Hello ARM community.
The 21.08 release is near, so lets get in some more new stuff!
Some highlights:
- Most of our kernels got updated
- KDE Frameworks is now on version 5.85.0
- Updated most of our themes, like Breath2 and Matcha
- Element, the popular Matrix client reached version 1.8.1
- Lots of Mobile specific packages got updated
- Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Older notifications
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes
(Wed Aug 18 16:14:33 CEST 2021)
- arm-testing community aarch64: 156 new and 150 removed package(s)
- arm-testing core aarch64: 13 new and 13 removed package(s)
- arm-testing extra aarch64: 123 new and 122 removed package(s)
- arm-testing kde-unstable aarch64: 353 new and 355 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-08-13 2021-08-18
amazfish 1.9.5-1.2 2.0.2-1
anbox 0_git20210320-3 0_git20210320-4
breath2-icon-themes 1.0.18-2 1.0.18-4
breath2-wallpaper 1.0.18-2 1.0.18-4
electron 13.1.9-1 13.2.1-1
electron11 11.4.10-1 11.4.12-1
electron12 12.0.16-1 12.0.17-1
element-desktop 1.7.34-1 1.8.1-1
element-web 1.7.34-1 1.8.1-1
gnome-control-center-mobile 3.38.6-1 3.38.6-2
gnome-initial-setup-mobile 3.36.4-2 3.38.5-1
handbrake 1.4.0-1 1.4.1-1
handbrake-cli 1.4.0-1 1.4.1-1
inxi 3.3.05.1-1 3.3.06.1-1
libarchive-qt 2.0.4-2 2.0.6-1
manjaro-arm-installer 1.4.5-1 1.4.7-1
matcha-gtk-theme 20210708-1 20210802-1
plasma5-themes-breath2 1.0.18-2 1.0.18-4
sddm-breath2-theme 1.0.18-2 1.0.18-4
snapd 2.51.4-1 2.51.5-1
:: Different sync package(s) in repository community aarch64
aws-cli 1.20.2-1 1.20.21-1
b4 0.7.2-1 0.7.3-1
benchmark 1.5.5-1 1.5.6-1
binwalk 2.3.1-1 2.3.2-1
cataclysm-dda 0.F-1 0.F.1-1
cataclysm-dda-tiles 0.F-1 0.F.1-1
clasp 3.3.5-2 3.3.6-1
clojure 1.10.3.933-2 1.10.3.943-1
croc 9.2.1-1 9.3.0-1
dnsperf 2.6.0-1 2.7.0-1
dovecot 2.3.15-2 2.3.16-1
dovecot-fts-elastic 1.0.0-5 1.0.0-6
dovecot-fts-xapian 1.4.11-1 1.4.12-2
eid-mw 5.0.27-2 5.0.28-1
emscripten 2.0.26-1 2.0.27-1
firefox-tree-style-tab 3.8.8-1 3.8.11-1
firewalld 1.0.0-3 1.0.1-1
fluxctl 1.23.1-1 1.23.2-1
gala 6.0.0-4 6.0.1-1
geda-gaf 1.10.0-1 1.10.2-1
glider 0.14.0-1 0.15.0-1
gnuchess 6.2.8-1 6.2.9-1
go 2:1.16.7-1 2:1.17-1
go-ethereum 1.10.6-1 1.10.7-1
grpc 1.39.0-1 1.39.1-1
grpc-cli 1.39.0-1 1.39.1-1
hcloud 1.26.1-1 1.27.0-1
helix 0.3.0-4 0.4.1-1
home-assistant 2021.8.4-1 2021.8.6-1
i2c-tools 4.2-1 4.2-3
ibus-m17n 1.4.6-1 1.4.7-1
kicad 5.1.9-1 5.1.10-2
kitty 0.22.2-1 0.23.1-1
kitty-terminfo 0.22.2-1 0.23.1-1
lesspipe 1.87-1 1.88-1
libgexiv2 0.12.2-1 0.12.3-1
libmilter 8.15.2-3 8.17.1-1
libvips 8.11.2-3 8.11.3-1
logcli 2.3.0-1 2.3.0-2
loki 2.3.0-1 2.3.0-2
loki-canary 2.3.0-1 2.3.0-2
marked 2.1.3-1 3.0.0-1
mediathekview13.7.1.r152.g178bb58c-1 13.8.0-1
mod_passenger 6.0.9-2 6.0.10-1
multipath-tools 0.8.5-4 0.8.6-1
nbtscan 1.6-1 1.7.1-1
nginx-mod-passenger 6.0.9-2 6.0.10-1
ngspice 33-1 35-1
operator-sdk 1.10.1-1 1.11.0-1
pavucontrol-qt 0.17.0-1 0.17.0-2
pcb 1:4.2.2-1 1:4.3.0-1
pdftk 3.2.3-1 3.3.0-1
php-grpc 1.39.0-1 1.39.1-1
php7-grpc 1.39.0-1 1.39.1-1
pigeonhole 0.5.15-1 0.5.16-1
popeye 0.9.0-2 0.9.7-1
primecount 7.0-1 7.1-1
promtail 2.3.0-1 2.3.0-2
pulumi 3.9.1-1 3.10.1-1
pyright 1.1.161-1 1.1.162-1
python-boto3 1.18.2-1 1.18.21-1
python-botocore 1.21.2-1 1.21.21-1
python-django-debug-toolbar 3.2.1-1 3.2.2-1
python-flexmock 0.10.5-1 0.10.6-1
python-google-auth 1.30.1-1 1.31.0-1
python-grpcio 1.39.0-1 1.39.1-1
python-httpretty 1.1.3-1 1.1.4-1
python-hypothesis 6.14.6-1 6.14.8-1
python-klein 20.6.0-3 21.8.0-1
python-kubernetes 17.17.0-1 18.20.0-1
python-pdftotext 2.1.6-1 2.2.0-1
python-pyee 8.1.0-3 8.2.2-1
python-pygments 2.9.0-1 2.10.0-1
python-pyppeteer 0.2.5-2 0.2.6-1
python-pytools 2021.2.7-1 2021.2.8-1
python-qasync 0.18.0-1 0.18.1-1
python-tqdm 4.62.0-1 4.62.1-1
python-wand 0.6.6-1 0.6.7-1
python-yaspin 2.0.0-1 2.1.0-1
qpid-proton 0.33.0-1 0.35.0-1
rofimoji 5.2.0-2 5.3.0-1
ruby-ffi 1.15.0-2 1.15.3-1
ruby-metadata-json-lint 3.0.0-1 3.0.1-1
ruby-metadata_json_deps 0.2.0-1 0.3.0-1
ruby-nats-pure 0.6.2-4 0.7.0-1
ruby-nokogiri 1.11.7-2 1.12.2-1
ruby-pg 1.1.4-3 1.2.3-1
ruby-semantic_puppet 1.0.3-2 1.0.4-1
rust-analyzer 20210809-1 20210816-1
sad 0.4.11-1 0.4.14-1
skaffold 1.29.0-1 1.30.0-1
smokeping 2.7.3-3 2.8.2-1
spampd 2.53-3 2.61-1
spdlog 1.9.1-1 1.9.2-1
streamlink 2.2.0-1 2.3.0-1
supercollider 3.11.2-4 3.12.0-1
switchboard-plug-online-accounts 6.0.0-1 6.1.0-1
terragrunt 0.31.1-1 0.31.3-1
texmaker 5.0.4-1 5.1.0-1
timescaledb 2.3.1-1 2.4.0-4
ttc-iosevka 9.0.1-1 10.0.0-1
ttc-iosevka-aile 9.0.1-1 10.0.0-1
ttc-iosevka-curly 9.0.1-1 10.0.0-1
ttc-iosevka-curly-slab 9.0.1-1 10.0.0-1
ttc-iosevka-etoile 9.0.1-1 10.0.0-1
ttc-iosevka-slab 9.0.1-1 10.0.0-1
ttc-iosevka-ss01 9.0.1-1 10.0.0-1
ttc-iosevka-ss02 9.0.1-1 10.0.0-1
ttc-iosevka-ss03 9.0.1-1 10.0.0-1
ttc-iosevka-ss04 9.0.1-1 10.0.0-1
ttc-iosevka-ss05 9.0.1-1 10.0.0-1
ttc-iosevka-ss06 9.0.1-1 10.0.0-1
ttc-iosevka-ss07 9.0.1-1 10.0.0-1
ttc-iosevka-ss08 9.0.1-1 10.0.0-1
ttc-iosevka-ss09 9.0.1-1 10.0.0-1
ttc-iosevka-ss10 9.0.1-1 10.0.0-1
ttc-iosevka-ss11 9.0.1-1 10.0.0-1
ttc-iosevka-ss12 9.0.1-1 10.0.0-1
ttc-iosevka-ss13 9.0.1-1 10.0.0-1
ttc-iosevka-ss14 9.0.1-1 10.0.0-1
ttc-iosevka-ss15 9.0.1-1 10.0.0-1
ttc-iosevka-ss16 9.0.1-1 10.0.0-1
ttc-iosevka-ss17 9.0.1-1 10.0.0-1
ttc-iosevka-ss18 9.0.1-1 10.0.0-1
v2ray 4.40.1-1 4.41.1-1
v2ray-domain-list-community 20210812210645-1 20210816014827-1
waybar 0.9.7-5 0.9.8-1
yodl 4.02.02-2 4.03.03-1
you-get 0.4.1536-1 0.4.1545-1
cargo-generate - 0.8.0-1
elvish - 0.15.0-3
gortr - 0.14.7-6
perl-test-most - 0.37-4
usd - 21.08-1
zoxide - 0.7.4-2
:: Different overlay package(s) in repository core aarch64
linux 5.13.10-1 5.13.12-1
linux-headers 5.13.10-1 5.13.12-1
linux-pinephone 5.13.10-1 5.13.11-1
linux-pinephone-headers 5.13.10-1 5.13.11-1
linux-rc 5.14.rc5-3 5.14.rc6-1
linux-rc-headers 5.14.rc5-3 5.14.rc6-1
linux-rpi4 5.10.52-2 5.10.59-1
linux-rpi4-headers 5.10.52-2 5.10.59-1
linux-vim 5.13.0-1 5.13.5-1
linux-vim-headers 5.13.0-1 5.13.5-1
pacman-mirrors 4.21.1-2 4.21.5-1
:: Different sync package(s) in repository core aarch64
device-mapper 2.03.12-1 2.03.13-1
lvm2 2.03.12-1 2.03.13-1
:: Different overlay package(s) in repository extra aarch64
mesa-git21.3.0_devel.143405.02b60159458-121.3.0_devel.143595.4d9acfa5331-1
network-manager-applet 1.22.0-1 1.24.0-1
nm-connection-editor 1.22.0-1 1.24.0-1
:: Different sync package(s) in repository extra aarch64
attica 5.84.0-1 5.85.0-1
baloo 5.84.0-1 5.85.0-1
bluez-qt 5.84.0-1 5.85.0-1
breeze-icons 5.84.0-1 5.85.0-1
chromium 92.0.4515.131-1 92.0.4515.159-1
devhelp 40.0-1 40.0-2
eog 40.2-1 40.3-1
evolution 3.40.3-1 3.40.4-1
evolution-bogofilter 3.40.3-1 3.40.4-1
evolution-data-server 3.40.3-1 3.40.4-1
evolution-ews 3.40.3-1 3.40.4-1
evolution-spamassassin 3.40.3-1 3.40.4-1
extra-cmake-modules 5.84.0-1 5.85.0-1
frameworkintegration 5.84.0-1 5.85.0-1
gi-docgen 2021.6-1 2021.7-1
gjs 2:1.68.2-1 2:1.68.3-1
gnome-maps 40.3-1 40.4-1
gnome-shell 1:40.3-1 1:40.4-1
gnome-shell-extensions 40.3-1 40.4-1
gnome-software 40.3-1 40.4-1
gnome-software-packagekit-plugin 40.3-1 40.4-1
gnome-user-docs 40.3-1 40.4-1
js78 78.12.0-1 78.13.0-1
json-glib 1.6.2-1 1.6.4-1
kactivities 5.84.0-1 5.85.0-1
kactivities-stats 5.84.0-1 5.85.0-1
kapidox 5.84.0-1 5.85.0-1
karchive 5.84.0-1 5.85.0-1
kauth 5.84.0-1 5.85.0-1
kbookmarks 5.84.0-1 5.85.0-1
kcalendarcore 5.84.0-1 5.85.0-1
kcmutils 5.84.0-1 5.85.0-1
kcodecs 5.84.0-1 5.85.0-1
kcompletion 5.84.0-1 5.85.0-1
kconfig 5.84.0-1 5.85.0-1
kconfigwidgets 5.84.0-1 5.85.0-1
kcontacts 1:5.84.0-1 1:5.85.0-1
kcoreaddons 5.84.0-1 5.85.0-1
kcrash 5.84.0-1 5.85.0-1
kdav 1:5.84.0-1 1:5.85.0-1
kdbusaddons 5.84.0-1 5.85.0-1
kdeclarative 5.84.0-1 5.85.0-1
kded 5.84.0-1 5.85.0-1
kdelibs4support 5.84.0-1 5.85.0-1
kdesignerplugin 5.84.0-1 5.85.0-1
kdesu 5.84.0-1 5.85.0-1
kdewebkit 5.84.0-1 5.85.0-1
kdnssd 5.84.0-1 5.85.0-1
kdoctools 5.84.0-1 5.85.0-1
kemoticons 5.84.0-1 5.85.0-1
kfilemetadata 5.84.0-1 5.85.0-1
kglobalaccel 5.84.0-1 5.85.0-1
kguiaddons 5.84.0-1 5.85.0-1
kholidays 1:5.84.0-1 1:5.85.0-1
khtml 5.84.0-1 5.85.0-1
ki18n 5.84.0-1 5.85.0-1
kiconthemes 5.84.0-1 5.85.0-1
kidletime 5.84.0-1 5.85.0-1
kimageformats 5.84.0-3 5.85.0-1
kinit 5.84.0-1 5.85.0-1
kio 5.84.0-2 5.85.0-1
kirigami2 5.84.0-1 5.85.0-1
kitemmodels 5.84.0-1 5.85.0-1
kitemviews 5.84.0-1 5.85.0-1
kjobwidgets 5.84.0-1 5.85.0-1
kjs 5.84.0-1 5.85.0-1
kjsembed 5.84.0-1 5.85.0-1
kmediaplayer 5.84.0-1 5.85.0-1
knewstuff 5.84.0-1 5.85.0-1
knotifications 5.84.0-1 5.85.0-1
knotifyconfig 5.84.0-1 5.85.0-1
kpackage 5.84.0-1 5.85.0-1
kparts 5.84.0-1 5.85.0-1
kpeople 5.84.0-1 5.85.0-1
kplotting 5.84.0-1 5.85.0-1
kpty 5.84.0-1 5.85.0-1
kquickcharts 5.84.0-1 5.85.0-1
kross 5.84.0-1 5.85.0-1
krunner 5.84.0-1 5.85.0-1
kservice 5.84.0-1 5.85.0-1
ktexteditor 5.84.0-1 5.85.0-1
ktextwidgets 5.84.0-1 5.85.0-1
kunitconversion 5.84.0-1 5.85.0-1
kwallet 5.84.0-1 5.85.0-1
kwayland 5.84.0-1 5.85.0-1
kwidgetsaddons 5.84.0-1 5.85.0-1
kwindowsystem 5.84.0-1 5.85.0-1
kxmlgui 5.84.0-1 5.85.0-1
kxmlrpcclient 5.84.0-1 5.85.0-1
libepoxy 1.5.8-1 1.5.9-1
libgudev 236-1 237-1
libphonenumber 8.12.25-1 8.12.29-1
libsrtp 1:2.3.0-1 1:2.4.0-1
libstemmer 0+713-2 2.1.0-1
libwebp 1.2.0-1 1.2.1-1
meld 3.20.3-1 3.20.4-1
modemmanager-qt 5.84.0-1 5.85.0-1
mutter 40.3-1 40.4-1
networkmanager-qt 5.84.0-1 5.85.0-1
nuget 5.9.0-2 5.10.0-1
oxygen-icons 1:5.84.0-1 1:5.85.0-1
oxygen-icons-svg 1:5.84.0-1 1:5.85.0-1
pavucontrol 1:4.0-2 1:5.0-1
perl-convert-binhex 1.125-8 1.125-9
perl-image-exiftool 12.26-2 12.30-1
plasma-framework 5.84.0-1 5.85.0-2
prison 5.84.0-1 5.85.0-1
purpose 5.84.0-1 5.85.0-1
qqc2-desktop-style 5.84.0-1 5.85.0-1
qt5-base 5.15.2+kde+r215-1 5.15.2+kde+r215-2
qt5-xcb-private-headers 5.15.2+kde+r215-1 5.15.2+kde+r215-2
snowball 0+713-2 2.1.0-1
solid 5.84.0-1 5.85.0-1
sonnet 5.84.0-1 5.85.0-1
syndication 5.84.0-1 5.85.0-1
syntax-highlighting 5.84.0-1 5.85.0-1
tali 40.1-1 40.2-1
threadweaver 5.84.0-1 5.85.0-1
vala 0.52.4-1 0.52.5-1
json-glib-docs - 1.6.4-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.04.3.r12553.g7156605d0-121.08.0.r12559.gb0ff923f6-1
akonadi-calendar21.04.3.r1968.gb46a382-121.08.0.r1973.g6a48eb5-1
akonadi-calendar-tools21.04.3.r888.g5e6f8c1-121.08.0.r893.g41c7036-1
akonadi-contacts21.04.3.r3041.g6f278659-121.08.0.r3049.g1c29e2c5-1
akonadi-import-wizard21.04.3.r1723.gc0bdc86-121.08.0.r1728.gc01c991-1
akonadi-mime21.04.3.r1632.gd1f5c99-121.08.0.r1637.g365d1a7-1
akonadi-notes21.04.3.r1016.g846761c-121.08.0.r1021.gf727062-1
akonadi-search21.04.3.r1112.g69ed14e-121.08.0.r1117.g429d8fd-1
akonadiconsole21.04.3.r1503.gedf648f-121.08.0.r1507.g30bd800-1
akregator21.04.3.r6207.g609cf5bb-121.08.0.r6213.gdd54f9c4-1
analitza21.04.3.r2330.g7072e346-121.08.0.r2330.g7072e346-1
angelfish 21.07.r6.g1132102-1 21.07.r7.g54f06d5-1
ark21.04.3.r4609.g57196499-121.08.0.r4610.g80b46edb-1
artikulate21.04.3.r1388.g89c15b6-121.08.0.r1388.g89c15b6-1
attica5.84.0.r825.g71ec656-15.85.0.r829.g943437d-1
audiocd-kio21.04.3.r1031.g6d88fa2-121.08.0.r1031.g6d88fa2-1
baloo5.84.0.r2996.g99b5b4dc-15.85.0.r3003.g2cea245a-1
baloo-widgets21.04.3.r690.gf8a23f9-121.08.0.r694.g70ec4e1-1
blinken21.04.3.r628.ga97495d-121.08.0.r628.ga97495d-1
bluedevil1:5.22.4.r2274.gc428cb0e-11:5.22.4.r2275.g6557286a-1
bluez-qt5.84.0.r669.gde9369b-15.85.0.r673.g6779881-1
bomber21.04.3.r521.g52c9ed0-121.08.0.r521.g52c9ed0-1
bovo21.04.3.r732.g66396f2-121.08.0.r732.g66396f2-1
breeze5.22.4.r2233.gd59275df-15.22.4.r2234.gfc30c11a-1
breeze-icons5.84.0.r1768.g794f2088-15.85.0.r1772.gaf27e281-1
calendarsupport21.08.0.r11.ga3bef3e-121.08.0.r20.gfc8619e-1
cervisia21.04.3.r1640.g2cbf459-121.08.0.r1640.g2cbf459-1
disman5.22.0.r1808.g431141e-15.22.4.r1808.g431141e-1
dolphin21.04.3.r6676.g0ac57fbe9-121.08.0.r6677.g0ed31f10c-1
dolphin-plugins21.04.3.r599.gf51b224-121.08.0.r600.ga0a4b6f-1
dragon21.04.3.r1008.g727feec-121.08.0.r1010.g75b3036-1
drkonqi5.22.4.r678.g271ad724-15.22.4.r683.g75d86806-1
elisa21.04.3.r2751.gd69ad3c8-121.08.0.r2751.gd69ad3c8-1
eventviews21.07.80.r13.g0765c30-121.07.80.r19.g93776ac-1
extra-cmake-modules5.84.0.r3357.g602e481-15.85.0.r3361.g3a75f89-1
ffmpegthumbs21.04.3.r190.g7dc382a-121.08.0.r190.g7dc382a-1
filelight21.04.3.r980.gdd1887c-121.08.0.r983.ge640b40-1
frameworkintegration5.84.0.r590.g83123c6-15.85.0.r594.gaa33981-1
granatier21.04.3.r925.gb30c3bc-121.08.0.r925.gb30c3bc-1
grantlee-editor21.04.3.r761.gd7bc71f-121.08.0.r765.g7458ee2-1
grantleetheme21.04.3.r339.gf169f6e-121.08.0.r342.g5cc6f08-1
gwenview21.04.3.r6651.g659d788b-121.08.0.r6652.g3a0b5cd4-1
incidenceeditor21.04.3.r750.g3a37a2f-121.08.0.r758.g23951f4-1
index-fm 2.0.0.r0.g9164432-1 2.0.0.r5.g818bd9f-1
itinerary21.04.3.r1425.g3ed36d8-121.08.0.r1434.gaf41337-1
juk21.04.3.r3110.ga1b028be-121.08.0.r3110.ga1b028be-1
k3b1:21.04.3.r6668.ga56b535c0-11:21.08.0.r6669.g57244a4a2-1
kaccounts-integration21.04.3.r1213.g1c40dc4-121.08.0.r1213.g1c40dc4-1
kaccounts-providers21.04.3.r383.gaf778e5-121.08.0.r383.gaf778e5-1
kactivities5.84.0.r1354.g91641d3-15.85.0.r1358.ga15ef9b-1
kactivities-stats5.84.0.r367.gb166722-15.85.0.r369.g8efa0c2-1
kaddressbook21.04.3.r6021.gac4df746-121.08.0.r6028.g68316021-1
kajongg21.04.3.r4196.gf578c92a-121.08.0.r4196.gf578c92a-1
kalarm21.04.3.r6437.gb29746b3-121.08.0.r6441.gc8d41145-1
kalarmcal21.04.3.r1135.gd8835e3-121.08.0.r1140.g16e912e-1
kalgebra21.04.3.r2040.g3738f5b-121.08.0.r2040.g3738f5b-1
kalk 21.07.r3.g19491a1-1 21.07.r5.g7f968c3-1
kalzium21.04.3.r4255.ge6aecd1b-121.08.0.r4255.ge6aecd1b-1
kamera21.04.3.r655.g975c8f5-121.08.0.r655.g975c8f5-1
kamoso21.04.3.r1429.g37ed426-121.08.0.r1429.g37ed426-1
kanagram21.04.3.r1285.gf761457-121.08.0.r1285.gf761457-1
kapidox5.84.0.r549.g461b6d6-15.85.0.r550.g41ab74c-1
kapman21.04.3.r603.gf7203b6-121.08.0.r603.gf7203b6-1
kapptemplate21.04.3.r955.gbf03e61-121.08.0.r956.gb948162-1
karchive5.84.0.r499.g03e1c5d-15.85.0.r501.gddef030-1
kasts 21.07.r7.g0b33c62-1 21.07.r9.g4efca61-1
kate21.04.3.r18323.g8fb90faec-121.08.0.r18325.ga94a3781b-1
katomic21.04.3.r917.g47ca0e1-121.08.0.r917.g47ca0e1-1
kauth5.84.0.r442.ga0145e5-15.85.0.r444.ga478e23-1
kbackup21.04.3.r390.g1aab938-121.08.0.r393.gcd1f6b5-1
kblackbox21.04.3.r725.g4682f86-121.08.0.r725.g4682f86-1
kblocks21.04.3.r666.g24ec0b5-121.08.0.r666.g24ec0b5-1
kbookmarks5.84.0.r413.g5bff8b2-15.85.0.r415.ga1a6901-1
kbounce21.04.3.r805.g7b942ee-121.08.0.r806.g641a0b4-1
kbreakout21.04.3.r862.g70ea259-121.08.0.r863.g33eb537-1
kbruch21.04.3.r816.gef98da6-121.08.0.r816.gef98da6-1
kcachegrind21.04.3.r1151.ge04e43e-121.08.0.r1151.ge04e43e-1
kcachegrind-common21.04.3.r1151.ge04e43e-121.08.0.r1151.ge04e43e-1
kcalc21.04.3.r1516.gd28fcbf-121.08.0.r1517.g96d87f0-1
kcalendarcore5.84.0.r1229.g2171b6fe0-15.85.0.r1231.g58561b7d8-1
kcalutils21.04.3.r857.g34750c5b0-121.08.0.r863.g396a4445d-1
kcharselect21.04.3.r469.g54c67b1-121.08.0.r470.g91d8e7b-1
kcmutils5.84.0.r535.g4a66431-15.85.0.r538.g0f75ac4-1
kcodecs5.84.0.r377.gc3ef591-15.85.0.r379.g9638b2d-1
kcolorchooser21.04.3.r226.gf67480a-121.08.0.r229.gbe6cf4d-1
kcompletion5.84.0.r450.g08b30d1-15.85.0.r452.g2397f79-1
kconfig5.84.0.r852.g783d1c2-15.85.0.r854.g98e74c2-1
kconfigwidgets5.84.0.r607.gaae5c2d-15.85.0.r609.g1fad95e-1
kcontacts1:5.84.0.r3246.gafa4ae75-11:5.85.0.r3249.g0139b880-1
kcoreaddons5.84.0.r1262.g5d5834d8-15.85.0.r1267.ged4a5b45-1
kcrash5.84.0.r403.gdc45a01-15.85.0.r406.gc9f0ae9-1
kcron21.04.3.r777.g4c6e344-121.08.0.r778.gec9a965-1
kdav1:5.84.0.r1293.g46d1baf-11:5.85.0.r1296.ge087771-1
kdbusaddons5.84.0.r372.gd810bd0-15.85.0.r374.gfa42997-1
kde-dev-scripts21.04.3.r4138.g0262243-121.08.0.r4139.gac3f5f4-1
kde-dev-utils21.04.3.r559.g53c8482-121.08.0.r562.g9d0f3b4-1
kde-gtk-config5.22.4.r898.g6b2c211-15.22.4.r908.g50b9cd5-1
kdebugsettings21.04.3.r834.g37eaded-121.08.0.r837.g35e36de-1
kdeclarative5.84.0.r905.g5db5b88-15.85.0.r908.g37c280d-1
kdeconnect21.04.3.r3308.ge213eb50-121.08.0.r3308.ge213eb50-1
kded5.84.0.r411.g5c3ef36-15.85.0.r413.ge013683-1
kdeedu-data21.04.3.r15.g8dc3dee-121.08.0.r15.g8dc3dee-1
kdegraphics-mobipocket21.04.3.r259.g9c61298-121.08.0.r259.g9c61298-1
kdegraphics-thumbnailers21.04.3.r235.ga26b83c-121.08.0.r235.ga26b83c-1
kdelibs4support5.84.0.r1030.g9029e796-15.85.0.r1032.g476732ba-1
kdenetwork-filesharing21.04.3.r889.g0abade9-121.08.0.r889.g0abade9-1
kdenlive21.04.2.r14526.gea4527ae1-121.08.0.r14773.g736c714c9-1
kdepim-addons21.04.3.r4239.g4180eccf-121.08.0.r4298.g2407d85b-1
kdepim-runtime21.04.3.r15179.g778b060e2-121.08.0.r15187.ge73eb393d-1
kdeplasma-addons5.22.4.r8571.gc6361d75e-15.22.4.r8576.gf5609a152-1
kdesdk-kioslaves21.04.3.r498.g061c880-121.08.0.r499.gf0b4adb-1
kdesdk-thumbnailers21.04.3.r84.gd7821b4-121.08.0.r85.g29d3ad1-1
kdesignerplugin5.84.0.r329.g8141fca-15.85.0.r331.gc2529e3-1
kdesu5.84.0.r470.g45a82b6-15.85.0.r473.g55e7b78-1
kdewebkit5.84.0.r276.g9e20914-15.85.0.r279.g977967d-1
kdf21.04.3.r794.g026d092-121.08.0.r797.g44c6e09-1
kdialog21.04.3.r1187.ga26935bba-121.08.0.r1188.gafed367a3-1
kdiamond21.04.3.r668.g7fc116c-121.08.0.r668.g7fc116c-1
kdisplay5.22.0.r1450.g1fa20e2-15.22.4.r1450.g1fa20e2-1
kdnssd5.84.0.r316.g5a5e100-15.85.0.r318.gf5e6f53-1
kdoctools5.84.0.r617.g7f217be-15.85.0.r624.g32dace3-1
keditbookmarks21.04.3.r2740.g956c0e3dc-121.08.0.r2743.g0d54808cd-1
kemoticons5.84.0.r379.gde2d0fb-15.85.0.r381.g9adbf11-1
kfilemetadata5.84.0.r800.gdf7a567-15.85.0.r804.g37f293b-1
kfind21.04.3.r2640.g71dfb8180-121.08.0.r2643.gd1dc939db-1
kfloppy21.04.3.r754.g999a9a9-121.08.0.r756.ga4a1563-1
kfourinline21.04.3.r981.ga16283e-121.08.0.r981.ga16283e-1
kgeography21.04.3.r1111.g5fab02b-121.08.0.r1111.g5fab02b-1
kget21.04.3.r3119.gcfe2bbb1-121.08.0.r3119.gcfe2bbb1-1
kglobalaccel5.84.0.r454.g355e20c-15.85.0.r457.g13268e2-1
kgoldrunner21.04.3.r1238.g3c80544-121.08.0.r1238.g3c80544-1
kgpg21.04.3.r3129.gf892e2fd-121.08.0.r3129.gf892e2fd-1
kguiaddons5.84.0.r380.g45b830a-15.85.0.r383.g4566708-1
khangman21.04.3.r1564.gcbc467e-121.08.0.r1564.gcbc467e-1
khealthcertificate r67.735d6be-1 r68.05a8e52-1
khelpcenter21.04.3.r2677.g322c8a6e-121.08.0.r2677.g322c8a6e-1
kholidays1:5.84.0.r952.g8b43e99-11:5.85.0.r955.g559cfb4-1
khtml5.84.0.r551.ga34c800-15.85.0.r553.gf3a98a4-1
ki18n5.84.0.r472.gf3e663b-15.85.0.r475.g302a3d3-1
kiconthemes5.84.0.r533.g52064e0-15.85.0.r536.g40d092d-1
kidentitymanagement21.04.3.r3808.gd2db1899-121.08.0.r3815.g7f5c1c82-1
kidletime5.84.0.r308.gec6e0b6-15.85.0.r311.g1fb8340-1
kig21.04.3.r3145.g4e77085b-121.08.0.r3145.g4e77085b-1
kigo21.04.3.r521.g2c02486-121.08.0.r521.g2c02486-1
killbots21.04.3.r735.g9a89476-121.08.0.r735.g9a89476-1
kimageformats5.84.0.r349.ga8f92e5-15.85.0.r351.g28099ee-1
kimagemapeditor21.04.3.r470.g909a43c-121.08.0.r470.g909a43c-1
kimap21.04.3.r1103.g61ec98b-121.08.0.r1108.g2abb127-1
kinfocenter5.22.4.r1873.gabe93df-15.22.4.r1879.g29f7177-1
kinit5.84.0.r406.g2a5d047-15.85.0.r408.g396a0d3-1
kio5.84.0.r4909.g806d2b00-15.85.0.r4925.ga379d1b4-1
kio-extras21.04.3.r7098.ge6afe2f9-121.08.0.r7098.ge6afe2f9-1
kio-gdrive21.04.3.r565.gae07881-121.08.0.r565.gae07881-1
kipi-plugins21.04.3.r12061.g955fc31c6-121.08.0.r12061.g955fc31c6-1
kirigami-gallery21.04.3.r213.g381565a-121.08.0.r213.g381565a-1
kirigami25.84.0.r2857.g6c40eaa0-15.85.0.r2863.gc8e04b6d-1
kiriki21.04.3.r419.gd1d767e-121.08.0.r419.gd1d767e-1
kitemmodels5.84.0.r549.g4a40dd7-15.85.0.r552.gdd7b8e2-1
kitemviews5.84.0.r332.gf2786d0-15.85.0.r335.gf244f43-1
kiten21.04.3.r1143.g8115656-121.08.0.r1146.g028b49c-1
kitinerary21.04.3.r1869.ge0e7e5e-121.08.0.r1874.g9a01b21-1
kjobwidgets5.84.0.r370.g45f58fd-15.85.0.r373.gdd7a427-1
kjs5.84.0.r331.g1157752-15.85.0.r333.gc185445-1
kjsembed5.84.0.r300.g1e8b825-15.85.0.r302.g7b4ec52-1
kjumpingcube21.04.3.r784.g7772574-121.08.0.r784.g7772574-1
kldap21.04.3.r874.g717c9a5-121.08.0.r881.gf876ba4-1
kleopatra21.04.3.r5932.g84707907-121.08.0.r5944.gaa59b873-1
klettres21.04.3.r914.g6ec4462-121.08.0.r914.g6ec4462-1
klickety21.04.3.r634.g0b9b09e-121.08.0.r634.g0b9b09e-1
klines21.04.3.r763.ge9a3a51-121.08.0.r763.ge9a3a51-1
kmag21.04.3.r692.g22e28dd-121.08.0.r693.g7051a15-1
kmahjongg21.04.3.r1468.g5f0ecda-121.08.0.r1468.g5f0ecda-1
kmail-account-wizard21.04.3.r796.gbb43520-121.08.0.r808.g6a8e44a-1
kmailtransport21.04.3.r1637.g49f684c-121.08.0.r1641.g014924e-1
kmbox21.04.3.r532.g1dbd7e6-121.08.0.r537.g13fa9f3-1
kmediaplayer5.84.0.r291.g8385c6b-15.85.0.r293.gb43ad1c-1
kmime21.04.3.r1445.g4d7c3cd-121.08.0.r1451.g615cc69-1
kmines21.04.3.r1717.g2b23d0f-121.08.0.r1717.g2b23d0f-1
kmix21.04.3.r2378.g33e80f14-121.08.0.r2378.g33e80f14-1
kmousetool21.04.3.r388.gc4b2d98-121.08.0.r399.ga0ccf22-1
kmouth21.04.3.r692.g434a8a6-121.08.0.r692.g434a8a6-1
kmplot21.04.3.r1464.g484cd7c-121.08.0.r1464.g484cd7c-1
knavalbattle21.04.3.r1385.gb2634cb-121.08.0.r1385.gb2634cb-1
knetwalk21.04.3.r656.g424c743-121.08.0.r656.g424c743-1
knewstuff5.84.0.r1191.g0cc9f119-15.85.0.r1196.gee390b03-1
knights21.04.3.r1049.g9855fd8-121.08.0.r1049.g9855fd8-1
knotes21.04.3.r3494.g52f0e087-121.08.0.r3498.g54f8ec3a-1
knotifications5.84.0.r668.g3009331-15.85.0.r672.g087e474-1
knotifyconfig5.84.0.r348.gbbcae0e-15.85.0.r350.gebd2dca-1
kolf21.04.3.r1438.g8386d3d-121.08.0.r1438.g8386d3d-1
kollision21.04.3.r490.ge5fde57-121.08.0.r490.ge5fde57-1
kolourpaint21.04.3.r2351.g3a3515b9-121.08.0.r2351.g3a3515b9-1
kompare21.04.3.r1105.gd41a4cf-121.08.0.r1105.gd41a4cf-1
konqueror21.04.3.r14927.gadf291805-121.08.0.r14928.gc9a57d30f-1
konquest21.04.3.r895.gafbcde6-121.08.0.r895.gafbcde6-1
konsole21.04.3.r7917.gbbec7225-121.08.0.r7919.g3d967a59-1
kontact21.04.3.r5369.gf32877d2-121.08.0.r5375.gcb509c5b-1
kontactinterface21.04.3.r624.g48b9253-121.08.0.r628.gd333f9e-1
kontrast21.04.3.r171.g8e90006-121.08.0.r171.g8e90006-1
konversation21.04.3.r8990.g063aab07-121.08.0.r8990.g063aab07-1
kopeninghours21.04.3.r267.g81cc4e5-121.08.0.r267.g81cc4e5-1
korganizer21.04.3.r11455.g840f8391a-121.08.0.r11460.gc94c1c1bc-1
kosmindoormap21.04.3.r628.g4ffe68e-121.08.0.r628.g4ffe68e-1
kpackage5.84.0.r689.g01b766f-15.85.0.r692.gf3fff45-1
kparts5.84.0.r516.g9c751ff-15.85.0.r519.g1187e96-1
kpat21.04.3.r2561.g5291a71-121.08.0.r2561.g5291a71-1
kpeople5.84.0.r1337.g3f4ab34-15.85.0.r1340.g3712e51-1
kpimtextedit21.04.3.r1400.g1298bc2-121.08.0.r1406.g1853009-1
kpkpass21.04.3.r231.g9878df2-121.08.0.r235.gd8294ec-1
kplotting5.84.0.r287.g96be9c3-15.85.0.r290.g9259a3f-1
kpmcore21.04.3.r1195.gc47ee6c-121.08.0.r1195.gc47ee6c-1
kpty5.84.0.r331.g09b4e06-15.85.0.r339.g3d4ebc6-1
kpublictransport21.04.3.r1703.gf36365e-121.08.0.r1724.g7fb6f77f-1
kqtquickcharts21.04.3.r74.g264af68-121.08.0.r74.g264af68-1
kquickcharts5.84.0.r466.g09e9642-15.85.0.r469.gace1cfe-1
krdc21.04.3.r1532.ge42e5f0-121.08.0.r1532.ge42e5f0-1
kreversi21.04.3.r1222.g668dbbd-121.08.0.r1222.g668dbbd-1
krfb21.04.3.r1410.gcb86f9c-121.08.0.r1410.gcb86f9c-1
kross5.84.0.r330.g2e0b5b7-15.85.0.r333.g87fb2aa-1
kross-interpreters21.04.3.r722.g8d54326-121.08.0.r723.g473116a-1
kruler21.04.3.r695.g6155077-121.08.0.r698.g91ab1d1-1
krunner5.84.0.r660.ge4316d2-15.85.0.r663.g0deb66d-1
kscreenlocker5.22.4.r863.ga9b3fdc-15.22.4.r865.ge31b987-1
kservice5.84.0.r925.gc2cedaa-15.85.0.r931.gc1ccc2d-1
kshisen21.04.3.r1199.g74d5caa-121.08.0.r1199.g74d5caa-1
ksirk21.04.3.r959.g2ecfb4d-121.08.0.r959.g2ecfb4d-1
ksmtp21.04.3.r360.g252e4a1-121.08.0.r364.g51fce68-1
ksnakeduel21.04.3.r800.g5e44a0c-121.08.0.r802.g6d1d2a7-1
kspaceduel21.04.3.r627.g704594a-121.08.0.r627.g704594a-1
ksquares21.04.3.r513.g01ea286-121.08.0.r515.gb36c79b-1
ksudoku21.04.3.r1048.ga204d83-121.08.0.r1048.ga204d83-1
ksysguard5.22.4.r3508.g4d304e1e-15.22.4.r3509.gcfd3a0f8-1
ksystemlog21.04.3.r649.g2889185-121.08.0.r652.g5e50432-1
kteatime21.04.3.r720.gd35c30d-121.08.0.r724.ga51c5b3-1
ktexteditor5.84.0.r2911.g6fe00457-15.85.0.r2921.g15d17611-1
ktextwidgets5.84.0.r404.g042f5a7-15.85.0.r407.g30acf54-1
ktimer21.04.3.r468.g08ad6e6-121.08.0.r468.g08ad6e6-1
ktnef21.04.3.r657.g6db4839-121.08.0.r661.g3d85473-1
ktorrent21.04.3.r2763.g63832ef7-121.08.0.r2763.g63832ef7-1
ktouch21.04.3.r2138.g066e658-121.08.0.r2138.g066e658-1
ktrip 21.07.r5.g7317bbf-1 21.07.r6.g1a9d591-1
ktuberling21.04.3.r1004.g323ddab-121.08.0.r1004.g323ddab-1
kturtle21.04.3.r1116.g57ace23-121.08.0.r1117.g598a847-1
kubrick21.04.3.r366.g56f5df7-121.08.0.r366.g56f5df7-1
kunitconversion5.84.0.r370.g92eea5a-15.85.0.r373.gf8808e7-1
kwallet5.84.0.r1079.gaea7be1-15.85.0.r1082.g4638b89-1
kwalletmanager21.04.3.r1205.g4384d15-121.08.0.r1207.g4179fca-1
kwave21.04.3.r3739.g9357ded2-121.08.0.r3739.g9357ded2-1
kwayland5.84.0.r1101.g311f60b-15.85.0.r1104.gc253809-1
kwayland-integration5.22.4.r179.g5901512-15.22.4.r180.g88c55e8-1
kwayland-server5.22.4.r1365.g260d461-15.22.4.r1366.g9a7578d-1
kweathercore 0.4.r5.gf6196b4-1 0.4.r6.g93ab451-1
kwidgetsaddons5.84.0.r841.g63d2e03c-15.85.0.r847.g6b294099-1
kwin5.22.4.r19745.g3982f8399-15.22.4.r19777.g1fbd99b57-1
kwindowsystem5.84.0.r605.g61cfaf3-15.85.0.r609.g441a306-1
kwinft5.22.0.r19123.g8c03f21df-15.22.4.r19218.g01e39c224-1
kwordquiz21.04.3.r1140.g81820a6-121.08.0.r1140.g81820a6-1
kwrite21.04.3.r18323.g8fb90faec-121.08.0.r18325.ga94a3781b-1
kxmlgui5.84.0.r793.gac22655f-15.85.0.r796.g63156af4-1
kxmlrpcclient5.84.0.r452.gdcaf14c9e-15.85.0.r454.gfeaaab040-1
libakonadi21.04.3.r12553.g7156605d0-121.08.0.r12559.gb0ff923f6-1
libgravatar21.04.3.r360.g81e937a-121.08.0.r365.gf03ffbb-1
libkcddb21.04.3.r736.g24d5755-121.08.0.r736.g24d5755-1
libkcompactdisc21.04.3.r386.g4f9a6d2-121.08.0.r387.ge9f53ab-1
libkdcraw21.04.3.r1148.g4af2f68-121.08.0.r1148.g4af2f68-1
libkdegames21.04.3.r2187.gf5381404-121.08.0.r2187.gf5381404-1
libkdepim21.04.3.r842.g10f77da-121.08.0.r846.g57bad32-1
libkeduvocdocument21.04.3.r1791.g4966f86-121.08.0.r1791.g4966f86-1
libkexiv221.04.3.r815.gb0e00f4-121.08.0.r815.gb0e00f4-1
libkipi21.04.3.r1250.geea9c7b-121.08.0.r1250.geea9c7b-1
libkleo21.04.3.r918.gc5adace-121.08.0.r923.gb3bb0ce-1
libkmahjongg21.04.3.r456.ga02d1ab-121.08.0.r456.ga02d1ab-1
libkomparediff221.04.3.r339.ge9ed555-121.08.0.r339.ge9ed555-1
libksane21.04.3.r553.g644e071-121.08.0.r553.g644e071-1
libksieve21.04.3.r1572.g292958af-121.08.0.r1578.g4f8c2c48-1
libksysguard5.22.4.r2270.g7f8e215-15.22.4.r2271.gea38a1f-1
libktorrent21.04.3.r522.gfb083f5-121.08.0.r524.ga3f8f37-1
linux-aml 5.13.0-0.5 -
linux-aml-headers 5.13.0-0.5 -
lokalize21.04.3.r1768.ge30edb2-121.08.0.r1768.ge30edb2-1
lskat21.04.3.r810.g1ddcf41-121.08.0.r810.g1ddcf41-1
mailcommon21.04.3.r1085.g26af4ec-121.08.0.r1093.g45d8e6c-1
mailimporter21.04.3.r464.g9bd4688-121.08.0.r469.gc2fe16c-1
marble21.04.3.r13326.gd34223487-121.08.0.r13326.gd34223487-1
marble-common21.04.3.r13326.gd34223487-121.08.0.r13326.gd34223487-1
marble-qt21.04.3.r13326.gd34223487-121.08.0.r13326.gd34223487-1
markdownpart21.04.3.r80.g641b90a-121.08.0.r80.g641b90a-1
maui-clip 2.0.0.r0.g619cd12-1 2.0.0.r1.g9edd324-1
maui-nota 2.0.0.r0.gd501118-1 2.0.0.r1.g23828ea-1
maui-pix 2.0.0.r0.gae52b1e-1 2.0.0.r1.gb75ac86-1
mauikit 2.0.0.r0.g310ac842-1 2.0.0.r4.g45044100-1
mauikit-filebrowsing 2.0.0.r0.g5357cad-1 2.0.0.r4.g644cd72-1
mauikit-imagetools 2.0.0.r0.g1dcafdc-1 2.0.0.r2.g3fb2d7c-1
mauikit-texteditor 1.2.2.r12.g5808dc0-1 2.0.0.r1.g7dfdbde-1
mbox-importer21.04.3.r505.gb65ac8c-121.08.0.r509.gd851cfc-1
messagelib21.04.3.r6120.gcfe20f60-121.08.0.r6131.geb6be669-1
milou5.22.4.r745.g65c72f4-15.22.4.r747.gf7c2897-1
minuet21.04.3.r580.ga23c7c7-121.08.0.r580.ga23c7c7-1
modemmanager-qt5.84.0.r515.gd228c82-15.85.0.r518.ga25335a-1
neochat r1815.ge064243d-1 r1819.g94c4bbc3-1
networkmanager-qt5.84.0.r1113.ga66c9d1-15.85.0.r1116.gd48b86f-1
okular21.04.3.r9415.ga3f242cbc-121.08.0.r9424.gd9cb0c907-1
oxygen-icons1:5.84.0.r5.gbff159d-11:5.85.0.r5.gbff159d-1
oxygen-icons-svg1:5.84.0.r5.gbff159d-11:5.85.0.r5.gbff159d-1
palapeli21.04.3.r1228.g4d18ee6-121.08.0.r1228.g4d18ee6-1
parley21.04.3.r4417.g670f8f95-121.08.0.r4417.g670f8f95-1
partitionmanager21.04.3.r1530.gd4afb41-121.08.0.r1530.gd4afb41-1
picmi21.04.3.r526.ge88c260-121.08.0.r526.ge88c260-1
pim-data-exporter21.04.3.r2434.g3a022254-121.08.0.r2438.g9edc82b9-1
pim-sieve-editor21.04.3.r1498.g6c3c612-121.08.0.r1502.g5345fa3-1
pimcommon21.07.80.r1082.g270c25f-121.07.80.r1088.gab86d0c-1
plasma-desktop5.22.4.r8577.g56f49e474-15.22.4.r8582.g10a1805ed-1
plasma-framework5.84.0.r15940.g90a78d4d0-15.85.0.r15946.g730889c89-1
plasma-mobile-nm5.22.3.r3067.g99ed744a-15.22.3.r3070.g3213592c-1
plasma-phone-components5.22.3.r1443.g7ef6c9c7-15.22.3.r1444.gc0ff474e-1
plasma-settings 21.07.r8.gaca9de5-1 21.07.r9.ge9abd2c-1
plasma-wayland-session5.22.4.r10507.g1a2383f88-15.22.4.r10540.g5d7726252-1
plasma-workspace5.22.4.r10507.g1a2383f88-15.22.4.r10540.g5d7726252-1
powerdevil5.22.4.r2457.geccf6a12-15.22.4.r2458.ga9ab770e-1
poxml21.04.3.r277.ge2d4dfb-121.08.0.r277.ge2d4dfb-1
print-manager21.04.3.r1034.g66346a7-121.08.0.r1034.g66346a7-1
prison5.84.0.r323.g4fee056-15.85.0.r326.ge95c14c-1
purpose5.84.0.r869.g23c142a-15.85.0.r872.gba798d7-1
qcachegrind21.04.3.r1151.ge04e43e-121.08.0.r1151.ge04e43e-1
qqc2-desktop-style5.84.0.r507.gd1ce238-15.85.0.r515.g509f0f7-1
rocs21.04.3.r3022.gc2e0af1d-121.08.0.r3026.gecdb6a31-1
signon-kwallet-extension21.04.3.r65.g82912be-121.08.0.r65.g82912be-1
solid5.84.0.r694.gec915ed-15.85.0.r699.g0e7d56e-1
sonnet5.84.0.r623.gf7fbede-15.85.0.r628.g037df8e-1
spacebar 21.07.r6.gc80303c-1 21.07.r8.g842fa38-1
spectacle21.04.3.r1146.gc168340-121.08.0.r1149.g1d53cd0-1
step21.04.3.r1155.g2b2c1cc-121.08.0.r1155.g2b2c1cc-1
svgpart21.04.3.r179.ga6fa58c-121.08.0.r179.ga6fa58c-1
sweeper21.04.3.r527.g04cbc19-121.08.0.r527.g04cbc19-1
syndication5.84.0.r834.g43f3876-15.85.0.r837.gf71da59-1
syntax-highlighting5.84.0.r1639.gc6084409-15.85.0.r1647.g35cf6684-1
systemsettings5.22.4.r2479.g4d525b5d-15.22.4.r2481.g87be1c58-1
telepathy-kde-accounts-kcm21.04.3.r1195.gd0ffbec-121.08.0.r1195.gd0ffbec-1
telepathy-kde-approver21.04.3.r295.g4f4fc32-121.08.0.r295.g4f4fc32-1
telepathy-kde-auth-handler21.04.3.r277.g1db14c4-121.08.0.r277.g1db14c4-1
telepathy-kde-call-ui21.04.3.r445.g8815182-121.08.0.r445.g8815182-1
telepathy-kde-common-internals21.04.3.r1994.g4d6f30e-121.08.0.r1994.g4d6f30e-1
telepathy-kde-contact-list21.04.3.r1085.g6ede63e-121.08.0.r1085.g6ede63e-1
telepathy-kde-contact-runner21.04.3.r253.g9fa10bb-121.08.0.r253.g9fa10bb-1
telepathy-kde-desktop-applets21.04.3.r995.gc1eb268-121.08.0.r995.gc1eb268-1
telepathy-kde-filetransfer-handler21.04.3.r220.g3eb1cbb-121.08.0.r220.g3eb1cbb-1
telepathy-kde-integration-module21.04.3.r391.g52b0f46-121.08.0.r391.g52b0f46-1
telepathy-kde-send-file21.04.3.r228.g376d937-121.08.0.r228.g376d937-1
telepathy-kde-text-ui21.04.3.r2020.gf0e1be3-121.08.0.r2020.gf0e1be3-1
threadweaver5.84.0.r504.gb7953f0-15.85.0.r507.gf4b4ad4-1
umbrello21.04.3.r8261.g8ac7e25df-121.08.0.r8261.g8ac7e25df-1
vvave 2.0.0.r0.g8a0ebc6-1 2.0.0.r2.g7416427-1
wrapland5.22.0.r1536.g6d7ebc9-15.22.4.r1536.g6d7ebc9-1
yakuake21.04.3.r729.g7053b39-121.08.0.r729.g7053b39-1
zeroconf-ioslave21.04.3.r357.gb6713ee-121.08.0.r357.gb6713ee-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
