Hello ARM community.
A big update this time. Boost was updated, Plasma was updated. Lots of stuff was updated!
Try out Plasma 5.22!
Some highlights:
- Most of our kernels got updated
- Plasma is now updated to 5.22
- A new major version of Pacman brings it to version 6.0
- Boost was updated to 1.76, resulting in a lot of rebuilds. Did we miss any?
- Version 21.06 of PlaMo Gear brings in a couple of new apps, like Kasts
- Pamac version 10.1.3 now works with the updated pacman
- Lots of Mobile specific packages got updated
- Many python packages got updated
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
https://archlinux.org/news/sorting-out-old-password-hashes/
Older notifications
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss
package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip
and firewalld
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
(Sun Jun 13 21:22:47 CEST 2021)
- arm-testing community aarch64: 446 new and 439 removed package(s)
- arm-testing core aarch64: 43 new and 43 removed package(s)
- arm-testing extra aarch64: 591 new and 588 removed package(s)
- arm-testing kde-unstable aarch64: 350 new and 348 removed package(s)
- arm-testing mobile aarch64: 0 new and 1 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-06-07 2021-06-13
alligator 21.05-2 21.06-1
anbox 0_git20210320-1 0_git20210320-2
angelfish 21.05-1 21.06-1
appimagelauncher 2.2.0-4 2.2.0-5
arch-audit 0.1.19-1 -
arch-repro-status 1.2.0-1 -
calindori 21.05-1 21.06-1
calls 0.3.3+47+g9b5508c-1 0.3.4-1
chatty 0.3.1+31+g6355b74-1 0.3.1+38+gef0cb56-1
eg25-manager 0.3.0+2+g64145ac-7 0.3.0+2+g64145ac-8
electron 13.1.0-1 13.1.2-1
electron12 12.0.10-1 12.0.11-2
expac 10-2 -
kalk 21.05-1 21.06-1
kclock 21.05-1 21.06-1
koko 21.05-1 21.06-1
kongress 21.05-1 21.06-1
krecorder 21.05-1 21.06-1
ktrip 21.05-1 21.06-1
kweather 0.4-0 21.06-1
libpackagekit-glib 1.1.13-1.1 1.2.3-0.1
manjaro-arm-installer 1.4.1-1 1.4.2-1
megapixels 1.0.1-1 1.0.1-2
obs-studio 26.1.1-1 27.0.1-1
packagekit 1.1.13-1.1 1.2.3-0.1
pacutils 0.10.0-1 -
pcurses 5-3 -
phosh 0.11.0-2 0.11.0+12+g2ca82dd-1
pinephone-post-install 20210325-1 20210612-2
pinetab-post-install 20210526-1 20210610-1
plasma-dialer 21.05-2 21.06-1
plasma-phonebook 21.05-1 21.06-1
plasma-settings 21.05-1 21.06-1
qmlkonsole 21.05-1 21.06-1
repose 7.1-5 -
spacebar 21.05-1 21.06-1
vivaldi 3.8.2259.42-1 4.0.2312.25-1
wcm 0.7.0-1 0.7.0-2
hfd-service - 0.1.0-1
kasts - 21.06-1
keysmith - 21.06-1
tokodon - 21.06-1
:: Different sync package(s) in repository community aarch64
acorn 1:8.3.0-1 1:8.4.0-1
adriconf 2.4.1-1 2.4.1-2
afl 2.57b-5 2.57b-6
alembic 1.8.1-2 1.8.2-1
ansible 4.0.0-1 4.1.0-1
babel-cli 7.14.3-1 7.14.5-1
babel-core 7.14.3-1 7.14.5-1
babeld 1.9.2-2 1.10-1
baidupcs-go 3.8.0-1 3.8.1-1
bcc 0.20.0-1 0.20.0-3
bcc-tools 0.20.0-1 0.20.0-3
bchoppr 1.10.6-1 1.10.8-1
bees 0.6.4-2 0.6.5-1
bitcoin-cli 0.21.1-1 0.21.1-2
bitcoin-daemon 0.21.1-1 0.21.1-2
bitcoin-qt 0.21.1-1 0.21.1-2
bitcoin-tx 0.21.1-1 0.21.1-2
blender 17:2.93.0-2 17:2.93.0-4
borgmatic 1.5.13-2 1.5.14-1
bpftrace 0.12.0-1 0.12.0-2
bpytop 1.0.66-1 1.0.67-1
bshapr 0.12-1 0.13-1
bslizr 1.2.14-1 1.2.16-1
caddy 2.4.1-1 2.4.2-1
calibre 5.20.0-1 5.21.0-1
camlp4 4.10-1 4.11-1
cclive 0.9.3-24 0.9.3-25
ccls 0.20210330-1 0.20210330-2
ceph 15.2.12-1 15.2.12-2
ceph-libs 15.2.12-1 15.2.12-2
ceph-mgr 15.2.12-1 15.2.12-2
cgal 4.14.3-1 4.14.3-2
chafa 1.6.0-2 1.6.1-1
cimg 2.9.6-1 2.9.7-1
cinnamon-screensaver 5.0.2-1 5.0.4-1
cinnamon-settings-daemon 5.0.0-1 5.0.1-1
cockpit 245-1 246-1
cockpit-machines 244.1-1 245-1
cockpit-pcp 245-1 246-1
containers-common 0.39.0-2 0.39.0-3
cordova 10.0.0-1 10.0.0-2
cpp-hocon 0.3.0-5 0.3.0-6
croc 9.1.4-1 9.1.5-1
cryptominisat5 5.8.0-5 5.8.0-6
ctop 0.7.5-3 0.7.6-1
dart 2.13.1-1 2.13.3-1
dcd 1:0.13.2-1 1:0.13.4-1
dd_rescue 1.99.10-1 1.99.11-1
diesel-cli 1.4.6-1 1.4.7-1
dnsperf 2.5.2-2 2.6.0-1
drupal 9.1.7-1 9.1.10-1
dub 1.25.0-1 1.26.0-1
eclib 20210503-1 20210503-2
efm-langserver 0.0.30-1 0.0.31-1
emscripten 2.0.17-1 2.0.24-1
facter 3.14.16-3 3.14.16-4
faust 2.30.5-2 2.30.5-3
fcitx5-chinese-addons 5.0.6-1 5.0.6-2
feeluown-qqmusic 0.3.2-1 0.3.3-1
firefox-tree-style-tab 3.8.0-1 3.8.2-1
fossil 2.15-1 2.15.1-1
foxdot 0.8.11-2 0.8.12-1
freecad 0.19.1-2 0.19.2-2
freeradius 3.0.22-2 3.0.23-1
gdal 3.2.3-3 3.3.0-1
gdnsd 3.5.1-1 3.5.2-1
gearmand 1.1.18-14 1.1.18-15
giac 1.7.0.11-1 1.7.0.13-1
giada 0.17.2-1 0.18.0.1-1
gimagereader-common 3.3.1-3 3.3.1-4
gimagereader-gtk 3.3.1-3 3.3.1-4
gimagereader-qt 3.3.1-3 3.3.1-4
gitui 0.15.0-1 0.16.1-1
glob2 0.9.4.4-41 0.9.4.4-42
glom 1.32.0-5 1.32.0-6
gmt 6.1.1-2 6.1.1-3
gmt-doc 6.1.1-2 6.1.1-3
gnuradio 3.8.2.0-1 3.8.2.0-2
gnuradio-companion 3.8.2.0-1 3.8.2.0-2
gnuradio-osmosdr 0.2.3-1 0.2.3-2
gocryptfs 2.0-1 2.0.1-1
gource 0.51-5 0.51-6
gpg-tui 0.3.0-1 0.4.1-1
gpick 0.2.6-1 0.2.6-2
grunt-cli 1.4.3-1 1.4.3-2
heaptrack 1.2.0-3 1.2.0-4
helmfile 0.139.7-1 0.139.9-1
hexer-hobu 1.4.0-5 1.4.0-6
hoel 1.4.17-3 1.4.18-1
htmlhint 0.14.2-3 0.15.1-1
hugin 2020.0.0-3 2020.0.0-4
i2pd 2.38.0-1 2.38.0-2
iaito 5.2.2-1 5.2.2-2
ibus-table 1.13.1-1 1.13.3-1
icewm 2.3.4-1 2.4.0-1
imagescan 3.65.0-2 3.65.0-3
innoextract 1.9-3 1.9-4
isync 1.4.1-1 1.4.2-1
jedi-language-server 0.31.0-1 0.31.2-1
jenkins 2.296-1 2.297-1
jruby 9.2.17.0-1 9.2.18.0-1
kea 1.9.6-2 1.9.8-3
kitty 0.20.3-1 0.21.0-1
kitty-terminfo 0.20.3-1 0.21.0-1
klayout 0.27-2 0.27.1-1
kubeone 1.2.1-2 1.2.2-1
kup 0.9.0-2 0.9.1-1
ldc 2:1.26.0-1 2:1.26.0-3
leatherman 1.12.4-1 1.12.4-2
ledger 3.2.1-6 3.2.1-7
level-zero-headers 1.0.22-1 1.2.3-1
level-zero-loader 1.0.22-1 1.2.3-1
libck 0.7.0-1 0.7.1-1
libcontentaction 0.3.16-1 0.3.18-1
libgig 4.2.0-3 4.3.0-3
libime 1.0.7-1 1.0.7-2
libiodbc 3.52.14-1 3.52.15-1
liblas1.8.1.r120+ge12742f4-41.8.1.r120+ge12742f4-6
liblphobos 2:1.26.0-1 2:1.26.0-3
liblscp 0.6.0-3 0.9.3-1
libquotient 0.6.6-1 0.6.7-1
librecad 2.1.3-5 2.1.3-6
libressl 3.2.5-1 3.3.3-1
libretro-core-info 1.9.2-1 1.9.4-1
libretro-shaders-slang 802-1 808-1
libuhd 4.0.0.0-1 4.0.0.0-2
libvips 8.10.6-5 8.11.0-1
libwhereami 0.5.0-5 0.5.0-6
libzim 6.3.0-3 6.3.2-1
linssid 3.6-7 3.6-9
lmms 1.2.2-3 1.2.2-4
lucene++ 3.0.8-1 3.0.8-2
luminancehdr 2.6.1-1 2.6.1-2
mapnik 3.1.0-3 3.1.0-5
matterbridge 1.22.1-1 1.22.2-1
mdbook 0.4.9-1 0.4.10-1
mediawiki 1.35.2-1 1.36.0-1
mediawiki-math 1.35.2-1 1.36.0-1
merkaartor 0.18.4-6 0.18.4-7
minikube 1.20.0-1 1.21.0-1
minio 2021.03.17-1 2021.06.09-1
minio-client 2021.02.19-1 2021.06.08-1
mlite 0.3.5-1 0.3.7-1
mod_passenger 6.0.8-3 6.0.9-2
molecule 3.3.3-1 3.3.4-1
mosquitto 2.0.10-2 2.0.11-1
mujs 1.1.2-1 1.1.3-1
nbtscan 1.5.1-8 1.6-1
ncmpcpp 0.9.2-2 0.9.2-3
nemo 5.0.0-1 5.0.1-1
nextcloud-app-spreed 1:11.2.1-1 1:11.3.0-1
nginx-mod-auth-pam 1.5.2-2 1.5.2-3
nginx-mod-brotli 1:1.0.0rc-2 1:1.0.0rc-3
nginx-mod-cache_purge 2.5.1-2 2.5.1-3
nginx-mod-echo 0.62-1 0.62-2
nginx-mod-geoip2 3.3-3 3.3-4
nginx-mod-headers-more 0.33-8 0.33-9
nginx-mod-memc 0.19-7 0.19-8
nginx-mod-modsecurity 1:1.0.1-4 1:1.0.2-2
nginx-mod-naxsi 1.3-3 1.3-4
nginx-mod-ndk 0.32+0.3.1-4 0.32+0.3.1-5
nginx-mod-njs 0.5.3-2 0.5.3-3
nginx-mod-passenger 6.0.8-3 6.0.9-2
nginx-mod-redis 0.3.9-7 0.3.9-8
nginx-mod-redis2 0.15-7 0.15-8
nginx-mod-set-misc 0.32+0.3.1-4 0.32+0.3.1-5
nginx-mod-srcache 0.32-2 0.32-3
nginx-mod-vts 0.1.18-3 0.1.18-4
nim 1.4.6-1 1.4.8-1
node-gyp 8.1.0-1 8.1.0-2
npm 7.16.0-1 7.17.0-1
npm-check-updates 11.6.0-1 11.6.0-2
nuitka 0.6.15-1 0.6.15.3-1
ocrfeeder 0.8.3-4 0.8.3-5
openimageio 2.2.15.1-1 2.2.15.1-3
openscad 2021.01-1 2021.01-2
openscenegraph 3.6.5-5 3.6.5-6
openshadinglanguage 1.11.14.0-1 1.11.14.0-3
opensips 3.1.0-1 3.1.2-1
openvdb 8.0.1-4 8.0.1-5
openxr 1.0.16-1 1.0.17-1
orcania 2.2.1-1 2.2.1-2
pacredir 0.4.3-1 0.4.4-1
pamixer 1.4-5 1.4-6
paperwork 2.0.2-1 2.0.3-1
pass 1.7.3-4 1.7.4-1
pcp 5.3.0-2 5.3.1-1
pcp-gui 5.3.0-2 5.3.1-1
pcp-pmda-activemq 5.3.0-2 5.3.1-1
pcp-pmda-bcc 5.3.0-2 5.3.1-1
pcp-pmda-bind2 5.3.0-2 5.3.1-1
pcp-pmda-bpftrace 5.3.0-2 5.3.1-1
pcp-pmda-libvirt 5.3.0-2 5.3.1-1
pcp-pmda-mysql 5.3.0-2 5.3.1-1
pcp-pmda-nginx 5.3.0-2 5.3.1-1
pcp-pmda-nutcracker 5.3.0-2 5.3.1-1
pcp-pmda-openmetrics 5.3.0-2 5.3.1-1
pcp-pmda-podman 5.3.0-2 5.3.1-1
pcp-pmda-postgresql 5.3.0-2 5.3.1-1
pcp-pmda-snmp 5.3.0-2 5.3.1-1
pdal 2.2.0-2 2.2.0-3
perl-crypt-cbc 2.33-4 3.04-1
perl-datetime-format-iso8601 0.08-5 0.16-1
perl-datetime-format-w3cdtf 0.07-4 0.08-1
perl-datetime-locale 1.22-2 1.32-1
perl-json-xs 4.0-5 4.03-1
perl-ldap 0.67-1 0.68-1
perl-poe 1.367-4 1.368-1
perl-term-readline-gnu 1.38-1 1.40-1
phonegap 9.0.0-1 9.0.0-2
php-igbinary 3.2.2-1 3.2.3-1
php7-igbinary 3.2.2-1 3.2.3-1
phpmyadmin 5.1.0-1 5.1.1-1
picard 2.6.2-1 2.6.3-1
pm2 4.5.6-1 5.1.0-1
poedit 1:2.4.3-1 1:3.0-3
polymake 4.4-2 4.4-3
postgis 3.1.1-1 3.1.2-1
povray 2:3.7.0.8-11 2:3.7.0.9-1
powerdns 4.4.1-3 4.4.1-4
powerdns-recursor 4.5.1-1 4.5.2-1
prjtrellis 1.0-4 1.0-5
proxytunnel 1.9.0.253-4 1.10.20210604-1
prusa-slicer 2.3.1-2 2.3.1-3
pulseview 0.4.2-4 0.4.2-5
pyenv 2.0.0-1 2.0.1-1
pynac 0.7.27-1 0.7.27-2
pyright 1.1.147-1 1.1.148-1
python-apispec 4.4.2-1 4.5.0-1
python-awesomeversion 21.5.0-1 21.6.0-1
python-bcc 0.20.0-1 0.20.0-3
python-black 21.5b2-1 21.6b0-1
python-btrees 4.7.2-3 4.8.0-1
python-configargparse 1.2.3-3 1.4.1-1
python-django-crispy-forms 1.11.2-1 1.12.0-1
python-django-modeltranslation 0.17.1-1 0.17.2-1
python-django-q 1.3.6-1 1.3.9-1
python-docutils 0.16-4 0.17-1
python-email-validator 1.1.2-3 1.1.3-1
python-engineio 4.1.0-1 4.2.0-1
python-faker 8.5.1-1 8.7.0-1
python-fasteners 0.15-5 0.16-1
python-gdal 3.2.3-3 3.3.0-1
python-gdspy 1.6.4-1 1.6.6-1
python-hypothesis 6.13.13-1 6.14.0-1
python-identify 2.2.9-1 2.2.10-1
python-igraph 0.9.4-1 0.9.6-1
python-jose 3.2.0-4 3.3.0-1
python-libarchive-c 2.9-3 3.1-1
python-manhole 1.7.0-1 1.8.0-1
python-marshmallow-sqlalchemy 0.24.2-1 0.26.1-1
python-minidb 2.0.4-3 2.0.5-1
python-mongomock 3.22.1-1 3.23.0-1
python-neutronclient 7.4.0-1 7.5.0-1
python-noseofyeti 2.0.2-1 2.0.3-1
python-osc-lib 2.3.1-1 2.4.0-2
python-oslo-concurrency 4.4.0-1 4.4.0-2
python-oslo-config 8.4.0-1 8.6.0-1
python-oslo-i18n 5.0.1-3 5.0.1-4
python-oslo-log 4.5.0-1 4.5.0-2
python-oslo-serialization 4.1.0-1 4.1.0-2
python-oslo-utils 4.9.0-1 4.9.0-2
python-osprofiler 3.4.0-3 3.4.1-1
python-pefile 2019.4.18-1 2021.5.24-1
python-persistent 4.7.0-1 4.7.0-2
python-pikepdf 2.12.1-1 2.12.2-1
python-pint 0.16.1-3 0.17-1
python-pipenv 2020.11.15-1 2021.5.29-1
python-prawcore 2.0.0-1 2.2.0-1
python-pycapnp 1.0.0-1 1.1.0-1
python-pyfakefs 4.4.0-1 4.5.0-1
python-pynitrokey 0.4.2-1 0.4.3.1-1
python-pytesseract 0.3.7-3 0.3.8-1
python-pytest-cov 2.12.0-1 2.12.1-1
python-pytest-django 4.3.0-1 4.4.0-1
python-pytest-repeat 0.9.0-1 0.9.1-1
python-quart 0.15.0-1 0.15.1-1
python-queuelib 1.6.0-1 1.6.1-1
python-r2pipe 5.1.0-1 5.3.0-1
python-requests-aws4auth 1.0.1-3 1.1.1-1
python-rich 10.2.2-1 10.3.0-1
python-ruamel-yaml 0.17.7-1 0.17.9-1
python-setuptools-rust 0.12.0-1 0.12.1-1
python-slugify 5.0.1-1 5.0.2-1
python-socketio 5.2.1-1 5.3.0-1
python-sphinxcontrib-bibtex 2.2.0-1 2.3.0-1
python-subprocess-tee 0.3.1-1 0.3.2-1
python-tqdm 4.61.0-1 4.61.1-1
python-typeguard 2.11.1-1 2.12.0-1
python-unicorn 1.0.2-2 1.0.3-1
python-websockets 9.0.1-3 9.1-1
python-yara 4.0.5-2 4.1.0-1
python-z3 4.8.10-1 4.8.11-1
python2-docutils 0.16-4 0.17-1
python2-pygments 2.5.2-2 -
python2-pytest-cov 2.12.0-1 2.12.1-1
qbittorrent 4.3.3-1 4.3.5-1
qbittorrent-nox 4.3.3-1 4.3.5-1
qcad 3.26.3.0-1 3.26.4.2-1
qgis 3.18.3-1 3.18.3-2
qmapshack1.15.2+35+ga06d2f78-1 1.16.0-1
r2ghidra 5.2.1-2 5.3.0.r6.ge9d8fafe-1
radare2 5.2.1-1 5.3.1-1
realtime-privileges 2-2 3-1
remmina 1:1.4.17-1 1:1.4.18-1
retroarch 1.9.3-1 1.9.4-1
rhonabwy 0.9.9999-1 0.9.9999-2
ripgrep 12.1.1-1 13.0.0-1
rng-tools 6.12-1 6.13-1
rubberband 1.9.1-1 1.9.2-1
ruby-bundler 2.2.19-1 2.2.20-1
ruby-mini_portile2 2.5.0-2 2.6.1-1
ruby-nokogiri 1.11.2-2 1.11.7-2
ruby-unicorn-engine 1.0.2-2 1.0.3-1
rust-analyzer 20210531-1 20210607-1
rustup 1.24.2-1 1.24.3-1
s3fs-fuse 1.88-1 1.89-1
sbt 1:1.5.1-1 1:1.5.2-1
schroot 1.6.10-26 1.6.10-27
singular 4.2.0.p3-1 4.2.1-1
skaffold 1.25.0-1 1.26.0-1
skrooge 2.24.6-1 2.25.0-1
snap-pac 2.3.3-1 3.0.1-1
snapper 0.9.0-1 0.9.0-2
sniffit 0.4.0-1 0.5-1
soapyosmo 0.2.5-9 0.2.5-10
sqlitebrowser 3.12.1-1 3.12.2-1
sslscan 1.10.2-8 2.0.10-1
sssd 2.5.0-1 2.5.1-1
sstp-client 1:1.0.13-1 1:1.0.15-1
strip-nondeterminism 1.9.0-2 1.12.0-1
supercollider 3.11.2-3 3.11.2-4
supertux 0.6.2-3 0.6.2-4
swift-im 4.0.2-4 4.0.2-5
swiften 4.0.2-4 4.0.2-5
swtpm 0.5.2-2 0.6.0-1
sympol 0.1.9-8 0.1.9-9
tailscale 1.8.6-1 1.8.7-1
tekton-cli 0.18.0-1 0.19.0-1
terraform 0.15.5-1 1.0.0-1
terragrunt 0.29.2-1 0.29.10-1
thefuck 3.30-3 3.31-1
tiled 1.6.0-1 1.7.0-1
tinygo 0.17.0-1 0.18.0-1
tmux 3.2-1 3.2_a-1
trash-cli 0.17.1.14-6 0.21.5.25-1
trojan 1.16.0-3 1.16.0-4
ttc-iosevka 7.0.2-1 7.0.4-1
ttc-iosevka-aile 7.0.2-1 7.0.4-1
ttc-iosevka-curly 7.0.2-1 7.0.4-1
ttc-iosevka-curly-slab 7.0.2-1 7.0.4-1
ttc-iosevka-etoile 7.0.2-1 7.0.4-1
ttc-iosevka-slab 7.0.2-1 7.0.4-1
ttc-iosevka-ss01 7.0.2-1 7.0.4-1
ttc-iosevka-ss02 7.0.2-1 7.0.4-1
ttc-iosevka-ss03 7.0.2-1 7.0.4-1
ttc-iosevka-ss04 7.0.2-1 7.0.4-1
ttc-iosevka-ss05 7.0.2-1 7.0.4-1
ttc-iosevka-ss06 7.0.2-1 7.0.4-1
ttc-iosevka-ss07 7.0.2-1 7.0.4-1
ttc-iosevka-ss08 7.0.2-1 7.0.4-1
ttc-iosevka-ss09 7.0.2-1 7.0.4-1
ttc-iosevka-ss10 7.0.2-1 7.0.4-1
ttc-iosevka-ss11 7.0.2-1 7.0.4-1
ttc-iosevka-ss12 7.0.2-1 7.0.4-1
ttc-iosevka-ss13 7.0.2-1 7.0.4-1
ttc-iosevka-ss14 7.0.2-1 7.0.4-1
ttc-iosevka-ss15 7.0.2-1 7.0.4-1
ttc-iosevka-ss16 7.0.2-1 7.0.4-1
ttc-iosevka-ss17 7.0.2-1 7.0.4-1
ttc-iosevka-ss18 7.0.2-1 7.0.4-1
ttf-sarasa-gothic 0.32.3-1 0.32.4-1
ulfius 2.7.3-1 2.7.3-2
unarj 2.63a-6 2.65-1
v2ray-domain-list-community 20210606084319-1 20210612110829-1
v2ray-geoip 202106030115-1 202106100026-1
vaultwarden-web 2.20.3-1 2.20.4-1
vigra 1.11.1-32 1.11.1-33
vigra-doc 1.11.1-32 1.11.1-33
vim-ansible 3.1-1 3.2-1
vit 1.3-2 2.1.0-1
vtk 8.2.0-18 8.2.0-19
wake 0.20.1-1 0.20.2-1
wireplumber 0.3.96-1 0.4.0-2
wireplumber-docs 0.3.96-1 0.4.0-2
wireshark-cli 3.4.5-1 3.4.6-1
wireshark-qt 3.4.5-1 3.4.6-1
wt 4.5.0-2 4.5.0-3
xapp 2.2.0-1 2.2.1-1
xdg-desktop-portal-wlr 0.4.0-1 0.4.0-2
xplr 0.14.0-1 0.14.1-1
xwallpaper 0.6.6-1 0.7.0-1
yaegi 0.9.17-1 0.9.18-1
yara 4.0.5-1 4.1.1-1
yder 1.4.14-1 1.4.14-2
yosys 0.9-12 0.9-13
znc 1.8.2-3 1.8.2-4
zsh-autosuggestions 0.6.4-1 0.7.0-1
lzlib - 1.12-2
minisat - 2.2.1.20201216-1
nodejs-nopt - 5.0.0-2
ode - 0.16.2-1
python-fabulous - 0.3.0-2
python-getkey - 0.6.5-1
python-pynetbox - 6.1.2-1
python-tasklib - 2.3.0-1
spirv-llvm-translator - 12.0.0-1
stp - 2.3.3-2
:: Different overlay package(s) in repository core aarch64
linux 5.12.9-1 5.12.10-1
linux-headers 5.12.9-1 5.12.10-1
linux-pinephone 5.12.9-1 5.12.10-1
linux-pinephone-headers 5.12.9-1 5.12.10-1
linux-rpi4 5.10.39-1 5.10.42-1
linux-rpi4-headers 5.10.39-1 5.10.42-1
linux-rpi4-mainline 5.12.6-1 5.12.9-1
linux-rpi4-mainline-headers 5.12.6-1 5.12.9-1
linux-vim 5.12.1-1 5.12.9-1
linux-vim-headers 5.12.1-1 5.12.9-1
manjaro-system 20210607-1 20210612-3
pacman 5.2.2-6 6.0.0-3
pacman-debug 5.2.2-6 6.0.0-3
raspberrypi-bootloader 20210525-1 20210608-1
raspberrypi-bootloader-x 20210525-1 20210608-1
uboot-pinephone 2021.01rc4-2 2021.04-1
uboot-raspberrypi 2021.04-1 2021.04-2
:: Different sync package(s) in repository core aarch64
ca-certificates 20210529-1 20210603-1
ca-certificates-mozilla 3.66-1 3.67-1
ca-certificates-utils 20210529-1 20210603-1
dash 0.5.11.3-1 0.5.11.4-1
dialog 1:1.3_20210509-1 1:1.3_20210530-1
gnutls 3.7.2-1 3.7.2-2
hdparm 9.61-1 9.62-1
inetutils 1.9.4-9 2.0-1
lemon 3.35.5-1 3.35.5-2
libcap 2.50-1 2.50-2
libedit 20210419_3.1-1 20210522_3.1-1
libp11-kit 0.23.22-1 0.24.0-1
libpcap 1.10.0-1 1.10.1-1
libxcrypt 4.4.20-1 4.4.22-4
nettle 3.7.2-1 3.7.3-1
nss 3.66-1 3.67-1
pambase 20200721.1-2 20210605-2
sqlite 3.35.5-1 3.35.5-2
sqlite-analyzer 3.35.5-1 3.35.5-2
sqlite-doc 3.35.5-1 3.35.5-2
sqlite-tcl 3.35.5-1 3.35.5-2
sudo 1.9.7-1 1.9.7.p1-1
util-linux 2.37-1 2.37-3
util-linux-libs 2.37-1 2.37-3
wireless-regdb 2020.11.20-1 2021.04.21-1
:: Different overlay package(s) in repository extra aarch64
appstream-glib 0.7.18-2 0.7.18-3
arch-rebuild-order 0.1.2-1 -
calamares 3.2.34-7 3.2.34-8
disman 0.521.0-1 0.522.0-1
kdisplay 5.21.0-1 5.22.0-1
kwin 5.21.5-1.1 -
kwinft 5.21.0-1 5.22.0-1
mesa-git21.2.0_devel.140212.17d7b0bb8f0-121.2.0_devel.140692.c129ede5238-1
okular 21.04.0-1 -
pamac-cli 10.1.2-2 10.1.3-1
pamac-common 10.1.2-2 10.1.3-1
pamac-gnome-integration 10.1.2-2 10.1.3-1
pamac-gtk 10.1.2-2 10.1.3-1
plasma-mobile-nm 5.21.5-1 5.22.0-1
plasma-nano 5.21.5-1 5.22.0-1
plasma-phone-components 5.21.5-1 5.22.0-1
pyalpm 0.9.2-1 -
qqc2-breeze-style 5.21.5-1 5.22.0-1
wrapland 0.521.0-1 0.522.0-1
kweathercore - 0.3-1
libpamac - 11.0.0-2
libpamac-flatpak-plugin - 11.0.0-2
libpamac-snap-plugin - 11.0.0-2
:: Different sync package(s) in repository extra aarch64
accounts-qml-module 0.7-3 0.7-4
akonadi 21.04.1-1 21.04.2-1
akonadi-calendar 21.04.1-1 21.04.2-1
akonadi-calendar-tools 21.04.1-1 21.04.2-1
akonadi-contacts 21.04.1-1 21.04.2-1
akonadi-import-wizard 21.04.1-1 21.04.2-1
akonadi-mime 21.04.1-1 21.04.2-1
akonadi-notes 21.04.1-1 21.04.2-1
akonadi-search 21.04.1-1 21.04.2-1
akonadiconsole 21.04.1-1 21.04.2-1
akregator 21.04.1-1 21.04.2-1
alsa-card-profiles 1:0.3.29-1 1:0.3.30-2
alsa-ucm-conf 1.2.5-1 1.2.5-2
alsa-utils 1.2.5-2 1.2.5-3
analitza 21.04.1-1 21.04.2-1
aom 3.1.0-1 3.1.1-1
aom-docs 3.1.0-1 3.1.1-1
archlinux-appstream-data 20210423-1 20210612-1
ark 21.04.1-1 21.04.2-1
artikulate 21.04.1-1 21.04.2-1
asymptote 2.64-1 2.70-1
audiocd-kio 21.04.1-1 21.04.2-1
baloo-widgets 21.04.1-1 21.04.2-1
blinken 21.04.1-1 21.04.2-1
bluedevil 1:5.21.5-1 1:5.22.0-1
bomber 21.04.1-1 21.04.2-1
boost 1.75.0-3 1.76.0-1
boost-libs 1.75.0-3 1.76.0-1
bovo 21.04.1-1 21.04.2-1
breeze 5.21.5-2 5.22.0-1
breeze-grub 5.21.5-1 5.22.0-1
breeze-gtk 5.21.5-1 5.22.0-1
cairo-perl 1.107-3 1.108-1
calendarsupport 21.04.1-1 21.04.2-1
cantor 21.04.1-1 21.04.2-1
cervisia 21.04.1-1 21.04.2-1
chromium 91.0.4472.77-1 91.0.4472.101-1
clang 11.1.0-1 12.0.0-1
clazy 1.9-2 1.9-3
compiler-rt 11.1.0-1 12.0.0-1
composer 2.1.1-1 2.1.3-1
discover 5.21.5-1 5.22.0-1
dolphin 21.04.1-1 21.04.2-1
dolphin-plugins 21.04.1-1 21.04.2-1
dragon 21.04.1-1 21.04.2-1
drkonqi 5.21.5-1 5.22.0-1
elisa 21.04.1-1 21.04.2-1
enchant 2.2.15-2 2.2.15-3
eventviews 21.04.1-1 21.04.2-1
evince 40.1-2 40.2-1
ffmpeg 2:4.4-3 2:4.4-4
ffmpegthumbs 21.04.1-1 21.04.2-1
filelight 21.04.1-1 21.04.2-1
git 2.31.1-1 2.32.0-1
gnome-desktop 1:40.1-2 1:40.2-1
gnome-music 1:40.0-1 1:40.1.1-1
gnome-shell 1:40.1-2 1:40.2-1
gnome-shell-extensions 40.1-1 40.2-1
gnumeric 1.12.49-2 1.12.50-1
gnuplot 5.4.1-1 5.4.2-1
goffice 0.10.49-1 0.10.50-1
gptfdisk 1.0.7-1 1.0.8-1
granatier 21.04.1-1 21.04.2-1
grantlee-editor 21.04.1-1 21.04.2-1
grantleetheme 21.04.1-1 21.04.2-1
gst-plugin-pipewire 1:0.3.29-1 1:0.3.30-2
gwenview 21.04.1-1 21.04.2-1
imath 3.0.4-1 3.0.4-2
incidenceeditor 21.04.1-1 21.04.2-1
inkscape 1.1-3 1.1-4
ispell 3.4.02-1 3.4.04-1
itinerary 21.04.1-1 21.04.2-1
jasper 2.0.28-1 2.0.29-1
jasper-doc 2.0.28-1 2.0.29-1
jdk-openjdk 15.0.2.u7-1 15.0.3.u3-1
jre-openjdk 15.0.2.u7-1 15.0.3.u3-1
jre-openjdk-headless 15.0.2.u7-1 15.0.3.u3-1
juk 21.04.1-1 21.04.2-1
junit 4.13.1-1 4.13.2-1
k3b 1:21.04.1-1 1:21.04.2-1
kaccounts-integration 21.04.1-1 21.04.2-1
kaccounts-providers 21.04.1-1 21.04.2-1
kactivitymanagerd 5.21.5-1 5.22.0-1
kaddressbook 21.04.1-1 21.04.2-1
kajongg 21.04.1-1 21.04.2-1
kalarm 21.04.1-1 21.04.2-1
kalarmcal 21.04.1-1 21.04.2-1
kalgebra 21.04.1-1 21.04.2-1
kalzium 21.04.1-1 21.04.2-1
kamera 21.04.1-1 21.04.2-1
kamoso 21.04.1-1 21.04.2-1
kanagram 21.04.1-1 21.04.2-1
kapman 21.04.1-1 21.04.2-1
kapptemplate 21.04.1-1 21.04.2-1
kate 21.04.1-1 21.04.2-1
katomic 21.04.1-1 21.04.2-1
kbackup 21.04.1-1 21.04.2-1
kblackbox 21.04.1-1 21.04.2-1
kblocks 21.04.1-1 21.04.2-1
kbounce 21.04.1-1 21.04.2-1
kbreakout 21.04.1-1 21.04.2-1
kbruch 21.04.1-1 21.04.2-1
kcachegrind 21.04.1-1 21.04.2-1
kcachegrind-common 21.04.1-1 21.04.2-1
kcalc 21.04.1-1 21.04.2-1
kcalutils 21.04.1-1 21.04.2-1
kcharselect 21.04.1-1 21.04.2-1
kcolorchooser 21.04.1-1 21.04.2-1
kcron 21.04.1-1 21.04.2-1
kde-cli-tools 5.21.5-1 5.22.0-1
kde-dev-scripts 21.04.1-1 21.04.2-1
kde-dev-utils 21.04.1-1 21.04.2-1
kde-gtk-config 5.21.5-1 5.22.0-1
kdebugsettings 21.04.1-1 21.04.2-1
kdeconnect 21.04.1-2 21.04.2-1
kdecoration 5.21.5-1 5.22.0-1
kdeedu-data 21.04.1-1 21.04.2-1
kdegraphics-mobipocket 21.04.1-1 21.04.2-1
kdegraphics-thumbnailers 21.04.1-1 21.04.2-1
kdenetwork-filesharing 21.04.1-1 21.04.2-1
kdenlive 21.04.1-1 21.04.2-1
kdepim-addons 21.04.1-1 21.04.2-1
kdepim-runtime 21.04.1-1 21.04.2-1
kdeplasma-addons 5.21.5-1 5.22.0-1
kdesdk-kioslaves 21.04.1-1 21.04.2-1
kdesdk-thumbnailers 21.04.1-1 21.04.2-1
kdevelop 5.6.2-3 5.6.2-4
kdf 21.04.1-1 21.04.2-1
kdialog 21.04.1-1 21.04.2-1
kdiamond 21.04.1-1 21.04.2-1
keditbookmarks 21.04.1-1 21.04.2-1
kfind 21.04.1-1 21.04.2-1
kfloppy 21.04.1-1 21.04.2-1
kfourinline 21.04.1-1 21.04.2-1
kgamma5 5.21.5-1 5.22.0-1
kgeography 21.04.1-1 21.04.2-1
kget 21.04.1-1 21.04.2-1
kgoldrunner 21.04.1-1 21.04.2-1
kgpg 21.04.1-1 21.04.2-1
khangman 21.04.1-1 21.04.2-1
khelpcenter 21.04.1-1 21.04.2-1
khotkeys 5.21.5-1 5.22.0-1
kidentitymanagement 21.04.1-1 21.04.2-1
kig 21.04.1-1 21.04.2-1
kigo 21.04.1-1 21.04.2-1
killbots 21.04.1-1 21.04.2-1
kimagemapeditor 21.04.1-1 21.04.2-1
kimap 21.04.1-1 21.04.2-1
kinfocenter 5.21.5-1 5.22.0-1
kio-extras 21.04.1-2 21.04.2-1
kio-gdrive 21.04.1-1 21.04.2-1
kipi-plugins 21.04.1-1 21.04.2-1
kirigami-gallery 21.04.1-1 21.04.2-1
kiriki 21.04.1-1 21.04.2-1
kiten 21.04.1-1 21.04.2-1
kitinerary 21.04.1-2 21.04.2-1
kjumpingcube 21.04.1-1 21.04.2-1
kldap 21.04.1-1 21.04.2-1
kleopatra 21.04.1-1 21.04.2-1
klettres 21.04.1-1 21.04.2-1
klickety 21.04.1-1 21.04.2-1
klines 21.04.1-1 21.04.2-1
kmag 21.04.1-1 21.04.2-1
kmahjongg 21.04.1-1 21.04.2-1
kmail 21.04.1-1 21.04.2-1
kmail-account-wizard 21.04.1-1 21.04.2-1
kmailtransport 21.04.1-1 21.04.2-1
kmbox 21.04.1-1 21.04.2-1
kmenuedit 5.21.5-1 5.22.0-1
kmime 21.04.1-1 21.04.2-1
kmines 21.04.1-1 21.04.2-1
kmix 21.04.1-1 21.04.2-1
kmousetool 21.04.1-1 21.04.2-1
kmouth 21.04.1-1 21.04.2-1
kmplot 21.04.1-1 21.04.2-1
knavalbattle 21.04.1-1 21.04.2-1
knetwalk 21.04.1-1 21.04.2-1
knights 21.04.1-1 21.04.2-1
knotes 21.04.1-1 21.04.2-1
kolf 21.04.1-1 21.04.2-1
kollision 21.04.1-1 21.04.2-1
kolourpaint 21.04.1-1 21.04.2-1
kompare 21.04.1-1 21.04.2-1
konqueror 21.04.1-1 21.04.2-1
konquest 21.04.1-1 21.04.2-1
konsole 21.04.1-1 21.04.2-1
kontact 21.04.1-1 21.04.2-1
kontactinterface 21.04.1-1 21.04.2-1
kontrast 21.04.1-1 21.04.2-1
konversation 21.04.1-1 21.04.2-1
kopeninghours 21.04.1-1 21.04.2-1
kopete 21.04.1-1 21.04.2-1
korganizer 21.04.1-1 21.04.2-1
kosmindoormap 21.04.1-1 21.04.2-1
kpat 21.04.1-1 21.04.2-1
kpimtextedit 21.04.1-1 21.04.2-1
kpkpass 21.04.1-1 21.04.2-1
kpmcore 21.04.1-1 21.04.2-1
kpublictransport 21.04.1-1 21.04.2-1
kqtquickcharts 21.04.1-1 21.04.2-1
krdc 21.04.1-1 21.04.2-1
kreversi 21.04.1-1 21.04.2-1
krfb 21.04.1-1 21.04.2-1
krita 4.4.3-4 4.4.5-1
kross-interpreters 21.04.1-1 21.04.2-1
kruler 21.04.1-1 21.04.2-1
kscreen 5.21.5-1 5.22.0-1
kscreenlocker 5.21.5-1 5.22.0-1
kseexpr 4.0.1.0-1 4.0.2.0-1
kshisen 21.04.1-1 21.04.2-1
ksirk 21.04.1-1 21.04.2-1
ksmtp 21.04.1-1 21.04.2-1
ksnakeduel 21.04.1-1 21.04.2-1
kspaceduel 21.04.1-1 21.04.2-1
ksquares 21.04.1-1 21.04.2-1
ksshaskpass 5.21.5-1 5.22.0-1
ksudoku 21.04.1-1 21.04.2-1
ksysguard 5.21.5-1 5.22.0-1
ksystemlog 21.04.1-1 21.04.2-1
kteatime 21.04.1-1 21.04.2-1
ktimer 21.04.1-1 21.04.2-1
ktnef 21.04.1-1 21.04.2-1
ktorrent 21.04.1-1 21.04.2-1
ktouch 21.04.1-1 21.04.2-1
ktuberling 21.04.1-1 21.04.2-1
kturtle 21.04.1-1 21.04.2-1
kubrick 21.04.1-1 21.04.2-1
kwallet-pam 5.21.5-1 5.22.0-1
kwalletmanager 21.04.1-1 21.04.2-1
kwave 21.04.1-1 21.04.2-1
kwayland-integration 5.21.5-1 5.22.0-1
kwayland-server 5.21.5-1 5.22.0-1
kwin 5.21.5-1 5.22.0-1
kwordquiz 21.04.1-1 21.04.2-1
kwrite 21.04.1-1 21.04.2-1
kwrited 5.21.5-1 5.22.0-1
libaccounts-glib 1.25-3 1.25-4
libaccounts-qt 1.16-2 1.16-3
libakonadi 21.04.1-1 21.04.2-1
libappimage 1.0.3-3 1.0.3-4
libbpf 0.3-1 0.4.0-1
libcerf 1:1.14-1 1:1.15-1
libclc 11.1.0-1 12.0.0-1
libcmis 0.5.2-7 0.5.2-8
libgravatar 21.04.1-1 21.04.2-1
libgusb 0.3.6-1 0.3.7-1
libixion 0.16.1-5 0.16.1-6
libkcddb 21.04.1-1 21.04.2-1
libkcompactdisc 21.04.1-1 21.04.2-1
libkdcraw 21.04.1-1 21.04.2-1
libkdegames 21.04.1-1 21.04.2-1
libkdepim 21.04.1-1 21.04.2-1
libkeduvocdocument 21.04.1-1 21.04.2-1
libkexiv2 21.04.1-1 21.04.2-1
libkgapi 21.04.1-1 21.04.2-1
libkipi 21.04.1-1 21.04.2-1
libkleo 21.04.1-1 21.04.2-1
libkmahjongg 21.04.1-1 21.04.2-1
libkolabxml 1.1.6-15 1.1.6-16
libkomparediff2 21.04.1-1 21.04.2-1
libksane 21.04.1-1 21.04.2-1
libkscreen 5.21.5-1 5.22.0-1
libksieve 21.04.1-1 21.04.2-1
libksysguard 5.21.5-1 5.22.0-2
libktorrent 21.04.1-1 21.04.2-1
liblouis 3.17.0-1 3.18.0-1
libmm-glib 1.16.4-1 1.16.6-1
liborcus 0.16.1-6 0.16.1-7
libphonenumber 8.12.23-1 8.12.24-1
libpst 0.6.76-1 0.6.76-2
libpst-docs 0.6.76-1 0.6.76-2
libreoffice-fresh 7.1.3-2 7.1.4-1
libreoffice-fresh-af 7.1.3-1 7.1.4-1
libreoffice-fresh-am 7.1.3-1 7.1.4-1
libreoffice-fresh-ar 7.1.3-1 7.1.4-1
libreoffice-fresh-as 7.1.3-1 7.1.4-1
libreoffice-fresh-ast 7.1.3-1 7.1.4-1
libreoffice-fresh-be 7.1.3-1 7.1.4-1
libreoffice-fresh-bg 7.1.3-1 7.1.4-1
libreoffice-fresh-bn 7.1.3-1 7.1.4-1
libreoffice-fresh-bn-in 7.1.3-1 7.1.4-1
libreoffice-fresh-bo 7.1.3-1 7.1.4-1
libreoffice-fresh-br 7.1.3-1 7.1.4-1
libreoffice-fresh-brx 7.1.3-1 7.1.4-1
libreoffice-fresh-bs 7.1.3-1 7.1.4-1
libreoffice-fresh-ca 7.1.3-1 7.1.4-1
libreoffice-fresh-ca-valencia 7.1.3-1 7.1.4-1
libreoffice-fresh-ckb 7.1.3-1 7.1.4-1
libreoffice-fresh-cs 7.1.3-1 7.1.4-1
libreoffice-fresh-cy 7.1.3-1 7.1.4-1
libreoffice-fresh-da 7.1.3-1 7.1.4-1
libreoffice-fresh-de 7.1.3-1 7.1.4-1
libreoffice-fresh-dgo 7.1.3-1 7.1.4-1
libreoffice-fresh-dsb 7.1.3-1 7.1.4-1
libreoffice-fresh-dz 7.1.3-1 7.1.4-1
libreoffice-fresh-el 7.1.3-1 7.1.4-1
libreoffice-fresh-en-gb 7.1.3-1 7.1.4-1
libreoffice-fresh-en-za 7.1.3-1 7.1.4-1
libreoffice-fresh-eo 7.1.3-1 7.1.4-1
libreoffice-fresh-es 7.1.3-1 7.1.4-1
libreoffice-fresh-et 7.1.3-1 7.1.4-1
libreoffice-fresh-eu 7.1.3-1 7.1.4-1
libreoffice-fresh-fa 7.1.3-1 7.1.4-1
libreoffice-fresh-fi 7.1.3-1 7.1.4-1
libreoffice-fresh-fr 7.1.3-1 7.1.4-1
libreoffice-fresh-fur 7.1.3-1 7.1.4-1
libreoffice-fresh-fy 7.1.3-1 7.1.4-1
libreoffice-fresh-ga 7.1.3-1 7.1.4-1
libreoffice-fresh-gd 7.1.3-1 7.1.4-1
libreoffice-fresh-gl 7.1.3-1 7.1.4-1
libreoffice-fresh-gu 7.1.3-1 7.1.4-1
libreoffice-fresh-gug 7.1.3-1 7.1.4-1
libreoffice-fresh-he 7.1.3-1 7.1.4-1
libreoffice-fresh-hi 7.1.3-1 7.1.4-1
libreoffice-fresh-hr 7.1.3-1 7.1.4-1
libreoffice-fresh-hsb 7.1.3-1 7.1.4-1
libreoffice-fresh-hu 7.1.3-1 7.1.4-1
libreoffice-fresh-id 7.1.3-1 7.1.4-1
libreoffice-fresh-is 7.1.3-1 7.1.4-1
libreoffice-fresh-it 7.1.3-1 7.1.4-1
libreoffice-fresh-ja 7.1.3-1 7.1.4-1
libreoffice-fresh-ka 7.1.3-1 7.1.4-1
libreoffice-fresh-kab 7.1.3-1 7.1.4-1
libreoffice-fresh-kk 7.1.3-1 7.1.4-1
libreoffice-fresh-km 7.1.3-1 7.1.4-1
libreoffice-fresh-kmr-latn 7.1.3-1 7.1.4-1
libreoffice-fresh-kn 7.1.3-1 7.1.4-1
libreoffice-fresh-ko 7.1.3-1 7.1.4-1
libreoffice-fresh-kok 7.1.3-1 7.1.4-1
libreoffice-fresh-ks 7.1.3-1 7.1.4-1
libreoffice-fresh-lb 7.1.3-1 7.1.4-1
libreoffice-fresh-lo 7.1.3-1 7.1.4-1
libreoffice-fresh-lt 7.1.3-1 7.1.4-1
libreoffice-fresh-lv 7.1.3-1 7.1.4-1
libreoffice-fresh-mai 7.1.3-1 7.1.4-1
libreoffice-fresh-mk 7.1.3-1 7.1.4-1
libreoffice-fresh-ml 7.1.3-1 7.1.4-1
libreoffice-fresh-mn 7.1.3-1 7.1.4-1
libreoffice-fresh-mni 7.1.3-1 7.1.4-1
libreoffice-fresh-mr 7.1.3-1 7.1.4-1
libreoffice-fresh-my 7.1.3-1 7.1.4-1
libreoffice-fresh-nb 7.1.3-1 7.1.4-1
libreoffice-fresh-ne 7.1.3-1 7.1.4-1
libreoffice-fresh-nl 7.1.3-1 7.1.4-1
libreoffice-fresh-nn 7.1.3-1 7.1.4-1
libreoffice-fresh-nr 7.1.3-1 7.1.4-1
libreoffice-fresh-nso 7.1.3-1 7.1.4-1
libreoffice-fresh-oc 7.1.3-1 7.1.4-1
libreoffice-fresh-om 7.1.3-1 7.1.4-1
libreoffice-fresh-or 7.1.3-1 7.1.4-1
libreoffice-fresh-pa-in 7.1.3-1 7.1.4-1
libreoffice-fresh-pl 7.1.3-1 7.1.4-1
libreoffice-fresh-pt 7.1.3-1 7.1.4-1
libreoffice-fresh-pt-br 7.1.3-1 7.1.4-1
libreoffice-fresh-ro 7.1.3-1 7.1.4-1
libreoffice-fresh-ru 7.1.3-1 7.1.4-1
libreoffice-fresh-rw 7.1.3-1 7.1.4-1
libreoffice-fresh-sa-in 7.1.3-1 7.1.4-1
libreoffice-fresh-sat 7.1.3-1 7.1.4-1
libreoffice-fresh-sd 7.1.3-1 7.1.4-1
libreoffice-fresh-sdk 7.1.3-2 7.1.4-1
libreoffice-fresh-si 7.1.3-1 7.1.4-1
libreoffice-fresh-sid 7.1.3-1 7.1.4-1
libreoffice-fresh-sk 7.1.3-1 7.1.4-1
libreoffice-fresh-sl 7.1.3-1 7.1.4-1
libreoffice-fresh-sq 7.1.3-1 7.1.4-1
libreoffice-fresh-sr 7.1.3-1 7.1.4-1
libreoffice-fresh-sr-latn 7.1.3-1 7.1.4-1
libreoffice-fresh-ss 7.1.3-1 7.1.4-1
libreoffice-fresh-st 7.1.3-1 7.1.4-1
libreoffice-fresh-sv 7.1.3-1 7.1.4-1
libreoffice-fresh-sw-tz 7.1.3-1 7.1.4-1
libreoffice-fresh-szl 7.1.3-1 7.1.4-1
libreoffice-fresh-ta 7.1.3-1 7.1.4-1
libreoffice-fresh-te 7.1.3-1 7.1.4-1
libreoffice-fresh-tg 7.1.3-1 7.1.4-1
libreoffice-fresh-th 7.1.3-1 7.1.4-1
libreoffice-fresh-tn 7.1.3-1 7.1.4-1
libreoffice-fresh-tr 7.1.3-1 7.1.4-1
libreoffice-fresh-ts 7.1.3-1 7.1.4-1
libreoffice-fresh-tt 7.1.3-1 7.1.4-1
libreoffice-fresh-ug 7.1.3-1 7.1.4-1
libreoffice-fresh-uk 7.1.3-1 7.1.4-1
libreoffice-fresh-uz 7.1.3-1 7.1.4-1
libreoffice-fresh-ve 7.1.3-1 7.1.4-1
libreoffice-fresh-vec 7.1.3-1 7.1.4-1
libreoffice-fresh-vi 7.1.3-1 7.1.4-1
libreoffice-fresh-xh 7.1.3-1 7.1.4-1
libreoffice-fresh-zh-cn 7.1.3-1 7.1.4-1
libreoffice-fresh-zh-tw 7.1.3-1 7.1.4-1
libreoffice-fresh-zu 7.1.3-1 7.1.4-1
libreoffice-still 7.0.6-2 7.0.6-3
libreoffice-still-sdk 7.0.6-2 7.0.6-3
libtorrent-rasterbar 1:1.2.11-1 1:1.2.14-1
libva-mesa-driver 21.1.1-1 21.1.2-1
libx11 1.7.1-1 1.7.2-1
lld 11.1.0-1 12.0.0-1
lldb 11.1.0-1 12.0.0-1
llvm 11.1.0-1 12.0.0-1
llvm-libs 11.1.0-1 12.0.0-1
llvm-ocaml 11.1.0-1 12.0.0-1
lokalize 21.04.1-1 21.04.2-1
lskat 21.04.1-1 21.04.2-1
lyx 2.3.6.1-1 2.3.6.1-2
m17n-lib 1.8.0-9 1.8.0-10
maeparser 1.2.4-3 1.2.4-4
mailcommon 21.04.1-1 21.04.2-1
mailimporter 21.04.1-1 21.04.2-1
marble 21.04.1-2 21.04.2-1
marble-common 21.04.1-2 21.04.2-1
marble-maps 21.04.1-2 21.04.2-1
marble-qt 21.04.1-2 21.04.2-1
markdownpart 21.04.1-1 21.04.2-1
mbox-importer 21.04.1-1 21.04.2-1
mesa 21.1.1-1 21.1.2-1
mesa-vdpau 21.1.1-1 21.1.2-1
meson 0.58.0-2 0.58.1-1
messagelib 21.04.1-1 21.04.2-1
milou 5.21.5-1 5.22.0-1
minuet 21.04.1-1 21.04.2-1
mkvtoolnix-cli 56.1.0-1 57.0.0-1
mkvtoolnix-gui 56.1.0-1 57.0.0-1
modemmanager 1.16.4-1 1.16.6-1
mpg123 1.27.2-1 1.28.0-1
mutt 2.0.7-1 2.1-1
mutter 40.1-2 40.2-2
netpbm 10.73.33-1 10.73.34-1
nginx 1.20.0-1 1.20.1-1
nginx-src 1.20.0-1 1.20.1-1
nuget 5.8.0-1 5.8.1-1
ocaml-topkg 1.0.2-2 1.0.3-1
okular 21.04.1-1 21.04.2-1
opencl-mesa 21.1.1-1 21.1.2-1
openjdk-src 15.0.2.u7-1 15.0.3.u3-1
openmp 11.1.0-1 12.0.0-1
openmpi 4.0.5-3 4.1.1-2
oxygen 5.21.5-1 5.22.0-1
palapeli 21.04.1-1 21.04.2-1
parley 21.04.1-1 21.04.2-1
partitionmanager 21.04.1-1 21.04.2-1
perl-mime-lite 3.031-4 3.033-1
picmi 21.04.1-1 21.04.2-1
pim-data-exporter 21.04.1-1 21.04.2-1
pim-sieve-editor 21.04.1-1 21.04.2-1
pimcommon 21.04.1-1 21.04.2-1
pipewire-alsa 1:0.3.29-1 1:0.3.30-2
pipewire-docs 1:0.3.29-1 1:0.3.30-2
pipewire-jack 1:0.3.29-1 1:0.3.30-2
pipewire-media-session 1:0.3.29-1 1:0.3.30-2
pipewire-pulse 1:0.3.29-1 1:0.3.30-2
pipewire-zeroconf 1:0.3.29-1 1:0.3.30-2
plasma-browser-integration 5.21.5-1 5.22.0-1
plasma-desktop 5.21.5-1 5.22.0-1
plasma-disks 5.21.5-1 5.22.0-1
plasma-firewall 5.21.5-1 5.22.0-1
plasma-integration 5.21.5-1 5.22.0-1
plasma-meta 5.21-2 5.22-1
plasma-nm 5.21.5-1 5.22.0-1
plasma-pa 5.21.5-1 5.22.0-1
plasma-sdk 5.21.5-1 5.22.0-1
plasma-systemmonitor 5.21.5-1 5.22.0-1
plasma-thunderbolt 5.21.5-1 5.22.0-1
plasma-vault 5.21.5-1 5.22.0-1
plasma-wayland-session 5.21.5-1 5.22.0-2
plasma-workspace 5.21.5-1 5.22.0-2
plasma-workspace-wallpapers 5.21.5-1 5.22.0-1
polkit-kde-agent 5.21.5-1 5.22.0-1
polly 11.1.0-1 12.0.0-1
postgresql 13.3-2 13.3-3
postgresql-docs 13.3-2 13.3-3
postgresql-libs 13.3-2 13.3-3
postgresql-old-upgrade 12.7-2 12.7-3
powerdevil 5.21.5-1 5.22.0-1
poxml 21.04.1-1 21.04.2-1
print-manager 21.04.1-1 21.04.2-1
pyside6 6.1.0-1 6.1.1-1
python-astroid 2.5.7-1 2.5.8-1
python-pip 20.3.1-1 20.3.1-2
python-resolvelib 0.5.4-1 0.5.5-1
python-shiboken2 5.15.2-6 5.15.2-8
python2-pip 20.3.1-1 20.3.1-2
python2-resolvelib 0.5.4-1 0.5.5-1
qcachegrind 21.04.1-1 21.04.2-1
qt5-quick3d 5.15.2+kde+r18-1 5.15.2+kde+r19-1
qt5-script 5.15.2-1 5.15.4-1
qt5-tools 5.15.2+kde+r17-1 5.15.2+kde+r17-2
qt6-3d 6.1.0-1 6.1.1-1
qt6-5compat 6.1.0-1 6.1.1-1
qt6-base 6.1.0-1 6.1.1-1
qt6-charts 6.1.0-1 6.1.1-1
qt6-datavis3d 6.1.0-1 6.1.1-1
qt6-declarative 6.1.0-1 6.1.1-1
qt6-doc 6.1.0-1 6.1.1-1
qt6-examples 6.1.0-1 6.1.1-1
qt6-imageformats 6.1.0-1 6.1.1-1
qt6-lottie 6.1.0-1 6.1.1-1
qt6-networkauth 6.1.0-1 6.1.1-1
qt6-quick3d 6.1.0-1 6.1.1-1
qt6-quickcontrols2 6.1.0-1 6.1.1-1
qt6-quicktimeline 6.1.0-1 6.1.1-1
qt6-scxml 6.1.0-1 6.1.1-1
qt6-shadertools 6.1.0-1 6.1.1-1
qt6-svg 6.1.0-1 6.1.1-1
qt6-tools 6.1.0-1 6.1.1-1
qt6-translations 6.1.0-1 6.1.1-1
qt6-virtualkeyboard 6.1.0-1 6.1.1-1
qt6-wayland 6.1.0-1 6.1.1-1
qtcreator 4.15.0-1 4.15.1-1
quadrapassel 40.1-1 40.2-1
rebuilderd-website 0.5.2-1 0.5.3-1
ristretto 0.10.0-3 0.11.0-1
rocs 21.04.1-1 21.04.2-1
rubygems 3.2.18-1 3.2.19-1
rust 1:1.52.1-1 1:1.52.1-3
rust-docs 1:1.52.1-1 1:1.52.1-3
samba 4.14.4-1 4.14.5-1
sddm-kcm 5.21.5-1 5.22.0-1
shiboken6 6.1.0-1 6.1.1-1
signon-kwallet-extension 21.04.1-1 21.04.2-1
smbclient 4.14.4-1 4.14.5-1
source-highlight 3.1.9-4 3.1.9-5
spectacle 21.04.1-1 21.04.2-1
step 21.04.1-1 21.04.2-1
svgpart 21.04.1-1 21.04.2-1
sweeper 21.04.1-1 21.04.2-1
systemsettings 5.21.5-1 5.22.0-1
tcpdump 4.99.0-1 4.99.1-1
telepathy-kde-accounts-kcm 21.04.1-1 21.04.2-1
telepathy-kde-approver 21.04.1-1 21.04.2-1
telepathy-kde-auth-handler 21.04.1-1 21.04.2-1
telepathy-kde-call-ui 21.04.1-1 21.04.2-1
telepathy-kde-common-internals 21.04.1-1 21.04.2-1
telepathy-kde-contact-list 21.04.1-1 21.04.2-1
telepathy-kde-contact-runner 21.04.1-1 21.04.2-1
telepathy-kde-desktop-applets 21.04.1-1 21.04.2-1
telepathy-kde-filetransfer-handler 21.04.1-1 21.04.2-1
telepathy-kde-integration-module 21.04.1-1 21.04.2-1
telepathy-kde-send-file 21.04.1-1 21.04.2-1
telepathy-kde-text-ui 21.04.1-1 21.04.2-1
tomcat-native 1.2.28-1 1.2.30-1
tomcat10 10.0.5-1 10.0.7-1
tomcat8 8.5.66-1 8.5.68-1
tomcat9 9.0.46-1 9.0.48-1
tracker3 3.1.1-2 3.1.2-1
tracker3-miners 3.1.1-2 3.1.2-1
umbrello 21.04.1-1 21.04.2-1
visualvm 1.4.4-1 2.0.7-1
vlc 3.0.14-1 3.0.15-2
vulkan-broadcom 21.1.1-1 21.1.2-1
vulkan-headers 1:1.2.178-1 1:1.2.179-1
vulkan-icd-loader 1.2.176-1 1.2.177-1
vulkan-mesa-layers 21.1.1-1 21.1.2-1
vulkan-radeon 21.1.1-1 21.1.2-1
vulkan-swrast 21.1.1-1 21.1.2-1
whois 5.5.9-1 5.5.10-1
xdg-desktop-portal-kde 5.21.5-1 5.22.0-1
xfce4-settings 4.16.1-3 4.16.2-1
xkeyboard-config 2.32-1 2.33-1
xterm 367-1 368-1
yakuake 21.04.1-1 21.04.2-1
yelp 40.0-1 40.2-1
yelp-xsl 40.0-1 40.2-1
zabbix-agent 5.4.0-1 5.4.1-1
zabbix-agent2 5.4.0-1 5.4.1-1
zabbix-frontend-php 5.4.0-1 5.4.1-1
zabbix-proxy 5.4.0-1 5.4.1-1
zabbix-server 5.4.0-1 5.4.1-1
zeroconf-ioslave 21.04.1-1 21.04.2-1
ksystemstats - 5.22.0-1
layer-shell-qt - 5.22.0-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.04.1.r12505.g8beee8e18-121.04.2.r12508.g0aa26872d-1
akonadi-calendar21.04.1.r1940.gfe381df-121.04.2.r1942.g744e395-1
akonadi-calendar-tools21.04.1.r866.g35d0f5c-121.04.2.r866.g35d0f5c-1
akonadi-contacts21.04.1.r3010.g17212707-121.04.2.r3012.g2ad01454-1
akonadi-import-wizard21.04.1.r1708.g3d9a682-121.04.2.r1710.g435d82f-1
akonadi-mime21.04.1.r1619.g3a75f11-121.04.2.r1622.g66d238f-1
akonadi-notes21.04.1.r1004.g1bb8a32-121.04.2.r1006.g44ff2e9-1
akonadi-search21.04.1.r1093.gfd42115-121.04.2.r1095.g1bd0e5e-1
akonadiconsole21.04.1.r1489.g9675755-121.04.2.r1489.g9675755-1
akregator21.04.1.r6131.g3f060ceb-121.04.2.r6133.gb14a7c7b-1
alligator 21.05.r10.gdcb3c1f-1 21.06.r1.g840fa21-1
amazfish 2.0.0.r13.gc63f451-1 2.0.0.r14.g3842e88-1
angelfish 21.05.r30.gb1b0f61-1 21.06.r7.gc634ab8-1
ark21.04.1.r4542.g28f6736c-121.04.2.r4544.g754f6818-1
artikulate21.04.1.r1384.g9c5d1cd-121.04.2.r1384.g9c5d1cd-1
attica5.82.0.r809.g6b84634-15.82.0.r813.g586562c-1
audiocd-kio21.04.1.r1018.ge260225-121.04.2.r1018.ge260225-1
baloo5.82.0.r2988.gfbbd2025-15.82.0.r2989.g0d7f0461-1
blinken21.04.1.r623.g07b1991-121.04.2.r623.g07b1991-1
bluedevil1:5.21.5.r2265.g2b0bbc6a-11:5.22.0.r2268.g87b46065-1
bluez-qt5.82.0.r660.g2853539-15.82.0.r661.g064d64b-1
bomber21.04.1.r516.g07153d2-121.04.2.r516.g07153d2-1
bovo21.04.1.r726.geada516-121.04.2.r727.g7c7afb7-1
breeze5.21.5.r2195.ge40760a9-15.22.0.r2214.g2be7d7be-1
breeze-grub 5.21.5.r8.g2c1d5e7-15.22.0.r11.g63136a9-1
breeze-icons5.82.0.r1746.gd430e041-15.82.0.r1749.ge11c195e-1
buho 1.2.2.r19.g2509c30-1 1.2.2.r20.g14a1556-1
calendarsupport21.04.1.r532.gc6209c3-121.04.2.r538.ge7d2b6e-1
calindori 21.05.r13.g4060b2d-1 21.06.r2.g1d32933-1
cervisia21.04.1.r1637.g3e29b0d-121.04.2.r1637.g3e29b0d-1
discover5.21.5.r8198.g38118d17-15.22.0.r8201.g4e1617ae-1
disman5.21.5.r1805.g8474b17-15.22.0.r1808.g431141e-1
dolphin21.04.1.r6603.g14687479d-121.04.2.r6607.g699ddc354-1
dolphin-plugins21.04.1.r563.g0833cfa-121.04.2.r564.gd9cea44-1
dragon21.04.1.r1000.g4b895d5-121.04.2.r1000.g4b895d5-1
drkonqi5.21.5.r646.g296cdd77-15.22.0.r648.gb3d75b38-1
elisa21.04.1.r2714.gad0b1c9c-121.04.2.r2716.g2a64ff02-1
eventviews21.04.1.r652.g10884a8-121.04.2.r655.g5c8bca0-1
extra-cmake-modules5.82.0.r3316.gde019f4-15.82.0.r3321.gb60dee1-1
ffmpegthumbs21.04.1.r171.g648104f-121.04.2.r171.g648104f-1
filelight21.04.1.r968.gdbae689-121.04.2.r968.gdbae689-1
frameworkintegration5.82.0.r585.g6b0732e-15.82.0.r586.ga8986c7-1
granatier21.04.1.r916.g5ba8c3b-121.04.2.r916.g5ba8c3b-1
grantlee-editor21.04.1.r744.gfefec5f-121.04.2.r744.gfefec5f-1
grantleetheme21.04.1.r323.g6696d42-121.04.2.r325.gd54967c-1
gwenview21.04.1.r6607.g034d673f-121.04.2.r6613.g5e20e12b-1
incidenceeditor21.04.1.r725.g31a5b98-121.04.2.r727.g2f550a0-1
index-fm 1.2.2.r42.g39f2c1c-1 1.2.2.r49.gb4ed2b5-1
itinerary21.04.1.r1298.gb197060-121.04.2.r1315.g8b35b40-1
juk21.04.1.r3105.g3b94a681-121.04.2.r3105.g3b94a681-1
k3b1:21.04.1.r6622.ge7c3e6de0-11:21.04.2.r6622.ge7c3e6de0-1
kactivities5.82.0.r1348.g5fc95fd-15.82.0.r1349.g92832d8-1
kactivities-stats5.82.0.r355.g8db79e5-15.82.0.r356.g6c0afc7-1
kactivitymanagerd5.21.5.r1355.g9cabb88-15.22.0.r1355.g9cabb88-1
kaddressbook21.04.1.r5969.g77047101-121.04.2.r5973.g7dbbf4c9-1
kajongg21.04.1.r4186.gfe75232f-121.04.2.r4186.gfe75232f-1
kalarm21.04.1.r6381.ge0c14cfe-121.04.2.r6382.g952dd6dd-1
kalarmcal21.04.1.r1112.ga14eacc-121.04.2.r1115.ga8e996f-1
kalgebra21.04.1.r2030.ga66d4d2-121.04.2.r2031.g0d339a4-1
kalk 21.05.r21.g177fd79-1 21.06.r2.g3865adc-1
kalzium21.04.1.r4251.gb7804b8b-121.04.2.r4251.gb7804b8b-1
kamera21.04.1.r653.gd09472c-121.04.2.r653.gd09472c-1
kamoso21.04.1.r1425.g9a3017c-121.04.2.r1425.g9a3017c-1
kanagram21.04.1.r1277.g1c064a6-121.04.2.r1277.g1c064a6-1
kapidox5.82.0.r525.gdae2fd7-15.82.0.r526.g1544e54-1
kapman21.04.1.r596.gb20985d-121.04.2.r596.gb20985d-1
kapptemplate21.04.1.r951.g57b0257-121.04.2.r951.g57b0257-1
karchive5.82.0.r485.g6ab54ac-15.82.0.r486.gd9f727b-1
kate21.04.1.r18192.ga5d2b7a4f-121.04.2.r18205.g3a5cd5698-1
katomic21.04.1.r911.g27db726-121.04.2.r911.g27db726-1
kauth5.82.0.r435.g433b15c-15.82.0.r436.g6b59cbf-1
kbackup21.04.1.r372.g12a1af6-121.04.2.r374.g2334cf5-1
kblackbox21.04.1.r717.g34d60ce-121.04.2.r717.g34d60ce-1
kblocks21.04.1.r635.gf020ddf-121.04.2.r635.gf020ddf-1
kbookmarks5.82.0.r407.g691b294-15.82.0.r408.g35319dc-1
kbounce21.04.1.r794.g88211ac-121.04.2.r794.g88211ac-1
kbreakout21.04.1.r849.g9e11d24-121.04.2.r849.g9e11d24-1
kbruch21.04.1.r813.gce09ef3-121.04.2.r813.gce09ef3-1
kcachegrind21.04.1.r1147.g093b45f-121.04.2.r1147.g093b45f-1
kcachegrind-common21.04.1.r1147.g093b45f-121.04.2.r1147.g093b45f-1
kcalc21.04.1.r1496.gb0d8681-121.04.2.r1496.gb0d8681-1
kcalendarcore5.82.0.r1208.gd8f6ca7aa-15.82.0.r1212.g8e326063c-1
kcalutils21.04.1.r835.g78554af2b-121.04.2.r848.g3f45545b3-1
kcharselect21.04.1.r463.gde270f8-121.04.2.r463.gde270f8-1
kclock 21.05.r31.g2a98d58-1 21.06.r5.ga7df6f5-1
kcmutils5.82.0.r511.g83ac10d-15.82.0.r514.gb48f48a-1
kcodecs5.82.0.r369.g8b29c3e-15.82.0.r370.g6067fc3-1
kcolorchooser21.04.1.r220.g1d56f55-121.04.2.r220.g1d56f55-1
kcompletion5.82.0.r443.g83be45e-15.82.0.r444.g57b17e8-1
kconfig5.82.0.r838.gad2c9eb-15.82.0.r839.gc5a8157-1
kconfigwidgets5.82.0.r578.g21388aa-15.82.0.r582.g4e2c3ab-1
kcontacts1:5.82.0.r3240.g5af68fd4-11:5.82.0.r3242.g96fb2310-1
kcoreaddons5.82.0.r1225.ga42909c3-15.82.0.r1228.g8d9baa85-1
kcrash5.82.0.r386.gd11e239-15.82.0.r387.ged0abf0-1
kdav1:5.82.0.r1284.g077da94-11:5.82.0.r1286.g3d074ed-1
kdbusaddons5.82.0.r363.g6451696-15.82.0.r364.g822999d-1
kde-dev-scripts21.04.1.r4130.gcfc51d2-121.04.2.r4132.g8b1162a-1
kde-dev-utils21.04.1.r553.g358a3de-121.04.2.r553.g358a3de-1
kdebugsettings21.04.1.r807.gf283b6a-121.04.2.r808.g93c237b-1
kdeclarative5.82.0.r893.gb50d3f3-15.82.0.r895.g4262590-1
kdeconnect21.04.1.r3209.g82129cd8-121.04.2.r3218.gd22c6641-1
kdecoration5.21.5.r265.g319d174-15.22.0.r267.g7be8cbb-1
kded5.82.0.r403.g3e0b6f5-15.82.0.r404.gb7a1dd8-1
kdegraphics-thumbnailers21.04.1.r231.g224d34b-121.04.2.r231.g224d34b-1
kdelibs4support5.82.0.r1020.g0af76e1b-15.82.0.r1021.g8cc57d3e-1
kdenlive21.04.1.r14497.gb6ef7c627-121.04.2.r14523.gee7a141b1-1
kdepim-addons21.04.1.r4120.g42a9c86d-121.04.2.r4120.g42a9c86d-1
kdepim-runtime21.04.1.r15116.g4d03afe20-121.04.2.r15117.g76126986c-1
kdeplasma-addons5.21.5.r8526.g61d2b54a3-15.22.0.r8527.g679e97721-1
kdesdk-kioslaves21.04.1.r488.g99737ef-121.04.2.r488.g99737ef-1
kdesdk-thumbnailers21.04.1.r68.gb71f553-121.04.2.r68.gb71f553-1
kdesignerplugin5.82.0.r325.g082d2a2-15.82.0.r326.gbb2a8ce-1
kdesu5.82.0.r463.gb045947-15.82.0.r464.g78cd928-1
kdewebkit5.82.0.r270.ge31c06b-15.82.0.r271.gefee461-1
kdf21.04.1.r787.g8ebda46-121.04.2.r787.g8ebda46-1
kdialog21.04.1.r1180.gd4f172738-121.04.2.r1180.gd4f172738-1
kdiamond21.04.1.r660.g7ff443b-121.04.2.r660.g7ff443b-1
kdisplay5.21.5.r1446.gdbac314-15.22.0.r1447.g1963036-1
kdnssd5.82.0.r309.g3fa7f77-15.82.0.r310.g8e2c3b6-1
kdoctools5.82.0.r608.g224e376-15.82.0.r611.g9d5ab52-1
keditbookmarks21.04.1.r2738.g5e122c923-121.04.2.r2738.g5e122c923-1
kemoticons5.82.0.r373.g8d35fae-15.82.0.r374.g716775b-1
keysmith 0.1.r218.g9689369-1 21.06.r1.gaddd873-1
kfilemetadata5.82.0.r792.gadc6b76-15.82.0.r793.g32ac7f7-1
kfind21.04.1.r2632.g4ebc96a8f-121.04.2.r2632.g4ebc96a8f-1
kfloppy21.04.1.r749.ge3ecf6a-121.04.2.r749.ge3ecf6a-1
kfourinline21.04.1.r974.g3e4a6f2-121.04.2.r974.g3e4a6f2-1
kgeography21.04.1.r1108.g889d027-121.04.2.r1108.g889d027-1
kget21.04.1.r3098.g5add194a-121.04.2.r3099.g06f334d4-1
kglobalaccel5.82.0.r445.g75f156b-15.82.0.r447.g6d281dd-1
kgoldrunner21.04.1.r1223.gb69af3c-121.04.2.r1224.gb5994ad-1
kgpg21.04.1.r3122.g9c45b462-121.04.2.r3122.g9c45b462-1
kguiaddons5.82.0.r364.gf825d80-15.82.0.r366.g5e9d675-1
khangman21.04.1.r1557.g7f579fb-121.04.2.r1557.g7f579fb-1
khelpcenter21.04.1.r2658.g809cac01-121.04.2.r2658.g809cac01-1
kholidays1:5.82.0.r933.ga5b1b98-11:5.82.0.r934.gf2c9f0e-1
khtml5.82.0.r546.g826df94-15.82.0.r547.g5ac7996-1
ki18n5.82.0.r465.gbdeedec-15.82.0.r467.gd0beae8-1
kiconthemes5.82.0.r525.gdece676-15.82.0.r526.g5a974b7-1
kidentitymanagement21.04.1.r3783.g58cbe37a-121.04.2.r3784.g8a99ae7e-1
kidletime5.82.0.r303.gce83451-15.82.0.r304.g21faaef-1
kig21.04.1.r3136.g636c3557-121.04.2.r3136.g636c3557-1
kigo21.04.1.r509.gacd3663-121.04.2.r509.gacd3663-1
killbots21.04.1.r724.g32c950b-121.04.2.r724.g32c950b-1
kimagemapeditor21.04.1.r458.gfceb8af-121.04.2.r458.gfceb8af-1
kimap21.04.1.r1089.g3574668-121.04.2.r1091.g6eddbfb-1
kinfocenter5.21.5.r1842.gb2bcf7e-15.22.0.r1846.g43a3b50-1
kinit5.82.0.r399.g467b7b8-15.82.0.r400.g2ca0a1d-1
kio5.82.0.r4776.g828ac01c-15.82.0.r4784.gbca2aa22-1
kio-extras21.04.1.r7034.g8e17ce0e-121.04.2.r7048.g33f48497-1
kio-gdrive21.04.1.r555.ga7f26c5-121.04.2.r555.ga7f26c5-1
kipi-plugins21.04.1.r12060.g5fe710f54-121.04.2.r12060.g5fe710f54-1
kirigami-gallery21.04.1.r207.g38d56e0-121.04.2.r207.g38d56e0-1
kirigami25.82.0.r2805.g2e618d13-15.82.0.r2811.g8f128b17-1
kiriki21.04.1.r414.g3eb1ea1-121.04.2.r414.g3eb1ea1-1
kitemmodels5.82.0.r541.g37e129e-15.82.0.r542.g2df6568-1
kitemviews5.82.0.r326.g0817606-15.82.0.r327.g0da5de7-1
kiten21.04.1.r1138.g54e1359-121.04.2.r1138.g54e1359-1
kitinerary21.04.1.r1804.g9605982-121.04.2.r1807.g59f1aba-1
kjobwidgets5.82.0.r363.g4d54d26-15.82.0.r364.gfc520a5-1
kjs5.82.0.r326.gf7ee293-15.82.0.r327.g553d5a5-1
kjsembed5.82.0.r295.g4e25cc2-15.82.0.r296.g704b86e-1
kjumpingcube21.04.1.r777.g2a1f947-121.04.2.r777.g2a1f947-1
kldap21.04.1.r860.gbd954e2-121.04.2.r862.gdd335bc-1
kleopatra21.04.1.r5867.g7aee9857-121.04.2.r5872.gb1648586-1
klettres21.04.1.r909.g40e40d4-121.04.2.r909.g40e40d4-1
klickety21.04.1.r621.g8b95538-121.04.2.r621.g8b95538-1
klines21.04.1.r735.gc409f0c-121.04.2.r735.gc409f0c-1
kmag21.04.1.r684.g5bac8b7-121.04.2.r684.g5bac8b7-1
kmahjongg21.04.1.r1461.g0c18f1c-121.04.2.r1461.g0c18f1c-1
kmail21.04.1.r25757.gcae9e6a9e-121.04.2.r25771.g58a1191a1-1
kmail-account-wizard21.04.1.r780.gd8b8beb-121.04.2.r780.gd8b8beb-1
kmailtransport21.04.1.r1605.gc21f9c1-121.04.2.r1608.g006cf2a-1
kmbox21.04.1.r519.gb777ed4-121.04.2.r521.gcef25bd-1
kmediaplayer5.82.0.r287.g57aa8cf-15.82.0.r288.gf63aabc-1
kmime21.04.1.r1432.gb46a5d1-121.04.2.r1434.g00b4a86-1
kmines21.04.1.r1709.g4ca019d-121.04.2.r1709.g4ca019d-1
kmix21.04.1.r2367.ged18b68d-121.04.2.r2367.ged18b68d-1
kmousetool21.04.1.r387.g3e256a8-121.04.2.r387.g3e256a8-1
kmplot21.04.1.r1458.g0a5391d-121.04.2.r1459.g6cdacb6-1
knavalbattle21.04.1.r1378.g866bcbc-121.04.2.r1378.g866bcbc-1
knetwalk21.04.1.r648.ge3b8b85-121.04.2.r648.ge3b8b85-1
knewstuff5.82.0.r1155.gee29d1bf-15.82.0.r1173.g332558d3-1
knights21.04.1.r1046.g9c41563-121.04.2.r1046.g9c41563-1
knotes21.04.1.r3454.g31e39c27-121.04.2.r3455.gac0f5731-1
knotifications5.82.0.r657.g223ce39-15.82.0.r660.g323418f-1
knotifyconfig5.82.0.r342.g5297588-15.82.0.r343.gcc773de-1
koko 21.05.r14.gf736a1b-1 21.06.r1.gf25306b-1
kolf21.04.1.r1416.g255c4fc-121.04.2.r1416.g255c4fc-1
kollision21.04.1.r483.gc56666d-121.04.2.r483.gc56666d-1
kolourpaint21.04.1.r2342.ge42126f9-121.04.2.r2342.ge42126f9-1
kompare21.04.1.r1100.gc15db89-121.04.2.r1100.gc15db89-1
kongress 21.05.r12.g63d2201-1 21.06.r2.g4c2f21b-1
konqueror21.04.1.r14904.gfb9f052e4-121.04.2.r14904.gfb9f052e4-1
konquest21.04.1.r888.g8b6d0b6-121.04.2.r888.g8b6d0b6-1
konsole21.04.1.r7803.gddce31d6-121.04.2.r7817.ga66d2e23-1
kontact21.04.1.r5321.gc8bdb20e-121.04.2.r5321.gc8bdb20e-1
kontactinterface21.04.1.r611.gc8ca081-121.04.2.r612.g7dcfd93-1
kontrast21.04.1.r167.gaf1bb0b-121.04.2.r167.gaf1bb0b-1
konversation21.04.1.r8962.g900588e9-121.04.2.r8962.g900588e9-1
korganizer21.04.1.r11373.g19f273828-121.04.2.r11375.ge8973c570-1
kosmindoormap21.04.1.r602.g2d396ba-121.04.2.r612.gf2a1151-1
kpackage5.82.0.r662.gf64c391-15.82.0.r667.g5695d05-1
kparts5.82.0.r507.g3c94c7d-15.82.0.r508.g1d6b59c-1
kpat21.04.1.r2545.gc42b14b-121.04.2.r2548.gc30fa25-1
kpeople5.82.0.r1321.gde7f669-15.82.0.r1326.g60d476e-1
kpeoplesink r67.g27b72f4-1 r68.g9533e23-1
kpeoplevcard 0.1.r3.gb10c103-2 0.1.r11.gba721cb-1
kpimtextedit21.04.1.r1381.gaf49746-121.04.2.r1384.g1729196-1
kpkpass21.04.1.r216.g0eae141-121.04.2.r218.ga182f77-1
kplotting5.82.0.r282.ga17ea65-15.82.0.r283.g40b6613-1
kpty5.82.0.r326.g60b3c2d-15.82.0.r327.gaacc592-1
kpublictransport21.04.1.r1651.g4ae36e2-121.04.2.r1667.g5a894a4-1
kquickcharts5.82.0.r458.gee15a91-15.82.0.r461.g12d18ba-1
krdc21.04.1.r1506.g0326876-121.04.2.r1506.g0326876-1
krecorder 21.05.r14.g94e9d93-1 21.06.r2.gb273970-1
kreversi21.04.1.r1213.g259705c-121.04.2.r1214.g028f16e-1
krfb21.04.1.r1395.ga4cc0e8-121.04.2.r1395.ga4cc0e8-1
kross5.82.0.r325.ga61d2da-15.82.0.r326.g4c67e48-1
kross-interpreters21.04.1.r722.g8d54326-121.04.2.r722.g8d54326-1
kruler21.04.1.r687.gb67a000-121.04.2.r687.gb67a000-1
krunner5.82.0.r629.g6b6eff9-15.82.0.r630.g2304570-1
kscreenlocker5.21.5.r851.gc2a126e-15.22.0.r852.g60b4f53-1
kservice5.82.0.r912.g7d967b2-15.82.0.r914.g60ba3fa-1
kshisen21.04.1.r1187.g1666233-121.04.2.r1187.g1666233-1
ksirk21.04.1.r956.g4f0e5e8-121.04.2.r956.g4f0e5e8-1
ksmtp21.04.1.r349.gd5983b8-121.04.2.r350.g108f328-1
ksnakeduel21.04.1.r791.g2c074eb-121.04.2.r791.g2c074eb-1
kspaceduel21.04.1.r620.g35aa5a3-121.04.2.r620.g35aa5a3-1
ksquares21.04.1.r509.g970e068-121.04.2.r509.g970e068-1
ksshaskpass5.21.5.r196.gdaa2679-15.22.0.r196.gdaa2679-1
ksudoku21.04.1.r1044.g19e3de6-121.04.2.r1044.g19e3de6-1
ksysguard5.21.5.r3505.g992dfda3-15.22.0.r3505.g992dfda3-1
ksystemlog21.04.1.r636.g95a942e-121.04.2.r636.g95a942e-1
ksystemstats5.21.5.r174.g0639a7f-15.22.0.r174.g0639a7f-1
kteatime21.04.1.r717.g94dd38e-121.04.2.r717.g94dd38e-1
ktexteditor5.82.0.r2856.g14b33489-15.82.0.r2875.g9ce5dd98-1
ktextwidgets5.82.0.r399.g6fe7292-15.82.0.r400.gc2efa56-1
ktimer21.04.1.r462.g217ff99-121.04.2.r462.g217ff99-1
ktnef21.04.1.r646.g3fa4c6b-121.04.2.r648.gd374f3e-1
ktorrent21.04.1.r2748.g53599a17-121.04.2.r2748.g53599a17-1
ktouch21.04.1.r2133.g7496746-121.04.2.r2133.g7496746-1
ktrip 21.05.r13.ga32532d-1 21.06.r7.g594a733-1
ktuberling21.04.1.r997.gcc07968-121.04.2.r1001.ga0d2404-1
kturtle21.04.1.r1111.gcd6a6f3-121.04.2.r1111.gcd6a6f3-1
kubrick21.04.1.r362.gcd11cfe-121.04.2.r362.gcd11cfe-1
kunitconversion5.82.0.r363.g9edb815-15.82.0.r364.g6c844da-1
kwallet5.82.0.r1068.gbdcb7bb-15.82.0.r1069.g2f7222e-1
kwalletmanager21.04.1.r1192.g4c7fdf2-121.04.2.r1193.gba6de7c-1
kwave21.04.1.r3735.gbe0fbd8d-121.04.2.r3735.gbe0fbd8d-1
kwayland5.82.0.r1088.g6c08615-15.82.0.r1089.g89e88c0-1
kwayland-integration5.21.5.r175.g9fcecb7-15.22.0.r175.g9fcecb7-1
kwayland-server5.21.5.r1334.g53fa053-15.22.0.r1334.g53fa053-1
kweather 0.4.r105.g644e718-1 21.06.r1.ge5c9e18-1
kweathercore 21.05.r11.gd5bf1dd-1 21.05.r12.g4690eee-1
kwidgetsaddons5.82.0.r818.g1c706bb6-15.82.0.r820.gc4994a19-1
kwin5.21.5.r19491.g34bfc2575-15.22.0.r19539.g943bdc0e6-1
kwindowsystem5.82.0.r593.g749d789-15.82.0.r594.ga568e89-1
kwinft5.21.5.r18908.gfba1f5cef-15.22.0.r18909.g1620a5368-1
kwordquiz21.04.1.r1136.ged21a88-121.04.2.r1136.ged21a88-1
kwrite21.04.1.r18192.ga5d2b7a4f-121.04.2.r18205.g3a5cd5698-1
kxmlgui5.82.0.r761.g7f454b5c-15.82.0.r764.g50482de0-1
kxmlrpcclient5.82.0.r448.g0e44fd82f-15.82.0.r449.g8381cc83b-1
libakonadi21.04.1.r12505.g8beee8e18-121.04.2.r12508.g0aa26872d-1
libgravatar21.04.1.r350.ga9d89cc-121.04.2.r352.g9c0bd2d-1
libkdepim21.04.1.r830.g42f1731-121.04.2.r831.g7709e80-1
libkgapi21.04.1.r1277.g934c300-121.04.2.r1279.g373fb68-1
libkleo21.04.1.r885.g44ad019-121.04.2.r892.g525fb65-1
libksieve21.04.1.r1528.g046fdbd3-121.04.2.r1530.g13942b86-1
libksysguard5.21.5.r2238.ge949ee0-15.22.0.r2241.g2660f2d-1
libktorrent21.04.1.r515.g56be4b3-121.04.2.r516.g36beec0-1
libquotient r1979.g7761c2b-1 r1980.g0571ba1-1
lokalize21.04.1.r1759.g07fa320-121.04.2.r1759.g07fa320-1
lskat21.04.1.r803.g199b556-121.04.2.r803.g199b556-1
mailcommon21.04.1.r1037.g19013a4-121.04.2.r1039.g1782c4d-1
mailimporter21.04.1.r452.g6ba2f37-121.04.2.r455.g8eafa65-1
marble21.04.1.r13309.g64de32f42-121.04.2.r13309.g64de32f42-1
marble-common21.04.1.r13309.g64de32f42-121.04.2.r13309.g64de32f42-1
marble-qt21.04.1.r13309.g64de32f42-121.04.2.r13309.g64de32f42-1
markdownpart21.04.1.r70.g203975d-121.04.2.r70.g203975d-1
maui-nota 1.2.2.r31.g25faed5-1 1.2.2.r36.gbed4091-1
maui-pix 1.2.2.r27.g9f488c3-1 1.2.2.r32.g1d4f744-1
mauikit2.2.2.r57.g1ea1bba5-12.2.2.r68.gba94cc4c-1
mauikit-filebrowsing 1.2.2.r32.g9655d4f-1 1.2.2.r36.gdeb2b7a-1
mbox-importer21.04.1.r493.g9a11543-121.04.2.r493.g9a11543-1
milou5.21.5.r743.gaef14f0-15.22.0.r743.gaef14f0-1
minuet21.04.1.r575.g2ec077c-121.04.2.r575.g2ec077c-1
modemmanager-qt5.82.0.r508.g17ad1cb-15.82.0.r509.g553bfcb-1
neochat r1738.gd9eaa95b-1 r1746.gd1d4d6ef-1
networkmanager-qt5.82.0.r1105.g3b4bf04-15.82.0.r1106.g83ec746-1
okular21.04.1.r9351.gc78588751-121.04.2.r9367.gac083e44e-1
palapeli21.04.1.r1222.g9259743-121.04.2.r1223.ga39f151-1
parley21.04.1.r4408.g8c4ab163-121.04.2.r4409.g32cb840a-1
partitionmanager21.04.1.r1525.g03fad35-121.04.2.r1526.g9212d74-1
picmi21.04.1.r526.ge88c260-121.04.2.r526.ge88c260-1
pim-data-exporter21.04.1.r2411.gdd4590d8-121.04.2.r2411.gdd4590d8-1
pim-sieve-editor21.04.1.r1478.g3ce2707-121.04.2.r1478.g3ce2707-1
pimcommon21.04.1.r1052.g8441f73-121.04.2.r1053.g5b06e02-1
plasma-browser-integration5.21.5.r1258.g1166bf0c-15.22.0.r1260.g0f027324-1
plasma-desktop5.21.5.r8485.ga17076973-15.22.0.r8489.gbe6e36e54-1
plasma-dialer 21.05.r53.gf5b4dda-1 21.06.r3.ga5197f7-1
plasma-disks5.21.5.r210.gdc9e6ff-15.22.0.r213.g4297443-1
plasma-framework5.82.0.r15867.g33eb00127-15.82.0.r15872.g2c6c29064-1
plasma-nano5.21.5.r146.g47f2857-15.21.5.r150.gefb823e-1
plasma-nm5.21.5.r3055.g6cac88b6-15.22.0.r3057.ge8c90783-1
plasma-phone-components5.21.4.r1409.gf292ca20-15.22.0.r1419.g99295008-1
plasma-phonebook 21.05.r31.gbcc6059-1 21.06.r2.g97dcf94-1
plasma-settings 21.05.r17.g22049e3-1 21.05.r18.gdb9e587-1
plasma-systemmonitor5.21.5.r444.ge1981e2-15.22.0.r448.g147c717-1
plasma-thunderbolt5.21.5.r132.g1af85bd-15.22.0.r133.g176fb93-1
plasma-vault5.21.5.r334.g236e6c2-15.22.0.r335.gb971ea2-1
plasma-wayland-session5.21.5.r10360.g6c4cc0767-15.22.0.r10378.g81fc2406b-1
plasma-workspace5.21.5.r10360.g6c4cc0767-15.22.0.r10378.g81fc2406b-1
plasma-workspace-wallpapers5.21.5.r271.g9f378b2-15.22.0.r272.g4f13f0b-1
powerdevil5.21.5.r2438.g4e43cce8-15.22.0.r2439.gdb265c00-1
poxml21.04.1.r277.ge2d4dfb-121.04.2.r277.ge2d4dfb-1
print-manager21.04.1.r1026.g88a09c9-121.04.2.r1026.g88a09c9-1
prison5.82.0.r314.g08ad504-15.82.0.r315.g110b42b-1
purpose5.82.0.r856.g010b610-15.82.0.r859.g1ed1a20-1
qcachegrind21.04.1.r1147.g093b45f-121.04.2.r1147.g093b45f-1
qmlkonsole 21.05.r2.g1b2599b-1 21.06.r0.gb676b13-1
qqc2-desktop-style5.82.0.r487.g1159ccd-15.82.0.r489.g325dddb-1
rocs21.04.1.r3016.g80c7c4a9-121.04.2.r3016.g80c7c4a9-1
solid5.82.0.r673.g35ab631-15.82.0.r674.g02b1d5e-1
sonnet5.82.0.r615.g807e1b6-15.82.0.r617.gecede9c-1
spacebar 21.05.r15.gc75e6d7-1 21.06.r2.g5457a15-1
spectacle21.04.1.r1106.g74cf11a-121.04.2.r1109.g0f7c130-1
step21.04.1.r1151.g311e188-121.04.2.r1151.g311e188-1
svgpart21.04.1.r166.gcca88a1-121.04.2.r166.gcca88a1-1
sweeper21.04.1.r520.g10e3008-121.04.2.r520.g10e3008-1
syndication5.82.0.r826.gd766b1d-15.82.0.r827.gcb77b6b-1
syntax-highlighting5.82.0.r1588.g4e1203e2-15.82.0.r1589.g6de3c6a8-1
systemsettings5.21.5.r2438.gf0e45181-15.22.0.r2440.g5f46b35b-1
telepathy-kde-accounts-kcm21.04.1.r1192.g5a27a75-121.04.2.r1192.g5a27a75-1
telepathy-kde-approver21.04.1.r293.g45db24b-121.04.2.r293.g45db24b-1
telepathy-kde-auth-handler21.04.1.r276.g48e529c-121.04.2.r276.g48e529c-1
telepathy-kde-call-ui21.04.1.r445.g8815182-121.04.2.r445.g8815182-1
telepathy-kde-contact-list21.04.1.r1084.gd88224a-121.04.2.r1084.gd88224a-1
telepathy-kde-contact-runner21.04.1.r252.g6d4f602-121.04.2.r252.g6d4f602-1
telepathy-kde-desktop-applets21.04.1.r992.g4a74f96-121.04.2.r992.g4a74f96-1
telepathy-kde-filetransfer-handler21.04.1.r219.gd345782-121.04.2.r219.gd345782-1
telepathy-kde-integration-module21.04.1.r390.g08eac55-121.04.2.r390.g08eac55-1
telepathy-kde-send-file21.04.1.r227.g53297c0-121.04.2.r227.g53297c0-1
telepathy-kde-text-ui21.04.1.r2019.g2cae1c7-121.04.2.r2019.g2cae1c7-1
threadweaver5.82.0.r498.g363a686-15.82.0.r499.g8b92b77-1
vvave 1.2.2.r18.g3d5a3d9-1 1.2.2.r21.gcb935e1-1
wrapland5.21.5.r1470.g1d4b347-15.22.0.r1471.gfd438e9-1
zeroconf-ioslave21.04.1.r336.g9bfa090-121.04.2.r336.g9bfa090-1
kasts - 21.06.r7.gaed1a94-1
tokodon - 21.06.r4.g8035b8f-1
:: Different overlay package(s) in repository mobile aarch64
keysmith 0.2-1.7 -
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
