Another Failed Update
My Package Manager failed to update. I tried updating a few packages at a time, in the hopes that I’d be able to find out which bit wasn’t working. Updated quite a few, then it failed again. Then the Package Manager disappeared completely. Looking in the forum I have tried a few suggestions, but still failed to get things back to work. I can’t read pdfs, nor does Libreoffice open, along with several other apps, but some do open. Presumably those that use libxml2 fail, but…:
[katherine@katherine-labtop ~]$ sudo pacman -Syu
[sudo] password for katherine:
:: Synchronising package databases...
 core is up to date
 extra is up to date
 multilib is up to date
resolving dependencies...
:: installing libxml2 (2.14.3-1) breaks dependency libxml2.so=2-64 required by electron32
:: installing libxml2 (2.14.3-1) breaks dependency libxml2.so=2-64 required by electron33
:: installing libxml2 (2.14.3-1) breaks dependency libxml2.so=2-64 required by rest
Mod Edit: Fixed formatting
That’s a bad idea, because it’s guaranteed to break your system.
Also, you are probably better off updating by way of pacman — not pamac — from within a tty environment, and rebooting right away after the process has finished.
For now, I will leave you with these two HowTos, hoping they may be of help… :point_down:
You could try removing those packages. If they’re still required by something then you’ll get another error, if not then update.
sudo pacman -R electron32 electron33 rest
sudo pacman -Syu
Just to add, electron32 & electron33 are both AUR packages. rest no longer exists in Manjaro’s repos or the AUR
pamac info electron32 electron33 rest | grep -E 'Name|Version|Repository|not found'
Version               : 32.3.3-1
Repository            : AUR
Version               : 33.4.11-2
Repository            : AUR
Error: target not found: rest
You can check what foreign packages (i.e. those not currently in Manjaro’s repos) you have on your system by running the following command:
pamac list -m
I was able to remove electron32 and electron33 but when I tried to remove “rest” I got the message:
sudo pacman -R rest
checking dependencies...
:: removing rest breaks dependency 'rest' required by lib32-rest
I fear I’ve played too much with trying out different apps, which probably accounts for probably dormant, unnecessary dependencies - but Linux, in its various forms, is so much more fun Windows!
Then try removing lib32-rest.
It really is. :slight_smile:
I think I tried that correctly, but obviously not completely correctly:
sudo pacman -R lib32-rest
Packages (1) lib32-rest-0.8.1-4
Total Removed Size:  0.13 MiB
:: Do you want to remove these packages? [Y/n] y
(1/1) removing lib32-rest                          [######################] 100%
(1/1) Arming ConditionNeedsUpdate...
 core is up to date
 extra is up to date
Looks like you didn’t remove rest
sudo pacman -R rest
sudo pacman -Syu
Looks like things are happening now, but I’ve got a bit of waiting to do (currently at 11/505 - so I’m obviously a bit behind with my upgrades.
Thank you so much for your guidance.
Not sure where the html tags came from, but the way the output was formatted kept cutting off the package that was causing the trouble.
In future please format the output by putting three backticks around it, like so:
output
which gives you this:
output
Alternatively paste the text, then select it and press </>
You’re welcome. :slight_smile:
Update has now finished, laptop restarted, and all is working! So thank you.
Sorry about the formatting - I copied the Terminal output using the “HTML” option, and pasted that, thinking that would do the job correctly!
There are so many ways one can be wrong! Challenge is to remember the right ways in future.
