How to enable Wayland in Manjaro KDE
How can I enable wayland ? couldn’t find any tutorial on it. I’m trying to solve a screen tearing problem and want to see if wayland will solve it.
system:    Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=3eb6f3ad-5767-4869-8316-44365a52609e rw quiet
           apparmor=1 security=apparmor resume=UUID=3b69790b-e216-4ce0-ac38-d2f4d8d718f8 udev.log_priority=3
           Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 20RW v: Lenovo ThinkBook 15-IML serial: <filter> Chassis: type: 10
           serial: <filter>
           Mobo: LENOVO model: LVA/LVAB v: NO DPK serial: <filter> UEFI: LENOVO v: CJCN29WW date: 06/19/2020
Battery:   ID-1: BAT1 charge: 26.1 Wh condition: 44.8/45.0 Wh (100%) volts: 11.6/11.5 model: Celxpert L19C3PF1
           type: Li-poly serial: <filter> status: Discharging cycles: 24
Memory:    RAM: total: 3.36 GiB used: 1.17 GiB (35.0%)
CPU:       Topology: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP arch: Kaby Lake family: 6
           model-id: 8E (142) stepping: C (12) microcode: D6 L2 cache: 6144 KiB bogomips: 33615
           Speed: 800 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 789 7: 772
           8: 785
           Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art avx avx2 bmi1
           bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
           ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
           hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
           monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
           popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
           stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
           xsavec xsaveopt xsaves xtopology xtpr
           Type: srbds mitigation: TSX disabled
Graphics:  Device-1: Intel UHD Graphics vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:9b41
           Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo bus ID: 1-6:3 chip ID: 5986:2113
           Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel unloaded: modesetting
           alternate: fbdev,vesa display ID: :0 screens: 1
           Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
           Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
           OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.1.7 direct render: Yes
Audio:     Device-1: Intel vendor: Lenovo driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
           bus ID: 00:1f.3 chip ID: 8086:02c8
           Sound Server: ALSA v: k5.8.6-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel
           port: 3000 bus ID: 01:00.0 chip ID: 10ec:8168
           IF: enp1s0 state: down mac: <filter>
           Device-2: Realtek vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: 2000 bus ID: 02:00.0
           chip ID: 10ec:c82f
           IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives:    Local Storage: total: 931.51 GiB used: 9.64 GiB (1.0%)
           ID-1: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB block size: physical: 4096 B
           logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0E scheme: GPT
RAID:      Message: No RAID data was found.
Partition: ID-1: / raw size: 923.83 GiB size: 908.32 GiB (98.32%) used: 9.64 GiB (1.1%) fs: ext4 dev: /dev/sda2
           label: N/A uuid: 3eb6f3ad-5767-4869-8316-44365a52609e
           ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%) used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1
           label: N/A uuid: 120B-E6B6
Swap:      Kernel: swappiness: 60 (default) cache pressure: 100 (default)
           ID-1: swap-1 type: partition size: 7.39 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 label: N/A
           uuid: 3b69790b-e216-4ce0-ac38-d2f4d8d718f8
Unmounted: Message: No unmounted partitions found.
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
           Device-1: 1-5:2 info: Shenzhen Goodix Goodix FingerPrint Device type: <vendor specific> driver: N/A
           interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 27c6:55a4
           Device-2: 1-6:3 info: Acer SunplusIT Integrated Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0
           speed: 480 Mb/s chip ID: 5986:2113
           Device-3: 1-10:4 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb interfaces: 2 rev: 1.0
           speed: 12 Mb/s chip ID: 0bda:c02f serial: <filter>
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 39.0 C mobo: N/A
Info:      Processes: 209 Uptime: 18m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1194 lib: 321
           flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
Install plasma-wayland-session. After that you should be able chose Wayland in SDDM :wink:
can you please give me the command line to install it through the terminal ? I’m a little bit new to this.
is it sudo install plasma-wayland-session ?
It should be sudo pacman -S plasma-wayland-session
I used the software manager to install it. but couldn’t find it in SDDM.
you can find it in the login screen, for me its in the left bottom corner.
can’t find it
no before you login…that screen
Not here. You must log out or reboot – after that you see option in the left bottom corner :wink:
Oh my bad. :joy:
