- During installation, I encountered a black screen when booting the live USB with Boot with open source drive.
- I had to use
nomodeset just to access the installer, so I think the system never loaded the proper amdgpu driver during install.
- After installing, I’m now stuck with software rendering (
llvmpipe), and inxi shows “driver: N/A”.
full system info:
inxi -zav7
Kernel: 6.6.99-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
root=UUID=2049e622-3a95-4ad5-a931-fb2b92446d67 rw rootflags=subvol=@
quiet splash radeon.cik_support=0 amdgpu.cik_support=1 apparmor=1
Desktop: GNOME v: 48.3 tk: GTK v: 3.24.49 wm: gnome-shell
base: Arch Linux
Type: Desktop System: Gigabyte product: N/A v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Gigabyte model: F2A68HM-S1 v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: FD date: 10/09/2018
System RAM: total: 16 GiB available: 15.08 GiB used: 2.5 GiB (16.6%)
Array-1: capacity: 32 GiB note: est. slots: 4 modules: 2 EC: None
Device-1: Node0_Dimm0 type: no module installed
Device-2: Node0_Dimm1 type: DDR3 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 1866 MT/s volts: N/A width (bits):
data: 64 total: 64 manufacturer: Kingston part-no: HX318C10FK2/1
serial: <filter>
Device-3: Node0_Dimm2 type: no module installed
Device-4: Node0_Dimm3 type: DDR3 detail: synchronous unbuffered
serial: <filter>
Info: model: AMD A8-7680 Radeon R7 10 Compute Cores 4C+6G bits: 64
type: MT MCP arch: Excavator level: v3 note: check built: 2015
process: GF 28nm family: 0x15 (21) model-id: 0x60 (96) stepping: 1
microcode: 0x600611A
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: enabled cache:
L1: 320 KiB desc: d-4x32 KiB; i-2x96 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1398 min/max: 1400/3500 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1398 2: 1398 3: 1398
4: 1398 bogomips: 27963
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avic avx avx2
bmi1 bmi2 bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy
cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fma4
fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs lahf_lm lbrv lm lwp mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nodeid_msr
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
pse36 ptsc rdtscp rep_good sep skinit smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vgif
vmcb_clean vme vmmcall wdt xop xsave xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: Advanced Micro Devices [AMD/ATI] Wani [Radeon R5/R6/R7 Graphics]
vendor: Gigabyte driver: N/A alternate: amdgpu arch: GCN-3
code: Volcanic Islands process: TSMC 28nm built: 2014-19 bus-ID: 00:01.0
chip-ID: 1002:9874 class-ID: 0300
compositor: gnome-shell driver: X: loaded: radeon unloaded: modesetting
alternate: fbdev,vesa gpu: N/A display-ID: 0 note: no compositor data
Monitor-1: Unknown-1 size-res: N/A modes: 1024x768
API: EGL v: 1.5 platforms: device: 0 drv: swrast surfaceless: drv: swrast
wayland: drv: swrast x11: drv: swrast inactive: gbm
API: OpenGL v: 4.5 vendor: mesa v: 25.1.6-arch1.1 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 20.1.8 256 bits)
device-ID: ffffffff:ffffffff memory: 14.72 GiB unified: yes
display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xprop
Device-1: Advanced Micro Devices [AMD] FCH Azalia vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d
class-ID: 0403
API: ALSA v: k6.6.99-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 409.88 GiB used: 9.65 GiB (2.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37 120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: HD322HJ
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 1118 scheme: GPT
ID-1: / raw-size: 30 GiB size: 30 GiB (100.00%) used: 9.61 GiB (32.0%)
fs: btrfs dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 2049e622-3a95-4ad5-a931-fb2b92446d67
used: 31.4 MiB (32.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 7CA6-B183
ID-3: /home raw-size: 30 GiB size: 30 GiB (100.00%) used: 9.61 GiB (32.0%)
ID-4: /var/cache raw-size: 30 GiB size: 30 GiB (100.00%)
used: 9.61 GiB (32.0%) fs: btrfs dev: /dev/sda5 maj-min: 8:5 label: N/A
ID-5: /var/log raw-size: 30 GiB size: 30 GiB (100.00%)
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 81.03 GiB fs: ntfs label: N/A
uuid: 01DBFEC65EF31410
ID-3: /dev/sda4 maj-min: 8:4 size: 660 MiB fs: ntfs label: N/A
uuid: D8E6617BE6615B30
ID-4: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-5: /dev/sdb2 maj-min: 8:18 size: 298.07 GiB fs: ntfs label: Storage
uuid: 4824BB7D24BB6C96
Hub-1: 1-0:1 info: full speed or root hub ports: 5 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Hub-2: 2-0:1 info: full speed or root hub ports: 5 rev: 2.0
Hub-3: 3-0:1 info: full speed or root hub ports: 5 rev: 2.0
Hub-4: 4-0:1 info: full speed or root hub ports: 5 rev: 1.1
Device-1: 4-4:2 info: USB Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1
chip-ID: 30fa:0300 class-ID: 0301
Hub-5: 5-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-6: 6-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 6-1:2 info: SINO WEALTH Gaming KB type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 258a:003a class-ID: 0300
Hub-7: 7-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 225 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.01 GiB services: gsd-power,
tool: systemctl
Packages: pm: pacman pkgs: 1176 libs: 326 tools: gnome-software,pamac
pm: flatpak pkgs: 0 Compilers: N/A Shell: Zsh v: 5.9 running-in: kgx
inxi: 3.3.38
logs:
journalctl -b0 -p5 --no-pager ✔ 4s
mhwd -l && mhwd -li
Jul 28 17:44:22 marc-tobefilledbyoem kernel: Linux version 6.6.99-1-MANJARO (builduser@pkrvmq0rgcvqdmg) (gcc (GCC) 15.1.1 20250425, GNU ld (GNU Binutils) 2.44.0) #1 SMP PREEMPT_DYNAMIC Thu Jul 17 22:09:32 UTC 2025
Jul 28 17:44:22 marc-tobefilledbyoem kernel: ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20230628/tbfadt-615)
Jul 28 17:44:22 marc-tobefilledbyoem kernel: Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64 root=UUID=2049e622-3a95-4ad5-a931-fb2b92446d67 rw rootflags=subvol=@ quiet splash radeon.cik_support=0 amdgpu.cik_support=1 apparmor=1 security=apparmor udev.log_priority=3
Jul 28 17:44:22 marc-tobefilledbyoem kernel: Unknown kernel command line parameters "splash BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64", will be passed to user space.
Jul 28 17:44:22 marc-tobefilledbyoem kernel: random: crng init done
Jul 28 17:44:22 marc-tobefilledbyoem kernel: audit: type=2000 audit(1753695859.166:1): state=initialized audit_enabled=0 res=1
Jul 28 17:44:23 marc-tobefilledbyoem kernel: SCSI subsystem initialized
Jul 28 17:44:23 marc-tobefilledbyoem kernel: VFS: Disk quotas dquot_6.6.0
Jul 28 17:44:23 marc-tobefilledbyoem kernel: Initialise system trusted keyrings
Jul 28 17:44:23 marc-tobefilledbyoem kernel: Key type blacklist registered
Jul 28 17:44:23 marc-tobefilledbyoem kernel: integrity: Platform Keyring initialized
Jul 28 17:44:23 marc-tobefilledbyoem kernel: integrity: Machine keyring initialized
Jul 28 17:44:23 marc-tobefilledbyoem kernel: Key type asymmetric registered
Jul 28 17:44:23 marc-tobefilledbyoem kernel: Asymmetric key parser 'x509' registered
Jul 28 17:44:23 marc-tobefilledbyoem kernel: amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
Jul 28 17:44:23 marc-tobefilledbyoem kernel: Loading compiled-in X.509 certificates
Jul 28 17:44:23 marc-tobefilledbyoem kernel: Loaded X.509 cert 'Build time autogenerated kernel key: df3a18165e14ebd53627bd0791dff3f643628655'
Jul 28 17:44:23 marc-tobefilledbyoem kernel: Key type .fscrypt registered
Jul 28 17:44:23 marc-tobefilledbyoem kernel: Key type fscrypt-provisioning registered
Jul 28 17:44:23 marc-tobefilledbyoem kernel: integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
Jul 28 17:44:23 marc-tobefilledbyoem kernel: integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
Jul 28 17:44:23 marc-tobefilledbyoem kernel: scsi 0:0:0:0: Direct-Access ATA KINGSTON SA400S3 1A0 PQ: 0 ANSI: 5
Jul 28 17:44:23 marc-tobefilledbyoem kernel: scsi 1:0:0:0: Direct-Access ATA SAMSUNG HD322HJ 1118 PQ: 0 ANSI: 5
Jul 28 17:44:23 marc-tobefilledbyoem kernel: sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
Jul 28 17:44:23 marc-tobefilledbyoem kernel: sd 0:0:0:0: [sda] Write Protect is off
Jul 28 17:44:23 marc-tobefilledbyoem kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 28 17:44:23 marc-tobefilledbyoem kernel: sd 1:0:0:0: [sdb] 625142448 512-byte logical blocks: (320 GB/298 GiB)
Jul 28 17:44:23 marc-tobefilledbyoem kernel: sd 1:0:0:0: [sdb] Write Protect is off
Jul 28 17:44:23 marc-tobefilledbyoem kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 28 17:44:23 marc-tobefilledbyoem kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jul 28 17:44:23 marc-tobefilledbyoem kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Jul 28 17:44:23 marc-tobefilledbyoem kernel: systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Jul 28 17:44:23 marc-tobefilledbyoem kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jul 28 17:44:23 marc-tobefilledbyoem kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Jul 28 17:44:22 marc-tobefilledbyoem systemd-vconsole-setup[281]: All allocated VCs are currently busy, skipping initialization of font and keyboard settings.
Jul 28 17:44:24 marc-tobefilledbyoem systemd-journald[273]: File /var/log/journal/4f173845860b46b7bc65ef8c4a63d0c3/system.journal corrupted or uncleanly shut down, renaming and replacing.
Jul 28 17:44:24 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695864.295:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=408 comm="apparmor_parser"
Jul 28 17:44:24 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695864.295:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=407 comm="apparmor_parser"
Jul 28 17:44:24 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695864.298:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=409 comm="apparmor_parser"
Jul 28 17:44:24 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695864.298:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=410 comm="apparmor_parser"
Jul 28 17:44:24 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695864.301:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=413 comm="apparmor_parser"
Jul 28 17:44:24 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695864.305:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=416 comm="apparmor_parser"
Jul 28 17:44:24 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695864.308:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="busybox" pid=418 comm="apparmor_parser"
Jul 28 17:44:24 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695864.315:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=419 comm="apparmor_parser"
Jul 28 17:44:24 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695864.321:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=415 comm="apparmor_parser"
Jul 28 17:44:24 marc-tobefilledbyoem systemd-vconsole-setup[456]: All allocated VCs are currently busy, skipping initialization of font and keyboard settings.
Jul 28 17:44:25 marc-tobefilledbyoem kernel: kauditd_printk_skb: 94 callbacks suppressed
Jul 28 17:44:25 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695865.058:105): apparmor="STATUS" operation="profile_load" profile="unconfined" name="syslogd" pid=510 comm="apparmor_parser"
Jul 28 17:44:25 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695865.075:106): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-anvil" pid=547 comm="apparmor_parser"
Jul 28 17:44:25 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695865.135:107): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-config" pid=549 comm="apparmor_parser"
Jul 28 17:44:25 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695865.201:108): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-deliver" pid=550 comm="apparmor_parser"
Jul 28 17:44:25 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695865.218:109): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-auth" pid=548 comm="apparmor_parser"
Jul 28 17:44:25 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695865.265:110): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-dict" pid=551 comm="apparmor_parser"
Jul 28 17:44:25 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695865.288:111): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-doveadm-server" pid=553 comm="apparmor_parser"
Jul 28 17:44:25 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695865.308:112): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/apache2/mpm-prefork/apache2" pid=546 comm="apparmor_parser"
Jul 28 17:44:25 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695865.308:113): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/apache2/mpm-prefork/apache2//DEFAULT_URI" pid=546 comm="apparmor_parser"
Jul 28 17:44:25 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753695865.308:114): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/apache2/mpm-prefork/apache2//HANDLING_UNTRUSTED_INPUT" pid=546 comm="apparmor_parser"
Jul 28 17:44:26 marc-tobefilledbyoem polkitd[594]: Loading rules from directory /etc/polkit-1/rules.d
Jul 28 17:44:26 marc-tobefilledbyoem polkitd[594]: Loading rules from directory /run/polkit-1/rules.d
Jul 28 17:44:26 marc-tobefilledbyoem polkitd[594]: Error opening rules directory: Error opening directory “/run/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
Jul 28 17:44:26 marc-tobefilledbyoem polkitd[594]: Loading rules from directory /usr/local/share/polkit-1/rules.d
Jul 28 17:44:26 marc-tobefilledbyoem polkitd[594]: Error opening rules directory: Error opening directory “/usr/local/share/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
Jul 28 17:44:26 marc-tobefilledbyoem polkitd[594]: Loading rules from directory /usr/share/polkit-1/rules.d
Jul 28 17:44:26 marc-tobefilledbyoem polkitd[594]: Finished loading, compiling and executing 12 rules
Jul 28 17:44:26 marc-tobefilledbyoem polkitd[594]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jul 28 17:44:26 marc-tobefilledbyoem ModemManager[637]: <msg> ModemManager (version 1.24.0-2) starting in system bus...
Jul 28 17:44:30 marc-tobefilledbyoem dbus-broker-launch[590]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Jul 28 17:44:30 marc-tobefilledbyoem ModemManager[637]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.5/0000:01:00.0': not supported by any plugin
Jul 28 17:44:38 marc-tobefilledbyoem dbus-broker-launch[590]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Jul 28 17:44:38 marc-tobefilledbyoem (systemd)[676]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[gdm] ruser=[<unknown>] rhost=[<unknown>]
Jul 28 17:44:38 marc-tobefilledbyoem gsettings[697]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:38 marc-tobefilledbyoem gsettings[697]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:38 marc-tobefilledbyoem gsettings[697]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:39 marc-tobefilledbyoem gnome-session-b[696]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:39 marc-tobefilledbyoem gnome-session-b[696]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:39 marc-tobefilledbyoem gnome-session-b[696]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:39 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.2' (uid=120 pid=696 comm="/usr/lib/gnome-session-binary --autostart /usr/sha")
Jul 28 17:44:39 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Jul 28 17:44:39 marc-tobefilledbyoem gnome-session-binary[696]: WARNING: Could not check if unit gnome-session-wayland@gnome.target is active: Error calling StartServiceByName for org.freedesktop.systemd1: Process org.freedesktop.systemd1 exited with status 1
Jul 28 17:44:39 marc-tobefilledbyoem gnome-session-binary[696]: WARNING: Desktop file /usr/share/gdm/greeter/autostart/orca-autostart.desktop for application orca-autostart.desktop could not be parsed or references a missing TryExec binary
Jul 28 17:44:39 marc-tobefilledbyoem gnome-shell[708]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:39 marc-tobefilledbyoem gnome-shell[708]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:39 marc-tobefilledbyoem gnome-shell[708]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:39 marc-tobefilledbyoem gnome-shell[708]: Running GNOME Shell (using mutter 48.4) as a Wayland display server
Jul 28 17:44:40 marc-tobefilledbyoem gnome-shell[708]: Thread 'KMS thread' will be using high priority scheduling
Jul 28 17:44:40 marc-tobefilledbyoem gnome-shell[708]: Added device '/dev/dri/card0' (simpledrm) using atomic mode setting.
Jul 28 17:44:40 marc-tobefilledbyoem gnome-shell[708]: Failed to initialize accelerated iGPU/dGPU framebuffer sharing: Not hardware accelerated
Jul 28 17:44:40 marc-tobefilledbyoem gnome-shell[708]: Created gbm renderer for '/dev/dri/card0'
Jul 28 17:44:40 marc-tobefilledbyoem gnome-shell[708]: Integrated GPU /dev/dri/card0 selected as primary
Jul 28 17:44:41 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=120 pid=708 comm="/usr/bin/gnome-shell")
Jul 28 17:44:41 marc-tobefilledbyoem at-spi-bus-laun[749]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:41 marc-tobefilledbyoem at-spi-bus-laun[749]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:41 marc-tobefilledbyoem at-spi-bus-laun[749]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:41 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Successfully activated service 'org.a11y.Bus'
Jul 28 17:44:41 marc-tobefilledbyoem gnome-shell[708]: Using public X11 display :1024, (using :1025 for managed services)
Jul 28 17:44:41 marc-tobefilledbyoem gnome-shell[708]: Using Wayland display name 'wayland-0'
Jul 28 17:44:41 marc-tobefilledbyoem gnome-shell[708]: Couldn't find suitable cursor plane format for /dev/dri/card0, disabling HW cursor
Jul 28 17:44:41 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[755]: dbus-daemon[755]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=120 pid=708 comm="/usr/bin/gnome-shell")
Jul 28 17:44:41 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[755]: dbus-daemon[755]: Successfully activated service 'org.a11y.atspi.Registry'
Jul 28 17:44:42 marc-tobefilledbyoem dbus-broker-launch[590]: Activation request for 'org.freedesktop.Avahi' failed: The systemd unit 'dbus-org.freedesktop.Avahi.service' could not be found.
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Unset XDG_SESSION_ID, getCurrentSessionProxy() called outside a user session. Asking logind directly.
Jul 28 17:44:42 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.gnome.Shell.Screencast' requested by ':1.3' (uid=120 pid=708 comm="/usr/bin/gnome-shell")
Jul 28 17:44:42 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.freedesktop.impl.portal.PermissionStore' requested by ':1.3' (uid=120 pid=708 comm="/usr/bin/gnome-shell")
Jul 28 17:44:42 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
Jul 28 17:44:42 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=120 pid=708 comm="/usr/bin/gnome-shell")
Jul 28 17:44:42 marc-tobefilledbyoem gjs[779]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:42 marc-tobefilledbyoem gjs[779]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:42 marc-tobefilledbyoem gjs[779]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension appindicatorsupport@rgcjonas.gmail.com already installed in /usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com. /usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension apps-menu@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/apps-menu@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/apps-menu@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension arcmenu@arcmenu.com already installed in /usr/share/gnome-shell/extensions/arcmenu@arcmenu.com. /usr/share/gnome-shell/extensions/arcmenu@arcmenu.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension auto-move-windows@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/auto-move-windows@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/auto-move-windows@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension dash-to-dock@micxgx.gmail.com already installed in /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com. /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension dash-to-panel@jderose9.github.com already installed in /usr/share/gnome-shell/extensions/dash-to-panel@jderose9.github.com. /usr/share/gnome-shell/extensions/dash-to-panel@jderose9.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension drive-menu@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/drive-menu@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/drive-menu@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension forge@jmmaranan.com already installed in /usr/share/gnome-shell/extensions/forge@jmmaranan.com. /usr/share/gnome-shell/extensions/forge@jmmaranan.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension gnome-ui-tune@itstime.tech already installed in /usr/share/gnome-shell/extensions/gnome-ui-tune@itstime.tech. /usr/share/gnome-shell/extensions/gnome-ui-tune@itstime.tech will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension gsconnect@andyholmes.github.io already installed in /usr/share/gnome-shell/extensions/gsconnect@andyholmes.github.io. /usr/share/gnome-shell/extensions/gsconnect@andyholmes.github.io will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension gtk4-ding@smedius.gitlab.com already installed in /usr/share/gnome-shell/extensions/gtk4-ding@smedius.gitlab.com. /usr/share/gnome-shell/extensions/gtk4-ding@smedius.gitlab.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension launch-new-instance@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/launch-new-instance@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/launch-new-instance@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension legacyschemeautoswitcher@joshimukul29.gmail.com already installed in /usr/share/gnome-shell/extensions/legacyschemeautoswitcher@joshimukul29.gmail.com. /usr/share/gnome-shell/extensions/legacyschemeautoswitcher@joshimukul29.gmail.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension light-style@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/light-style@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/light-style@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension native-window-placement@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/native-window-placement@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/native-window-placement@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension pamac-updates@manjaro.org already installed in /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org. /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension places-menu@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/places-menu@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/places-menu@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension screenshot-window-sizer@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/screenshot-window-sizer@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/screenshot-window-sizer@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension space-bar@luchrioh already installed in /usr/share/gnome-shell/extensions/space-bar@luchrioh. /usr/share/gnome-shell/extensions/space-bar@luchrioh will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension status-icons@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/status-icons@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/status-icons@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension system-monitor@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/system-monitor@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/system-monitor@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension user-theme@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/user-theme@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/user-theme@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension window-list@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/window-list@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/window-list@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension windowsNavigator@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/windowsNavigator@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/windowsNavigator@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Extension workspace-indicator@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/workspace-indicator@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/workspace-indicator@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 17:44:42 marc-tobefilledbyoem gnome-shell[708]: Failed to parse saved session file: Failed to open file “/var/lib/gdm/.config/mutter/sessions/10d1ae61d61ed848a175369587925669600000006960000.ms”: No such file or directory
Jul 28 17:44:43 marc-tobefilledbyoem gsd-sharing[813]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-sharing[813]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-sharing[813]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-wacom[850]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-wacom[850]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-wacom[850]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-keyboard[833]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-keyboard[833]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-keyboard[833]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem polkitd[594]: Registered Authentication Agent for unix-session:1 (system bus name :1.20 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_PH.UTF-8)
Jul 28 17:44:43 marc-tobefilledbyoem gsd-color[826]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-color[826]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-color[826]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gnome-shell[708]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
Jul 28 17:44:43 marc-tobefilledbyoem gnome-shell[708]: Will monitor session 1
Jul 28 17:44:43 marc-tobefilledbyoem gsd-smartcard[847]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-smartcard[847]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-smartcard[847]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-sound[873]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-sound[873]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-sound[873]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-a11y-settin[878]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-a11y-settin[878]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-a11y-settin[878]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.freedesktop.portal.IBus' requested by ':1.23' (uid=120 pid=821 comm="ibus-daemon --panel disable")
Jul 28 17:44:43 marc-tobefilledbyoem gsd-housekeepin[901]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-housekeepin[901]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-housekeepin[901]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-usb-protect[822]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-datetime[861]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-datetime[861]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-datetime[861]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-usb-protect[822]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-usb-protect[822]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.21' (uid=120 pid=901 comm="/usr/lib/gsd-housekeeping")
Jul 28 17:44:43 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Successfully activated service 'org.gnome.Shell.Notifications'
Jul 28 17:44:43 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Jul 28 17:44:43 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.gnome.ScreenSaver' requested by ':1.11' (uid=120 pid=822 comm="/usr/lib/gsd-usb-protection")
Jul 28 17:44:43 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.10' (uid=120 pid=813 comm="/usr/lib/gsd-sharing")
Jul 28 17:44:43 marc-tobefilledbyoem gsd-media-keys[865]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-sharing[813]: Failed to handle service change: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Jul 28 17:44:43 marc-tobefilledbyoem gsd-media-keys[865]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-media-keys[865]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Successfully activated service 'org.freedesktop.portal.IBus'
Jul 28 17:44:43 marc-tobefilledbyoem gsd-power[915]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-power[915]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem gsd-power[915]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:43 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Successfully activated service 'org.gnome.ScreenSaver'
Jul 28 17:44:43 marc-tobefilledbyoem gsd-usb-protect[822]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
Jul 28 17:44:44 marc-tobefilledbyoem wpa_supplicant[1057]: Successfully initialized wpa_supplicant
Jul 28 17:44:44 marc-tobefilledbyoem geoclue[1032]: Failed to connect to avahi service: Daemon not running
Jul 28 17:44:44 marc-tobefilledbyoem gnome-shell[708]: Registering session with GDM
Jul 28 17:44:44 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Successfully activated service 'org.gnome.Shell.Screencast'
Jul 28 17:44:45 marc-tobefilledbyoem wireplumber[1022]: spa.bluez5: BlueZ system service is not available
Jul 28 17:44:45 marc-tobefilledbyoem wireplumber[1022]: wp-device: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
Jul 28 17:44:45 marc-tobefilledbyoem wireplumber[1022]: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
Jul 28 17:44:45 marc-tobefilledbyoem wireplumber[1022]: wp-pw-obj-mixin: <WpNode:0x56486ebe03c0> ignoring set_param on already destroyed objects
Jul 28 17:44:45 marc-tobefilledbyoem gsd-media-keys[865]: Unable to get default sink
Jul 28 17:44:45 marc-tobefilledbyoem gsd-xsettings[886]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:45 marc-tobefilledbyoem gsd-xsettings[886]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:45 marc-tobefilledbyoem gsd-xsettings[886]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:45 marc-tobefilledbyoem gsd-media-keys[865]: Failed to grab accelerator for keybinding settings:hibernate
Jul 28 17:44:45 marc-tobefilledbyoem gsd-media-keys[865]: Failed to grab accelerator for keybinding settings:playback-repeat
Jul 28 17:44:45 marc-tobefilledbyoem gnome-session-binary[696]: Entering running state
Jul 28 17:44:45 marc-tobefilledbyoem gsd-media-keys[865]: Unable to get default source
Jul 28 17:44:45 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.freedesktop.portal.IBus' requested by ':1.39' (uid=120 pid=1092 comm="ibus-daemon --panel disable -r --xim")
Jul 28 17:44:45 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Successfully activated service 'org.freedesktop.portal.IBus'
Jul 28 17:44:45 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.freedesktop.portal.Desktop' requested by ':1.43' (uid=120 pid=1087 comm="/usr/lib/mutter-x11-frames")
Jul 28 17:44:45 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.freedesktop.portal.Documents' requested by ':1.44' (uid=120 pid=1149 comm="/usr/lib/xdg-desktop-portal")
Jul 28 17:44:45 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Successfully activated service 'org.freedesktop.portal.Documents'
Jul 28 17:44:45 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.freedesktop.impl.portal.desktop.gnome' requested by ':1.44' (uid=120 pid=1149 comm="/usr/lib/xdg-desktop-portal")
Jul 28 17:44:45 marc-tobefilledbyoem xdg-desktop-por[1167]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:45 marc-tobefilledbyoem xdg-desktop-por[1167]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:45 marc-tobefilledbyoem xdg-desktop-por[1167]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:46 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.gnome.Settings.GlobalShortcutsProvider' requested by ':1.46' (uid=120 pid=1167 comm="/usr/lib/xdg-desktop-portal-gnome")
Jul 28 17:44:46 marc-tobefilledbyoem gnome-control-c[1182]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:46 marc-tobefilledbyoem gnome-control-c[1182]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:46 marc-tobefilledbyoem gnome-control-c[1182]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:46 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Successfully activated service 'org.gnome.Settings.GlobalShortcutsProvider'
Jul 28 17:44:49 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.desktop.gnome'
Jul 28 17:44:49 marc-tobefilledbyoem xdg-desktop-por[1149]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:49 marc-tobefilledbyoem xdg-desktop-por[1149]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:49 marc-tobefilledbyoem xdg-desktop-por[1149]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:49 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.freedesktop.impl.portal.desktop.gtk' requested by ':1.44' (uid=120 pid=1149 comm="/usr/lib/xdg-desktop-portal")
Jul 28 17:44:49 marc-tobefilledbyoem xdg-desktop-por[1193]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:49 marc-tobefilledbyoem xdg-desktop-por[1193]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:49 marc-tobefilledbyoem xdg-desktop-por[1193]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:44:50 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.desktop.gtk'
Jul 28 17:44:50 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.freedesktop.secrets' requested by ':1.44' (uid=120 pid=1149 comm="/usr/lib/xdg-desktop-portal")
Jul 28 17:44:50 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[1202]: gnome-keyring-daemon: no process capabilities, insecure memory might get used
Jul 28 17:44:50 marc-tobefilledbyoem gnome-keyring-daemon[1203]: The Secret Service was already initialized
Jul 28 17:44:50 marc-tobefilledbyoem gnome-keyring-d[1203]: The Secret Service was already initialized
Jul 28 17:44:50 marc-tobefilledbyoem gnome-keyring-daemon[1202]: discover_other_daemon: 1
Jul 28 17:45:10 marc-tobefilledbyoem mutter-x11-fram[1087]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:45:10 marc-tobefilledbyoem mutter-x11-fram[1087]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:45:10 marc-tobefilledbyoem mutter-x11-fram[1087]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 17:45:12 marc-tobefilledbyoem gdm-password][1217]: gkr-pam: unable to locate daemon control file
Jul 28 17:45:13 marc-tobefilledbyoem (systemd)[1227]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[marca] ruser=[<unknown>] rhost=[<unknown>]
Jul 28 17:45:13 marc-tobefilledbyoem gsd-media-keys[865]: Unable to get default sink
Jul 28 17:45:14 marc-tobefilledbyoem gnome-session-binary[1305]: WARNING: Desktop file /home/marca/.config/autostart/manjaro-app-folder-settings.desktop for application manjaro-app-folder-settings.desktop could not be parsed or references a missing TryExec binary
Jul 28 17:45:14 marc-tobefilledbyoem gnome-keyring-daemon[1239]: The PKCS#11 component was already initialized
Jul 28 17:45:14 marc-tobefilledbyoem gnome-keyring-d[1239]: The PKCS#11 component was already initialized
Jul 28 17:45:14 marc-tobefilledbyoem gnome-keyring-daemon[1319]: discover_other_daemon: 1
Jul 28 17:45:14 marc-tobefilledbyoem gnome-keyring-daemon[1239]: The Secret Service was already initialized
Jul 28 17:45:14 marc-tobefilledbyoem gnome-keyring-d[1239]: The Secret Service was already initialized
Jul 28 17:45:14 marc-tobefilledbyoem gnome-keyring-daemon[1321]: discover_other_daemon: 1
Jul 28 17:45:14 marc-tobefilledbyoem systemd[1227]: app-gnome-gnome\x2dkeyring\x2dpkcs11-1312.scope: Failed to add PIDs to scope's control group: No such process
Jul 28 17:45:14 marc-tobefilledbyoem systemd[1227]: app-gnome-gnome\x2dkeyring\x2dpkcs11-1312.scope: Failed with result 'resources'.
Jul 28 17:45:14 marc-tobefilledbyoem systemd[1227]: Failed to start Application launched by gnome-session-binary.
Jul 28 17:45:14 marc-tobefilledbyoem systemd[1227]: app-gnome-gnome\x2dkeyring\x2dsecrets-1314.scope: No PIDs left to attach to the scope's control group, refusing.
Jul 28 17:45:14 marc-tobefilledbyoem systemd[1227]: app-gnome-gnome\x2dkeyring\x2dsecrets-1314.scope: Failed with result 'resources'.
Jul 28 17:45:14 marc-tobefilledbyoem gnome-shell[1323]: Running GNOME Shell (using mutter 48.4) as a Wayland display server
Jul 28 17:45:15 marc-tobefilledbyoem gnome-shell[1323]: Thread 'KMS thread' will be using high priority scheduling
Jul 28 17:45:15 marc-tobefilledbyoem gnome-shell[1323]: Added device '/dev/dri/card0' (simpledrm) using atomic mode setting.
Jul 28 17:45:15 marc-tobefilledbyoem gnome-shell[1323]: Failed to initialize accelerated iGPU/dGPU framebuffer sharing: Not hardware accelerated
Jul 28 17:45:15 marc-tobefilledbyoem gnome-shell[1323]: Created gbm renderer for '/dev/dri/card0'
Jul 28 17:45:15 marc-tobefilledbyoem gnome-shell[1323]: Integrated GPU /dev/dri/card0 selected as primary
Jul 28 17:45:15 marc-tobefilledbyoem xdg-desktop-por[1149]: Failed to create secret proxy: Error calling StartServiceByName for org.freedesktop.secrets: Timeout was reached
Jul 28 17:45:15 marc-tobefilledbyoem xdg-desktop-por[1149]: No skeleton to export
Jul 28 17:45:15 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[1202]: discover_other_daemon: 1
Jul 28 17:45:15 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Successfully activated service 'org.freedesktop.portal.Desktop'
Jul 28 17:45:15 marc-tobefilledbyoem gnome-shell[1323]: Using public X11 display :0, (using :1 for managed services)
Jul 28 17:45:15 marc-tobefilledbyoem gnome-shell[1323]: Using Wayland display name 'wayland-0'
Jul 28 17:45:15 marc-tobefilledbyoem gnome-shell[1323]: Couldn't find suitable cursor plane format for /dev/dri/card0, disabling HW cursor
Jul 28 17:45:17 marc-tobefilledbyoem gnome-shell[1323]: Unset XDG_SESSION_ID, getCurrentSessionProxy() called outside a user session. Asking logind directly.
Jul 28 17:45:17 marc-tobefilledbyoem systemd[1227]: GNOME session X11 services is inactive.
Jul 28 17:45:17 marc-tobefilledbyoem systemd[1227]: Dependency failed for GNOME XSettings service.
Jul 28 17:45:17 marc-tobefilledbyoem systemd[1227]: org.gnome.SettingsDaemon.XSettings.service: Job org.gnome.SettingsDaemon.XSettings.service/start failed with result 'dependency'.
Jul 28 17:45:17 marc-tobefilledbyoem systemd[1227]: gnome-session-x11-services-ready.target: Job gnome-session-x11-services-ready.target/verify-active failed with result 'dependency'.
Jul 28 17:45:18 marc-tobefilledbyoem gnome-session-binary[1305]: Entering running state
Jul 28 17:45:18 marc-tobefilledbyoem udisksd[1551]: udisks daemon version 2.10.1 starting
Jul 28 17:45:18 marc-tobefilledbyoem goa-daemon[1608]: goa-daemon version 3.54.4 starting
Jul 28 17:45:19 marc-tobefilledbyoem udisksd[1551]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jul 28 17:45:19 marc-tobefilledbyoem gnome-shell[1323]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
Jul 28 17:45:19 marc-tobefilledbyoem gnome-shell[1323]: Will monitor session 3
Jul 28 17:45:19 marc-tobefilledbyoem gsd-usb-protect[1487]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
Jul 28 17:45:19 marc-tobefilledbyoem polkitd[594]: Registered Authentication Agent for unix-session:3 (system bus name :1.80 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_PH.UTF-8)
Jul 28 17:45:21 marc-tobefilledbyoem gnome-shell[1323]: loading default theme (Adwaita)
Jul 28 17:45:21 marc-tobefilledbyoem wireplumber[1759]: spa.bluez5: BlueZ system service is not available
Jul 28 17:45:21 marc-tobefilledbyoem wireplumber[1759]: wp-device: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
Jul 28 17:45:21 marc-tobefilledbyoem wireplumber[1759]: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
Jul 28 17:45:22 marc-tobefilledbyoem gnome-shell[1323]: GNOME Shell started at Mon Jul 28 2025 17:45:17 GMT+0800 (Philippine Standard Time)
Jul 28 17:45:22 marc-tobefilledbyoem gnome-shell[1323]: Registering session with GDM
Jul 28 17:45:22 marc-tobefilledbyoem gnome-shell[708]: Connection to xwayland lost
Jul 28 17:45:22 marc-tobefilledbyoem gnome-shell[708]: Xwayland terminated, exiting since it was mandatory
Jul 28 17:45:22 marc-tobefilledbyoem gnome-shell[708]: JS ERROR: Gio.IOErrorEnum: Xwayland exited unexpectedly
@resource:///org/gnome/shell/ui/init.js:21:20
Jul 28 17:45:22 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[695]: dbus-daemon[695]: [session uid=120 pid=695 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.10' (uid=120 pid=813 comm="/usr/lib/gsd-sharing")
Jul 28 17:45:22 marc-tobefilledbyoem gnome-shell[708]: Execution of main.js threw exception: Module resource:///org/gnome/shell/ui/init.js threw an exception
Jul 28 17:45:22 marc-tobefilledbyoem xdg-document-po[1155]: Error releasing name org.freedesktop.portal.Documents: The connection is closed
Jul 28 17:45:22 marc-tobefilledbyoem systemd[1]: session-1.scope: Killing process 737 (gnome-s:disk$0) with signal SIGKILL.
Jul 28 17:45:22 marc-tobefilledbyoem systemd[1]: session-1.scope: Killing process 1139 (mutter-:disk$0) with signal SIGKILL.
Jul 28 17:45:22 marc-tobefilledbyoem gdm[653]: Gdm: Child process -688 was already dead.
Jul 28 17:45:22 marc-tobefilledbyoem systemd[1]: session-1.scope: Consumed 24.595s CPU time, 729.2M memory peak.
Jul 28 17:45:22 marc-tobefilledbyoem polkitd[594]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.20, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_PH.UTF-8) (disconnected from bus)
Jul 28 17:45:23 marc-tobefilledbyoem gsd-media-keys[1454]: Failed to grab accelerator for keybinding settings:playback-repeat
Jul 28 17:45:23 marc-tobefilledbyoem gsd-media-keys[1454]: Failed to grab accelerator for keybinding settings:hibernate
Jul 28 17:45:33 marc-tobefilledbyoem systemd[1]: user-120.slice: Consumed 26.287s CPU time, 819.2M memory peak.
Jul 28 17:45:35 marc-tobefilledbyoem kgx[1874]: Vulkan: Loader Message: setup_loader_term_phys_devs: Failed to detect any valid GPUs in the current config
Jul 28 17:45:35 marc-tobefilledbyoem kgx[1874]: vkEnumeratePhysicalDevices(): Initialization of an object could not be completed for implementation-specific reasons. (VK_ERROR_INITIALIZATION_FAILED) (-3)
Jul 28 17:45:36 marc-tobefilledbyoem gnome-shell[1323]: Invalid sequence for VSYNC frame info
Jul 28 17:45:44 marc-tobefilledbyoem geoclue[1032]: Service not used for 60 seconds. Shutting down..
Jul 28 17:45:51 marc-tobefilledbyoem gnome-shell[1323]: updates_checker.vala:59: check updates
Jul 28 17:46:06 marc-tobefilledbyoem gsd-xsettings[2417]: Failed to get current UI scaling factor: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Destination does not exist
Jul 28 17:46:09 marc-tobefilledbyoem sudo[2542]: marca : a password is required ; TTY=pts/0 ; PWD=/home/marca ; USER=root ; COMMAND=/sbin/file -s /dev/sda2
Jul 28 17:46:09 marc-tobefilledbyoem sudo[2544]: marca : a password is required ; TTY=pts/0 ; PWD=/home/marca ; USER=root ; COMMAND=/sbin/file -s /dev/sdb1
Jul 28 17:46:09 marc-tobefilledbyoem polkitd[594]: Registered Authentication Agent for unix-process:2554:10960 (system bus name :1.148 [/sbin/flatpak list], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
Jul 28 17:46:09 marc-tobefilledbyoem polkitd[594]: Unregistered Authentication Agent for unix-process:2554:10960 (system bus name :1.148, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
> 0000:00:01.0 (0300:1002:9874) Display controller ATI Technologies Inc:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:01:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2023.09.12 true PCI
> Installed PCI configs:
Thanks for the reply sir!
