I recently installed the Manjaro os
I installed ark shortly after to play with my friends, and i was able to.
The next day when i got on to play, i tried joining a server and my ark crashed here is the information it gave me, lmk if you need more info about my system or anything:
Generating report for minidump
Application version 1.0.0.0
... built from changelist 0
OS version Linux 5.9.16-1-MANJARO (network name: ethan-alienwareaurorar7)
Running 6 x86_64 processors (12 logical cores)
Exception was "SIGSEGV: invalid attempt to access memory at address 0x00000003"
<SOURCE START>
<SOURCE END>
<CALLSTACK START>
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1db4022] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0xa0626f] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1db4d54] + some bytes
Unknown!/usr/lib/libpthread.so.0(+0x13960) [0x7fe304d47960] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1db516b] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1e050ac] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1df78d5] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x27bfb6a] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x27c55e4] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x2285e15] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x212c7d4] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x212b99f] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1da55c3] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1da4f73] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1da4ea4] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0xa00fb8] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0xa01c03] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0xa06a7b] + some bytes
Unknown!/usr/lib/libc.so.6(__libc_start_main+0xd5) [0x7fe302fccb25] + some bytes
Unknown!/home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x9fcf5c] + some bytes
Assertion failed: Assertion failed: IsValid() [File:Runtime/Core/Public/Templates\SharedPointer.h] [Line: 658]
[Callstack] 02 0x0000000001db4022 /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1db4022]
[Callstack] 03 0x0000000000a0626f /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0xa0626f]
[Callstack] 04 0x0000000001db4d54 /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1db4d54]
[Callstack] 05 0x00007fe304d47960 /usr/lib/libpthread.so.0(+0x13960) [0x7fe304d47960]
[Callstack] 06 0x0000000001db516b /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1db516b]
[Callstack] 07 0x0000000001e050ac /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1e050ac]
[Callstack] 08 0x0000000001df78d5 /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1df78d5]
[Callstack] 09 0x00000000027bfb6a /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x27bfb6a]
[Callstack] 10 0x00000000027c55e4 /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x27c55e4]
[Callstack] 11 0x0000000002285e15 /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x2285e15]
[Callstack] 12 0x000000000212c7d4 /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x212c7d4]
[Callstack] 13 0x000000000212b99f /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x212b99f]
[Callstack] 14 0x0000000001da55c3 /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1da55c3]
[Callstack] 15 0x0000000001da4f73 /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1da4f73]
[Callstack] 16 0x0000000001da4ea4 /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x1da4ea4]
[Callstack] 17 0x0000000000a00fb8 /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0xa00fb8]
[Callstack] 18 0x0000000000a01c03 /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0xa01c03]
[Callstack] 19 0x0000000000a06a7b /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0xa06a7b]
[Callstack] 20 0x00007fe302fccb25 /usr/lib/libc.so.6(__libc_start_main+0xd5) [0x7fe302fccb25]
[Callstack] 21 0x00000000009fcf5c /home/ethan/.local/share/Steam/steamapps/common/ARK/ShooterGame/Binaries/Linux/ShooterGame() [0x9fcf5c]
<CALLSTACK END>
0 loaded modules
Report end!
Welcome to Manjaro!
