[ARM Stable Update] 2023-03-12 - Plasma 5.27, Phosh 0.25, Kodi 20, SystemD 253 and Kernels
Hello ARM community.
This is a big update. It has just about everything.
Some highlights:
  • Most of our kernels got updated
  • Thunderbird updated to 102.8.0
  • KDE Gear applications updated to 22.12.3
  • Plasma updated to 5.27.2
  • LibreOffice updated to 7.5.1
  • Firefox updated to 110.0.1
  • Mesa updated to 22.3.7
  • SystemD updated to 253.1
  • Maui Applications updated to 2.2.2
  • Phosh updated to 0.25
  • Kodi updated to 20.0
  • Lots of updated packages for our Mobile offerings
  • The regular Python updates
  • And regular updates from upstream
End Of Life kernels (will soon by removed from the repo):
  • linux60 (EOL on 2023-01-12) (removed from repository, please update to 6.1 or 6.2)
Gnome 43 theme changes
Gnome 43 changes how themes are applied to the system, so when upgrading you might notice something is off with the theming.
We have tried to make it easy to get a pretty good theme going when updating, but it does require a few steps.
  1. Install adw-gtk3 and gradience. But you will need to set your own colors in Gradience after it’s installed.
  2. Open Gradience and import this preset (link will follow) and Apply it.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installed. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Removing python2 from the repositories
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
Chromium will loose sync support in early March:
Arch Linux - News: Chromium losing Sync support in early March
ghostpcl>=9.53.2-2 and ghostxps>=9.53.2-2 updates require manual intervention:
The nss and zn_poly packages requires manual intervention:
Arch Linux - News: zn_poly 0.9.2-2 update requires manual intervention
The packages hplip and firewalld requires manual intervention:
Package changes:
(Sun Mar 12 19:57:10 CET 2023)
  • arm-stable community aarch64: 941 new and 900 removed package(s)
  • arm-stable core aarch64: 94 new and 91 removed package(s)
  • arm-stable extra aarch64: 920 new and 919 removed package(s)
  • arm-stable kde-unstable aarch64: 420 new and 420 removed package(s)
See the full package list here
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #manjaro-arm:arm-testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
Donation
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Poll
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
2023-02-16
Docker 23 not starting
Since the update to Docker 23, upstream is now inforcing new paths for apparmor related stuff. But there has been changes to dependencies yet. So Docker 23 will error on start.
Fix: Install apparmor from the repositories.
2023-01-03
Ethernet and Wifi not working right on kernel 6.1.2+ on some devices
Some devices have been reported to not have properly working ethernet and wifi after the update to kernel 6.1.2 and above.
Fix: Kernel 6.1.5-2 and above should have working ethernet and wifi again.
Reduced video playback performance in mpv
There has been reports of video playback performance in mpv has regressed since an update to mpv.
Fix: MPV now needs a vd-lavc-dr=no parameter to play hw acceleration supported 1080p videos smoothly.
Touch input on Firefox with Phosh not working in Firefox 108
Since the update to Firefox 108, the touch input does not work. Seems to be an issue with a couple of the changes the mobile-config brings in. PostMarketOS likely won’t fix this in their source, so we might need to carry a patch for this.
2022-11-20
OpenSSL 1.1 library not found
Some applications might still be looking for openssl 1.1.
Solution: Install openssl-1.1 package with sudo pacman -S openssl-1.1.
2022-10-31
Firefox shows wrong colors when playing video on Raspberry Pi 4
Since Mesa 22.2, Firefox has been showing weird colors when playing video on the Raspberry Pi 4. This is caused by an issue in upstream mesa, which was recently fixed.
Fix: Update to mesa 22.2.3-0.1 in the repository, which includes this fix.
Chromium in Wayland crashes with --in-process-gpu
Since Mesa 22.2.0, Chromium running in wayland sessions seems to crash when running with the --in-process-gpu option. Running in X11 seems fine, although it’s slow.
Fix: Update to Mesa 22.3.2 was reported to work here.
2022-10-21
Plasma Mobile Dialer seems to be unreliable
Plasma Dialer 22.09 seems to have issues switching audio profiles and as such might require manual switching. Sometimes audio is completely missing.
Reduced video performance on youtube
Some may encounter reduced video playback performance on YouTube in Firefox with the new Mesa 22.2 drivers.
No workaround at this time.
Old Issues
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
[Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
(190/195) upgrading uboot-pinephone                                      [########################################] 100%
Re-generating U-Boot boot script from /boot/boot.txt completed successfully.
egrep: warning: egrep is obsolescent; using grep -E
Flashing U-Boot image...
Thumbs up for up-to-date Mesa while upstream is still behind
On a PPP, just updated.
I cannot maintain an SSH session over WIFI without seeing a lot of client_loop: send disconnect: Broken pipe errors. Tried reducing the ServerAliveInterval variable but no change.
Also, the Plasma Settings app won’t launch from app menu or the quick settings pull down, it just hangs at the loading animation. The qmlkonsole app appears to load but doesn’t bring me to the TTY.
So far, so good, works perfectly with Kodi 20.
My kernel was automatically updated from 5.15 to 6.1.
Was it mandatory for some reason ?
Nonetheless, good job ! :beers:
If you have linux-lts installed, then yes. It uses the latest LTS kernel.
Had to install pipewire-alsa for sound to work in kodi 20. Other than that smooth sailing :ok_hand:
Good call on the apparmor/docker 23 fix. I swear installing apparmor was the first thing i tried after encountering the error last update. After reading this I installed apparmor again, rebooted and that did it. Maybe the reboot is essential? I have no experience whatsoever with apparmor.
Maybe a restart of the docker daemon is enough, but a reboot is a way to make sure.
5 posts were split to a new topic: After the latest update on my Pinebook Pro my internet won’t work
