The wayland support is getting better on each release, awsome! I’m trying to switch now permanently to wayland, but I do have this issue:
When pressing Alt+Tab when using VirtualBox (or Citrix Receiver client) the Alt+Tab event is hadled by the host OS (Manjaro+KDE) but I do like that it is forwarded to the guest OS. Is it possible to change this setting somewhere?
To clarify this: Alt+Tab switches between my applications. When another OS is started in VirtualBox and I do press Alt+Tab there it should switch between the applications in the guest OS inside VirtualBox (or Citrix Receiver) instead of the host/parent OS. It works when using X11 but not on Wayland.
Press the Windows key, is called HOST key by Virtualbox and the TAB key instead of the ALT key, then it should work as usual. So press HOST+TAB. Wayland works really great so far without any problems!
Pressing HOST+TAB works for VirtualBox - but not for Citrix Receiver. And well - I still prefer using the common Alt+Tab. So no possibility available to redirect Alt+Tab to the application when VirtualBox or Citrix is in Foreground?
It perfectly works on X11 - so it should also be supported somehow in Wayland?!
