Hello, I am new to linux and I decided to use the kde manjaro version, everything works perfectly but I have a small problem with the customization.
I would like to know if there is any alternative software to the Radeon software to configure its graphic preferences.
PS: What I really need is a graphic monitor that would allow me to increase the saturation of my screen (something I used to do before with the radeon software and catalyst)
Thanks
I do use the controls of my monitor to manipulate the saturation
Hi, I have a built-in screen, a sollution?(laptop)
Jim.B
6 September 2022 03:29
4
There is very little software that will do that. You can try vibrantLinux, but it says its for Nvidia. Its in the AUR, the command to build it is pamac build vibrantlinux .
Yes but no, it doesn’t help me, if you tell me that I have to use an nvidia card instead of amd, what’s the use?
Jim.B
6 September 2022 05:27
6
Did you install it to see if it would work?
KDE Plasma Settings > Display and Monitor > Gamma
Can help, as it can handle changes per channel for red, green and blue. Set them at 1.1 and see if that works for you …
no I don’t know how it works, when I try to launch it the program doesn’t start
increasing gamma only makes the display lighter or darker, saturation does not change
Jim.B
6 September 2022 17:16
10
Sorry it didnt work for you. This page may be helpful.
where am I supposed to change the saturation settings in the application?
does not work, I have changed several settings without success
omano
6 September 2022 18:40
15
Did you try to install vibrant-cli AUR (en) - vibrant from the AUR? if it works it seems simple to use from terminal as explained in the GitHub page GitHub - libvibrant/libvibrant: Adjust color vibrancy of X11 outputs
Useless it uses the x11 outputs and I am in wayland
Jim.B
6 September 2022 19:09
17
At this point I think its a good idea to provide system info. Please provide the output of
inxi -v7azy
Also list all the applications you have tried, as well as searches to fix the problem.
I ain’t sure whether it’s changed, but colour management for wayland is a work in progress.
$ inxi -v7azy
Kernel: 5.19.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=7c886f9b-de0e-461c-8f8e-2c0bb474300a rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_wayland vt: 2
Type: Laptop System: ASUSTeK product: ROG Strix G513QY_G513QY v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G513QY v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G513QY.318 date: 03/29/2022
ID-1: BAT0 charge: 83.9 Wh (100.0%) condition: 83.9/90.0 Wh (93.2%)
volts: 17.0 min: 15.9 model: AS3GWYF3KC GA50358 type: Li-ion
serial: <filter> status: full
RAM: total: 30.76 GiB used: 6.57 GiB (21.3%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2023 high: 2395 min/max: 1200/4889 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2394 2: 1200
3: 1915 4: 1956 5: 2394 6: 2395 7: 2394 8: 2393 9: 1916 10: 1200 11: 2394
12: 1200 13: 1916 14: 1916 15: 2394 16: 2394 bogomips: 105444
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: none empty: DP-1 bus-ID: 03:00.0
chip-ID: 1002:73df class-ID: 0380
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 07:00.0 chip-ID: 1002:1638
class-ID: 0300
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_wayland driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu,amdgpu
display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.47 5.19.1-3-MANJARO) v: 4.6
Mesa 22.1.6 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.19.1-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 3-4:2 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Local Storage: total: 953.87 GiB used: 53.12 GiB (5.6%)
model: MZVLQ1T0HBLB-00B00 size: 953.87 GiB block-size: physical: 512 B
rev: FXM7201Q temp: 32.9 C scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 53.12 GiB
(5.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 7c886f9b-de0e-461c-8f8e-2c0bb474300a
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: 3AB9-ECDC
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-2:2 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Device-2: 1-3:3 info: ASUSTek N-KEY Device type: Keyboard
driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 0b05:1866 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-4:2 info: IMC Networks Wireless_Device type: Bluetooth
driver: btusb interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 100mA
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 55.2 C mobo: N/A
Fan Speeds (RPM): cpu: 0
GPU: device: amdgpu temp: N/A device: amdgpu temp: 51.0 C mem: 44.0 C
fan: 0 watts: 12.00
Processes: 340 Uptime: 2h 59m wakeups: 4 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: pm: pacman pkgs: 1167 libs: 320 tools: pamac,paru,yay Shell: Bash
v: 5.1.16 running-in: alacritty inxi: 3.3.21
I have tried all the software mentioned in the conversation and my research was very focused on “linux screen saturation”, “how to configure screen saturation on linux”, “displaycal saturation”, “radeon software alternative screen saturation”…
omano
6 September 2022 20:01
20
Riptils:
I am in wayland
There is not much solution apparently, so maybe use X11?
x) I don’t plan to use x11, it would be bad for the performance of my system
