Hallo Gemeinde,
Bei mir ergibt alsactl init folgendes
alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -6
Found hardware: "HDA-Intel" "Realtek ALC889" "HDA:10ec0889,1043840f,00100004" "0x1043" "0x840f"
Hardware is initialized using a generic method
alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA NVidia at 0xfbdfc000 irq 53)
alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:1 use case configuration -6
Found hardware: "HDA-Intel" "Nvidia GPU 71 HDMI/DP" "HDA:10de0071,10438508,00100100" "0x1043" "0x8508"
Das letzte Update hat leider nicht geholfen wie erhofft.
Gefunden dazu habe ich folgendes
Hier
und hier
Hängt das zusammen ? Weiß da wer mehr ?
Fabby
August 11, 2021, 10:41pm
2
ergibt folgendes
Kernel: 5.13.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=8e8bee42-aea7-4b6f-b8f2-d227ae9eb969 rw quiet apparmor=1
security=apparmor udev.log_priority=3 systemd.unified_cgroup_hierarchy=true
noibrs noibpb mitigations=off intremap=off modprobe.blacklist=pcspkr
nvidia-drm.modeset=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: Rampage III Extreme v: Rev 1.xx
serial: <filter> BIOS: American Megatrends v: 1601 date: 01/03/2012
RAM: total: 11.68 GiB used: 1.93 GiB (16.5%)
Info: 6-Core model: Intel Core i7 X 980 bits: 64 type: MT MCP arch: Nehalem
family: 6 model-id: 2C (44) stepping: 2 microcode: 1F cache: L2: 12 MiB
bogomips: 84331
Speed: 3512 MHz min/max: N/A Core speeds (MHz): 1: 3512 2: 3512 3: 3512
4: 3512 5: 2152 6: 3512 7: 3512 8: 3512 9: 3512 10: 3512 11: 3512 12: 3512
Flags: acpi aes aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est flexpriority
flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pni
popcnt pse pse36 rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: ASUSTeK driver: nvidia
v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 03:00.0
chip-ID: 10de:13c2 class-ID: 0300
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.7x13.5")
s-diag: 692mm (27.3")
Monitor-1: DP-0 res: 2560x1440 dpi: 109 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 470.57.02
direct render: Yes
Device-1: Intel 82801JI HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 10de:0fbb
class-ID: 0403
Sound Server-1: ALSA v: k5.13.8-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Device-1: Intel 82567V-2 Gigabit Network vendor: ASUSTeK driver: e1000e
v: kernel port: cc00 bus-ID: 00:19.0 chip-ID: 8086:10ce class-ID: 0200
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 7-1:2 chip-ID: 0a12:0001 class-ID: fe01
Local Storage: total: 8.43 TiB used: 5.77 TiB (68.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 950 PRO 512GB
lanes: 4 type: SSD serial: <filter> rev: 2B0QBXX7 temp: 35.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500630NS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
type: N/A serial: <filter> rev: E
ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD2000FYYZ-01UL1B0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1K01 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST3000NM0033-9ZM178
size: 2.73 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: SN07 scheme: GPT
ID-6: /dev/sde maj-min: 8:64 vendor: Seagate model: ST3000NM0033-9ZM178
ID-1: / raw-size: 209.59 GiB size: 205.25 GiB (97.93%)
used: 24.8 GiB (12.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 8e8bee42-aea7-4b6f-b8f2-d227ae9eb969
ID-2: /home/<filter>/C raw-size: 63.4 GiB size: 63.4 GiB (100.00%)
used: 46.4 GiB (73.2%) fs: ntfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 983C244E3C2429A8
ID-3: /home/<filter>/D raw-size: 365.21 GiB size: 365.21 GiB (100.00%)
used: 256.4 GiB (70.2%) fs: ntfs dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: 0E9B08BF0E9B08BF
ID-4: /home/<filter>/F raw-size: 465.63 GiB size: 465.63 GiB (100.00%)
used: 277.23 GiB (59.5%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18 label: Volume
uuid: FCDA2921DA28D9A2
ID-5: /home/<filter>/G raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
used: 2.19 TiB (80.4%) fs: ntfs dev: /dev/sdd2 maj-min: 8:50 label: Volume
uuid: 80F6DB58F6DB4D52
ID-6: /home/<filter>/H raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
used: 2.52 TiB (92.3%) fs: ntfs dev: /dev/sde2 maj-min: 8:66 label: Volume
uuid: C624E96724E95B47
ID-7: /home/<filter>/I raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 481.18 GiB (25.8%) fs: ntfs dev: /dev/sdc1 maj-min: 8:33 label: Volume
uuid: A81A6EFE1A6EC940
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: ntfs label: N/A
uuid: B4FC7F32FC7EEE4C
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 550 MiB fs: ntfs label: N/A
uuid: B2EE7C42EE7C00C1
ID-3: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdd1 maj-min: 8:49 size: 128 MiB fs: <superuser required>
ID-5: /dev/sde1 maj-min: 8:65 size: 128 MiB fs: <superuser required>
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-2: 1-4:2 info: Genesys Logic Hub ports: 3 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-8: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 7-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 3 rev: 2.0 speed: 12 Mb/s
Hub-9: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 8-1:2 info: ASUSTek ROG GLADIUS III type: HID,Mouse
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b05:197b class-ID: 0300
Device-2: 8-2:3 info: ASUSTek ROG Claymore Gaming Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0b05:184d class-ID: 0300
Hub-10: 9-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-11: 10-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0
speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-12: 10-1:2 info: Genesys Logic Hub ports: 3 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
System Temperatures: cpu: 33.5 C mobo: 35.0 C gpu: nvidia temp: 64 C
Fan Speeds (RPM): cpu: 1328 gpu: nvidia fan: 34%
Power: 12v: 12.14 5v: N/A 3.3v: 3.30 vbat: N/A
Processes: 263 Uptime: 7m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1307 lib: 380 flatpak: 0
Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06 ```
Fabby
August 13, 2021, 8:35am
4
weingeist:
Haben sie Kernel 5.10 LTS probiert? (“LTS” = mehr stabil als “Stable”)
Schaut mal bitte meinen Alsamixer Output an. Vielleicht hilft das ja weiter
Ist das so korrekt ? Etwas viel in- und Output meiner Meinung nach.
