[ARM Stable Update] 2021-05-17 - Mesa, KDE Frameworks, Gnome 40.1, Maui and Kernels
Hello ARM community.
Pretty big update this time. Linux 5.12 released, KDE has stuff going on. Gnome got a point release.
We even updated the uboots for most of the AMLogic boards.
Manjaro ARM is adding Gnome and Sway edition next release! Check out the preview images of Gnome on the Raspberry Pi and Pinebook Pro, as well as Sway on Raspberry Pi and Pinebook Pro which is returning!
Some highlights:
  • Most of our kernels got updated
  • Mesa 21.1.0 was released
  • A new KDE Frameworks release brings it to 5.82
  • Gnome is now at version 40.1
  • And all the Maui apps have new releases
  • Lots of updated packages for our Mobile offerings
  • The regular Python updates
  • And regular updates from upstream
How to use the new Kodi RPI on Manjaro ARM (by @Darksky)
If anyone wants to test kodi on the rpi:
Change to the unstable or testing branch and install kodi packages:
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
Boot straight into Kodi
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi.
Kodi home directory will be /var/lib/kodi.
So put test video in /var/lib/kodi/Videos so you can get to it after setting up the video directory in kodi.
Upstream Notifications:
Older notifications
Chromium will loose sync support in early March:
Arch Linux - News: Chromium losing Sync support in early March
ghostpcl>=9.53.2-2 and ghostxps>=9.53.2-2 updates require manual intervention:
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss and zn_poly packages requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
https://www.archlinux.org/news/zn_poly-092-2-update-requires-manual-intervention/
The packages hplip and firewalld requires manual intervention:
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package changes:
(Mon May 17 20:42:07 CEST 2021)
  • arm-stable community aarch64: 399 new and 369 removed package(s)
  • arm-stable core aarch64: 30 new and 31 removed package(s)
  • arm-stable extra aarch64: 537 new and 612 removed package(s)
  • arm-stable kde-unstable aarch64: 236 new and 235 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE           2021-05-09          2021-05-17
                           alligator                0.1-0              21.05-1
                           angelfish              1.8.0-1              21.05-1
                           bitwarden             1.24.6-1             1.26.0-1
                 breath2-icon-themes             1.0.10-1             1.0.11-2
                   breath2-wallpaper             1.0.10-1             1.0.11-2
                           calindori                1.4-1              21.05-1
                        eg25-manager   0.3.0+2+g64145ac-3   0.3.0+2+g64145ac-5
                     element-desktop             1.7.26-1             1.7.27-1
                         element-web             1.7.26-1             1.7.27-1
               gnome-contacts-mobile             3.38.1-2             3.38.1-3
                                kalk                0.2-1              21.05-1
                              kclock              0.4.0-0              21.05-1
                            kodi-rpi              19.0-10               19.1-4
                        kodi-rpi-dev              19.0-10               19.1-4
               kodi-rpi-eventclients              19.0-10               19.1-4
        kodi-rpi-tools-texturepacker              19.0-10               19.1-4
                                koko   0.1+r520.9159df6-1              21.05-1
                            kongress                1.0-0              21.05-1
                           krecorder                0.1-1              21.05-1
                       libmm-pp-glib             1.16.2-1             1.16.4-2
                           maui-clip            1.1.0-1.1                    -
                           maui-nota            1.2.1-1.1                    -
                     modemmanager-pp             1.16.2-1             1.16.4-2
                              peruse  1.2.r281.g2bda54c-1               1.80-2
                               phosh 0.10.2+20+g0472e0f-1 0.10.2+53+gd14786a-1
                       plasma-dialer                0.3-1              21.05-1
                    plasma-phonebook                0.1-0              21.05-1
                     plasma-settings              0.2-0.1              21.05-1
              plasma5-themes-breath2             1.0.10-1             1.0.11-2
                          qmlkonsole                0.1-1              21.05-1
                  sddm-breath2-theme             1.0.10-1             1.0.11-2
                            spacebar                0.2-1              21.05-1
                       spacebear-git        r35.75f33e6-1                    -
                    user-manager-git5.19.90.r501.g1b71858-1                    -
                             vivaldi        3.8.2259.40-1        3.8.2259.42-1
                        wire-desktop          3.24.2939-1          3.25.2940-1
                                 yay             10.2.1-1             10.2.2-1
                               ktrip                    -              21.05-1
                         wake-mobile                    -                1.7-1
:: Different sync package(s) in repository community aarch64
                       acme-redirect              0.5.0-1              0.5.1-1
                       android-tools             31.0.0-2             31.0.0-3
                             ansible              3.3.0-2              3.4.0-1
                          apache-orc              1.6.7-2              1.6.7-3
                   arch-repro-status              0.1.0-1              1.0.0-1
                               arcus              4.8.0-3              4.8.0-4
                             arduino           1:1.8.13-3           1:1.8.14-1
                     arduino-builder              1.5.4-2              1.6.0-1
                               arrow              3.0.0-1              3.0.0-2
                              autofs              5.1.7-1                    -
                             avr-gcc             10.3.0-1             11.1.0-1
                             aws-cli            1.19.55-1            1.19.72-1
                         baidupcs-go              3.7.2-2              3.7.9-1
                                 bcc             0.19.0-1             0.20.0-1
                           bcc-tools             0.19.0-1             0.20.0-1
                           bctoolbox             4.5.13-1             4.5.15-1
                            bfgminer              5.5.0-3                    -
                             bitlbee                3.6-2                    -
                                borg             1.1.16-3             1.1.16-4
                               broot              1.3.1-1              1.4.0-1
                                buho              1.2.1-1              1.2.2-1
                               bzrtp             4.5.13-1             4.5.15-1
                             cargo-c              0.8.0-1              0.8.1-1
                             cawbird                1.4-1              1.4.1-1
                              ccache              4.2.1-1                4.3-1
                              cclive             0.9.3-23             0.9.3-24
                             cgminer             4.10.0-4                    -
                              cgoban             1.9.14-4                    -
                             chezmoi             2.0.11-1             2.0.12-1
                              chrony                4.0-1                4.1-1
                               clash              1.5.0-1              1.6.0-1
                          clementine1.4.0rc1+495+g10bf5dc17-21.4.0rc1+495+g10bf5dc17-3
                                cmst         2020.11.01-1                    -
                          cockatrice              2.8.0-2              2.8.0-3
                            collectd             5.12.0-3                    -
                        communicator              1.2.1-1              1.2.2-1
                          containerd              1.5.0-1              1.5.0-2
                          coolreader             3.2.55-1             3.2.57-1
                                croc              9.1.2-1              9.1.3-1
                          curaengine              4.8.0-2              4.8.0-3
                            deadbeef              1.8.4-1                    -
                                 dee             1.2.7-11                    -
          deepin-qt5platform-plugins             5.0.21-1             5.0.23-2
                                deno              1.9.2-1             1.10.1-1
                          diffoscope                173-1                174-1
                           dnstracer               1.10-1                    -
                      docker-compose             1.29.1-2             1.29.2-1
                            dropbear            2020.81-2            2020.81-3
                        dropbear-scp            2020.81-2            2020.81-3
                           drumstick              2.1.1-1              2.2.0-1
                             dua-cli             2.11.1-1             2.11.3-1
                               encfs              1.9.5-2              1.9.5-4
                              erlang             23.3.2-1               24.0-1
                           erlang-cl              1.2.4-2              1.2.4-3
                         erlang-docs               23.3-1               24.0-1
                     erlang-unixodbc             23.3.2-1               24.0-1
                              eslint             7.25.0-1             7.26.0-1
                           etherwall              3.0.2-3              3.0.2-4
                                 etl              1.4.0-1              1.4.1-1
                           exploitdb           20210316-1           20210508-1
                          fcitx5-gtk              5.0.6-2              5.0.7-1
                           filezilla             3.53.1-1             3.54.1-2
                           findomain              4.1.1-1              4.2.0-1
                          fingerterm              1.4.1-1              1.4.2-1
                                fish              3.2.1-1              3.2.2-1
                              flake8            1:3.9.1-1            1:3.9.2-1
                         flatbuffers             1.12.0-3              2.0.0-1
                                gdal              3.2.2-2              3.2.3-1
                             git-lfs             2.13.3-1             2.13.3-2
                               gmock             1.10.0-3                    -
                               gmrun               1.1w-1               1.2w-1
                              gnokii            0.6.31-19                    -
                 gnome-phone-manager              0.69-16                    -
                            gnuchess              6.2.7-1              6.2.8-1
                              gnunet             0.14.1-1                    -
                               gnurl             7.72.0-1                    -
                         google-glog              0.4.0-2              0.5.0-1
                              gopass             1.12.5-1             1.12.6-1
                               gopls              0.6.4-2             0.6.11-1
                              grails              4.0.6-1             4.0.10-1
                         grails-docs              4.0.6-1             4.0.10-1
                                grpc             1.36.4-1             1.36.4-2
                            grpc-cli             1.36.4-1             1.36.4-2
                               gtest             1.10.0-3             1.10.0-6
                                gxkb              0.9.1-1              0.9.2-1
                            hyperion            1.03.2-23            1.03.2-24
                       i3status-rust             0.14.7-1             0.20.1-1
                          ibus-table             1.12.6-1             1.13.0-1
                               icewm              2.3.3-1              2.3.4-1
                             imwheel         1.0.0pre12-5         1.0.0pre12-6
                            index-fm              1.2.1-1              1.2.2-1
                  interception-tools              0.6.5-1              0.6.6-1
                              iodine              0.7.0-4              0.7.0-5
                               jedit              5.6.0-1                    -
                             jenkins              2.291-1              2.293-1
                                jmol           14.31.36-1           14.31.38-1
                               jsmol           14.31.36-1           14.31.38-1
                   jupyter-nbclassic              0.2.7-1              0.2.8-1
                      jupyter-server              1.6.4-1              1.7.0-2
                          jupyterlab             3.0.14-1             3.0.15-1
                                 k9s             0.24.8-1             0.24.9-1
                            kio-fuse              5.0.1-1                    -
                             klayout               0.27-1               0.27-2
                       kodi-platform  20190726.809c5e9-22  20190726.809c5e9-23
                              kupfer                320-2                321-1
                              ld-lsb                  3-7                  3-8
                 libappletdecoration              0.8.1-3                    -
                        libfilezilla             0.27.1-1             0.28.0-2
                       libimagequant             2.14.1-1             2.15.0-1
                             libmgba              0.9.0-1              0.9.1-1
                            liboping             1.10.0-8                    -
                          librdkafka              1.6.1-1              1.7.0-1
                                 lxd               4.13-1               4.14-1
                      matrix-synapse             1.29.0-1             1.33.2-1
                           maui-clip              1.1.0-1              1.1.1-1
                           maui-nota              1.2.1-1              1.2.2-1
                            maui-pix              1.2.1-2              1.2.2-2
                          maui-shelf              1.1.0-1              1.1.1-1
                        maui-station              1.2.1-2              1.2.2-1
                             mauikit              1.2.1-1              1.2.2-3
                          maxima-ecl             5.44.0-2             5.44.0-3
                              mdbook              0.4.7-1              0.4.8-1
                               mdcat             0.22.4-1             0.22.4-2
                           mediaelch              2.8.6-1             2.8.12-1
                       mediastreamer             4.5.13-1             4.5.15-1
                              medusa                2.2-9               2.2-10
                             mgba-qt              0.9.0-1              0.9.1-1
                            mgba-sdl              0.9.0-1              0.9.1-1
                              minder             1.12.0-2             1.12.2-1
                                mksh               59.c-1                    -
                            mldonkey              3.1.7-1                    -
                            molecule              3.3.0-1              3.3.0-2
                                mosh             1.3.2-13             1.3.2-14
                                mpop              1.4.8-1             1.4.13-1
                              mumble              1.3.4-4              1.3.4-5
                              murmur              1.3.4-4              1.3.4-5
                     mysql-workbench             8.0.24-2             8.0.25-1
                                 nbd               3.21-1               3.21-2
                             netdata             1.30.1-1             1.30.1-2
                           newsflash              1.4.0-3              1.4.1-1
                               nload              0.7.4-6              0.7.4-7
                       nlohmann-json              3.9.1-1              3.9.1-2
                                 npm             7.11.2-1             7.12.1-1
                   npm-check-updates            11.5.10-1            11.5.11-1
                              nsjail                3.0-2                3.0-3
                           nvchecker                2.3-1                2.3-2
                           opendmarc              1.4.0-2            1.4.1.1-1
                 openshadinglanguage          1.11.13.0-4          1.11.14.0-1
                                ortp             4.5.13-1             4.5.15-1
                                paps              0.7.1-2                    -
                            pdf2djvu           0.9.17.1-9                    -
                            perl-cgi               4.51-1               4.52-1
                    perl-test2-suite           0.000139-1           0.000140-1
                          photoflare            1.6.7.1-1              1.6.8-1
                            php-grpc             1.36.4-1             1.36.4-2
                           php7-grpc             1.36.4-1             1.36.4-2
                              pifpaf              3.1.1-1              3.1.4-1
      plasma5-applets-window-buttons              0.8.1-3              0.9.0-1
                            pngquant             2.14.1-1             2.15.0-1
                              polipo              1.1.1-4                    -
                              polyml              5.8.1-1              5.8.2-1
                             ponymix                  5-3                    -
                            powerdns              4.4.1-2              4.4.1-3
                   powerdns-recursor              4.4.3-1              4.4.3-2
                            prettier              2.2.1-1              2.3.0-1
                                proj              8.0.0-3              8.0.1-1
                            projectm             3.1.12-1             3.1.12-2
                 projectm-pulseaudio             3.1.12-1             3.1.12-2
                        projectm-sdl             3.1.12-1             3.1.12-2
                           proselint             0.10.2-6                    -
                             prosody           1:0.11.8-1           1:0.11.9-1
                      python-alembic              1.4.3-3              1.6.2-1
                        python-anyio              2.2.0-1              3.0.1-1
                      python-apispec              4.4.0-1              4.4.1-1
               python-awesomeversion             21.4.0-1             21.5.0-1
                        python-babel              2.9.0-1              2.9.1-1
                          python-bcc             0.19.0-1             0.20.0-1
                        python-black             21.5b0-1             21.5b1-1
                        python-boto3            1.17.55-1            1.17.72-1
                     python-botocore            1.20.55-1            1.20.72-1
                    python-braintree              4.8.0-1              4.9.0-1
                     python-cerberus              1.3.3-1              1.3.4-1
                        python-click              7.1.2-4              8.0.0-1
              python-click-threading              0.4.4-9             0.4.4-10
                 python-cookiecutter              1.7.2-3              1.7.2-5
                     python-engineio              4.0.0-1              4.1.0-1
                     python-eventlet             0.30.2-1             0.31.0-1
                        python-faker              8.1.2-1              8.1.3-1
                        python-flask              1.1.2-4              2.0.0-1
             python-flask-sqlalchemy              2.4.4-3              2.5.1-1
                  python-flatbuffers             1.12.0-3              2.0.0-1
                           python-fs             2.4.13-1             2.4.13-2
                        python-funcy               1.15-2               1.16-1
                         python-gdal              3.2.2-2              3.2.3-1
                       python-geoip2              4.1.0-3              4.2.0-1
              python-google-api-core             1.26.1-1             1.26.3-1
     python-google-api-python-client             1.12.8-1              2.3.0-1
                       python-grpcio             1.36.4-1             1.36.4-2
                    python-httpretty              1.0.5-1              1.1.0-1
                   python-hypothesis             6.10.1-1             6.12.0-1
                 python-itsdangerous              1.1.0-6              2.0.0-1
                        python-jinja             2.11.3-2              3.0.0-1
                       python-joblib              1.0.0-1              1.0.1-1
            python-jupyter_packaging             0.10.1-1             0.10.2-1
            python-jupyterlab_server              2.5.0-1              2.5.1-1
                      python-kitchen              1.2.6-5                    -
                         python-ldap              3.3.1-3              3.3.1-4
                        python-magic               5.39-3               5.40-1
                  python-marshmallow             3.11.1-1             3.12.1-1
                  python-meilisearch             0.14.1-1             0.14.2-1
                       python-mocket             3.9.40-1             3.9.40-2
       python-openapi-spec-validator              0.3.0-1              0.3.1-1
                     python-openmdao              3.8.0-1              3.9.1-1
                      python-oslo-db              8.6.0-1              9.0.0-1
                   python-oslo-utils              4.8.0-1              4.9.0-1
             python-ovirt-engine-sdk             4.4.10-1             4.4.12-1
                       python-owslib             0.23.0-1             0.24.1-1
                       python-pandas              1.2.3-1              1.2.3-2
                        python-parso            1:0.8.1-1            1:0.8.2-1
                 python-phonenumbers            8.12.22-1            8.12.23-1
                      python-pikepdf             2.11.4-1             2.12.0-1
                         python-pudb             2020.1-1             2021.1-1
                      python-pycares              3.1.1-3              4.0.0-1
                   python-pydocstyle              5.1.1-3              6.0.0-1
                       python-pygame              2.0.1-1              2.0.1-2
                        python-pygls             0.10.3-1             0.10.3-2
                        python-pyotp              2.4.1-1              2.6.0-2
             python-pytest-benchmark              3.2.3-4              3.4.0-1
                python-pytest-celery            0.0.0a1-4              0.0.0-1
             python-pytest-checkdocs              2.3.0-1              2.5.0-1
                 python-pytest-httpx             0.11.0-1             0.12.0-1
                 python-pytest-isort              1.3.0-1              2.0.0-1
              python-pytest-randomly              3.5.0-2              3.7.0-1
                      python-pywinrm              0.4.1-4              0.4.2-1
                    python-reportlab             3.5.66-1             3.5.67-1
            python-rfc3339-validator              0.1.3-1              0.1.4-1
                      python-rfc3986              1.4.0-3              1.5.0-1
                   python-s3transfer              0.4.1-1              0.4.2-1
                 python-scikit-learn             0.24.1-1             0.24.2-1
                      python-serpent             1.30.2-3             1.30.2-5
                     python-socketio              5.0.4-1              5.2.1-1
                       python-sphinx              3.5.4-2              4.0.1-2
             python-sqlalchemy-utils             0.36.8-3             0.37.1-1
                    python-sshtunnel              0.1.5-5              0.4.0-1
                    python-typeguard             2.10.0-3             2.11.0-1
             python-websocket-client             0.58.0-1             0.59.0-1
                   python-websockets                8.1-3              9.0.1-3
                     python-werkzeug              1.0.1-4              2.0.0-1
                      python-wtforms             2.2.1-10              2.3.3-1
                     python-zeroconf             0.29.0-1             0.29.0-2
                                qgis             3.18.2-2             3.18.2-3
                                qmmp              1.4.5-1              1.4.6-1
                              qpress                1.1-3                1.1-4
                             redmine              4.1.1-2              4.2.1-1
                             remmina           1:1.4.13-1           1:1.4.14-1
                           rpm-tools           4.16.1.2-1           4.16.1.3-1
                                 rtv             1.27.0-3                    -
                  ruby-activesupport              6.1.3-3            6.1.3.2-1
                          ruby-cairo             1.17.5-2             1.17.5-3
                          ruby-crack              0.4.4-2                    -
                       ruby-hashdiff              1.0.0-3                    -
                    ruby-json-schema              2.8.1-3                    -
                           ruby-rdoc              6.3.0-3              6.3.1-1
                        ruby-ronn-ng              0.9.1-3              0.9.1-4
                      ruby-rspec-its              1.3.0-4                    -
                        ruby-webmock             3.11.2-1                    -
                                runc          1.0.0rc93-2          1.0.0rc94-1
                       rust-analyzer           20210503-1           20210510-1
                               sbctl                0.3-1                0.4-2
                           screenkey                1.4-1                1.4-2
                               siege              4.0.8-1              4.0.9-1
                           skk-jisyo           20210411-1           20210509-1
                                 ssr              0.5.0-3              0.5.0-4
                             step-ca            0.15.14-1            0.15.15-1
                          swi-prolog              8.2.3-1              8.2.4-1
                           syncthing             1.15.1-1             1.16.1-1
                  syncthing-relaysrv             1.15.1-1             1.16.1-1
                           tailscale              1.8.1-1              1.8.3-1
                            tcptrace              6.6.7-6                    -
                             termite                 15-3                 15-4
                    termite-terminfo                 15-3                 15-4
                           termtosvg              1.1.0-2                    -
                           terraform             0.15.1-1             0.15.3-1
                          terragrunt             0.29.0-1             0.29.2-1
                          testssl.sh              3.0.4-1              3.0.5-1
                               tnftp           20151004-4           20200705-1
                                 tor            0.4.5.7-1            0.4.5.8-1
                           towncrier          19.9.0rc1-3             21.3.0-1
                             toxcore           1:0.2.12-1           1:0.2.12-2
                         ttc-iosevka              5.2.1-2              6.1.3-1
                    ttc-iosevka-aile              5.2.1-2              6.1.3-1
                   ttc-iosevka-curly              5.2.1-2              6.1.3-1
              ttc-iosevka-curly-slab              5.2.1-2              6.1.3-1
                  ttc-iosevka-etoile              5.2.1-2              6.1.3-1
                    ttc-iosevka-slab              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss01              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss02              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss03              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss04              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss05              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss06              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss07              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss08              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss09              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss10              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss11              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss12              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss13              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss14              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss15              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss16              5.2.1-2              6.1.3-1
                    ttc-iosevka-ss17              5.2.1-2              6.1.3-1
                                uget              2.2.3-3              2.2.3-4
                           uglify-js             3.13.5-1             3.13.6-1
                            umockdev             0.15.4-1             0.15.5-1
                          uncrustify             0.72.0-1             0.73.0-1
                        unionfs-fuse                2.1-1                2.1-2
         v2ray-domain-list-community     20210507022421-1     20210508061759-1
                         v2ray-geoip       202105070029-1       202105130030-1
                     vaultwarden-web           2.19.0.d-1             2.20.1-1
                             vicious              2.4.1-2              2.5.0-1
                                vmpk              0.8.2-1              0.8.3-1
                           vultr-cli              2.5.0-2              2.5.1-1
                               vvave              1.2.1-1              1.2.2-1
                              wifite  1:87.r139.918a499-3            2:2.5.8-1
                         wireplumber              0.3.0-1             0.3.95-1
                     xcursor-premium                0.3-9               0.3-10
                            xkcdpass             1.17.6-1                    -
                               yosys               0.9-11               0.9-12
                      youtube-viewer            1:3.9.0-1                    -
                              zinnia               0.06-6                    -
                           aspell-es                    -               1.11-8
                                 efl                    -             1.25.1-6
                            efl-docs                    -             1.25.1-6
                               glide                    -              0.5.8-2
                         hunspell-it                    -                2.4-9
                         hunspell-ro                    -             3.3.10-5
                           hyphen-it                    -           20071127-5
                mauikit-filebrowsing                    -              1.2.2-2
                  mauikit-imagetools                    -              1.2.2-1
                  mauikit-texteditor                    -              1.2.2-1
                           mythes-it                    -             2.0.9l-6
                           mythes-ro                    -                3.3-7
                         procinfo-ng                    -            2.0.304-8
                  python-aiounittest                    -              1.4.0-1
    python-sphinxcontrib-log-cabinet                    -              1.0.1-1
                       python-zxcvbn                    -             4.4.28-1
                     ruby-red-colors                    -              0.1.1-1
                        vim-spell-af                    -           20190731-2
                        vim-spell-am                    -           20190731-2
                        vim-spell-bg                    -           20190731-2
                        vim-spell-br                    -           20190731-2
                        vim-spell-ca                    -           20190731-2
                        vim-spell-cs                    -           20190731-2
                        vim-spell-cy                    -           20190731-2
                        vim-spell-da                    -           20190731-2
                        vim-spell-de                    -           20190731-2
                        vim-spell-el                    -           20190731-2
                        vim-spell-en                    -           20190731-2
                        vim-spell-eo                    -           20190731-2
                        vim-spell-es                    -           20190731-2
                        vim-spell-fo                    -           20190731-2
                        vim-spell-fr                    -           20190731-2
                        vim-spell-ga                    -           20190731-2
                        vim-spell-gd                    -           20190731-2
                        vim-spell-gl                    -           20190731-2
                        vim-spell-he                    -           20190731-2
                        vim-spell-hr                    -           20190731-2
                        vim-spell-hu                    -           20190731-2
                        vim-spell-id                    -           20190731-2
                        vim-spell-it                    -           20190731-2
                        vim-spell-ku                    -           20190731-2
                        vim-spell-la                    -           20190731-2
                        vim-spell-lt                    -           20190731-2
                        vim-spell-lv                    -           20190731-2
                        vim-spell-mg                    -           20190731-2
                        vim-spell-mi                    -           20190731-2
                        vim-spell-ms                    -           20190731-2
                        vim-spell-nb                    -           20190731-2
                        vim-spell-nl                    -           20190731-2
                        vim-spell-nn                    -           20190731-2
                        vim-spell-ny                    -           20190731-2
                        vim-spell-pl                    -           20190731-2
                        vim-spell-pt                    -           20190731-2
                        vim-spell-ro                    -           20190731-2
                        vim-spell-ru                    -           20190731-2
                        vim-spell-rw                    -           20190731-2
                        vim-spell-sk                    -           20190731-2
                        vim-spell-sl                    -           20190731-2
                        vim-spell-sr                    -           20190731-2
                        vim-spell-sv                    -           20190731-2
                        vim-spell-sw                    -           20190731-2
                       vim-spell-tet                    -           20190731-2
                        vim-spell-th                    -           20190731-2
                        vim-spell-tl                    -           20190731-2
                        vim-spell-tn                    -           20190731-2
                        vim-spell-uk                    -           20190731-2
                        vim-spell-yi                    -           20190731-2
                        vim-spell-zu                    -           20190731-2
                                xplr                    -              0.9.0-1
                      zram-generator                    -              0.3.2-1
:: Different overlay package(s) in repository core aarch64
                               linux             5.12.2-2             5.12.4-1
                       linux-headers             5.12.2-2             5.12.4-1
                     linux-pinephone             5.12.2-2             5.12.3-1
             linux-pinephone-headers             5.12.2-2             5.12.3-1
                            linux-rc           5.12.rc8-3           5.13.rc1-1
                    linux-rc-headers           5.12.rc8-3           5.13.rc1-1
                          linux-rpi4            5.10.35-1            5.10.36-1
                  linux-rpi4-headers            5.10.35-1            5.10.36-1
                 linux-rpi4-mainline             5.12.1-1             5.12.3-1
         linux-rpi4-mainline-headers             5.12.1-1             5.12.3-1
                              pacman              5.2.2-4              5.2.2-6
                        pacman-debug              5.2.2-4              5.2.2-6
              raspberrypi-bootloader           20210507-1           20210513-1
            raspberrypi-bootloader-x           20210507-1           20210513-1
           uboot-pinebookpro-display         2021.07rc1-1         2021.07rc2-1
:: Different sync package(s) in repository core aarch64
                                bash            5.1.004-1            5.1.008-1
                         btrfs-progs             5.11.1-1               5.12-2
                       device-mapper            2.03.11-5            2.03.12-1
                                file               5.40-2               5.40-3
                               glib2             2.68.1-1             2.68.2-1
                          glib2-docs             2.68.1-1             2.68.2-1
                              hdparm               9.60-1               9.61-1
                                lvm2            2.03.11-5            2.03.12-1
                         procinfo-ng            2.0.304-8                    -
                            readline              8.1.0-2            8.1.001-1
                              sdparm               1.11-1               1.12-1
                             systemd                248-5              248.2-2
                        systemd-libs                248-5              248.2-2
                  systemd-resolvconf                248-5              248.2-2
                  systemd-sysvcompat                248-5              248.2-2
                                  vi           1:070224-4           1:070224-5
:: Different overlay package(s) in repository extra aarch64
                            mesa-git21.2.0_devel.138945.3326861f4f4-121.2.0_devel.139382.d81a6e5f1d3-1
              network-manager-applet             1.18.0-1             1.22.0-1
                nm-connection-editor             1.18.0-1             1.22.0-1
:: Different sync package(s) in repository extra aarch64
                               abook              0.6.1-6                    -
                  adwaita-icon-theme               40.1-1             40.1.1-1
                             akonadi            21.04.0-1            21.04.1-1
                    akonadi-calendar            21.04.0-1            21.04.1-1
              akonadi-calendar-tools            21.04.0-1            21.04.1-1
                    akonadi-contacts            21.04.0-1            21.04.1-1
               akonadi-import-wizard            21.04.0-1            21.04.1-1
                        akonadi-mime            21.04.0-1            21.04.1-1
                       akonadi-notes            21.04.0-1            21.04.1-1
                      akonadi-search            21.04.0-1            21.04.1-1
                      akonadiconsole            21.04.0-1            21.04.1-1
                           akregator            21.04.0-1            21.04.1-1
                            analitza            21.04.0-1            21.04.1-1
                              apache             2.4.46-3             2.4.47-1
                                 ark            21.04.0-1            21.04.1-1
                          artikulate            21.04.0-1            21.04.1-1
                           aspell-es               1.11-8                    -
                              attica             5.81.0-1             5.82.0-1
                         audiocd-kio            21.04.0-1            21.04.1-1
                               baloo             5.81.0-1             5.82.0-1
                       baloo-widgets            21.04.0-1            21.04.1-1
                             blinken            21.04.0-1            21.04.1-1
                            bluez-qt             5.81.0-1             5.82.0-1
                              bomber            21.04.0-1            21.04.1-1
                               botan             2.18.0-1             2.18.1-1
                                bovo            21.04.0-1            21.04.1-1
                        breeze-icons             5.81.0-1             5.82.0-1
                              bullet               3.08-2               3.17-1
                         bullet-docs               3.08-2               3.17-1
                     calendarsupport            21.04.0-1            21.04.1-1
                              cantor            21.04.0-1            21.04.1-1
                            cervisia            21.04.0-1            21.04.1-1
                  chrome-gnome-shell               10.1-5                    -
                            chromium       90.0.4430.93-1      90.0.4430.212-1
                               cvsps               3.13-3                    -
                             dolphin            21.04.0-1            21.04.1-1
                     dolphin-plugins            21.04.0-1            21.04.1-1
                              dragon            21.04.0-1            21.04.1-1
                                 ecl            20.4.24-2             21.2.1-1
                                 efl             1.25.1-4                    -
                            efl-docs             1.25.1-4                    -
                               elisa            21.04.0-1            21.04.1-1
                             ethtool             1:5.10-1             1:5.12-1
                          eventviews            21.04.0-1            21.04.1-1
                 extra-cmake-modules             5.81.0-1             5.82.0-1
                                 feh              3.6.3-1                3.7-1
                        ffmpegthumbs            21.04.0-1            21.04.1-1
                           filelight            21.04.0-1            21.04.1-1
                                flac              1.3.3-2              1.3.3-3
                            flac-doc              1.3.3-2              1.3.3-3
                         font-bh-ttf              1.0.3-7                    -
                frameworkintegration             5.81.0-1             5.82.0-1
                                fvwm              2.6.9-3                    -
                              galera             26.4.7-1             26.4.8-1
                                 gdb               10.1-4               10.2-1
                          gdb-common               10.1-4               10.2-1
                      gnome-calendar               40.0-1               40.1-1
                         gnome-shell1:40.0+67+g79acae417-1             1:40.1-1
              gnome-shell-extensions               40.0-2               40.1-1
                           granatier            21.04.0-1            21.04.1-1
                     grantlee-editor            21.04.0-1            21.04.1-1
                       grantleetheme            21.04.0-1            21.04.1-1
               gtk-update-icon-cache            1:4.2.0-5            1:4.2.1-1
                                gtk4            1:4.2.0-5            1:4.2.1-1
                          gtk4-demos            1:4.2.0-5            1:4.2.1-1
                           gtk4-docs            1:4.2.0-5            1:4.2.1-1
                            gtkglext             1.2.0-12             1.2.0-13
                         gtkmathview              0.8.0-8              0.8.0-9
                                gvim           8.2.2815-1           8.2.2845-1
                            gwenview            21.04.0-1            21.04.1-1
                               hefur                1.0-2                1.0-3
                         hunspell-it                2.4-9                    -
                         hunspell-ro             3.3.10-5                    -
                           hyphen-it           20071127-5                    -
                         imagemagick          7.0.11.11-1          7.0.11.12-1
                     imagemagick-doc          7.0.11.11-1          7.0.11.12-1
                     incidenceeditor            21.04.0-1            21.04.1-1
                           itinerary            21.04.0-1            21.04.1-1
                 java-activation-gnu              1.1.2-2                    -
                           java-bcel                6.2-2                    -
                   java-commons-net1              1.4.1-4                    -
                        java-gnumail              1.1.2-4                    -
                        java-inetlib              1.1.2-4                    -
                        java-jdepend              2.9.1-4                    -
                           java-jsch             0.1.55-2                    -
                       java-resolver                1.2-4                    -
                                 joe                4.6-2                    -
                                 juk            21.04.0-1            21.04.1-1
                                 k3b          1:21.04.0-1          1:21.04.1-1
               kaccounts-integration            21.04.0-1            21.04.1-1
                 kaccounts-providers            21.04.0-1            21.04.1-1
                         kactivities             5.81.0-1             5.82.0-1
                   kactivities-stats             5.81.0-1             5.82.0-1
                        kaddressbook            21.04.0-1            21.04.1-1
                             kajongg            21.04.0-1            21.04.1-1
                              kalarm            21.04.0-1            21.04.1-1
                           kalarmcal            21.04.0-1            21.04.1-1
                            kalgebra            21.04.0-1            21.04.1-1
                             kalzium            21.04.0-1            21.04.1-1
                              kamera            21.04.0-1            21.04.1-1
                              kamoso            21.04.0-1            21.04.1-1
                            kanagram            21.04.0-1            21.04.1-1
                             kapidox             5.81.0-1             5.82.0-1
                              kapman            21.04.0-1            21.04.1-1
                        kapptemplate            21.04.0-1            21.04.1-1
                            karchive             5.81.0-1             5.82.0-1
                                kate            21.04.0-1            21.04.1-1
                             katomic            21.04.0-1            21.04.1-1
                               kauth             5.81.0-1             5.82.0-1
                             kbackup            21.04.0-1            21.04.1-1
                           kblackbox            21.04.0-1            21.04.1-1
                             kblocks            21.04.0-1            21.04.1-1
                          kbookmarks             5.81.0-1             5.82.0-1
                             kbounce            21.04.0-1            21.04.1-1
                           kbreakout            21.04.0-1            21.04.1-1
                              kbruch            21.04.0-1            21.04.1-1
                         kcachegrind            21.04.0-1            21.04.1-1
                  kcachegrind-common            21.04.0-1            21.04.1-1
                               kcalc            21.04.0-1            21.04.1-1
                       kcalendarcore             5.81.0-1             5.82.0-1
                           kcalutils            21.04.0-1            21.04.1-1
                         kcharselect            21.04.0-1            21.04.1-1
                            kcmutils             5.81.0-1             5.82.0-1
                             kcodecs             5.81.0-1             5.82.0-1
                       kcolorchooser            21.04.0-1            21.04.1-1
                         kcompletion             5.81.0-1             5.82.0-1
                             kconfig             5.81.0-1             5.82.0-1
                      kconfigwidgets             5.81.0-1             5.82.0-1
                           kcontacts           1:5.81.0-1           1:5.82.0-1
                         kcoreaddons             5.81.0-1             5.82.0-1
                              kcrash             5.81.0-1             5.82.0-1
                               kcron            21.04.0-1            21.04.1-1
                                kdav           1:5.81.0-1           1:5.82.0-1
                         kdbusaddons             5.81.0-1             5.82.0-1
                     kde-dev-scripts            21.04.0-1            21.04.1-1
                       kde-dev-utils            21.04.0-1            21.04.1-1
                      kdebugsettings            21.04.0-1            21.04.1-1
                        kdeclarative             5.81.0-1             5.82.0-1
                          kdeconnect            21.04.0-1            21.04.1-1
                                kded             5.81.0-1             5.82.0-1
                         kdeedu-data            21.04.0-1            21.04.1-1
              kdegraphics-mobipocket            21.04.0-1            21.04.1-1
            kdegraphics-thumbnailers            21.04.0-1            21.04.1-1
                     kdelibs4support             5.81.0-1             5.82.0-1
              kdenetwork-filesharing            21.04.0-1            21.04.1-1
                            kdenlive            21.04.0-3            21.04.1-1
                       kdepim-addons            21.04.0-1            21.04.1-1
                      kdepim-runtime            21.04.0-1            21.04.1-1
                    kdesdk-kioslaves            21.04.0-1            21.04.1-1
                 kdesdk-thumbnailers            21.04.0-1            21.04.1-1
                     kdesignerplugin             5.81.0-1             5.82.0-1
                               kdesu             5.81.0-1             5.82.0-1
                           kdewebkit             5.81.0-1             5.82.0-1
                                 kdf            21.04.0-1            21.04.1-1
                             kdialog            21.04.0-1            21.04.1-1
                            kdiamond            21.04.0-1            21.04.1-1
                              kdnssd             5.81.0-1             5.82.0-1
                           kdoctools             5.81.0-1             5.82.0-1
                      keditbookmarks            21.04.0-1            21.04.1-1
                          kemoticons             5.81.0-1             5.82.0-1
                       kfilemetadata             5.81.0-1             5.82.0-1
                               kfind            21.04.0-1            21.04.1-1
                             kfloppy            21.04.0-1            21.04.1-1
                         kfourinline            21.04.0-1            21.04.1-1
                          kgeography            21.04.0-1            21.04.1-1
                                kget            21.04.0-1            21.04.1-1
                        kglobalaccel             5.81.0-1             5.82.0-1
                         kgoldrunner            21.04.0-1            21.04.1-1
                                kgpg            21.04.0-1            21.04.1-1
                          kguiaddons             5.81.0-1             5.82.0-1
                            khangman            21.04.0-1            21.04.1-1
                         khelpcenter            21.04.0-1            21.04.1-1
                           kholidays           1:5.81.0-1           1:5.82.0-1
                               khtml             5.81.0-1             5.82.0-1
                               ki18n             5.81.0-1             5.82.0-1
                         kiconthemes             5.81.0-1             5.82.0-1
                 kidentitymanagement            21.04.0-1            21.04.1-1
                           kidletime             5.81.0-1             5.82.0-1
                                 kig            21.04.0-1            21.04.1-1
                                kigo            21.04.0-1            21.04.1-1
                            killbots            21.04.0-1            21.04.1-1
                       kimageformats             5.81.0-2             5.82.0-1
                     kimagemapeditor            21.04.0-1            21.04.1-1
                               kimap            21.04.0-1            21.04.1-1
                               kinit             5.81.0-1             5.82.0-1
                                 kio             5.81.0-1             5.82.0-1
                          kio-extras            21.04.0-2            21.04.1-1
                          kio-gdrive            21.04.0-1            21.04.1-1
                        kipi-plugins            21.04.0-1            21.04.1-1
                    kirigami-gallery            21.04.0-1            21.04.1-1
                           kirigami2             5.81.0-1             5.82.0-1
                              kiriki            21.04.0-1            21.04.1-1
                              kismet         2020_12_R3-3         2020_12_R3-4
                         kitemmodels             5.81.0-1             5.82.0-1
                          kitemviews             5.81.0-1             5.82.0-1
                               kiten            21.04.0-1            21.04.1-1
                          kitinerary            21.04.0-2            21.04.1-1
                         kjobwidgets             5.81.0-1             5.82.0-1
                                 kjs             5.81.0-1             5.82.0-1
                            kjsembed             5.81.0-1             5.82.0-1
                        kjumpingcube            21.04.0-1            21.04.1-1
                               kldap            21.04.0-1            21.04.1-1
                           kleopatra            21.04.0-1            21.04.1-1
                            klettres            21.04.0-1            21.04.1-1
                            klickety            21.04.0-1            21.04.1-1
                              klines            21.04.0-1            21.04.1-1
                                kmag            21.04.0-1            21.04.1-1
                           kmahjongg            21.04.0-1            21.04.1-1
                               kmail            21.04.0-1            21.04.1-1
                kmail-account-wizard            21.04.0-1            21.04.1-1
                      kmailtransport            21.04.0-1            21.04.1-1
                               kmbox            21.04.0-1            21.04.1-1
                        kmediaplayer             5.81.0-1             5.82.0-1
                               kmime            21.04.0-1            21.04.1-1
                              kmines            21.04.0-1            21.04.1-1
                                kmix            21.04.0-1            21.04.1-1
                          kmousetool            21.04.0-1            21.04.1-1
                              kmouth            21.04.0-1            21.04.1-1
                              kmplot            21.04.0-1            21.04.1-1
                        knavalbattle            21.04.0-1            21.04.1-1
                            knetwalk            21.04.0-1            21.04.1-1
                           knewstuff             5.81.0-1             5.82.0-1
                             knights            21.04.0-1            21.04.1-1
                              knotes            21.04.0-1            21.04.1-1
                      knotifications             5.81.0-1             5.82.0-1
                       knotifyconfig             5.81.0-1             5.82.0-1
                                kolf            21.04.0-1            21.04.1-1
                           kollision            21.04.0-1            21.04.1-1
                         kolourpaint            21.04.0-1            21.04.1-1
                             kompare            21.04.0-1            21.04.1-1
                           konqueror            21.04.0-1            21.04.1-1
                            konquest            21.04.0-1            21.04.1-1
                             konsole            21.04.0-2            21.04.1-1
                             kontact            21.04.0-1            21.04.1-1
                    kontactinterface            21.04.0-1            21.04.1-1
                            kontrast            21.04.0-1            21.04.1-1
                        konversation            21.04.0-1            21.04.1-1
                       kopeninghours            21.04.0-1            21.04.1-1
                              kopete            21.04.0-1            21.04.1-1
                          korganizer            21.04.0-1            21.04.1-1
                       kosmindoormap            21.04.0-1            21.04.1-1
                            kpackage             5.81.0-1             5.82.0-1
                              kparts             5.81.0-1             5.82.0-1
                                kpat            21.04.0-1            21.04.1-1
                             kpeople             5.81.0-1             5.82.0-1
                        kpimtextedit            21.04.0-1            21.04.1-1
                             kpkpass            21.04.0-1            21.04.1-1
                           kplotting             5.81.0-1             5.82.0-1
                             kpmcore            21.04.0-1            21.04.1-1
                                kpty             5.81.0-1             5.82.0-1
                    kpublictransport            21.04.0-1            21.04.1-1
                      kqtquickcharts            21.04.0-1            21.04.1-1
                        kquickcharts             5.81.0-1             5.82.0-1
                                krdc            21.04.0-1            21.04.1-1
                            kreversi            21.04.0-1            21.04.1-1
                                krfb            21.04.0-1            21.04.1-1
                               kross             5.81.0-1             5.82.0-1
                  kross-interpreters            21.04.0-1            21.04.1-1
                              kruler            21.04.0-1            21.04.1-1
                             krunner             5.81.0-1             5.82.0-1
                            kservice             5.81.0-1             5.82.0-1
                             kshisen            21.04.0-1            21.04.1-1
                               ksirk            21.04.0-1            21.04.1-1
                               ksmtp            21.04.0-1            21.04.1-1
                          ksnakeduel            21.04.0-1            21.04.1-1
                          kspaceduel            21.04.0-1            21.04.1-1
                            ksquares            21.04.0-1            21.04.1-1
                             ksudoku            21.04.0-1            21.04.1-1
                          ksystemlog            21.04.0-1            21.04.1-1
                            kteatime            21.04.0-1            21.04.1-1
                         ktexteditor             5.81.0-1             5.82.0-1
                        ktextwidgets             5.81.0-1             5.82.0-1
                              ktimer            21.04.0-1            21.04.1-1
                               ktnef            21.04.0-1            21.04.1-1
                            ktorrent            21.04.0-1            21.04.1-1
                              ktouch            21.04.0-1            21.04.1-1
                          ktuberling            21.04.0-1            21.04.1-1
                             kturtle            21.04.0-1            21.04.1-1
                             kubrick            21.04.0-1            21.04.1-1
                     kunitconversion             5.81.0-1             5.82.0-1
                             kwallet             5.81.0-1             5.82.0-1
                      kwalletmanager            21.04.0-1            21.04.1-1
                               kwave            21.04.0-1            21.04.1-1
                            kwayland             5.81.0-1             5.82.0-1
                      kwidgetsaddons             5.81.0-1             5.82.0-1
                       kwindowsystem             5.81.0-1             5.82.0-1
                           kwordquiz            21.04.0-1            21.04.1-1
                              kwrite            21.04.0-1            21.04.1-1
                             kxmlgui             5.81.0-1             5.82.0-1
                       kxmlrpcclient             5.81.0-1             5.82.0-1
                            lablgtk2            2.18.11-3            2.18.11-6
                          libakonadi            21.04.0-1            21.04.1-1
                         libgravatar            21.04.0-1            21.04.1-1
                            libkcddb            21.04.0-1            21.04.1-1
                     libkcompactdisc            21.04.0-1            21.04.1-1
                           libkdcraw            21.04.0-1            21.04.1-1
                         libkdegames            21.04.0-1            21.04.1-1
                           libkdepim            21.04.0-1            21.04.1-1
                  libkeduvocdocument            21.04.0-1            21.04.1-1
                           libkexiv2            21.04.0-1            21.04.1-1
                            libkgapi            21.04.0-1            21.04.1-1
                             libkipi            21.04.0-1            21.04.1-1
                             libkleo            21.04.0-1            21.04.1-1
                        libkmahjongg            21.04.0-1            21.04.1-1
                     libkomparediff2            21.04.0-1            21.04.1-1
                            libksane            21.04.0-1            21.04.1-1
                           libksieve            21.04.0-1            21.04.1-1
                         libktorrent            21.04.0-1            21.04.1-1
                             libmwaw             0.3.18-1             0.3.19-1
                      libphonenumber            8.12.21-1            8.12.22-1
                          libplacebo            3.120.2-1            3.120.3-1
                             libpqxx              6.4.5-2              7.5.2-1
                   libreoffice-still              7.0.5-4              7.0.6-1
                libreoffice-still-af              7.0.5-1              7.0.6-1
                libreoffice-still-am              7.0.5-1              7.0.6-1
                libreoffice-still-ar              7.0.5-1              7.0.6-1
                libreoffice-still-as              7.0.5-1              7.0.6-1
               libreoffice-still-ast              7.0.5-1              7.0.6-1
                libreoffice-still-be              7.0.5-1              7.0.6-1
                libreoffice-still-bg              7.0.5-1              7.0.6-1
                libreoffice-still-bn              7.0.5-1              7.0.6-1
             libreoffice-still-bn-in              7.0.5-1              7.0.6-1
                libreoffice-still-bo              7.0.5-1              7.0.6-1
                libreoffice-still-br              7.0.5-1              7.0.6-1
               libreoffice-still-brx              7.0.5-1              7.0.6-1
                libreoffice-still-bs              7.0.5-1              7.0.6-1
                libreoffice-still-ca              7.0.5-1              7.0.6-1
       libreoffice-still-ca-valencia              7.0.5-1              7.0.6-1
               libreoffice-still-ckb              7.0.5-1              7.0.6-1
                libreoffice-still-cs              7.0.5-1              7.0.6-1
                libreoffice-still-cy              7.0.5-1              7.0.6-1
                libreoffice-still-da              7.0.5-1              7.0.6-1
                libreoffice-still-de              7.0.5-1              7.0.6-1
               libreoffice-still-dgo              7.0.5-1              7.0.6-1
               libreoffice-still-dsb              7.0.5-1              7.0.6-1
                libreoffice-still-dz              7.0.5-1              7.0.6-1
                libreoffice-still-el              7.0.5-1              7.0.6-1
             libreoffice-still-en-gb              7.0.5-1              7.0.6-1
             libreoffice-still-en-za              7.0.5-1              7.0.6-1
                libreoffice-still-eo              7.0.5-1              7.0.6-1
                libreoffice-still-es              7.0.5-1              7.0.6-1
                libreoffice-still-et              7.0.5-1              7.0.6-1
                libreoffice-still-eu              7.0.5-1              7.0.6-1
                libreoffice-still-fa              7.0.5-1              7.0.6-1
                libreoffice-still-fi              7.0.5-1              7.0.6-1
                libreoffice-still-fr              7.0.5-1              7.0.6-1
               libreoffice-still-fur              7.0.5-1              7.0.6-1
                libreoffice-still-fy              7.0.5-1              7.0.6-1
                libreoffice-still-ga              7.0.5-1              7.0.6-1
                libreoffice-still-gd              7.0.5-1              7.0.6-1
                libreoffice-still-gl              7.0.5-1              7.0.6-1
                libreoffice-still-gu              7.0.5-1              7.0.6-1
               libreoffice-still-gug              7.0.5-1              7.0.6-1
                libreoffice-still-he              7.0.5-1              7.0.6-1
                libreoffice-still-hi              7.0.5-1              7.0.6-1
                libreoffice-still-hr              7.0.5-1              7.0.6-1
               libreoffice-still-hsb              7.0.5-1              7.0.6-1
                libreoffice-still-hu              7.0.5-1              7.0.6-1
                libreoffice-still-id              7.0.5-1              7.0.6-1
                libreoffice-still-is              7.0.5-1              7.0.6-1
                libreoffice-still-it              7.0.5-1              7.0.6-1
                libreoffice-still-ja              7.0.5-1              7.0.6-1
                libreoffice-still-ka              7.0.5-1              7.0.6-1
               libreoffice-still-kab              7.0.5-1              7.0.6-1
                libreoffice-still-kk              7.0.5-1              7.0.6-1
                libreoffice-still-km              7.0.5-1              7.0.6-1
          libreoffice-still-kmr-latn              7.0.5-1              7.0.6-1
                libreoffice-still-kn              7.0.5-1              7.0.6-1
                libreoffice-still-ko              7.0.5-1              7.0.6-1
               libreoffice-still-kok              7.0.5-1              7.0.6-1
                libreoffice-still-ks              7.0.5-1              7.0.6-1
                libreoffice-still-lb              7.0.5-1              7.0.6-1
                libreoffice-still-lo              7.0.5-1              7.0.6-1
                libreoffice-still-lt              7.0.5-1              7.0.6-1
                libreoffice-still-lv              7.0.5-1              7.0.6-1
               libreoffice-still-mai              7.0.5-1              7.0.6-1
                libreoffice-still-mk              7.0.5-1              7.0.6-1
                libreoffice-still-ml              7.0.5-1              7.0.6-1
                libreoffice-still-mn              7.0.5-1              7.0.6-1
               libreoffice-still-mni              7.0.5-1              7.0.6-1
                libreoffice-still-mr              7.0.5-1              7.0.6-1
                libreoffice-still-my              7.0.5-1              7.0.6-1
                libreoffice-still-nb              7.0.5-1              7.0.6-1
                libreoffice-still-ne              7.0.5-1              7.0.6-1
                libreoffice-still-nl              7.0.5-1              7.0.6-1
                libreoffice-still-nn              7.0.5-1              7.0.6-1
                libreoffice-still-nr              7.0.5-1              7.0.6-1
               libreoffice-still-nso              7.0.5-1              7.0.6-1
                libreoffice-still-oc              7.0.5-1              7.0.6-1
                libreoffice-still-om              7.0.5-1              7.0.6-1
                libreoffice-still-or              7.0.5-1              7.0.6-1
             libreoffice-still-pa-in              7.0.5-1              7.0.6-1
                libreoffice-still-pl              7.0.5-1              7.0.6-1
                libreoffice-still-pt              7.0.5-1              7.0.6-1
             libreoffice-still-pt-br              7.0.5-1              7.0.6-1
                libreoffice-still-ro              7.0.5-1              7.0.6-1
                libreoffice-still-ru              7.0.5-1              7.0.6-1
                libreoffice-still-rw              7.0.5-1              7.0.6-1
             libreoffice-still-sa-in              7.0.5-1              7.0.6-1
               libreoffice-still-sat              7.0.5-1              7.0.6-1
                libreoffice-still-sd              7.0.5-1              7.0.6-1
               libreoffice-still-sdk              7.0.5-4              7.0.6-1
                libreoffice-still-si              7.0.5-1              7.0.6-1
               libreoffice-still-sid              7.0.5-1              7.0.6-1
                libreoffice-still-sk              7.0.5-1              7.0.6-1
                libreoffice-still-sl              7.0.5-1              7.0.6-1
                libreoffice-still-sq              7.0.5-1              7.0.6-1
                libreoffice-still-sr              7.0.5-1              7.0.6-1
           libreoffice-still-sr-latn              7.0.5-1              7.0.6-1
                libreoffice-still-ss              7.0.5-1              7.0.6-1
                libreoffice-still-st              7.0.5-1              7.0.6-1
                libreoffice-still-sv              7.0.5-1              7.0.6-1
             libreoffice-still-sw-tz              7.0.5-1              7.0.6-1
               libreoffice-still-szl              7.0.5-1              7.0.6-1
                libreoffice-still-ta              7.0.5-1              7.0.6-1
                libreoffice-still-te              7.0.5-1              7.0.6-1
                libreoffice-still-tg              7.0.5-1              7.0.6-1
                libreoffice-still-th              7.0.5-1              7.0.6-1
                libreoffice-still-tn              7.0.5-1              7.0.6-1
                libreoffice-still-tr              7.0.5-1              7.0.6-1
                libreoffice-still-ts              7.0.5-1              7.0.6-1
                libreoffice-still-tt              7.0.5-1              7.0.6-1
                libreoffice-still-ug              7.0.5-1              7.0.6-1
                libreoffice-still-uk              7.0.5-1              7.0.6-1
                libreoffice-still-uz              7.0.5-1              7.0.6-1
                libreoffice-still-ve              7.0.5-1              7.0.6-1
               libreoffice-still-vec              7.0.5-1              7.0.6-1
                libreoffice-still-vi              7.0.5-1              7.0.6-1
                libreoffice-still-xh              7.0.5-1              7.0.6-1
             libreoffice-still-zh-cn              7.0.5-1              7.0.6-1
             libreoffice-still-zh-tw              7.0.5-1              7.0.6-1
                libreoffice-still-zu              7.0.5-1              7.0.6-1
                             libupnp             1.14.6-1             1.14.7-1
                   libva-mesa-driver             21.0.3-3             21.1.0-1
                            libwnck3             3.36.0-1               40.0-1
                            lokalize            21.04.0-1            21.04.1-1
                               lskat            21.04.0-1            21.04.1-1
                          mailcommon            21.04.0-1            21.04.1-1
                        mailimporter            21.04.0-1            21.04.1-1
                              marble            21.04.0-1            21.04.1-1
                       marble-common            21.04.0-1            21.04.1-1
                           marble-qt            21.04.0-1            21.04.1-1
                             mariadb             10.5.9-1            10.5.10-1
                     mariadb-clients             10.5.9-1            10.5.10-1
                        mariadb-libs             10.5.9-1            10.5.10-1
                        markdownpart            21.04.0-1            21.04.1-1
                       mbox-importer            21.04.0-1            21.04.1-1
                                md4c              0.4.7-1              0.4.8-1
                           mercurial                5.8-1                5.8-2
                                mesa             21.0.3-3             21.1.0-1
                          mesa-vdpau             21.0.3-3             21.1.0-1
                               meson             0.58.0-1             0.58.0-2
                          messagelib            21.04.0-2            21.04.1-1
                              minuet            21.04.0-1            21.04.1-1
                     modemmanager-qt             5.81.0-1             5.82.0-1
                            mousepad              0.5.4-1              0.5.5-2
                              mpg123             1.26.5-1             1.27.2-1
                              mutter 40.0+69+geaf75f070-1               40.1-1
                           mythes-it             2.0.9l-6                    -
                           mythes-ro                3.3-7                    -
                               mytop             10.5.9-1            10.5.10-1
                   networkmanager-qt             5.81.0-1             5.82.0-1
                              okular            21.04.0-1            21.04.1-1
                        opencl-clhpp             2.0.13-1             2.0.14-1
                      opencl-headers       2:2020.12.18-1       2:2021.04.29-1
                         opencl-mesa             21.0.3-3             21.1.0-1
                        oxygen-icons           1:5.81.0-1           1:5.82.0-1
                    oxygen-icons-svg           1:5.81.0-1           1:5.82.0-1
                            palapeli            21.04.0-1            21.04.1-1
                              parley            21.04.0-1            21.04.1-1
                    partitionmanager            21.04.0-1            21.04.1-1
            perl-crypt-openssl-guess               0.12-1               0.13-1
                     perl-mime-types               2.19-1               2.20-1
                               picmi            21.04.0-1            21.04.1-1
                   pim-data-exporter            21.04.0-1            21.04.1-1
                    pim-sieve-editor            21.04.0-1            21.04.1-1
                           pimcommon            21.04.0-1            21.04.1-1
                    plasma-framework             5.81.0-1             5.82.0-1
                               poxml            21.04.0-1            21.04.1-1
                       print-manager            21.04.0-1            21.04.1-1
                              prison             5.81.0-1             5.82.0-1
        prometheus-blackbox-exporter             0.18.0-3             0.19.0-1
                            protobuf             3.15.8-1             3.16.0-1
                          protobuf-c              1.3.3-3              1.3.3-4
                             purpose             5.81.0-1             5.82.0-1
                               putty               0.74-1               0.75-1
                        pyqt-builder              1.9.1-1             1.10.0-1
                              python            3.9.4-1.1              3.9.5-2
                      python-astroid              2.5.5-1              2.5.6-1
                       python-django              3.2.2-1              3.2.3-1
                   python-markupsafe              1.1.1-7              2.0.0-1
                       python-pep517             0.10.0-1             0.10.0-2
                     python-protobuf             3.15.8-1             3.16.0-1
                     python-pybullet               3.08-2               3.17-1
                   python-setuptools           1:56.0.0-1           1:56.1.0-1
                          python-six             1.15.0-3             1.16.0-1
                        python-tests            3.9.4-1.1              3.9.5-2
                   python-virtualenv             20.4.4-1             20.4.6-1
                      python2-pep517             0.10.0-1             0.10.0-2
                         python2-six             1.15.0-3             1.16.0-1
                  python2-virtualenv             20.4.4-1             20.4.6-1
                                 qbs             1.18.2-1             1.19.0-1
                         qcachegrind            21.04.0-1            21.04.1-1
                                qpdf             10.3.1-1             10.3.2-1
                  qqc2-desktop-style             5.81.0-1             5.82.0-1
                         qt5-wayland     5.15.2+kde+r19-1     5.15.2+kde+r22-1
                                rocs            21.04.0-1            21.04.1-1
                            rp-pppoe               3.14-3               3.15-2
                                rust           1:1.52.0-1           1:1.52.1-1
                           rust-docs           1:1.52.0-1           1:1.52.1-1
                             shaderc             2020.5-1             2021.0-1
            signon-kwallet-extension            21.04.0-1            21.04.1-1
                                 sip              6.0.3-1              6.1.0-1
                               solid             5.81.0-1             5.82.0-1
                              sonnet             5.81.0-1             5.82.0-1
                           spectacle            21.04.0-1            21.04.1-1
                         spirv-tools             2020.7-1             2021.1-1
                                step            21.04.0-1            21.04.1-1
                             svgpart            21.04.0-1            21.04.1-1
                             sweeper            21.04.0-1            21.04.1-1
                         syndication             5.81.0-1             5.82.0-1
                 syntax-highlighting             5.81.0-1             5.82.0-1
                           syslog-ng             3.31.2-1             3.32.1-1
          telepathy-kde-accounts-kcm            21.04.0-1            21.04.1-1
              telepathy-kde-approver            21.04.0-1            21.04.1-1
          telepathy-kde-auth-handler            21.04.0-1            21.04.1-1
               telepathy-kde-call-ui            21.04.0-1            21.04.1-1
      telepathy-kde-common-internals            21.04.0-1            21.04.1-1
          telepathy-kde-contact-list            21.04.0-1            21.04.1-1
        telepathy-kde-contact-runner            21.04.0-1            21.04.1-1
       telepathy-kde-desktop-applets            21.04.0-1            21.04.1-1
  telepathy-kde-filetransfer-handler            21.04.0-1            21.04.1-1
    telepathy-kde-integration-module            21.04.0-1            21.04.1-1
             telepathy-kde-send-file            21.04.0-1            21.04.1-1
               telepathy-kde-text-ui            21.04.0-1            21.04.1-1
                             texmacs            1.99.19-1            1.99.20-1
                        threadweaver             5.81.0-1             5.82.0-1
                                 uim              1.8.8-5                    -
                            umbrello            21.04.0-1            21.04.1-1
                            usbguard              1.0.0-2              1.0.0-3
                         vim-runtime           8.2.2815-1           8.2.2845-1
                        vim-spell-af           20190731-2                    -
                        vim-spell-am           20190731-2                    -
                        vim-spell-bg           20190731-2                    -
                        vim-spell-br           20190731-2                    -
                        vim-spell-ca           20190731-2                    -
                        vim-spell-cs           20190731-2                    -
                        vim-spell-cy           20190731-2                    -
                        vim-spell-da           20190731-2                    -
                        vim-spell-de           20190731-2                    -
                        vim-spell-el           20190731-2                    -
                        vim-spell-en           20190731-2                    -
                        vim-spell-eo           20190731-2                    -
                        vim-spell-es           20190731-2                    -
                        vim-spell-fo           20190731-2                    -
                        vim-spell-fr           20190731-2                    -
                        vim-spell-ga           20190731-2                    -
                        vim-spell-gd           20190731-2                    -
                        vim-spell-gl           20190731-2                    -
                        vim-spell-he           20190731-2                    -
                        vim-spell-hr           20190731-2                    -
                        vim-spell-hu           20190731-2                    -
                        vim-spell-id           20190731-2                    -
                        vim-spell-it           20190731-2                    -
                        vim-spell-ku           20190731-2                    -
                        vim-spell-la           20190731-2                    -
                        vim-spell-lt           20190731-2                    -
                        vim-spell-lv           20190731-2                    -
                        vim-spell-mg           20190731-2                    -
                        vim-spell-mi           20190731-2                    -
                        vim-spell-ms           20190731-2                    -
                        vim-spell-nb           20190731-2                    -
                        vim-spell-nl           20190731-2                    -
                        vim-spell-nn           20190731-2                    -
                        vim-spell-ny           20190731-2                    -
                        vim-spell-pl           20190731-2                    -
                        vim-spell-pt           20190731-2                    -
                        vim-spell-ro           20190731-2                    -
                        vim-spell-ru           20190731-2                    -
                        vim-spell-rw           20190731-2                    -
                        vim-spell-sk           20190731-2                    -
                        vim-spell-sl           20190731-2                    -
                        vim-spell-sr           20190731-2                    -
                        vim-spell-sv           20190731-2                    -
                        vim-spell-sw           20190731-2                    -
                       vim-spell-tet           20190731-2                    -
                        vim-spell-th           20190731-2                    -
                        vim-spell-tl           20190731-2                    -
                        vim-spell-tn           20190731-2                    -
                        vim-spell-uk           20190731-2                    -
                        vim-spell-yi           20190731-2                    -
                        vim-spell-zu           20190731-2                    -
                       virglrenderer              0.8.2-1              0.9.1-1
                                 vlc             3.0.13-1             3.0.14-1
                     vulkan-broadcom             21.0.3-3             21.1.0-1
                      vulkan-headers          1:1.2.177-1          1:1.2.178-1
                  vulkan-mesa-layers             21.0.3-3             21.1.0-1
                       vulkan-radeon             21.0.3-3             21.1.0-1
                       vulkan-swrast             21.0.3-3             21.1.0-1
                                 w3m  0.5.3.git20200507-20.5.3.git20210102_6-1
                          webkit2gtk             2.32.0-2             2.32.1-1
                      wpebackend-fdo              1.8.3-1             1.9.92-1
                           wpewebkit             2.32.0-2             2.32.1-1
                          xalan-java              2.7.2-3                    -
                  xdg-desktop-portal              1.8.0-1              1.8.1-1
                        xerces2-java             2.12.1-1                    -
                             yakuake            21.04.0-1            21.04.1-1
                    zeroconf-ioslave            21.04.0-1            21.04.1-1
                            kio-fuse                    -              5.0.1-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi21.04.0.r12495.g1857ebaf0-121.04.0.r12499.gb1eeb34f1-1
                    akonadi-calendar21.04.0.r1933.g7402b73-121.04.0.r1937.g7149985-1
              akonadi-calendar-tools21.04.0.r861.gbb343d6-121.04.0.r865.g7e11fb9-1
                    akonadi-contacts21.04.0.r3002.gff3759f1-121.04.0.r3006.gbee0faca-1
               akonadi-import-wizard21.04.0.r1701.gb327524-121.04.0.r1705.g3c9dbc8-1
                        akonadi-mime21.04.0.r1613.ga4122be-121.04.0.r1616.g46f211e-1
                       akonadi-notes21.04.0.r998.g09463de-121.04.0.r1001.g3828b7a-1
                      akonadi-search21.04.0.r1085.g6f7bd8e-121.04.0.r1088.g1df6390-1
                      akonadiconsole21.04.0.r1483.g10803d2-121.04.0.r1486.gb53bd1c-1
                           akregator21.04.0.r6119.gf88c7eec-121.04.0.r6123.g0e844d97-1
                            amazfish  1.9.9.r1.gc8b22c5-1  2.0.0.r2.g225bef2-1
                                 ark21.04.0.r4521.gef64cfdb-121.04.0.r4522.gad8f47da-1
                              attica5.81.0.r806.g5d9b03d-15.82.0.r806.g5d9b03d-1
                               baloo5.81.0.r2979.gb94aa021-15.82.0.r2979.gb94aa021-1
                           bluedevil1:5.21.4.r2257.g05ab0754-11:5.21.4.r2261.gcc950509-1
                            bluez-qt5.81.0.r656.g705dee7-15.82.0.r656.g705dee7-1
                              breeze5.21.4.r2176.g3c70ee66-15.21.4.r2180.g8f7e7168-1
                          breeze-gtk5.21.4.r418.g4091eb0-15.21.4.r420.gfccd7df-1
                        breeze-icons5.81.0.r1734.ga7868107-15.82.0.r1740.g038230e0-1
                                buho 1.2.1.r12.g16ebcf2-1  1.2.2.r0.g16ebcf2-1
                     calendarsupport21.04.0.r517.ge58a41d-121.04.0.r521.g298a8e3-1
                           calindori   1.4.r14.gd68a289-1  21.05.r1.gb7c997f-1
                            discover5.21.4.r8160.gaf981612-15.21.4.r8173.geef27e49-1
                             dolphin21.04.0.r6559.gf9e3d9c8a-121.04.0.r6574.g53a778c1e-1
                             drkonqi5.21.4.r633.g3c48c539-15.21.4.r639.g74962561-1
                               elisa21.04.0.r2688.g07f3abbe-121.04.0.r2689.g3b1f0b6c-1
                          eventviews21.04.0.r642.g63c9b40-121.04.0.r645.g0bf78b3-1
                frameworkintegration5.81.0.r581.g1d78f16-15.82.0.r581.g1d78f16-1
                     grantlee-editor21.04.0.r740.ge79323b-121.04.0.r743.ga6b8da3-1
                       grantleetheme21.04.0.r316.g4404baa-121.04.0.r319.g6b3e595-1
                            gwenview21.04.0.r6580.g9dd9fc77-121.04.0.r6588.g2027581c-1
                     incidenceeditor21.04.0.r707.g2c53c91-121.04.0.r710.gb721620-1
                            index-fm 1.2.1.r58.g21402ee-1  1.2.2.r0.g21402ee-1
                           itinerary21.04.0.r1276.g68dac97-121.04.0.r1277.g337e190-1
                                 juk21.04.0.r3103.g8da3155e-121.04.0.r3104.ge35afcaa-1
                         kactivities5.81.0.r1344.g170b79a-15.82.0.r1344.g170b79a-1
                   kactivities-stats5.81.0.r350.gf7dfecb-15.82.0.r350.gf7dfecb-1
                   kactivitymanagerd5.21.4.r1347.g7d9cdb6-15.21.4.r1348.g89ed4b8-1
                        kaddressbook21.04.0.r5955.g48b2ad51-121.04.0.r5959.gc94e61d6-1
                              kalarm21.04.0.r6369.gb86cc0ff-121.04.0.r6374.g71b15a11-1
                           kalarmcal21.04.0.r1105.g1812655-121.04.0.r1109.g5291b78-1
                                kalk   0.2.r68.g6a00a4e-1  21.05.r0.gb5247dd-1
                             kapidox5.81.0.r524.g2c36122-15.82.0.r524.g2c36122-1
                            karchive5.81.0.r476.gb2de441-15.82.0.r476.gb2de441-1
                                kate21.04.0.r18105.gb4366e99c-121.04.0.r18108.gf8109d304-1
                               kauth5.81.0.r431.g5ee37da-15.82.0.r431.g5ee37da-1
                          kbookmarks5.81.0.r404.g7f1fd62-15.82.0.r404.g7f1fd62-1
                       kcalendarcore5.81.0.r1198.g2c8ad6d7d-15.82.0.r1200.g79b407c25-1
                           kcalutils21.04.0.r829.g945d78eea-121.04.0.r832.g5b1c36893-1
                              kclock 0.4.0.r83.g7b5c19e-1  21.05.r0.gbe4073d-1
                            kcmutils5.81.0.r507.g6085d90-15.82.0.r507.g6085d90-1
                             kcodecs5.81.0.r363.g27f018d-15.82.0.r363.g27f018d-1
                         kcompletion5.81.0.r437.gd41c4ef-15.82.0.r437.gd41c4ef-1
                             kconfig5.81.0.r827.gf3e8853-15.82.0.r829.g40f2371-1
                      kconfigwidgets5.81.0.r569.g4e07ea6-15.82.0.r570.ga55be68-1
                           kcontacts1:5.81.0.r3233.gdb74df7e-11:5.82.0.r3233.gdb74df7e-1
                         kcoreaddons5.81.0.r1216.g7ac3b201-15.82.0.r1217.g532c0201-1
                              kcrash5.81.0.r379.g4ed3863-15.82.0.r379.g4ed3863-1
                                kdav1:5.81.0.r1281.gc7bd0ce-11:5.82.0.r1281.gc7bd0ce-1
                         kdbusaddons5.81.0.r357.g400365a-15.82.0.r358.g189e302-1
                       kde-cli-tools5.21.4.r1835.ga72c880-15.21.4.r1842.g6d7f8ac-1
                     kde-dev-scripts21.04.0.r4128.gc530806-121.04.0.r4129.g329a38f-1
                      kde-gtk-config5.21.4.r888.g82e01e1-15.21.4.r891.gcdcdb9d-1
                      kdebugsettings21.04.0.r797.gb869f9e-121.04.0.r801.g1e0e9e0-1
                        kdeclarative5.81.0.r889.gbf4869e-15.82.0.r889.gbf4869e-1
                          kdeconnect21.04.0.r3188.g153bc227-121.04.0.r3192.g036704e1-1
                         kdecoration5.21.4.r259.g5b318a3-15.21.4.r264.ga067a6e-1
                                kded5.81.0.r398.g292a1a0-15.82.0.r398.g292a1a0-1
                     kdelibs4support5.81.0.r1011.g48bf4e1f-15.82.0.r1013.g457a5877-1
                            kdenlive21.04.0.r14393.g6cb21c200-121.04.0.r14411.g3613496aa-1
                       kdepim-addons21.04.0.r4080.g57191d38-121.04.0.r4090.gd65e1491-1
                      kdepim-runtime20.12.3.r15079.g46ac490b6-121.04.0.r15090.g3a2a751cd-1
                    kdeplasma-addons5.21.4.r8511.g725017d08-15.21.4.r8515.g913616041-1
                     kdesignerplugin5.81.0.r321.g72df7a8-15.82.0.r321.g72df7a8-1
                               kdesu5.81.0.r460.gb7d5d82-15.82.0.r460.gb7d5d82-1
                           kdewebkit5.81.0.r267.ge131752-15.82.0.r268.gd2d8247-1
                                 kdf21.04.0.r780.g58163e7-121.04.0.r781.gae6d5f4-1
                              kdnssd5.81.0.r304.g9a9c94f-15.82.0.r304.g9a9c94f-1
                           kdoctools5.81.0.r604.g74b961d-15.82.0.r604.g74b961d-1
                          kemoticons5.81.0.r369.gb05e814-15.82.0.r369.gb05e814-1
                       kfilemetadata5.81.0.r789.g0a3889e-15.82.0.r789.g0a3889e-1
                             kgamma55.21.4.r449.ge60884b-15.21.4.r454.g86956bc-1
                                kget21.04.0.r3095.gde22b7e2-121.04.0.r3096.g7be01882-1
                        kglobalaccel5.81.0.r440.gb6469a8-15.82.0.r440.gb6469a8-1
                          kguiaddons5.81.0.r361.g9d391d9-15.82.0.r361.g9d391d9-1
                           kholidays1:5.81.0.r930.gb409c9d-11:5.82.0.r930.gb409c9d-1
                            khotkeys5.21.4.r2064.g02caef4-15.21.4.r2068.gfc9bf56-1
                               khtml5.81.0.r541.g8534295-15.82.0.r543.g76d37f0-1
                               ki18n5.81.0.r459.g06bb2b1-15.82.0.r459.g06bb2b1-1
                         kiconthemes5.81.0.r520.gc0b726b-15.82.0.r520.gc0b726b-1
                 kidentitymanagement21.04.0.r3777.gf454549b-121.04.0.r3780.g6bec3091-1
                           kidletime5.81.0.r297.g2fd4d9c-15.82.0.r297.g2fd4d9c-1
                       kimageformats5.81.0.r333.g780f342-15.82.0.r335.g62f9af9-1
                               kimap21.04.0.r1083.g2758e23-121.04.0.r1086.g21ab06f-1
                         kinfocenter5.21.4.r1826.g0f08232-15.21.4.r1828.g85ed039-1
                               kinit5.81.0.r395.g0d64e3c-15.82.0.r395.g0d64e3c-1
                                 kio5.81.0.r4712.ga0833670-15.82.0.r4720.g6c501459-1
                          kio-extras21.04.0.r7005.g7380d965-121.04.0.r7007.g42f00fc1-1
                           kirigami25.81.0.r2769.gfa503643-15.82.0.r2778.g11baf9ed-1
                         kitemmodels5.81.0.r533.ge52ae3b-15.82.0.r536.g11a3839-1
                          kitemviews5.81.0.r323.g4560636-15.82.0.r323.g4560636-1
                          kitinerary21.04.0.r1721.geeb9c4e-121.04.0.r1752.gda45806-1
                         kjobwidgets5.81.0.r359.g96421aa-15.82.0.r359.g96421aa-1
                                 kjs5.81.0.r324.g2def7e8-15.82.0.r324.g2def7e8-1
                            kjsembed5.81.0.r289.gc92dcda-15.82.0.r291.g15051fa-1
                               kldap21.04.0.r850.g3d2613a-121.04.0.r853.g380d52e-1
                           kleopatra21.04.0.r5799.g419f8be9-121.04.0.r5822.g01f8c6af-1
                               kmail21.04.0.r25704.gc9d9d5ce0-121.04.0.r25721.g6a9873997-1
                kmail-account-wizard21.04.0.r776.g75978a2-121.04.0.r779.g549a0ea-1
                      kmailtransport21.04.0.r1598.g94e68c4-121.04.0.r1601.g696c03f-1
                               kmbox21.04.0.r513.g962e7fe-121.04.0.r516.g2790933-1
                        kmediaplayer5.81.0.r281.gdd9983e-15.82.0.r282.gec1df64-1
                           kmenuedit5.21.4.r963.g9633caf-15.21.4.r966.g3031e2f-1
                               kmime21.04.0.r1426.ga9fc910-121.04.0.r1429.gfc6d12e-1
                              kmplot21.04.0.r1452.ga839461-121.04.0.r1457.g0f8a6f5-1
                           knewstuff5.81.0.r1089.g38d18b87-15.82.0.r1089.g38d18b87-1
                              knotes21.04.0.r3445.gf367f456-121.04.0.r3450.g1e4815bc-1
                      knotifications5.81.0.r650.ga0598cc-15.82.0.r650.ga0598cc-1
                       knotifyconfig5.81.0.r338.g6210b2d-15.82.0.r338.g6210b2d-1
                            kongress      r198.g3568497-1      r199.g1d77510-1
                           konqueror21.04.0.r14893.ge9bc7c5d3-121.04.0.r14895.g7e9aed1cd-1
                             kontact21.04.0.r5307.gf64a9924-121.04.0.r5313.g14d1b543-1
                    kontactinterface21.04.0.r605.g363f919-121.04.0.r608.g98bfd2c-1
                          korganizer21.04.0.r11356.gadf6e83c9-121.04.0.r11364.g5624ecf3c-1
                       kosmindoormap21.04.0.r595.gd5d8bb2-121.04.0.r596.gc2acfdb-1
                            kpackage5.81.0.r657.g2d408fc-15.82.0.r657.g2d408fc-1
                              kparts5.81.0.r502.g8bfdd25-15.82.0.r502.g8bfdd25-1
                             kpeople5.81.0.r1315.g1edd4d0-15.82.0.r1315.g1edd4d0-1
                        kpimtextedit21.04.0.r1369.ga2859d6-121.04.0.r1377.ge2831e4-1
                             kpkpass21.04.0.r210.g3dc9d40-121.04.0.r213.g1a72fe1-1
                           kplotting5.81.0.r278.gf3e5ee8-15.82.0.r278.gf3e5ee8-1
                                kpty5.81.0.r321.gb17ae81-15.82.0.r321.gb17ae81-1
                    kpublictransport21.04.0.r1612.gfae064e-121.04.0.r1617.gf8ef74a-1
                        kquickcharts5.81.0.r451.g26c0c73-15.82.0.r452.gef279a2-1
                           krecorder       r94.g3a86adc-1       r96.g53444ff-1
                                krfb21.04.0.r1381.g68866dc-121.04.0.r1382.g5e18689-1
                               kross5.81.0.r320.gf122890-15.82.0.r322.gdd27630-1
                             krunner5.81.0.r618.ga1740e5-15.82.0.r621.gef6c25d-1
                             kscreen5.21.4.r1323.g4b0f09f-15.21.4.r1329.g7382845-1
                       kscreenlocker5.21.4.r836.g7ef4e50-15.21.4.r847.g52a439b-1
                            kservice5.81.0.r907.gb347ca5-15.82.0.r907.gb347ca5-1
                               ksmtp21.04.0.r342.gf4aefa7-121.04.0.r345.gdefe997-1
                         ksshaskpass5.21.4.r191.g3310435-15.21.4.r195.g37bc83d-1
                           ksysguard5.21.4.r3501.gebf85f87-15.21.4.r3503.g5b75d854-1
                         ktexteditor5.81.0.r2826.g110c91d3-15.82.0.r2832.g4e4bd09a-1
                        ktextwidgets5.81.0.r394.g83faea5-15.82.0.r394.g83faea5-1
                               ktnef21.04.0.r640.gf780a03-121.04.0.r643.g4ee2612-1
                            ktorrent21.04.0.r2736.g3cec5197-121.04.0.r2737.gdc691bab-1
                               ktrip0.99.5.r16.ge9608a8-1  21.05.r3.g9c70d13-1
                     kunitconversion5.81.0.r358.g5893dbb-15.82.0.r358.g5893dbb-1
                             kwallet5.81.0.r1063.g192e0a4-15.82.0.r1063.g192e0a4-1
                         kwallet-pam5.21.4.r238.g6c85df1-15.21.4.r242.g96e0e42-1
                            kwayland5.81.0.r1081.gd0fecf1-15.82.0.r1084.g9ac92ee-1
                kwayland-integration5.21.4.r168.gd1dc90b-15.21.4.r173.gcaec340-1
                     kwayland-server5.21.4.r1311.gd640d1c-15.21.4.r1322.g0525ea4-1
                      kwidgetsaddons5.81.0.r805.g5c768976-15.82.0.r809.gc2daa371-1
                                kwin5.21.4.r19319.gbaf3ddea7-15.21.4.r19386.gb9b58b6e6-1
                       kwindowsystem5.81.0.r588.gcac726b-15.82.0.r588.gcac726b-1
                              kwrite21.04.0.r18105.gb4366e99c-121.04.0.r18108.gf8109d304-1
                             kwrited5.21.4.r473.g6237496-15.21.4.r477.gf2b3dec-1
                             kxmlgui5.81.0.r751.g2554dfa7-15.82.0.r752.g9aef7a7f-1
                       kxmlrpcclient5.81.0.r441.g6846715ee-15.82.0.r443.g25fd65f8c-1
                      layer-shell-qt5.21.4.r36.g7d46bd6-15.21.4.r40.g525fa9b-1
                          libakonadi21.04.0.r12495.g1857ebaf0-121.04.0.r12499.gb1eeb34f1-1
                         libgravatar21.04.0.r344.g0c8d730-121.04.0.r347.gc18e7aa-1
                         libkdegames21.04.0.r2173.gc27165eb-121.04.0.r2174.gcd0dc330-1
                           libkdepim21.04.0.r824.g06e4977-121.04.0.r827.g1e772f6-1
                            libkgapi21.04.0.r1269.gcd89f8d-121.04.0.r1272.g99808eb-1
                             libkleo21.04.0.r856.g85c593a-121.04.0.r868.g703a387-1
                          libkscreen5.21.4.r1573.g3a7821b-15.21.4.r1577.g3de67e2-1
                           libksieve21.04.0.r1519.ge2b23db1-121.04.0.r1523.gf5830fa7-1
                        libksysguard5.21.4.r2217.g4b89479-15.21.4.r2223.g795def2-1
                         libquotient     r1976.gf89ece6-1     r1977.g0c8a819-1
                          mailcommon21.04.0.r1029.g69725fe-121.04.0.r1032.gce01fc9-1
                        mailimporter21.04.0.r445.g6c98c05-121.04.0.r448.g0c88874-1
                              marble21.04.0.r13304.g8957fd690-121.04.0.r13305.g6424c2b1d-1
                       marble-common21.04.0.r13304.g8957fd690-121.04.0.r13305.g6424c2b1d-1
                           marble-qt21.04.0.r13304.g8957fd690-121.04.0.r13305.g6424c2b1d-1
                           maui-clip 1.1.0.r14.gd0690b8-1  1.1.1.r0.gd0690b8-1
                           maui-nota 1.2.1.r35.gab0dbc5-1  1.2.2.r1.gf42d352-1
                            maui-pix 1.2.1.r37.g327d024-1  1.2.2.r0.g327d024-1
                             mauikit1.2.1.r139.g6b0f399a-1 1.2.2.r5.gc9c922f0-1
                mauikit-filebrowsing        r34.267b862-1        r36.93a9bde-1
                       mbox-importer21.04.0.r489.g2d58ab2-121.04.0.r492.gc4bc6f0-1
                          messagelib21.04.0.r5922.g1d0ed197-121.04.0.r5933.g6488be32-1
                               milou5.21.4.r737.g9eefca5-15.21.4.r741.ge5b5a0a-1
                     modemmanager-qt5.81.0.r504.g3368386-15.82.0.r505.gd355355-1
                             neochat    r1655.gf20501fe-1    r1660.g8f403012-1
                   networkmanager-qt5.81.0.r1099.g44468d1-15.82.0.r1100.g5b71e55-1
                              okular21.04.0.r9304.g34b8c1e72-121.04.0.r9322.g3ff6ff35b-1
                              oxygen5.21.4.r4411.g60706eb2-15.21.4.r4414.g85e6c9e8-1
                        oxygen-icons1:5.81.0.r5.gbff159d-11:5.82.0.r5.gbff159d-1
                    oxygen-icons-svg1:5.81.0.r5.gbff159d-11:5.82.0.r5.gbff159d-1
                              parley21.04.0.r4404.gdcf01c57-121.04.0.r4406.g2a5c816c-1
                   pim-data-exporter21.04.0.r2403.g5ed57b7b-121.04.0.r2406.gcd6ac2ac-1
                    pim-sieve-editor21.04.0.r1468.g1260cc4-121.04.0.r1472.g3906e0c-1
                           pimcommon21.04.0.r1046.ga44e051-121.04.0.r1049.gc29a711-1
          plasma-browser-integration5.21.4.r1245.g5405143d-15.21.4.r1250.gffe37ebf-1
                      plasma-desktop5.21.4.r8417.g74e95a2a0-15.21.4.r8446.gf2f21e54a-1
                       plasma-dialer   0.3.r19.g3921ecb-1 21.05.r11.gacf9c6a-1
                        plasma-disks5.21.4.r200.gf51003f-15.21.4.r205.g22862d9-1
                     plasma-firewall5.21.4.r484.gb7623b3-15.21.4.r488.g45d86b7-1
                    plasma-framework5.81.0.r15849.ga9372fb6a-15.82.0.r15850.g9a8613612-1
                  plasma-integration5.21.4.r512.g68f7d1b-15.21.4.r516.gc123126-1
                           plasma-nm5.21.4.r3041.ged9ac713-15.21.4.r3044.g7e42256f-1
                           plasma-pa5.21.4.r937.g8b3b582-15.21.4.r940.g66e97be-1
             plasma-phone-components5.21.4.r1389.g8852ad01-15.21.4.r1394.g866f52e3-1
                    plasma-phonebook      r216.g4524c5b-1      r232.gb22a40f-1
                          plasma-sdk5.21.4.r2264.ge9ee7a4a-15.21.4.r2267.g2debfd05-1
                     plasma-settings      r871.g09ceccd-1      r879.gd3293e4-1
                plasma-systemmonitor5.21.4.r418.g38b2876-15.21.4.r426.g3ada685-1
                  plasma-thunderbolt5.21.4.r130.g50c56a4-15.21.4.r131.g4040d01-1
                        plasma-vault5.21.4.r330.g03c7ff3-15.21.4.r332.geb439e8-1
              plasma-wayland-session5.21.4.r10245.gbc0e09345-15.21.4.r10265.g901cb4a7f-1
                    plasma-workspace5.21.4.r10245.gbc0e09345-15.21.4.r10265.g901cb4a7f-1
         plasma-workspace-wallpapers5.21.4.r255.g7bf46a9-15.21.4.r257.gaed7cb3-1
                    polkit-kde-agent5.21.4.r489.g312fd58-15.21.4.r492.g1dd5955-1
                          powerdevil5.21.4.r2430.gd7c1181a-15.21.4.r2433.g3a86d909-1
                       print-manager21.04.0.r1020.gf7a3057-121.04.0.r1021.g7429802-1
                              prison5.81.0.r307.gd795030-15.82.0.r309.g9102227-1
                             purpose5.81.0.r848.g3a9554b-15.82.0.r852.g853010e-1
                          qmlkonsole       r83.ga10b9fc-1       r87.g51d8906-1
                  qqc2-desktop-style5.81.0.r481.ga5477e9-15.82.0.r482.g54308c4-1
                            sddm-kcm5.21.4.r576.g28f3a33-15.21.4.r580.g6d236b6-1
                               solid5.81.0.r667.g51da9c9-15.82.0.r668.g3bdef38-1
                              sonnet5.81.0.r610.gc844d7a-15.82.0.r611.g61b4183-1
                            spacebar      r370.g032ba29-1      r386.gf4f47a1-1
                             svgpart21.04.0.r158.gacf1ca4-121.04.0.r159.g3b49dfc-1
                         syndication5.81.0.r822.gae3f065-15.82.0.r823.g256a953-1
                 syntax-highlighting5.81.0.r1578.gf292e54f-15.82.0.r1580.g717399ea-1
                      systemsettings5.21.4.r2424.g1c7b26f0-15.21.4.r2429.g50a47f40-1
                        threadweaver5.81.0.r491.g4f1ef2a-15.82.0.r491.g4f1ef2a-1
                            umbrello21.04.0.r8241.ge01b8ac44-121.04.0.r8246.g7bc661137-1
                               vvave 1.2.1.r36.g4d66b10-1  1.2.2.r0.g4d66b10-1
              xdg-desktop-portal-kde5.21.4.r353.g3cd683a-15.21.4.r361.gf7c1523-1
                              peruse                    -   1.80.r6.g25247a1-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #manjaro-arm:arm-testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
Donation
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Poll
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Old Issues
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
Save the file and reboot.
Initally, my trackpad didn’t work after the update. I plugged in a usb mouse and was able to navigate to a shut down. I unplugged the mouse, rebooted and the track pad is now working with no issues.
Seamonkey crashes due to a library error:
[tjh@PineBookPro ~]$ seamonkey
XPCOMGlueLoad error for file /usr/lib/seamonkey/libxul.so:
/usr/lib/seamonkey/libxul.so: undefined symbol: u_strToUpper_68
Couldn’t load XPCOM.
Running stock KDE Plasma on a PineBookPro:
Operating System: Manjaro-ARM
KDE Plasma Version: 5.21.5
KDE Frameworks Version: 5.82.0
Qt Version: 5.15.2
Kernel Version: 5.12.4-1-MANJARO-ARM
OS Type: 64-bit
Graphics Platform: X11
Processors: 6 ×
Memory: 3.8 GiB of RAM
Graphics Processor: Mali T860
Both octave-cli and R crash upon execution. But these can be resolved by remappinng the blas libraries:
$ cd /lib
$ sudo ln -s libopenblas_armv8p-r0.3.14.so libblas.so.3
$ sudo rm libblas.so
$ sudo ln -s libblas.so.3 libblas.so
Both of those packages octave and r has not been updated in upstream between this stable update and the previous. So this would also have been an issue in the previous update and upstream.
Even openblas didn’t change…
Wayland is mentioned and updated during the up date, but not actived (ARM and x86)
I think it’s a huge transition, x11 → Wayland
When Wayland will be available for the use on ARM ?
Testers needed ?
It is available. Just not enabled by default on most editions. I think both Gnome and Sway uses it by default.
On plasma, you can get it, by installing plasma-wayland-session and switcing to “Plasma (Wayland)” in the Login Manager.
As far as I know, Wayland is not supported on XFCE and MATE.
Thanks, I did, I’m waiting on the device reboot…
it’s done
It looks good after the reboot, I reboot now with Wayland…
The device don’t reboot with the GUI or CLI, I unplug and plug the power supply
After the reboot with Wayland krfb doesn’t work…
the other software are working, looks good for a first test with Wayland
I rebooted with x11 and krfb is working again :-)
Yeah, some software is not wayland ready yet. :slight_smile:
Thanks for your reply.
I did an image for the Odroid C2 kde stable branch, it don’t boot, a message on the begining and then nothing…
The blue led don’t blink, I flashed the image on an emmc module.
I take a picture, user feedback, see below
even my attempts in the last few days have failed.
No working image creation for Odroid C2 xfce and PP Lomiri on testing & unstable
Hm. I must admit, I haven’t tested the Odroid C2 for a while. But it seems like the Odroid C2 would also need the change in initrd loadaddr as the other amlogic boards have.
Lomiri has been broken for a while now. Needs rebuilds of all the packages I think.
The favorite program icons in the start menu in the KDE Plasma are not visibly selected when mouse cursor is above them or using the arrow keys, but you can use the arrow keys to select programs in the favorites menu blind, if you feel lucky.
Also the ‘allow automatic sleep and screen lock’ (battery widget) and ‘turn on presentation mode’ (display widget) still aren’t working properly (the screen won’t lock automatically in case of re-allowing automatic sleep and etc. or turning off the presentation mode).
Update went fine on my Pinebook Pro.
Anbox stopped working, but I received the update for Anbox now.
Thanks.
