bamu
October 6, 2020, 5:55pm
#1
I’ve looked through the numerous no-display manjaro support posts, but have not found a solution for AMD yet. I have a Samsung monitor with a built in KVM switch that runs seamlessly on Windows10 and my previous Manjaro Ideapad (3500U). However after upgrading to Renoir with an HP Omen 15, Manjaro will no longer allow a connection to the monitor. Worse yet it momentarily provides access to the keyboard/mouse connected to the monitor before noping-out.
I’ve tried using the AUR package for optimus-manager with AMD. Switching to AMD mode, however this does not alleviate the issues. (link removed, no links allowed)
I have installed XRANDR (xorg-xrandr-1.5.1-2) however this has not helped either.
The devices INXI data is listed below, if anyone could point me in the right direction I’d really appreciate it.
bamu
October 6, 2020, 5:58pm
#2
System: Kernel: 5.9.0-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=f04f6ea2-976b-4044-bb0e-84aeaf085516 rw
quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: OMEN Laptop 15-en0xxx v: N/A serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: HP model: 8786 v: 22.53 serial: <filter> UEFI: AMI v: F.06 date: 07/15/2020
Battery: ID-1: BAT0 charge: 68.0 Wh condition: 68.0/68.0 Wh (100%) volts: 13.1/11.6
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Full cycles: 612
Memory: RAM: total: 62.25 GiB used: 2.71 GiB (4.4%)
CPU: Topology: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600103 L2 cache: 4096 KiB bogomips: 92663
Speed: 1396 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1398 3: 1397
4: 1397 5: 1397 6: 1396 7: 1397 8: 1397 9: 1396 10: 1397 11: 1397 12: 1397 13: 1406 14: 1397 15: 1397
16: 1396
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3 cdp_l3
clflush clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local
cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm lbrv lm mba mca mce
misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold
pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Hewlett-Packard driver: N/A
alternate: nouveau bus ID: 01:00.0 chip ID: 10de:2191
Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
bus ID: 07:00.0 chip ID: 1002:1636
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera type: USB driver: uvcvideo
bus ID: 3-3:2 chip ID: 05c8:03df
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: amdgpu FAILED: ati
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.0-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.8
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus ID: 07:00.5
chip ID: 1022:15e2
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 07:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.0-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: e000 bus ID: 02:00.0 chip ID: 10ec:8168
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000 bus ID: 03:00.0 chip ID: 8086:2723
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Drives: Local Storage: total: 931.51 GiB used: 64.29 GiB (6.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 1B2QEXE7 scheme: GPT
ID-2: /dev/nvme1n1 vendor: Sabrent model: Rocket 4.0 1TB size: 931.51 GiB block size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 serial: <filter> rev: RKT401.2 scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 931.22 GiB size: 915.60 GiB (98.32%) used: 64.29 GiB (7.0%) fs: ext4
dev: /dev/nvme0n1p2 label: N/A uuid: f04f6ea2-976b-4044-bb0e-84aeaf085516
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%) used: 284 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1 label: N/A uuid: EF6C-1570
Swap: Alert: No Swap data was found.
Unmounted: ID-1: /dev/nvme1n1p1 size: 100.0 MiB fs: vfat label: N/A uuid: C08B-61D8
ID-2: /dev/nvme1n1p2 size: 16.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-3: /dev/nvme1n1p3 size: 930.90 GiB fs: ntfs label: N/A uuid: 2A4A8C024A8BC8D1
ID-4: /dev/nvme1n1p4 size: 505.0 MiB fs: ntfs label: N/A uuid: 8232C64B32C6443F
USB: Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 3-1:24 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip ID: 0bda:5411
Device-1: 3-1.1:25 info: Corsair Vengeance K70R keyboard type: Keyboard,HID driver: corsair,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 1b1c:1b09
Device-2: 3-1.2:26 info: Areson Corp type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2
rev: 1.1 speed: 12 Mb/s chip ID: 25a7:fa3f
Device-3: 3-3:2 info: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 05c8:03df
Device-4: 3-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 8087:0029
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 5-2:2 info: Lenovo USB Receiver type: Mouse,HID driver: hid-generic,usbhid interfaces: 2
rev: 2.0 speed: 12 Mb/s chip ID: 17ef:6042
Hub: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 51.6 C mobo: N/A gpu: amdgpu temp: 44 C
Info: Processes: 371 Uptime: 1d 4h 08m Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 9 clang: 10.0.1
Packages: 1331 pacman: 1315 lib: 368 flatpak: 0 snap: 16 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.05
pobrn
October 6, 2020, 6:00pm
#3
I think this is the same issue .
Have you tried the nvidia mode? That’s the one that should work.
bamu
October 6, 2020, 6:04pm
#4
@pobrn thanks for the quick response, I’ll try now.
bamu
October 6, 2020, 6:09pm
#5
@pobrn unfortunately switching to nvidia does not resolve the issue.
Graphics: Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] driver: N/A
Device-2: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel
Display: x11 server: X.Org 1.20.9 driver: amdgpu FAILED: ati unloaded: modesetting resolution: 1920x1080~144Hz
bamu
October 6, 2020, 6:13pm
#6
Double checking that the drivers are installed properly & up-to-date reveals I’m using the latest Nvidia/AMD drivers.
sudo mhwd -a pci nonfree 0300
[sudo] password for bamu:
> Skipping already installed config 'video-hybrid-amd-nvidia-450xx-prime' for device: 0000:01:00.0 (0300:10de:2191) Display controller nVidia Corporation TU116M [GeForce GTX 1660 Ti Mobile]
> Skipping already installed config 'video-hybrid-amd-nvidia-450xx-prime' for device: 0000:07:00.0 (0300:1002:1636) Display controller ATI Technologies Inc Renoir
pobrn
October 6, 2020, 6:29pm
#7
This indicates that the nvidia driver is not loaded/installed. Can you run sudo mhwd -f -i pci video-hybrid-amd-nvidia-450xx-prime
and then post the output of pacman -Qqs nvidia-450xx
bamu
October 6, 2020, 7:09pm
#8
[bamu@bamu-omen ~]$ sudo mhwd -f -i pci video-hybrid-amd-nvida-450xx-prime
Error: config 'video-hybrid-amd-nvida-450xx-prime' does not exist!
The mystery continues. I tried sharing a photo but I’m unallowed. Hardware Configuration – System Settings GUI shows that video-hybrid-amd-nvidia-450xx-prime is the only current driver installed.
pobrn
October 6, 2020, 7:10pm
#9
Did I mistype it? What does sudo mhwd -la
output?
bamu
October 6, 2020, 7:14pm
#10
[bamu@bamu-omen ~]$ sudo mhwd -la
> All PCI configs:
NAME VERSION FREEDRIVER TYPE
network-slmodem 2013.12.07 true PCI
network-broadcom-wl 2018.10.07 true PCI
network-r8168 2016.04.20 true PCI
network-rt3562sta 2013.12.07 true PCI
video-hybrid-intel-nvidia-340xx-bumblebee 2019.10.25 false PCI
video-nvidia-435xx 2019.10.25 false PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2019.10.25 false PCI
video-hybrid-intel-nvidia-435xx-prime 2019.10.25 false PCI
video-nvidia-450xx 2019.10.25 false PCI
video-hybrid-amd-nvidia-450xx-prime 2019.10.25 false PCI
video-s3 2020.01.18 true PCI
video-rendition 2020.01.18 true PCI
video-hybrid-intel-nvidia-440xx-prime 2019.10.25 false PCI
video-nvidia-340xx 2019.10.25 false PCI
video-openchrome 2020.01.18 true PCI
video-modesetting 2020.01.13 true PCI
video-nvidia-430xx 2019.10.25 false PCI
video-sisusb 2020.01.18 true PCI
video-nvidia-418xx 2019.10.25 false PCI
video-hybrid-amd-nvidia-435xx-prime 2019.10.25 false PCI
video-hybrid-amd-nvidia-440xx-prime 2019.10.25 false PCI
video-hybrid-intel-nvidia-430xx-bumblebee 2019.10.25 false PCI
video-nvidia-390xx 2019.10.25 false PCI
video-nvidia-440xx 2019.10.25 false PCI
video-vesa 2017.03.12 true PCI
video-hybrid-intel-nvidia-450xx-prime 2019.10.25 false PCI
video-hybrid-intel-nvidia-418xx-bumblebee 2019.10.25 false PCI
video-virtualmachine 2020.03.26 true PCI
video-voodoo 2017.03.12 true PCI
Warning: No USB configs found!
pobrn
October 6, 2020, 7:15pm
#11
And this doesn’t work? sudo mhwd -f -i pci video-hybrid-amd-nvidia-450xx-prime
bamu
October 6, 2020, 7:17pm
#12
I think I must have missed typed (my apologies), I re-tried your original line:
[bamu@bamu-omen ~]$ sudo mhwd -f -i pci video-hybrid-amd-nvidia-450xx-prime
> Removing video-hybrid-amd-nvidia-450xx-prime...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-hybrid-amd-nvidia-450xx-prime/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
checking dependencies...
:: removing nvidia-450xx-utils breaks dependency 'nvidia-utils>=450.51.06' required by cuda
Error: pacman failed!
Error: script failed!
pobrn
#13
Please remove cuda
for the time being and try again.
bamu
#14
Looks like cuda dependency is blocking the removal.
bamu
October 6, 2020, 7:19pm
#15
Looking up method to remove cuda now.
pobrn
October 6, 2020, 7:21pm
#16
pamac remove cuda
or pacman -R cuda
will do now.
bamu
October 6, 2020, 7:22pm
#17
Thank you, after removing cuda.
:: ffmpeg optionally requires nvidia-utils: Nvidia NVDEC/NVENC support
:: google-earth-pro optionally requires nvidia-utils: For the NVIDIA driver
:: ksysguard optionally requires nvidia-utils: NVIDIA GPU usage
:: lib32-vulkan-icd-loader optionally requires lib32-vulkan-driver: packaged vulkan driver
:: steam-manjaro optionally requires vulkan-driver: packaged vulkan driver
:: steam-manjaro optionally requires lib32-vulkan-driver: packaged vulkan driver (32bit)
:: vulkan-icd-loader optionally requires vulkan-driver: packaged vulkan driver
Packages (6) lib32-nvidia-450xx-utils-450.66-1 linux414-nvidia-450xx-450.66-8 linux57-nvidia-450xx-450.66-6 linux58-nvidia-450xx-450.66-15 nvidia-450xx-
utils-450.66-1 nvidia-prime-1.0-4
Total Removed Size: 393.69 MiB
:: Do you want to remove these packages? [Y/n]
removing linux58-nvidia-450xx...
removing linux57-nvidia-450xx...
removing linux414-nvidia-450xx...
removing lib32-nvidia-450xx-utils...
xorg configuration symlink valid...
removing nvidia-prime...
removing nvidia-450xx-utils...
(1/4) Reloading system manager configuration...
(2/4) Arming ConditionNeedsUpdate...
(3/4) Updating module dependencies...
(4/4) Updating the desktop file MIME type cache...
'/etc/X11/xorg.conf.d/90-mhwd.conf' symlink is invalid! Removing it...
> Successfully removed video-hybrid-amd-nvidia-450xx-prime
> Installing video-hybrid-amd-nvidia-450xx-prime...
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/hybrid-amd-nvidia-450xx-prime/MHWDCONFIG
core is up to date
extra is up to date
downloading community.db...
error: target not found: linux59-nvidia-450xx
multilib is up to date
pobrn
October 6, 2020, 7:27pm
#18
I see now. The 450xx drivers are not available for the 5.9 kernel, only the 455xx (and only in the unstable branch). Since that’s a beta driver, I cannot recommend it. I suggest you install linux-latest
, reboot and select the 5.8 kernel in the GRUB menu, then uninstall the 5.9 kernel, and try again. Or do you have any reason for using an rc kernel?
bamu
October 6, 2020, 7:31pm
#19
No explicit reason for being on 5.9, I will revert to 5.8 and test.
bamu
October 6, 2020, 8:20pm
#20
Switched to 5.8, still targeting 5.9
core is up to date
extra is up to date
community is up to date
[bamu@bamu-omen ~]$ mhwd-kernel -li
Currently running: 5.8.11-1-MANJARO (linux58)
* linux58
* linux59
