Any symlinks at hard-drive with BTRFS file system (linux) open their folders at NTFS file system (when double click), but doesn’t link to their folders when do right click->properties->point to.
Symlinks located and linking from BTRFS to BTRFS (inside Linux) run when do click->properties->point to
Your picture says that The file or folder /home/.... does not exist.
which means that the link points to a location within your /home/$user directory
which is unlikely the point where you have mounted your ntfs drive to
which is why it doesn’t exist
Thanks, but the link points to a location within my /home/$user directory
is the point where I had mounted my ntfs drive to which is exist and opens with this link
Any Linux mount any hard-disk to /run automatically. I didn’t. Where I should mount my hard-discs? Is that correctly to create directory /media/ or /discs/ right in root directory and mount my discs with NTFS fs there?
Line in fstab:
UUID=70F16E1582224975 /drives/320_tmp ntfs-3g defaults,uid=1000 0 0
But! If make this (right click on link and press “points to” button) not from Desktop but from link right in Dolphin (/home/vorobuszek/Desktop/) - It works, directs to original location.
I cannot say what your issue is - I cannot replicate it.
Please create the symlink using the Konsole terminal emulator.
Open konsole in your home folder (press tab for autocomplete
ln -s /drives/320_tmp/ {TAB}
I have been meaning to test btrfs - so I replicated reinstalled my system with btrfs and my usual setup - and added in a USB formatted disk mounted in my usual structure
The second test using drag’n’drop with pcmanfm file manager - when asked - I chosed Create Symlink
The third test has been created using dolphin drag’n’drop - when asked - chosed Create Symlink
$ ls -lA
lrwxrwxrwx 1 fh fh 49 18 sep 08:42 '[NOTECONS01] Linux USB Crash Card Adapter' -> '/a/ntfs/[NOTECONS01] Linux USB Crash Card Adapter'
lrwxrwxrwx 1 fh fh 49 18 sep 08:46 '[NOTECONS01] Linux USB Crash Card Adapter (created using dolphin)' -> '/a/ntfs/[NOTECONS01] Linux USB Crash Card Adapter'
lrwxrwxrwx 1 fh fh 50 18 sep 08:22 'ntfs test disk' -> '/a/ntfs/[NOTECONS01] Linux USB Crash Card Adapter/'
This reference has no underscores yet in a previous comment you are using underscores Proko_Figure_drawing_fundamentals
Spelling and casing is very important on a case sensitive system - the same goes for filenames with spaces - either escape the spaces like name\ with\ spaces or quote the name like “name with spaces”
doesn’t help anything you say. Even simple file named “1” causes the same problem. No problems if link locate to any file/directory from root btrfs drive
