Application (flatpak) installs and launches twice
Hello,
I’m very new to Linux and Manjaro so I’m sorry if this is a rookie question. I installed Slack from Pamac, which only comes as a Flatpak. It installed correctly, but created two entries in my application menu, and when I launch it, it starts twice (and eats twice as much RAM).
Tried to reboot, uninstall and re install from the Konsole, doesn’t seem to be working. Install is fresh, I’m running 510 kernel and plasma 5.22.4
Didn’t quite find the solution to this problem after a quick search online.
Anybody help ? Greatly appreciated :stuck_out_tongue:
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    [HowTo] become a Manjaro power user when you're a wizard at Windows but a N00b at Manjaro / Linux
    because Slack is also available in the AUR…
  2. For the future, please read this:
    How to provide good information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  3. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
Thanks a lot ! Here is my inxi output.
  Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=ba2e3d3a-ca69-454a-a0fc-7875a258620f rw quiet apparmor=1
  Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
  Type: Laptop System: Micro-Star product: Modern 15 A11M v: REV:1.0
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: Micro-Star model: MS-1552 v: REV:1.0 serial: <filter>
  UEFI: American Megatrends LLC. v: E1552IMS.111 date: 03/01/2021
  ID-1: BAT1 charge: 30.0 Wh (59.8%) condition: 50.2/52.4 Wh (95.7%)
  volts: 11.4 min: 11.4 model: MSI Corp. MS-1552 type: Li-ion serial: N/A
  status: Discharging
  RAM: total: 7.48 GiB used: 3.18 GiB (42.5%)
  Info: Quad Core model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
  arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1 microcode: 88
  cache: L2: 12 MiB bogomips: 44864
  Speed: 1000 MHz min/max: 400/4700 MHz Core speeds (MHz): 1: 1000 2: 1000
  3: 1000 4: 1000 5: 1002 6: 1000 7: 1001 8: 1000
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
  avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
  avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush
  clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
  dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
  fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify
  hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
  lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
  nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
  pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
  sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
  ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
  tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
  xsavec xsaveopt xsaves xtopology xtpr
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Micro-Star MSI
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 3-7:2
  chip-ID: 5986:211c class-ID: 0e02
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
  screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.1.5
  direct render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Micro-Star MSI
  driver: sof-audio-pci alternate: snd_hda_intel,snd_sof_pci bus-ID: 00:1f.3
  chip-ID: 8086:a0c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.32 running: yes
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel port: 3000
  bus-ID: 00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
  bus-ID: 3-10:3 chip-ID: 8087:0026 class-ID: e001
  Local Storage: total: 476.94 GiB used: 44.58 GiB (9.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD
  lanes: 4 type: SSD serial: <filter> rev: P6MA001 temp: 33.9 C scheme: GPT
  ID-1: / raw-size: 290.45 GiB size: 284.83 GiB (98.06%)
  used: 44.55 GiB (15.6%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
  label: N/A uuid: ba2e3d3a-ca69-454a-a0fc-7875a258620f
  used: 32.1 MiB (33.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: N/A uuid: 9E5A-4C4B
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 186.38 GiB fs: ntfs label: N/A
  uuid: B2C260B9C2608407
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 3-7:2 info: Acer HD Webcam type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:211c
  class-ID: 0e02
  Device-2: 3-10:3 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
  interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
  class-ID: e001
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 37.0 C mobo: N/A
  Processes: 258 Uptime: 12m wakeups: 1164 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 Packages: 1231 pacman: 1225 lib: 329
  flatpak: 6 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
It also appears to do it with Skype. These are the only two faltpaks I’ve installed, but I need them for work. I understand that they are also available in the AUR, but I’ve been told that as a beginner it was best to avoid the AUR as much as I can until I get a better understanding of what I’m doing.
What can I do next ? Can I provide more information ?
This is weird behavior.
Can you run flatpak run com.slack.Slack from the terminal?
Yes I can. It does the same thing.
My terminal doesn’t seem to do able to complete the task tho ; if I try to close it I get a warning saying that bwrap is still running
Flatpaks and snaps come with their own disadvantages, so:
  • file a bug upstream with the package maintainer
    OR
  • activate the AUR, delete all snaps and flatpaks and install from the AUR and then the application runs natively and any bugs can be taken up with the developer of the software instead of the flatpak maintainer.
:man_shrugging:
Ok done that, indeed it works better. Thanks !
In the meantime I also tried to download several packages from the AUR but it is hard to see which ones are maintained and which aren’t. Is there anyway of judging if a package is still relevant prior to downloading and testing it ?
Oh and also, many of them end with -git. What is the difference between those and the “regular ones” ?
