[ARM Stable Update] 2023-11-15 - Kernels, OPI5-Plus, KODI, Plasma, Pipewire, Plasma, Gnome 45
Hello ARM community.
We updated kernels, added intitial support for OPI5-Plus, renewed Plasma and offer other related goodies for you.
Update Announcement
Some highlights:
  • Some Kernels got updated
  • We added initial support for OrangePi 5-Plus
    • development images can be found here
  • Linux-Firmware got updated
  • KODI for RasberryPi got renewed
  • Plasma got updated to 5.27.9
  • Firefox is now at 119.0 and Thunderbird at 115.4.1
  • PipeWire is now at 1.0-rc3
  • KDE Gear got renewed to 23.08.2 and KDE Frameworks is at 5.111.0
  • More updates to Gnome 45.0
    • remember to check your extensions for compability
  • Thunderbird got updated to 115.3.3
  • The usual python and KDE-git updates (which moved to Qt6)
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The PHP package has been updated to 8.2. If you still need 8.1, use php-legacy packages.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes (Wed Nov 1 07:02:27 CET 2023)
  • arm-stable core aarch64: 82 new and 81 removed package(s)
  • arm-stable extra aarch64: 2535 new and 2499 removed package(s)
  • arm-stable kde-unstable aarch64: 325 new and 314 removed package(s)
A full list of all package changes can be found here.
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Donate
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
:arrow_right: 2023-11-15
2023-06-06
If you have a lot of pip/AUR packages to upgrade to Python 3.11
Short version, for experienced users:
[HowTo] Python upgrade: reinstall AUR and pip packages
Long version with full details:
[HowTo] After a Python interpreter upgrade, reinstall non-working Python packages
Many applications (firefox, thunderbird, etc) slow to start on desktops other than Gnome
There is a bug with xdg-desktop-portal-gnome (more details here).
Workaround for gtk-based desktops (including Xfce)
sudo pacman -Rdd xdg-desktop-portal-gnome
sudo pacman -S xdg-desktop-portal-gtk
Workaround for KDE
sudo pacman -S xdg-desktop-portal-kde
Workaround for Lxqt
sudo pacman -S xdg-desktop-portal-lxqt
Workaround for desktops using hyprland
sudo pacman -S xdg-desktop-portal-hyprland
Workaround for desktops using wlroots
sudo pacman -S xdg-desktop-portal-wlr
If you installed python311 from the AUR, you need to uninstall it before running this update.
2023-02-16
Docker 23 not starting
Since the update to Docker 23, upstream is now inforcing new paths for apparmor related stuff. But there has been changes to dependencies yet. So Docker 23 will error on start.
Fix: Install apparmor from the repositories.
2023-01-03
Reduced video playback performance in mpv
There has been reports of video playback performance in mpv has regressed since an update to mpv.
Fix: MPV now needs a vd-lavc-dr=no parameter to play hw acceleration supported 1080p videos smoothly.
Touch input on Firefox with Phosh not working in Firefox 108
Since the update to Firefox 108, the touch input does not work. Seems to be an issue with a couple of the changes the mobile-config brings in. PostMarketOS likely won’t fix this in their source, so we might need to carry a patch for this.
2022-11-20
OpenSSL 1.1 library not found
Some applications might still be looking for openssl 1.1.
Solution: Install openssl-1.1 package with sudo pacman -S openssl-1.1.
2022-10-31
Firefox shows wrong colors when playing video on Raspberry Pi 4
Since Mesa 22.2, Firefox has been showing weird colors when playing video on the Raspberry Pi 4. This is caused by an issue in upstream mesa, which was recently fixed.
Fix: Update to mesa 22.2.3-0.1 in the repository, which includes this fix.
Chromium in Wayland crashes with --in-process-gpu
Since Mesa 22.2.0, Chromium running in wayland sessions seems to crash when running with the --in-process-gpu option. Running in X11 seems fine, although it’s slow.
Fix: Update to Mesa 22.3.2 was reported to work here.
2022-10-21
Plasma Mobile Dialer seems to be unreliable
Plasma Dialer 22.09 seems to have issues switching audio profiles and as such might require manual switching. Sometimes audio is completely missing.
Reduced video performance on youtube
Some may encounter reduced video playback performance on YouTube in Firefox with the new Mesa 22.2 drivers.
No workaround at this time.
Old Issues
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
[Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
```Hello ARM community,
this is my fourth **stable** update for our aarch64 architecture.
Most already know that we had some staff changes in our Manjaro ARM team. You might already have noticed that Dan [left the team](https://blog.strits.dk/i-no-longer-work-for-manjaro/) and the company. Therefore we have also to see when the next install medias for ARM SBCs and devices will been created. Dan did a lot for the ARM branch of Manjaro, including endless testing of boards and devices. Before releasing any image for an ARM device it needs to been tested on the device itself. You can find untested [development builds](https://github.com/orgs/manjaro-arm/repositories) at github.
Therefore I'll act as the interim release manager until we found the right staff member for this job.
## Donate
Manjaro, like many other open-source projects, relies on the generosity of its community through [donations](https://manjaro.org/donate/) and corporate sponsorships to support its growth and development. These [donations](https://manjaro.org/donate/) are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or [conferences](https://blog.manjaro.org/fosdem-2023/) and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to [donate](https://manjaro.org/donate/)!
## Update Announcement
With this update we have mostly updates to [Apple Silicon](https://gitlab.manjaro.org/manjaro-arm/packages/apple-silicon) and mobile.
*Some highlights:*
- Some **Kernels** got renewed
- **Apple-Silicon** packages got renewed to the latest issued by Asahi Linux. [Graphic stack](https://asahilinux.org/2023/06/opengl-3-1-on-asahi-linux/) got improved a lot. However, our installer is still internal
- **Calls** is now at [44.2](https://gitlab.gnome.org/GNOME/calls/-/raw/91e5cad939f6753bc232c8990be295b068473949/debian/changelog)
- the app **vakzination** got rebuild to fix so-file issues
- **libpamac** got renewed to [11.5.4](https://gitlab.manjaro.org/applications/libpamac/-/tags/11.5.4)
- Usual **KDE-git** updates
*End Of Life kernels (will be removed from repo soon):*
* `linux60` (EOL on 2023-01-12) (removed from repository)
## Tips And Tricks
[details="Error about missing openssl 1.1 library"]
Fortunately Arch Linux created a compatability package for such events called `openssl-1.1`.
Applications currently known to specifically look for 1.1 is `silver`. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install `openssl-1.1` as part of this update.
[/details]
[details="How to get Waydroid working"]
*Remember, Waydroid only works on wayland!*
* Install `waydroid-image` and all it's dependencies.
* Run `pkexec setup-waydroid`.
* You should now be able to launch Waydroid. The first launch takes a while.
[/details]
[details="How to use Kodi RPI on Manjaro ARM"]
`sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev`
### Have it set up is to boot straight in to kodi
`sudo systemctl disable lightdm.service`
`sudo systemctl enable kodi.service`
over_voltage=5
arm_freq=2000
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
Some notes:
[/details]
## Upstream Notifications:
[details="Older notifications"]
The PHP package has been updated to 8.2. If you still need 8.1, use `php-legacy` packages.
https://archlinux.org/news/php-82-update-and-introduction-of-legacy-branch/
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to `libxcrypt`:
https://archlinux.org/news/sorting-out-old-password-hashes/
The `ghostpcl` and `ghostxps` requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The `nss` package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages `hplip` and `firewalld` requires manual intervention:
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
[/details]
## Package Changes (Fri May 19 13:30:34 CEST 2023)
 - arm-stable community aarch64:  20 new and 20 removed package(s)
 - arm-stable core aarch64:  24 new and 23 removed package(s)
 - arm-stable extra aarch64:  4 new and 4 removed package(s)
 - arm-stable kde-unstable aarch64:  289 new and 289 removed package(s)
:: Different overlay package(s) in repository community aarch64
                         PACKAGE           2023.06.09           2023.06.12
           apple-silicon-configs           20221206-1           20230517-1
                 asahi-fwextract            0.5pre2-3              0.5.4-1
                   asahi-scripts           20221206-1           20230606-2
                       bitwarden           2023.5.0-1           2023.5.0-2
                      callaudiod              0.1.9-1              0.1.9-2
                            code             1.78.2-1             1.79.0-1
                        electron             23.1.2-1             23.3.6-1
                      electron20            20.3.11-1                    -
                      electron21             21.4.2-1             21.4.4-1
                      electron22             22.3.2-1            22.3.12-1
                     gnome-calls               44.1-2               44.2-1
              gnome-shell-mobile44.0+r283+g034144c20-144.1+r326+g9b7df11f1-1
         mesa-apple-silicon-edge 23.1.0_pre20230311-1 23.2.0_pre20230606-1
   mesa-apple-silicon-edge-debug 23.1.0_pre20230311-1 23.2.0_pre20230606-1
                   mutter-mobile44.0+r88+g780aadd4e-244.1+r191+g5e72de83d-2.0
                           phosh             0.28.0-10.28.0+13+g31896512-1
                  phosh-antispam              3.2.0-2              3.3.0-1
                     vakzination            23.01.0-1            23.01.0-2
vulkan-swrast-apple-silicon-edge 23.1.0_pre20230311-1 23.2.0_pre20230606-1
                    wire-desktop          3.30.3018-1          3.31.3060-1
                      electron24                    -             24.5.0-1
:: Different overlay package(s) in repository core aarch64
                           linux              6.3.5-1              6.3.7-1
                       linux-aml             6.1.31-1             6.1.33-1
               linux-aml-headers             6.1.31-1             6.1.33-1
             linux-apple-silicon                6.2-1                6.3-1
        linux-apple-silicon-edge                6.2-1                6.3-1
     linux-apple-silicon-headers                6.2-1                6.3-1
                   linux-headers              6.3.5-1              6.3.7-1
                       linux-lts             6.1.31-1             6.1.33-1
               linux-lts-headers             6.1.31-1             6.1.33-1
                 linux-pinephone              6.3.5-1              6.3.7-1
         linux-pinephone-headers              6.3.5-1              6.3.7-1
              linux-pinephonepro              6.3.5-1              6.3.7-1
      linux-pinephonepro-headers              6.3.5-1              6.3.7-1
                      linux-rpi4             6.1.31-1             6.1.32-1
              linux-rpi4-headers             6.1.31-1             6.1.32-1
             linux-rpi4-mainline              6.3.5-1              6.3.6-1
     linux-rpi4-mainline-headers              6.3.5-1              6.3.6-1
                   linux-rpi4-rc            6.4.rc4-1            6.4.rc5-1
           linux-rpi4-rc-headers            6.4.rc4-1            6.4.rc5-1
                            m1n1              1.2.6-1              1.2.9-1
             uboot-apple-silicon            2023.01-1            2023.04-1
              uboot-pinephonepro     5:2023.07rc2-0.3     5:2023.07rc2-0.4
     uboot-pinephonepro-rockchip     5:2023.07rc2-0.3     5:2023.07rc2-0.4
                uboot-odroid-n2l                    -            2023.04-1
:: Different overlay package(s) in repository extra aarch64
                        libpamac             11.5.3-1             11.5.4-1
         libpamac-flatpak-plugin             11.5.3-1             11.5.4-1
            libpamac-snap-plugin             11.5.3-1             11.5.4-1
                           snapd             2.59.5-1             2.59.5-2
:: Different overlay package(s) in repository kde-unstable aarch64
                         akonadi23.04.1.r13076.g84e914c45-123.04.2.r13076.g84e914c45-1
                akonadi-calendar23.04.1.r2364.g2c16022-123.04.2.r2364.g2c16022-1
          akonadi-calendar-tools23.04.0.r1047.g7a009d5-123.04.2.r1050.g9ba89ef-1
                akonadi-contacts23.04.1.r3474.gc4e5f229-123.04.2.r3474.gc4e5f229-1
           akonadi-import-wizard23.04.1.r1941.g5abcbc9-123.04.2.r1941.g5abcbc9-1
                    akonadi-mime23.04.1.r1873.gae00608-123.04.2.r1874.gf4c29c4-1
                   akonadi-notes23.04.1.r1169.gb451bbe-123.04.2.r1169.gb451bbe-1
                  akonadi-search23.04.1.r1395.gc9cd29c-123.04.2.r1397.gfd9883c-1
                  akonadiconsole23.04.0.r1747.g17f7951-123.04.2.r1748.gb566587-1
                       akregator23.04.0.r6725.g3b691ed9-123.04.2.r6726.g5325284a-1
                        analitza23.04.1.r2396.gb2b30fe1-123.04.2.r2396.gb2b30fe1-1
                             ark23.04.0.r5088.g2a7f46b3-123.04.2.r5090.g5033a623-1
                      artikulate23.04.1.r1522.g9344e4f-123.04.2.r1522.g9344e4f-1
                     audiocd-kio23.04.1.r1206.ge338398-123.04.2.r1208.g061a22c-1
                           baloo5.106.0.r3244.geafae07a-15.106.0.r3245.g9755144d-1
                   baloo-widgets23.04.1.r878.g2e8ea3c-123.04.2.r878.g2e8ea3c-1
                         blinken23.04.1.r740.g6d13ea0-123.04.2.r740.g6d13ea0-1
                       bluedevil1:5.27.5.r2612.ge033d939-11:5.27.5.r2613.gb31f376a-1
                          bomber23.04.1.r636.g7e6e493-123.04.2.r636.g7e6e493-1
                            bovo23.04.1.r857.ga9f1dbe-123.04.2.r857.ga9f1dbe-1
                          breeze5.27.5.r2628.g5d279205-15.27.5.r2629.g4afc46e7-1
                            buho  3.0.0.r5.gec42169-1  3.0.0.r6.ga4c2c66-1
                 calendarsupport23.04.0.r849.gde62582-123.04.2.r849.gde62582-1
                          cantor23.04.1.r3600.g19ed0b66-123.04.2.r3603.gdbbd804e-1
                        cervisia23.04.0.r1778.g9b84f0b-123.04.2.r1779.gefbddbb-1
                        discover5.27.5.r9333.gc4c0ad257-15.27.5.r9335.g725681901-1
                         dolphin23.04.1.r7416.ge5abe2c67-123.04.2.r7417.gbb08c70a9-1
                 dolphin-plugins23.04.0.r760.gb6391fd-123.04.2.r761.g1abd322-1
                          dragon23.04.1.r1194.g8f5664a-123.04.2.r1196.g94b6111-1
                         drkonqi5.27.5.r930.g8cb1aea1-15.27.5.r931.g9c42ce25-1
                           elisa23.04.1.r3313.g2ebf6bd6-123.04.2.r3320.g8d11cf2f-1
                      elisa-qtmm23.04.1.r3313.g2ebf6bd6-123.04.2.r3320.g8d11cf2f-1
                      eventviews23.04.0.r1026.g54d1d27-123.04.2.r1028.gdd65a38-1
                    ffmpegthumbs23.04.1.r263.g8a8b7c2-123.04.2.r263.g8a8b7c2-1
                       filelight23.04.0.r1408.g2f2b5a1-123.04.2.r1410.g253b29d-1
                       granatier23.04.1.r1051.g5e93a6c-123.04.2.r1051.g5e93a6c-1
                 grantlee-editor23.04.0.r941.gb634afb-123.04.2.r941.gb634afb-1
                   grantleetheme23.04.1.r504.g1f1c47b-123.04.2.r504.g1f1c47b-1
                        gwenview23.04.1.r7161.ga483380d-123.04.1.r7164.g47e8bdb0-1
                 incidenceeditor23.04.1.r1050.g7b9c8a1-123.04.2.r1051.g7c3d773-1
                       itinerary23.04.0.r2712.g01b4fc49-123.04.2.r2715.gae36bdb6-1
                             juk23.04.1.r3265.g77d80714-123.04.2.r3266.gf840340e-1
                             k3b1:23.04.1.r6998.g1cf60e813-11:23.04.2.r6999.g329361b61-1
           kaccounts-integration23.04.1.r1364.gbf22267-223.04.2.r1364.gbf22267-1
             kaccounts-providers23.04.1.r443.g3e40fe3-123.04.2.r443.g3e40fe3-1
               kactivitymanagerd5.27.5.r1462.g861f9de-15.27.5.r1463.gd454806-1
                    kaddressbook23.04.1.r6417.g5c6a2248-123.04.2.r6420.gbc60dd46-1
                         kajongg23.04.1.r4419.gdcdf2ee5-123.04.2.r4422.g451e34a3-1
                          kalarm23.04.0.r8339.g365a6581-123.04.2.r8395.g124644f6-1
                        kalgebra23.04.1.r2162.g0ded608-123.04.2.r2162.g0ded608-1
                         kalzium23.04.1.r4512.ge103ed83-123.04.2.r4516.g80a9ab41-1
                          kamera23.04.1.r828.gd491cfd-123.04.2.r828.gd491cfd-1
                          kamoso23.04.0.r1557.ga018c91-123.04.2.r1557.ga018c91-1
                        kanagram23.04.1.r1406.gbc68a1f-123.04.2.r1406.gbc68a1f-1
                          kapman23.04.1.r734.gc63a2da-123.04.2.r734.gc63a2da-1
                    kapptemplate23.04.0.r1063.g5fded2a-123.04.2.r1063.g5fded2a-1
                           kasts23.01.0.r165.gb1d8d47-123.01.0.r168.g21952c6-1
                            kate23.04.0.r20721.gd208dfe5a-123.04.2.r20730.geefd3ba2d-1
                         katomic23.04.1.r1046.g9ed1b51-123.04.2.r1046.g9ed1b51-1
                         kbackup23.04.0.r544.g81bfeb6-123.04.2.r544.g81bfeb6-1
                       kblackbox23.04.1.r846.gb0bfda4-123.04.2.r847.gdc37f08-1
                         kblocks23.04.1.r826.g2447c84-123.04.2.r826.g2447c84-1
                      kbookmarks5.106.0.r535.g5dd2497-15.106.0.r536.g60642fc-1
                         kbounce23.04.1.r932.gc80ffc9-123.04.2.r932.gc80ffc9-1
                       kbreakout23.04.1.r999.gbfe0cbd-123.04.2.r999.gbfe0cbd-1
                          kbruch23.04.1.r956.g4a4b7e8-123.04.2.r956.g4a4b7e8-1
                     kcachegrind23.04.0.r1278.g5cbbd88-123.04.2.r1281.gbf373a0-1
              kcachegrind-common23.04.0.r1278.g5cbbd88-123.04.2.r1281.gbf373a0-1
                           kcalc23.04.0.r1736.ga499fae-123.04.2.r1736.ga499fae-1
                       kcalutils23.04.1.r1084.gf8302135f-123.04.2.r1084.gf8302135f-1
                     kcharselect23.04.0.r625.g019cf4f-123.04.2.r625.g019cf4f-1
                          kclock23.01.0.r72.g6533949-123.01.0.r74.g352cc69-1
                        kcmutils5.106.0.r752.g861104da-15.106.0.r754.g9772c61d-1
                   kcolorchooser23.04.1.r337.gde9049d-123.04.2.r337.gde9049d-1
                         kconfig5.106.0.r1082.g1b47e6c3-15.106.0.r1083.g3c6d59de-1
                       kcontacts1:5.106.0.r3432.g80b99ae8-11:5.106.0.r3433.g729e4154-1
                           kcron23.04.0.r907.g9637eb7-123.04.2.r907.g9637eb7-1
                   kde-cli-tools5.27.5.r2130.ge8132be-15.27.5.r2133.g1787873-1
                 kde-dev-scripts23.04.0.r4182.gbd504fa-123.04.2.r4182.gbd504fa-1
                   kde-dev-utils23.04.0.r663.g74eae5a-123.04.2.r666.g0d5e900-1
                  kdebugsettings23.04.0.r1367.g2b9cccc-123.04.2.r1368.gba99146-1
                      kdeconnect23.04.0.r3842.gdf9be7e6-123.04.2.r3849.g4ef7c262-1
                     kdeedu-data23.04.1.r22.g793df3b-123.04.2.r22.g793df3b-1
          kdegraphics-mobipocket23.04.1.r290.g16b2e58-123.04.2.r290.g16b2e58-1
        kdegraphics-thumbnailers23.04.1.r295.g3da9b35-123.04.2.r297.g9dbad70-1
                 kdelibs4support5.106.0.r1205.g6356e0ee-15.106.0.r1206.ga4526feb-1
          kdenetwork-filesharing23.04.0.r1094.gdc7ac35-123.04.2.r1094.gdc7ac35-1
                        kdenlive23.04.0.r18149.gc00260e0d-123.04.2.r18192.g6154d791d-1
                   kdepim-addons23.04.0.r5271.g0cc67708c-123.04.2.r5272.g9f5ee3de1-1
                  kdepim-runtime23.04.1.r15928.gea73e40e2-123.04.2.r15929.ge2729f0ab-1
                kdeplasma-addons5.27.5.r9399.gb86d9f13b-15.27.5.r9401.gdeff16fd2-1
                kdesdk-kioslaves23.04.0.r505.g1f7909e-123.04.2.r505.g1f7909e-1
             kdesdk-thumbnailers23.04.0.r133.g989c6a3-123.04.2.r135.gbc52836-1
                             kdf23.04.0.r976.g86e7b91-123.04.2.r976.g86e7b91-1
                         kdialog23.04.0.r1365.g0fe2062c1-123.04.2.r1366.g0832b04ba-1
                        kdiamond23.04.1.r798.gcc46502-123.04.2.r799.g7596172-1
                  keditbookmarks23.04.0.r2838.ga35a913a2-123.04.2.r2841.ga0c18fdc0-1
                        keysmith23.01.0.r64.gb6f41d9-123.01.0.r65.ge941e7e-1
                   kfilemetadata5.106.0.r973.g7c395e2-15.106.0.r976.g53923f5-1
                           kfind23.04.0.r2820.g86338ab1e-123.04.2.r2821.g789620dbc-1
                         kfloppy23.04.0.r874.g96209b6-123.04.2.r875.gf2f65d2-1
                     kfourinline23.04.1.r1108.g0461ef3-123.04.2.r1108.g0461ef3-1
                      kgeography23.04.1.r1255.g7d31981-123.04.2.r1255.g7d31981-1
                            kget23.04.0.r3369.g22d0c200-123.04.2.r3370.g179d7f65-1
                    kglobalaccel5.106.0.r663.g659f251-15.106.0.r664.gc538ad5-1
                     kgoldrunner23.04.1.r1380.g1aa9eee-123.04.2.r1382.gb59d5d2-1
                        khangman23.04.1.r1700.g5d32616-123.04.2.r1700.g5d32616-1
                     khelpcenter23.04.0.r2896.g2d2d1f04-123.04.2.r2899.ge7acf8e8-1
                        khotkeys5.27.5.r2245.g85c7f71-15.27.5.r2246.gb2a103e-1
                           khtml5.106.0.r682.g121f508-15.106.0.r683.g14a5880-1
                     kiconthemes5.106.0.r702.ga973b2a-15.106.0.r703.gcc16d7d-1
             kidentitymanagement23.04.1.r4007.g36e0f760-123.04.2.r4008.gcb17bd07-1
                             kig23.04.1.r3343.g58ce31b1-123.04.2.r3345.g046a3f87-1
                            kigo23.04.1.r659.ge608c95-123.04.2.r660.gd1de2ff-1
                        killbots23.04.1.r873.ge3deff6-123.04.2.r875.gdec0ee7-1
                 kimagemapeditor23.04.1.r584.ge06fa84-123.04.2.r586.g0bf89e6-1
                           kimap23.04.1.r1301.ge04dd9b-123.04.2.r1301.ge04dd9b-1
                     kinfocenter5.27.5.r2383.g18c0d4d0-15.27.5.r2386.g8d0d365c-1
                             kio5.106.0.r6191.g0e6c01e0c-15.106.0.r6196.g811fae761-1
                      kio-extras23.04.0.r7573.g6950463ed-123.04.2.r7575.g0680a0462-1
                      kio-gdrive23.04.0.r725.g39de711-123.04.2.r725.g39de711-1
                 kirigami-addons1:0.8.0.r47.g3604f34-11:0.8.0.r49.gcf3d908-1
                kirigami-gallery23.04.0.r353.gb960590-123.04.2.r353.gb960590-1
                       kirigami25.106.0.r3710.g21106c6e-15.106.0.r3713.g74155121-1
                          kiriki23.04.1.r533.g282d39b-123.04.2.r534.g7e28ff1-1
                     kitemmodels5.106.0.r649.g736563f-15.106.0.r650.g0952af4-1
                           kiten23.04.1.r1286.g11f5f88-123.04.2.r1286.g11f5f88-1
                      kitinerary23.04.1.r2949.gc43adca3-123.04.2.r2957.gf62f9635-1
                    kjumpingcube23.04.1.r917.gcd4e342-123.04.2.r917.gcd4e342-1
                           kldap23.04.1.r1092.g385db87-123.04.2.r1092.g385db87-1
                       kleopatra23.04.0.r7300.ge249c30e-123.04.2.r7308.g8cbe0a3d-1
                        klettres23.04.1.r1050.ga7614e7-123.04.2.r1050.ga7614e7-1
                        klickety23.04.1.r775.g8f86b24-123.04.2.r775.g8f86b24-1
                          klines23.04.1.r893.g05309f8-123.04.2.r894.g7c56c56-1
                            kmag23.04.1.r819.gc83e844-123.04.2.r819.gc83e844-1
                       kmahjongg23.04.1.r1664.g1390305-123.04.2.r1665.g515b2d5-1
                           kmail23.04.0.r27005.g05f2056d5-123.04.2.r27037.g58218c12c-1
            kmail-account-wizard23.04.0.r985.ge4a7cf5-123.04.2.r985.ge4a7cf5-1
                  kmailtransport23.04.1.r1937.g588a092-123.04.2.r1938.g5961f5b-1
                           kmbox23.04.1.r653.gf9238bc-123.04.2.r653.gf9238bc-1
                       kmenuedit5.27.5.r1180.g3ed6ce1-15.27.5.r1181.g0e27bea-1
                           kmime23.04.1.r1629.ga926427-123.04.2.r1629.ga926427-1
                          kmines23.04.1.r1845.g02b3b61-123.04.2.r1845.g02b3b61-1
                            kmix23.04.0.r2556.g2f7272a2-123.04.2.r2582.g1d516924-1
                      kmousetool23.04.1.r523.g55db80d-123.04.2.r524.g2d95fcf-1
                          kmouth23.04.1.r829.g82e5da8-123.04.2.r830.gdd57bdd-1
                          kmplot23.04.1.r1593.g76d6ade-123.04.2.r1594.gf6720cc-1
                    knavalbattle23.04.1.r1514.gde963e6-123.04.2.r1514.gde963e6-1
                        knetwalk23.04.1.r788.g017a27e-123.04.2.r788.g017a27e-1
                       knewstuff5.106.0.r1552.g5bf8c87f-15.106.0.r1554.gb67db719-1
                         knights23.04.1.r1243.ga2b1ca6-123.04.2.r1243.ga2b1ca6-1
                          knotes23.04.0.r3917.gc00720f7-123.04.2.r3918.gb55dded6-1
                            kolf23.04.1.r1604.gce02248-123.04.2.r1604.gce02248-1
                       kollision23.04.1.r606.ga16e446-123.04.2.r606.ga16e446-1
                     kolourpaint23.04.1.r2534.g3c112dc4-123.04.2.r2536.g4b279d88-1
                         kompare23.04.0.r1285.geebb3f3-123.04.2.r1287.g4bce7f2-1
                       konqueror23.04.0.r15448.g3e8624be9-123.04.2.r15452.g4cd673089-1
                        konquest23.04.1.r1021.gc3687c4-123.04.2.r1021.gc3687c4-1
                         konsole23.04.0.r9075.g95bcf2e0a-123.04.2.r9082.g73d067991-1
                         kontact23.04.0.r5767.g2c999500-123.04.2.r5767.g2c999500-1
                kontactinterface23.04.1.r791.gfca2805-123.04.2.r791.gfca2805-1
                        kontrast23.04.1.r319.gfd12f26-123.04.2.r319.gfd12f26-1
                    konversation23.04.0.r9297.g2379a978-123.04.2.r9297.g2379a978-1
                   kopeninghours23.04.1.r391.gfae8220-123.04.2.r391.gfae8220-1
                          kopete23.04.0.r16568.g7b7a0f0c9-123.04.2.r16570.ga053f12a8-1
                      korganizer23.04.0.r12137.g194a9f057-123.04.2.r12137.g194a9f057-1
                   kosmindoormap23.04.1.r1010.g90a71f2-123.04.2.r1010.g90a71f2-1
                            kpat23.04.1.r2756.g24dba31f-123.04.2.r2756.g24dba31f-1
                    kpimtextedit23.04.1.r1874.g5c1eaaa-123.04.2.r1901.ge91a512-1
                         kpkpass23.04.1.r348.ge38d0dd-123.04.2.r348.ge38d0dd-1
                         kpmcore23.04.1.r1374.g992174e-123.04.2.r1375.g6640766-1
                kpublictransport23.04.1.r2179.g231e3f02-123.04.2.r2180.g8b7136a5-1
                  kqtquickcharts23.04.1.r78.g22ff9c9-123.04.2.r78.g22ff9c9-1
                            krdc23.04.0.r1721.g4d6fa90-123.04.2.r1721.g4d6fa90-1
                        kreversi23.04.1.r1353.gd7e11ea-123.04.2.r1353.gd7e11ea-1
                            krfb23.04.0.r1578.gf2fc9ca-123.04.2.r1578.gf2fc9ca-1
              kross-interpreters23.04.0.r725.gdef2cfe-123.04.2.r725.gdef2cfe-1
                          kruler23.04.1.r852.g9b1eff8-123.04.2.r852.g9b1eff8-1
                         kshisen23.04.1.r1342.g1117378-123.04.2.r1343.gc44c7f9-1
                           ksirk23.04.1.r1141.g8fb1bae-123.04.2.r1142.gf1b7179-1
                           ksmtp23.04.1.r532.g0b9c77f-123.04.2.r532.g0b9c77f-1
                      ksnakeduel23.04.1.r929.g2ef8918-123.04.2.r929.g2ef8918-1
                      kspaceduel23.04.1.r740.gfb3d585-123.04.2.r740.gfb3d585-1
                        ksquares23.04.1.r658.g090ed62-123.04.2.r658.g090ed62-1
                         ksudoku23.04.1.r1202.g30027d1-123.04.2.r1203.ge15bbbe-1
                      ksystemlog23.04.0.r855.g7139f9e-123.04.2.r856.g17b7432-1
                        kteatime23.04.0.r831.g5c745f8-123.04.2.r832.g1a85fd8-1
                     ktextaddons      r481.g1030c42-1      r483.g85d7867-1
                     ktexteditor5.106.0.r3833.gd8abfb98-15.106.0.r3834.gf3e43910-1
                          ktimer23.04.0.r596.g5430a02-123.04.2.r596.g5430a02-1
                           ktnef23.04.1.r816.g405852e-123.04.2.r817.g04882d2-1
                        ktorrent23.04.0.r2990.g519d9ec6-123.04.2.r2994.g1b0408e0-1
                          ktouch23.04.1.r2269.gd0a1621-123.04.2.r2273.gd2d25550-1
                           ktrip23.01.0.r26.g1befab2-123.01.0.r30.g0122db5-1
                      ktuberling23.04.1.r1163.g9378253-123.04.2.r1163.g9378253-1
                         kturtle23.04.1.r1273.gb6e55e2-123.04.2.r1274.g0ebcf61-1
                         kubrick23.04.1.r490.ge5163ce-123.04.2.r491.gb6c8628-1
                  kwalletmanager23.04.0.r1464.g6a4a01b-123.04.2.r1464.g6a4a01b-1
                           kwave23.04.0.r3882.g8e97359f-123.04.2.r3883.g2a03ba6d-1
                        kwayland5.106.0.r1212.g25e86ba-15.106.0.r1213.g6f31cb0-1
                  kwidgetsaddons5.106.0.r1097.g64c59987-15.106.0.r1098.ga70ee848-1
                            kwin5.27.5.r24236.g5a9cfe174a-15.27.5.r24241.g3cf71114cb-1
                       kwordquiz23.04.1.r1319.g5ffc9f9-123.04.2.r1320.g73a22e3-1
                          kwrite23.04.0.r20721.gd208dfe5a-123.04.2.r20730.geefd3ba2d-1
                         kxmlgui5.106.0.r1006.g52234202-15.106.0.r1007.gb507bcd9-1
                      libakonadi23.04.1.r13076.g84e914c45-123.04.2.r13076.g84e914c45-1
                     libgravatar23.04.1.r519.gb7fcd18-123.04.2.r519.gb7fcd18-1
                        libkcddb23.04.1.r850.g0c12974-123.04.2.r851.ga26e08a-1
                 libkcompactdisc23.04.1.r437.g16014b8-123.04.2.r437.g16014b8-1
                       libkdcraw23.04.1.r1160.g580849c-123.04.2.r1160.g580849c-1
                     libkdegames23.04.1.r2335.g052d0506-123.04.2.r2336.gd8f0a978-1
                       libkdepim23.04.1.r1005.g73e26e7-123.04.2.r1005.g73e26e7-1
              libkeduvocdocument23.04.1.r1857.g1f4c062-123.04.2.r1857.g1f4c062-1
                       libkexiv223.04.1.r843.g68c21bb-123.04.2.r843.g68c21bb-1
                        libkgapi23.04.1.r1575.ge3db7440-123.04.2.r1575.ge3db7440-1
                         libkipi23.04.1.r1289.g8cacdbb-123.04.2.r1289.g8cacdbb-1
                         libkleo23.04.1.r1528.g7f9e67d-123.04.2.r1530.gdfe3d6b-1
                    libkmahjongg23.04.1.r532.g735eefe-123.04.2.r532.g735eefe-1
                 libkomparediff223.04.1.r406.ge391412-123.04.2.r406.ge391412-1
                        libksane23.04.1.r657.g70a8a78-123.04.2.r657.g70a8a78-1
                       libksieve23.04.1.r1911.gb2d65ed4-123.04.2.r1912.g9c6669e6-1
                     libktorrent23.04.1.r604.g5eb5b48-123.04.2.r604.g5eb5b48-1
                        lokalize23.04.0.r2041.gf1d105e8-123.04.2.r2042.g8fbd5973-1
                           lskat23.04.1.r935.g9ea5ee9-123.04.2.r935.g9ea5ee9-1
                      mailcommon23.04.1.r1490.g5da6718-123.04.2.r1491.g3eaf59e-1
                    mailimporter23.04.1.r628.g18495f3-123.04.2.r628.g18495f3-1
                          marble23.04.1.r13685.g579881495-123.04.2.r13688.gc59f6e9c3-1
                   marble-common23.04.1.r13685.g579881495-123.04.2.r13688.gc59f6e9c3-1
                       marble-qt23.04.1.r13685.g579881495-123.04.2.r13688.gc59f6e9c3-1
                    markdownpart23.04.0.r208.g3c2e1ad-123.04.2.r208.g3c2e1ad-1
                         mauikit 3.0.0.r5.gf252a3be-1 3.0.0.r6.g41bf0289-1
            mauikit-filebrowsing 2.2.2.r53.g41625fa-1 2.2.2.r54.g0550cee-1
                   mbox-importer23.04.0.r651.g97d40f2-123.04.2.r651.g97d40f2-1
                      messagelib23.04.1.r7166.g516798438-123.04.2.r7168.gee6a11b8f-1
                          minuet23.04.1.r700.gfe37472-123.04.2.r700.gfe37472-1
                         neochat23.01.0.r424.gb5c781212-123.01.0.r446.g7c75a2fd0-1
                          okular23.04.1.r10109.g57f5c6933-123.04.2.r10118.gd78752ea3-1
                          oxygen5.27.5.r4586.g91d4055f-15.27.5.r4588.g4b77ceb9-1
                        palapeli23.04.1.r1396.g8e47257-123.04.2.r1396.g8e47257-1
                          parley23.04.1.r4622.g5ab4330b-123.04.2.r4622.g5ab4330b-1
                partitionmanager23.04.0.r1810.g58e6465-123.04.2.r1810.g58e6465-1
                           picmi23.04.1.r640.gcf33236-123.04.2.r640.gcf33236-1
               pim-data-exporter23.04.0.r2921.gfe05d2a1-123.04.2.r2921.gfe05d2a1-1
                pim-sieve-editor23.04.0.r1786.gca81f38-123.04.2.r1786.gca81f38-1
                       pimcommon23.04.0.r2111.ge11b2f04-123.04.2.r2112.g65d25789-1
                   plasma-camera  1.0.r173.g9972dc5-1  1.0.r175.gaa98c44-1
                  plasma-desktop5.27.5.r10256.g344a69a38-15.27.5.r10260.g30bf5d7d7-1
                 plasma-firewall5.27.5.r737.g4a94a16-15.27.5.r738.g4be5574-1
                   plasma-mobile5.27.5.r2229.g8de183099-15.27.5.r2231.g5f81c766d-1
                plasma-mobile-nm5.27.5.r3616.g6d6314e9-15.27.5.r3617.gdf2d73b9-1
                       plasma-nm5.27.5.r3616.g6d6314e9-15.27.5.r3617.gdf2d73b9-1
                       plasma-pa5.27.5.r1235.g5a5d6b8-15.27.5.r1236.g6282ef8-1
                plasma-phonebook23.01.0.r65.g93c377b-123.01.0.r69.g4c89eef-1
                      plasma-sdk5.27.5.r2514.gcb01a3dc-15.27.5.r2517.gfd4eb174-1
            plasma-systemmonitor5.27.5.r736.g4a23fb6-15.27.5.r738.g009565c-1
                    plasma-vault5.27.5.r451.gf48f354-15.27.5.r452.gc5577ab-1
          plasma-wayland-session5.27.5.r13443.g6de6467f1-15.27.5.r13450.g3672104c7-1
                plasma-workspace5.27.5.r13443.g6de6467f1-15.27.5.r13450.g3672104c7-1
                      powerdevil5.27.5.r2737.gb6aea53e-15.27.5.r2741.g7740e71c-1
                           poxml23.04.0.r290.ge730008-123.04.2.r290.ge730008-1
                   print-manager23.04.0.r1280.g3f40324-123.04.2.r1280.g3f40324-1
                     qcachegrind23.04.0.r1278.g5cbbd88-123.04.2.r1281.gbf373a0-1
                            rocs23.04.1.r3193.g2e016f81-123.04.2.r3193.g2e016f81-1
                            sddm0.19.0.r230.g9a07cf0-10.19.0.r231.g40250a6-1
        signon-kwallet-extension23.04.1.r85.g2d8eb31-123.04.2.r85.g2d8eb31-1
                        spacebar23.01.0.r69.g1c98873-123.01.0.r70.gb07b3fa-1
                       spectacle23.04.1.r1759.g862d435-123.04.2.r1761.g8e3afdd-1
                            step23.04.1.r1338.g8d3252b-123.04.2.r1338.g8d3252b-1
                         svgpart23.04.1.r286.g152c942-123.04.2.r286.g152c942-1
                         sweeper23.04.0.r645.g61bef39-123.04.2.r645.g61bef39-1
             syntax-highlighting5.106.0.r2149.gb1306e94-15.106.0.r2150.gef98ada2-1
      telepathy-kde-accounts-kcm23.04.0.r1266.g8bb97ee-123.04.2.r1267.g06f990b-1
          telepathy-kde-approver23.04.0.r336.ge5115f0-123.04.2.r336.ge5115f0-1
      telepathy-kde-auth-handler23.04.0.r317.gfbadbdc-123.04.2.r317.gfbadbdc-1
           telepathy-kde-call-ui23.04.0.r483.gc3f00a3-123.04.2.r483.gc3f00a3-1
  telepathy-kde-common-internals23.04.1.r2075.g4f5cb39-123.04.2.r2075.g4f5cb39-1
      telepathy-kde-contact-list23.04.0.r1137.g995a78f-123.04.2.r1137.g995a78f-1
    telepathy-kde-contact-runner23.04.0.r295.g52d80fe-123.04.2.r295.g52d80fe-1
   telepathy-kde-desktop-applets23.04.0.r1038.ge6891d9-123.04.2.r1038.ge6891d9-1
telepathy-kde-filetransfer-handler23.04.0.r257.gacf7572-123.04.2.r257.gacf7572-1
telepathy-kde-integration-module23.04.0.r438.gd9df304-123.04.2.r438.gd9df304-1
telepathy-kde-send-file23.04.0.r270.gf28ca8f-123.04.2.r270.gf28ca8f-1
telepathy-kde-text-ui23.04.0.r2106.g5f3cd61d-123.04.2.r2106.g5f3cd61d-1
umbrello23.04.0.r8678.ga686a0a74-123.04.2.r8679.gde006014d-1
vakzination23.01.0.r73.g6038668-123.01.0.r74.g7ce6f4c-1
vvave 3.0.0.r7.g6f9bed1-1 3.0.0.r8.g26b46cd-1
xdg-desktop-portal-kde5.27.5.r708.gbc247f6-15.27.5.r709.g9053e1f-1
yakuake23.04.0.r969.g89321fe-123.04.2.r970.gb23b734-1
zeroconf-ioslave23.04.0.r394.gd86416e-123.04.2.r394.gd86416e-1
## Testers needed on arm-testing branch
* Run this command to switch branch: `sudo pacman-mirrors -aS testing && sudo pacman -Syyu`. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
[poll type=regular]
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
[/poll]
- [Mirror-Check Service](https://repo.manjaro.org/)
2) any time you launch waydroid, run the following after it has started:
echo ā€œip route add default via 192.168.250.1ā€ |sudo waydroid shell
Conflicts:
:: Replace knewstuff with extra/knewstuff5? [Y/n]
:: Replace knotifications with extra/knotifications5? [Y/n]
:: Replace knotifyconfig with extra/knotifyconfig5? [Y/n]
:: Replace kpackage with extra/kpackage5? [Y/n]
resolving dependencies...
:: removing knotifications breaks dependency 'knotifications' required by manjaro-settings-manager-knotifier
pacman -Syu
 core is up to date
 extra is up to date
 community is up to date
:: Replace kauth with extra/kauth5? [Y/n] y
:: Replace kcoreaddons with extra/kcoreaddons5? [Y/n]
:: Replace kitemmodels with extra/kitemmodels5? [Y/n]
:: Replace kitemviews with extra/kitemviews5? [Y/n]
:: Replace kwidgetsaddons with extra/kwidgetsaddons5? [Y/n]
:: Replace kwindowsystem with extra/kwindowsystem5? [Y/n]
:: Replace rpi-eeprom with extra/rpi4-eeprom? [Y/n]
:: raspberrypi-utils and raspberrypi-userland-aarch64-git are in conflict (raspberrypi-firmware). Remove raspberrypi-userland-aarch64-git? [y/N] y^[[B^[[D
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Update didn’t work for me … will dig in when I have time. Meanwhile, here’s the error
Error
Failed to prepare transaction
could not satisfy dependencies:
  • removing kxmlgui breaks dependency ā€˜kxmlgui’ required by libkipi
  • removing kservice breaks dependency ā€˜kservice’ required by libkipi
What type of answer is y^[[B^[[D? You hit the backspace key instead of the enter key on the response line. raspberrypi-userland-aarch64-git is depreciated and is replaced with raspberrypi-utils.
You need to rebuild your 3rd party apps replacing kservice5 as a depend with kservice5 installed.
HI,
Thanks a lot to the dev for the hard work !
Feedback, kde devices, stable branch.
Odroid c2
up date => ok hola
built image => ok
Odroid c4
up date => ok
built image => ok
Odroid n2
up date => ok
built image => black screen, no blinking blue led but fix
Odroid m1
up date => ok
built image => don’t find the network, don’t boot.
Having trouble with the manjaro-settings-manager package on my Pinebook Pro:
error: manjaro-settings-manager: signature from "Ray Sherwin <slick517d@gmail.com>" is marginal trust
:: File /var/cache/pacman/pkg/manjaro-settings-manager-0.5.7-7-aarch64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
I updated the archlinux-keyring separately, but that didn’t help.
Should be manjaro-arm-keyring.
I was able to fix this with the following steps:
  1. Reinstall manjaro-arm-keyring
  2. Removing manjaro-settings-manager
  3. Removing the existing archlinux-keyring files
/usr/bin/archlinux-keyring-wkd-sync
/usr/lib/systemd/system/archlinux-keyring-wkd-sync.service
/usr/lib/systemd/system/archlinux-keyring-wkd-sync.timer
/usr/lib/systemd/system/timers.target.wants/archlinux-keyring-wkd-sync.timer
/usr/share/pacman/keyrings/archlinux-revoked
/usr/share/pacman/keyrings/archlinux-trusted
/usr/share/pacman/keyrings/archlinux.gpg
  1. Upgrading all packages
  2. Re-installing manjaro-settings-manager
Looks like several of the Manjaro Plasma Mobile packages still need to be rebuilt for the KF5 package rename:
:: removing baloo breaks dependency 'baloo' required by elisa-qtmm
:: removing kdeclarative breaks dependency 'kdeclarative' required by elisa-qtmm
:: removing kcoreaddons breaks dependency 'kcoreaddons' required by kdav2
:: removing kcoreaddons breaks dependency 'kcoreaddons' required by kimap2
:: removing modemmanager-qt breaks dependency 'modemmanager-qt' required by plas
ma-dialer
:: removing kcontacts breaks dependency 'kcontacts' required by plasma-dialer
:: removing knotifications breaks dependency 'knotifications' required by plasma
-dialer
:: removing kwindowsystem breaks dependency 'kwindowsystem' required by plasma-d
ialer
:: removing plasma-framework breaks dependency 'plasma-framework' required by pl
asma-phonebook
:: removing kcontacts breaks dependency 'kcontacts' required by plasma-phonebook
:: removing kpeople breaks dependency 'kpeople' required by plasma-phonebook
:: removing kcontacts breaks dependency 'kcontacts' required by sink
:: removing kcalendarcore breaks dependency 'kcalendarcore' required by sink
:: removing kcontacts breaks dependency 'kcontacts' required by spacebar
:: removing knotifications breaks dependency 'knotifications' required by spaceb
ar
:: removing kconfig breaks dependency 'kconfig' required by spacebar
:: removing kio breaks dependency 'kio' required by spacebar
:: removing modemmanager-qt breaks dependency 'modemmanager-qt' required by spac
ebar
:: removing ki18n breaks dependency 'ki18n' required by vakzination
:: removing kconfig breaks dependency 'kconfig' required by vakzination
:: removing prison breaks dependency 'prison' required by vakzination
Note that those are not third-party applications, they all come from the official Manjaro ARM repositories.
Plamo is currently unmaintained on our end, hence the oversight …
Stumbled through it, I still have some cleanup to do but the update worked fine now. Thanks.
Is there an easy way to see ONLY stuff I’ve installed/built from AUR via GUI or CLI pacman?
Thanks for all the work here btw. Manjaro has been working great for me for years
pacman -Qm
I am aware of this sad state of affairs.
Does the maintainer have to be a Manjaro employee or could a community volunteer step in to fill the void? (How?)
Or even more than one. (Maintaining all the Plasma stuff is a lot of work for one person, especially if said person is an unpaid volunteer.)
@Kevin_Kofler ā€œoffersā€ his help to maintain plasma mobile on Manjaro, congratulation.
On my side I encounter issue with the images I built for 2 arm devices, the Odroid n2 and m1.
How can I help the dev team to solve it ?
So let me explicitly offer my help: I am willing to help maintaining the Plasma Mobile packages (and possibly the Plasma Desktop ones, but only if I am not the only one) in Manjaro ARM. I have years of KDE packaging experience from Fedora, and I believe I understand the Arch-style PKGBUILD packaging well enough to not make a mess. Things like simple rebuilds should definitely be something I can do immediately, though I will need an introduction to the processes (i.e., do we submit jobs to a build server like Fedora or do we upload binaries built on some random machine like Debian? As I understand it, the former, at least the kernel packages appear to come from some CI-type system) and the relevant accounts and permissions.
2 posts were split to a new topic: How to install the Manjaro on OrangePi 5+?
Amazing.
Let’s connect in dm ?
@oberon is the one maintaining all plasma packages atm. He can use some help.
sure we can talk about it @Kevin_Kofler. you can include me to the dm if there is any @spikerguy
