Downgrading to kernel 5.9 didn’t help. But seems that driver is being loaded.
lspci -nnk | grep -A3 -i vga | grep "in use" 13:53:41
Kernel driver in use: nvidia
Kernel driver in use: amdgpu
[ 35.749] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 35.750]
X.Org X Server 1.20.10
[ 35.750] Build Operating System: Linux Manjaro Linux
[ 35.750] Current Operating System: Linux hrbstwo 5.9.16-1-MANJARO #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020 x86_64
[ 35.750] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=f25a7ae6-b57a-4223-adb2-2bfb39a485ea rw quiet nowatchdog apparmor=1 security=apparmor resume=UUID=ae1d4c85-e6cd-4642-aeb6-25c0a831108b udev.log_priority=3
[ 35.750] Build Date: 16 December 2020 10:33:32PM
[ 35.750]
[ 35.750] Current version of pixman: 0.40.0
[ 35.750] Before reporting problems, check http://wiki.x.org
[ 35.750] Markers: (--) probed, (**) from config file, (==) default setting,
[ 35.750] (==) Log file: "/home/<>/.local/share/xorg/Xorg.0.log", Time: Thu Jan 21 13:50:00 2021
[ 35.751] (==) Using config file: "/etc/X11/xorg.conf"
[ 35.751] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 35.751] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 35.753] (==) ServerLayout "layout"
[ 35.753] (==) No screen section available. Using defaults.
[ 35.753] (**) |-->Screen "Default Screen Section" (0)
[ 35.753] (**) | |-->Monitor "<default monitor>"
[ 35.753] (==) No monitor specified for screen "Default Screen Section".
[ 35.753] (==) Automatically adding devices
[ 35.753] (==) Automatically enabling devices
[ 35.753] (==) Automatically adding GPU devices
[ 35.753] (==) Automatically binding GPU devices
[ 35.753] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 35.753] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 35.753] Entry deleted from font path.
[ 35.753] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 35.753] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 35.753] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF
[ 35.753] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 35.753] (II) The server relies on udev to provide the list of input devices.
[ 35.753] (II) Module ABI versions:
[ 35.753] X.Org ANSI C Emulation: 0.4
[ 35.753] X.Org Video Driver: 24.1
[ 35.753] X.Org XInput driver : 24.1
[ 35.753] X.Org Server Extension : 10.0
[ 35.754] (++) using VT number 2
[ 35.756] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_35
[ 35.757] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 35.758] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[ 35.760] (--) PCI: (1@0:0:0) 10de:2191:103c:8786 rev 161, Mem @ 0xfb000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[ 35.760] (--) PCI:*(6@0:0:0) 1002:1636:103c:8786 rev 199, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xfc500000/524288, I/O @ 0x0000d000/256
[ 35.760] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 35.760] (II) LoadModule: "glx"
[ 35.761] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 35.763] (II) Module glx: vendor="X.Org Foundation"
[ 35.763] compiled for 1.20.10, module version = 1.0.0
[ 35.763] ABI class: X.Org Server Extension, version 10.0
[ 35.763] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[ 35.763] loading driver: amdgpu
[ 35.763] (==) Matched amdgpu as autoconfigured driver 0
[ 35.763] (==) Matched ati as autoconfigured driver 1
[ 35.763] (==) Matched modesetting as autoconfigured driver 2
[ 35.763] (==) Matched fbdev as autoconfigured driver 3
[ 35.763] (==) Matched vesa as autoconfigured driver 4
[ 35.763] (==) Assigned the driver to the xf86ConfigLayout
[ 35.763] (II) LoadModule: "amdgpu"
[ 35.763] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 35.764] (II) Module amdgpu: vendor="X.Org Foundation"
[ 35.764] compiled for 1.20.8, module version = 19.1.0
[ 35.764] Module class: X.Org Video Driver
[ 35.764] ABI class: X.Org Video Driver, version 24.1
[ 35.764] (II) LoadModule: "ati"
[ 35.764] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 35.765] (II) Module ati: vendor="X.Org Foundation"
[ 35.765] compiled for 1.20.8, module version = 19.1.0
[ 35.765] Module class: X.Org Video Driver
[ 35.765] ABI class: X.Org Video Driver, version 24.1
[ 35.765] (II) LoadModule: "modesetting"
[ 35.765] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 35.765] (II) Module modesetting: vendor="X.Org Foundation"
[ 35.765] compiled for 1.20.10, module version = 1.20.10
[ 35.765] (II) LoadModule: "fbdev"
[ 35.766] (WW) Warning, couldn't open module fbdev
[ 35.766] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 35.766] (II) LoadModule: "vesa"
[ 35.766] (WW) Warning, couldn't open module vesa
[ 35.766] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 35.766] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 35.766] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 35.767] (WW) Falling back to old probe method for modesetting
[ 35.767] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 35.767] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 35.767] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 35.767] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 35.767] (==) AMDGPU(0): Default visual is TrueColor
[ 35.767] (==) AMDGPU(0): RGB weight 888
[ 35.767] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 35.767] (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x1636)
[ 35.767] (II) Loading sub module "fb"
[ 35.767] (II) LoadModule: "fb"
[ 35.767] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 35.768] (II) Module fb: vendor="X.Org Foundation"
[ 35.768] compiled for 1.20.10, module version = 1.0.0
[ 35.768] ABI class: X.Org ANSI C Emulation, version 0.4
[ 35.768] (II) Loading sub module "dri2"
[ 35.768] (II) LoadModule: "dri2"
[ 35.768] (II) Module "dri2" already built-in
[ 35.795] (II) Loading sub module "glamoregl"
[ 35.795] (II) LoadModule: "glamoregl"
[ 35.795] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 35.799] (II) Module glamoregl: vendor="X.Org Foundation"
[ 35.799] compiled for 1.20.10, module version = 1.0.1
[ 35.799] ABI class: X.Org ANSI C Emulation, version 0.4
[ 35.810] (II) AMDGPU(0): glamor X acceleration enabled on AMD RENOIR (DRM 3.39.0, 5.9.16-1-MANJARO, LLVM 11.0.1)
[ 35.810] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 35.810] (==) AMDGPU(0): TearFree property default: auto
[ 35.810] (==) AMDGPU(0): VariableRefresh: disabled
[ 35.810] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 35.810] (II) AMDGPU(0): Output eDP has no monitor section
[ 35.818] (II) AMDGPU(0): EDID for output eDP
[ 35.818] (II) AMDGPU(0): Manufacturer: AUO Model: 82ed Serial#: 0
[ 35.818] (II) AMDGPU(0): Year: 2018 Week: 12
[ 35.818] (II) AMDGPU(0): EDID Version: 1.4
[ 35.818] (II) AMDGPU(0): Digital Display Input
[ 35.818] (II) AMDGPU(0): 8 bits per channel
[ 35.818] (II) AMDGPU(0): Digital interface is DisplayPort
[ 35.818] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 35.818] (II) AMDGPU(0): Gamma: 2.20
[ 35.818] (II) AMDGPU(0): No DPMS capabilities specified
[ 35.818] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4
[ 35.818] (II) AMDGPU(0): First detailed timing is preferred mode
[ 35.818] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 35.818] (II) AMDGPU(0): redX: 0.642 redY: 0.338 greenX: 0.322 greenY: 0.611
[ 35.818] (II) AMDGPU(0): blueX: 0.153 blueY: 0.046 whiteX: 0.313 whiteY: 0.329
[ 35.818] (II) AMDGPU(0): Manufacturer's mask: 0
[ 35.818] (II) AMDGPU(0): Supported detailed timing:
[ 35.818] (II) AMDGPU(0): clock: 368.1 MHz Image Size: 344 x 193 mm
[ 35.818] (II) AMDGPU(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2102 h_border: 0
[ 35.818] (II) AMDGPU(0): v_active: 1080 v_sync: 1090 v_sync_end 1095 v_blanking: 1216 v_border: 0
[ 35.818] (II) AMDGPU(0): v_active: 1080 v_sync: 1090 v_sync_end 1095 v_blanking: 2915 v_border: 0
[ 35.818] (II) AMDGPU(0): Unknown vendor-specific block 2
[ 35.818] (II) AMDGPU(0): EDID (in hex):
[ 35.818] (II) AMDGPU(0): 00ffffffffffff0006afed8200000000
[ 35.818] (II) AMDGPU(0): 0c1c0104a5221378026a75a456529c27
[ 35.818] (II) AMDGPU(0): 0b505400000001010101010101010101
[ 35.818] (II) AMDGPU(0): 010101010101ce8f80b6703888403020
[ 35.818] (II) AMDGPU(0): a50058c110000018ce8f80b670382b47
[ 35.818] (II) AMDGPU(0): 3020a50058c110000018000000000000
[ 35.818] (II) AMDGPU(0): 00000000000000000000000000000002
[ 35.818] (II) AMDGPU(0): 001036ff0f3c9624143396202020000f
[ 35.818] (II) AMDGPU(0): Printing probed modes for output eDP
[ 35.818] (II) AMDGPU(0): Modeline "1920x1080"x144.0 368.14 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (175.1 kHz eP)
[ 35.818] (II) AMDGPU(0): Modeline "1920x1080"x60.1 368.14 1920 1968 2000 2102 1080 1090 1095 2915 -hsync -vsync (175.1 kHz e)
[ 35.818] (II) AMDGPU(0): Modeline "1680x1050"x144.0 368.14 1680 1968 2000 2102 1050 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 35.818] (II) AMDGPU(0): Modeline "1280x1024"x144.0 368.14 1280 1968 2000 2102 1024 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 35.818] (II) AMDGPU(0): Modeline "1440x900"x144.0 368.14 1440 1968 2000 2102 900 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 35.818] (II) AMDGPU(0): Modeline "1280x800"x144.0 368.14 1280 1968 2000 2102 800 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 35.818] (II) AMDGPU(0): Modeline "1280x720"x144.0 368.14 1280 1968 2000 2102 720 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 35.818] (II) AMDGPU(0): Modeline "1024x768"x144.0 368.14 1024 1968 2000 2102 768 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 35.818] (II) AMDGPU(0): Modeline "800x600"x144.0 368.14 800 1968 2000 2102 600 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 35.818] (II) AMDGPU(0): Modeline "640x480"x144.0 368.14 640 1968 2000 2102 480 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 35.818] (II) AMDGPU(0): Output eDP connected
[ 35.818] (II) AMDGPU(0): Using exact sizes for initial modes
[ 35.818] (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
[ 35.818] (II) AMDGPU(0): mem size init: gart size :bf6b3000 vram size: s:1da55000 visible:1da55000
[ 35.818] (==) AMDGPU(0): DPI set to (96, 96)
[ 35.818] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 35.818] (II) Loading sub module "ramdac"
[ 35.818] (II) LoadModule: "ramdac"
[ 35.818] (II) Module "ramdac" already built-in
[ 35.818] (II) UnloadModule: "modesetting"
[ 35.818] (II) Unloading modesetting
[ 35.818] (II) AMDGPU(0): [DRI2] Setup complete
[ 35.818] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 35.818] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 35.832] (II) AMDGPU(0): Front buffer pitch: 7680 bytes
[ 35.834] (II) AMDGPU(0): SYNC extension fences enabled
[ 35.834] (II) AMDGPU(0): Present extension enabled
[ 35.834] (==) AMDGPU(0): DRI3 enabled
[ 35.834] (==) AMDGPU(0): Backing store enabled
[ 35.834] (II) AMDGPU(0): Direct rendering enabled
[ 35.848] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 35.848] (II) AMDGPU(0): Acceleration enabled
[ 35.848] (==) AMDGPU(0): DPMS enabled
[ 35.848] (==) AMDGPU(0): Silken mouse disabled
[ 35.848] (II) AMDGPU(0): Set up textured video (glamor)
[ 35.853] (II) Initializing extension Generic Event Extension
[ 35.853] (II) Initializing extension SHAPE
[ 35.853] (II) Initializing extension MIT-SHM
[ 35.853] (II) Initializing extension XInputExtension
[ 35.853] (II) Initializing extension XTEST
[ 35.853] (II) Initializing extension BIG-REQUESTS
[ 35.853] (II) Initializing extension SYNC
[ 35.853] (II) Initializing extension XKEYBOARD
[ 35.853] (II) Initializing extension XC-MISC
[ 35.853] (II) Initializing extension SECURITY
[ 35.853] (II) Initializing extension XFIXES
[ 35.854] (II) Initializing extension RENDER
[ 35.854] (II) Initializing extension RANDR
[ 35.854] (II) Initializing extension COMPOSITE
[ 35.854] (II) Initializing extension DAMAGE
[ 35.854] (II) Initializing extension MIT-SCREEN-SAVER
[ 35.854] (II) Initializing extension DOUBLE-BUFFER
[ 35.854] (II) Initializing extension RECORD
[ 35.854] (II) Initializing extension DPMS
[ 35.854] (II) Initializing extension Present
[ 35.854] (II) Initializing extension DRI3
[ 35.854] (II) Initializing extension X-Resource
[ 35.854] (II) Initializing extension XVideo
[ 35.854] (II) Initializing extension XVideo-MotionCompensation
[ 35.854] (II) Initializing extension GLX
[ 35.861] (II) AIGLX: Loaded and initialized radeonsi
[ 35.861] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 35.861] (II) Initializing extension XFree86-VidModeExtension
[ 35.861] (II) Initializing extension XFree86-DGA
[ 35.861] (II) Initializing extension XFree86-DRI
[ 35.861] (II) Initializing extension DRI2
[ 35.862] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[ 35.908] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 35.908] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 35.908] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 35.908] (II) LoadModule: "libinput"
[ 35.908] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 35.910] (II) Module libinput: vendor="X.Org Foundation"
[ 35.910] compiled for 1.20.8, module version = 0.30.0
[ 35.910] Module class: X.Org XInput Driver
[ 35.910] ABI class: X.Org XInput driver, version 24.1
[ 35.910] (II) Using input driver 'libinput' for 'Power Button'
[ 36.437] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 20 paused 0
[ 36.437] (**) Power Button: always reports core events
[ 36.437] (**) Option "Device" "/dev/input/event2"
[ 36.437] (**) Option "_source" "server/udev"
[ 36.439] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 36.439] (II) event2 - Power Button: device is a keyboard
[ 36.440] (II) event2 - Power Button: device removed
[ 36.440] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 36.440] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 36.441] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 36.441] (II) event2 - Power Button: device is a keyboard
[ 36.442] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[ 36.442] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 36.442] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 36.442] (II) Using input driver 'libinput' for 'Video Bus'
[ 36.444] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 23 paused 0
[ 36.444] (**) Video Bus: always reports core events
[ 36.444] (**) Option "Device" "/dev/input/event3"
[ 36.444] (**) Option "_source" "server/udev"
[ 36.446] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 36.446] (II) event3 - Video Bus: device is a keyboard
[ 36.446] (II) event3 - Video Bus: device removed
[ 36.446] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:03/LNXVIDEO:00/input/input3/event3"
[ 36.446] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 36.448] (II) event3 - Video Bus: is tagged by udev as: Keyboard
[ 36.448] (II) event3 - Video Bus: device is a keyboard
[ 36.449] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 36.449] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 36.449] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 36.449] (II) Using input driver 'libinput' for 'Power Button'
[ 36.451] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 24 paused 0
[ 36.451] (**) Power Button: always reports core events
[ 36.451] (**) Option "Device" "/dev/input/event0"
[ 36.451] (**) Option "_source" "server/udev"
[ 36.452] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 36.452] (II) event0 - Power Button: device is a keyboard
[ 36.453] (II) event0 - Power Button: device removed
[ 36.453] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 36.453] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 36.454] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 36.454] (II) event0 - Power Button: device is a keyboard
[ 36.455] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[ 36.455] (II) No input driver specified, ignoring this device.
[ 36.455] (II) This device may have been added with another device file.
[ 36.456] (II) config/udev: Adding input device HP Wide Vision HD Camera: HP Wi (/dev/input/event14)
[ 36.456] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "evdev keyboard catchall"
[ 36.456] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "libinput keyboard catchall"
[ 36.456] (II) Using input driver 'libinput' for 'HP Wide Vision HD Camera: HP Wi'
[ 36.458] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 25 paused 0
[ 36.458] (**) HP Wide Vision HD Camera: HP Wi: always reports core events
[ 36.458] (**) Option "Device" "/dev/input/event14"
[ 36.458] (**) Option "_source" "server/udev"
[ 36.460] (II) event14 - HP Wide Vision HD Camera: HP Wi: is tagged by udev as: Keyboard
[ 36.460] (II) event14 - HP Wide Vision HD Camera: HP Wi: device is a keyboard
[ 36.461] (II) event14 - HP Wide Vision HD Camera: HP Wi: device removed
[ 36.461] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.3/usb3/3-3/3-3:1.0/input/input18/event14"
[ 36.461] (II) XINPUT: Adding extended input device "HP Wide Vision HD Camera: HP Wi" (type: KEYBOARD, id 9)
[ 36.463] (II) event14 - HP Wide Vision HD Camera: HP Wi: is tagged by udev as: Keyboard
[ 36.463] (II) event14 - HP Wide Vision HD Camera: HP Wi: device is a keyboard
[ 36.464] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 (/dev/input/event11)
[ 36.464] (**) Microsoft Microsoft® Nano Transceiver v2.0: Applying InputClass "evdev keyboard catchall"
[ 36.464] (**) Microsoft Microsoft® Nano Transceiver v2.0: Applying InputClass "libinput keyboard catchall"
[ 36.464] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0'
[ 36.466] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 26 paused 0
[ 36.466] (**) Microsoft Microsoft® Nano Transceiver v2.0: always reports core events
[ 36.466] (**) Option "Device" "/dev/input/event11"
[ 36.466] (**) Option "_source" "server/udev"
[ 36.469] (II) event11 - Microsoft Microsoft® Nano Transceiver v2.0: is tagged by udev as: Keyboard
[ 36.469] (II) event11 - Microsoft Microsoft® Nano Transceiver v2.0: device is a keyboard
[ 36.469] (II) event11 - Microsoft Microsoft® Nano Transceiver v2.0: device removed
[ 36.469] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb5/5-1/5-1:1.0/0003:045E:0745.0002/input/input15/event11"
[ 36.469] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0" (type: KEYBOARD, id 10)
[ 36.471] (II) event11 - Microsoft Microsoft® Nano Transceiver v2.0: is tagged by udev as: Keyboard
[ 36.472] (II) event11 - Microsoft Microsoft® Nano Transceiver v2.0: device is a keyboard
[ 36.473] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Mouse (/dev/input/event12)
[ 36.473] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: Applying InputClass "evdev pointer catchall"
[ 36.473] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: Applying InputClass "libinput pointer catchall"
[ 36.473] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Mouse'
[ 36.475] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 27 paused 0
[ 36.475] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: always reports core events
[ 36.475] (**) Option "Device" "/dev/input/event12"
[ 36.475] (**) Option "_source" "server/udev"
[ 36.478] (II) event12 - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: is tagged by udev as: Mouse
[ 36.478] (II) event12 - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: device is a pointer
[ 36.478] (II) event12 - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: device removed
[ 36.478] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb5/5-1/5-1:1.1/0003:045E:0745.0003/input/input16/event12"
[ 36.478] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Mouse" (type: MOUSE, id 11)
[ 36.478] (**) Option "AccelerationScheme" "none"
[ 36.478] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: (accel) selected scheme none/0
[ 36.478] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: (accel) acceleration factor: 2.000
[ 36.478] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: (accel) acceleration threshold: 4
[ 36.481] (II) event12 - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: is tagged by udev as: Mouse
[ 36.481] (II) event12 - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: device is a pointer
[ 36.482] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Mouse (/dev/input/mouse2)
[ 36.482] (II) No input driver specified, ignoring this device.
[ 36.482] (II) This device may have been added with another device file.
[ 36.483] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control (/dev/input/event13)
[ 36.483] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 36.483] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 36.483] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[ 36.485] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 28 paused 0
[ 36.485] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: always reports core events
[ 36.485] (**) Option "Device" "/dev/input/event13"
[ 36.485] (**) Option "_source" "server/udev"
[ 36.487] (II) event13 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[ 36.487] (II) event13 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[ 36.488] (II) event13 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device removed
[ 36.488] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: needs a virtual subdevice
[ 36.488] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb5/5-1/5-1:1.1/0003:045E:0745.0003/input/input17/event13"
[ 36.488] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: MOUSE, id 12)
[ 36.488] (**) Option "AccelerationScheme" "none"
[ 36.488] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) selected scheme none/0
[ 36.488] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration factor: 2.000
[ 36.488] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration threshold: 4
[ 36.490] (II) event13 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[ 36.490] (II) event13 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[ 36.492] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control (/dev/input/event15)
[ 36.492] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 36.492] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 36.492] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[ 36.494] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 29 paused 0
[ 36.494] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: always reports core events
[ 36.494] (**) Option "Device" "/dev/input/event15"
[ 36.494] (**) Option "_source" "server/udev"
[ 36.496] (II) event15 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[ 36.496] (II) event15 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[ 36.496] (II) event15 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device removed
[ 36.496] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: needs a virtual subdevice
[ 36.496] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb5/5-1/5-1:1.2/0003:045E:0745.0004/input/input19/event15"
[ 36.496] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: MOUSE, id 13)
[ 36.496] (**) Option "AccelerationScheme" "none"
[ 36.496] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) selected scheme none/0
[ 36.496] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration factor: 2.000
[ 36.496] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration threshold: 4
[ 36.498] (II) event15 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[ 36.498] (II) event15 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[ 36.500] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 System Control (/dev/input/event16)
[ 36.500] (**) Microsoft Microsoft® Nano Transceiver v2.0 System Control: Applying InputClass "evdev keyboard catchall"
[ 36.500] (**) Microsoft Microsoft® Nano Transceiver v2.0 System Control: Applying InputClass "libinput keyboard catchall"
[ 36.500] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 System Control'
[ 36.501] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 30 paused 0
[ 36.501] (**) Microsoft Microsoft® Nano Transceiver v2.0 System Control: always reports core events
[ 36.501] (**) Option "Device" "/dev/input/event16"
[ 36.501] (**) Option "_source" "server/udev"
[ 36.504] (II) event16 - Microsoft Microsoft® Nano Transceiver v2.0 System Control: is tagged by udev as: Keyboard
[ 36.504] (II) event16 - Microsoft Microsoft® Nano Transceiver v2.0 System Control: device is a keyboard
[ 36.504] (II) event16 - Microsoft Microsoft® Nano Transceiver v2.0 System Control: device removed
[ 36.504] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb5/5-1/5-1:1.2/0003:045E:0745.0004/input/input21/event16"
[ 36.504] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 System Control" (type: KEYBOARD, id 14)
[ 36.507] (II) event16 - Microsoft Microsoft® Nano Transceiver v2.0 System Control: is tagged by udev as: Keyboard
[ 36.507] (II) event16 - Microsoft Microsoft® Nano Transceiver v2.0 System Control: device is a keyboard
[ 36.508] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event6)
[ 36.508] (II) No input driver specified, ignoring this device.
[ 36.508] (II) This device may have been added with another device file.
[ 36.508] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event7)
[ 36.509] (II) config/udev: Adding input device SYNA32A5:00 06CB:CE17 Mouse (/dev/input/event9)
[ 36.509] (**) SYNA32A5:00 06CB:CE17 Mouse: Applying InputClass "evdev pointer catchall"
[ 36.509] (**) SYNA32A5:00 06CB:CE17 Mouse: Applying InputClass "libinput pointer catchall"
[ 36.509] (II) Using input driver 'libinput' for 'SYNA32A5:00 06CB:CE17 Mouse'
[ 36.511] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 31 paused 0
[ 36.511] (**) SYNA32A5:00 06CB:CE17 Mouse: always reports core events
[ 36.511] (**) Option "Device" "/dev/input/event9"
[ 36.511] (**) Option "_source" "server/udev"
[ 36.513] (II) event9 - SYNA32A5:00 06CB:CE17 Mouse: is tagged by udev as: Mouse Pointingstick
[ 36.513] (II) event9 - SYNA32A5:00 06CB:CE17 Mouse: device is a pointer
[ 36.514] (II) event9 - SYNA32A5:00 06CB:CE17 Mouse: device removed
[ 36.515] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-SYNA32A5:00/0018:06CB:CE17.0001/input/input12/event9"
[ 36.515] (II) XINPUT: Adding extended input device "SYNA32A5:00 06CB:CE17 Mouse" (type: MOUSE, id 15)
[ 36.515] (**) Option "AccelerationScheme" "none"
[ 36.515] (**) SYNA32A5:00 06CB:CE17 Mouse: (accel) selected scheme none/0
[ 36.515] (**) SYNA32A5:00 06CB:CE17 Mouse: (accel) acceleration factor: 2.000
[ 36.515] (**) SYNA32A5:00 06CB:CE17 Mouse: (accel) acceleration threshold: 4
[ 36.516] (II) event9 - SYNA32A5:00 06CB:CE17 Mouse: is tagged by udev as: Mouse Pointingstick
[ 36.517] (II) event9 - SYNA32A5:00 06CB:CE17 Mouse: device is a pointer
[ 36.519] (II) config/udev: Adding input device SYNA32A5:00 06CB:CE17 Mouse (/dev/input/mouse0)
[ 36.519] (II) No input driver specified, ignoring this device.
[ 36.519] (II) This device may have been added with another device file.
[ 36.520] (II) config/udev: Adding input device SYNA32A5:00 06CB:CE17 Touchpad (/dev/input/event10)
[ 36.520] (**) SYNA32A5:00 06CB:CE17 Touchpad: Applying InputClass "evdev touchpad catchall"
[ 36.520] (**) SYNA32A5:00 06CB:CE17 Touchpad: Applying InputClass "libinput touchpad catchall"
[ 36.520] (II) Using input driver 'libinput' for 'SYNA32A5:00 06CB:CE17 Touchpad'
[ 36.521] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 32 paused 0
[ 36.521] (**) SYNA32A5:00 06CB:CE17 Touchpad: always reports core events
[ 36.521] (**) Option "Device" "/dev/input/event10"
[ 36.521] (**) Option "_source" "server/udev"
[ 36.523] (II) event10 - SYNA32A5:00 06CB:CE17 Touchpad: is tagged by udev as: Touchpad
[ 36.525] (II) event10 - SYNA32A5:00 06CB:CE17 Touchpad: device is a touchpad
[ 36.525] (II) event10 - SYNA32A5:00 06CB:CE17 Touchpad: device removed
[ 36.526] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-SYNA32A5:00/0018:06CB:CE17.0001/input/input13/event10"
[ 36.526] (II) XINPUT: Adding extended input device "SYNA32A5:00 06CB:CE17 Touchpad" (type: TOUCHPAD, id 16)
[ 36.528] (**) Option "AccelerationScheme" "none"
[ 36.528] (**) SYNA32A5:00 06CB:CE17 Touchpad: (accel) selected scheme none/0
[ 36.528] (**) SYNA32A5:00 06CB:CE17 Touchpad: (accel) acceleration factor: 2.000
[ 36.528] (**) SYNA32A5:00 06CB:CE17 Touchpad: (accel) acceleration threshold: 4
[ 36.529] (II) event10 - SYNA32A5:00 06CB:CE17 Touchpad: is tagged by udev as: Touchpad
[ 36.531] (II) event10 - SYNA32A5:00 06CB:CE17 Touchpad: device is a touchpad
[ 36.532] (II) config/udev: Adding input device SYNA32A5:00 06CB:CE17 Touchpad (/dev/input/mouse1)
[ 36.532] (II) No input driver specified, ignoring this device.
[ 36.532] (II) This device may have been added with another device file.
[ 36.533] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 36.533] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 36.533] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 36.533] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 36.535] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 33 paused 0
[ 36.535] (**) AT Translated Set 2 keyboard: always reports core events
[ 36.535] (**) Option "Device" "/dev/input/event4"
[ 36.535] (**) Option "_source" "server/udev"
[ 36.536] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 36.536] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 36.537] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 36.538] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 36.538] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 17)
[ 36.539] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 36.539] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 36.541] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 36.541] (II) No input driver specified, ignoring this device.
[ 36.541] (II) This device may have been added with another device file.
[ 36.542] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event8)
[ 36.542] (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 36.542] (**) HP WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 36.542] (II) Using input driver 'libinput' for 'HP WMI hotkeys'
[ 36.543] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 34 paused 0
[ 36.543] (**) HP WMI hotkeys: always reports core events
[ 36.543] (**) Option "Device" "/dev/input/event8"
[ 36.543] (**) Option "_source" "server/udev"
[ 36.544] (II) event8 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 36.545] (II) event8 - HP WMI hotkeys: device is a keyboard
[ 36.545] (II) event8 - HP WMI hotkeys: device is a switch device
[ 36.545] (II) event8 - HP WMI hotkeys: device removed
[ 36.545] (**) Option "config_info" "udev:/sys/devices/virtual/input/input8/event8"
[ 36.545] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 18)
[ 36.546] (II) event8 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 36.546] (II) event8 - HP WMI hotkeys: device is a keyboard
[ 36.546] (II) event8 - HP WMI hotkeys: device is a switch device
[ 36.552] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 36.552] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 36.552] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[ 36.552] (II) systemd-logind: returning pre-existing fd for /dev/input/event13 13:77
[ 36.552] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: always reports core events
[ 36.552] (**) Option "Device" "/dev/input/event13"
[ 36.552] (**) Option "_source" "_driver/libinput"
[ 36.552] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is a virtual subdevice
[ 36.552] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb5/5-1/5-1:1.1/0003:045E:0745.0003/input/input17/event13"
[ 36.552] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: KEYBOARD, id 19)
[ 36.552] (II) systemd-logind: returning pre-existing fd for /dev/input/event15 13:79
[ 36.552] (**) Option "Device" "/dev/input/event15"
[ 36.552] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb5/5-1/5-1:1.2/0003:045E:0745.0004/input/input19/event15"
[ 36.552] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: KEYBOARD, id 20)
[ 37.132] (II) AMDGPU(0): EDID vendor "AUO", prod id 33517
[ 37.132] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 37.132] (II) AMDGPU(0): Modeline "1920x1080"x0.0 368.14 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (175.1 kHz eP)
[ 37.132] (II) AMDGPU(0): Modeline "1920x1080"x0.0 368.14 1920 1968 2000 2102 1080 1090 1095 2915 -hsync -vsync (175.1 kHz e)
[ 68.491] (II) AMDGPU(0): EDID vendor "AUO", prod id 33517
[ 68.491] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 68.491] (II) AMDGPU(0): Modeline "1920x1080"x0.0 368.14 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (175.1 kHz eP)
[ 68.491] (II) AMDGPU(0): Modeline "1920x1080"x0.0 368.14 1920 1968 2000 2102 1080 1090 1095 2915 -hsync -vsync (175.1 kHz e)
$ ls -l /dev/dri/
total 0
drwxr-xr-x 2 root root 80 01-21 13:49 by-path
crw-rw----+ 1 root video 226, 0 01-21 13:49 card0
crw-rw-rw- 1 root render 226, 128 01-21 13:49 renderD128
$ nvidia-smi
Thu Jan 21 13:54:51 2021
| NVIDIA-SMI 460.32.03 Driver Version: 460.32.03 CUDA Version: 11.2 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 GeForce GTX 166... Off | 00000000:01:00.0 Off | N/A |
| N/A 38C P0 21W / N/A | 0MiB / 5944MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
