is fast boot disabled in windows? if not, disable it, and test
yes sir fast boot was disabled
and is secure boot disabled in bios?
are you now running with nomodeset parameter?
post output from:
mhwd -li
and try this command, and post output from it:
sudo modprobe -v amdgpu
- yes sir secure boot is disable
- yes i am running rn at nomodeset
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2024.05.06 true PCI
[sudo] password for marca:
insmod /lib/modules/6.6.99-1-MANJARO/kernel/drivers/gpu/drm/amd/amdgpu/amdgpu.ko.zst
modprobe: ERROR: could not insert 'amdgpu': Invalid argument
so boot without the nomodest parameter, so that you get stuck, we need logs without the nomodeset parameter… then boot with the parameter, and provide them:
journalctl -b-1 -p5 --no-pager
journalctl -b-1 --no-pager | grep amdgpu
i do what you says, boot without the parameter and then boot with parameter
the output is: journalctl -b-1 -p5 --no-pager
Jul 28 23:07:58 marc-tobefilledbyoem kernel: Linux version 6.6.99-1-MANJARO (builduser@pkrvmq0rgcvqdmg) (gcc (GCC) 15.1.1 20250425, GNU ld (GNU Binutils) 2.44.0) #1 SMP PREEMPT_DYNAMIC Thu Jul 17 22:09:32 UTC 2025
Jul 28 23:07:58 marc-tobefilledbyoem kernel: ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20230628/tbfadt-615)
Jul 28 23:07:58 marc-tobefilledbyoem kernel: Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64 root=UUID=2049e622-3a95-4ad5-a931-fb2b92446d67 rw rootflags=subvol=@ quiet splash apparmor=1 security=apparmor udev.log_priority=3
Jul 28 23:07:58 marc-tobefilledbyoem kernel: Unknown kernel command line parameters "splash BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64", will be passed to user space.
Jul 28 23:07:58 marc-tobefilledbyoem kernel: random: crng init done
Jul 28 23:07:58 marc-tobefilledbyoem kernel: audit: type=2000 audit(1753715263.169:1): state=initialized audit_enabled=0 res=1
Jul 28 23:07:58 marc-tobefilledbyoem kernel: SCSI subsystem initialized
Jul 28 23:07:58 marc-tobefilledbyoem kernel: VFS: Disk quotas dquot_6.6.0
Jul 28 23:07:58 marc-tobefilledbyoem kernel: Initialise system trusted keyrings
Jul 28 23:07:58 marc-tobefilledbyoem kernel: Key type blacklist registered
Jul 28 23:07:58 marc-tobefilledbyoem kernel: integrity: Platform Keyring initialized
Jul 28 23:07:58 marc-tobefilledbyoem kernel: integrity: Machine keyring initialized
Jul 28 23:07:58 marc-tobefilledbyoem kernel: Key type asymmetric registered
Jul 28 23:07:58 marc-tobefilledbyoem kernel: Asymmetric key parser 'x509' registered
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
Jul 28 23:07:58 marc-tobefilledbyoem kernel: Loading compiled-in X.509 certificates
Jul 28 23:07:58 marc-tobefilledbyoem kernel: Loaded X.509 cert 'Build time autogenerated kernel key: df3a18165e14ebd53627bd0791dff3f643628655'
Jul 28 23:07:58 marc-tobefilledbyoem kernel: Key type .fscrypt registered
Jul 28 23:07:58 marc-tobefilledbyoem kernel: Key type fscrypt-provisioning registered
Jul 28 23:07:58 marc-tobefilledbyoem kernel: scsi 0:0:0:0: Direct-Access ATA KINGSTON SA400S3 1A0 PQ: 0 ANSI: 5
Jul 28 23:07:58 marc-tobefilledbyoem kernel: sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
Jul 28 23:07:58 marc-tobefilledbyoem kernel: sd 0:0:0:0: [sda] Write Protect is off
Jul 28 23:07:58 marc-tobefilledbyoem kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 28 23:07:58 marc-tobefilledbyoem kernel: scsi 1:0:0:0: Direct-Access ATA SAMSUNG HD322HJ 1118 PQ: 0 ANSI: 5
Jul 28 23:07:58 marc-tobefilledbyoem kernel: sd 1:0:0:0: [sdb] 625142448 512-byte logical blocks: (320 GB/298 GiB)
Jul 28 23:07:58 marc-tobefilledbyoem kernel: sd 1:0:0:0: [sdb] Write Protect is off
Jul 28 23:07:58 marc-tobefilledbyoem kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 28 23:07:58 marc-tobefilledbyoem kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jul 28 23:07:58 marc-tobefilledbyoem kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Jul 28 23:07:58 marc-tobefilledbyoem kernel: [drm] Unsupported Connector type:5!
Jul 28 23:07:58 marc-tobefilledbyoem kernel: systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Jul 28 23:07:58 marc-tobefilledbyoem kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jul 28 23:07:58 marc-tobefilledbyoem kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Jul 28 23:07:58 marc-tobefilledbyoem systemd-vconsole-setup[306]: All allocated VCs are currently busy, skipping initialization of font and keyboard settings.
Jul 28 23:07:59 marc-tobefilledbyoem kernel: Failed to reset ACP
Jul 28 23:07:59 marc-tobefilledbyoem kernel: acp_audio_dma acp_audio_dma.1.auto: ACP Init failed status:-110
Jul 28 23:07:59 marc-tobefilledbyoem kernel: acp_audio_dma: probe of acp_audio_dma.1.auto failed with error -110
Jul 28 23:07:59 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753715279.851:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=447 comm="apparmor_parser"
Jul 28 23:07:59 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753715279.855:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=450 comm="apparmor_parser"
Jul 28 23:07:59 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753715279.855:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=448 comm="apparmor_parser"
Jul 28 23:07:59 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753715279.855:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=449 comm="apparmor_parser"
Jul 28 23:07:59 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753715279.861:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=456 comm="apparmor_parser"
Jul 28 23:07:59 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753715279.865:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=454 comm="apparmor_parser"
Jul 28 23:07:59 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753715279.871:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="busybox" pid=458 comm="apparmor_parser"
Jul 28 23:07:59 marc-tobefilledbyoem systemd-vconsole-setup[440]: All allocated VCs are currently busy, skipping initialization of font and keyboard settings.
Jul 28 23:07:59 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753715279.878:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=460 comm="apparmor_parser"
Jul 28 23:07:59 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753715279.881:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=457 comm="apparmor_parser"
Jul 28 23:07:59 marc-tobefilledbyoem kernel: audit: type=1400 audit(1753715279.881:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-checkns" pid=461 comm="apparmor_parser"
Jul 28 23:08:02 marc-tobefilledbyoem systemd[1]: shadow.timer: Not using persistent file timestamp Tue 2025-07-29 02:35:07 PST as it is in the future.
Jul 28 23:08:02 marc-tobefilledbyoem polkitd[623]: Loading rules from directory /etc/polkit-1/rules.d
Jul 28 23:08:02 marc-tobefilledbyoem polkitd[623]: Loading rules from directory /run/polkit-1/rules.d
Jul 28 23:08:02 marc-tobefilledbyoem polkitd[623]: Error opening rules directory: Error opening directory “/run/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
Jul 28 23:08:02 marc-tobefilledbyoem polkitd[623]: Loading rules from directory /usr/local/share/polkit-1/rules.d
Jul 28 23:08:02 marc-tobefilledbyoem polkitd[623]: Error opening rules directory: Error opening directory “/usr/local/share/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
Jul 28 23:08:02 marc-tobefilledbyoem polkitd[623]: Loading rules from directory /usr/share/polkit-1/rules.d
Jul 28 23:08:02 marc-tobefilledbyoem polkitd[623]: Finished loading, compiling and executing 12 rules
Jul 28 23:08:02 marc-tobefilledbyoem polkitd[623]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jul 28 23:08:02 marc-tobefilledbyoem ModemManager[666]: <msg> ModemManager (version 1.24.0-2) starting in system bus...
Jul 28 23:08:03 marc-tobefilledbyoem dbus-broker-launch[619]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Jul 28 23:08:03 marc-tobefilledbyoem (systemd)[703]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[gdm] ruser=[<unknown>] rhost=[<unknown>]
Jul 28 23:08:04 marc-tobefilledbyoem gsettings[724]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:04 marc-tobefilledbyoem gsettings[724]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:04 marc-tobefilledbyoem gsettings[724]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:04 marc-tobefilledbyoem gnome-session-b[723]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:04 marc-tobefilledbyoem gnome-session-b[723]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:04 marc-tobefilledbyoem gnome-session-b[723]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:04 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.2' (uid=120 pid=723 comm="/usr/lib/gnome-session-binary --autostart /usr/sha")
Jul 28 23:08:04 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Jul 28 23:08:04 marc-tobefilledbyoem gnome-session-binary[723]: WARNING: Could not check if unit gnome-session-wayland@gnome.target is active: Error calling StartServiceByName for org.freedesktop.systemd1: Process org.freedesktop.systemd1 exited with status 1
Jul 28 23:08:04 marc-tobefilledbyoem dbus-broker-launch[619]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Jul 28 23:08:04 marc-tobefilledbyoem gnome-session-binary[723]: WARNING: Desktop file /usr/share/gdm/greeter/autostart/orca-autostart.desktop for application orca-autostart.desktop could not be parsed or references a missing TryExec binary
Jul 28 23:08:05 marc-tobefilledbyoem gnome-shell[736]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:05 marc-tobefilledbyoem gnome-shell[736]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:05 marc-tobefilledbyoem gnome-shell[736]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:05 marc-tobefilledbyoem gnome-shell[736]: Running GNOME Shell (using mutter 48.4) as a Wayland display server
Jul 28 23:08:06 marc-tobefilledbyoem gnome-shell[736]: Thread 'KMS thread' will be using high priority scheduling
Jul 28 23:08:06 marc-tobefilledbyoem gnome-shell[736]: Device '/dev/dri/card1' prefers shadow buffer
Jul 28 23:08:06 marc-tobefilledbyoem gnome-shell[736]: Added device '/dev/dri/card1' (amdgpu) using atomic mode setting.
Jul 28 23:08:06 marc-tobefilledbyoem gnome-shell[736]: Created gbm renderer for '/dev/dri/card1'
Jul 28 23:08:06 marc-tobefilledbyoem gnome-shell[736]: Boot VGA GPU /dev/dri/card1 selected as primary
Jul 28 23:08:06 marc-tobefilledbyoem gnome-shell[736]: Obtained a high priority EGL context
Jul 28 23:08:06 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=120 pid=736 comm="/usr/bin/gnome-shell")
Jul 28 23:08:06 marc-tobefilledbyoem at-spi-bus-laun[779]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:06 marc-tobefilledbyoem at-spi-bus-laun[779]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:06 marc-tobefilledbyoem at-spi-bus-laun[779]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:06 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Successfully activated service 'org.a11y.Bus'
Jul 28 23:08:06 marc-tobefilledbyoem gnome-shell[736]: Using public X11 display :1024, (using :1025 for managed services)
Jul 28 23:08:06 marc-tobefilledbyoem gnome-shell[736]: Using Wayland display name 'wayland-0'
Jul 28 23:08:06 marc-tobefilledbyoem ModemManager[666]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:02.5/0000:01:00.0': not supported by any plugin
Jul 28 23:08:07 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[785]: dbus-daemon[785]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=120 pid=736 comm="/usr/bin/gnome-shell")
Jul 28 23:08:07 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[785]: dbus-daemon[785]: Successfully activated service 'org.a11y.atspi.Registry'
Jul 28 23:08:08 marc-tobefilledbyoem dbus-broker-launch[619]: Activation request for 'org.freedesktop.Avahi' failed: The systemd unit 'dbus-org.freedesktop.Avahi.service' could not be found.
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Unset XDG_SESSION_ID, getCurrentSessionProxy() called outside a user session. Asking logind directly.
Jul 28 23:08:08 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.gnome.Shell.Screencast' requested by ':1.3' (uid=120 pid=736 comm="/usr/bin/gnome-shell")
Jul 28 23:08:08 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.freedesktop.impl.portal.PermissionStore' requested by ':1.3' (uid=120 pid=736 comm="/usr/bin/gnome-shell")
Jul 28 23:08:08 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
Jul 28 23:08:08 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=120 pid=736 comm="/usr/bin/gnome-shell")
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension appindicatorsupport@rgcjonas.gmail.com already installed in /usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com. /usr/share/gnome-shell/extensions/appindicatorsupport@rgcjonas.gmail.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension apps-menu@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/apps-menu@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/apps-menu@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension arcmenu@arcmenu.com already installed in /usr/share/gnome-shell/extensions/arcmenu@arcmenu.com. /usr/share/gnome-shell/extensions/arcmenu@arcmenu.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension auto-move-windows@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/auto-move-windows@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/auto-move-windows@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension dash-to-dock@micxgx.gmail.com already installed in /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com. /usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension dash-to-panel@jderose9.github.com already installed in /usr/share/gnome-shell/extensions/dash-to-panel@jderose9.github.com. /usr/share/gnome-shell/extensions/dash-to-panel@jderose9.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension drive-menu@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/drive-menu@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/drive-menu@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension forge@jmmaranan.com already installed in /usr/share/gnome-shell/extensions/forge@jmmaranan.com. /usr/share/gnome-shell/extensions/forge@jmmaranan.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension gnome-ui-tune@itstime.tech already installed in /usr/share/gnome-shell/extensions/gnome-ui-tune@itstime.tech. /usr/share/gnome-shell/extensions/gnome-ui-tune@itstime.tech will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension gsconnect@andyholmes.github.io already installed in /usr/share/gnome-shell/extensions/gsconnect@andyholmes.github.io. /usr/share/gnome-shell/extensions/gsconnect@andyholmes.github.io will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension gtk4-ding@smedius.gitlab.com already installed in /usr/share/gnome-shell/extensions/gtk4-ding@smedius.gitlab.com. /usr/share/gnome-shell/extensions/gtk4-ding@smedius.gitlab.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension launch-new-instance@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/launch-new-instance@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/launch-new-instance@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension legacyschemeautoswitcher@joshimukul29.gmail.com already installed in /usr/share/gnome-shell/extensions/legacyschemeautoswitcher@joshimukul29.gmail.com. /usr/share/gnome-shell/extensions/legacyschemeautoswitcher@joshimukul29.gmail.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension light-style@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/light-style@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/light-style@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension native-window-placement@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/native-window-placement@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/native-window-placement@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension pamac-updates@manjaro.org already installed in /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org. /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension places-menu@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/places-menu@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/places-menu@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension screenshot-window-sizer@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/screenshot-window-sizer@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/screenshot-window-sizer@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension space-bar@luchrioh already installed in /usr/share/gnome-shell/extensions/space-bar@luchrioh. /usr/share/gnome-shell/extensions/space-bar@luchrioh will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension status-icons@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/status-icons@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/status-icons@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension system-monitor@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/system-monitor@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/system-monitor@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension user-theme@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/user-theme@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/user-theme@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension window-list@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/window-list@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/window-list@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension windowsNavigator@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/windowsNavigator@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/windowsNavigator@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Extension workspace-indicator@gnome-shell-extensions.gcampax.github.com already installed in /usr/share/gnome-shell/extensions/workspace-indicator@gnome-shell-extensions.gcampax.github.com. /usr/share/gnome-shell/extensions/workspace-indicator@gnome-shell-extensions.gcampax.github.com will not be loaded
Jul 28 23:08:08 marc-tobefilledbyoem gnome-shell[736]: Failed to parse saved session file: Failed to open file “/var/lib/gdm/.config/mutter/sessions/10f4b044be46d41b08175371528482311100000007230000.ms”: No such file or directory
Jul 28 23:08:09 marc-tobefilledbyoem gsd-sharing[845]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-sharing[845]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-sharing[845]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Successfully activated service 'org.gnome.Shell.Notifications'
Jul 28 23:08:09 marc-tobefilledbyoem gsd-keyboard[857]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-keyboard[857]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.freedesktop.portal.IBus' requested by ':1.14' (uid=120 pid=850 comm="ibus-daemon --panel disable")
Jul 28 23:08:09 marc-tobefilledbyoem gsd-keyboard[857]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-color[853]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-color[853]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-color[853]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Successfully activated service 'org.freedesktop.portal.IBus'
Jul 28 23:08:09 marc-tobefilledbyoem gsd-wacom[883]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-wacom[883]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-wacom[883]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-usb-protect[849]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-usb-protect[849]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-usb-protect[849]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-datetime[888]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-smartcard[877]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-smartcard[877]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-smartcard[877]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-datetime[888]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-datetime[888]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.gnome.ScreenSaver' requested by ':1.10' (uid=120 pid=849 comm="/usr/lib/gsd-usb-protection")
Jul 28 23:08:09 marc-tobefilledbyoem gsd-a11y-settin[934]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-a11y-settin[934]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-a11y-settin[934]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.9' (uid=120 pid=845 comm="/usr/lib/gsd-sharing")
Jul 28 23:08:09 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Jul 28 23:08:09 marc-tobefilledbyoem gsd-media-keys[892]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-media-keys[892]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-media-keys[892]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-sound[925]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-sharing[845]: Failed to handle service change: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Jul 28 23:08:09 marc-tobefilledbyoem gsd-housekeepin[949]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-housekeepin[949]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-housekeepin[949]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-sound[925]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-sound[925]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.freedesktop.systemd1' requested by ':1.25' (uid=120 pid=949 comm="/usr/lib/gsd-housekeeping")
Jul 28 23:08:09 marc-tobefilledbyoem gnome-shell[736]: Will monitor session 1
Jul 28 23:08:09 marc-tobefilledbyoem gnome-shell[736]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
Jul 28 23:08:09 marc-tobefilledbyoem gsd-power[954]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-power[954]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gsd-power[954]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem polkitd[623]: Registered Authentication Agent for unix-session:1 (system bus name :1.19 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_PH.UTF-8)
Jul 28 23:08:09 marc-tobefilledbyoem gjs[809]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gjs[809]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem gjs[809]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:09 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Successfully activated service 'org.gnome.ScreenSaver'
Jul 28 23:08:09 marc-tobefilledbyoem gsd-usb-protect[849]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
Jul 28 23:08:10 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Successfully activated service 'org.gnome.Shell.Screencast'
Jul 28 23:08:10 marc-tobefilledbyoem wpa_supplicant[1100]: Successfully initialized wpa_supplicant
Jul 28 23:08:10 marc-tobefilledbyoem geoclue[1079]: Failed to connect to avahi service: Daemon not running
Jul 28 23:08:10 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.freedesktop.portal.IBus' requested by ':1.37' (uid=120 pid=1106 comm="ibus-daemon --panel disable -r --xim")
Jul 28 23:08:11 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Successfully activated service 'org.freedesktop.portal.IBus'
Jul 28 23:08:11 marc-tobefilledbyoem gsd-media-keys[892]: Failed to grab accelerator for keybinding settings:playback-repeat
Jul 28 23:08:11 marc-tobefilledbyoem gsd-media-keys[892]: Failed to grab accelerator for keybinding settings:hibernate
Jul 28 23:08:11 marc-tobefilledbyoem gsd-xsettings[942]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:11 marc-tobefilledbyoem gsd-xsettings[942]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:11 marc-tobefilledbyoem gsd-xsettings[942]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:11 marc-tobefilledbyoem gnome-session-binary[723]: Entering running state
Jul 28 23:08:11 marc-tobefilledbyoem wireplumber[1065]: spa.bluez5: BlueZ system service is not available
Jul 28 23:08:11 marc-tobefilledbyoem wireplumber[1065]: wp-device: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
Jul 28 23:08:11 marc-tobefilledbyoem wireplumber[1065]: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
Jul 28 23:08:11 marc-tobefilledbyoem gsd-media-keys[892]: Unable to get default sink
Jul 28 23:08:11 marc-tobefilledbyoem gsd-media-keys[892]: Unable to get default source
Jul 28 23:08:11 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.freedesktop.portal.Desktop' requested by ':1.43' (uid=120 pid=1105 comm="/usr/lib/mutter-x11-frames")
Jul 28 23:08:11 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.freedesktop.portal.Documents' requested by ':1.44' (uid=120 pid=1188 comm="/usr/lib/xdg-desktop-portal")
Jul 28 23:08:11 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Successfully activated service 'org.freedesktop.portal.Documents'
Jul 28 23:08:11 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.freedesktop.impl.portal.desktop.gnome' requested by ':1.44' (uid=120 pid=1188 comm="/usr/lib/xdg-desktop-portal")
Jul 28 23:08:11 marc-tobefilledbyoem xdg-desktop-por[1209]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:11 marc-tobefilledbyoem xdg-desktop-por[1209]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:11 marc-tobefilledbyoem xdg-desktop-por[1209]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:11 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.gnome.Settings.GlobalShortcutsProvider' requested by ':1.46' (uid=120 pid=1209 comm="/usr/lib/xdg-desktop-portal-gnome")
Jul 28 23:08:12 marc-tobefilledbyoem gnome-control-c[1220]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:12 marc-tobefilledbyoem gnome-control-c[1220]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:12 marc-tobefilledbyoem gnome-control-c[1220]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:12 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Successfully activated service 'org.gnome.Settings.GlobalShortcutsProvider'
Jul 28 23:08:16 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.desktop.gnome'
Jul 28 23:08:16 marc-tobefilledbyoem xdg-desktop-por[1188]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:16 marc-tobefilledbyoem xdg-desktop-por[1188]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:16 marc-tobefilledbyoem xdg-desktop-por[1188]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:16 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.freedesktop.impl.portal.desktop.gtk' requested by ':1.44' (uid=120 pid=1188 comm="/usr/lib/xdg-desktop-portal")
Jul 28 23:08:16 marc-tobefilledbyoem xdg-desktop-por[1231]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:16 marc-tobefilledbyoem xdg-desktop-por[1231]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:16 marc-tobefilledbyoem xdg-desktop-por[1231]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:16 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Successfully activated service 'org.freedesktop.impl.portal.desktop.gtk'
Jul 28 23:08:16 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[722]: dbus-daemon[722]: [session uid=120 pid=722 pidfd=5] Activating service name='org.freedesktop.secrets' requested by ':1.44' (uid=120 pid=1188 comm="/usr/lib/xdg-desktop-portal")
Jul 28 23:08:16 marc-tobefilledbyoem /usr/lib/gdm-wayland-session[1240]: gnome-keyring-daemon: no process capabilities, insecure memory might get used
Jul 28 23:08:16 marc-tobefilledbyoem gnome-keyring-daemon[1241]: The Secret Service was already initialized
Jul 28 23:08:16 marc-tobefilledbyoem gnome-keyring-d[1241]: The Secret Service was already initialized
Jul 28 23:08:16 marc-tobefilledbyoem gnome-keyring-daemon[1240]: discover_other_daemon: 1
Jul 28 23:08:35 marc-tobefilledbyoem gnome-shell[736]: Error calling StartServiceByName for org.freedesktop.UPower.PowerProfiles: Timeout was reached
Jul 28 23:08:36 marc-tobefilledbyoem mutter-x11-fram[1105]: unable to open file '/etc/dconf/db/gdm': Failed to open file “/etc/dconf/db/gdm”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:36 marc-tobefilledbyoem mutter-x11-fram[1105]: unable to open file '/etc/dconf/db/site': Failed to open file “/etc/dconf/db/site”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:08:36 marc-tobefilledbyoem mutter-x11-fram[1105]: unable to open file '/etc/dconf/db/distro': Failed to open file “/etc/dconf/db/distro”: open() failed: No such file or directory; expect degraded performance
Jul 28 23:07:58 marc-tobefilledbyoem kernel: [drm] amdgpu kernel modesetting enabled.
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amdgpu: Virtual CRAT table created for CPU
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amdgpu: Topology: Add CPU node
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amdgpu 0000:00:01.0: amdgpu: Fetched VBIOS from VFCT
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amdgpu: ATOM BIOS: ATOMBIOSBK-AMD VER015.048.000.071
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amdgpu 0000:00:01.0: vgaarb: deactivate vga console
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amdgpu 0000:00:01.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amdgpu 0000:00:01.0: amdgpu: VRAM: 512M 0x000000F400000000 - 0x000000F41FFFFFFF (512M used)
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amdgpu 0000:00:01.0: amdgpu: GART: 1024M 0x000000FF00000000 - 0x000000FF3FFFFFFF
Jul 28 23:07:58 marc-tobefilledbyoem kernel: [drm] amdgpu: 512M of VRAM memory ready
Jul 28 23:07:58 marc-tobefilledbyoem kernel: [drm] amdgpu: 7719M of GTT memory ready.
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amdgpu: hwmgr_sw_init smu backed is smu8_smu
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amdgpu: smu version 19.13.09
Jul 28 23:07:58 marc-tobefilledbyoem kernel: kfd kfd: amdgpu: Allocated 3969056 bytes on gart
Jul 28 23:07:58 marc-tobefilledbyoem kernel: kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amdgpu: Virtual CRAT table created for GPU
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amdgpu: Topology: Add dGPU node [0x9874:0x1002]
Jul 28 23:07:58 marc-tobefilledbyoem kernel: kfd kfd: amdgpu: added device 1002:9874
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amdgpu 0000:00:01.0: amdgpu: SE 1, SH per SE 1, CU per SH 8, active_cu_number 6
Jul 28 23:07:58 marc-tobefilledbyoem kernel: [drm] Initialized amdgpu 3.54.0 20150101 for 0000:00:01.0 on minor 1
Jul 28 23:07:58 marc-tobefilledbyoem kernel: amdgpu 0000:00:01.0: [drm] Cannot find any crtc or sizes
ok, so lets try some kernel parameters, add this:
amdgpu.dc=0
update grub, reboot and see if it helped…
yo yo it finally work!!!
I added amdgpu.dc=0 in GRUB then after reboot its goods now man!
Thank you so much for helping me step-by-step, I wouldn’t have figured this out alone. Super thankful to you sir brahma ![]()
