Hello ARM community.
Getting ready for our next release, this update brings in a lot of everything.
Some highlights:
- Most of our kernels got updated
- Firefox updated to 110.0
- Plasma Mobile Gear updated to 23.01.0
- Mesa updated to 22.3.5
- Plasma Frameworks updated to 5.103
- KDE Gear applications updated to 22.12.2
- GStreamer updated to 1.22
- LibreOffice updated to 7.5.0
- QEMU updated to 7.2.0
- Thunderbird updated to 102.7.2
- Lots of updated packages for our Mobile offerings
- The regular Python updates
- And regular updates from upstream
End Of Life kernels (will soon by removed from the repo):
linux60(EOL on 2023-01-12)
Gnome 43 theme changes
Gnome 43 changes how themes are applied to the system, so when upgrading you might notice something is off with the theming.
We have tried to make it easy to get a pretty good theme going when updating, but it does require a few steps.
- Install
adw-gtk3andgradience. But you will need to set your own colors in Gradience after it’s installed. - Open Gradience and import this preset (link will follow) and Apply it.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-imageand all it’s dependencies. - Run
pkexec setup-waydroid. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installed. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Removing python2 from the repositories
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
Chromium will loose sync support in early March:
Arch Linux - News: Chromium losing Sync support in early March
ghostpcl>=9.53.2-2 and ghostxps>=9.53.2-2 updates require manual intervention:
The nss and zn_poly packages requires manual intervention:
Arch Linux - News: zn_poly 0.9.2-2 update requires manual intervention
The packages hplip and firewalld requires manual intervention:
Package changes:
(Thu Feb 16 19:35:21 CET 2023)
- arm-stable community aarch64: ??? new and ??? removed package(s)
- arm-stable core aarch64: ?? new and ?? removed package(s)
- arm-stable extra aarch64: ??? new and ??? removed package(s)
- arm-stable kde-unstable aarch64: ??? new and ??? removed package(s)
See the full package list here
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #manjaro-arm:arm-testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
Donation
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Poll
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
