So there is a line that goes over the display, and it shows on every applications. This suddenly appeared after a reboot and I can’t figure out how to get rid of it. It is not a hardware issue as this bar is not shown in BIOS, and if it was a hardware issue you won’t see it in the screenshot. Is there a way to fix this? Thanks
[Can’t show the screenshot in the post
Here is the screenshot of the issue with the line marked.
sorry your going to have to post the image somewhere else, its asking to download & nobody is going to want to download an unknown file.
Thanks, updated the link
That line reminds me of a panel’s shadow. Do you have an auto-hiding panel there?
Also:
Thanks for the tip. Now I noticed that it was the shadow from plank so I disabled it from the window manager tweaks. The problem is now fixed.
