Hello ARM community.
An update on the smaller side this time!
DesQ is a new desktop environment based on wlroots and wayfire
Some highlights:
- Most of our kernels got updated
- Plasma updated to 5.22.4
- Introducing a new Desktop Environment DesQ
- Kodishould now be fixed
- Version 15.0 of PulseAudio is now available
- Added a couple of new packages, including Vakzination
- Lots of updated packages for our Mobile offerings
- The regular Python updates
- And regular updates from upstream
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
https://archlinux.org/news/sorting-out-old-password-hashes/
Older notifications
Chromium will loose sync support in early March:
Arch Linux - News: Chromium losing Sync support in early March
ghostpcl>=9.53.2-2 and ghostxps>=9.53.2-2 updates require manual intervention:
The nss
and zn_poly
packages requires manual intervention:
Arch Linux - News: zn_poly 0.9.2-2 update requires manual intervention
The packages hplip
and firewalld
Package changes:
(Thu Aug 5 21:18:52 CEST 2021)
- arm-stable community aarch64: 574 new and 551 removed package(s)
- arm-stable core aarch64: 44 new and 43 removed package(s)
- arm-stable extra aarch64: 485 new and 487 removed package(s)
- arm-stable kde-unstable aarch64: 244 new and 242 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-07-23 2021-08-05
ap6256-firmware 2020.02-5 2020.02-7
ap6398s-firmware 2020.04-3 2020.04-4
bitwarden 1.27.1-1 1.27.1-2
chatty 0.3.3-1 0.3.3+19+g1fd48d5-1
code 1.57.1-1 1.58.2-1
desq-session-git r50.b24bf9a-1 -
desq-shell-git r105.4d54364-1 -
electron11 11.4.9-1 11.4.10-1
element-desktop 1.7.33-1 1.7.34-1
element-web 1.7.33-1 1.7.34-1
hwinfo 21.75-1 21.76-1
kodi-common 19.0-1 -
kodi-dev 19.0-1 19.1-5
kodi-eventclients 19.0-1 19.1-5
kodi-gbm 19.0-1 -
kodi-rpi 19.1-9 19.1-10
kodi-rpi-dev 19.1-9 19.1-10
kodi-rpi-eventclients 19.1-9 19.1-10
kodi-rpi-tools-texturepacker 19.1-9 19.1-10
kodi-tools-texturepacker 19.0-1 19.1-5
kodi-wayland 19.0-1 -
kodi-x11 19.0-1 -
libdesq-git r81.87e986b-1 -
libdesqui-git r28.3b8b76c-1 -
libdesqwl-git r26.6c72627-1 -
libmm-pp-glib 1.16.6-1 1.16.8-1
lxc 1 4.0.6-1 -
modemmanager-pp 1.16.6-1 1.16.8-1
mygnuhealth 1.0.2-1 1.0.3-1
oyster-git r7.1418f70-1 -
pinebook-pro-keyboard-updater 0.0.3-2 0.0.3-4
pinebookpro-post-install 20210709-2 20210728-1
portfolio-file-manager 0.9.10+7+g4174bfa-1 0.9.11-2
rockpi4-post-install 20210709-1 20210728-1
rockpro64-post-install 20210709-2 20210728-1
spacebar 21.07-2 21.07-3
vivaldi 4.0.2312.41-1 4.1.2369.11-1
xsel 1.2.0.20190821-1 -
yay 10.3.0-1 10.3.1-2
desq-apps-archiver - 0.0rwt1-1
desq-apps-docs - 0.0rwt1-1
desq-apps-dropdown - 0.0rwt1-1
desq-apps-term - 0.0rwt1-1
desq-session - 0.0rwt1.2-1
desq-shell - 0.0rwt1-1
desq-utils-lock - 0.0rwt1-1
desq-utils-polkitexec - 0.0rwt1-1
desq-utils-powerdaemon - 0.0rwt1-1
desq-utils-powermanager - 0.0rwt1-1
desq-utils-runner - 0.0rwt1.1-1
desq-utils-sni - 0.0rwt1-1
desq-utils-splash - 0.0rwt1-1
desq-utils-volume - 0.0rwt1-1
kodi - 19.1-5
libdesq - 0.0rwt1.1-1
libdesqui - 0.0rwt1-1
libdesqwl - 0.0rwt1-1
pacutils - 0.11.0-4
vakzination - 0.1-1
:: Different sync package(s) in repository community aarch64
absl-py 0.12.0-1 0.13.0-1
acme.sh 2.9.0-1 3.0.0-1
aliyun-cli 3.0.81-1 3.0.82-1
android-tools 31.0.0-4 31.0.2-1
ansible 4.2.0-1 4.3.0-1
antic 0.2.4-1 0.2.4-2
apache-orc 1.6.7-4 1.6.9-1
arb 2.19.0-2 2.20.0-1
arch-wiki-docs 20200527-1 20210802-1
ardour 6.8-1 6.8-2
argocd 2.0.4-1 2.0.5-1
arrow 3.0.0-4 3.0.0-5
aspell-pl 20210105-1 20210731-1
atomicparsley20210617.200601.1ac7c08-120210715.151551.e7ad03a-1
autopep8 1:1.5.7-1 1:1.5.7-2
babel-cli 7.14.5-2 7.14.8-1
babel-core 7.14.6-1 7.14.8-1
baidupcs-go 3.8.1-1 3.8.2-1
bash-bats 1.3.0-1 1.4.1-1
bcc 0.20.0-3 0.21.0-1
bcc-tools 0.20.0-3 0.21.0-1
bctoolbox 5.0.0-2 5.0.3-1
bemenu 0.6.2-2 0.6.3-1
bemenu-ncurses 0.6.2-2 0.6.3-1
bemenu-wayland 0.6.2-2 0.6.3-1
bemenu-x11 0.6.2-2 0.6.3-1
bibletime 3.0-2 3.0.1-1
birdfont 2.29.4-1 2.29.5-1
blender 17:2.93.1-4 17:2.93.1-5
blueberry 1.4.2-1 1.4.4-1
blueman 2.1.4-1 2.2.1-1
borg 1.1.16-5 1.1.17-2
borgmatic 1.5.15-1 1.5.17-1
bpftrace 0.12.0-2 0.13.0-1
broot 1.6.1-1 1.6.2-1
buildah 1.21.3-1 1.21.4-1
calf 0.90.3-4 0.90.3-5
calibre 5.23.0-1 5.23.0-2
camlp4 4.11-1 4.12+1-1
camlp5 7.12-11 8.0-1
capnet-assist 2.2.5-3 2.3.0-1
cargo-spellcheck 0.8.9-1 0.8.11-1
cargo-watch 7.8.1-1 8.0.0-1
carla 2.3.1-1 2.3.1-2
catfish 4.16.0-4 4.16.1-1
ccfits 2.5-5 2.6-1
ccid 1.4.34-1 1.4.35-1
cdrtools 3.02a09-4 3.02a09-5
ceph 15.2.13-1 15.2.13-2
ceph-libs 15.2.13-1 15.2.13-2
ceph-mgr 15.2.13-1 15.2.13-2
cherrytree 0.99.38-1 0.99.39-2
chezmoi 2.1.2-1 2.1.3-1
chrono-date 3.0.0-2 3.0.1-1
chuck 1.4.0.1-1 1.4.1.0-1
clojure 1.10.3.849-1 1.10.3.933-2
cockpit 248-1 249-1
cockpit-machines 247-1 248-1
cockpit-pcp 248-1 249-1
container-diff 0.16.0-2 0.17.0-1
containerd 1.5.2-1 1.5.4-1
contractor 0.3.4-3 0.3.5-1
converseen 0.9.9.0-2 0.9.9.1-1
coq 8.13.2-1 8.13.2-2
coq-doc 8.13.2-1 8.13.2-2
coqide 8.13.2-1 8.13.2-2
cosign 0.3.1-2 1.0.1-1
crystal 1.0.0-3 1.1.1-1
curtail 1.1.0-3 1.2.1-1
diff-so-fancy 1.4.2-1 1.4.3-1
diffoscope 178-1 179-1
drawing 0.8.0-1 0.8.3-1
drumstick 2.3.0-1 2.3.1-1
dua-cli 2.14.1-1 2.14.3-1
dune 2.9.0-1 2.9.0-2
e-antic 1.0.1-2 1.0.1-3
eclib 20210625-1 20210625-2
efm-langserver 0.0.35-1 0.0.36-1
elementary-icon-theme 5.3.1-1 6.0.0-1
elementary-wallpapers 5.5.0-2 6.0.0-1
emscripten 2.0.24-1 2.0.26-1
erlang 24.0-1 24.0.4-1
erlang-nox 24.0-1 24.0.4-1
erlang-unixodbc 24.0-1 24.0.4-1
erlang22-nox 22.3.4.11-1 22.3.4.20-1
eslint 7.31.0-1 7.32.0-1
etl 1.4.1-1 1.4.2-1
faudio 21.07-1 21.08-1
faust 2.30.5-3 2.33.1-1
fcitx5-pinyin-zhwiki 1:0.2.3.20210704-1 1:0.2.3.20210722-1
fetchmail 6.4.19-1 6.4.20-1
filezilla 3.55.0-1 3.55.0-2
firefox-ublock-origin 1.36.2-1 1.37.2-1
firewalld 0.9.4-1 1.0.0-1
flameshot 0.10.0-1 0.10.1-1
flint 2.7.1-2 2.8.0-1
fltk 1.3.6-1 1.3.7-1
fltk-docs 1.3.6-1 1.3.7-1
fltk-examples 1.3.6-1 1.3.7-1
fluajho 1.6.2-2 1.6.2-3
fluxctl 1.23.0-1 1.23.1-1
freecad 0.19.2-2 0.19.2-3
freerdp 2:2.3.2-1 2:2.4.0-1
freewheeling 0.6.6-2 0.6.6-3
fuse-overlayfs 1.6-1 1.7-1
gala 6.0.0-1 6.0.0-2
gdal 3.3.0-1 3.3.1-3
geckodriver 0.26.0-1 0.29.1-1
gensio 2.2.4-1 2.2.8-1
geoipupdate 4.7.1-1 4.8.0-1
ghostwriter 2.0.1-1 2.0.2-1
giac 1.7.0.21-1 1.7.0.23-1
giada 0.18.0.1-1 0.18.1-1
github-cli 1.12.1-1 1.13.1-1
glances 3.2.0-1 3.2.1-1
glewlwyd 2.5.2-2 2.5.3-1
glusterfs 1:9.1-1 1:9.3-1
gnubg 1.06.002-5 1.06.002-6
gnuradio 3.8.2.0-2 3.9.2.0-2
gnuradio-companion 3.8.2.0-2 3.9.2.0-2
go-ethereum 1.10.5-1 1.10.6-1
go-ipfs 0.9.0-1 0.9.1-1
go-md2man 2.0.0-4 2.0.1-1
gpg-tui 0.7.2-1 0.7.3-1
gping 1.2.1-1 1.2.3-1
gpodder 3.10.20-1 3.10.21-1
gpsprune 20.3-1 20.4-1
gpxsee 9.0-1 9.3-1
grpc 1.38.1-1 1.39.0-1
grpc-cli 1.38.1-1 1.39.0-1
gsoap 2.8.115-1 2.8.116-1
gtk-theme-elementary 5.4.2-1 6.0.0-1
hamlib 3.3-10 3.3-11
haxe 4.2.3-2 4.2.3-3
helm 3.6.2-1 3.6.3-1
helmfile 0.139.9-1 0.140.0-1
hivex 1.3.20-5 1.3.20-6
home-assistant 2021.5.3-2 2021.7.4-2
hugo 0.85.0-1 0.86.1-1
hunspell-pl 20210105-1 20210731-1
i3status-rust 0.20.2-1 0.20.3-1
ibus-table 1.13.3-1 1.14.0-1
in-toto 1.0.1-1 1.1.1-1
innernet 1.4.0-1 1.4.1-1
ipython 7.25.0-1 7.26.0-1
iwd 1.15-1 1.16-1
jack2 1.9.19-1 -
jack2-dbus 1.9.19-1 -
jenkins 2.302-1 2.304-1
jitterentropy 3.0.2-1 3.1.0-1
jmol 14.31.44-1 14.31.48-1
josm 17919-1 18004-1
jrnl 2.8.1-1 2.8.2-1
jsmol 14.31.44-1 14.31.48-1
jupyter-server 1.9.0-2 1.10.1-1
jupyterlab 3.0.16-1 3.1.1-1
khal 0.10.3-1 0.10.4-1
kitty 0.21.2-2 0.22.2-1
kitty-terminfo 0.21.2-2 0.22.2-1
klavaro 3.11-1 3.13-1
klayout 0.27.2-1 0.27.3-1
kmymoney 5.1.1-2 5.1.2-1
kodi-platform 20190726.809c5e9-27 20190726.809c5e9-28
kstars 1:3.5.3-1 1:3.5.4-1
kustomize 4.1.3-1 4.2.0-1
kvantum-qt5 0.20.0-1 0.20.1-1
kvantum-theme-materia 20210624-1 20210722-1
lablgtk3 3.1.1-2 3.1.1-3
languagetool 5.3-1 5.4-1
libcontentaction 0.4.0-1 0.4.1-1
libcurl-compat 7.77.0-1 7.78.0-1
libcurl-gnutls 7.77.0-1 7.78.0-1
libdsme 0.66.3-1 -
libdwarf 20201201-1 20210528-1
libfilezilla 0.30.0-1 0.31.0-1
libkeccak 1.2-2 1.2.2-1
libpoly 0.1.9-1 0.1.10-1
libretro-beetle-pce-fast 1127-1 1129-1
libretro-beetle-psx 2538-1 2544-1
libretro-beetle-psx-hw 2538-1 2544-1
libretro-bsnes2014 1:566-1 1:577-1
libretro-dolphin 32990-2 32990-3
libretro-gambatte 908-1 912-1
libretro-genesis-plus-gx 1580-1 1786-1
libretro-mgba 7842-1 7979-1
libretro-play 6549-1 6632-1
libretro-shaders-slang 814-1 816-1
libsemigroups 1.3.7-2 1.3.7-3
libtracefs 1.2.3-1 1.2.4-1
libuhd 4.0.0.0-2 4.1.0.1-2
libuhd-firmware 4.0.0.0-1 4.1.0.1-1
libvirt-dbus 1.4.0-1 1.4.1-1
libvolk 2.4.1-1 2:2.5.0-1
lifeograph 2.0.1-1 2.0.2-1
lightdm-gtk-greeter-settings 1.2.2-5 1.2.2-6
lmms 1.2.2-4 1.2.2-5
lxcfs 4.0.8-1 4.0.9-1
mame 0.233-1 0.234-1
mame-tools 0.233-1 0.234-1
man-pages-zh_cn 1.6.3.4-2 1.6.3.5-1
man-pages-zh_tw 1.6.3.4-2 1.6.3.5-1
materia-kde 20210624-1 20210722-1
mdbook 0.4.10-1 0.4.12-1
mediastreamer 5.0.0-1 5.0.3-1
mgard 0.1.0-1 0.1.0-2
micro 2.0.9-1 2.0.9-2
minio 2021.07.08-1 2021.07.22-1
minio-client 2021.06.08-1 2021.06.13-1
mongo-c-driver 1.17.5-1 1.18.0-1
monit 5.27.1-1 5.28.1-1
mumble 1.3.4-7 1.3.4-8
murmur 1.3.4-7 1.3.4-8
muse 4.0.0-1 4.0.0-2
mutter6 3.36.8-2 3.36.9-1
networkmanager-strongswan 1.5.2-1 1.5.2-2
newsboat 2.24-1 2.24-2
newsflash 1.4.1-1 1.4.2-1
nextcloud-app-bookmarks 1:4.3.0-1 1:4.4.0-1
nicotine+ 3.0.6-1 3.1.1-1
nlohmann-json 3.9.1-3 3.9.1-4
nnn 4.1.1-1 4.2-1
nodejs 16.5.0-1 16.6.0-1
nodejs-lts-erbium 12.22.3-1 12.22.4-2
nodejs-lts-fermium 14.17.3-1 14.17.4-1
nomad-driver-containerd 0.8-2 0.9-1
normaliz 3.9.0-1 3.9.0-2
npm 7.17.0-1 7.20.3-1
nsd 4.3.6-1 4.3.7-1
nvchecker 2.3-4 2.4-1
ocaml-base 0.14.1-1 0.14.1-2
ocaml-cairo 0.6.2-1 0.6.2-2
ocaml-compiler-libs-repackaged 0.12.3-1 0.12.3-2
ocaml-csexp 1.3.2-1 1.3.2-2
ocaml-findlib 1.9.1-1 1.9.1-2
ocaml-hashcons 1.3-1 1.3-2
ocaml-lablgl 1.06-8 1.06-9
ocaml-num 1.4-2 1.4-3
ocaml-ppx_derivers 1.2.1-5 1.2.1-6
ocaml-sexplib0 0.14.0-2 0.14.0-3
ocaml-stdio 0.14.0-2 0.14.0-3
ocaml-stdlib-shims 0.3.0-1 0.3.0-2
ocaml-zarith 1.11-1 1.11-2
oha 0.4.4-1 0.4.6-1
oidentd 2.5.0-1 2.5.1-1
opam 2.0.8-1 2.1.0-1
opendht 1:2.1.10-2 1:2.1.10-3
openfire 4.6.3-1 4.6.4-1
openfortivpn 1.16.0-2 1.17.0-1
openrct2 0.3.4-1 0.3.4.1-1
opensubdiv 3.4.4-2 3.4.4-4
openttd 1.11.2-4 1.11.2-5
operator-sdk 1.9.0-1 1.10.0-1
osdlyrics 0.4.3-7 0.5.6-1
otf-cascadia-code 2105.24-1 2106.17-1
pacutils 0.11.0-2 -
pantheon-applications-menu 2.7.1-3 2.8.0-1
pantheon-calculator 1.6.1-1 1.6.2-1
pantheon-calendar 5.1.1-3 6.0.0-1
pantheon-code 3.4.1-3 6.0.0-1
pantheon-screenshot 1.7.1-2 6.0.0-1
papirus-icon-theme 20210701-1 20210802-1
pdfjs 2.9.359-1 2.10.377-1
pdfmixtool 0.6-2 1.0.2-1
perl-specio 0.43-2 0.47-1
perl-sys-virt 7.1.0-1 7.4.0-1
perl-test-simple 1.302185-2 1.302186-1
perl-test2-suite 0.000140-2 0.000141-1
php-grpc 1.38.1-1 1.39.0-1
php-igbinary 3.2.3-1 3.2.4-1
php-imagick 3.5.0-1 3.5.1-1
php-snuffleupagus 0.7.0-2 0.7.1-1
php7-grpc 1.38.1-1 1.39.0-1
php7-igbinary 3.2.3-1 3.2.4-1
php7-imagick 3.5.0-1 3.5.1-1
picocom 3.1-2 3.1-3
piping-server 0.8.4-1 0.8.5-1
polymake 4.4-4 4.4-5
postgis 3.1.2-1 3.1.3-1
powerdns 4.5.0-1 4.5.1-1
powerdns-recursor 4.5.4-1 4.5.5-1
presage 0.9.1-1 -
proxychains-ng 4.14-2 4.15-1
pulumi 3.7.0-1 3.7.1-1
pybind11 2.7.0-1 2.7.0-2
pyenv 2.0.3-1 2.0.4-1
pynac 0.7.29-2 0.7.29-3
pyright 1.1.157-1 1.1.159-1
python-abydos 0.5.0-1 0.5.0-2
python-aiogram 2.14.2-1 2.14.3-1
python-anyio 3.2.1-1 3.3.0-1
python-apispec 4.7.1-1 5.0.0-1
python-aws-sam-translator 1.37.0-1 1.38.0-1
python-bcc 0.20.0-3 0.21.0-1
python-beniget 0.4.0-1 0.4.1-1
python-black 21.6b0-3 21.7b0-1
python-breathe 4.30.0-1 4.30.0-2
python-btrfs 12-2 13-1
python-build 0.5.1-1 0.6.0-1
python-celery 5.1.1-1 5.1.2-1
python-cfn-lint 0.52.0-1 0.53.0-1
python-cftime 1.4.1-1 1.5.0-1
python-cinderclient 7.4.0-1 8.0.0-1
python-confuse 1.4.0-1 1.5.0-1
python-dbus-next 0.2.2-2 0.2.3-1
python-discogs-client 2.3.12-1 2.3.12-2
python-django-q 1.3.9-1 1.3.9-2
python-dotenv 0.18.0-1 0.19.0-1
python-entrypoint2 0.2-3 0.2.4-1
python-faker 8.10.1-1 8.10.3-1
python-flake8-black 0.2.1-5 0.2.2-1
python-flexmock 0.10.4-6 0.10.5-1
python-flit 3.2.0-2 3.2.0-3
python-flit-core 3.2.0-2 3.2.0-3
python-fonttools 4.25.1-1 4.25.2-1
python-gdal 3.3.0-1 3.3.1-3
python-google-auth 1.28.1-1 1.29.0-1
python-grpcio 1.38.1-1 1.39.0-1
python-hcloud 1.12.0-1 1.13.0-1
python-hunter 3.3.6-1 3.3.8-1
python-hypothesis 6.14.3-1 6.14.5-1
python-ibm-db-sa 0.3.5-4 0.3.7-1
python-intervals 0.9.1-1 0.9.2-1
python-invoke 1.5.0-1 1.6.0-1
python-jeepney 0.7.0-1 0.7.1-1
python-json-logger 0.1.11-5 2.0.0-1
python-jsonschema-objects 0.3.13-1 0.3.14-1
python-kombu 5.0.2-3 5.1.0-1
python-libnacl 1.7.2-3 1.8.0-1
python-marshmallow 3.12.2-1 3.13.0-1
python-matplotlib 3.4.2-1 3.4.2-3
python-matrix-nio 0.18.4-1 0.18.6-1
python-matrix_client 0.3.2-3 -
python-more-itertools 8.7.0-1 8.8.0-1
python-moto 2.1.0-1 2.2.0-1
python-mss 6.0.0-3 6.1.0-1
python-networkx 2.5.1-2 2.6.2-1
python-ovirt-engine-sdk 4.4.13-1 4.4.14-1
python-pandas 1.2.5-1 1.3.1-1
python-param 1.10.1-1 1.11.1-1
python-partd 1.1.0-3 1.2.0-1
python-path 16.0.0-1 16.2.0-1
python-pdfminer 20201018-2 20201018-3
python-pdoc 7.1.1-1 7.2.0-1
python-pg8000 1.20.0-1 1.21.0-1
python-phonenumbers 8.12.27-1 8.12.28-1
python-pikepdf 2.15.1-1 2.16.1-1
python-pivy 0.6.5-3 0.6.6-1
python-praw 7.3.0-1 7.4.0-1
python-prawcore 2.2.0-1 2.3.0-1
python-py3c 1.3-1 1.3.1-1
python-py_stringmatching 0.4.2-1 0.4.2-2
python-pycdio 2.1.0-5 2.1.1-1
python-pygls 0.11.1-1 0.11.2-1
python-pyhamcrest 1.10.0-1 1.10.1-1
python-pykeepass 4.0.0-1 4.0.1-1
python-pyotherside 1.5.8-3 1.5.9-1
python-pyscard 2.0.0-2 2.0.1-1
python-pyscreenshot 2.3-1 3.0-1
python-pyspnego 0.1.5-1 0.1.6-1
python-pytest-checkdocs 2.7.0-1 2.7.1-1
python-pytest-mpi 0.4-3 0.5-1
python-pytest-relaxed 1.1.5-5 1.1.5-6
python-pytest-runner 5.2-3 5.3.1-1
python-pytest-twisted 1.13.2-3 1.13.3-1
python-pyvirtualdisplay 2.1-1 2.2-1
python-pyxdameraulevenshtein 1.6.1-1 1.7.0-1
python-pyzmq 22.0.3-1 22.1.0-1
python-qasync 0.17.0-1 0.18.0-1
python-qstylizer 0.1.10-1 0.2.0-1
python-rstr 2.2.6-10 3.0.0-1
python-ruamel.yaml.clib 0.2.4-1 0.2.6-1
python-schemdraw 0.8-2 0.9-1
python-scipy 1.7.0-1 1.7.1-1
python-securesystemslib 0.20.0-1 0.20.1-1
python-sounddevice 0.4.1-2 0.4.2-1
python-sphinx 4.1.1-1 4.1.2-1
python-sphinx-autoapi 1.8.1-1 1.8.2-1
python-textdistance 4.2.0-1 4.2.1-1
python-threadpoolctl 2.1.0-3 2.2.0-1
python-tqdm 4.61.2-1 4.62.0-1
python-uvloop 0.15.2-1 0.15.3-1
python-virtualenv-clone 0.5.5-1 0.5.6-1
python-watchgod 0.6-2 0.7-1
python-wurlitzer 2.0.0-3 2.1.1-1
python-xlsxwriter 1.4.4-1 1.4.5-1
python-xmlschema 1.2.4-1 1.2.5-1
python-zita-jacktools 1.5.2-1 1.5.3-1
python-zope-proxy 4.3.5-3 4.4.0-1
python2-pytest-runner 5.2-3 5.2-4
qcad 3.26.4.2-1 3.26.4.5-1
qgis 3.20.0-3 3.20.1-1
qmmp 1.5.0-2 1.5.1-1
qsynth 0.9.4-1 0.9.4-2
qt5ct 1.2-1 1.3-1
qt6ct 0.3-1 0.4-1
qutebrowser 2.3.0-1 2.3.1-1
radicale 3.0.6-2 3.0.6-3
rclone 1.55.1-1 1.56.0-1
rebuilderd 0.12.0-1 0.13.0-1
redis 6.2.4-1 6.2.5-1
rekor 0.2.0-1 0.3.0-1
renpy 7.4.6-1 7.4.7-1
renpy-demos 7.4.6-1 7.4.7-1
repo 2.16-1 2.16.4-1
retroarch 1.9.6-3 1.9.7-1
rime-pinyin-zhwiki 1:0.2.3.20210704-1 1:0.2.3.20210722-1
ruby-bundler 2.2.24-1 2.2.25-1
ruby-rb-fsevent 0.10.4-2 0.11.0-1
rust-analyzer 20210719-1 20210802-1
rust-bindgen 0.58.1-1 0.59.1-1
sakura 3.8.2-1 3.8.3-1
sassc 3.6.2-2 3.6.2-3
scite 5.0.3-1 5.1.0-1
scribus 1.5.7-1 1.5.7-2
scrot 1.5-1 1.6-1
seamonkey 2.53.8-1 2.53.8.1-1
shards 0.14.1-1 0.15.0-1
singular 4.2.1-2 4.2.1-3
skaffold 1.28.0-1 1.28.1-1
skrooge 2.25.0-1 2.26.1-1
smtube 20.6.0-1 21.7.0-1
soapyuhd 0.4.1-3 0.4.1-4
sound-theme-elementary 1.0-1 1.1.0-1
spdlog 1.8.5-2 1.9.1-1
squashfs-tools 4.4_git.1-1 -
squid 4.15-1 4.16-1
step-ca 0.15.15-1 0.16.0-1
strongswan 5.9.2-1 5.9.3-1
suscan 0.1.0-4 0.1.0-5
svgcleaner 0.9.5-2 0.9.5-3
sweethome3d 6.5.2-1 6.6-1
switchboard-plug-printers 2.1.9-2 2.1.10-1
symengine 0.7.0-1 0.7.0-2
syncthing 1.17.0-1 1.18.0-1
syncthing-relaysrv 1.17.0-1 1.18.0-1
systemc 2.3.3-1 2.3.3-2
tailscale 1.10.2-1 1.12.1-1
telegram-desktop 2.8.11-2 2.9.0-2
terraform 1.0.2-1 1.0.3-2
terragrunt 0.30.7-1 0.31.1-1
tint2 17.0-1 17.0.1-1
tldr 1.2.1-1 2.0.0-1
trace-cmd 2.9.3-2 2.9.5-1
ttc-iosevka 7.2.6-1 7.3.2-1
ttc-iosevka-aile 7.2.6-1 7.3.2-1
ttc-iosevka-curly 7.2.6-1 7.3.2-1
ttc-iosevka-curly-slab 7.2.6-1 7.3.2-1
ttc-iosevka-etoile 7.2.6-1 7.3.2-1
ttc-iosevka-slab 7.2.6-1 7.3.2-1
ttc-iosevka-ss01 7.2.6-1 7.3.2-1
ttc-iosevka-ss02 7.2.6-1 7.3.2-1
ttc-iosevka-ss03 7.2.6-1 7.3.2-1
ttc-iosevka-ss04 7.2.6-1 7.3.2-1
ttc-iosevka-ss05 7.2.6-1 7.3.2-1
ttc-iosevka-ss06 7.2.6-1 7.3.2-1
ttc-iosevka-ss07 7.2.6-1 7.3.2-1
ttc-iosevka-ss08 7.2.6-1 7.3.2-1
ttc-iosevka-ss09 7.2.6-1 7.3.2-1
ttc-iosevka-ss10 7.2.6-1 7.3.2-1
ttc-iosevka-ss11 7.2.6-1 7.3.2-1
ttc-iosevka-ss12 7.2.6-1 7.3.2-1
ttc-iosevka-ss13 7.2.6-1 7.3.2-1
ttc-iosevka-ss14 7.2.6-1 7.3.2-1
ttc-iosevka-ss15 7.2.6-1 7.3.2-1
ttc-iosevka-ss16 7.2.6-1 7.3.2-1
ttc-iosevka-ss17 7.2.6-1 7.3.2-1
ttc-iosevka-ss18 7.2.6-1 7.3.2-1
ttf-cascadia-code 2105.24-1 2106.17-1
ttf-ibm-plex 5.1.3-1 5.2.1-1
ttf-jetbrains-mono 2.225-1 2.242-1
ttf-sarasa-gothic 0.32.12-1 0.34.1-1
twine 3.4.1-1 3.4.2-1
uglify-js 3.13.10-1 3.14.1-1
umockdev 0.16.0-1 0.16.1-1
unbound 1.13.1-1 1.13.1-2
urh 2.9.2-1 2.9.2-2
urlwatch 2.23-2 2.23-3
uvicorn 0.14.0-1 0.14.0-2
v2ray-domain-list-community 20210718155822-1 20210802121239-1
v2ray-geoip 202107150023-1 202108020308-1
vapoursynth R53-1 R54-1
vaultwarden 1.22.1-1 1.22.2-1
vaultwarden-web 2.20.4-1 2.21.1-1
verilator 4.210-1 4.210-2
vidcutter 6.0.5-2 6.0.5.1-1
vim-clap 0.26-1 0.27-1
warpinator 1.2.0-1 1.2.4-1
watchexec 1.15.3-1 1.17.1-1
waybar 0.9.7-2 0.9.7-5
whipper 0.10.0-2 0.10.0-3
wingpanel 2.3.2-4 3.0.0-2
wingpanel-indicator-bluetooth 2.1.6-1 2.1.7-1
wingpanel-indicator-datetime 2.2.5-4 2.3.0-1
wingpanel-indicator-keyboard 2.3.0-2 2.4.0-1
wingpanel-indicator-network 2.2.4-1 2.3.0-1
wingpanel-indicator-nightlight 2.0.4-1 2.1.0-1
wingpanel-indicator-notifications 2.1.4-2 6.0.0-1
wingpanel-indicator-power 2.2.0-1 6.0.0-1
wingpanel-indicator-session 2.2.8-2 2.3.0-1
wingpanel-indicator-sound 2.1.8-2 6.0.0-1
woff2-cascadia-code 2105.24-1 2106.17-1
woob 3.0-1 3.0-2
wordpress 5.7.2-1 5.8-1
xh 0.10.0-1 0.11.0-1
xmms20.8DrO_o.7391.dedc33d7-50.8DrO_o.7391.dedc33d7-6
xonsh 0.9.27-1 0.10.0-1
xplr 0.14.4-1 0.14.5-1
xsimd 7.5.0-1 7.6.0-1
yaegi 0.9.19-1 0.9.21-1
yarn 1.22.10-1 1.22.11-1
youtube-dl 2021.06.06-1 -
yubikey-manager 4.0.3-2 4.0.5-1
zaz 1.0.0-9 1.0.1-1
b3sum - 1.0.0-2
cargo-expand - 1.0.8-1
fulcio - 0.1.1-1
gtkdatabox - 1.0.0-1
helix - 0.3.0-2
lua-language-server - 2.3.3-1
nitrocli - 0.4.1-1
pantheon-mail - 6.1.0-1
pantheon-notifications - 6.0.0-1
pantheon-onboarding - 6.0.0-1
pantheon-sideload - 6.0.0-1
python-fluidity - 0.2.1-1
python-gdstk - 0.6.1-1
python-glob2 - 0.7-1
python-jq - 1.2.1-1
python-lexicon - 1.0.0-1
python-pytest-bdd - 4.1.0-1
python-pytest-raises - 0.11-1
python-pyu2f - 0.1.5-1
python-should-dsl - 2.1.2-1
python-spec - 1.4.1-1
tea - 0.7.0-2
:: Different overlay package(s) in repository core aarch64
linux 5.13.4-1 5.13.7-1
linux-headers 5.13.4-1 5.13.7-1
linux-pinephone 5.12.19-1 5.13.7-1
linux-pinephone-headers 5.12.19-1 5.13.7-1
linux-quartz64 5.13.0-0.8 5.14.0-0.3
linux-quartz64-headers 5.13.0-0.8 5.14.0-0.3
linux-rc 5.14.rc2-3 5.14.rc4-1
linux-rc-headers 5.14.rc2-3 5.14.rc4-1
linux-rpi4 5.10.50-2 5.10.52-1
linux-rpi4-headers 5.10.50-2 5.10.52-1
manjaro-arm-keyring 20200210-1 20210731-1
manjaro-release 21.07-1 21.08-1
pacman 6.0.0-3 6.0.0-5
pacman-debug 6.0.0-3 6.0.0-5
uboot-pinebookpro 2021.07-1 2021.07-2
uboot-pinebookpro-bsp 1.5-9 1.5-10
uboot-quartz64-bsp 2017.09-0.6 2017.09-0.8
uboot-raspberrypi 2021.07-2 2021.07-3
uboot-rockpi4b 2021.07-1 2021.07-2
uboot-rockpi4c 2021.07-1 2021.07-2
uboot-rockpro64 2021.07-1 2021.07-2
:: Different sync package(s) in repository core aarch64
archlinux-keyring 20210616-1 20210802-1
audit 3.0.2-1 3.0.3-1
curl 7.77.0-1 7.78.0-1
e2fsprogs 1.46.2-1 1.46.3-1
inetutils 2.0-1 2.1-1
iputils 20210202-1 20210722-1
libcap-ng 0.8.2-1 0.8.2-3
libidn2 2.3.1-1 2.3.2-1
libldap 2.4.59-1 2.4.59-2
libnghttp2 1.43.0-1 1.44.0-1
logrotate 3.18.0-1 3.18.1-1
man-pages 5.12-1 5.12-2
openldap 2.4.59-1 2.4.59-2
perl 5.34.0-1 5.34.0-2
python-audit 3.0.2-1 3.0.3-1
sudo 1.9.7.p1-1 1.9.7.p2-1
systemd 249.1-1 249.2-1
systemd-libs 249.1-1 249.2-1
systemd-resolvconf 249.1-1 249.2-1
systemd-sysvcompat 249.1-1 249.2-1
util-linux 2.37-3 2.37.1-1
util-linux-libs 2.37-3 2.37.1-1
python-capng - 0.8.2-3
:: Different overlay package(s) in repository extra aarch64
archlinux-appstream-data 20210423-1 -
firefox 90.0.1-1 90.0.2-1
firefox-i18n-ach 90.0.1-1 90.0.2-1
firefox-i18n-af 90.0.1-1 90.0.2-1
firefox-i18n-an 90.0.1-1 90.0.2-1
firefox-i18n-ar 90.0.1-1 90.0.2-1
firefox-i18n-ast 90.0.1-1 90.0.2-1
firefox-i18n-az 90.0.1-1 90.0.2-1
firefox-i18n-be 90.0.1-1 90.0.2-1
firefox-i18n-bg 90.0.1-1 90.0.2-1
firefox-i18n-bn 90.0.1-1 90.0.2-1
firefox-i18n-br 90.0.1-1 90.0.2-1
firefox-i18n-bs 90.0.1-1 90.0.2-1
firefox-i18n-ca 90.0.1-1 90.0.2-1
firefox-i18n-cak 90.0.1-1 90.0.2-1
firefox-i18n-cs 90.0.1-1 90.0.2-1
firefox-i18n-cy 90.0.1-1 90.0.2-1
firefox-i18n-da 90.0.1-1 90.0.2-1
firefox-i18n-de 90.0.1-1 90.0.2-1
firefox-i18n-dsb 90.0.1-1 90.0.2-1
firefox-i18n-el 90.0.1-1 90.0.2-1
firefox-i18n-en-ca 90.0.1-1 90.0.2-1
firefox-i18n-en-gb 90.0.1-1 90.0.2-1
firefox-i18n-en-us 90.0.1-1 90.0.2-1
firefox-i18n-eo 90.0.1-1 90.0.2-1
firefox-i18n-es-ar 90.0.1-1 90.0.2-1
firefox-i18n-es-cl 90.0.1-1 90.0.2-1
firefox-i18n-es-es 90.0.1-1 90.0.2-1
firefox-i18n-es-mx 90.0.1-1 90.0.2-1
firefox-i18n-et 90.0.1-1 90.0.2-1
firefox-i18n-eu 90.0.1-1 90.0.2-1
firefox-i18n-fa 90.0.1-1 90.0.2-1
firefox-i18n-ff 90.0.1-1 90.0.2-1
firefox-i18n-fi 90.0.1-1 90.0.2-1
firefox-i18n-fr 90.0.1-1 90.0.2-1
firefox-i18n-fy-nl 90.0.1-1 90.0.2-1
firefox-i18n-ga-ie 90.0.1-1 90.0.2-1
firefox-i18n-gd 90.0.1-1 90.0.2-1
firefox-i18n-gl 90.0.1-1 90.0.2-1
firefox-i18n-gn 90.0.1-1 90.0.2-1
firefox-i18n-gu-in 90.0.1-1 90.0.2-1
firefox-i18n-he 90.0.1-1 90.0.2-1
firefox-i18n-hi-in 90.0.1-1 90.0.2-1
firefox-i18n-hr 90.0.1-1 90.0.2-1
firefox-i18n-hsb 90.0.1-1 90.0.2-1
firefox-i18n-hu 90.0.1-1 90.0.2-1
firefox-i18n-hy-am 90.0.1-1 90.0.2-1
firefox-i18n-ia 90.0.1-1 90.0.2-1
firefox-i18n-id 90.0.1-1 90.0.2-1
firefox-i18n-is 90.0.1-1 90.0.2-1
firefox-i18n-it 90.0.1-1 90.0.2-1
firefox-i18n-ja 90.0.1-1 90.0.2-1
firefox-i18n-ka 90.0.1-1 90.0.2-1
firefox-i18n-kab 90.0.1-1 90.0.2-1
firefox-i18n-kk 90.0.1-1 90.0.2-1
firefox-i18n-km 90.0.1-1 90.0.2-1
firefox-i18n-kn 90.0.1-1 90.0.2-1
firefox-i18n-ko 90.0.1-1 90.0.2-1
firefox-i18n-lij 90.0.1-1 90.0.2-1
firefox-i18n-lt 90.0.1-1 90.0.2-1
firefox-i18n-lv 90.0.1-1 90.0.2-1
firefox-i18n-mk 90.0.1-1 90.0.2-1
firefox-i18n-mr 90.0.1-1 90.0.2-1
firefox-i18n-ms 90.0.1-1 90.0.2-1
firefox-i18n-my 90.0.1-1 90.0.2-1
firefox-i18n-nb-no 90.0.1-1 90.0.2-1
firefox-i18n-ne-np 90.0.1-1 90.0.2-1
firefox-i18n-nl 90.0.1-1 90.0.2-1
firefox-i18n-nn-no 90.0.1-1 90.0.2-1
firefox-i18n-oc 90.0.1-1 90.0.2-1
firefox-i18n-pa-in 90.0.1-1 90.0.2-1
firefox-i18n-pl 90.0.1-1 90.0.2-1
firefox-i18n-pt-br 90.0.1-1 90.0.2-1
firefox-i18n-pt-pt 90.0.1-1 90.0.2-1
firefox-i18n-rm 90.0.1-1 90.0.2-1
firefox-i18n-ro 90.0.1-1 90.0.2-1
firefox-i18n-ru 90.0.1-1 90.0.2-1
firefox-i18n-si 90.0.1-1 90.0.2-1
firefox-i18n-sk 90.0.1-1 90.0.2-1
firefox-i18n-sl 90.0.1-1 90.0.2-1
firefox-i18n-son 90.0.1-1 90.0.2-1
firefox-i18n-sq 90.0.1-1 90.0.2-1
firefox-i18n-sr 90.0.1-1 90.0.2-1
firefox-i18n-sv-se 90.0.1-1 90.0.2-1
firefox-i18n-ta 90.0.1-1 90.0.2-1
firefox-i18n-te 90.0.1-1 90.0.2-1
firefox-i18n-th 90.0.1-1 90.0.2-1
firefox-i18n-tr 90.0.1-1 90.0.2-1
firefox-i18n-uk 90.0.1-1 90.0.2-1
firefox-i18n-ur 90.0.1-1 90.0.2-1
firefox-i18n-uz 90.0.1-1 90.0.2-1
firefox-i18n-vi 90.0.1-1 90.0.2-1
firefox-i18n-xh 90.0.1-1 90.0.2-1
firefox-i18n-zh-cn 90.0.1-1 90.0.2-1
firefox-i18n-zh-tw 90.0.1-1 90.0.2-1
libadwaita1.1.0.r1547.g660d529-1 -
mesa-git21.3.0_devel.142713.57dcfb4e553-121.3.0_devel.143163.f5b9d16823a-1
plasma-mobile-nm 5.22.3-1 5.22.4-1
plasma-nano 5.22.3-1 5.22.4-1
plasma-phone-components 5.22.3-1 5.22.4-1
qqc2-breeze-style 5.22.3-1 5.22.4-1
khealthcertificate - 21.07.0-0
:: Different sync package(s) in repository extra aarch64
389-ds-base 2.0.3-2 2.0.7-1
alsa-card-profiles 1:0.3.32-1 1:0.3.32-2
amf-headers 1.4.21-1 1.4.21-2
aom 3.1.1-1 3.1.2-1
aom-docs 3.1.1-1 3.1.2-1
appstream-glib 0.7.18-2 -
archlinux-appstream-data 20210612-1 20210723-1
audacious-plugins 4.1-3 4.1-4
bind 9.16.18-1 9.16.19-1
bluedevil 1:5.22.3-1 1:5.22.4-1
booster 0.5-1 0.6-1
breeze 5.22.3-1 5.22.4-1
breeze-grub 5.22.3-1 5.22.4-1
breeze-gtk 5.22.3-1 5.22.4-1
brltty 6.3-3 6.3-4
calligra 3.2.1-17 3.2.1-18
cantor 21.04.3-1 21.04.3-2
cbindgen 0.19.0-1 0.20.0-1
chromium 91.0.4472.164-1 92.0.4515.107-3
clazy 1.9-3 1.10-1
cmake 3.21.0-1 3.21.1-1
composer 2.1.3-1 2.1.5-1
dbus-python 1.2.16-4 1.2.18-1
digikam 7.3.0-2 7.3.0-4
discover 5.22.3-1 5.22.4-1
drkonqi 5.22.3-1 5.22.4-1
ell 0.41-1 0.42-1
evince 40.3-1 40.4-1
f2fs-tools 1.14.0-1 1.14.0-2
facile 1.1.3-12 1.1.3-13
feh 3.7-1 3.7.1-1
fluidsynth 2.1.8-1 2.2.2-1
fmt 8.0.0-2 8.0.1-1
gdk-pixbuf2 2.42.6-1 2.42.6-2
gdk-pixbuf2-docs 2.42.6-1 2.42.6-2
gdm 40.0-1 40.1-1
gegl 0.4.30-4 0.4.30-5
geoip-database 20210622-1 20210727-1
geoip-database-extra 20210622-1 20210727-1
gnome-desktop 1:40.2-1 1:40.3-1
gnome-sudoku 40.1-1 40.2-1
graphviz 2.48.0-1 2.48.0-2
gst-plugin-opencv 1.18.4-9 1.18.4-10
gst-plugin-pipewire 1:0.3.32-1 1:0.3.32-2
gst-plugin-wpe 1.18.4-9 1.18.4-10
gst-plugins-bad 1.18.4-9 1.18.4-10
gst-plugins-bad-libs 1.18.4-9 1.18.4-10
imath 3.1.0-1 3.1.2-1
imlib2 1.7.1-1 1.7.2-1
inkscape 1.1-4 1.1-5
ipset 7.12-1 7.14-1
jack 0.125.0-9 -
jdk-openjdk 16.0.1.u9-1 16.0.2.u7-1
jdk11-openjdk 11.0.11.u9-1 11.0.12.u7-1
jre-openjdk 16.0.1.u9-1 16.0.2.u7-1
jre-openjdk-headless 16.0.1.u9-1 16.0.2.u7-1
jre11-openjdk 11.0.11.u9-1 11.0.12.u7-1
jre11-openjdk-headless 11.0.11.u9-1 11.0.12.u7-1
kactivitymanagerd 5.22.3-1 5.22.4-1
kde-cli-tools 5.22.3-1 5.22.4-1
kde-gtk-config 5.22.3-1 5.22.4-1
kdecoration 5.22.3-1 5.22.4-1
kdeplasma-addons 5.22.3-1 5.22.4-1
kgamma5 5.22.3-1 5.22.4-1
khotkeys 5.22.3-1 5.22.4-1
kinfocenter 5.22.3-1 5.22.4-1
kitinerary 21.04.3-1 21.04.3-2
kmenuedit 5.22.3-1 5.22.4-1
kscreen 5.22.3-1 5.22.4-1
kscreenlocker 5.22.3-1 5.22.4-1
ksshaskpass 5.22.3-1 5.22.4-1
ksystemstats 5.22.3-1 5.22.4-1
kwallet-pam 5.22.3-1 5.22.4-1
kwayland-integration 5.22.3-1 5.22.4-1
kwayland-server 5.22.3-1 5.22.4-1
kwin 5.22.3-1 5.22.4-1
kwrited 5.22.3-1 5.22.4-1
lablgtk2 2.18.11-6 2.18.11-7
layer-shell-qt 5.22.3-1 5.22.4-1
ldb 1:2.3.0-1 2:2.3.0-1
libadwaita 1.0.0alpha.1-1 1.0.0alpha.2-1
libadwaita-docs 1.0.0alpha.1-1 1.0.0alpha.2-1
libbytesize 2.5-1 2.6-1
libfprint 1.92.0-1 1.92.1-1
libgdm 40.0-1 40.1-1
libgnt 2.14.1-1 2.14.2-1
libidn 1.37-1 1.38-1
libkscreen 5.22.3-1 5.22.4-1
libksysguard 5.22.3-1 5.22.4-1
libmbim 1.24.8-1 1.26.0-1
libmm-glib 1.16.6-1 1.16.8-1
libnm 1.32.4-1 -
libpulse 14.2-3 15.0-1
libqalculate 3.19.0-1 3.20.1-1
libreoffice-fresh 7.1.4-1 7.1.5-2
libreoffice-fresh-af 7.1.4-1 7.1.5-1
libreoffice-fresh-am 7.1.4-1 7.1.5-1
libreoffice-fresh-ar 7.1.4-1 7.1.5-1
libreoffice-fresh-as 7.1.4-1 7.1.5-1
libreoffice-fresh-ast 7.1.4-1 7.1.5-1
libreoffice-fresh-be 7.1.4-1 7.1.5-1
libreoffice-fresh-bg 7.1.4-1 7.1.5-1
libreoffice-fresh-bn 7.1.4-1 7.1.5-1
libreoffice-fresh-bn-in 7.1.4-1 7.1.5-1
libreoffice-fresh-bo 7.1.4-1 7.1.5-1
libreoffice-fresh-br 7.1.4-1 7.1.5-1
libreoffice-fresh-brx 7.1.4-1 7.1.5-1
libreoffice-fresh-bs 7.1.4-1 7.1.5-1
libreoffice-fresh-ca 7.1.4-1 7.1.5-1
libreoffice-fresh-ca-valencia 7.1.4-1 7.1.5-1
libreoffice-fresh-ckb 7.1.4-1 7.1.5-1
libreoffice-fresh-cs 7.1.4-1 7.1.5-1
libreoffice-fresh-cy 7.1.4-1 7.1.5-1
libreoffice-fresh-da 7.1.4-1 7.1.5-1
libreoffice-fresh-de 7.1.4-1 7.1.5-1
libreoffice-fresh-dgo 7.1.4-1 7.1.5-1
libreoffice-fresh-dsb 7.1.4-1 7.1.5-1
libreoffice-fresh-dz 7.1.4-1 7.1.5-1
libreoffice-fresh-el 7.1.4-1 7.1.5-1
libreoffice-fresh-en-gb 7.1.4-1 7.1.5-1
libreoffice-fresh-en-za 7.1.4-1 7.1.5-1
libreoffice-fresh-eo 7.1.4-1 7.1.5-1
libreoffice-fresh-es 7.1.4-1 7.1.5-1
libreoffice-fresh-et 7.1.4-1 7.1.5-1
libreoffice-fresh-eu 7.1.4-1 7.1.5-1
libreoffice-fresh-fa 7.1.4-1 7.1.5-1
libreoffice-fresh-fi 7.1.4-1 7.1.5-1
libreoffice-fresh-fr 7.1.4-1 7.1.5-1
libreoffice-fresh-fur 7.1.4-1 7.1.5-1
libreoffice-fresh-fy 7.1.4-1 7.1.5-1
libreoffice-fresh-ga 7.1.4-1 7.1.5-1
libreoffice-fresh-gd 7.1.4-1 7.1.5-1
libreoffice-fresh-gl 7.1.4-1 7.1.5-1
libreoffice-fresh-gu 7.1.4-1 7.1.5-1
libreoffice-fresh-gug 7.1.4-1 7.1.5-1
libreoffice-fresh-he 7.1.4-1 7.1.5-1
libreoffice-fresh-hi 7.1.4-1 7.1.5-1
libreoffice-fresh-hr 7.1.4-1 7.1.5-1
libreoffice-fresh-hsb 7.1.4-1 7.1.5-1
libreoffice-fresh-hu 7.1.4-1 7.1.5-1
libreoffice-fresh-id 7.1.4-1 7.1.5-1
libreoffice-fresh-is 7.1.4-1 7.1.5-1
libreoffice-fresh-it 7.1.4-1 7.1.5-1
libreoffice-fresh-ja 7.1.4-1 7.1.5-1
libreoffice-fresh-ka 7.1.4-1 7.1.5-1
libreoffice-fresh-kab 7.1.4-1 7.1.5-1
libreoffice-fresh-kk 7.1.4-1 7.1.5-1
libreoffice-fresh-km 7.1.4-1 7.1.5-1
libreoffice-fresh-kmr-latn 7.1.4-1 7.1.5-1
libreoffice-fresh-kn 7.1.4-1 7.1.5-1
libreoffice-fresh-ko 7.1.4-1 7.1.5-1
libreoffice-fresh-kok 7.1.4-1 7.1.5-1
libreoffice-fresh-ks 7.1.4-1 7.1.5-1
libreoffice-fresh-lb 7.1.4-1 7.1.5-1
libreoffice-fresh-lo 7.1.4-1 7.1.5-1
libreoffice-fresh-lt 7.1.4-1 7.1.5-1
libreoffice-fresh-lv 7.1.4-1 7.1.5-1
libreoffice-fresh-mai 7.1.4-1 7.1.5-1
libreoffice-fresh-mk 7.1.4-1 7.1.5-1
libreoffice-fresh-ml 7.1.4-1 7.1.5-1
libreoffice-fresh-mn 7.1.4-1 7.1.5-1
libreoffice-fresh-mni 7.1.4-1 7.1.5-1
libreoffice-fresh-mr 7.1.4-1 7.1.5-1
libreoffice-fresh-my 7.1.4-1 7.1.5-1
libreoffice-fresh-nb 7.1.4-1 7.1.5-1
libreoffice-fresh-ne 7.1.4-1 7.1.5-1
libreoffice-fresh-nl 7.1.4-1 7.1.5-1
libreoffice-fresh-nn 7.1.4-1 7.1.5-1
libreoffice-fresh-nr 7.1.4-1 7.1.5-1
libreoffice-fresh-nso 7.1.4-1 7.1.5-1
libreoffice-fresh-oc 7.1.4-1 7.1.5-1
libreoffice-fresh-om 7.1.4-1 7.1.5-1
libreoffice-fresh-or 7.1.4-1 7.1.5-1
libreoffice-fresh-pa-in 7.1.4-1 7.1.5-1
libreoffice-fresh-pl 7.1.4-1 7.1.5-1
libreoffice-fresh-pt 7.1.4-1 7.1.5-1
libreoffice-fresh-pt-br 7.1.4-1 7.1.5-1
libreoffice-fresh-ro 7.1.4-1 7.1.5-1
libreoffice-fresh-ru 7.1.4-1 7.1.5-1
libreoffice-fresh-rw 7.1.4-1 7.1.5-1
libreoffice-fresh-sa-in 7.1.4-1 7.1.5-1
libreoffice-fresh-sat 7.1.4-1 7.1.5-1
libreoffice-fresh-sd 7.1.4-1 7.1.5-1
libreoffice-fresh-sdk 7.1.4-1 7.1.5-2
libreoffice-fresh-si 7.1.4-1 7.1.5-1
libreoffice-fresh-sid 7.1.4-1 7.1.5-1
libreoffice-fresh-sk 7.1.4-1 7.1.5-1
libreoffice-fresh-sl 7.1.4-1 7.1.5-1
libreoffice-fresh-sq 7.1.4-1 7.1.5-1
libreoffice-fresh-sr 7.1.4-1 7.1.5-1
libreoffice-fresh-sr-latn 7.1.4-1 7.1.5-1
libreoffice-fresh-ss 7.1.4-1 7.1.5-1
libreoffice-fresh-st 7.1.4-1 7.1.5-1
libreoffice-fresh-sv 7.1.4-1 7.1.5-1
libreoffice-fresh-sw-tz 7.1.4-1 7.1.5-1
libreoffice-fresh-szl 7.1.4-1 7.1.5-1
libreoffice-fresh-ta 7.1.4-1 7.1.5-1
libreoffice-fresh-te 7.1.4-1 7.1.5-1
libreoffice-fresh-tg 7.1.4-1 7.1.5-1
libreoffice-fresh-th 7.1.4-1 7.1.5-1
libreoffice-fresh-tn 7.1.4-1 7.1.5-1
libreoffice-fresh-tr 7.1.4-1 7.1.5-1
libreoffice-fresh-ts 7.1.4-1 7.1.5-1
libreoffice-fresh-tt 7.1.4-1 7.1.5-1
libreoffice-fresh-ug 7.1.4-1 7.1.5-1
libreoffice-fresh-uk 7.1.4-1 7.1.5-1
libreoffice-fresh-uz 7.1.4-1 7.1.5-1
libreoffice-fresh-ve 7.1.4-1 7.1.5-1
libreoffice-fresh-vec 7.1.4-1 7.1.5-1
libreoffice-fresh-vi 7.1.4-1 7.1.5-1
libreoffice-fresh-xh 7.1.4-1 7.1.5-1
libreoffice-fresh-zh-cn 7.1.4-1 7.1.5-1
libreoffice-fresh-zh-tw 7.1.4-1 7.1.5-1
libreoffice-fresh-zu 7.1.4-1 7.1.5-1
libreoffice-still 7.0.6-3 7.0.6-4
libreoffice-still-sdk 7.0.6-3 7.0.6-4
libsidplayfp 2.2.0-1 2.2.1-1
libva-mesa-driver 21.1.5-1 21.1.6-1
libxfont2 2.0.4-3 2.0.5-1
libxft 2.3.3-2 2.3.4-1
live-media 2021.04.06-2 2021.07.20-1
llvm 12.0.1-1 12.0.1-2
llvm-libs 12.0.1-1 12.0.1-2
llvm-ocaml 12.0.1-1 12.0.1-2
malcontent 0.9.0-1 0.10.1-1
memcached 1.6.9-1 1.6.10-1
mesa 21.1.5-1 21.1.6-1
mesa-vdpau 21.1.5-1 21.1.6-1
meson 0.58.1-1 0.59.0-2
milou 5.22.3-1 5.22.4-1
minuet 21.04.3-1 21.04.3-2
mkvtoolnix-cli 58.0.0-6 60.0.0-1
mkvtoolnix-gui 58.0.0-6 60.0.0-1
modemmanager 1.16.6-1 1.16.8-1
mousepad 0.5.5-3 0.5.6-1
mpd 0.22.9-1 0.22.9-2
mtools 1:4.0.33-1 1:4.0.34-1
networkmanager 1.32.4-1 -
nftables 1:0.9.9-1 1:0.9.9-6
nm-cloud-setup 1.32.4-1 -
nss-mdns 0.14.1-3 0.15.1-1
ocaml 4.11.1-1 4.12.0-1
ocaml-compiler-libs 4.11.1-1 4.12.0-1
ocaml-ctypes 0.17.1-5 0.17.1-6
ocaml-integers 0.4.0-3 0.4.0-4
ocaml-result 1.5-3 1.5-4
ocaml-topkg 1.0.3-1 1.0.3-2
ocamlbuild 0.14.0-9 0.14.0-10
okular 21.04.3-2 -
opencl-mesa 21.1.5-1 21.1.6-1
openjdk-src 16.0.1.u9-1 16.0.2.u7-1
openjdk11-src 11.0.11.u9-1 11.0.12.u7-1
oxygen 5.22.3-1 5.22.4-1
perl-dbd-sqlite 1.66-2 1.70-1
php 8.0.8-1 8.0.9-1
php-apache 8.0.8-1 8.0.9-1
php-cgi 8.0.8-1 8.0.9-1
php-dblib 8.0.8-1 8.0.9-1
php-embed 8.0.8-1 8.0.9-1
php-enchant 8.0.8-1 8.0.9-1
php-fpm 8.0.8-1 8.0.9-1
php-gd 8.0.8-1 8.0.9-1
php-imap 8.0.8-1 8.0.9-1
php-intl 8.0.8-1 8.0.9-1
php-odbc 8.0.8-1 8.0.9-1
php-pgsql 8.0.8-1 8.0.9-1
php-phpdbg 8.0.8-1 8.0.9-1
php-pspell 8.0.8-1 8.0.9-1
php-snmp 8.0.8-1 8.0.9-1
php-sodium 8.0.8-1 8.0.9-1
php-sqlite 8.0.8-1 8.0.9-1
php-tidy 8.0.8-1 8.0.9-1
php-xsl 8.0.8-1 8.0.9-1
php7 7.4.21-1 7.4.22-1
php7-apache 7.4.21-1 7.4.22-1
php7-cgi 7.4.21-1 7.4.22-1
php7-dblib 7.4.21-1 7.4.22-1
php7-embed 7.4.21-1 7.4.22-1
php7-enchant 7.4.21-1 7.4.22-1
php7-fpm 7.4.21-1 7.4.22-1
php7-gd 7.4.21-1 7.4.22-1
php7-imap 7.4.21-1 7.4.22-1
php7-intl 7.4.21-1 7.4.22-1
php7-odbc 7.4.21-1 7.4.22-1
php7-pgsql 7.4.21-1 7.4.22-1
php7-phpdbg 7.4.21-1 7.4.22-1
php7-pspell 7.4.21-1 7.4.22-1
php7-snmp 7.4.21-1 7.4.22-1
php7-sodium 7.4.21-1 7.4.22-1
php7-sqlite 7.4.21-1 7.4.22-1
php7-tidy 7.4.21-1 7.4.22-1
php7-xsl 7.4.21-1 7.4.22-1
pipewire-alsa 1:0.3.32-1 1:0.3.32-2
pipewire-docs 1:0.3.32-1 1:0.3.32-2
pipewire-jack 1:0.3.32-1 1:0.3.32-2
pipewire-media-session 1:0.3.32-1 1:0.3.32-2
pipewire-pulse 1:0.3.32-1 1:0.3.32-2
pipewire-zeroconf 1:0.3.32-1 1:0.3.32-2
plasma-browser-integration 5.22.3-1 5.22.4-1
plasma-desktop 5.22.3-1 5.22.4-1
plasma-disks 5.22.3-1 5.22.4-1
plasma-firewall 5.22.3-1 5.22.4-1
plasma-integration 5.22.3-1 5.22.4-1
plasma-nm 5.22.3-1 5.22.4-1
plasma-pa 5.22.3-1 5.22.4-1
plasma-sdk 5.22.3-1 5.22.4-1
plasma-systemmonitor 5.22.3-2 5.22.4-1
plasma-thunderbolt 5.22.3-1 5.22.4-1
plasma-vault 5.22.3-1 5.22.4-1
plasma-wayland-session 5.22.3-1 5.22.4-2
plasma-workspace 5.22.3-1 5.22.4-2
plasma-workspace-wallpapers 5.22.3-1 5.22.4-1
polkit-kde-agent 5.22.3-1 5.22.4-1
poppler 21.07.0-1 21.08.0-1
poppler-glib 21.07.0-1 21.08.0-1
poppler-qt5 21.07.0-1 21.08.0-1
poppler-qt6 21.07.0-1 21.08.0-1
postfix 3.6.1-1 3.6.2-1
postfix-cdb 3.6.1-1 3.6.2-1
postfix-ldap 3.6.1-1 3.6.2-1
postfix-lmdb 3.6.1-1 3.6.2-1
postfix-mysql 3.6.1-1 3.6.2-1
postfix-pcre 3.6.1-1 3.6.2-1
postfix-pgsql 3.6.1-1 3.6.2-1
postfix-sqlite 3.6.1-1 3.6.2-1
powerdevil 5.22.3-1 5.22.4-1
pulseaudio 14.2-3 15.0-1
pulseaudio-bluetooth 14.2-3 15.0-1
pulseaudio-equalizer 14.2-3 15.0-1
pulseaudio-jack 14.2-3 15.0-1
pulseaudio-lirc 14.2-3 15.0-1
pulseaudio-rtp 14.2-3 15.0-1
pulseaudio-zeroconf 14.2-3 15.0-1
pytest-pacman 0.1-1 0.1-2
python-astroid 2.5.8-1 2.6.1-1
python-dbusmock 0.23.0-1 0.23.1-1
python-fastimport 0.9.12-1 0.9.13-1
python-pylint 2.7.4-1 2.8.1-1
python-requests 2.25.1-1 2.26.0-1
python-tomli 1.0.4-1 1.1.0-2
python2-requests 2.25.1-1 2.26.0-1
qalculate-gtk 3.19.0-1 3.20.1-1
qbs 1.19.1-1 1.19.2-1
qt5-3d 5.15.2+kde+r25-1 5.15.2+kde+r26-1
qt5-base 5.15.2+kde+r210-1 5.15.2+kde+r211-1
qt5-xcb-private-headers 5.15.2+kde+r210-1 5.15.2+kde+r211-1
rebuilderd-website 0.5.3-1 0.5.4-1
rsync 3.2.3-3 3.2.3-4
rust 1:1.53.0-2 1:1.54.0-1
rust-docs 1:1.53.0-2 1:1.54.0-1
sbcl 2.1.1-1 2.1.7-1
scons 4.1.0-2 4.2.0-1
sddm-kcm 5.22.3-1 5.22.4-1
step 21.04.3-1 21.04.3-2
strace 5.12-1 5.13-1
systemsettings 5.22.3-1 5.22.4-1
tdb 1.4.4-1 1.4.5-1
tevent 1:0.10.2-3 1:0.11.0-1
tomcat10 10.0.8-1 10.0.10-1
tomcat9 9.0.50-1 9.0.52-1
vulkan-broadcom 21.1.5-1 21.1.6-1
vulkan-headers 1:1.2.184-1 1:1.2.185-1
vulkan-icd-loader 1.2.184-1 1.2.185-1
vulkan-mesa-layers 21.1.5-1 21.1.6-1
vulkan-radeon 21.1.5-1 21.1.6-1
vulkan-swrast 21.1.5-1 21.1.6-1
webkit2gtk 2.32.2-1 2.32.3-1
wpewebkit 2.32.2-1 2.32.3-1
xdg-desktop-portal-kde 5.22.3-1 5.22.4-1
xf86-video-amdgpu 19.1.0-2 21.0.0-1
xfce4-sensors-plugin 1.3.95-1 1.4.1-1
xorg-server 1.20.12-1 1.20.13-1
xorg-server-common 1.20.12-1 1.20.13-1
xorg-server-devel 1.20.12-1 1.20.13-1
xorg-server-xephyr 1.20.12-1 1.20.13-1
xorg-server-xnest 1.20.12-1 1.20.13-1
xorg-server-xvfb 1.20.12-1 1.20.13-1
xorg-xeyes 1.1.2-2 1.2.0-1
xorg-xwd 1.0.7-2 1.0.8-1
zabbix-agent 5.4.2-1 5.4.3-1
zabbix-agent2 5.4.2-1 5.4.3-1
zabbix-frontend-php 5.4.2-1 5.4.3-1
zabbix-proxy 5.4.2-1 5.4.3-1
zabbix-server 5.4.2-1 5.4.3-1
jack2 - 1.9.19-2
jack2-dbus - 1.9.19-2
libfreeaptx - 0.1.1-1
mkinitcpio-archiso - 58-1
squashfs-tools - 4.5-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi21.04.3.r12527.g78ccf477a-121.04.3.r12533.g61dc5a751-1
akonadi-calendar21.04.3.r1958.gbaae021-121.04.3.r1959.g76c6501-1
akonadi-calendar-tools21.04.3.r876.g6b18da3-121.04.3.r878.gb2ab190-1
akonadi-contacts21.04.3.r3027.g7dd573ce-121.04.3.r3028.g76b0d406-1
akonadi-import-wizard21.04.3.r1720.gf4ac9fa-121.04.3.r1722.g75337ed-1
akonadi-mime21.04.3.r1630.g5012eb8-121.04.3.r1631.g7fc4fcf-1
akonadi-notes21.04.3.r1014.g4dc5575-121.04.3.r1015.gc21120f-1
akonadi-search21.04.3.r1107.g26c21d0-121.04.3.r1110.g10b87f2-1
akonadiconsole21.04.3.r1501.g7eef7f3-121.04.3.r1502.gfa07fb0-1
akregator21.04.3.r6188.g12c82b62-121.04.3.r6192.gd8d346aa-1
alligator 21.06.r11.g7c37563-1 21.07.r0.g7c37563-1
angelfish 21.06.r26.g6c07c3d-1 21.07.r3.ga434e27-1
ark21.04.3.r4604.g6548b395-121.04.3.r4608.g8f550c80-1
baloo5.84.0.r2995.gc28a53c6-15.84.0.r2996.g99b5b4dc-1
baloo-widgets21.04.3.r680.g5a3b20a-121.04.3.r684.g3396374-1
bluedevil1:5.22.3.r2269.gfaade374-11:5.22.4.r2274.gc428cb0e-1
bomber21.04.3.r519.g0902c55-121.04.3.r520.g3512757-1
breeze5.22.3.r2222.g5b0ea0f6-15.22.4.r2225.g5c385621-1
breeze-grub5.22.3.r11.g63136a9-15.22.4.r11.g63136a9-1
breeze-gtk5.22.3.r420.gfccd7df-15.22.4.r420.gfccd7df-1
breeze-icons5.84.0.r1759.ge396413f-15.84.0.r1766.g2f468e61-1
buho 1.2.2.r31.g0db48ec-1 1.2.2.r36.g54ea38b-1
calendarsupport21.04.3.r567.ga773765-121.07.80.r12.gcfa15bb-1
calindori 21.06.r13.g08c5859-1 21.07.r2.g9becb13-1
discover5.22.3.r8234.ga75a100c-15.22.4.r8247.g1c28a1cc-1
dolphin21.04.3.r6656.g32c1bd718-121.04.3.r6661.g393c659c9-1
dolphin-plugins21.04.3.r593.g87e219d-121.04.3.r597.g81a72bf-1
drkonqi5.22.3.r672.gf511b225-15.22.4.r672.gf511b225-1
elisa21.04.3.r2736.g7fb3d070-121.04.3.r2742.g77152c3a-1
eventviews21.04.3.r670.g381f3ec-121.07.80.r11.g092aeb4-1
extra-cmake-modules5.84.0.r3351.g027797a-15.84.0.r3352.g72e9fb9-1
filelight21.04.3.r978.gd62b437-121.04.3.r979.ge2f90c0-1
frameworkintegration5.84.0.r589.g4aa5e78-15.84.0.r590.g83123c6-1
grantlee-editor21.04.3.r757.gd920171-121.04.3.r759.g0890ce9-1
grantleetheme21.04.3.r332.gc2d1dd4-121.04.3.r333.g20debce-1
gwenview21.04.3.r6646.g5681c504-121.04.3.r6650.gb292af50-1
incidenceeditor21.04.3.r743.gf49fe33-121.04.3.r748.g454e216-1
index-fm 1.2.2.r99.gace6e6b-11.2.2.r116.g826fde5-1
itinerary21.04.3.r1378.gfff8e96-121.04.3.r1400.gd9cfd32-1
k3b1:21.04.3.r6654.gc63fd9665-11:21.04.3.r6660.g56fed98f6-1
kaccounts-integration21.04.3.r1210.g7660f66-121.04.3.r1212.g7571d86-1
kaccounts-providers21.04.3.r382.g2f7fb54-121.04.3.r383.gaf778e5-1
kactivitymanagerd5.22.3.r1355.g9cabb88-15.22.4.r1360.gb3214fa-1
kaddressbook21.04.2.r5991.gbb5f088e-121.04.3.r6007.gc027d7fd-1
kalarm21.04.3.r6410.g503c8fd5-121.04.3.r6431.gb64ccf88-1
kalarmcal21.04.3.r1123.gc773ba4-121.04.3.r1134.g73e5c63-1
kalk 21.06.r10.g2412914-1 21.07.r2.g9bb86f2-1
kamera21.04.3.r654.g9eadd76-121.04.3.r655.g975c8f5-1
kamoso21.04.3.r1427.gfda571b-121.04.3.r1428.gda4ba0d-1
kanagram21.04.3.r1280.g871912c-121.04.3.r1283.g2bd976e-1
kapidox5.84.0.r542.g0326b90-15.84.0.r548.gcf9ced6-1
kapman21.04.3.r601.g19d549f-121.04.3.r602.gdf5602c-1
kapptemplate21.04.3.r953.g27f61d7-121.04.3.r954.g39dbb12-1
karchive5.84.0.r496.ge657605-15.84.0.r498.g9ab5f2b-1
kasts 21.06.r78.gfc99ec5-1 21.07.r7.g0b33c62-1
kate21.04.3.r18293.gd317129cd-121.04.3.r18306.gd3dd58cb9-1
kbackup21.04.3.r387.g54d03c1-121.04.3.r389.g54a4a86-1
kblocks21.04.3.r664.g59ca52a-121.04.3.r665.gc497aa0-1
kcalc21.04.3.r1510.g22dd01f-121.04.3.r1511.g6e9f4ed-1
kcalendarcore5.84.0.r1226.g92da321bd-15.84.0.r1227.gaa08db3d6-1
kcalutils21.04.3.r855.g697195969-121.04.3.r856.ga2b6d716f-1
kclock 21.06.r28.g71d7c4b-1 21.07.r23.g34b2ae8-1
kcmutils5.84.0.r528.ge7ef632-15.84.0.r531.g2fdc32c-1
kcolorchooser21.04.3.r224.g29e79c1-121.04.3.r225.gf937de8-1
kconfigwidgets5.84.0.r599.g83a1edf-15.84.0.r605.g9fc356a-1
kcoreaddons5.84.0.r1247.gc1eea322-15.84.0.r1251.g4a24d363-1
kcrash5.84.0.r402.g701cd36-15.84.0.r403.gdc45a01-1
kcron21.04.3.r775.g91d5a01-121.04.3.r776.gc138442-1
kde-cli-tools5.22.3.r1845.gddccf63-15.22.4.r1856.gd940b78-1
kde-dev-utils21.04.3.r556.g6d918c3-121.04.3.r558.geff6b70-1
kde-gtk-config5.22.3.r895.g93da65a-15.22.4.r898.g6b2c211-1
kdebugsettings21.04.3.r831.g82ea95e-121.04.3.r833.g66b577d-1
kdeclarative5.84.0.r903.g9f07247-15.84.0.r905.g5db5b88-1
kdeconnect21.04.3.r3289.gac53f3f3-121.04.3.r3302.gcf8ada2b-1
kdecoration5.22.3.r268.g1dabf57-15.22.4.r268.g1dabf57-1
kdegraphics-thumbnailers21.04.3.r233.g3f941f1-121.04.3.r234.gb335558-1
kdelibs4support5.84.0.r1027.gbd5c6518-15.84.0.r1029.gf886651a-1
kdepim-addons21.04.2.r4239.g4180eccf-121.04.3.r4239.g4180eccf-1
kdepim-runtime21.04.3.r15148.g47b49d185-121.04.3.r15152.gdeb4e7272-1
kdeplasma-addons5.22.3.r8557.g718cbaede-15.22.4.r8568.g547d4c76a-1
kdialog21.04.3.r1183.g3c9c5e3a9-121.04.3.r1184.g4c144a1f6-1
kdisplay5.22.0.r1448.g0cb3d65-15.22.0.r1450.g1fa20e2-1
kdoctools5.84.0.r616.g1a544d9-15.84.0.r617.g7f217be-1
kemoticons5.84.0.r378.gd8d5133-15.84.0.r379.gde2d0fb-1
keysmith 21.06.r8.g818ed69-1 21.07.r3.g3c0fc62-1
kgamma55.22.3.r456.g5885d2f-15.22.4.r456.g5885d2f-1
kget21.04.3.r3117.g003064ad-121.04.3.r3118.g0012b007-1
kgoldrunner21.04.3.r1236.gb6c375d-121.04.3.r1237.gc613e06-1
khelpcenter21.04.3.r2673.gc8241571-121.04.3.r2675.g0657272e-1
kholidays1:5.84.0.r945.ga00d0fe-11:5.84.0.r952.g8b43e99-1
khotkeys5.22.3.r2078.ge95171d-15.22.4.r2086.g1b06be5-1
kidentitymanagement21.04.3.r3795.g5a86412f-121.04.3.r3797.ge8dad504-1
kimageformats5.84.0.r347.g7f56d83-15.84.0.r348.gfbeef55-1
kimap21.04.3.r1101.ge0538b4-121.04.3.r1102.g08437b8-1
kinfocenter5.22.3.r1861.g07fdf4a-15.22.4.r1865.g8a215f1-1
kinit5.84.0.r405.ge6668c4-15.84.0.r406.g2a5d047-1
kio5.84.0.r4857.gf070c2a8-15.84.0.r4874.g2c01ea96-1
kio-extras21.04.3.r7092.g2f2f6253-121.04.3.r7096.g1d2655f1-1
kio-gdrive21.04.3.r562.g7b06d00-121.04.3.r564.g20d635f-1
kirigami-addons 0.2.r36.gb197d98-1 1:0.2.r6.gc4f3e01-1
kirigami25.84.0.r2840.gbdfac7d0-15.84.0.r2846.g537e2132-1
kitinerary21.04.3.r1832.g964e622-121.04.3.r1860.g236a36f-1
kldap21.04.3.r869.g4ae869e-121.04.3.r872.g1a0513d-1
kleopatra21.04.3.r5913.gbb92dfd2-121.04.3.r5915.g9de140ce-1
klettres21.04.3.r912.g6f0aff5-121.04.3.r913.gda6529b-1
klines21.04.3.r755.g37f5f5f-121.04.3.r761.g2b02c75-1
kmail21.04.2.r25806.g4b85ab9c2-121.04.3.r25854.gfcf8afc62-1
kmail-account-wizard21.04.3.r791.gd0b9f1a-121.04.3.r795.g35d4ddf-1
kmailtransport21.04.3.r1619.gae8911b-121.04.3.r1620.g74fa6eb-1
kmbox21.04.3.r529.geffe162-121.04.3.r531.g0315daf-1
kmenuedit5.22.3.r968.g2742003-15.22.4.r968.g2742003-1
kmime21.04.3.r1441.gebb0fc1-121.04.3.r1443.g30e622a-1
kmines21.04.3.r1715.g58f37a8-121.04.3.r1716.ga7fef85-1
kmix21.04.3.r2372.g04491098-121.04.3.r2374.g9f1eeb70-1
kmousetool21.04.3.r387.g3e256a8-121.04.3.r388.gc4b2d98-1
kmplot21.04.3.r1459.g6cdacb6-121.04.3.r1461.g2a626fb-1
knetwalk21.04.3.r651.g71b9db7-121.04.3.r654.g85a36d1-1
knewstuff5.84.0.r1186.g6c373eb2-15.84.0.r1188.g54d6dcab-1
knotes21.04.3.r3473.g1891433d-121.04.3.r3477.g02cd958d-1
koko 21.06.r23.g1b02c9d-1 21.07.r7.g7f7d241-1
kolourpaint21.04.3.r2349.g5849a5f2-121.04.3.r2350.g48141741-1
kongress 21.06.r7.g8150560-1 21.07.r0.g8150560-1
konqueror21.04.3.r14917.gd825e73d9-121.04.3.r14922.g7c14c663d-1
konsole21.04.3.r7892.gfb69c183-121.04.3.r7908.g414f933f-1
kontact21.04.3.r5346.ged3f1b15-121.04.3.r5351.g1ebc9a57-1
kontactinterface21.04.3.r621.g7bec405-121.04.3.r623.g4f8ba48-1
kontrast21.04.3.r169.gb64bb54-121.04.3.r170.gc62ac8f-1
konversation21.04.3.r8987.geb3708e7-121.04.3.r8988.ge7560658-1
korganizer21.04.3.r11410.ge4b327b64-121.04.3.r11428.gae4950ddc-1
kpackage5.84.0.r683.g0aaf95f-15.84.0.r684.g7b77a77-1
kparts5.84.0.r514.g8b81bf4-15.84.0.r515.g5d0c684-1
kpat21.04.3.r2559.g1b5eda1-121.04.3.r2560.g40ec2ed-1
kpimtextedit21.04.3.r1393.g3874363-121.04.3.r1394.gab26ddd-1
kpkpass21.04.3.r229.g16211f8-121.04.3.r230.g394482f-1
kpublictransport21.04.2.r1692.g7d976ae5-121.04.3.r1703.gf36365e-1
krdc21.04.3.r1529.gdb18bb3-121.04.3.r1531.gd7c1899-1
krecorder 21.06.r7.gb90079d-1 21.07.r2.gfd5e12a-1
kruler21.04.3.r691.gbdd7e07-121.04.3.r692.gf64ae61-1
krunner5.84.0.r646.ge067c4f-15.84.0.r650.gcc01f58-1
kscreen5.22.3.r1337.g413adfe-15.22.4.r1338.g845c8ab-1
kscreenlocker5.22.3.r858.gf78ccfc-15.22.4.r861.g7964776-1
kservice5.84.0.r924.g0b569b0-15.84.0.r925.gc2cedaa-1
ksmtp21.04.3.r358.g5969962-121.04.3.r359.g4c722cc-1
ksshaskpass5.22.3.r196.gdaa2679-15.22.4.r196.gdaa2679-1
ksudoku21.04.3.r1046.g245abab-121.04.3.r1047.g7a05a76-1
ksysguard5.22.3.r3507.g9bc6de87-15.22.4.r3508.g4d304e1e-1
ksystemstats5.22.3.r176.g5f93a3f-15.22.4.r177.g65c605e-1
ktnef21.04.3.r655.ga27e7de-121.04.3.r656.gb1891cd-1
ktrip 21.06.r26.g4e972de-1 21.07.r5.g7317bbf-1
kunitconversion5.84.0.r369.geed860d-15.84.0.r370.g92eea5a-1
kwallet-pam5.22.3.r250.g3bdf94a-15.22.4.r251.gbcc5922-1
kwayland5.84.0.r1098.g05ded8f-15.84.0.r1101.g311f60b-1
kwayland-integration5.22.3.r179.g5901512-15.22.4.r179.g5901512-1
kwayland-server5.22.3.r1345.g9fe2aa5-15.22.4.r1361.g02267a3-1
kweather 21.06.r40.g5076241-1 21.07.r10.gd70d011-1
kweathercore 21.05.r12.g4690eee-1 0.4.r4.g35b7c5c-1
kwidgetsaddons5.84.0.r837.ga4b21dac-15.84.0.r841.g63d2e03c-1
kwin5.22.3.r19651.gb344afd8c-15.22.4.r19705.gb90d92a8f-1
kwindowsystem5.84.0.r599.g26e295a-15.84.0.r600.g2ee7179-1
kwinft5.22.0.r19035.gc2a9a76b5-15.22.0.r19054.g177a84db9-1
kwrite21.04.3.r18293.gd317129cd-121.04.3.r18306.gd3dd58cb9-1
kwrited5.22.3.r479.g8d34f29-15.22.4.r481.g42c83af-1
kxmlgui5.84.0.r790.g917b743d-15.84.0.r792.g06ec4803-1
libakonadi21.04.3.r12527.g78ccf477a-121.04.3.r12533.g61dc5a751-1
libgravatar21.04.3.r358.g027f657-121.04.3.r359.g8ace9f1-1
libkdepim21.04.3.r840.ge2cbe34-121.04.3.r841.g24a530e-1
libkgapi21.04.3.r1286.gab3d548-121.04.3.r1287.g81197c8-1
libkleo21.04.3.r914.g9f79f52-121.04.3.r917.g0608fbe-1
libkomparediff221.04.3.r337.g9827753-121.04.3.r339.ge9ed555-1
libksane21.04.3.r549.gcd38e98-121.04.3.r551.g0454ecf-1
libkscreen5.22.3.r1585.g19fb52b-15.22.4.r1586.g618f24d-1
libksieve21.04.3.r1551.gfc1ed601-121.04.3.r1559.gec618362-1
libksysguard5.22.3.r2252.g375ee5b-15.22.4.r2259.g2dac54c-1
libquotient r2023.ge4bfe89-1 r2035.g72643d2-1
mailcommon21.04.3.r1057.gc8d5a1d-121.04.3.r1076.g1eac913-1
mailimporter21.04.3.r462.gaaac664-121.04.3.r463.g21c0351-1
maliit-keyboard r2088.g81bfdd24-2 r2097.g14b96f8e-1
marble21.04.3.r13317.gf08f15fd3-121.04.3.r13322.gb973663cb-1
marble-common21.04.3.r13317.gf08f15fd3-121.04.3.r13322.gb973663cb-1
marble-qt21.04.3.r13317.gf08f15fd3-121.04.3.r13322.gb973663cb-1
maui-clip 1.1.1.r8.gb3d9db9-4 1.1.1.r11.g619cd12-1
maui-nota 1.2.2.r53.g9e2d63e-1 1.2.2.r59.g75b4c9c-1
maui-pix 1.2.2.r62.ge828aa0-1 1.2.2.r69.g52ea825-1
mauikit1.2.2.r152.g0012b03f-11.2.2.r167.g21371ec4-1
mauikit-accounts r9.398b635-1 r10.d9f46d9-1
mauikit-filebrowsing 1.2.2.r67.g60d945d-1 1.2.2.r72.g34d99f6-1
mauikit-imagetools 1.2.2.r17.g470723e-1 1.2.2.r19.g977cd44-1
mauikit-texteditor 1.2.2.r11.g40a45c4-3 1.2.2.r12.g5808dc0-1
mbox-importer21.04.3.r502.gfe6e5f9-121.04.3.r504.g99b2e67-1
messagelib21.04.3.r6075.g1de22472-121.04.3.r6098.gbd96fddc-1
milou5.22.3.r745.g65c72f4-15.22.4.r745.g65c72f4-1
minuet21.04.3.r577.ga4303ed-121.04.3.r579.gdc33ba7-1
neochat r1785.gae60834c-1 r1795.gde7354f0-1
networkmanager-qt5.84.0.r1110.g898e976-15.84.0.r1113.ga66c9d1-1
okular21.04.3.r9397.g1d9081766-121.04.3.r9408.g263952458-1
oxygen5.22.3.r4422.g5c8c3271-15.22.4.r4423.g9de84e89-1
palapeli21.04.3.r1226.gd3f694b-121.04.3.r1227.g2df0f22-1
parley21.04.3.r4414.gdc7ae8d4-121.04.3.r4416.g1f5f767e-1
pim-data-exporter21.04.3.r2421.gb2205fd4-121.04.3.r2423.g492127c1-1
pim-sieve-editor21.04.3.r1493.ge0cae80-121.04.3.r1495.g057b6a9-1
pimcommon21.04.3.r1064.g6dfebc4-121.04.3.r1069.gc4cfdbb-1
plasma-browser-integration5.22.3.r1267.gb9e54d8c-15.22.3.r1269.g4c28b9a1-1
plasma-desktop5.22.3.r8553.g54e5468e5-15.22.4.r8565.gefb9823aa-1
plasma-dialer 21.06.r11.gfcc384e-1 21.07.r2.gde002cf-1
plasma-disks5.22.3.r221.gaaf1ef6-15.22.4.r224.gd64d104-1
plasma-firewall5.22.3.r497.g8e86ae7-15.22.4.r499.gfe33df5-1
plasma-framework5.84.0.r15921.g75c31c08d-15.84.0.r15928.g42e64f455-1
plasma-integration5.22.3.r519.gf7c25d9-15.22.4.r521.g61c99d0-1
plasma-mobile-nm5.21.4.r3063.gf891c384-15.22.3.r3066.g3a86df12-1
plasma-nm5.22.3.r3063.gf891c384-15.22.3.r3066.g3a86df12-1
plasma-pa5.22.3.r951.ge87dcf3-15.22.4.r955.ga0738d9-1
plasma-phone-components5.22.3.r1427.g27a3d33b-15.22.3.r1442.g5ab4624f-1
plasma-phonebook 21.06.r11.gc712939-1 21.07.r5.g7f2dac8-1
plasma-sdk5.22.3.r2272.g32b423a6-15.22.4.r2273.g3d24bfcc-1
plasma-settings 21.06.r12.gc824f2a-1 21.07.r7.g1915342-1
plasma-systemmonitor5.22.3.r468.ge20cb86-15.22.4.r472.g8bc52a3-1
plasma-thunderbolt5.22.3.r134.gff4b4f9-15.22.4.r134.gff4b4f9-1
plasma-vault5.22.3.r336.g2b49118-15.22.4.r339.gab42eca-1
plasma-wayland-protocols1.3.0.r1027.gad543cf-11.3.0.r1028.g8d33090-1
plasma-wayland-session5.22.3.r10449.g746ac9503-15.22.4.r10482.g14bcd88cc-1
plasma-workspace5.22.3.r10449.g746ac9503-15.22.4.r10482.g14bcd88cc-1
plasma-workspace-wallpapers5.22.3.r280.ge462299-15.22.4.r281.g4fc06b7-1
polkit-kde-agent5.22.3.r498.g12157d1-15.22.4.r499.g6aa608d-1
powerdevil5.22.3.r2442.g93e441d9-15.22.4.r2453.g013f76a4-1
purpose5.84.0.r864.g3469d7c-15.84.0.r867.g599e08d-1
qmlkonsole 21.06.r7.g6b630f5-1 21.07.r0.g6b630f5-1
qqc2-breeze-style5.22.3.r220.gdcfd65f-15.22.4.r220.gdcfd65f-1
rocs21.04.2.r3022.gc2e0af1d-121.04.3.r3022.gc2e0af1d-1
sddm0.19.0.r49.gbb54497-10.19.0.r50.g8b9ffb4-1
sddm-kcm5.22.3.r588.gc51c2a1-15.22.4.r590.gd77c138-1
solid5.84.0.r690.g9829c51-15.84.0.r693.g80310ba-1
sonnet5.84.0.r622.g7f36a22-15.84.0.r623.gf7fbede-1
spacebar 21.06.r27.g5ce9e9e-1 21.07.r5.g27b884f-1
spectacle21.04.3.r1132.g874b5b0-121.04.3.r1134.g0aec65b-1
svgpart21.04.3.r174.g4fd95bd-121.04.3.r176.ga5f3adc-1
syntax-highlighting5.84.0.r1630.ga2bb6f45-15.84.0.r1638.g5f4d8be2-1
systemsettings5.22.3.r2453.g07fcc030-15.22.4.r2470.ga8e7e1dc-1
tokodon 21.06.r19.geb4d447-1 21.07.r5.g9f88f8d-1
vvave 1.2.2.r55.g4b8fb82-1 1.2.2.r58.g5ca7e7d-1
xdg-desktop-portal-kde5.22.3.r374.g96ead88-15.22.4.r375.g66640c6-1
yakuake21.04.3.r724.gc1a2abe-121.04.3.r727.g76c4132-1
zeroconf-ioslave21.04.3.r355.g370f3e4-121.04.3.r356.g0bb67c4-1
khealthcertificate - r67.735d6be-1
vakzination - r68.690b1a6-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #manjaro-arm:arm-testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
Donation
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Poll
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
