This is not a big issue for me but I did wonder if anyone had had any success getting the Asus AC56 wireless USB adaptor to work in KDE?
I have gotten it working seamlessly on the other laptop which runs LMDE (Mint) but thus far I have found nothing regarding Manjaro or Arch when I widened out the search that points to success.
If anyone has succeeded please drop me a line. Would be v helpful.
Bus 002 Device 002: ID 8086:0aa5 Intel Corp. Intel(R) RealSense⢠Camera SR300
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 0489:e09f Foxconn / Hon Hai
Bus 001 Device 004: ID 09da:0260 A4Tech Co., Ltd. KV-300H Isolation Keyboard
Bus 001 Device 003: ID 0b05:17d2 ASUSTek Computer, Inc. USB-AC56 802.11a/b/g/n/ac Wireless Adapter [Realtek RTL8812AU]
Bus 001 Device 006: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 002: ID 25a7:fa61 Areson Technology Corp Elecom Co., Ltd MR-K013 Multicard Reader
I see the system finds the Asus Dongle but how to activate it?
When you have a piece of hardware that does not work out of the box, it is advisable to visit linux-hardware.org to see which drivers others are using. In this case, we can learn that the rtl8812au driver is needed, which you can install from AUR by running pamac build rtl8812au-dkms-git.
But first please remove the other driver you tried: pamac remove rtl8814au-dkms-git.
So I removed the driver as you instructed, enabled AUR, searched from add/remove software and built the driver. Manjaro can see the dongle but its still not working. I did try powering down and restarting the system and I have tried more than one USB port just in case one has a fault of some kind.
Output below:
Bus 002 Device 002: ID 8086:0aa5 Intel Corp. IntelŽ RealSense⢠Camera SR300
I just realized that the driver I linked is now obsolete, please remove it using pamac remove rtl8812au-dkms-git, and install a different one: pamac build rtl88xxau-aircrack-dkms-git.
modprobe: FATAL: Module rtl8812au not found in directory /lib/modules/5.9.11-3-MANJARO
AndâŚ
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/8p, 5000M
|__ Port 5: Dev 2, If 0, Class=Video, Driver=uvcvideo, 5000M
|__ Port 5: Dev 2, If 1, Class=Video, Driver=uvcvideo, 5000M
|__ Port 5: Dev 2, If 2, Class=Video, Driver=uvcvideo, 5000M
|__ Port 5: Dev 2, If 3, Class=Video, Driver=uvcvideo, 5000M
|__ Port 5: Dev 2, If 4, Class=Vendor Specific Class, Driver=, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/16p, 480M
|__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 3, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 6: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 6: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 7: Dev 5, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 7: Dev 5, If 1, Class=Wireless, Driver=btusb, 12M
|__ Port 10: Dev 6, If 0, Class=Vendor Specific Class, Driver=rtsx_usb, 480M
I have built the driver and then ran sudo rfkill unblock all, powered down the system and restarted but sadly its there but not working:
Bus 001 Device 004: ID 0489:e09f Foxconn / Hon Hai
Bus 001 Device 003: ID 09da:0260 A4Tech Co., Ltd. KV-300H Isolation Keyboard
Bus 001 Device 007: ID 0b05:17d2 ASUSTek Computer, Inc. USB-AC56 802.11a/b/g/n/ac Wireless Adapter [Realtek RTL8812AU]
Bus 001 Device 005: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
I wonder is it worth following this approach from " 1. Stop Network Manager" onwards?
|__ Port 1: Dev 8, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 1: Dev 8, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 10, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 6: Dev 11, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 6: Dev 11, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 7: Dev 4, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 7: Dev 4, If 1, Class=Wireless, Driver=btusb, 12M
|__ Port 10: Dev 5, If 0, Class=Vendor Specific Class, Driver=rtsx_usb, 480M
[s@s-aspirevn7592g ~]$ lsusb
Bus 001 Device 011: ID 09da:0260 A4Tech Co., Ltd. KV-300H Isolation Keyboard
Bus 001 Device 010: ID 0b05:17d2 ASUSTek Computer, Inc. USB-AC56 802.11a/b/g/n/ac Wireless Adapter [Realtek RTL8812AU]
Bus 001 Device 008: ID 25a7:fa61 Areson Technology Corp Elecom Co., Ltd MR-K013 Multicard Reader
