Apps and system not connecting to internet but browsers do
Greetings.
I am having issues with my internet connection: applications (Thunderbird, RStudio, etc) cannot access internet but web browsers can. Also, I cannot update any package through terminal.
When I connect to other networks everything is ok: system and application access internet. My other pc (also Manjaro but KDE) does not have this issue on the same network.
Week or two ago, everything worked flawlessly.
I am using -MANJARO x86_64 20.2.1 Nibia GNOME 3.38.3 kernel: 5.9.16-1
I did:
  • router factory reset
  • disable IPv6
  • NetworkManager restart
  • firewall disabled
Do you have any recommendations?
Thank you
Hi @Grunf11, and welcome!
That, to me, sounds kind of like some kind of proxy somewhere.
Double chefk that and make sure you didn’t, knowingly or accidentally set a proxy somewhere. Maybe one for KDE only. Not dure.
Hope this helps.
There was no proxy but I managed to solve it by changing nameserver in etc/resolv.conf to google servers by adding these lines:
nameserver 8.8.8.8
nameserver 8.8.4.4
and also in etc/resolvconf.conf adding this line:
resolv_conf=/etc/resolv.conf
I still dont know why this issue randomly started few weeks ago but these lines in resolv.conf solved it.
