Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
2024-01-04
2023-06-06
If you have a lot of pip/AUR packages to upgrade to Python 3.11
Short version, for experienced users:
[HowTo] Python upgrade: reinstall AUR and pip packages
Long version with full details:
[HowTo] After a Python interpreter upgrade, reinstall non-working Python packages
Many applications (firefox, thunderbird, etc) slow to start on desktops other than Gnome
There is a bug with xdg-desktop-portal-gnome (more details here).
Workaround for gtk-based desktops (including Xfce)
sudo pacman -Rdd xdg-desktop-portal-gnome
sudo pacman -S xdg-desktop-portal-gtk
Workaround for KDE
sudo pacman -S xdg-desktop-portal-kde
Workaround for Lxqt
sudo pacman -S xdg-desktop-portal-lxqt
Workaround for desktops using hyprland
sudo pacman -S xdg-desktop-portal-hyprland
Workaround for desktops using wlroots
sudo pacman -S xdg-desktop-portal-wlr
If you installed python311 from the AUR, you need to uninstall it before running this update.
2023-02-16
Docker 23 not starting
Since the update to Docker 23, upstream is now inforcing new paths for apparmor related stuff. But there has been changes to dependencies yet. So Docker 23 will error on start.
Fix: Install apparmor from the repositories.
2023-01-03
Reduced video playback performance in mpv
There has been reports of video playback performance in mpv has regressed since an update to mpv.
Fix: MPV now needs a vd-lavc-dr=no parameter to play hw acceleration supported 1080p videos smoothly.
Touch input on Firefox with Phosh not working in Firefox 108
Since the update to Firefox 108, the touch input does not work. Seems to be an issue with a couple of the changes the mobile-config brings in. PostMarketOS likely won’t fix this in their source, so we might need to carry a patch for this.
2022-11-20
OpenSSL 1.1 library not found
Some applications might still be looking for openssl 1.1.
Solution: Install openssl-1.1 package with sudo pacman -S openssl-1.1.
2022-10-31
Firefox shows wrong colors when playing video on Raspberry Pi 4
Since Mesa 22.2, Firefox has been showing weird colors when playing video on the Raspberry Pi 4. This is caused by an issue in upstream mesa, which was recently fixed.
Fix: Update to mesa 22.2.3-0.1 in the repository, which includes this fix.
Chromium in Wayland crashes with --in-process-gpu
Since Mesa 22.2.0, Chromium running in wayland sessions seems to crash when running with the --in-process-gpu option. Running in X11 seems fine, although it’s slow.
Fix: Update to Mesa 22.3.2 was reported to work here.
2022-10-21
Plasma Mobile Dialer seems to be unreliable
Plasma Dialer 22.09 seems to have issues switching audio profiles and as such might require manual switching. Sometimes audio is completely missing.
Reduced video performance on youtube
Some may encounter reduced video playback performance on YouTube in Firefox with the new Mesa 22.2 drivers.
No workaround at this time.
Old Issues
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
[Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
- create
/etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
chain input {
iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
chain forward {
iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
ct state {established, related} counter accept comment "accept established connections"
```Hello ARM community,
this is my fourth **stable** update for our aarch64 architecture.
Most already know that we had some staff changes in our Manjaro ARM team. You might already have noticed that Dan [left the team](https://blog.strits.dk/i-no-longer-work-for-manjaro/) and the company. Therefore we have also to see when the next install medias for ARM SBCs and devices will been created. Dan did a lot for the ARM branch of Manjaro, including endless testing of boards and devices. Before releasing any image for an ARM device it needs to been tested on the device itself. You can find untested [development builds](https://github.com/orgs/manjaro-arm/repositories) at github.
Therefore I'll act as the interim release manager until we found the right staff member for this job.
## Donate
Manjaro, like many other open-source projects, relies on the generosity of its community through [donations](https://manjaro.org/donate/) and corporate sponsorships to support its growth and development. These [donations](https://manjaro.org/donate/) are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or [conferences](https://blog.manjaro.org/fosdem-2023/) and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to [donate](https://manjaro.org/donate/)!
## Update Announcement
With this update we have mostly updates to [Apple Silicon](https://gitlab.manjaro.org/manjaro-arm/packages/apple-silicon) and mobile.
*Some highlights:*
- Some **Kernels** got renewed
- **Apple-Silicon** packages got renewed to the latest issued by Asahi Linux. [Graphic stack](https://asahilinux.org/2023/06/opengl-3-1-on-asahi-linux/) got improved a lot. However, our installer is still internal
- **Calls** is now at [44.2](https://gitlab.gnome.org/GNOME/calls/-/raw/91e5cad939f6753bc232c8990be295b068473949/debian/changelog)
- the app **vakzination** got rebuild to fix so-file issues
- **libpamac** got renewed to [11.5.4](https://gitlab.manjaro.org/applications/libpamac/-/tags/11.5.4)
- Usual **KDE-git** updates
*End Of Life kernels (will be removed from repo soon):*
* `linux60` (EOL on 2023-01-12) (removed from repository)
## Tips And Tricks
[details="Error about missing openssl 1.1 library"]
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called `openssl-1.1`.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is `silver`. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install `openssl-1.1` as part of this update.
[/details]
[details="How to get Waydroid working"]
If you follow these steps, you should have Waydroid working fine.
*Remember, Waydroid only works on wayland!*
* Install `waydroid-image` and all it's dependencies.
* Run `pkexec setup-waydroid`.
* You should now be able to launch Waydroid. The first launch takes a while.
[/details]
[details="How to use Kodi RPI on Manjaro ARM"]
`sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev`
### Have it set up is to boot straight in to kodi
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
`sudo systemctl disable lightdm.service`
`sudo systemctl enable kodi.service`
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
[/details]
## Upstream Notifications:
[details="Older notifications"]
The PHP package has been updated to 8.2. If you still need 8.1, use `php-legacy` packages.
https://archlinux.org/news/php-82-update-and-introduction-of-legacy-branch/
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to `libxcrypt`:
https://archlinux.org/news/sorting-out-old-password-hashes/
The `ghostpcl` and `ghostxps` requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The `nss` package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages `hplip` and `firewalld` requires manual intervention:
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
[/details]
## Package Changes (Fri May 19 13:30:34 CEST 2023)
- arm-stable community aarch64: 20 new and 20 removed package(s)
- arm-stable core aarch64: 24 new and 23 removed package(s)
- arm-stable extra aarch64: 4 new and 4 removed package(s)
- arm-stable kde-unstable aarch64: 289 new and 289 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2023.06.09 2023.06.12
apple-silicon-configs 20221206-1 20230517-1
asahi-fwextract 0.5pre2-3 0.5.4-1
asahi-scripts 20221206-1 20230606-2
bitwarden 2023.5.0-1 2023.5.0-2
callaudiod 0.1.9-1 0.1.9-2
code 1.78.2-1 1.79.0-1
electron 23.1.2-1 23.3.6-1
electron20 20.3.11-1 -
electron21 21.4.2-1 21.4.4-1
electron22 22.3.2-1 22.3.12-1
gnome-calls 44.1-2 44.2-1
gnome-shell-mobile44.0+r283+g034144c20-144.1+r326+g9b7df11f1-1
mesa-apple-silicon-edge 23.1.0_pre20230311-1 23.2.0_pre20230606-1
mesa-apple-silicon-edge-debug 23.1.0_pre20230311-1 23.2.0_pre20230606-1
mutter-mobile44.0+r88+g780aadd4e-244.1+r191+g5e72de83d-2.0
phosh 0.28.0-10.28.0+13+g31896512-1
phosh-antispam 3.2.0-2 3.3.0-1
vakzination 23.01.0-1 23.01.0-2
vulkan-swrast-apple-silicon-edge 23.1.0_pre20230311-1 23.2.0_pre20230606-1
wire-desktop 3.30.3018-1 3.31.3060-1
electron24 - 24.5.0-1
:: Different overlay package(s) in repository core aarch64
linux 6.3.5-1 6.3.7-1
linux-aml 6.1.31-1 6.1.33-1
linux-aml-headers 6.1.31-1 6.1.33-1
linux-apple-silicon 6.2-1 6.3-1
linux-apple-silicon-edge 6.2-1 6.3-1
linux-apple-silicon-headers 6.2-1 6.3-1
linux-headers 6.3.5-1 6.3.7-1
linux-lts 6.1.31-1 6.1.33-1
linux-lts-headers 6.1.31-1 6.1.33-1
linux-pinephone 6.3.5-1 6.3.7-1
linux-pinephone-headers 6.3.5-1 6.3.7-1
linux-pinephonepro 6.3.5-1 6.3.7-1
linux-pinephonepro-headers 6.3.5-1 6.3.7-1
linux-rpi4 6.1.31-1 6.1.32-1
linux-rpi4-headers 6.1.31-1 6.1.32-1
linux-rpi4-mainline 6.3.5-1 6.3.6-1
linux-rpi4-mainline-headers 6.3.5-1 6.3.6-1
linux-rpi4-rc 6.4.rc4-1 6.4.rc5-1
linux-rpi4-rc-headers 6.4.rc4-1 6.4.rc5-1
m1n1 1.2.6-1 1.2.9-1
uboot-apple-silicon 2023.01-1 2023.04-1
uboot-pinephonepro 5:2023.07rc2-0.3 5:2023.07rc2-0.4
uboot-pinephonepro-rockchip 5:2023.07rc2-0.3 5:2023.07rc2-0.4
uboot-odroid-n2l - 2023.04-1
:: Different overlay package(s) in repository extra aarch64
libpamac 11.5.3-1 11.5.4-1
libpamac-flatpak-plugin 11.5.3-1 11.5.4-1
libpamac-snap-plugin 11.5.3-1 11.5.4-1
snapd 2.59.5-1 2.59.5-2
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi23.04.1.r13076.g84e914c45-123.04.2.r13076.g84e914c45-1
akonadi-calendar23.04.1.r2364.g2c16022-123.04.2.r2364.g2c16022-1
akonadi-calendar-tools23.04.0.r1047.g7a009d5-123.04.2.r1050.g9ba89ef-1
akonadi-contacts23.04.1.r3474.gc4e5f229-123.04.2.r3474.gc4e5f229-1
akonadi-import-wizard23.04.1.r1941.g5abcbc9-123.04.2.r1941.g5abcbc9-1
akonadi-mime23.04.1.r1873.gae00608-123.04.2.r1874.gf4c29c4-1
akonadi-notes23.04.1.r1169.gb451bbe-123.04.2.r1169.gb451bbe-1
akonadi-search23.04.1.r1395.gc9cd29c-123.04.2.r1397.gfd9883c-1
akonadiconsole23.04.0.r1747.g17f7951-123.04.2.r1748.gb566587-1
akregator23.04.0.r6725.g3b691ed9-123.04.2.r6726.g5325284a-1
analitza23.04.1.r2396.gb2b30fe1-123.04.2.r2396.gb2b30fe1-1
ark23.04.0.r5088.g2a7f46b3-123.04.2.r5090.g5033a623-1
artikulate23.04.1.r1522.g9344e4f-123.04.2.r1522.g9344e4f-1
audiocd-kio23.04.1.r1206.ge338398-123.04.2.r1208.g061a22c-1
baloo5.106.0.r3244.geafae07a-15.106.0.r3245.g9755144d-1
baloo-widgets23.04.1.r878.g2e8ea3c-123.04.2.r878.g2e8ea3c-1
blinken23.04.1.r740.g6d13ea0-123.04.2.r740.g6d13ea0-1
bluedevil1:5.27.5.r2612.ge033d939-11:5.27.5.r2613.gb31f376a-1
bomber23.04.1.r636.g7e6e493-123.04.2.r636.g7e6e493-1
bovo23.04.1.r857.ga9f1dbe-123.04.2.r857.ga9f1dbe-1
breeze5.27.5.r2628.g5d279205-15.27.5.r2629.g4afc46e7-1
buho 3.0.0.r5.gec42169-1 3.0.0.r6.ga4c2c66-1
calendarsupport23.04.0.r849.gde62582-123.04.2.r849.gde62582-1
cantor23.04.1.r3600.g19ed0b66-123.04.2.r3603.gdbbd804e-1
cervisia23.04.0.r1778.g9b84f0b-123.04.2.r1779.gefbddbb-1
discover5.27.5.r9333.gc4c0ad257-15.27.5.r9335.g725681901-1
dolphin23.04.1.r7416.ge5abe2c67-123.04.2.r7417.gbb08c70a9-1
dolphin-plugins23.04.0.r760.gb6391fd-123.04.2.r761.g1abd322-1
dragon23.04.1.r1194.g8f5664a-123.04.2.r1196.g94b6111-1
drkonqi5.27.5.r930.g8cb1aea1-15.27.5.r931.g9c42ce25-1
elisa23.04.1.r3313.g2ebf6bd6-123.04.2.r3320.g8d11cf2f-1
elisa-qtmm23.04.1.r3313.g2ebf6bd6-123.04.2.r3320.g8d11cf2f-1
eventviews23.04.0.r1026.g54d1d27-123.04.2.r1028.gdd65a38-1
ffmpegthumbs23.04.1.r263.g8a8b7c2-123.04.2.r263.g8a8b7c2-1
filelight23.04.0.r1408.g2f2b5a1-123.04.2.r1410.g253b29d-1
granatier23.04.1.r1051.g5e93a6c-123.04.2.r1051.g5e93a6c-1
grantlee-editor23.04.0.r941.gb634afb-123.04.2.r941.gb634afb-1
grantleetheme23.04.1.r504.g1f1c47b-123.04.2.r504.g1f1c47b-1
gwenview23.04.1.r7161.ga483380d-123.04.1.r7164.g47e8bdb0-1
incidenceeditor23.04.1.r1050.g7b9c8a1-123.04.2.r1051.g7c3d773-1
itinerary23.04.0.r2712.g01b4fc49-123.04.2.r2715.gae36bdb6-1
juk23.04.1.r3265.g77d80714-123.04.2.r3266.gf840340e-1
k3b1:23.04.1.r6998.g1cf60e813-11:23.04.2.r6999.g329361b61-1
kaccounts-integration23.04.1.r1364.gbf22267-223.04.2.r1364.gbf22267-1
kaccounts-providers23.04.1.r443.g3e40fe3-123.04.2.r443.g3e40fe3-1
kactivitymanagerd5.27.5.r1462.g861f9de-15.27.5.r1463.gd454806-1
kaddressbook23.04.1.r6417.g5c6a2248-123.04.2.r6420.gbc60dd46-1
kajongg23.04.1.r4419.gdcdf2ee5-123.04.2.r4422.g451e34a3-1
kalarm23.04.0.r8339.g365a6581-123.04.2.r8395.g124644f6-1
kalgebra23.04.1.r2162.g0ded608-123.04.2.r2162.g0ded608-1
kalzium23.04.1.r4512.ge103ed83-123.04.2.r4516.g80a9ab41-1
kamera23.04.1.r828.gd491cfd-123.04.2.r828.gd491cfd-1
kamoso23.04.0.r1557.ga018c91-123.04.2.r1557.ga018c91-1
kanagram23.04.1.r1406.gbc68a1f-123.04.2.r1406.gbc68a1f-1
kapman23.04.1.r734.gc63a2da-123.04.2.r734.gc63a2da-1
kapptemplate23.04.0.r1063.g5fded2a-123.04.2.r1063.g5fded2a-1
kasts23.01.0.r165.gb1d8d47-123.01.0.r168.g21952c6-1
kate23.04.0.r20721.gd208dfe5a-123.04.2.r20730.geefd3ba2d-1
katomic23.04.1.r1046.g9ed1b51-123.04.2.r1046.g9ed1b51-1
kbackup23.04.0.r544.g81bfeb6-123.04.2.r544.g81bfeb6-1
kblackbox23.04.1.r846.gb0bfda4-123.04.2.r847.gdc37f08-1
kblocks23.04.1.r826.g2447c84-123.04.2.r826.g2447c84-1
kbookmarks5.106.0.r535.g5dd2497-15.106.0.r536.g60642fc-1
kbounce23.04.1.r932.gc80ffc9-123.04.2.r932.gc80ffc9-1
kbreakout23.04.1.r999.gbfe0cbd-123.04.2.r999.gbfe0cbd-1
kbruch23.04.1.r956.g4a4b7e8-123.04.2.r956.g4a4b7e8-1
kcachegrind23.04.0.r1278.g5cbbd88-123.04.2.r1281.gbf373a0-1
kcachegrind-common23.04.0.r1278.g5cbbd88-123.04.2.r1281.gbf373a0-1
kcalc23.04.0.r1736.ga499fae-123.04.2.r1736.ga499fae-1
kcalutils23.04.1.r1084.gf8302135f-123.04.2.r1084.gf8302135f-1
kcharselect23.04.0.r625.g019cf4f-123.04.2.r625.g019cf4f-1
kclock23.01.0.r72.g6533949-123.01.0.r74.g352cc69-1
kcmutils5.106.0.r752.g861104da-15.106.0.r754.g9772c61d-1
kcolorchooser23.04.1.r337.gde9049d-123.04.2.r337.gde9049d-1
kconfig5.106.0.r1082.g1b47e6c3-15.106.0.r1083.g3c6d59de-1
kcontacts1:5.106.0.r3432.g80b99ae8-11:5.106.0.r3433.g729e4154-1
kcron23.04.0.r907.g9637eb7-123.04.2.r907.g9637eb7-1
kde-cli-tools5.27.5.r2130.ge8132be-15.27.5.r2133.g1787873-1
kde-dev-scripts23.04.0.r4182.gbd504fa-123.04.2.r4182.gbd504fa-1
kde-dev-utils23.04.0.r663.g74eae5a-123.04.2.r666.g0d5e900-1
kdebugsettings23.04.0.r1367.g2b9cccc-123.04.2.r1368.gba99146-1
kdeconnect23.04.0.r3842.gdf9be7e6-123.04.2.r3849.g4ef7c262-1
kdeedu-data23.04.1.r22.g793df3b-123.04.2.r22.g793df3b-1
kdegraphics-mobipocket23.04.1.r290.g16b2e58-123.04.2.r290.g16b2e58-1
kdegraphics-thumbnailers23.04.1.r295.g3da9b35-123.04.2.r297.g9dbad70-1
kdelibs4support5.106.0.r1205.g6356e0ee-15.106.0.r1206.ga4526feb-1
kdenetwork-filesharing23.04.0.r1094.gdc7ac35-123.04.2.r1094.gdc7ac35-1
kdenlive23.04.0.r18149.gc00260e0d-123.04.2.r18192.g6154d791d-1
kdepim-addons23.04.0.r5271.g0cc67708c-123.04.2.r5272.g9f5ee3de1-1
kdepim-runtime23.04.1.r15928.gea73e40e2-123.04.2.r15929.ge2729f0ab-1
kdeplasma-addons5.27.5.r9399.gb86d9f13b-15.27.5.r9401.gdeff16fd2-1
kdesdk-kioslaves23.04.0.r505.g1f7909e-123.04.2.r505.g1f7909e-1
kdesdk-thumbnailers23.04.0.r133.g989c6a3-123.04.2.r135.gbc52836-1
kdf23.04.0.r976.g86e7b91-123.04.2.r976.g86e7b91-1
kdialog23.04.0.r1365.g0fe2062c1-123.04.2.r1366.g0832b04ba-1
kdiamond23.04.1.r798.gcc46502-123.04.2.r799.g7596172-1
keditbookmarks23.04.0.r2838.ga35a913a2-123.04.2.r2841.ga0c18fdc0-1
keysmith23.01.0.r64.gb6f41d9-123.01.0.r65.ge941e7e-1
kfilemetadata5.106.0.r973.g7c395e2-15.106.0.r976.g53923f5-1
kfind23.04.0.r2820.g86338ab1e-123.04.2.r2821.g789620dbc-1
kfloppy23.04.0.r874.g96209b6-123.04.2.r875.gf2f65d2-1
kfourinline23.04.1.r1108.g0461ef3-123.04.2.r1108.g0461ef3-1
kgeography23.04.1.r1255.g7d31981-123.04.2.r1255.g7d31981-1
kget23.04.0.r3369.g22d0c200-123.04.2.r3370.g179d7f65-1
kglobalaccel5.106.0.r663.g659f251-15.106.0.r664.gc538ad5-1
kgoldrunner23.04.1.r1380.g1aa9eee-123.04.2.r1382.gb59d5d2-1
khangman23.04.1.r1700.g5d32616-123.04.2.r1700.g5d32616-1
khelpcenter23.04.0.r2896.g2d2d1f04-123.04.2.r2899.ge7acf8e8-1
khotkeys5.27.5.r2245.g85c7f71-15.27.5.r2246.gb2a103e-1
khtml5.106.0.r682.g121f508-15.106.0.r683.g14a5880-1
kiconthemes5.106.0.r702.ga973b2a-15.106.0.r703.gcc16d7d-1
kidentitymanagement23.04.1.r4007.g36e0f760-123.04.2.r4008.gcb17bd07-1
kig23.04.1.r3343.g58ce31b1-123.04.2.r3345.g046a3f87-1
kigo23.04.1.r659.ge608c95-123.04.2.r660.gd1de2ff-1
killbots23.04.1.r873.ge3deff6-123.04.2.r875.gdec0ee7-1
kimagemapeditor23.04.1.r584.ge06fa84-123.04.2.r586.g0bf89e6-1
kimap23.04.1.r1301.ge04dd9b-123.04.2.r1301.ge04dd9b-1
kinfocenter5.27.5.r2383.g18c0d4d0-15.27.5.r2386.g8d0d365c-1
kio5.106.0.r6191.g0e6c01e0c-15.106.0.r6196.g811fae761-1
kio-extras23.04.0.r7573.g6950463ed-123.04.2.r7575.g0680a0462-1
kio-gdrive23.04.0.r725.g39de711-123.04.2.r725.g39de711-1
kirigami-addons1:0.8.0.r47.g3604f34-11:0.8.0.r49.gcf3d908-1
kirigami-gallery23.04.0.r353.gb960590-123.04.2.r353.gb960590-1
kirigami25.106.0.r3710.g21106c6e-15.106.0.r3713.g74155121-1
kiriki23.04.1.r533.g282d39b-123.04.2.r534.g7e28ff1-1
kitemmodels5.106.0.r649.g736563f-15.106.0.r650.g0952af4-1
kiten23.04.1.r1286.g11f5f88-123.04.2.r1286.g11f5f88-1
kitinerary23.04.1.r2949.gc43adca3-123.04.2.r2957.gf62f9635-1
kjumpingcube23.04.1.r917.gcd4e342-123.04.2.r917.gcd4e342-1
kldap23.04.1.r1092.g385db87-123.04.2.r1092.g385db87-1
kleopatra23.04.0.r7300.ge249c30e-123.04.2.r7308.g8cbe0a3d-1
klettres23.04.1.r1050.ga7614e7-123.04.2.r1050.ga7614e7-1
klickety23.04.1.r775.g8f86b24-123.04.2.r775.g8f86b24-1
klines23.04.1.r893.g05309f8-123.04.2.r894.g7c56c56-1
kmag23.04.1.r819.gc83e844-123.04.2.r819.gc83e844-1
kmahjongg23.04.1.r1664.g1390305-123.04.2.r1665.g515b2d5-1
kmail23.04.0.r27005.g05f2056d5-123.04.2.r27037.g58218c12c-1
kmail-account-wizard23.04.0.r985.ge4a7cf5-123.04.2.r985.ge4a7cf5-1
kmailtransport23.04.1.r1937.g588a092-123.04.2.r1938.g5961f5b-1
kmbox23.04.1.r653.gf9238bc-123.04.2.r653.gf9238bc-1
kmenuedit5.27.5.r1180.g3ed6ce1-15.27.5.r1181.g0e27bea-1
kmime23.04.1.r1629.ga926427-123.04.2.r1629.ga926427-1
kmines23.04.1.r1845.g02b3b61-123.04.2.r1845.g02b3b61-1
kmix23.04.0.r2556.g2f7272a2-123.04.2.r2582.g1d516924-1
kmousetool23.04.1.r523.g55db80d-123.04.2.r524.g2d95fcf-1
kmouth23.04.1.r829.g82e5da8-123.04.2.r830.gdd57bdd-1
kmplot23.04.1.r1593.g76d6ade-123.04.2.r1594.gf6720cc-1
knavalbattle23.04.1.r1514.gde963e6-123.04.2.r1514.gde963e6-1
knetwalk23.04.1.r788.g017a27e-123.04.2.r788.g017a27e-1
knewstuff5.106.0.r1552.g5bf8c87f-15.106.0.r1554.gb67db719-1
knights23.04.1.r1243.ga2b1ca6-123.04.2.r1243.ga2b1ca6-1
knotes23.04.0.r3917.gc00720f7-123.04.2.r3918.gb55dded6-1
kolf23.04.1.r1604.gce02248-123.04.2.r1604.gce02248-1
kollision23.04.1.r606.ga16e446-123.04.2.r606.ga16e446-1
kolourpaint23.04.1.r2534.g3c112dc4-123.04.2.r2536.g4b279d88-1
kompare23.04.0.r1285.geebb3f3-123.04.2.r1287.g4bce7f2-1
konqueror23.04.0.r15448.g3e8624be9-123.04.2.r15452.g4cd673089-1
konquest23.04.1.r1021.gc3687c4-123.04.2.r1021.gc3687c4-1
konsole23.04.0.r9075.g95bcf2e0a-123.04.2.r9082.g73d067991-1
kontact23.04.0.r5767.g2c999500-123.04.2.r5767.g2c999500-1
kontactinterface23.04.1.r791.gfca2805-123.04.2.r791.gfca2805-1
kontrast23.04.1.r319.gfd12f26-123.04.2.r319.gfd12f26-1
konversation23.04.0.r9297.g2379a978-123.04.2.r9297.g2379a978-1
kopeninghours23.04.1.r391.gfae8220-123.04.2.r391.gfae8220-1
kopete23.04.0.r16568.g7b7a0f0c9-123.04.2.r16570.ga053f12a8-1
korganizer23.04.0.r12137.g194a9f057-123.04.2.r12137.g194a9f057-1
kosmindoormap23.04.1.r1010.g90a71f2-123.04.2.r1010.g90a71f2-1
kpat23.04.1.r2756.g24dba31f-123.04.2.r2756.g24dba31f-1
kpimtextedit23.04.1.r1874.g5c1eaaa-123.04.2.r1901.ge91a512-1
kpkpass23.04.1.r348.ge38d0dd-123.04.2.r348.ge38d0dd-1
kpmcore23.04.1.r1374.g992174e-123.04.2.r1375.g6640766-1
kpublictransport23.04.1.r2179.g231e3f02-123.04.2.r2180.g8b7136a5-1
kqtquickcharts23.04.1.r78.g22ff9c9-123.04.2.r78.g22ff9c9-1
krdc23.04.0.r1721.g4d6fa90-123.04.2.r1721.g4d6fa90-1
kreversi23.04.1.r1353.gd7e11ea-123.04.2.r1353.gd7e11ea-1
krfb23.04.0.r1578.gf2fc9ca-123.04.2.r1578.gf2fc9ca-1
kross-interpreters23.04.0.r725.gdef2cfe-123.04.2.r725.gdef2cfe-1
kruler23.04.1.r852.g9b1eff8-123.04.2.r852.g9b1eff8-1
kshisen23.04.1.r1342.g1117378-123.04.2.r1343.gc44c7f9-1
ksirk23.04.1.r1141.g8fb1bae-123.04.2.r1142.gf1b7179-1
ksmtp23.04.1.r532.g0b9c77f-123.04.2.r532.g0b9c77f-1
ksnakeduel23.04.1.r929.g2ef8918-123.04.2.r929.g2ef8918-1
kspaceduel23.04.1.r740.gfb3d585-123.04.2.r740.gfb3d585-1
ksquares23.04.1.r658.g090ed62-123.04.2.r658.g090ed62-1
ksudoku23.04.1.r1202.g30027d1-123.04.2.r1203.ge15bbbe-1
ksystemlog23.04.0.r855.g7139f9e-123.04.2.r856.g17b7432-1
kteatime23.04.0.r831.g5c745f8-123.04.2.r832.g1a85fd8-1
ktextaddons r481.g1030c42-1 r483.g85d7867-1
ktexteditor5.106.0.r3833.gd8abfb98-15.106.0.r3834.gf3e43910-1
ktimer23.04.0.r596.g5430a02-123.04.2.r596.g5430a02-1
ktnef23.04.1.r816.g405852e-123.04.2.r817.g04882d2-1
ktorrent23.04.0.r2990.g519d9ec6-123.04.2.r2994.g1b0408e0-1
ktouch23.04.1.r2269.gd0a1621-123.04.2.r2273.gd2d25550-1
ktrip23.01.0.r26.g1befab2-123.01.0.r30.g0122db5-1
ktuberling23.04.1.r1163.g9378253-123.04.2.r1163.g9378253-1
kturtle23.04.1.r1273.gb6e55e2-123.04.2.r1274.g0ebcf61-1
kubrick23.04.1.r490.ge5163ce-123.04.2.r491.gb6c8628-1
kwalletmanager23.04.0.r1464.g6a4a01b-123.04.2.r1464.g6a4a01b-1
kwave23.04.0.r3882.g8e97359f-123.04.2.r3883.g2a03ba6d-1
kwayland5.106.0.r1212.g25e86ba-15.106.0.r1213.g6f31cb0-1
kwidgetsaddons5.106.0.r1097.g64c59987-15.106.0.r1098.ga70ee848-1
kwin5.27.5.r24236.g5a9cfe174a-15.27.5.r24241.g3cf71114cb-1
kwordquiz23.04.1.r1319.g5ffc9f9-123.04.2.r1320.g73a22e3-1
kwrite23.04.0.r20721.gd208dfe5a-123.04.2.r20730.geefd3ba2d-1
kxmlgui5.106.0.r1006.g52234202-15.106.0.r1007.gb507bcd9-1
libakonadi23.04.1.r13076.g84e914c45-123.04.2.r13076.g84e914c45-1
libgravatar23.04.1.r519.gb7fcd18-123.04.2.r519.gb7fcd18-1
libkcddb23.04.1.r850.g0c12974-123.04.2.r851.ga26e08a-1
libkcompactdisc23.04.1.r437.g16014b8-123.04.2.r437.g16014b8-1
libkdcraw23.04.1.r1160.g580849c-123.04.2.r1160.g580849c-1
libkdegames23.04.1.r2335.g052d0506-123.04.2.r2336.gd8f0a978-1
libkdepim23.04.1.r1005.g73e26e7-123.04.2.r1005.g73e26e7-1
libkeduvocdocument23.04.1.r1857.g1f4c062-123.04.2.r1857.g1f4c062-1
libkexiv223.04.1.r843.g68c21bb-123.04.2.r843.g68c21bb-1
libkgapi23.04.1.r1575.ge3db7440-123.04.2.r1575.ge3db7440-1
libkipi23.04.1.r1289.g8cacdbb-123.04.2.r1289.g8cacdbb-1
libkleo23.04.1.r1528.g7f9e67d-123.04.2.r1530.gdfe3d6b-1
libkmahjongg23.04.1.r532.g735eefe-123.04.2.r532.g735eefe-1
libkomparediff223.04.1.r406.ge391412-123.04.2.r406.ge391412-1
libksane23.04.1.r657.g70a8a78-123.04.2.r657.g70a8a78-1
libksieve23.04.1.r1911.gb2d65ed4-123.04.2.r1912.g9c6669e6-1
libktorrent23.04.1.r604.g5eb5b48-123.04.2.r604.g5eb5b48-1
lokalize23.04.0.r2041.gf1d105e8-123.04.2.r2042.g8fbd5973-1
lskat23.04.1.r935.g9ea5ee9-123.04.2.r935.g9ea5ee9-1
mailcommon23.04.1.r1490.g5da6718-123.04.2.r1491.g3eaf59e-1
mailimporter23.04.1.r628.g18495f3-123.04.2.r628.g18495f3-1
marble23.04.1.r13685.g579881495-123.04.2.r13688.gc59f6e9c3-1
marble-common23.04.1.r13685.g579881495-123.04.2.r13688.gc59f6e9c3-1
marble-qt23.04.1.r13685.g579881495-123.04.2.r13688.gc59f6e9c3-1
markdownpart23.04.0.r208.g3c2e1ad-123.04.2.r208.g3c2e1ad-1
mauikit 3.0.0.r5.gf252a3be-1 3.0.0.r6.g41bf0289-1
mauikit-filebrowsing 2.2.2.r53.g41625fa-1 2.2.2.r54.g0550cee-1
mbox-importer23.04.0.r651.g97d40f2-123.04.2.r651.g97d40f2-1
messagelib23.04.1.r7166.g516798438-123.04.2.r7168.gee6a11b8f-1
minuet23.04.1.r700.gfe37472-123.04.2.r700.gfe37472-1
neochat23.01.0.r424.gb5c781212-123.01.0.r446.g7c75a2fd0-1
okular23.04.1.r10109.g57f5c6933-123.04.2.r10118.gd78752ea3-1
oxygen5.27.5.r4586.g91d4055f-15.27.5.r4588.g4b77ceb9-1
palapeli23.04.1.r1396.g8e47257-123.04.2.r1396.g8e47257-1
parley23.04.1.r4622.g5ab4330b-123.04.2.r4622.g5ab4330b-1
partitionmanager23.04.0.r1810.g58e6465-123.04.2.r1810.g58e6465-1
picmi23.04.1.r640.gcf33236-123.04.2.r640.gcf33236-1
pim-data-exporter23.04.0.r2921.gfe05d2a1-123.04.2.r2921.gfe05d2a1-1
pim-sieve-editor23.04.0.r1786.gca81f38-123.04.2.r1786.gca81f38-1
pimcommon23.04.0.r2111.ge11b2f04-123.04.2.r2112.g65d25789-1
plasma-camera 1.0.r173.g9972dc5-1 1.0.r175.gaa98c44-1
plasma-desktop5.27.5.r10256.g344a69a38-15.27.5.r10260.g30bf5d7d7-1
plasma-firewall5.27.5.r737.g4a94a16-15.27.5.r738.g4be5574-1
plasma-mobile5.27.5.r2229.g8de183099-15.27.5.r2231.g5f81c766d-1
plasma-mobile-nm5.27.5.r3616.g6d6314e9-15.27.5.r3617.gdf2d73b9-1
plasma-nm5.27.5.r3616.g6d6314e9-15.27.5.r3617.gdf2d73b9-1
plasma-pa5.27.5.r1235.g5a5d6b8-15.27.5.r1236.g6282ef8-1
plasma-phonebook23.01.0.r65.g93c377b-123.01.0.r69.g4c89eef-1
plasma-sdk5.27.5.r2514.gcb01a3dc-15.27.5.r2517.gfd4eb174-1
plasma-systemmonitor5.27.5.r736.g4a23fb6-15.27.5.r738.g009565c-1
plasma-vault5.27.5.r451.gf48f354-15.27.5.r452.gc5577ab-1
plasma-wayland-session5.27.5.r13443.g6de6467f1-15.27.5.r13450.g3672104c7-1
plasma-workspace5.27.5.r13443.g6de6467f1-15.27.5.r13450.g3672104c7-1
powerdevil5.27.5.r2737.gb6aea53e-15.27.5.r2741.g7740e71c-1
poxml23.04.0.r290.ge730008-123.04.2.r290.ge730008-1
print-manager23.04.0.r1280.g3f40324-123.04.2.r1280.g3f40324-1
qcachegrind23.04.0.r1278.g5cbbd88-123.04.2.r1281.gbf373a0-1
rocs23.04.1.r3193.g2e016f81-123.04.2.r3193.g2e016f81-1
sddm0.19.0.r230.g9a07cf0-10.19.0.r231.g40250a6-1
signon-kwallet-extension23.04.1.r85.g2d8eb31-123.04.2.r85.g2d8eb31-1
spacebar23.01.0.r69.g1c98873-123.01.0.r70.gb07b3fa-1
spectacle23.04.1.r1759.g862d435-123.04.2.r1761.g8e3afdd-1
step23.04.1.r1338.g8d3252b-123.04.2.r1338.g8d3252b-1
svgpart23.04.1.r286.g152c942-123.04.2.r286.g152c942-1
sweeper23.04.0.r645.g61bef39-123.04.2.r645.g61bef39-1
syntax-highlighting5.106.0.r2149.gb1306e94-15.106.0.r2150.gef98ada2-1
telepathy-kde-accounts-kcm23.04.0.r1266.g8bb97ee-123.04.2.r1267.g06f990b-1
telepathy-kde-approver23.04.0.r336.ge5115f0-123.04.2.r336.ge5115f0-1
telepathy-kde-auth-handler23.04.0.r317.gfbadbdc-123.04.2.r317.gfbadbdc-1
telepathy-kde-call-ui23.04.0.r483.gc3f00a3-123.04.2.r483.gc3f00a3-1
telepathy-kde-common-internals23.04.1.r2075.g4f5cb39-123.04.2.r2075.g4f5cb39-1
telepathy-kde-contact-list23.04.0.r1137.g995a78f-123.04.2.r1137.g995a78f-1
telepathy-kde-contact-runner23.04.0.r295.g52d80fe-123.04.2.r295.g52d80fe-1
telepathy-kde-desktop-applets23.04.0.r1038.ge6891d9-123.04.2.r1038.ge6891d9-1
telepathy-kde-filetransfer-handler23.04.0.r257.gacf7572-123.04.2.r257.gacf7572-1
telepathy-kde-integration-module23.04.0.r438.gd9df304-123.04.2.r438.gd9df304-1
telepathy-kde-send-file23.04.0.r270.gf28ca8f-123.04.2.r270.gf28ca8f-1
telepathy-kde-text-ui23.04.0.r2106.g5f3cd61d-123.04.2.r2106.g5f3cd61d-1
umbrello23.04.0.r8678.ga686a0a74-123.04.2.r8679.gde006014d-1
vakzination23.01.0.r73.g6038668-123.01.0.r74.g7ce6f4c-1
vvave 3.0.0.r7.g6f9bed1-1 3.0.0.r8.g26b46cd-1
xdg-desktop-portal-kde5.27.5.r708.gbc247f6-15.27.5.r709.g9053e1f-1
yakuake23.04.0.r969.g89321fe-123.04.2.r970.gb23b734-1
zeroconf-ioslave23.04.0.r394.gd86416e-123.04.2.r394.gd86416e-1
## Testers needed on arm-testing branch
* Run this command to switch branch: `sudo pacman-mirrors -aS testing && sudo pacman -Syyu`. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
[poll type=regular]
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
[/poll]
- [Mirror-Check Service](https://repo.manjaro.org/)
2) any time you launch waydroid, run the following after it has started:
echo “ip route add default via 192.168.250.1” |sudo waydroid shell
