Hello ARM community.
Pretty big update, with lots of perl, python and mobile stuff.
Curefish is a new DE, designed for tablets and desktop, based on qt and plasma!
Some highlights:
- Most of our kernels got updated
- Cutefish got added to the repository
- And QT6 got it’s first major point release with 6.1.0
- Thunderbird also got a new point release with 78.10.2
- Introducing Foot terminal emulator to the repository
- Lots of Perl packages got updated to work with 5.34
- Lots of updated packages for our Mobile offerings
- The regular Python updates
- And regular updates from upstream
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
Chromium will loose sync support in early March:
Arch Linux - News: Chromium losing Sync support in early March
ghostpcl>=9.53.2-2 and ghostxps>=9.53.2-2 updates require manual intervention:
The nss and zn_poly packages requires manual intervention:
Arch Linux - News: zn_poly 0.9.2-2 update requires manual intervention
The packages hplip and firewalld requires manual intervention:
Package changes:
(Fri Jun 4 12:22:27 CEST 2021)
- arm-stable community aarch64: 1264 new and 1123 removed package(s)
- arm-stable core aarch64: 60 new and 56 removed package(s)
- arm-stable extra aarch64: 469 new and 444 removed package(s)
- arm-stable kde-unstable aarch64: 400 new and 392 removed package(s)
- arm-stable mobile aarch64: 0 new and 2 removed package(s)
See all the package changes here !
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #manjaro-arm:arm-testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
Donation
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Poll
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
