Hello,
Recently I’ve been starting to get this very annoying RDRAND error, that I’m not yet entirely sure if its affecting my boot time or not.
I searched for solutions, and came across a grub command called “nordrand” that worked on my Ubuntu but not on Manjaro.
I believe the issue is somehow related to my AMD CPU from all the reading I’ve been doing ever since the error started.
Here’s my system’s info:
sudo inxi --admin --verbosity=7 --filter --no-host --width ✔
[sudo] password for ninjoi:
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=e8f08caa-a899-4a89-976b-1db55968e8cd rw quiet splash apparmor=1
security=apparmor resume=UUID=89e8f442-8e18-4c94-8123-38ea5003aae0
udev.log_priority=3
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE v: x.x serial: N/A
UEFI: American Megatrends v: F41 date: 07/22/2019
RAM: total: 15.57 GiB used: 3.64 GiB (23.4%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 type: no module installed
Device-2: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2133 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
data: 64 total: 64 manufacturer: G.Skill part-no: F4-3200C16-8GVKB
serial: N/A
Device-3: DIMM 0 type: no module installed
Device-4: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
serial: N/A
Info: model: AMD Ryzen 5 3600 socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2433 high: 3600 min/max: 2200/4208 boost: enabled
base/boost: 3600/4200 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 2200 2: 2200 3: 2200 4: 2200
5: 2200 6: 2200 7: 2200 8: 3600 9: 3600 10: 2200 11: 2200 12: 2200
bogomips: 86268
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdt_a rdtscp
rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 08:00.0 chip-ID: 10de:21c4
class-ID: 0300
Display: server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-size: <missing: xdpyinfo>
Monitor-1: DP-0 pos: right res: 1920x1080 hz: 60 dpi: 48
size: 1020x570mm (40.16x22.44") diag: 1168mm (46") modes: N/A
Monitor-2: DP-2 pos: primary,left res: 1920x1080 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce GTX 1660
SUPER/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel bus-ID: 5-2:3 v: kernel chip-ID: 1b3f:2019 pcie:
class-ID: 0300 gen: 3 speed: 8 GT/s serial: <filter> lanes: 16
bus-ID: 08:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Generalplus CAD Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 698.65 GiB used: 15.77 GiB (2.3%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Western Digital
model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
rev: 211210WD temp: 27.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: PNY model: CS3030 250GB SSD
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: CS303226 temp: 26.9 C scheme: GPT
ID-1: / raw-size: 55.88 GiB size: 54.7 GiB (97.89%) used: 14.68 GiB (26.8%)
fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p3 maj-min: 259:3 label: N/A
uuid: e8f08caa-a899-4a89-976b-1db55968e8cd
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:1 label: N/A uuid: 7B8D-24CB
ID-3: /home raw-size: 174.51 GiB size: 170.71 GiB (97.82%)
used: 1.09 GiB (0.6%) fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p4
maj-min: 259:4 label: N/A uuid: 86189e89-be53-4b8b-a2bf-5c0a06fe019c
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p2 maj-min: 259:2 label: N/A
uuid: 89e8f442-8e18-4c94-8123-38ea5003aae0
ID-1: /dev/nvme0n1p1 maj-min: 259:6 size: 100 MiB fs: vfat label: N/A
uuid: 10A7-18A9
ID-2: /dev/nvme0n1p2 maj-min: 259:7 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:8 size: 465.65 GiB fs: ntfs label: N/A
uuid: 84C4A8BDC4A8B2BA
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: Ducky One2 Mini RGB type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s power: 100mA
chip-ID: 3233:6301 class-ID: 0300 serial: <filter>
Device-2: 5-2:3 info: Generalplus CAD Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1b3f:2019 class-ID: 0300
serial: <filter>
Device-3: 5-3:4 info: Logitech USB Receiver type: Mouse,Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
chip-ID: 046d:c547 class-ID: 0300
Device-4: 5-4:5 info: XP-Pen STAR G640 type: Mouse,HID
driver: uclogic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 70mA
chip-ID: 28bd:0094 class-ID: 0300
Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 62.0 C mobo: N/A gpu: nvidia temp: 32 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 44%
Processes: 316 Uptime: 17m wakeups: 0 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1213
pm: pacman pkgs: 1206 libs: 299 tools: gnome-software,pamac pm: flatpak
pkgs: 7 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.25
3s
Any help is appreciated!
