I am unable to download any themes, icons, widgets, etc that involves clicking the “get new stuff” button. It says all categories are missing, everywhere. here’s a screenshot of what happens.
please can someone help me?
I don’t really know what broke it. I haven’t used the plasma store for weeks so I really don’t have any idea.
i will provide the system info here:
Kernel: 5.16.5-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=fe780552-423e-483f-a39f-82c6a23f80b4 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Portable System: Dell product: Inspiron 3542 v: N/A
serial: <superuser required> Chassis: type: 8 serial: <superuser required>
Mobo: Dell model: 0KHNVP v: A13 serial: <superuser required> UEFI: Dell
v: A13 date: 01/30/2018
ID-1: BAT0 charge: 40.3 Wh (100.0%) condition: 40.3/41.6 Wh (96.9%)
volts: 16.6 min: 14.6 model: SMP-LG2.85 DELL 1C12X31 type: Li-ion
serial: <filter> status: Full
RAM: total: 3.74 GiB used: 2.02 GiB (54.2%)
RAM Report:
Info: model: Intel Core i3-4005U bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1696 high: 1697 min/max: 800/1700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1696 2: 1696 3: 1696
4: 1697 bogomips: 13573
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-1.5:3 chip-ID: 0c45:670b class-ID: 0e02
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Sound Server-1: ALSA v: k5.16.5-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.45 running: no
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Dell driver: ath9k v: kernel bus-ID: 06:00.0 chip-ID: 168c:0036
class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp7s0 state: down mac: <filter>
Device-1: Qualcomm Atheros AR9462 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-1.6:6 chip-ID: 0cf3:0036 class-ID: e001
Local Storage: total: 931.51 GiB used: 132.06 GiB (14.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM024 HN-M101MBB
type: HDD rpm: 5400 serial: <filter> rev: 0004 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C0
dev-links: cdrom
ID-1: / raw-size: 70 GiB size: 68.35 GiB (97.64%) used: 15.6 GiB (22.8%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: root
uuid: fe780552-423e-483f-a39f-82c6a23f80b4
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: AE3A-D706
ID-3: /home raw-size: 53 GiB size: 51.87 GiB (97.86%)
used: 6.04 GiB (11.6%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: home
uuid: d2f8fd7a-7f22-4b97-8ad7-b2fa88b7a451
ID-4: /media/storage raw-size: 702.36 GiB size: 702.36 GiB (100.00%)
used: 110.42 GiB (15.7%) fs: ntfs dev: /dev/sda5 maj-min: 8:5 label: storage
uuid: 3C8E47E5341FDBFD
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 61a1b64b-c795-4beb-881a-0ea46ed95b4e
ID-1: /dev/sda6 maj-min: 8:6 size: 97.66 GiB fs: ext4 label: backuptimeshift
uuid: 87eb4f07-8984-46b0-8994-9d0d0338e3e7
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Device-1: 1-1.5:3 info: Microdia Integrated_Webcam_HD type: Video
Device-2: 1-1.6:6 info: Qualcomm Atheros AR9462 Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
Device-3: 1-1.8:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 8 rev: 2.0
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 50.0 C mobo: 48.0 C
Fan Speeds (RPM): cpu: 0
Processes: 209 Uptime: 11m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1475 lib: 388
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.12
How can I fix this?
thank you
