Please uninstall the 5.9 kernel.
[bamu@bamu-omen ~]$ pacman -Qqs nvidia-450xx
lib32-nvidia-450xx-utils
linux58-nvidia-450xx
mhwd-nvidia-450xx
nvidia-450xx-utils
opencl-nvidia-450xx
[bamu@bamu-omen ~]$
Looks like the driver is configured properly, going to restart and test the external monitor again.
Upon restart, confirmed external monitor is still not working.
Please run inxi -Fazy
and nvidia-smi
[bamu@bamu-omen ~]$ inxi -Fazy
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=f04f6ea2-976b-4044-bb0e-84aeaf085516 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: HP product: OMEN Laptop 15-en0xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8786 v: 22.53 serial: <filter> UEFI: AMI v: F.06
date: 07/15/2020
ID-1: BAT0 charge: 68.0 Wh condition: 68.0/68.0 Wh (100%) volts: 13.1/11.6
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Full
cycles: 612
Topology: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600103 L2 cache: 4096 KiB
bogomips: 92660
Speed: 1404 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1398 3: 1397 4: 1397 5: 1397 6: 1396 7: 1398 8: 1397 9: 1397
10: 1393 11: 1391 12: 1397 13: 1396 14: 1393 15: 1397 16: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Hewlett-Packard
driver: N/A alternate: nouveau, nvidia_drm, nvidia bus ID: 01:00.0
chip ID: 10de:2191
Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
bus ID: 07:00.0 chip ID: 1002:1636
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera
type: USB driver: uvcvideo bus ID: 3-3:3 chip ID: 05c8:03df
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.38.0 5.8.11-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Device-1: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x bus ID: 07:00.5 chip ID: 1022:15e2
Device-2: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 07:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.11-1-MANJARO
vendor: Hewlett-Packard driver: r8169 v: kernel port: e000 bus ID: 02:00.0
chip ID: 10ec:8168
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000
bus ID: 03:00.0 chip ID: 8086:2723
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 58.75 GiB (6.3%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 1B2QEXE7 scheme: GPT
ID-2: /dev/nvme1n1 vendor: Sabrent model: Rocket 4.0 1TB size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
serial: <filter> rev: RKT401.2 scheme: GPT
ID-1: / raw size: 931.22 GiB size: 915.60 GiB (98.32%)
used: 58.75 GiB (6.4%) fs: ext4 dev: /dev/nvme0n1p2
System Temperatures: cpu: 49.5 C mobo: N/A gpu: amdgpu temp: 40 C
Processes: 392 Uptime: 1m Memory: 62.25 GiB used: 1.70 GiB (2.7%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 9 clang: 10.0.1
Packages: 1323 pacman: 1307 lib: 368 flatpak: 0 snap: 16 Shell: Bash
v: 5.0.18 running in: konsole inxi: 3.1.05
[bamu@bamu-omen ~]$ nvidia-smi
Tue Oct 6 18:45:42 2020
| NVIDIA-SMI 450.66 Driver Version: 450.66 CUDA Version: 11.0 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 GeForce GTX 166... Off | 00000000:01:00.0 Off | N/A |
| N/A 41C P0 7W / N/A | 0MiB / 5944MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| No running processes found |
So, I have a similarly specced HP Omen 15 being delivered on monday 10/12 and I have been researching this issue for 2 weeks now in preperation for installing Manjaro as well, and I can see you haven’t made head way yet, I will be back with any info/tips I can find.
I suspect the issue is that the external hdmi ports are wired to the GTX, while the laptops monitor is wired to the integrated vega chip. when using prime, it uses the integrated and runs tasks on the gtx if using prime-run command, but how do we get the GTX to display a desktop if its deactivated?
have you tried disabling the integrated gpu and only using the GTX? does it output to hdmi that way?
Please run sudo mhwd -f -i pci video-hybrid-amd-nvidia-450xx-prime
again, and then reboot. Then please try installing optimus-manager-amd-git
from AUR. Then reboot, and try optimus-manager --switch nvidia
https://aur.archlinux.org/packages/optimus-manager-git/
optimus-manager-amd-git is now obsolete per Kr1ss & Askannz.
Trying optimus-manager-git instead. Thought I think the problem may be compounded as I’m trying to connect via USB-C rather HDMI. Gonna do some leg work to find the PCB traces on the motherboard to determine if the traces are through a bridge or to the APU directly.
Good news! (Not quite there yet)
Along with the updated optimus-manager-git have increased monitor connectivity.
I can now utilize the built in KVM switch via USB-C to the monitor, however I still don’t have video out.
This is an improvement as before it would connect for 3-5 seconds before disconnecting.
I haven’t applied: optimus-manager --switch nvidia
yet as I’m afraid to lose the KVM functionality over the built-in KVM.
I am using the same laptop and pop os works with external monitors on the nvidia gpu. However renoir gpu doesn’t have video out to external monitor.
I agree, however on Win10 the vega gpu CAN video output via the USB-C.
I’m finishing finals next week before I dive back into trouble shooting this issue.
Hello,
Recently I’ve purchased HP Omen 15 Laptop with Ryzen 4800h and RTX 2060.
I am not able make external display to work via dp or hdmi, only internal graphics are working.
Did you manage to solve that issue by any means guys?
I can paste more info about the specific kernel version etc., if needed.
Just as a side note, when using PopOS I was able to switch to nvidia graphics and make external display work, but in the Manjaro KDE it’s not working at all. (PopOS has little documentation about switching graphics on their website, but I can’t post links here)
I’ve also managed to switch to video-nvidia drivers available from the hardware settings and make external display working, but then the internal display of laptop wasn’t working at all.
My external displays:
- Dell U3417W connected via mDP,
- Dell S2719DGF connected via HDMI
Hi. I’m facing the same issue on HP Omen 15 Laptop with Ryzen 4600h and RTX 1660Ti and Manjaro Gnome , cannot connect external monitor via HDMI port (not sure why I cannot list that port via xrandr) . Tried bunch of solutions already, but nothing so worked far.
Bunch of infos:
$ pacman -Qs nvidia
local/lib32-libvdpau 1.4-1
Nvidia VDPAU library
local/libvdpau 1.4-1
local/libxnvctrl 460.27.04-1
NVIDIA NV-CONTROL X extension
local/linux-latest-nvidia 5.10-1 (linux-latest-extramodules)
NVIDIA drivers for Linux (metapackage)
local/linux510-nvidia 460.32.03-6 (linux510-extramodules)
NVIDIA drivers for linux.
local/linux511-nvidia 460.32.03-0.4 (linux511-extramodules)
local/linux54-nvidia 460.32.03-3 (linux54-extramodules)
local/linux59-nvidia 460.32.03-1 (linux59-extramodules)
local/mhwd-nvidia 460.32.03-1
MHWD module-ids for nvidia 460.32.03
local/mhwd-nvidia-340xx 340.108-1
MHWD module-ids for nvidia 340.108
local/mhwd-nvidia-390xx 390.141-1
MHWD module-ids for nvidia 390.141
local/nvidia-prime 1.0-4
NVIDIA Prime Render Offload configuration and utilities
local/nvidia-utils 460.32.03-1
NVIDIA drivers utilities
local/xf86-video-nouveau 1.0.16-2 (xorg-drivers)
Open Source 3D acceleration driver for nVidia cards
$ mhwd -la
> All PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-390xx 2020.11.30 false PCI
video-voodoo 2017.03.12 true PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
video-sisusb 2020.01.18 true PCI
video-virtualmachine 2020.03.26 true PCI
video-s3 2020.01.18 true PCI
video-openchrome 2020.01.18 true PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2020.11.30 false
PCI
video-rendition 2020.01.18 true PCI
network-rt3562sta 2013.12.07 true PCI
network-slmodem 2013.12.07 true PCI
network-broadcom-wl 2018.10.07 true PCI
network-r8168 2016.04.20 true PCI
System: Kernel: 5.11.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=f25a7ae6-b57a-4223-adb2-2bfb39a485ea rw quiet nowatchdog
apparmor=1 security=apparmor resume=UUID=ae1d4c85-e6cd-4642-aeb6-25c0a831108b udev.log_priority=3
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2, LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: OMEN Laptop 15-en0xxx v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8786 v: 22.26 serial: <filter> UEFI: AMI v: F.02 date: 05/11/2020
Battery: ID-1: BAT0 charge: 69.9 Wh condition: 69.9/69.9 Wh (100%) volts: 13.1/11.6 model: Hewlett-Packard Primary
type: Li-ion serial: N/A status: Full cycles: 628
CPU: Info: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 60 (96) stepping: 1 microcode: 8600103 L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71896
Speed: 1688 MHz min/max: 1400/3000 MHz boost: disabled Core speeds (MHz): 1: 1688 2: 1538 3: 2288 4: 1517 5: 1995
6: 1397 7: 1928 8: 1403 9: 1996 10: 1406 11: 1588 12: 1351
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Hewlett-Packard driver: nvidia v: 460.32.03
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:2191
Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel bus ID: 06:00.0
chip ID: 1002:1636
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo bus ID: 3-3:2 chip ID: 0408:5423
serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver: loaded: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 144 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.11.0-1-MANJARO LLVM 11.0.1) v: 4.6 Mesa 20.3.3 direct render: Yes
$ mhwd -a pci nonfree 0300
> Skipping already installed config 'video-linux' for device: 0000:01:00.0 (0300:10de:2191) Display controller nVidia Corporation TU116M [GeForce GTX 1660 Ti Mobile]
> Skipping already installed config 'video-linux' for device: 0000:06:00.0 (0300:1002:1636) Display controller ATI Technologies Inc Renoir
$ lspci | grep -A 2 -E "VGA|3D"
01:00.0 VGA compatible controller: NVIDIA Corporation TU116M [GeForce GTX 1660 Ti Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation TU116 High Definition Audio Controller (rev a1)
01:00.2 USB controller: NVIDIA Corporation TU116 USB 3.1 Host Controller (rev a1)
06:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev c7)
06:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
06:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1
$ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 144.03*+ 60.08
1680x1050 144.03
1280x1024 144.03
1440x900 144.03
1280x800 144.03
1280x720 144.03
1024x768 144.03
800x600 144.03
640x480 144.03
$ xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x54 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 1 associated providers: 0 name:Unknown AMD Radeon GPU @ pci:0000:06:00.0
$ nvidia-settings
ERROR: Unable to load info from any available syste
Got rid of all xorg.conf
because nvidia-settings was messing them up and X wasn’t starting at all.
Found out on Arch wiki that ( _https://wiki.archlinux.org/index.php/Laptop/HP) Wayland is not properly handling HDMI/DP for HP Omen so I switched to X11.
When I try to install custom drivers with pacman I get:
error: target not found: video-hybrid-intel-nvidia-45xx-prime
Even GDM stopped starting automatically - I need to switch to ttyX log in ans tart it via systemctl by hand (not sure if that is related).
Please, hjalp.
As NVIDIA writes:
The NVIDIA driver currently cannot be used as an output sink when the output source driver is xf86-video-amdgpu.
Which seems to be the case here. But what seems odd is that the NVIDIA Xorg driver doesn’t even seem to be loaded. Can you post the latest Xorg log from /var/log/
or ~/.local/share/xorg/
That has never existed as a pacman package. Those names are only relevant in mhwd
. But it seems you might need to reinstall the mhwd-db
package. Please do that, and post the output of mhwd -l
Probably because it’s connected to the NVIDIA GPU and since the NVIDIA Xorg driver is not loaded, the X server has no information that such port exists.
$ cat /var/log/Xorg.0.log
[ 86.525] (--) Log file renamed from "/var/log/Xorg.pid-1554.log" to "/var/log/Xorg.0.log"
[ 86.527]
X.Org X Server 1.20.10
[ 86.527] Build Operating System: Linux Manjaro Linux
[ 86.527] Current Operating System: Linux hrbstwo 5.11.0-1-MANJARO #1 SMP PREEMPT Mon Jan 11 00:50:28 UTC 2021 x86_64
[ 86.527] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=f25a7ae6-b57a-4223-adb2-2bfb39a485ea rw quiet nowatchdog apparmor=1 security=apparmor resume=UUID=ae1d4c85-e6cd-4642-aeb6-25c0a831108b udev.log_priority=3
[ 86.527] Build Date: 16 December 2020 10:33:32PM
[ 86.527]
[ 86.527] Current version of pixman: 0.40.0
[ 86.527] Before reporting problems, check http://wiki.x.org
[ 86.527] Markers: (--) probed, (**) from config file, (==) default setting,
[ 86.527] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 21 04:28:31 2021
[ 86.527] (==) Using config file: "/etc/X11/xorg.conf"
[ 86.527] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 86.527] (==) ServerLayout "layout"
[ 86.527] (**) |-->Screen "Screen0" (0)
[ 86.527] (**) | |-->Monitor "Monitor0"
[ 86.528] (**) | |-->Device "Device0"
[ 86.528] (==) Automatically adding devices
[ 86.528] (==) Automatically enabling devices
[ 86.528] (==) Automatically adding GPU devices
[ 86.528] (==) Automatically binding GPU devices
[ 86.528] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 86.528] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 86.528] Entry deleted from font path.
[ 86.528] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 86.528] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 86.528] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF
[ 86.528] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 86.528] (II) The server relies on udev to provide the list of input devices.
[ 86.528] (II) Module ABI versions:
[ 86.528] X.Org ANSI C Emulation: 0.4
[ 86.528] X.Org Video Driver: 24.1
[ 86.528] X.Org XInput driver : 24.1
[ 86.528] X.Org Server Extension : 10.0
[ 86.529] (++) using VT number 1
[ 86.529] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 86.530] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 86.539] (--) PCI: (1@0:0:0) 10de:2191:103c:8786 rev 161, Mem @ 0xfb000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[ 86.539] (--) PCI:*(6@0:0:0) 1002:1636:103c:8786 rev 199, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xfc500000/524288, I/O @ 0x0000d000/256
[ 86.539] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 86.539] (II) LoadModule: "glx"
[ 86.539] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 86.540] (II) Module glx: vendor="X.Org Foundation"
[ 86.540] compiled for 1.20.10, module version = 1.0.0
[ 86.540] ABI class: X.Org Server Extension, version 10.0
[ 86.540] (II) LoadModule: "nvidia"
[ 86.540] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 86.540] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 86.540] compiled for 1.6.99.901, module version = 1.0.0
[ 86.540] Module class: X.Org Video Driver
[ 86.540] (II) NVIDIA dlloader X Driver 460.32.03 Sun Dec 27 18:56:00 UTC 2020
[ 86.540] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 86.540] (EE) No devices detected.
[ 86.540] (EE)
Fatal server error:
[ 86.540] (EE) no screens found(EE)
[ 86.540] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 86.540] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 86.540] (EE)
[ 86.569] (EE) Server terminated with error (1). Closing log file.
I can share ~/.local/share/xorg/
but there is quite a lot of info, not sure what is relevant.
It’s flooded with
[ 247.277] (EE) AMDGPU(0): present flip failed
[ 247.298] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 247.298] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 247.298] (EE) AMDGPU(0): present flip failed
[ 247.311] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 247.311] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 247.311] (EE) AMDGPU(0): present flip failed
[ 247.318] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 247.318] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 247.318] (EE) AMDGPU(0): present flip failed
[ 247.340] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 247.340] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 247.340] (EE) AMDGPU(0): present flip failed
Let me know if this is needed anyway
When updating mhwd-db I got strange warnings:
resolving dependencies...
Packages (1) mhwd-db-0.6.5-7
Total Installed Size: 0,03 MiB
Net Upgrade Size: 0,00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [########################################################################################] 100%
(1/1) checking package integrity [########################################################################################] 100%
(1/1) loading package files [########################################################################################] 100%
(1/1) checking for file conflicts [########################################################################################] 100%
(1/1) checking available disk space [########################################################################################] 100%
warning: could not get file information for var/lib/mhwd/db/pci/graphic_drivers/hybrid-amd-nvidia-prime/MHWDCONFIG
warning: could not get file information for var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-prime/MHWDCONFIG
warning: could not get file information for var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
(1/1) reinstalling mhwd-db
but some additional info is there:
mhwd -l 11:57:43
> 0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
> 0000:01:00.0 (0300:10de:2191) Display controller nVidia Corporation:
video-hybrid-amd-nvidia-prime 2020.11.30 false PCI
video-nvidia 2020.11.30 false PCI
> 0000:06:00.0 (0300:1002:1636) Display controller ATI Technologies Inc:
$ sudo mhwd -a pci nonfree 0300
> Using config 'video-hybrid-amd-nvidia-prime' for device: 0000:01:00.0 (0300:10de:2191) Display controller nVidia Corporation TU116M [GeForce GTX 1660 Ti Mobile]
> Using config 'video-hybrid-amd-nvidia-prime' for device: 0000:06:00.0 (0300:1002:1636) Display controller ATI Technologies Inc Renoir
> Installing video-hybrid-amd-nvidia-prime.
Bit it didn’t help. HDMi is not detected, xrandr output is identical. Same xorg log.
Please post the most recent log file from either /var/log
in its entirety, you can use pastebin, etc. if you want.
~/.local/share/xorg/Xorg.0.log
[ 51.890] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 51.890]
[ 51.890] Build Operating System: Linux Manjaro Linux
[ 51.890] Current Operating System: Linux hrbstwo 5.11.0-1-MANJARO #1 SMP PREEMPT Mon Jan 11 00:50:28 UTC 2021 x86_64
[ 51.890] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=f25a7ae6-b57a-4223-adb2-2bfb39a485ea rw quiet nowatchdog apparmor=1 security=apparmor resume=UUID=ae1d4c85-e6cd-4642-aeb6-25c0a831108b udev.log_priority=3
[ 51.890] Build Date: 16 December 2020 10:33:32PM
[ 51.890]
[ 51.890] Current version of pixman: 0.40.0
[ 51.890] Before reporting problems, check http://wiki.x.org
[ 51.890] Markers: (--) probed, (**) from config file, (==) default setting,
[ 51.890] (==) Log file: "/home/<>/.local/share/xorg/Xorg.0.log", Time: Thu Jan 21 12:03:23 2021
[ 51.891] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 51.893] (==) ServerLayout "layout"
[ 51.893] (==) No screen section available. Using defaults.
[ 51.893] (**) |-->Screen "Default Screen Section" (0)
[ 51.893] (**) | |-->Monitor "<default monitor>"
[ 51.893] (==) No monitor specified for screen "Default Screen Section".
[ 51.893] (==) Automatically adding devices
[ 51.893] (==) Automatically enabling devices
[ 51.893] (==) Automatically adding GPU devices
[ 51.893] (==) Automatically binding GPU devices
[ 51.893] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 51.893] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 51.893] Entry deleted from font path.
[ 51.893] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 51.893] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 51.893] (==) FontPath set to:
[ 51.893] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 51.893] (II) The server relies on udev to provide the list of input devices.
[ 51.893] (II) Module ABI versions:
[ 51.893] X.Org ANSI C Emulation: 0.4
[ 51.893] X.Org Video Driver: 24.1
[ 51.893] X.Org XInput driver : 24.1
[ 51.893] X.Org Server Extension : 10.0
[ 51.894] (++) using VT number 2
[ 51.897] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_35
[ 51.897] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 51.898] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[ 51.903] (--) PCI: (1@0:0:0) 10de:2191:103c:8786 rev 161, Mem @ 0xfb000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[ 51.903] (--) PCI:*(6@0:0:0) 1002:1636:103c:8786 rev 199, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xfc500000/524288, I/O @ 0x0000d000/256
[ 51.903] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 51.903] (II) LoadModule: "glx"
[ 51.905] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 51.907] (II) Module glx: vendor="X.Org Foundation"
[ 51.907] compiled for 1.20.10, module version = 1.0.0
[ 51.907] ABI class: X.Org Server Extension, version 10.0
[ 51.907] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[ 51.907] loading driver: amdgpu
[ 51.907] (==) Matched amdgpu as autoconfigured driver 0
[ 51.907] (==) Matched ati as autoconfigured driver 1
[ 51.907] (==) Matched modesetting as autoconfigured driver 2
[ 51.907] (==) Matched fbdev as autoconfigured driver 3
[ 51.907] (==) Matched vesa as autoconfigured driver 4
[ 51.907] (==) Assigned the driver to the xf86ConfigLayout
[ 51.907] (II) LoadModule: "amdgpu"
[ 51.907] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 51.908] (II) Module amdgpu: vendor="X.Org Foundation"
[ 51.908] compiled for 1.20.8, module version = 19.1.0
[ 51.908] Module class: X.Org Video Driver
[ 51.908] ABI class: X.Org Video Driver, version 24.1
[ 51.908] (II) LoadModule: "ati"
[ 51.908] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 51.908] (II) Module ati: vendor="X.Org Foundation"
[ 51.909] (II) LoadModule: "modesetting"
[ 51.909] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 51.909] (II) Module modesetting: vendor="X.Org Foundation"
[ 51.909] compiled for 1.20.10, module version = 1.20.10
[ 51.909] Module class: X.Org Video Driver
[ 51.909] ABI class: X.Org Video Driver, version 24.1
[ 51.909] (II) LoadModule: "fbdev"
[ 51.909] (WW) Warning, couldn't open module fbdev
[ 51.909] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 51.909] (II) LoadModule: "vesa"
[ 51.909] (WW) Warning, couldn't open module vesa
[ 51.909] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 51.909] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 51.910] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 51.947] (WW) Falling back to old probe method for modesetting
[ 51.947] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 51.947] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 51.947] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 51.947] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 51.947] (==) AMDGPU(0): Default visual is TrueColor
[ 51.947] (==) AMDGPU(0): RGB weight 888
[ 51.947] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 51.947] (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x1636)
[ 51.947] (II) Loading sub module "fb"
[ 51.947] (II) LoadModule: "fb"
[ 51.948] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 51.948] (II) Module fb: vendor="X.Org Foundation"
[ 51.948] compiled for 1.20.10, module version = 1.0.0
[ 51.948] ABI class: X.Org ANSI C Emulation, version 0.4
[ 51.948] (II) Loading sub module "dri2"
[ 51.948] (II) LoadModule: "dri2"
[ 51.948] (II) Module "dri2" already built-in
[ 51.999] (II) Loading sub module "glamoregl"
[ 51.999] (II) LoadModule: "glamoregl"
[ 51.999] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 52.002] (II) Module glamoregl: vendor="X.Org Foundation"
[ 52.002] compiled for 1.20.10, module version = 1.0.1
[ 52.002] ABI class: X.Org ANSI C Emulation, version 0.4
[ 52.017] (II) AMDGPU(0): glamor X acceleration enabled on AMD RENOIR (DRM 3.40.0, 5.11.0-1-MANJARO, LLVM 11.0.1)
[ 52.017] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 52.017] (==) AMDGPU(0): TearFree property default: auto
[ 52.017] (==) AMDGPU(0): VariableRefresh: disabled
[ 52.017] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 52.018] (II) AMDGPU(0): Output eDP has no monitor section
[ 52.024] (II) AMDGPU(0): EDID for output eDP
[ 52.024] (II) AMDGPU(0): Manufacturer: AUO Model: 82ed Serial#: 0
[ 52.024] (II) AMDGPU(0): Year: 2018 Week: 12
[ 52.024] (II) AMDGPU(0): EDID Version: 1.4
[ 52.024] (II) AMDGPU(0): Digital Display Input
[ 52.024] (II) AMDGPU(0): 8 bits per channel
[ 52.024] (II) AMDGPU(0): Digital interface is DisplayPort
[ 52.024] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 52.024] (II) AMDGPU(0): Gamma: 2.20
[ 52.024] (II) AMDGPU(0): No DPMS capabilities specified
[ 52.024] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4
[ 52.024] (II) AMDGPU(0): First detailed timing is preferred mode
[ 52.024] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 52.024] (II) AMDGPU(0): redX: 0.642 redY: 0.338 greenX: 0.322 greenY: 0.611
[ 52.024] (II) AMDGPU(0): blueX: 0.153 blueY: 0.046 whiteX: 0.313 whiteY: 0.329
[ 52.024] (II) AMDGPU(0): Manufacturer's mask: 0
[ 52.024] (II) AMDGPU(0): Supported detailed timing:
[ 52.024] (II) AMDGPU(0): clock: 368.1 MHz Image Size: 344 x 193 mm
[ 52.024] (II) AMDGPU(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2102 h_border: 0
[ 52.024] (II) AMDGPU(0): v_active: 1080 v_sync: 1090 v_sync_end 1095 v_blanking: 1216 v_border: 0
[ 52.024] (II) AMDGPU(0): v_active: 1080 v_sync: 1090 v_sync_end 1095 v_blanking: 2915 v_border: 0
[ 52.024] (II) AMDGPU(0): Unknown vendor-specific block 2
[ 52.024] (II) AMDGPU(0): EDID (in hex):
[ 52.024] (II) AMDGPU(0): 00ffffffffffff0006afed8200000000
[ 52.024] (II) AMDGPU(0): 0c1c0104a5221378026a75a456529c27
[ 52.024] (II) AMDGPU(0): 0b505400000001010101010101010101
[ 52.024] (II) AMDGPU(0): 010101010101ce8f80b6703888403020
[ 52.024] (II) AMDGPU(0): a50058c110000018ce8f80b670382b47
[ 52.024] (II) AMDGPU(0): 3020a50058c110000018000000000000
[ 52.024] (II) AMDGPU(0): 00000000000000000000000000000002
[ 52.024] (II) AMDGPU(0): 001036ff0f3c9624143396202020000f
[ 52.024] (II) AMDGPU(0): Printing probed modes for output eDP
[ 52.024] (II) AMDGPU(0): Modeline "1920x1080"x144.0 368.14 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (175.1 kHz eP)
[ 52.024] (II) AMDGPU(0): Modeline "1920x1080"x60.1 368.14 1920 1968 2000 2102 1080 1090 1095 2915 -hsync -vsync (175.1 kHz e)
[ 52.024] (II) AMDGPU(0): Modeline "1680x1050"x144.0 368.14 1680 1968 2000 2102 1050 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 52.024] (II) AMDGPU(0): Modeline "1280x1024"x144.0 368.14 1280 1968 2000 2102 1024 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 52.024] (II) AMDGPU(0): Modeline "1440x900"x144.0 368.14 1440 1968 2000 2102 900 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 52.024] (II) AMDGPU(0): Modeline "1280x800"x144.0 368.14 1280 1968 2000 2102 800 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 52.024] (II) AMDGPU(0): Modeline "1280x720"x144.0 368.14 1280 1968 2000 2102 720 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 52.024] (II) AMDGPU(0): Modeline "1024x768"x144.0 368.14 1024 1968 2000 2102 768 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 52.024] (II) AMDGPU(0): Modeline "800x600"x144.0 368.14 800 1968 2000 2102 600 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 52.024] (II) AMDGPU(0): Modeline "640x480"x144.0 368.14 640 1968 2000 2102 480 1090 1095 1216 -hsync -vsync (175.1 kHz e)
[ 52.024] (II) AMDGPU(0): Output eDP connected
[ 52.024] (II) AMDGPU(0): Using exact sizes for initial modes
[ 52.024] (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
[ 52.024] (II) AMDGPU(0): mem size init: gart size :bf6b3000 vram size: s:1d60d000 visible:1d60d000
[ 52.024] (==) AMDGPU(0): DPI set to (96, 96)
[ 52.024] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 52.025] (II) Loading sub module "ramdac"
[ 52.025] (II) LoadModule: "ramdac"
[ 52.025] (II) Module "ramdac" already built-in
[ 52.025] (II) UnloadModule: "modesetting"
[ 52.025] (II) Unloading modesetting
[ 52.025] (II) AMDGPU(0): [DRI2] Setup complete
[ 52.025] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 52.025] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 52.039] (II) AMDGPU(0): Front buffer pitch: 7680 bytes
[ 52.040] (II) AMDGPU(0): SYNC extension fences enabled
[ 52.040] (II) AMDGPU(0): Present extension enabled
[ 52.040] (==) AMDGPU(0): DRI3 enabled
[ 52.040] (==) AMDGPU(0): Backing store enabled
[ 52.040] (II) AMDGPU(0): Direct rendering enabled
[ 52.053] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 52.053] (II) AMDGPU(0): Acceleration enabled
[ 52.053] (==) AMDGPU(0): DPMS enabled
[ 52.053] (==) AMDGPU(0): Silken mouse disabled
[ 52.054] (II) AMDGPU(0): Set up textured video (glamor)
[ 52.058] (II) Initializing extension Generic Event Extension
[ 52.058] (II) Initializing extension SHAPE
[ 52.058] (II) Initializing extension MIT-SHM
[ 52.058] (II) Initializing extension XInputExtension
[ 52.058] (II) Initializing extension XTEST
[ 52.058] (II) Initializing extension BIG-REQUESTS
[ 52.058] (II) Initializing extension SYNC
[ 52.058] (II) Initializing extension XKEYBOARD
[ 52.058] (II) Initializing extension XC-MISC
[ 52.058] (II) Initializing extension SECURITY
[ 52.058] (II) Initializing extension XFIXES
[ 52.058] (II) Initializing extension RENDER
[ 52.058] (II) Initializing extension RANDR
[ 52.058] (II) Initializing extension COMPOSITE
[ 52.058] (II) Initializing extension DAMAGE
[ 52.058] (II) Initializing extension MIT-SCREEN-SAVER
[ 52.058] (II) Initializing extension DOUBLE-BUFFER
[ 52.058] (II) Initializing extension RECORD
[ 52.058] (II) Initializing extension DPMS
[ 52.058] (II) Initializing extension Present
[ 52.058] (II) Initializing extension DRI3
[ 52.058] (II) Initializing extension X-Resource
[ 52.058] (II) Initializing extension XVideo
[ 52.058] (II) Initializing extension XVideo-MotionCompensation
[ 52.058] (II) Initializing extension GLX
[ 52.061] (II) AIGLX: Loaded and initialized radeonsi
[ 52.061] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 52.061] (II) Initializing extension XFree86-VidModeExtension
[ 52.061] (II) Initializing extension XFree86-DGA
[ 52.061] (II) Initializing extension XFree86-DRI
[ 52.061] (II) Initializing extension DRI2
[ 52.062] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[ 52.140] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 52.140] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 52.140] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 52.140] (II) LoadModule: "libinput"
[ 52.140] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 52.143] (II) Module libinput: vendor="X.Org Foundation"
[ 52.143] compiled for 1.20.8, module version = 0.30.0
[ 52.143] Module class: X.Org XInput Driver
[ 52.143] ABI class: X.Org XInput driver, version 24.1
[ 52.143] (II) Using input driver 'libinput' for 'Power Button'
[ 52.546] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 20 paused 0
[ 52.546] (**) Power Button: always reports core events
[ 52.546] (**) Option "Device" "/dev/input/event2"
[ 52.546] (**) Option "_source" "server/udev"
[ 52.548] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 52.549] (II) event2 - Power Button: device is a keyboard
[ 52.549] (II) event2 - Power Button: device removed
[ 52.549] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 52.549] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 52.550] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 52.550] (II) event2 - Power Button: device is a keyboard
[ 52.551] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[ 52.551] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 52.551] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 52.551] (II) Using input driver 'libinput' for 'Video Bus'
[ 52.553] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 23 paused 0
[ 52.553] (**) Video Bus: always reports core events
[ 52.553] (**) Option "Device" "/dev/input/event4"
[ 52.553] (**) Option "_source" "server/udev"
[ 52.555] (II) event4 - Video Bus: is tagged by udev as: Keyboard
[ 52.555] (II) event4 - Video Bus: device is a keyboard
[ 52.555] (II) event4 - Video Bus: device removed
[ 52.555] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:03/LNXVIDEO:00/input/input4/event4"
[ 52.555] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 52.557] (II) event4 - Video Bus: is tagged by udev as: Keyboard
[ 52.557] (II) event4 - Video Bus: device is a keyboard
[ 52.558] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 52.558] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 52.558] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 52.558] (II) Using input driver 'libinput' for 'Power Button'
[ 52.560] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 24 paused 0
[ 52.560] (**) Power Button: always reports core events
[ 52.560] (**) Option "Device" "/dev/input/event0"
[ 52.560] (**) Option "_source" "server/udev"
[ 52.561] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 52.561] (II) event0 - Power Button: device is a keyboard
[ 52.562] (II) event0 - Power Button: device removed
[ 52.562] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 52.562] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 52.563] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 52.563] (II) event0 - Power Button: device is a keyboard
[ 52.564] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[ 52.564] (II) No input driver specified, ignoring this device.
[ 52.564] (II) This device may have been added with another device file.
[ 52.565] (II) config/udev: Adding input device HP Wide Vision HD Camera: HP Wi (/dev/input/event16)
[ 52.566] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "evdev keyboard catchall"
[ 52.566] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "libinput keyboard catchall"
[ 52.566] (II) Using input driver 'libinput' for 'HP Wide Vision HD Camera: HP Wi'
[ 52.567] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 25 paused 0
[ 52.567] (**) HP Wide Vision HD Camera: HP Wi: always reports core events
[ 52.567] (**) Option "Device" "/dev/input/event16"
[ 52.567] (**) Option "_source" "server/udev"
[ 52.570] (II) event16 - HP Wide Vision HD Camera: HP Wi: is tagged by udev as: Keyboard
[ 52.570] (II) event16 - HP Wide Vision HD Camera: HP Wi: device is a keyboard
[ 52.570] (II) event16 - HP Wide Vision HD Camera: HP Wi: device removed
[ 52.570] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.3/usb3/3-3/3-3:1.0/input/input21/event16"
[ 52.570] (II) XINPUT: Adding extended input device "HP Wide Vision HD Camera: HP Wi" (type: KEYBOARD, id 9)
[ 52.572] (II) event16 - HP Wide Vision HD Camera: HP Wi: is tagged by udev as: Keyboard
[ 52.572] (II) event16 - HP Wide Vision HD Camera: HP Wi: device is a keyboard
[ 52.574] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 (/dev/input/event11)
[ 52.574] (**) Microsoft Microsoft® Nano Transceiver v2.0: Applying InputClass "evdev keyboard catchall"
[ 52.574] (**) Microsoft Microsoft® Nano Transceiver v2.0: Applying InputClass "libinput keyboard catchall"
[ 52.574] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0'
[ 52.575] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 26 paused 0
[ 52.575] (**) Microsoft Microsoft® Nano Transceiver v2.0: always reports core events
[ 52.575] (**) Option "Device" "/dev/input/event11"
[ 52.575] (**) Option "_source" "server/udev"
[ 52.578] (II) event11 - Microsoft Microsoft® Nano Transceiver v2.0: is tagged by udev as: Keyboard
[ 52.578] (II) event11 - Microsoft Microsoft® Nano Transceiver v2.0: device is a keyboard
[ 52.579] (II) event11 - Microsoft Microsoft® Nano Transceiver v2.0: device removed
[ 52.579] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb5/5-1/5-1:1.0/0003:045E:0745.0002/input/input15/event11"
[ 52.579] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0" (type: KEYBOARD, id 10)
[ 52.581] (II) event11 - Microsoft Microsoft® Nano Transceiver v2.0: is tagged by udev as: Keyboard
[ 52.581] (II) event11 - Microsoft Microsoft® Nano Transceiver v2.0: device is a keyboard
[ 52.583] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Mouse (/dev/input/event12)
[ 52.583] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: Applying InputClass "evdev pointer catchall"
[ 52.583] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: Applying InputClass "libinput pointer catchall"
[ 52.583] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Mouse'
[ 52.584] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 27 paused 0
[ 52.584] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: always reports core events
[ 52.584] (**) Option "Device" "/dev/input/event12"
[ 52.584] (**) Option "_source" "server/udev"
[ 52.587] (II) event12 - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: is tagged by udev as: Mouse
[ 52.588] (II) event12 - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: device is a pointer
[ 52.588] (II) event12 - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: device removed
[ 52.588] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb5/5-1/5-1:1.1/0003:045E:0745.0003/input/input16/event12"
[ 52.588] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Mouse" (type: MOUSE, id 11)
[ 52.588] (**) Option "AccelerationScheme" "none"
[ 52.588] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: (accel) selected scheme none/0
[ 52.588] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: (accel) acceleration factor: 2.000
[ 52.588] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: (accel) acceleration threshold: 4
[ 52.591] (II) event12 - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: is tagged by udev as: Mouse
[ 52.591] (II) event12 - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: device is a pointer
[ 52.592] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Mouse (/dev/input/mouse2)
[ 52.592] (II) No input driver specified, ignoring this device.
[ 52.592] (II) This device may have been added with another device file.
[ 52.593] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control (/dev/input/event13)
[ 52.593] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 52.593] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 52.593] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[ 52.595] (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 28 paused 0
[ 52.595] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: always reports core events
[ 52.595] (**) Option "Device" "/dev/input/event13"
[ 52.595] (**) Option "_source" "server/udev"
[ 52.598] (II) event13 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[ 52.598] (II) event13 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[ 52.598] (II) event13 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device removed
[ 52.598] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: needs a virtual subdevice
[ 52.598] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb5/5-1/5-1:1.1/0003:045E:0745.0003/input/input17/event13"
[ 52.598] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: MOUSE, id 12)
[ 52.598] (**) Option "AccelerationScheme" "none"
[ 52.598] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) selected scheme none/0
[ 52.598] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration factor: 2.000
[ 52.598] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration threshold: 4
[ 52.601] (II) event13 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[ 52.601] (II) event13 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[ 52.602] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control (/dev/input/event14)
[ 52.602] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 52.602] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 52.602] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[ 52.604] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 29 paused 0
[ 52.604] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: always reports core events
[ 52.604] (**) Option "Device" "/dev/input/event14"
[ 52.604] (**) Option "_source" "server/udev"
[ 52.607] (II) event14 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[ 52.607] (II) event14 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[ 52.607] (II) event14 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device removed
[ 52.607] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: needs a virtual subdevice
[ 52.607] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb5/5-1/5-1:1.2/0003:045E:0745.0004/input/input18/event14"
[ 52.607] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: MOUSE, id 13)
[ 52.607] (**) Option "AccelerationScheme" "none"
[ 52.607] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) selected scheme none/0
[ 52.607] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration factor: 2.000
[ 52.607] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration threshold: 4
[ 52.610] (II) event14 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[ 52.610] (II) event14 - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[ 52.611] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 System Control (/dev/input/event15)
[ 52.611] (**) Microsoft Microsoft® Nano Transceiver v2.0 System Control: Applying InputClass "evdev keyboard catchall"
[ 52.611] (**) Microsoft Microsoft® Nano Transceiver v2.0 System Control: Applying InputClass "libinput keyboard catchall"
[ 52.611] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 System Control'
[ 52.613] (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 30 paused 0
[ 52.613] (**) Microsoft Microsoft® Nano Transceiver v2.0 System Control: always reports core events
[ 52.613] (**) Option "Device" "/dev/input/event15"
[ 52.613] (**) Option "_source" "server/udev"
[ 52.616] (II) event15 - Microsoft Microsoft® Nano Transceiver v2.0 System Control: is tagged by udev as: Keyboard
[ 52.616] (II) event15 - Microsoft Microsoft® Nano Transceiver v2.0 System Control: device is a keyboard
[ 52.616] (II) event15 - Microsoft Microsoft® Nano Transceiver v2.0 System Control: device removed
[ 52.616] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb5/5-1/5-1:1.2/0003:045E:0745.0004/input/input20/event15"
[ 52.616] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 System Control" (type: KEYBOARD, id 14)
[ 52.619] (II) event15 - Microsoft Microsoft® Nano Transceiver v2.0 System Control: is tagged by udev as: Keyboard
[ 52.619] (II) event15 - Microsoft Microsoft® Nano Transceiver v2.0 System Control: device is a keyboard
[ 52.620] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event9)
[ 52.620] (II) No input driver specified, ignoring this device.
[ 52.620] (II) This device may have been added with another device file.
[ 52.620] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event8)
[ 52.621] (II) config/udev: Adding input device SYNA32A5:00 06CB:CE17 Mouse (/dev/input/event5)
[ 52.621] (**) SYNA32A5:00 06CB:CE17 Mouse: Applying InputClass "evdev pointer catchall"
[ 52.621] (**) SYNA32A5:00 06CB:CE17 Mouse: Applying InputClass "libinput pointer catchall"
[ 52.621] (II) Using input driver 'libinput' for 'SYNA32A5:00 06CB:CE17 Mouse'
[ 52.623] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 31 paused 0
[ 52.623] (**) SYNA32A5:00 06CB:CE17 Mouse: always reports core events
[ 52.623] (**) Option "Device" "/dev/input/event5"
[ 52.623] (**) Option "_source" "server/udev"
[ 52.625] (II) event5 - SYNA32A5:00 06CB:CE17 Mouse: is tagged by udev as: Mouse Pointingstick
[ 52.626] (II) event5 - SYNA32A5:00 06CB:CE17 Mouse: device is a pointer
[ 52.627] (II) event5 - SYNA32A5:00 06CB:CE17 Mouse: device removed
[ 52.627] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-SYNA32A5:00/0018:06CB:CE17.0001/input/input11/event5"
[ 52.627] (II) XINPUT: Adding extended input device "SYNA32A5:00 06CB:CE17 Mouse" (type: MOUSE, id 15)
[ 52.627] (**) Option "AccelerationScheme" "none"
[ 52.627] (**) SYNA32A5:00 06CB:CE17 Mouse: (accel) selected scheme none/0
[ 52.627] (**) SYNA32A5:00 06CB:CE17 Mouse: (accel) acceleration factor: 2.000
[ 52.627] (**) SYNA32A5:00 06CB:CE17 Mouse: (accel) acceleration threshold: 4
[ 52.629] (II) event5 - SYNA32A5:00 06CB:CE17 Mouse: is tagged by udev as: Mouse Pointingstick
[ 52.629] (II) event5 - SYNA32A5:00 06CB:CE17 Mouse: device is a pointer
[ 52.630] (II) config/udev: Adding input device SYNA32A5:00 06CB:CE17 Mouse (/dev/input/mouse0)
[ 52.630] (II) No input driver specified, ignoring this device.
[ 52.630] (II) This device may have been added with another device file.
[ 52.631] (II) config/udev: Adding input device SYNA32A5:00 06CB:CE17 Touchpad (/dev/input/event6)
[ 52.631] (**) SYNA32A5:00 06CB:CE17 Touchpad: Applying InputClass "evdev touchpad catchall"
[ 52.631] (**) SYNA32A5:00 06CB:CE17 Touchpad: Applying InputClass "libinput touchpad catchall"
[ 52.631] (II) Using input driver 'libinput' for 'SYNA32A5:00 06CB:CE17 Touchpad'
[ 52.632] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 32 paused 0
[ 52.632] (**) SYNA32A5:00 06CB:CE17 Touchpad: always reports core events
[ 52.632] (**) Option "Device" "/dev/input/event6"
[ 52.632] (**) Option "_source" "server/udev"
[ 52.633] (II) event6 - SYNA32A5:00 06CB:CE17 Touchpad: is tagged by udev as: Touchpad
[ 52.633] (II) event6 - SYNA32A5:00 06CB:CE17 Touchpad: device is a touchpad
[ 52.633] (II) event6 - SYNA32A5:00 06CB:CE17 Touchpad: device removed
[ 52.634] (**) Option "config_info" "udev:/sys/devices/platform/AMDI0010:03/i2c-0/i2c-SYNA32A5:00/0018:06CB:CE17.0001/input/input12/event6"
[ 52.634] (II) XINPUT: Adding extended input device "SYNA32A5:00 06CB:CE17 Touchpad" (type: TOUCHPAD, id 16)
[ 52.634] (**) Option "AccelerationScheme" "none"
[ 52.634] (**) SYNA32A5:00 06CB:CE17 Touchpad: (accel) selected scheme none/0
[ 52.634] (**) SYNA32A5:00 06CB:CE17 Touchpad: (accel) acceleration factor: 2.000
[ 52.634] (**) SYNA32A5:00 06CB:CE17 Touchpad: (accel) acceleration threshold: 4
[ 52.635] (II) event6 - SYNA32A5:00 06CB:CE17 Touchpad: is tagged by udev as: Touchpad
[ 52.636] (II) event6 - SYNA32A5:00 06CB:CE17 Touchpad: device is a touchpad
[ 52.636] (II) config/udev: Adding input device SYNA32A5:00 06CB:CE17 Touchpad (/dev/input/mouse1)
[ 52.636] (II) No input driver specified, ignoring this device.
[ 52.636] (II) This device may have been added with another device file.
[ 52.637] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 52.637] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 52.637] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 52.637] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 52.638] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 33 paused 0
[ 52.638] (**) AT Translated Set 2 keyboard: always reports core events
[ 52.638] (**) Option "Device" "/dev/input/event3"
[ 52.638] (**) Option "_source" "server/udev"
[ 52.638] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 52.638] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 52.640] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 52.640] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 52.640] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 17)
[ 52.642] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 52.642] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 52.644] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 52.644] (II) No input driver specified, ignoring this device.
[ 52.644] (II) This device may have been added with another device file.
[ 52.645] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event10)
[ 52.645] (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 52.645] (**) HP WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 52.645] (II) Using input driver 'libinput' for 'HP WMI hotkeys'
[ 52.646] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 34 paused 0
[ 52.646] (**) HP WMI hotkeys: always reports core events
[ 52.646] (**) Option "Device" "/dev/input/event10"
[ 52.646] (**) Option "_source" "server/udev"
[ 52.648] (II) event10 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 52.648] (II) event10 - HP WMI hotkeys: device is a keyboard
[ 52.648] (II) event10 - HP WMI hotkeys: device is a switch device
[ 52.648] (II) event10 - HP WMI hotkeys: device removed
[ 52.648] (**) Option "config_info" "udev:/sys/devices/virtual/input/input14/event10"
[ 52.648] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 18)
[ 52.650] (II) event10 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 52.650] (II) event10 - HP WMI hotkeys: device is a keyboard
[ 52.650] (II) event10 - HP WMI hotkeys: device is a switch device
[ 52.656] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 52.656] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 52.656] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[ 52.656] (II) systemd-logind: returning pre-existing fd for /dev/input/event13 13:77
[ 52.656] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: always reports core events
[ 52.656] (**) Option "Device" "/dev/input/event13"
[ 52.656] (**) Option "_source" "_driver/libinput"
[ 52.656] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is a virtual subdevice
[ 52.656] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb5/5-1/5-1:1.1/0003:045E:0745.0003/input/input17/event13"
[ 52.656] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: KEYBOARD, id 19)
[ 52.657] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 52.657] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 52.657] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[ 52.657] (II) systemd-logind: returning pre-existing fd for /dev/input/event14 13:78
[ 52.657] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: always reports core events
[ 52.657] (**) Option "Device" "/dev/input/event14"
[ 52.657] (**) Option "_source" "_driver/libinput"
[ 52.657] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is a virtual subdevice
[ 52.657] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:06:00.4/usb5/5-1/5-1:1.2/0003:045E:0745.0004/input/input18/event14"
[ 52.657] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: KEYBOARD, id 20)
[ 53.216] (II) AMDGPU(0): EDID vendor "AUO", prod id 33517
[ 53.216] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 53.216] (II) AMDGPU(0): Modeline "1920x1080"x0.0 368.14 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (175.1 kHz eP)
[ 53.216] (II) AMDGPU(0): Modeline "1920x1080"x0.0 368.14 1920 1968 2000 2102 1080 1090 1095 2915 -hsync -vsync (175.1 kHz e)
[ 54.980] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 54.980] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 54.980] (EE) AMDGPU(0): present flip failed
[ 54.987] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 54.987] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 54.987] (EE) AMDGPU(0): present flip failed
[ 55.027] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.027] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.027] (EE) AMDGPU(0): present flip failed
[ 55.036] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.036] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.036] (EE) AMDGPU(0): present flip failed
[ 55.043] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.043] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.043] (EE) AMDGPU(0): present flip failed
[ 55.050] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.050] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.050] (EE) AMDGPU(0): present flip failed
[ 55.057] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.057] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.057] (EE) AMDGPU(0): present flip failed
[ 55.064] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.064] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.064] (EE) AMDGPU(0): present flip failed
[ 55.070] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.070] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.070] (EE) AMDGPU(0): present flip failed
[ 55.078] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.078] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.078] (EE) AMDGPU(0): present flip failed
[ 55.085] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.085] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.085] (EE) AMDGPU(0): present flip failed
[ 55.091] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.092] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.092] (EE) AMDGPU(0): present flip failed
[ 55.098] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.099] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.099] (EE) AMDGPU(0): present flip failed
[ 55.106] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.106] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.106] (EE) AMDGPU(0): present flip failed
[ 55.112] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.112] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.112] (EE) AMDGPU(0): present flip failed
[ 55.119] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.119] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.119] (EE) AMDGPU(0): present flip failed
[ 55.126] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.126] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.126] (EE) AMDGPU(0): present flip failed
[ 55.133] (WW) AMDGPU(0): flip queue failed: Invalid argument
[ 55.133] (WW) AMDGPU(0): Page flip failed: Invalid argument
[ 55.133] (EE) AMDGPU(0): present flip failed
... -> all the logs after that are repeating the pattern
Interestingly, there is no mention of the NVIDIA driver there. Can you post the output of head -n999 /etc/X11/xorg.conf /etc/X11/xorg.conf.d/* /usr/share/X11/xorg.conf.d/*
