Hello ARM community.
Pretty big update this time. Linux 5.12 released, KDE has stuff going on. Gnome got a point release.
We even updated the uboots for most of the AMLogic boards.
Some highlights:
- Most of our kernels got updated
- Firefox updated to 88.0.1
- Thunderbird updated to 78.10.1
- LibreOffice updated to 7.1.3
- KDE Gear Applications updated to 21.04
- Also Gnome 40.1 is available
- Vivaldi got updated to 3.8
- Lots of updated packages for our Mobile offerings
- The regular Python updates
- And regular updates from upstream
How to use the new Kodi RPI on Manjaro ARM (by @Darksky)
If anyone wants to test kodi on the rpi:
Change to the unstable or testing branch and install kodi packages:
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4 xf86-video-fbturbo-git
Boot straight into Kodi
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi.
Kodi home directory will be /var/lib/kodi.
So put test video in /var/lib/kodi/Videos so you can get to it after setting up the video directory in kodi.
Upstream Notifications:
Older notifications
Chromium will loose sync support in early March:
Arch Linux - News: Chromium losing Sync support in early March
ghostpcl>=9.53.2-2 and ghostxps>=9.53.2-2 updates require manual intervention:
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss
and zn_poly
packages requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
https://www.archlinux.org/news/zn_poly-092-2-update-requires-manual-intervention/
The packages hplip
and firewalld
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package changes:
(Sun May 9 16:11:47 CEST 2021)
- arm-stable community aarch64: 634 new and 621 removed package(s)
- arm-stable core aarch64: 37 new and 35 removed package(s)
- arm-stable extra aarch64: 892 new and 884 removed package(s)
- arm-stable kde-unstable aarch64: 397 new and 396 removed package(s)
See all the package changes here !
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #manjaro-arm:arm-testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
Donation
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Poll
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
