Autorun.desktop permission denies
systemd-xdg-autostart-generator[814]: Not generating service for XDG autostart app-Autorun.desktop@autostart.service, error parsing Exec= line: Permission denied
I get this error once before and after lightdm is started, not sure if they are related.
journalctl -b | grep -i error
Aug 18 11:50:27 archlinux alsactl[396]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -2
Aug 18 11:50:27 archlinux alsactl[396]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:1 use case configuration -2
Aug 18 11:50:27 archlinux alsactl[396]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:2 use case configuration -2
Aug 18 11:50:35 rpi NetworkManager[341]: <warn>  [1629305435.6987] dns-sd-resolved[735e08197578e10f]: send-updates SetLinkDomains@2 failed: GDBus.Error:org.freedesktop.resolve1.LinkBusy: Link eth0 is managed.
Aug 18 11:51:24 rpi systemd-xdg-autostart-generator[814]: Not generating service for XDG autostart app-Autorun.desktop@autostart.service, error parsing Exec= line: Permission denied
Aug 18 11:51:24 rpi lightdm[782]: Error opening audit socket: Protocol not supported
Aug 18 11:51:26 rpi systemd-xdg-autostart-generator[949]: Not generating service for XDG autostart app-Autorun.desktop@autostart.service, error parsing Exec= line: Permission denied
Aug 18 11:51:28 rpi kcminit_startup[974]: QDBusConnection: error: could not send signal to service "" path "//home/qc/jlb/.kde/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/qc/jlb/.kde/share/config/kdeglobals
Aug 18 11:51:31 rpi ksmserver[1034]: Qt: Session management error: networkIdsList argument is NULL
Aug 18 11:51:32 rpi kwin_x11[987]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1148, resource id: 12582917, major code: 18 (ChangeProperty), minor code: 0
Aug 18 11:51:33 rpi kernel: hdmi-audio-codec hdmi-audio-codec.3.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -19
Aug 18 11:51:33 rpi kded5[983]: kf.bluezqt: PendingCall Error: "Unit dbus-org.bluez.service not found."
Aug 18 11:51:33 rpi kscreen_backend_launcher[1096]: kscreen.xcb.helper: Event Error:  147
Aug 18 11:51:39 rpi xembedsniproxy[1052]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 454, resource id: 46137347, major code: 12 (ConfigureWindow), minor code: 0
Aug 18 11:51:43 rpi plasmashell[1044]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:213: Error: Invalid write to global property "prefix"
Aug 18 11:51:43 rpi kwin_x11[987]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1541, resource id: 6291490, major code: 18 (ChangeProperty), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1270, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1271, resource id: 44040274, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1272, resource id: 44040274, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1273, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1274, resource id: 44040276, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1275, resource id: 44040276, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1276, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1277, resource id: 44040278, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1278, resource id: 44040278, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1279, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1280, resource id: 44040280, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1281, resource id: 44040280, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1282, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1283, resource id: 44040282, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1284, resource id: 44040282, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1285, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1286, resource id: 44040284, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1287, resource id: 44040284, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1288, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1289, resource id: 44040286, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1290, resource id: 44040286, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1291, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1292, resource id: 44040288, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:47 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1293, resource id: 44040288, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2757, resource id: 44040278, major code: 54 (FreePixmap), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2758, resource id: 44040279, major code: 60 (FreeGC), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2759, resource id: 44040280, major code: 54 (FreePixmap), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2760, resource id: 44040281, major code: 60 (FreeGC), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2761, resource id: 44040282, major code: 54 (FreePixmap), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2762, resource id: 44040283, major code: 60 (FreeGC), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2763, resource id: 44040284, major code: 54 (FreePixmap), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2764, resource id: 44040285, major code: 60 (FreeGC), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2765, resource id: 44040286, major code: 54 (FreePixmap), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2766, resource id: 44040287, major code: 60 (FreeGC), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2767, resource id: 44040288, major code: 54 (FreePixmap), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2768, resource id: 44040289, major code: 60 (FreeGC), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2769, resource id: 44040274, major code: 54 (FreePixmap), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2770, resource id: 44040275, major code: 60 (FreeGC), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 4 (BadPixmap), sequence: 2771, resource id: 44040276, major code: 54 (FreePixmap), minor code: 0
Aug 18 11:51:52 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 13 (BadGC), sequence: 2772, resource id: 44040277, major code: 60 (FreeGC), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2986, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2987, resource id: 44040314, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2988, resource id: 44040314, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2989, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2990, resource id: 44040316, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2991, resource id: 44040316, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2992, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2993, resource id: 44040318, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2994, resource id: 44040318, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2995, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2996, resource id: 44040320, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2997, resource id: 44040320, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 2998, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 2999, resource id: 44040322, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 3000, resource id: 44040322, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 3001, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 3002, resource id: 44040324, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 3003, resource id: 44040324, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 3004, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 3005, resource id: 44040326, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 3006, resource id: 44040326, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 3007, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 3008, resource id: 44040328, major code: 55 (CreateGC), minor code: 0
Aug 18 11:51:55 rpi plasmashell[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 3009, resource id: 44040328, major code: 72 (PutImage), minor code: 0
Aug 18 11:51:58 rpi kactivitymanagerd[1037]: org.kde.kactivities.resources: QSqlError("11", "Unable to fetch row", "database disk image is malformed")
Aug 18 11:52:00 rpi kactivitymanagerd[1037]: org.kde.kactivities.resources: QSqlError("11", "Unable to fetch row", "database disk image is malformed")
Aug 18 11:52:13 rpi kwin_x11[987]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3538, resource id: 44040353, major code: 18 (ChangeProperty), minor code: 0
Aug 18 11:52:14 rpi kactivitymanagerd[1037]: org.kde.kactivities.resources: QSqlError("11", "Unable to fetch row", "database disk image is malformed")
Aug 18 11:52:16 rpi kactivitymanagerd[1037]: org.kde.kactivities.resources: QSqlError("11", "Unable to fetch row", "database disk image is malformed")
What is the content of your /etc/xdg/autostart/ and ~/.config/autostart/ ?
I believe a couple you have there has wrong permissions, or the executable they point to have wrong permissions.
From the error the issue would be with: ~/.config/Autorun.desktop.desktop:
-rw------- 1 {myloginid} {mygroupid} 168 Jun 14 11:08 Autorun.desktop.desktop
~/.config/autostart/Autorun.desktop.desktop
[Desktop Entry]
Exec=/home/jlb/.config/old-autostart-scripts/Autorun.desktop
Icon=dialog-scripts
Name=Autorun.desktop
Path=
Type=Application
X-KDE-AutostartScript=true
I do not think that I created the file, but possibly. Not sure why the error (or two), my login process should be able to read the file. I’ll chmod the permissions to 644 and that should resolve the errors.
The other file permissions are 644.
Does not look like a proper name for a .destop file. Should be just one .destop
Maybe renaming it will work because I received the same two errors after changing the permissions. I’ll try renaming it now.
After renaming the file, same errors:
Aug 18 14:52:30 rpi systemd-xdg-autostart-generator[818]: Not generating service for XDG autostart app-Autorun@autostart.service, error parsing Exec= line: Permission denied
Aug 18 14:52:30 rpi lightdm[784]: Error opening audit socket: Protocol not supported
Aug 18 14:52:32 rpi systemd-xdg-autostart-generator[953]: Not generating service for XDG autostart app-Autorun@autostart.service, error parsing Exec= line: Permission denied
ls -l ~/.config/autostart
total 12
-rw-r--r-- 1 jlb devl_users 168 Jun 14 11:08 Autorun.desktop
-rw-r--r-- 1 jlb devl_users 167 Mar 12 06:32 mntray.desktop
-rw-r--r-- 1 jlb devl_users 156 Jun  8 06:34 org.moson.matray.desktop
ls -l /etc/xdg/autostart/
total 84
-rw-r--r-- 1 root root   292 Jul  9 18:02 at-spi-dbus-bus.desktop
-rw-r--r-- 1 root root  2002 Aug 14 15:31 baloo_file.desktop
-rw-r--r-- 1 root root  1397 Aug  8 04:37 gmenudbusmenuproxy.desktop
-rw-r--r-- 1 root root  2985 Jul 27 19:48 kaccess.desktop
-rw-r--r-- 1 root root 11875 Aug  8 04:37 klipper.desktop
-rw-r--r-- 1 root root  1122 Jul 27 08:51 org.kde.discover.notifier.desktop
-rw-r--r-- 1 root root  2939 Aug  8 04:37 org.kde.plasmashell.desktop
-rw-r--r-- 1 root root   156 Jul 12 17:19 org.moson.matray.desktop
-rw-r--r-- 1 root root  4460 Jul 27 08:48 pam_kwallet_init.desktop
-rw-r--r-- 1 root root   169 Jun 21 08:36 pamac-tray-budgie.desktop
-rw-r--r-- 1 root root   171 Jun 21 08:36 pamac-tray.desktop
-rw-r--r-- 1 root root  4457 Jul 27 08:43 polkit-kde-authentication-agent-1.desktop
-rw-r--r-- 1 root root  5726 Jul 27 19:44 powerdevil.desktop
-rw-r--r-- 1 root root  5315 Jul 28 19:40 pulseaudio.desktop
-rw-r--r-- 1 root root  1400 Aug  8 04:37 xembedsniproxy.desktop
As you don’t know if you created those autostarts or not, maybe you should just remove them?
They are not provided by us, at least and I don’t know of any “autorun” package.
What does this file contain?
cat /home/jlb/.config/old-autostart-scripts/Autorun.desktop
[Desktop Entry]
Name=Autorun
Name[cs]=Autorun
Name[da]=Autorun
Name[de]=Autorun
Name[es]=Autorun
Name[fr]=Autorun
Name[is]=Autorun
Name[it]=Autorun
Name[ja]=オートラン
Name[ko]=Autorun
Name[no]=Autorun
Name[pt]=Autorun
Name[ru]=Autorun
Name[sv]=Autorun
Name[tr]=Autorun
Name[zh_CN]=Autorun
Name[zh_TW]=Autorun
Comment=Autorun - the CD-ROM mounter for the lazy user
Comment[cs]=Autorun - připojovač CD-ROM pro líného uživatele
Comment[da]=Autorun - CD-montering for den dovne bruger
Comment[de]=Autorun - der CD-ROM Mounter für den trägen Benutzer
Comment[es]=Autorun - el montador de CD-ROM para el usuario holgazán
Comment[fr]=Autorun - le monteur de CD-ROM pour les paresseux
Comment[is]=Autorun - Geisladrifstengill fyrir lata notandann
Comment[it]=Autorun - il CD-ROM mounter per gli utenti più pigri!
Comment[ja]=オートラン---怠け者ユーザーの為のCD-ROMマウンター
Comment[ko]=Autorun - 게으른 사용자를 위한 CD-ROM 마운트 프로그램
Comment[no]=Autorun - CD-montering for den late bruker
Comment[pt]=Autorun - ferramenta para montar CD-ROMS para o utilizador preguiçoso
Comment[ru]=Autorun - программа монтирования CD-ROM для ленивого пользователя
Comment[sv]=Autorun - cd-rommonteraren för den late användaren
Comment[tr]=Autorun - aceleci kullanıcılar için CD-ROM bağlayıcı
Comment[zh_CN]=Autorun - 给喜欢省事的用户提供的光盘挂载器
Comment[zh_TW]=Autorun - 給懶惰使用者的 CD-ROM 掛載器
Exec=/usr/bin/autorun -l --interval=1000 --cdplayer=/usr/bin/kscd
Type=Application
Categories=Application;Utility;X-Red-Hat-Base;
Encoding=UTF-8
Do you have these executables?
It looks like you installed something called “Autorun - The CD_ROM mounter for the lazy user” at some point…
I am old… forgive me. I am in the office and this /home is my network home (nfs mount). Removing the file resolves the errors.
Yeah, you might have used the same /home for a red-hat box at some point. :wink:
Yes, we have been a RHEL shop, Manjaro is our new norm. So the mixing of the two is currently unavoidable, but I am working on it. :slight_smile:
