Hello. Thank you for viewing. After updating my computer yesterday, Ark is not working properly it seems. When I compress files, the ‘Dolphin’ windows, that shows the progress of the compression, never finishes even when the compression is complete. (For 7zip and for Zip)
When I click stop, I get Application Closed Unexpectedly followed by Dolphin Crashing
I believe I am using Wayland. Honestly, i do not know, as I am not an advanced Manjaro Linux user. I started a few months ago, so I don’t know which session I am using.
What happens if you try to only compress a single file with 7z compression in Ark?
What happens if you try to compress a small folder (few files only) with 7z compression in Ark?
What happens if you try to use “Store” or “Deflate” with the minimum compression strength using Zip or 7z in Ark?
What happens if you use ZSTD (Zstandard) with the default (level 3) compression strength?
What happens if you wait long enough for it to “really” complete? Does it ever exit cleanly? (Your screenshot shows it is compressing and archive 13,388 files!)
What happens if you try to compress the culprit folder (13,388 files!) using the command-line instead of Ark? (With the highest / ultra settings that 7z allows.)
Lord have mercy on my soul! As much as I love KDE, they seem to be dropping the ball on their updates and development overall. Has there been a loss of developers? QA testers?
I am facing the SAME EXACT ISSUE ever since the latest update, on two different computers! (I just tested it on on both computers; both recently fully updated on the Stable branch.)
The issue still stands that “rolling” with constant updates on a KDE desktop keeps breaking things more than I remember in the past. It’s like a gamble each time there’s a batch of updates, and you have to cross your fingers and hope nothing breaks.
I have a “notepad” out in which I bump into bugs and crashes and hangs and odd behaviors, which I try to submit bug reports, one by one, but it’s becoming too much of a hassle now. I’m losing enthusiasm, and my hunch tells me that KDE development has different visions and goals going forwards.
Right-click → Compress → Compress to → choose 7z format
Even if the archive is successfully created, the progress indicator will hang and “error out” if you try to stop or close it.
UPDATE: It’s a random surprise each time! How fun! Sometimes it will behave as @attishno1’s original post. Sometimes it will immediately abort in failure. Sometimes it will freeze the corresponding Dolphin window in which I need to forcefully terminate Dolphin to get it working again.
I understand. @winnie is actually experiencing the same issue that I am. The archives are being created successfully. It is just that the dialog box never closes. It just stays there.
If you manually add folders and files into a new archive (using Ark itself, not the Dolphin context menu), it behaves normally, regardless of size or number of files. The progress indicator in the bottom-right corner will behave normally as well.
