linux-vim
package is still on 5.11.
S905X device does not boot after update. Uboot - OK, Kernel - OK, but nothing happens after log: āStarting version 248-5-archā. I have uart access, how I can try to debug this? How can I display the full log on the screen during boot?
After update on pinebook 1080p with sway, the sway graphics is not working again. They told me that it is due to wlroots rewrites and mali3d lima driver bug. There are 2 solutions to the problem:
- upgrade mesa to newest development drivers:
sudo pacman -Syu mesa-git
or
- downgrade sway & wlroots:
sudo pacman -U /var/cache/pacman/pkg/wlroots-0.12.0-1-aarch64.pkg.tar.xz /var/cache/pacman/pkg/sway-1:1.5.1-2-aarch64.pgk.tar.xz
PS: Should I write this post/solution to the Issues wiki post on top of thread?
I would suggest making an own topic with the error description and then add a post with your proposed solution and mark it as solution to the original errorā¦ so it can be easily found and checked upon.
Hello @Strit you wrote:
āWe even updated the uboots for most of the AMLogic boards.ā
Can I get these uboots from Github for testing purpose?
Iāve installed Manjaro-ARM-xfce-vim3-20210510.img.xz, but there are no new uboots.
Thanks in advance.
Not sure Vim 3 uses our uboot currently.
Just checked, it does not. It just uses a boot script, so it relies on uboot from android on the eMMC.
Hi,
@Strit
Issue, no reboot after this stable up date for the Odroid C2 kde.
I built a new image, same issue no reboot.
If Iām not wrong itās the same issue as @Lila-Kuh
The Odroid c4 kde reboot after the last testing up date (2021.05.13)
x96mini tv box here.
Usually everything for khadas vim2 boots for me.
After the update Manjaro fails to boot, I created an installation myself but that also didnāt boot.
Iāve always had a 2 partition layout and the right extlinux conf, so thatās not the problem.
Hi there, thanks for the update!
Will there eventually be a Gnome RPi4 release? Or how can I get Gnome 40.1 running on my Rpi4?
Please have a look at our community builds: GitHub - manjaro-arm-community/gnome-images
Thanks, this is awesome! Should be in the download section on the main website.
soon i guess, in the raspberry imager as wellā¦ channel ārasberry pi projects & moreā just made a video review and ive messaged leepspvideo to mention it in pi news as well
Hereās the link to the video: https://youtu.be/C1agU4LdS_c
