Any command leads to "command not found" in text console (CTRL+ALT+F(n))
  1. When I use text console by CTRL+ALT+F3 and log in under my user, I can’t use any commands. For example:
    ls produces command not found, and so on.
  2. When I log in under root user - everything works as expected.
  3. When I do sudo su myuser and change the user ty my one from root - works as expected.
I checked PATH and it’s the same for cases 1) and 3), so I guess it’s not the issue with the PATH.
Probably there is a permissions issue, but how can I check it?
You have another post where you mention you can’t login … That and this one leads me to speculate you have ownership issues on files and folders in your home directory. Please fix that first.
sudo chown $USER:$USER $HOME
Reboot your system just in case.
After @anon89812132 suggestion:
Have you made any recent changes to .bashrc or .profile for USER or related system files?
Try:
  • Re-source (. .bashrc or source .bashrc) those files and see if there are any errors
  • echo "${PATH//:/$'\n'}"
  • type -a ls
  • use the full path from the above output /bin/ls -l
@anon89812132 before and after changing the ownership, I see the same picture:
ls -la /home
drwxr-xr-x 5 root root lost+found
drwxr----- 40 myuser myuser myuser
After reboot, it still doesn’t work.
@stargazer before I got all these issues, I installed oh-my-zsh, but I’ve been working for 2 more days after it.
When I do source /home/myuser/.bashrc, when I logged in under my user in text console, I get:
zsh: command not found uname
zsh: command not found shopt
zsh: command not found complete
/usr/share/bash-completion/bash_completion:1567: parse error near `|`
/home/myuser/.bashrc:type:66: bad option -P
I don’t know how you set your bash or zsh, or if you mixed something related to them. Make sure if you use zsh that you do this:
cp /etc/skel/.zshrc ~/
chsh -s /bin/zsh
And reboot to make sure.
If you use bash, then either you fix the typo in your .bashrc at line 66, or you do:
cp /etc/skel/.bashrc ~/
chsh -s /bin/bash
The .bashrc is the default one, installed with Manjaro KDE, I didn’t change it and it works well when I do sudo su myuser from root account.
So, I tried to change my default shell, just by running chsh -s /bin/sh and now it works!!! All the commands are now available, with syntax highlighting (as it was by default).
Moreover, I can now log in without errors to my profile (Login screen freezes after entering login/password, but works for root user)
Seems like zsh somehow breaks the system, but I can’t figure out how and in which way
I have never done that in my life, never had to do it. :slight_smile: Don’t know the end of it. Might test it one day.
I’ve never used this syntax either :slight_smile:
Does it make any difference if you use, sudo su - myuser or sudo su --login myuser or sudo -i -u myuser.
Notice these are going to create a login shell, thus read the specific login files.
What’s the output of chsh -l.
