoffice-still-gd              7.1.5-1              7.1.6-1
                libreoffice-still-gl              7.1.5-1              7.1.6-1
                libreoffice-still-gu              7.1.5-1              7.1.6-1
               libreoffice-still-gug              7.1.5-1              7.1.6-1
                libreoffice-still-he              7.1.5-1              7.1.6-1
                libreoffice-still-hi              7.1.5-1              7.1.6-1
                libreoffice-still-hr              7.1.5-1              7.1.6-1
               libreoffice-still-hsb              7.1.5-1              7.1.6-1
                libreoffice-still-hu              7.1.5-1              7.1.6-1
                libreoffice-still-id              7.1.5-1              7.1.6-1
                libreoffice-still-is              7.1.5-1              7.1.6-1
                libreoffice-still-it              7.1.5-1              7.1.6-1
                libreoffice-still-ja              7.1.5-1              7.1.6-1
                libreoffice-still-ka              7.1.5-1              7.1.6-1
               libreoffice-still-kab              7.1.5-1              7.1.6-1
                libreoffice-still-kk              7.1.5-1              7.1.6-1
                libreoffice-still-km              7.1.5-1              7.1.6-1
          libreoffice-still-kmr-latn              7.1.5-1              7.1.6-1
                libreoffice-still-kn              7.1.5-1              7.1.6-1
                libreoffice-still-ko              7.1.5-1              7.1.6-1
               libreoffice-still-kok              7.1.5-1              7.1.6-1
                libreoffice-still-ks              7.1.5-1              7.1.6-1
                libreoffice-still-lb              7.1.5-1              7.1.6-1
                libreoffice-still-lo              7.1.5-1              7.1.6-1
                libreoffice-still-lt              7.1.5-1              7.1.6-1
                libreoffice-still-lv              7.1.5-1              7.1.6-1
               libreoffice-still-mai              7.1.5-1              7.1.6-1
                libreoffice-still-mk              7.1.5-1              7.1.6-1
                libreoffice-still-ml              7.1.5-1              7.1.6-1
                libreoffice-still-mn              7.1.5-1              7.1.6-1
               libreoffice-still-mni              7.1.5-1              7.1.6-1
                libreoffice-still-mr              7.1.5-1              7.1.6-1
                libreoffice-still-my              7.1.5-1              7.1.6-1
                libreoffice-still-nb              7.1.5-1              7.1.6-1
                libreoffice-still-ne              7.1.5-1              7.1.6-1
                libreoffice-still-nl              7.1.5-1              7.1.6-1
                libreoffice-still-nn              7.1.5-1              7.1.6-1
                libreoffice-still-nr              7.1.5-1              7.1.6-1
               libreoffice-still-nso              7.1.5-1              7.1.6-1
                libreoffice-still-oc              7.1.5-1              7.1.6-1
                libreoffice-still-om              7.1.5-1              7.1.6-1
                libreoffice-still-or              7.1.5-1              7.1.6-1
             libreoffice-still-pa-in              7.1.5-1              7.1.6-1
                libreoffice-still-pl              7.1.5-1              7.1.6-1
                libreoffice-still-pt              7.1.5-1              7.1.6-1
             libreoffice-still-pt-br              7.1.5-1              7.1.6-1
                libreoffice-still-ro              7.1.5-1              7.1.6-1
                libreoffice-still-ru              7.1.5-1              7.1.6-1
                libreoffice-still-rw              7.1.5-1              7.1.6-1
             libreoffice-still-sa-in              7.1.5-1              7.1.6-1
               libreoffice-still-sat              7.1.5-1              7.1.6-1
                libreoffice-still-sd              7.1.5-1              7.1.6-1
               libreoffice-still-sdk              7.1.5-2              7.1.6-1
                libreoffice-still-si              7.1.5-1              7.1.6-1
               libreoffice-still-sid              7.1.5-1              7.1.6-1
                libreoffice-still-sk              7.1.5-1              7.1.6-1
                libreoffice-still-sl              7.1.5-1              7.1.6-1
                libreoffice-still-sq              7.1.5-1              7.1.6-1
                libreoffice-still-sr              7.1.5-1              7.1.6-1
           libreoffice-still-sr-latn              7.1.5-1              7.1.6-1
                libreoffice-still-ss              7.1.5-1              7.1.6-1
                libreoffice-still-st              7.1.5-1              7.1.6-1
                libreoffice-still-sv              7.1.5-1              7.1.6-1
             libreoffice-still-sw-tz              7.1.5-1              7.1.6-1
               libreoffice-still-szl              7.1.5-1              7.1.6-1
                libreoffice-still-ta              7.1.5-1              7.1.6-1
                libreoffice-still-te              7.1.5-1              7.1.6-1
                libreoffice-still-tg              7.1.5-1              7.1.6-1
                libreoffice-still-th              7.1.5-1              7.1.6-1
                libreoffice-still-tn              7.1.5-1              7.1.6-1
                libreoffice-still-tr              7.1.5-1              7.1.6-1
                libreoffice-still-ts              7.1.5-1              7.1.6-1
                libreoffice-still-tt              7.1.5-1              7.1.6-1
                libreoffice-still-ug              7.1.5-1              7.1.6-1
                libreoffice-still-uk              7.1.5-1              7.1.6-1
                libreoffice-still-uz              7.1.5-1              7.1.6-1
                libreoffice-still-ve              7.1.5-1              7.1.6-1
               libreoffice-still-vec              7.1.5-1              7.1.6-1
                libreoffice-still-vi              7.1.5-1              7.1.6-1
                libreoffice-still-xh              7.1.5-1              7.1.6-1
             libreoffice-still-zh-cn              7.1.5-1              7.1.6-1
             libreoffice-still-zh-tw              7.1.5-1              7.1.6-1
                libreoffice-still-zu              7.1.5-1              7.1.6-1
                            liburing                2.0-1                2.1-1
                          mjpegtools              2.2.0-1              2.2.1-1
                             ntfs-3g          2017.3.23-5          2021.8.22-1
                              ostree             2021.3-1             2021.4-1
                    perl-http-daemon               6.06-3               6.12-1
                              pidgin             2.14.6-1             2.14.6-2
                             postfix              3.6.2-1              3.6.2-2
                         postfix-cdb              3.6.2-1              3.6.2-2
                        postfix-ldap              3.6.2-1              3.6.2-2
                        postfix-lmdb              3.6.2-1              3.6.2-2
                       postfix-mysql              3.6.2-1              3.6.2-2
                        postfix-pcre              3.6.2-1              3.6.2-2
                       postfix-pgsql              3.6.2-1              3.6.2-2
                      postfix-sqlite              3.6.2-1              3.6.2-2
                              python              3.9.6-1                    -
                    python-packaging               20.9-1               20.9-2
                   python-setuptools           1:57.4.0-1           1:57.4.0-2
                        python-tests              3.9.6-1                    -
                             python2             2.7.18-3             2.7.18-4
                   python2-packaging               20.9-1               20.9-2
                                rust           1:1.54.0-1           1:1.55.0-1
                           rust-docs           1:1.54.0-1           1:1.55.0-1
                               samba             4.14.7-1             4.14.7-2
                           smbclient             4.14.7-1             4.14.7-2
                              snappy              1.1.9-1              1.1.9-2
                              strace               5.13-1               5.14-1
                            testdisk                7.1-2                7.1-3
                             varnish              6.6.1-1              6.6.1-2
                            xerces-c              3.2.3-3              3.2.3-4
:: Different overlay package(s) in repository kde-unstable aarch64
                           angelfish  21.08.r2.gd75eef2-1  21.08.r7.gd73b8a7-1
                           bluedevil1:5.22.5.r2277.g653e0b5c-11:5.22.5.r2278.g3a8288f0-1
                              breeze5.22.5.r2241.ge64c9aca-15.22.5.r2242.g3082f37f-1
                                buho  2.0.0.r4.g213f277-1  2.0.0.r5.g343a468-1
                     calendarsupport21.08.1.r27.gae7ce0e-121.08.1.r33.gbd875a6-1
                               elisa21.08.1.r2766.g3f8630cf-121.08.1.r2767.g2867b6f7-1
                          eventviews21.08.1.r28.g5cb693f-121.08.1.r31.g9f4e1b9-1
                            index-fm 2.0.0.r11.geb27369-1 2.0.0.r13.g9cb6e72-1
               kaccounts-integration21.08.1.r1215.gc8c7ed4-121.08.1.r1216.g7129f5d-1
                                kalk  21.08.r0.gcd8b9de-1  21.08.r2.g2150b10-1
                               kasts  21.08.r1.g8a57c1e-1  21.08.r7.g938a517-1
                          kdeconnect21.08.1.r3316.g1662179b-121.08.1.r3317.gd09dae15-1
                      kdepim-runtime21.08.1.r15272.gbded29022-121.08.1.r15273.gdbb3912c8-1
                          kio-extras21.08.1.r7110.g1d752c04-121.08.1.r7113.g196c4186-1
                           kirigami25.85.0.r2884.g9cb846a6-15.85.0.r2885.g95d68f9c-1
                               kmail21.08.1.r25954.gf8b603d7f-121.08.1.r25955.g5873e1bab-1
                           knewstuff5.85.0.r1202.g36c87be2-15.85.0.r1203.g9009aacb-1
                                koko  21.08.r1.gf5a484a-1  21.08.r4.g4437b03-1
                             kompare21.08.1.r1108.g7c0c2ba-121.08.1.r1110.gf2915d1-1
                            kongress  21.08.r1.gdab8bec-1  21.08.r2.gbd051df-1
                             konsole21.08.1.r7935.gfed1a9d2-121.08.1.r7940.gaa390e15-1
                       kosmindoormap21.08.1.r644.g0f6c059-121.08.1.r645.geca22a5-1
                    kpublictransport21.08.1.r1809.gcb34262f-121.08.1.r1812.g7fb16beb-1
                   kquickimageeditor       r54.gf34e8b4-1       r56.g9273b40-1
                           krecorder  21.08.r0.g3133d3c-1  21.08.r2.gb7676d0-1
                             kscreen5.22.5.r1349.g52f4bf6-15.22.5.r1350.g96d17b1-1
                       kscreenlocker5.22.5.r868.g7e2e549-15.22.5.r869.g1595241-1
                          ksystemlog21.08.1.r657.gfd6a0cc-121.08.1.r659.g83fd7a3-1
                     kwayland-server5.22.5.r1382.g56f201b-15.22.5.r1384.g955bcd0-1
                                kwin5.22.5.r19964.g16f5ce936-15.22.5.r19971.gd5be2232e-1
                              kwinft5.22.4.r19271.g7130ecce4-15.22.4.r19295.g053293198-1
                        libksysguard5.22.5.r2297.g9d91ea2-15.22.5.r2301.g88911f4-1
                         libquotient     r2080.g9ec9f5c-1     r2081.g9e548e0-1
                          mailcommon21.08.1.r1108.gf489d52-121.08.1.r1109.gaada67e-1
                        mailimporter21.08.1.r472.ge2281ed-121.08.1.r473.g45e02ff-1
                    maliit-framework0.99.1.r65.g2d2b7ac3-10.99.1.r69.g0eccc64f-1
                           maui-clip  2.0.0.r5.g343336b-1  2.0.0.r6.g2a69c67-1
                           maui-nota  2.0.0.r5.gedc2e3c-1  2.0.0.r6.g9689cfc-1
                             mauikit 2.0.1.r4.g9af13683-1 2.0.1.r6.gf2e4a212-1
                       mbox-importer21.08.1.r514.g0430e77-121.08.1.r515.g2f07864-1
                          messagelib21.08.1.r6161.gd7ba88b5-121.08.1.r6169.g4327f9ac-1
                             neochat    r1845.g8d59e2ba-1    r1850.g7dc48cab-1
                              okular21.08.1.r9454.g21f96680a-121.08.1.r9456.g8ea7214b0-1
                   pim-data-exporter21.08.1.r2449.g9e1ac191-121.08.1.r2451.gaf562344-1
                           pimcommon21.07.80.r1101.g1151f4d-121.07.80.r1104.gcc3043e-1
                       plasma-camera  1.0.r105.g96e682d-1  1.0.r106.g4fcd01e-1
                      plasma-desktop5.22.5.r8600.gc03d5deeb-15.22.5.r8603.g4ba3ca699-1
                     plasma-firewall5.22.5.r507.g01effba-15.22.5.r508.g5b5d64d-1
                    plasma-mobile-nm5.22.3.r3088.g85501e87-15.22.3.r3089.gcf60c53e-1
                    plasma-phonebook  21.08.r5.g277789e-1  21.08.r6.g7ab0b99-1
                     plasma-settings  21.08.r1.g5503a2b-1  21.08.r2.g50c5dbd-1
                plasma-systemmonitor5.22.5.r482.gf5c01df-15.22.5.r483.g4da01f9-1
                  plasma-thunderbolt5.22.5.r137.g6a6176d-15.22.5.r138.ge4a69fc-1
            plasma-wayland-protocols1.3.0.r1035.gefc0d76-11.3.0.r1036.g07e6f76-1
              plasma-wayland-session5.22.5.r10620.g9189bfea0-15.22.5.r10621.gefa083ff8-1
                    plasma-workspace5.22.5.r10620.g9189bfea0-15.22.5.r10621.gefa083ff8-1
                          powerdevil5.22.5.r2466.g0b843fe2-15.22.5.r2467.g2063de73-1
                       print-manager21.08.1.r1036.g25d47cd-121.08.1.r1038.ge09f179-1
                          qmlkonsole  21.08.r5.ge268c2f-1  21.08.r6.g8f53d7d-1
                            sddm-kcm5.22.5.r595.g95c49e0-15.22.5.r596.g7e44ccb-1
                            spacebar  21.08.r1.g138f5e7-1  21.08.r2.g5bd9368-1
                            umbrello21.08.1.r8261.g8ac7e25df-121.08.1.r8262.g0457a2ebb-1
                               vvave 2.0.0.r16.g7199c63-1 2.0.0.r17.gada7ee6-1
                            wrapland5.22.4.r1583.gb1c532a-15.22.4.r1595.g52ae265-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been fixed yet.
Fix: Update to linux-5.14.1-2 or newer.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Fix: Vivaldi 4.1.2369.21 fixed this issue.
Old Issues
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
I pushed some more packages, which includes chatty 0.4.0 and Pamac 10.2.
### BoxIt memo ###
User philip created a snapshot of branch 'arm-unstable' to 'arm-testing'.
 - arm-testing community aarch64:  1 new and 1 removed package(s)
 - arm-testing extra aarch64:  6 new and 6 removed package(s)
 - arm-testing kde-unstable aarch64:  68 new and 68 removed package(s)
                              chatty 0.4.0beta3+24+gebc1efc-1          0.4.0-1
:: Different overlay package(s) in repository extra aarch64
                            libpamac             11.0.1-2             11.1.0-1
             libpamac-flatpak-plugin             11.0.1-2             11.1.0-1
                libpamac-snap-plugin             11.0.1-2             11.1.0-1
                           pamac-cli             10.1.3-3             10.2.0-1
             pamac-gnome-integration             10.1.3-3             10.2.0-1
                           pamac-gtk             10.1.3-3             10.2.0-1
                             akonadi21.08.1.r12570.gfcf2e70f6-121.08.1.r12572.gd266e41b7-1
                    akonadi-calendar21.08.1.r1983.gfde63cc-121.08.1.r1984.g1192e6d-1
                    akonadi-contacts21.08.1.r3060.gbc611980-121.08.1.r3061.g94013a3a-1
                        akonadi-mime21.08.1.r1645.g63d3ceb-121.08.1.r1648.g3dd0baa-1
                      akonadi-search21.08.1.r1125.g9b17159-121.08.1.r1126.gf440581-1
                      akonadiconsole21.08.1.r1525.g848d3fa-121.08.1.r1526.g89dc082-1
                           bluedevil1:5.22.5.r2278.g3a8288f0-11:5.22.5.r2279.ga4e945f6-1
                        breeze-icons5.85.0.r1787.ged790d1a-15.85.0.r1788.gc612c124-1
                               elisa21.08.1.r2767.g2867b6f7-121.08.1.r2768.g0dd33183-1
                          eventviews21.08.1.r31.g9f4e1b9-121.08.1.r35.g848313a-1
                 extra-cmake-modules5.85.0.r3363.g6561e3a-15.85.0.r3364.g2bd7db9-1
                            gwenview21.08.1.r6660.ge8efe118-121.08.1.r6662.g33d6203c-1
               kaccounts-integration21.08.1.r1216.g7129f5d-121.08.1.r1217.g08642e1-1
                        kaddressbook21.08.1.r6039.g780193f5-121.08.1.r6040.g62ccc2ec-1
                              kalarm21.08.1.r6462.g1f83aa16-121.08.1.r6463.g0af8aa34-1
                           kalarmcal21.08.1.r1144.gae6dc9c-121.08.1.r1145.g4deaf3c-1
                              kamera21.08.1.r664.gf261878-121.08.1.r665.gd8ad7f5-1
                             kapidox5.85.0.r552.g9d1f94c-15.85.0.r553.g8ac0bf3-1
                            kcmutils5.85.0.r546.g69d97cc-15.85.0.r547.g6791d37-1
                         kcoreaddons5.85.0.r1290.g30a10900-15.85.0.r1292.g49d1ce7f-1
                          kdeconnect21.08.1.r3317.gd09dae15-121.08.1.r3319.g1f2d7139-1
                      kdepim-runtime21.08.1.r15273.gdbb3912c8-121.08.1.r15275.g6ef03229b-1
                                 kio5.85.0.r4963.g2abb3fa9-15.85.0.r4964.g36a715f5-1
                          kio-extras21.08.1.r7113.g196c4186-121.08.1.r7114.g8f4329cc-1
                          kitinerary21.08.1.r1932.g34d03bb-121.08.1.r1933.g1cf310b-1
                           kleopatra21.08.1.r5989.g69f69c15-121.08.1.r5991.gba72eade-1
                               kmail21.08.1.r25955.g5873e1bab-121.08.1.r25957.g3fd1720a9-1
                kmail-account-wizard21.08.1.r814.gf4cbf1e-121.08.1.r815.g01d3c34-1
                      kmailtransport21.08.1.r1655.g24e9b08-121.08.1.r1656.g08cf010-1
                              knotes21.08.1.r3515.g97ff7da1-121.08.1.r3516.g6cf6d5b7-1
                       kosmindoormap21.08.1.r645.geca22a5-121.08.1.r646.g8242cb2-1
                    kpublictransport21.08.1.r1812.g7fb16beb-121.08.1.r1817.gb30533b3-1
                                krfb21.08.1.r1415.gdf9e6d6-121.08.1.r1416.gf72674d-1
                             kscreen5.22.5.r1350.g96d17b1-15.22.5.r1351.g00ee9bc-1
                       kscreenlocker5.22.5.r869.g1595241-15.22.5.r870.g9c64959-1
                             ksudoku21.08.1.r1052.g6fe6bb1-121.08.1.r1056.g6a7a8b0-1
                             kturtle21.08.1.r1122.gc2dff90-121.08.1.r1123.g44cc22d-1
                kwayland-integration5.22.5.r185.g2f5d482-15.22.5.r186.g11769dd-1
                     kwayland-server5.22.5.r1384.g955bcd0-15.22.5.r1386.ga6a4760-1
                                kwin5.22.5.r19971.gd5be2232e-15.22.5.r19983.g5f306ae93-1
                          libakonadi21.08.1.r12570.gfcf2e70f6-121.08.1.r12572.gd266e41b7-1
                            libkgapi21.04.3.r1289.g258301b-121.08.1.r1296.gad7e812-1
                            libksane21.08.1.r558.gf135f4a-121.08.1.r561.gd9ab411-1
                          mailcommon21.08.1.r1109.gaada67e-121.08.1.r1110.g92934a8-1
                             mauikit 2.0.1.r6.gf2e4a212-1 2.0.1.r7.gfbb3e9da-1
                mauikit-filebrowsing  2.0.1.r1.g301faba-1  2.0.1.r3.g7ec385a-1
                       mbox-importer21.08.1.r515.g2f07864-121.08.1.r516.g42efae8-1
                          messagelib21.08.1.r6169.g4327f9ac-121.08.1.r6171.gec09b1f7-1
                     modemmanager-qt5.85.0.r521.g32e62f7-15.85.0.r522.g1f540d3-1
                             neochat    r1850.g7dc48cab-1    r1851.g35b88de5-1
                              okular21.08.1.r9456.g8ea7214b0-121.08.1.r9465.g7ae4288f3-1
                           pimcommon21.07.80.r1104.gcc3043e-121.07.80.r1106.ge73d898-1
                      plasma-desktop5.22.5.r8603.g4ba3ca699-15.22.5.r8605.g271df2d7b-1
                        plasma-disks5.22.5.r227.gcc30860-15.22.5.r229.g920cbc0-1
                     plasma-firewall5.22.5.r508.g5b5d64d-15.22.5.r509.gf8f3ba5-1
             plasma-phone-components5.22.5.r1459.g1de0f3ec-15.22.5.r1462.g30344fd6-1
                     plasma-settings  21.08.r2.g50c5dbd-1  21.08.r3.g3c44ea6-1
                  plasma-thunderbolt5.22.5.r138.ge4a69fc-15.22.5.r139.g1a11f04-1
                        plasma-vault5.22.5.r341.g3cb86f4-15.22.5.r342.g83b045a-1
              plasma-wayland-session5.22.5.r10621.gefa083ff8-15.22.5.r10627.g6869c5292-1
                    plasma-workspace5.22.5.r10621.gefa083ff8-15.22.5.r10627.g6869c5292-1
         plasma-workspace-wallpapers5.22.5.r282.g1a81932-15.22.5.r283.g2c3ee31-1
                          powerdevil5.22.5.r2467.g2063de73-15.22.5.r2468.g7855e6fb-1
                       print-manager21.08.1.r1038.ge09f179-121.08.1.r1039.gc5b8d91-1
                            sddm-kcm5.22.5.r596.g7e44ccb-15.22.5.r597.ge2f66e7-1
                           spectacle21.08.1.r1165.ga4f7dfb-121.08.1.r1167.gf89f2bc-1
                            umbrello21.08.1.r8262.g0457a2ebb-121.08.1.r8263.g0372f89d7-1
              xdg-desktop-portal-kde5.22.5.r382.g7cfe798-15.22.5.r383.gdbb4364-1
Some more packages …
### BoxIt memo ###
 - arm-testing community aarch64:  2 new and 1 removed package(s)
 - arm-testing extra aarch64:  1 new and 1 removed package(s)
 - arm-testing kde-unstable aarch64:  126 new and 126 removed package(s)
                             PACKAGE          arm-testing         arm-unstable
            pinephone-manjaro-tweaks           20210909-1           20210911-1
            pamac-mobile-integration                    -           20210912-3
                   calamares-arm-oem           20210903-1           20210911-1
                             akonadi21.08.1.r12572.gd266e41b7-121.08.1.r12575.g7cc57d6a2-1
               akonadi-import-wizard21.08.1.r1738.g9419065-121.08.1.r1739.gf5e8060-1
                           angelfish  21.08.r7.gd73b8a7-1  21.08.r9.gf8e31f6-1
                          artikulate21.08.1.r1389.g8c87655-121.08.1.r1390.g78f1bbb-1
                              attica5.85.0.r833.g921f663-15.85.0.r834.g0dbf2b6-1
                               baloo5.85.0.r3007.g76b61d36-15.85.0.r3008.g8909640a-1
                           bluedevil1:5.22.5.r2279.ga4e945f6-11:5.22.5.r2280.gde1e0734-1
                            bluez-qt5.85.0.r678.gc19c35f-15.85.0.r679.gba3af75-1
                        breeze-icons5.85.0.r1788.gc612c124-15.85.0.r1789.g9089f648-1
                          eventviews21.08.1.r35.g848313a-121.08.1.r37.g755eaa6-1
                 extra-cmake-modules5.85.0.r3364.g2bd7db9-15.85.0.r3365.g4282b34-1
                frameworkintegration5.85.0.r597.gecedf87-15.85.0.r598.g0a57fd9-1
                           itinerary21.08.1.r1448.ga779d04-121.08.1.r1449.gb408488-1
               kaccounts-integration21.08.1.r1217.g08642e1-121.08.1.r1218.g3a0486d-1
                         kactivities5.85.0.r1362.gedc455b-15.85.0.r1363.g207c2dc-1
                   kactivities-stats5.85.0.r371.g9e99d0c-15.85.0.r372.g195fbd2-1
                            karchive5.85.0.r506.g8385306-15.85.0.r507.g858a749-1
                                kate21.08.1.r18342.g834e06e7d-121.08.1.r18345.g2636bb3a9-1
                               kauth5.85.0.r448.g1016ded-15.85.0.r449.ga6a0c5a-1
                          kbookmarks5.85.0.r421.gfb2c00a-15.85.0.r422.g7d0378a-1
                       kcalendarcore5.85.0.r1238.g4d457484e-15.85.0.r1239.g10cfe8918-1
                            kcmutils5.85.0.r547.g6791d37-15.85.0.r548.g5e7c27f-1
                             kcodecs5.85.0.r385.g1a1e609-15.85.0.r386.g5e7feae-1
                         kcompletion5.85.0.r456.g887dac0-15.85.0.r457.g04f8bcb-1
                             kconfig5.85.0.r862.g3691e4f-15.85.0.r863.g7827501-1
                      kconfigwidgets5.85.0.r620.g1c535d8-15.85.0.r621.g652be62-1
                           kcontacts1:5.85.0.r3253.g100bbb25-11:5.85.0.r3254.g7ff774b3-1
                              kcrash5.85.0.r408.gf006b6f-15.85.0.r409.gf0a9e01-1
                                kdav1:5.85.0.r1299.g60fa2f6-11:5.85.0.r1300.gbb550f6-1
                         kdbusaddons5.85.0.r379.g901a435-15.85.0.r380.g54bc427-1
                        kdeclarative5.85.0.r921.g3583b5a-15.85.0.r922.gbfe8ca1-1
                          kdeconnect21.08.1.r3319.g1f2d7139-121.08.1.r3321.gdb697c56-1
                                kded5.85.0.r417.g7374a57-15.85.0.r418.gb278fc4-1
                     kdelibs4support5.85.0.r1036.g457d0509-15.85.0.r1037.g34b4edc2-1
                     kdesignerplugin5.85.0.r335.g36087aa-15.85.0.r336.g9733059-1
                               kdesu5.85.0.r475.gc8a8e38-15.85.0.r476.ge88b633-1
                           kdewebkit5.85.0.r282.gb686bcf-15.85.0.r283.g787f1a3-1
                              kdnssd5.85.0.r325.g2f11bd7-15.85.0.r326.g695a135-1
                           kdoctools5.85.0.r628.g28667e1-15.85.0.r629.gfbd4377-1
                          kemoticons5.85.0.r386.ge98dbf3-15.85.0.r387.g1c526eb-1
                       kfilemetadata5.85.0.r808.g92f2295-15.85.0.r809.gec8cde7-1
                        kglobalaccel5.85.0.r467.gadea064-15.85.0.r468.gc5ee700-1
                          kguiaddons5.85.0.r390.g3325717-15.85.0.r391.ga846d64-1
                           kholidays1:5.85.0.r958.g37b9c86-11:5.85.0.r959.g3a5164e-1
                               khtml5.85.0.r557.ge915e4c-15.85.0.r558.g5756c1e-1
                               ki18n5.85.0.r479.gb144562-15.85.0.r480.g8a8d70c-1
                         kiconthemes5.85.0.r543.g1b50a3c-15.85.0.r544.gf721a67-1
                           kidletime5.85.0.r317.g00e79dc-15.85.0.r318.geb71712-1
                         kinfocenter5.22.5.r1921.g3cb20ad-15.22.5.r1922.g003f003-1
                               kinit5.85.0.r412.gf92a618-15.85.0.r413.ga0c6715-1
                                 kio5.85.0.r4964.g36a715f5-15.85.0.r4965.gae2f5eb9-1
                          kio-extras21.08.1.r7114.g8f4329cc-121.08.1.r7115.g90d10ae7-1
                           kirigami25.85.0.r2885.g95d68f9c-15.85.0.r2886.g07abb970-1
                         kitemmodels5.85.0.r558.ga0b0db1-15.85.0.r559.gfa3b693-1
                          kitemviews5.85.0.r340.g4902bd2-15.85.0.r341.g39dc29e-1
                          kitinerary21.08.1.r1933.g1cf310b-121.08.1.r1934.g1864c3e-1
                         kjobwidgets5.85.0.r378.gaaff19c-15.85.0.r379.ge71984a-1
                                 kjs5.85.0.r336.g96b7c1b-15.85.0.r337.g2cf609d-1
                            kjsembed5.85.0.r305.gf506dc9-15.85.0.r306.gaaf5dd2-1
                kmail-account-wizard21.08.1.r815.g01d3c34-121.08.1.r816.g9cadf59-1
                        kmediaplayer5.85.0.r296.gaeed11a-15.85.0.r297.g7315fa5-1
                            knetwalk21.08.1.r658.ged8d6c5-121.08.1.r659.gf294dfd-1
                           knewstuff5.85.0.r1203.g9009aacb-15.85.0.r1204.g5c08bbb3-1
                      knotifications5.85.0.r679.g1d73ea7-15.85.0.r680.g471bd77-1
                       knotifyconfig5.85.0.r354.g3f81983-15.85.0.r355.gee646b9-1
                           konqueror21.08.1.r14935.g7754bd4e7-121.08.1.r14936.g80c20b528-1
                             konsole21.08.1.r7940.gaa390e15-121.08.1.r7941.gab25bd0a-1
                       kosmindoormap21.08.1.r646.g8242cb2-121.08.1.r647.g14f654a-1
                            kpackage5.85.0.r698.g9db62a6-15.85.0.r699.g3e01da3-1
                              kparts5.85.0.r526.g5be87a5-15.85.0.r527.gcb16108-1
                             kpeople5.85.0.r1345.gf218f48-15.85.0.r1346.g96ddb92-1
                           kplotting5.85.0.r295.g515f017-15.85.0.r296.g3060059-1
                                kpty5.85.0.r342.gde58c1d-15.85.0.r343.g75750f0-1
                    kpublictransport21.08.1.r1817.gb30533b3-121.08.1.r1836.gc41cbf5e-1
                        kquickcharts5.85.0.r479.gdfe0e74-15.85.0.r480.g627c40f-1
                               kross5.85.0.r336.gf97bdaf-15.85.0.r337.g7db053c-1
                             krunner5.85.0.r669.g172da4e-15.85.0.r670.gd53c5c2-1
                             kscreen5.22.5.r1351.g00ee9bc-15.22.5.r1352.g7b2ecb9-1
                       kscreenlocker5.22.5.r870.g9c64959-15.22.5.r871.g7157c9a-1
                            kservice5.85.0.r943.g332d979-15.85.0.r944.g927daaf-1
                         ktexteditor5.85.0.r2941.g4955f8c8-15.85.0.r2942.g6fae77cf-1
                        ktextwidgets5.85.0.r413.g676a32f-15.85.0.r414.g8901446-1
                     kunitconversion5.85.0.r377.ga73d698-15.85.0.r378.g6e34b50-1
                             kwallet5.85.0.r1090.gf8fc9d9-15.85.0.r1091.gf379e5f-1
                            kwayland5.85.0.r1113.g4fbfad6-15.85.0.r1114.gc662581-1
                      kwidgetsaddons5.85.0.r873.g54d85c98-15.85.0.r874.g05a6fcfd-1
                                kwin5.22.5.r19983.g5f306ae93-15.22.5.r19986.gabe6b4153-1
                       kwindowsystem5.85.0.r627.g3563ed0-15.85.0.r628.g5d08848-1
                              kwrite21.08.1.r18342.g834e06e7d-121.08.1.r18345.g2636bb3a9-1
                             kxmlgui5.85.0.r805.gbe808a4e-15.85.0.r808.g319b9318-1
                       kxmlrpcclient5.85.0.r457.ge48022fb4-15.85.0.r458.ga1ec55b43-1
                          libakonadi21.08.1.r12572.gd266e41b7-121.08.1.r12575.g7cc57d6a2-1
                        libksysguard5.22.5.r2301.g88911f4-15.22.5.r2302.g8f49602-1
                          mailcommon21.08.1.r1110.g92934a8-121.08.1.r1112.gbc29098-1
                    maliit-framework0.99.1.r69.g0eccc64f-10.99.1.r71.g3ef56e25-1
                     maliit-keyboard    r2103.g430c8326-1    r2105.ge373c9fc-1
                              marble21.08.1.r13327.gb20787a0c-121.08.1.r13328.gdfb3d905d-1
                       marble-common21.08.1.r13327.gb20787a0c-121.08.1.r13328.gdfb3d905d-1
                           marble-qt21.08.1.r13327.gb20787a0c-121.08.1.r13328.gdfb3d905d-1
                          messagelib21.08.1.r6171.gec09b1f7-121.08.1.r6179.ge28d6ce3-1
                     modemmanager-qt5.85.0.r522.g1f540d3-15.85.0.r523.gc4fd1f1-1
                             neochat    r1851.g35b88de5-1    r1858.gaf299257-1
                   networkmanager-qt5.85.0.r1120.gd8e33e6-15.85.0.r1121.g95baae9-1
                              okular21.08.1.r9465.g7ae4288f3-121.08.1.r9466.g3a513f34b-1
                       plasma-camera  1.0.r106.g4fcd01e-1  1.0.r108.g54c9966-1
                      plasma-desktop5.22.5.r8605.g271df2d7b-15.22.5.r8607.g81dbc710b-1
                     plasma-firewall5.22.5.r509.gf8f3ba5-15.22.5.r510.g6558f6c-1
                    plasma-framework5.85.0.r15978.gbddd5ff15-15.85.0.r15979.gb869a784a-1
                    plasma-mobile-nm5.22.3.r3089.gcf60c53e-15.22.3.r3090.g06eacc57-1
                           plasma-nm5.22.5.r3089.gcf60c53e-15.22.5.r3090.g06eacc57-1
                           plasma-pa5.22.5.r963.g7ccfe07-15.22.5.r964.ga54c0e6-1
                  plasma-thunderbolt5.22.5.r139.g1a11f04-15.22.5.r140.g4c9d324-1
              plasma-wayland-session5.22.5.r10627.g6869c5292-15.22.5.r10631.g368143329-1
                    plasma-workspace5.22.5.r10627.g6869c5292-15.22.5.r10631.g368143329-1
                          powerdevil5.22.5.r2468.g7855e6fb-15.22.5.r2469.g7b7e37df-1
                       print-manager21.08.1.r1039.gc5b8d91-121.08.1.r1040.g710cbb9-1
                              prison5.85.0.r332.g4fd34cf-15.85.0.r333.g9105c2d-1
                             purpose5.85.0.r879.gb867c66-15.85.0.r880.g32bb1ad-1
                  qqc2-desktop-style5.85.0.r522.g372d2d1-15.85.0.r523.g316fed5-1
                            sddm-kcm5.22.5.r597.ge2f66e7-15.22.5.r598.g9022354-1
                               solid5.85.0.r706.gb9b32db-15.85.0.r707.g483eba0-1
                              sonnet5.85.0.r633.gd7fc220-15.85.0.r634.gff5ae47-1
                         syndication5.85.0.r840.ge3f49c4-15.85.0.r841.gec613d1-1
                 syntax-highlighting5.85.0.r1695.g94a836af-15.85.0.r1696.gd277eb41-1
                        threadweaver5.85.0.r511.g30d66fc-15.85.0.r512.gd9c6fbc-1
                            umbrello21.08.1.r8263.g0372f89d7-121.08.1.r8264.g7a8d1cfb0-1
Hi,
Odroid c4 kde up to date.
I’ll try to build and test images for the Odroid c2 and n2 as soon as possible, user feedback later.
what is calamares-arm-oem ?
the same as the 21.08 release ?
Introducing Calamares
With this release we introduce Calamares as our new First Time Setup tool.
Calamares is a QT based graphical application for setting locale, keyboard layout, User information, timezone and so forth.
This also means, that SSH can no longer be used to setup the system on GUI editions.
@Strit
I built kde image for the odroid c2 and n2.
Both devices are booting without issue.
No issue with the odroid c2, samba and vnc are working well.
Issue with the odroid n2, samba and vnc are not working. mentioned for several months.
I can’t change with pamac the “use mirrors from”, it’s fixed by default on worldwide, I can’t choose a wished country. This pamac bug is new and not present on c2 and c4 devices.
Again, this is not something I know how to fix. I don’t use any of it.
What do you mean it’s fixed on Worldwide? It’s a context menu, so you should be able to choose your Country in it. If you can’t, do you have a recent mirrorlist?
You can get one with sudo pacman-mirrors -f
Thanks for your reply.
To set some parameter and then to use pacman I change the repo country, on the n2 I can’t do that with pamac, see below it is looking so.
thanks for the solution with sudo pacman...
The n2 have some issue for the moment :cry:
Have you tried clicking where it says “Worldwide”?
Your theme does not indicate it’s a menu item.
For sure, I clicked on the worldwide text and around the text.
I changed the theme, it’s solved, thanks a lot.
Has the Ethernet issue for rk3399 (e.g. Pinebook Pro) been resolved by now? It says update to new kernel, is this new kernel in this package ?
Correct. We reverted the offending commit in our kernel package.
