Hello ARM community,
this is my third stable update for our aarch64 architecture.
Most already know that we had some staff changes in our Manjaro ARM team. You might already have noticed that Dan left the team and the company. Therefore we have also to see when the next install medias for ARM SBCs and devices will been created. Dan did a lot for the ARM branch of Manjaro, including endless testing of boards and devices. Before releasing any image for an ARM device it needs to been tested on the device itself. You can find untested development builds at github.
Therefore I’ll act as the interim release manager until we found the right staff member for this job.
Donate
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
Update Announcement
With this update we have added a lot of new stuff. Beside kernel updates you may find some to Apple Silicon and Station M3.
Some highlights:
- Some Kernels got renewed
- Python wurde auf 3.11 erneuert: https://gitlab.manjaro.org/manjaro-arm/issues/packages/-/issues/1
- GNOME 44 / 44.1
- KDE Plasma 5.27.5
- KDE Gear got renewed to 23.04.1
- KDE Frameworks got updated to 5.106.0
- Firefox is at 113.0.1
- Thunderbird 102.11.0
- Still branch of LibreOffice got updated to 7.4.7 which is the last version of that series
- Usual KDE-git updates
End Of Life kernels (will be removed from repo soon):
linux60(EOL on 2023-01-12) (removed from repository)
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The PHP package has been updated to 8.2. If you still need 8.1, use php-legacy packages.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes (Fri May 19 13:30:34 CEST 2023)
- arm-stable community aarch64: 3009 new and 2956 removed package(s)
- arm-stable core aarch64: 85 new and 82 removed package(s)
- arm-stable extra aarch64: 1338 new and 1334 removed package(s)
- arm-stable kde-unstable aarch64: 389 new and 392 removed package(s)
See the full package list here
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
