First third
#################### journalctl -b -1 ########################
-- Journal begins at Mon 2021-01-11 15:22:17 CET, ends at Sun 2021-02-07 12:00:15 CET. --
feb 07 11:58:51 _hostname_ kernel: microcode: microcode updated early to revision 0x28, date = 2019-11-12
feb 07 11:58:51 _hostname_ kernel: Linux version 5.10.7-3-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP PREEMPT Fri Jan 15 21:11:34 UTC 2021
feb 07 11:58:51 _hostname_ kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=a24595d9-3927-42d7-bcf0-1ea69ff664a0 ro apparmor=1 security=apparmor resume=UUID=608187eb-e840-4181-b12b-fd38a1f87b86 udev.log_priority=3
feb 07 11:58:51 _hostname_ kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
feb 07 11:58:51 _hostname_ kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
feb 07 11:58:51 _hostname_ kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
feb 07 11:58:51 _hostname_ kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
feb 07 11:58:51 _hostname_ kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
feb 07 11:58:51 _hostname_ kernel: BIOS-provided physical RAM map:
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x0000000000059000-0x000000000009dfff] usable
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] reserved
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000bc721fff] usable
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000bc722000-0x00000000bcab4fff] reserved
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000bcab5000-0x00000000c9b69fff] usable
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000c9b6a000-0x00000000ca37cfff] reserved
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000ca37d000-0x00000000ca3aafff] ACPI data
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000ca3ab000-0x00000000cad12fff] ACPI NVS
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000cad13000-0x00000000caf9afff] reserved
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000caf9b000-0x00000000caffefff] type 20
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000cafff000-0x00000000caffffff] usable
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000cb800000-0x00000000cf9fffff] reserved
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
feb 07 11:58:51 _hostname_ kernel: BIOS-e820: [mem 0x0000000100000000-0x000000042f5fffff] usable
feb 07 11:58:51 _hostname_ kernel: NX (Execute Disable) protection: active
feb 07 11:58:51 _hostname_ kernel: efi: EFI v2.40 by American Megatrends
feb 07 11:58:51 _hostname_ kernel: efi: ESRT=0xcaf97218 ACPI=0xca386000 ACPI 2.0=0xca386000 SMBIOS=0xcaee3e18
feb 07 11:58:51 _hostname_ kernel: SMBIOS 2.8 present.
feb 07 11:58:51 _hostname_ kernel: DMI: Alienware Alienware 15/Alienware 15, BIOS A12 05/29/2019
feb 07 11:58:51 _hostname_ kernel: tsc: Fast TSC calibration using PIT
feb 07 11:58:51 _hostname_ kernel: tsc: Detected 2598.593 MHz processor
feb 07 11:58:51 _hostname_ kernel: [Firmware Bug]: TSC ADJUST: CPU0: -2603198 force to 0
feb 07 11:58:51 _hostname_ kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
feb 07 11:58:51 _hostname_ kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
feb 07 11:58:51 _hostname_ kernel: last_pfn = 0x42f600 max_arch_pfn = 0x400000000
feb 07 11:58:51 _hostname_ kernel: MTRR default type: uncachable
feb 07 11:58:51 _hostname_ kernel: MTRR fixed ranges enabled:
feb 07 11:58:51 _hostname_ kernel: 00000-9FFFF write-back
feb 07 11:58:51 _hostname_ kernel: A0000-EFFFF uncachable
feb 07 11:58:51 _hostname_ kernel: F0000-FFFFF write-protect
feb 07 11:58:51 _hostname_ kernel: MTRR variable ranges enabled:
feb 07 11:58:51 _hostname_ kernel: 0 base 0000000000 mask 7C00000000 write-back
feb 07 11:58:51 _hostname_ kernel: 1 base 0400000000 mask 7FC0000000 write-back
feb 07 11:58:51 _hostname_ kernel: 2 base 0430000000 mask 7FF0000000 uncachable
feb 07 11:58:51 _hostname_ kernel: 3 base 042F800000 mask 7FFF800000 uncachable
feb 07 11:58:51 _hostname_ kernel: 4 base 042F600000 mask 7FFFE00000 uncachable
feb 07 11:58:51 _hostname_ kernel: 5 base 00E0000000 mask 7FE0000000 uncachable
feb 07 11:58:51 _hostname_ kernel: 6 base 00D0000000 mask 7FF0000000 uncachable
feb 07 11:58:51 _hostname_ kernel: 7 base 00CC000000 mask 7FFC000000 uncachable
feb 07 11:58:51 _hostname_ kernel: 8 base 00CB800000 mask 7FFF800000 uncachable
feb 07 11:58:51 _hostname_ kernel: 9 disabled
feb 07 11:58:51 _hostname_ kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
feb 07 11:58:51 _hostname_ kernel: total RAM covered: 16302M
feb 07 11:58:51 _hostname_ kernel: gran_size: 64K chunk_size: 64K num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 64K chunk_size: 128K num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 64K chunk_size: 256K num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 64K chunk_size: 512K num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 64K chunk_size: 1M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 64K chunk_size: 2M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 64K chunk_size: 4M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 64K chunk_size: 8M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 64K chunk_size: 16M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 64K chunk_size: 32M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 64K chunk_size: 64M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 64K chunk_size: 128M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 64K chunk_size: 256M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 64K chunk_size: 512M num_reg: 10 lose cover RAM: -264M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 64K chunk_size: 1G num_reg: 10 lose cover RAM: -256M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 64K chunk_size: 2G num_reg: 10 lose cover RAM: -1280M
feb 07 11:58:51 _hostname_ kernel: gran_size: 128K chunk_size: 128K num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 128K chunk_size: 256K num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 128K chunk_size: 512K num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 128K chunk_size: 1M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 128K chunk_size: 2M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 128K chunk_size: 4M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 128K chunk_size: 8M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 128K chunk_size: 16M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 128K chunk_size: 32M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 128K chunk_size: 64M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 128K chunk_size: 128M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 128K chunk_size: 256M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 128K chunk_size: 512M num_reg: 10 lose cover RAM: -264M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 128K chunk_size: 1G num_reg: 10 lose cover RAM: -256M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 128K chunk_size: 2G num_reg: 10 lose cover RAM: -1280M
feb 07 11:58:51 _hostname_ kernel: gran_size: 256K chunk_size: 256K num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 256K chunk_size: 512K num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 256K chunk_size: 1M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 256K chunk_size: 2M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 256K chunk_size: 4M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 256K chunk_size: 8M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 256K chunk_size: 16M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 256K chunk_size: 32M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 256K chunk_size: 64M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 256K chunk_size: 128M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 256K chunk_size: 256M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 256K chunk_size: 512M num_reg: 10 lose cover RAM: -264M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 256K chunk_size: 1G num_reg: 10 lose cover RAM: -256M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 256K chunk_size: 2G num_reg: 10 lose cover RAM: -1280M
feb 07 11:58:51 _hostname_ kernel: gran_size: 512K chunk_size: 512K num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 512K chunk_size: 1M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 512K chunk_size: 2M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 512K chunk_size: 4M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 512K chunk_size: 8M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 512K chunk_size: 16M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 512K chunk_size: 32M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 512K chunk_size: 64M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 512K chunk_size: 128M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 512K chunk_size: 256M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 512K chunk_size: 512M num_reg: 10 lose cover RAM: -264M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 512K chunk_size: 1G num_reg: 10 lose cover RAM: -256M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 512K chunk_size: 2G num_reg: 10 lose cover RAM: -1280M
feb 07 11:58:51 _hostname_ kernel: gran_size: 1M chunk_size: 1M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 1M chunk_size: 2M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 1M chunk_size: 4M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 1M chunk_size: 8M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 1M chunk_size: 16M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 1M chunk_size: 32M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 1M chunk_size: 64M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 1M chunk_size: 128M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 1M chunk_size: 256M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 1M chunk_size: 512M num_reg: 10 lose cover RAM: -264M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 1M chunk_size: 1G num_reg: 10 lose cover RAM: -256M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 1M chunk_size: 2G num_reg: 10 lose cover RAM: -1280M
feb 07 11:58:51 _hostname_ kernel: gran_size: 2M chunk_size: 2M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 2M chunk_size: 4M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 2M chunk_size: 8M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 2M chunk_size: 16M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 2M chunk_size: 32M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 2M chunk_size: 64M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 2M chunk_size: 128M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 2M chunk_size: 256M num_reg: 10 lose cover RAM: -8M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 2M chunk_size: 512M num_reg: 10 lose cover RAM: -264M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 2M chunk_size: 1G num_reg: 10 lose cover RAM: -256M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 2M chunk_size: 2G num_reg: 10 lose cover RAM: -1280M
feb 07 11:58:51 _hostname_ kernel: gran_size: 4M chunk_size: 4M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 4M chunk_size: 8M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 4M chunk_size: 16M num_reg: 10 lose cover RAM: -6M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 4M chunk_size: 32M num_reg: 10 lose cover RAM: -6M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 4M chunk_size: 64M num_reg: 10 lose cover RAM: -6M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 4M chunk_size: 128M num_reg: 10 lose cover RAM: -6M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 4M chunk_size: 256M num_reg: 10 lose cover RAM: -6M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 4M chunk_size: 512M num_reg: 10 lose cover RAM: -262M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 4M chunk_size: 1G num_reg: 10 lose cover RAM: -254M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 4M chunk_size: 2G num_reg: 10 lose cover RAM: -1278M
feb 07 11:58:51 _hostname_ kernel: gran_size: 8M chunk_size: 8M num_reg: 10 lose cover RAM: 118M
feb 07 11:58:51 _hostname_ kernel: gran_size: 8M chunk_size: 16M num_reg: 10 lose cover RAM: 54M
feb 07 11:58:51 _hostname_ kernel: gran_size: 8M chunk_size: 32M num_reg: 10 lose cover RAM: 6M
feb 07 11:58:51 _hostname_ kernel: gran_size: 8M chunk_size: 64M num_reg: 10 lose cover RAM: 6M
feb 07 11:58:51 _hostname_ kernel: gran_size: 8M chunk_size: 128M num_reg: 10 lose cover RAM: 6M
feb 07 11:58:51 _hostname_ kernel: gran_size: 8M chunk_size: 256M num_reg: 10 lose cover RAM: 6M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 8M chunk_size: 512M num_reg: 10 lose cover RAM: -250M
feb 07 11:58:51 _hostname_ kernel: gran_size: 8M chunk_size: 1G num_reg: 10 lose cover RAM: 6M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 8M chunk_size: 2G num_reg: 10 lose cover RAM: -1018M
feb 07 11:58:51 _hostname_ kernel: gran_size: 16M chunk_size: 16M num_reg: 10 lose cover RAM: 62M
feb 07 11:58:51 _hostname_ kernel: gran_size: 16M chunk_size: 32M num_reg: 10 lose cover RAM: 14M
feb 07 11:58:51 _hostname_ kernel: gran_size: 16M chunk_size: 64M num_reg: 10 lose cover RAM: 14M
feb 07 11:58:51 _hostname_ kernel: gran_size: 16M chunk_size: 128M num_reg: 10 lose cover RAM: 14M
feb 07 11:58:51 _hostname_ kernel: gran_size: 16M chunk_size: 256M num_reg: 10 lose cover RAM: 14M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 16M chunk_size: 512M num_reg: 10 lose cover RAM: -242M
feb 07 11:58:51 _hostname_ kernel: gran_size: 16M chunk_size: 1G num_reg: 10 lose cover RAM: 14M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 16M chunk_size: 2G num_reg: 10 lose cover RAM: -1010M
feb 07 11:58:51 _hostname_ kernel: gran_size: 32M chunk_size: 32M num_reg: 10 lose cover RAM: 46M
feb 07 11:58:51 _hostname_ kernel: gran_size: 32M chunk_size: 64M num_reg: 10 lose cover RAM: 46M
feb 07 11:58:51 _hostname_ kernel: gran_size: 32M chunk_size: 128M num_reg: 10 lose cover RAM: 46M
feb 07 11:58:51 _hostname_ kernel: gran_size: 32M chunk_size: 256M num_reg: 10 lose cover RAM: 46M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 32M chunk_size: 512M num_reg: 10 lose cover RAM: -210M
feb 07 11:58:51 _hostname_ kernel: gran_size: 32M chunk_size: 1G num_reg: 10 lose cover RAM: 46M
feb 07 11:58:51 _hostname_ kernel: *BAD*gran_size: 32M chunk_size: 2G num_reg: 10 lose cover RAM: -978M
feb 07 11:58:51 _hostname_ kernel: gran_size: 64M chunk_size: 64M num_reg: 8 lose cover RAM: 110M
feb 07 11:58:51 _hostname_ kernel: gran_size: 64M chunk_size: 128M num_reg: 8 lose cover RAM: 110M
feb 07 11:58:51 _hostname_ kernel: gran_size: 64M chunk_size: 256M num_reg: 9 lose cover RAM: 110M
feb 07 11:58:51 _hostname_ kernel: gran_size: 64M chunk_size: 512M num_reg: 10 lose cover RAM: 110M
feb 07 11:58:51 _hostname_ kernel: gran_size: 64M chunk_size: 1G num_reg: 9 lose cover RAM: 110M
feb 07 11:58:51 _hostname_ kernel: gran_size: 64M chunk_size: 2G num_reg: 10 lose cover RAM: 110M
feb 07 11:58:51 _hostname_ kernel: gran_size: 128M chunk_size: 128M num_reg: 7 lose cover RAM: 174M
feb 07 11:58:51 _hostname_ kernel: gran_size: 128M chunk_size: 256M num_reg: 9 lose cover RAM: 174M
feb 07 11:58:51 _hostname_ kernel: gran_size: 128M chunk_size: 512M num_reg: 10 lose cover RAM: 174M
feb 07 11:58:51 _hostname_ kernel: gran_size: 128M chunk_size: 1G num_reg: 9 lose cover RAM: 174M
feb 07 11:58:51 _hostname_ kernel: gran_size: 128M chunk_size: 2G num_reg: 10 lose cover RAM: 174M
feb 07 11:58:51 _hostname_ kernel: gran_size: 256M chunk_size: 256M num_reg: 5 lose cover RAM: 430M
feb 07 11:58:51 _hostname_ kernel: gran_size: 256M chunk_size: 512M num_reg: 5 lose cover RAM: 430M
feb 07 11:58:51 _hostname_ kernel: gran_size: 256M chunk_size: 1G num_reg: 6 lose cover RAM: 430M
feb 07 11:58:51 _hostname_ kernel: gran_size: 256M chunk_size: 2G num_reg: 7 lose cover RAM: 430M
feb 07 11:58:51 _hostname_ kernel: gran_size: 512M chunk_size: 512M num_reg: 5 lose cover RAM: 430M
feb 07 11:58:51 _hostname_ kernel: gran_size: 512M chunk_size: 1G num_reg: 6 lose cover RAM: 430M
feb 07 11:58:51 _hostname_ kernel: gran_size: 512M chunk_size: 2G num_reg: 7 lose cover RAM: 430M
feb 07 11:58:51 _hostname_ kernel: gran_size: 1G chunk_size: 1G num_reg: 4 lose cover RAM: 942M
feb 07 11:58:51 _hostname_ kernel: gran_size: 1G chunk_size: 2G num_reg: 4 lose cover RAM: 942M
feb 07 11:58:51 _hostname_ kernel: gran_size: 2G chunk_size: 2G num_reg: 3 lose cover RAM: 1966M
feb 07 11:58:51 _hostname_ kernel: mtrr_cleanup: can not find optimal value
feb 07 11:58:51 _hostname_ kernel: please specify mtrr_gran_size/mtrr_chunk_size
feb 07 11:58:51 _hostname_ kernel: e820: update [mem 0xcb800000-0xffffffff] usable ==> reserved
feb 07 11:58:51 _hostname_ kernel: last_pfn = 0xcb000 max_arch_pfn = 0x400000000
feb 07 11:58:51 _hostname_ kernel: esrt: Reserving ESRT space from 0x00000000caf97218 to 0x00000000caf97250.
feb 07 11:58:51 _hostname_ kernel: check: Scanning 1 areas for low memory corruption
feb 07 11:58:51 _hostname_ kernel: Using GB pages for direct mapping
feb 07 11:58:51 _hostname_ kernel: Secure boot disabled
feb 07 11:58:51 _hostname_ kernel: RAMDISK: [mem 0x36b1d000-0x37585fff]
feb 07 11:58:51 _hostname_ kernel: ACPI: Early table checksum verification disabled
feb 07 11:58:51 _hostname_ kernel: ACPI: RSDP 0x00000000CA386000 000024 (v02 ALWARE)
feb 07 11:58:51 _hostname_ kernel: ACPI: XSDT 0x00000000CA3860A0 0000BC (v01 ALWARE ALIENWRE 01072009 AMI 00010013)
feb 07 11:58:51 _hostname_ kernel: ACPI: FACP 0x00000000CA39C3E8 00010C (v05 ALWARE ALIENWRE 01072009 AMI 00010013)
feb 07 11:58:51 _hostname_ kernel: ACPI: DSDT 0x00000000CA3861E8 016200 (v02 ALWARE ALIENWRE 01072009 INTL 20120913)
feb 07 11:58:51 _hostname_ kernel: ACPI: FACS 0x00000000CAD0DF80 000040
feb 07 11:58:51 _hostname_ kernel: ACPI: APIC 0x00000000CA39C4F8 0000BC (v03 ALWARE ALIENWRE 01072009 AMI 00010013)
feb 07 11:58:51 _hostname_ kernel: ACPI: FPDT 0x00000000CA39C5B8 000044 (v01 ALWARE ALIENWRE 01072009 AMI 00010013)
feb 07 11:58:51 _hostname_ kernel: ACPI: FIDT 0x00000000CA39C600 00009C (v01 ALWARE ALIENWRE 01072009 AMI 00010013)
feb 07 11:58:51 _hostname_ kernel: ACPI: MCFG 0x00000000CA39C6A0 00003C (v01 ALWARE ALIENWRE 01072009 MSFT 00000097)
feb 07 11:58:51 _hostname_ kernel: ACPI: HPET 0x00000000CA39C6E0 000038 (v01 ALWARE ALIENWRE 01072009 AMI. 00000005)
feb 07 11:58:51 _hostname_ kernel: ACPI: SSDT 0x00000000CA39C718 0003EF (v01 SataRe SataTabl 00001000 INTL 20120913)
feb 07 11:58:51 _hostname_ kernel: ACPI: UEFI 0x00000000CA39CB08 000042 (v01 00000000 00000000)
feb 07 11:58:51 _hostname_ kernel: ACPI: SSDT 0x00000000CA39CB50 0004A8 (v02 Ther_R Ther_Rvp 00001000 INTL 20120913)
feb 07 11:58:51 _hostname_ kernel: ACPI: ASF! 0x00000000CA39CFF8 0000A0 (v32 INTEL HCG 00000001 TFSM 000F4240)
feb 07 11:58:51 _hostname_ kernel: ACPI: SLIC 0x00000000CA39D098 000176 (v01 ALWARE ALIENWRE 01072009 AMI 00010013)
feb 07 11:58:51 _hostname_ kernel: ACPI: SSDT 0x00000000CA39D210 000539 (v02 PmRef Cpu0Ist 00003000 INTL 20120913)
feb 07 11:58:51 _hostname_ kernel: ACPI: SSDT 0x00000000CA39D750 000B74 (v02 CpuRef CpuSsdt 00003000 INTL 20120913)
feb 07 11:58:51 _hostname_ kernel: ACPI: SSDT 0x00000000CA39E2C8 003235 (v02 DptfTa DptfTabl 00001000 INTL 20120913)
feb 07 11:58:51 _hostname_ kernel: ACPI: SSDT 0x00000000CA3A1500 006594 (v02 SaSsdt SaSsdt 00003000 INTL 20120913)
feb 07 11:58:51 _hostname_ kernel: ACPI: SSDT 0x00000000CA3A7A98 00027A (v02 SgRef SgPeg 00001000 INTL 20120913)
feb 07 11:58:51 _hostname_ kernel: ACPI: DMAR 0x00000000CA3A7D18 0000B8 (v01 INTEL BDW 00000001 INTL 00000001)
feb 07 11:58:51 _hostname_ kernel: ACPI: BGRT 0x00000000CA3A7DD0 000038 (v01 ALWARE ALIENWRE 01072009 AMI 00010013)
feb 07 11:58:51 _hostname_ kernel: ACPI: SSDT 0x00000000CA3A7E08 002389 (v01 OptRef OptTabl 00001000 INTL 20120913)
feb 07 11:58:51 _hostname_ kernel: ACPI: Local APIC address 0xfee00000
feb 07 11:58:51 _hostname_ kernel: No NUMA configuration found
feb 07 11:58:51 _hostname_ kernel: Faking a node at [mem 0x0000000000000000-0x000000042f5fffff]
feb 07 11:58:51 _hostname_ kernel: NODE_DATA(0) allocated [mem 0x42f5fc000-0x42f5fffff]
feb 07 11:58:51 _hostname_ kernel: Zone ranges:
feb 07 11:58:51 _hostname_ kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
feb 07 11:58:51 _hostname_ kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
feb 07 11:58:51 _hostname_ kernel: Normal [mem 0x0000000100000000-0x000000042f5fffff]
feb 07 11:58:51 _hostname_ kernel: Device empty
feb 07 11:58:51 _hostname_ kernel: Movable zone start for each node
feb 07 11:58:51 _hostname_ kernel: Early memory node ranges
feb 07 11:58:51 _hostname_ kernel: node 0: [mem 0x0000000000001000-0x0000000000057fff]
feb 07 11:58:51 _hostname_ kernel: node 0: [mem 0x0000000000059000-0x000000000009dfff]
feb 07 11:58:51 _hostname_ kernel: node 0: [mem 0x0000000000100000-0x00000000bc721fff]
feb 07 11:58:51 _hostname_ kernel: node 0: [mem 0x00000000bcab5000-0x00000000c9b69fff]
feb 07 11:58:51 _hostname_ kernel: node 0: [mem 0x00000000cafff000-0x00000000caffffff]
feb 07 11:58:51 _hostname_ kernel: node 0: [mem 0x0000000100000000-0x000000042f5fffff]
feb 07 11:58:51 _hostname_ kernel: Zeroed struct page in unavailable ranges: 29324 pages
feb 07 11:58:51 _hostname_ kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000042f5fffff]
feb 07 11:58:51 _hostname_ kernel: On node 0 totalpages: 4164980
feb 07 11:58:51 _hostname_ kernel: DMA zone: 64 pages used for memmap
feb 07 11:58:51 _hostname_ kernel: DMA zone: 22 pages reserved
feb 07 11:58:51 _hostname_ kernel: DMA zone: 3996 pages, LIFO batch:0
feb 07 11:58:51 _hostname_ kernel: DMA32 zone: 12832 pages used for memmap
feb 07 11:58:51 _hostname_ kernel: DMA32 zone: 821208 pages, LIFO batch:63
feb 07 11:58:51 _hostname_ kernel: Normal zone: 52184 pages used for memmap
feb 07 11:58:51 _hostname_ kernel: Normal zone: 3339776 pages, LIFO batch:63
feb 07 11:58:51 _hostname_ kernel: Reserving Intel graphics memory at [mem 0xcba00000-0xcf9fffff]
feb 07 11:58:51 _hostname_ kernel: ACPI: PM-Timer IO Port: 0x1808
feb 07 11:58:51 _hostname_ kernel: ACPI: LAPIC_NMI (acpi_id[0x01] dfl edge lint[0xc6])
feb 07 11:58:51 _hostname_ kernel: ACPI: NMI not connected to LINT 1!
feb 07 11:58:51 _hostname_ kernel: ACPI: LAPIC_NMI (acpi_id[0x02] dfl edge lint[0x8d])
feb 07 11:58:51 _hostname_ kernel: ACPI: LAPIC_NMI (acpi_id[0x03] dfl res lint[0x90])
feb 07 11:58:51 _hostname_ kernel: ACPI: LAPIC_NMI (acpi_id[0x04] dfl dfl lint[0x8b])
feb 07 11:58:51 _hostname_ kernel: ACPI: LAPIC_NMI (acpi_id[0x05] dfl dfl lint[0x0])
feb 07 11:58:51 _hostname_ kernel: ACPI: LAPIC_NMI (acpi_id[0x06] low level lint[0x8c])
feb 07 11:58:51 _hostname_ kernel: ACPI: LAPIC_NMI (acpi_id[0x07] low level lint[0xf9])
feb 07 11:58:51 _hostname_ kernel: ACPI: LAPIC_NMI (acpi_id[0x08] dfl dfl lint[0x25])
feb 07 11:58:51 _hostname_ kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
feb 07 11:58:51 _hostname_ kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
feb 07 11:58:51 _hostname_ kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
feb 07 11:58:51 _hostname_ kernel: ACPI: IRQ0 used by override.
feb 07 11:58:51 _hostname_ kernel: ACPI: IRQ9 used by override.
feb 07 11:58:51 _hostname_ kernel: Using ACPI (MADT) for SMP configuration information
feb 07 11:58:51 _hostname_ kernel: ACPI: HPET id: 0x8086a701 base: 0xfed00000
feb 07 11:58:51 _hostname_ kernel: e820: update [mem 0xc7997000-0xc79f9fff] usable ==> reserved
feb 07 11:58:51 _hostname_ kernel: TSC deadline timer available
feb 07 11:58:51 _hostname_ kernel: smpboot: Allowing 8 CPUs, 0 hotplug CPUs
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xbc722000-0xbcab4fff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xc7997000-0xc79f9fff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xc9b6a000-0xca37cfff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xca37d000-0xca3aafff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xca3ab000-0xcad12fff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xcad13000-0xcaf9afff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xcaf9b000-0xcaffefff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xcb000000-0xcb7fffff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xcb800000-0xcf9fffff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xcfa00000-0xf7ffffff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
feb 07 11:58:51 _hostname_ kernel: PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
feb 07 11:58:51 _hostname_ kernel: [mem 0xcfa00000-0xf7ffffff] available for PCI devices
feb 07 11:58:51 _hostname_ kernel: Booting paravirtualized kernel on bare hardware
feb 07 11:58:51 _hostname_ kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
feb 07 11:58:51 _hostname_ kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
feb 07 11:58:51 _hostname_ kernel: percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
feb 07 11:58:51 _hostname_ kernel: pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
feb 07 11:58:51 _hostname_ kernel: pcpu-alloc: [0] 0 1 2 3 4 5 6 7
feb 07 11:58:51 _hostname_ kernel: Built 1 zonelists, mobility grouping on. Total pages: 4099878
feb 07 11:58:51 _hostname_ kernel: Policy zone: Normal
feb 07 11:58:51 _hostname_ kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=a24595d9-3927-42d7-bcf0-1ea69ff664a0 ro apparmor=1 security=apparmor resume=UUID=608187eb-e840-4181-b12b-fd38a1f87b86 udev.log_priority=3
feb 07 11:58:51 _hostname_ kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
feb 07 11:58:51 _hostname_ kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
feb 07 11:58:51 _hostname_ kernel: mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
feb 07 11:58:51 _hostname_ kernel: Memory: 16197100K/16659920K available (14344K kernel code, 2065K rwdata, 4832K rodata, 1720K init, 4232K bss, 462560K reserved, 0K cma-reserved)
feb 07 11:58:51 _hostname_ kernel: random: get_random_u64 called from __kmem_cache_create+0x26/0x520 with crng_init=0
feb 07 11:58:51 _hostname_ kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
feb 07 11:58:51 _hostname_ kernel: Kernel/User page tables isolation: enabled
feb 07 11:58:51 _hostname_ kernel: ftrace: allocating 42042 entries in 165 pages
feb 07 11:58:51 _hostname_ kernel: ftrace: allocated 165 pages with 4 groups
feb 07 11:58:51 _hostname_ kernel: rcu: Preemptible hierarchical RCU implementation.
feb 07 11:58:51 _hostname_ kernel: rcu: RCU dyntick-idle grace-period acceleration is enabled.
feb 07 11:58:51 _hostname_ kernel: rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
feb 07 11:58:51 _hostname_ kernel: rcu: RCU priority boosting: priority 1 delay 500 ms.
feb 07 11:58:51 _hostname_ kernel: Trampoline variant of Tasks RCU enabled.
feb 07 11:58:51 _hostname_ kernel: Rude variant of Tasks RCU enabled.
feb 07 11:58:51 _hostname_ kernel: Tracing variant of Tasks RCU enabled.
feb 07 11:58:51 _hostname_ kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
feb 07 11:58:51 _hostname_ kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
feb 07 11:58:51 _hostname_ kernel: NR_IRQS: 20736, nr_irqs: 488, preallocated irqs: 16
feb 07 11:58:51 _hostname_ kernel: Console: colour dummy device 80x25
feb 07 11:58:51 _hostname_ kernel: printk: console [tty0] enabled
feb 07 11:58:51 _hostname_ kernel: ACPI: Core revision 20200925
feb 07 11:58:51 _hostname_ kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
feb 07 11:58:51 _hostname_ kernel: APIC: Switch to symmetric I/O mode setup
feb 07 11:58:51 _hostname_ kernel: DMAR: Host address width 39
feb 07 11:58:51 _hostname_ kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
feb 07 11:58:51 _hostname_ kernel: DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c0000020660462 ecap f0101a
feb 07 11:58:51 _hostname_ kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
feb 07 11:58:51 _hostname_ kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c20660462 ecap f010da
feb 07 11:58:51 _hostname_ kernel: DMAR: RMRR base: 0x000000caef4000 end: 0x000000caf02fff
feb 07 11:58:51 _hostname_ kernel: DMAR: RMRR base: 0x000000cb800000 end: 0x000000cf9fffff
feb 07 11:58:51 _hostname_ kernel: DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
feb 07 11:58:51 _hostname_ kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
feb 07 11:58:51 _hostname_ kernel: DMAR-IR: x2apic is disabled because BIOS sets x2apic opt out bit.
feb 07 11:58:51 _hostname_ kernel: DMAR-IR: Use 'intremap=no_x2apic_optout' to override the BIOS setting.
feb 07 11:58:51 _hostname_ kernel: DMAR-IR: Enabled IRQ remapping in xapic mode
feb 07 11:58:51 _hostname_ kernel: x2apic: IRQ remapping doesn't support X2APIC mode
feb 07 11:58:51 _hostname_ kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
feb 07 11:58:51 _hostname_ kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x25750b1bcd7, max_idle_ns: 440795283676 ns
feb 07 11:58:51 _hostname_ kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 5199.73 BogoMIPS (lpj=8661976)
feb 07 11:58:51 _hostname_ kernel: pid_max: default: 32768 minimum: 301
feb 07 11:58:51 _hostname_ kernel: LSM: Security Framework initializing
feb 07 11:58:51 _hostname_ kernel: Yama: becoming mindful.
feb 07 11:58:51 _hostname_ kernel: AppArmor: AppArmor initialized
feb 07 11:58:51 _hostname_ kernel: Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
feb 07 11:58:51 _hostname_ kernel: Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
feb 07 11:58:51 _hostname_ kernel: mce: CPU0: Thermal monitoring enabled (TM1)
feb 07 11:58:51 _hostname_ kernel: process: using mwait in idle threads
feb 07 11:58:51 _hostname_ kernel: Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
feb 07 11:58:51 _hostname_ kernel: Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
feb 07 11:58:51 _hostname_ kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
feb 07 11:58:51 _hostname_ kernel: Spectre V2 : Mitigation: Full generic retpoline
feb 07 11:58:51 _hostname_ kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
feb 07 11:58:51 _hostname_ kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
feb 07 11:58:51 _hostname_ kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
feb 07 11:58:51 _hostname_ kernel: Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
feb 07 11:58:51 _hostname_ kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
feb 07 11:58:51 _hostname_ kernel: SRBDS: Mitigation: Microcode
feb 07 11:58:51 _hostname_ kernel: MDS: Mitigation: Clear CPU buffers
feb 07 11:58:51 _hostname_ kernel: Freeing SMP alternatives memory: 36K
feb 07 11:58:51 _hostname_ kernel: smpboot: CPU0: Intel(R) Core(TM) i7-4720HQ CPU @ 2.60GHz (family: 0x6, model: 0x3c, stepping: 0x3)
feb 07 11:58:51 _hostname_ kernel: Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
feb 07 11:58:51 _hostname_ kernel: ... version: 3
feb 07 11:58:51 _hostname_ kernel: ... bit width: 48
feb 07 11:58:51 _hostname_ kernel: ... generic registers: 4
feb 07 11:58:51 _hostname_ kernel: ... value mask: 0000ffffffffffff
feb 07 11:58:51 _hostname_ kernel: ... max period: 00007fffffffffff
feb 07 11:58:51 _hostname_ kernel: ... fixed-purpose events: 3
feb 07 11:58:51 _hostname_ kernel: ... event mask: 000000070000000f
feb 07 11:58:51 _hostname_ kernel: rcu: Hierarchical SRCU implementation.
feb 07 11:58:51 _hostname_ kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
feb 07 11:58:51 _hostname_ kernel: smp: Bringing up secondary CPUs ...
feb 07 11:58:51 _hostname_ kernel: x86: Booting SMP configuration:
feb 07 11:58:51 _hostname_ kernel: .... node #0, CPUs: #1
feb 07 11:58:51 _hostname_ kernel: [Firmware Bug]: TSC ADJUST differs within socket(s), fixing all errors
feb 07 11:58:51 _hostname_ kernel: #2 #3 #4
feb 07 11:58:51 _hostname_ kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
feb 07 11:58:51 _hostname_ kernel: #5 #6 #7
feb 07 11:58:51 _hostname_ kernel: smp: Brought up 1 node, 8 CPUs
feb 07 11:58:51 _hostname_ kernel: smpboot: Max logical packages: 1
feb 07 11:58:51 _hostname_ kernel: smpboot: Total of 8 processors activated (41594.88 BogoMIPS)
feb 07 11:58:51 _hostname_ kernel: devtmpfs: initialized
feb 07 11:58:51 _hostname_ kernel: x86/mm: Memory block size: 128MB
feb 07 11:58:51 _hostname_ kernel: PM: Registering ACPI NVS region [mem 0xca3ab000-0xcad12fff] (9863168 bytes)
feb 07 11:58:51 _hostname_ kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
feb 07 11:58:51 _hostname_ kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
feb 07 11:58:51 _hostname_ kernel: pinctrl core: initialized pinctrl subsystem
feb 07 11:58:51 _hostname_ kernel: PM: RTC time: 10:58:47, date: 2021-02-07
feb 07 11:58:51 _hostname_ kernel: NET: Registered protocol family 16
feb 07 11:58:51 _hostname_ kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
feb 07 11:58:51 _hostname_ kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
feb 07 11:58:51 _hostname_ kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
feb 07 11:58:51 _hostname_ kernel: audit: initializing netlink subsys (disabled)
feb 07 11:58:51 _hostname_ kernel: audit: type=2000 audit(1612695527.066:1): state=initialized audit_enabled=0 res=1
feb 07 11:58:51 _hostname_ kernel: thermal_sys: Registered thermal governor 'fair_share'
feb 07 11:58:51 _hostname_ kernel: thermal_sys: Registered thermal governor 'bang_bang'
feb 07 11:58:51 _hostname_ kernel: thermal_sys: Registered thermal governor 'step_wise'
feb 07 11:58:51 _hostname_ kernel: thermal_sys: Registered thermal governor 'user_space'
feb 07 11:58:51 _hostname_ kernel: thermal_sys: Registered thermal governor 'power_allocator'
feb 07 11:58:51 _hostname_ kernel: cpuidle: using governor ladder
feb 07 11:58:51 _hostname_ kernel: cpuidle: using governor menu
feb 07 11:58:51 _hostname_ kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
feb 07 11:58:51 _hostname_ kernel: ACPI: bus type PCI registered
feb 07 11:58:51 _hostname_ kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
feb 07 11:58:51 _hostname_ kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
feb 07 11:58:51 _hostname_ kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
feb 07 11:58:51 _hostname_ kernel: pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
feb 07 11:58:51 _hostname_ kernel: PCI: Using configuration type 1 for base access
feb 07 11:58:51 _hostname_ kernel: core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
feb 07 11:58:51 _hostname_ kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
feb 07 11:58:51 _hostname_ kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
feb 07 11:58:51 _hostname_ kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
feb 07 11:58:51 _hostname_ kernel: ACPI: Added _OSI(Module Device)
feb 07 11:58:51 _hostname_ kernel: ACPI: Added _OSI(Processor Device)
feb 07 11:58:51 _hostname_ kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
feb 07 11:58:51 _hostname_ kernel: ACPI: Added _OSI(Processor Aggregator Device)
feb 07 11:58:51 _hostname_ kernel: ACPI: Added _OSI(Linux-Dell-Video)
feb 07 11:58:51 _hostname_ kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
feb 07 11:58:51 _hostname_ kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
feb 07 11:58:51 _hostname_ kernel: ACPI: 9 ACPI AML tables successfully acquired and loaded
feb 07 11:58:51 _hostname_ kernel: ACPI: Dynamic OEM Table Load:
feb 07 11:58:51 _hostname_ kernel: ACPI: SSDT 0xFFFF9EAD40C9C800 0003D3 (v02 PmRef Cpu0Cst 00003001 INTL 20120913)
feb 07 11:58:51 _hostname_ kernel: ACPI: SSDT 0xFFFF9EAD40C40800 0005AA (v02 PmRef ApIst 00003000 INTL 20120913)
feb 07 11:58:51 _hostname_ kernel: ACPI: SSDT 0xFFFF9EAD4114F600 000119 (v02 PmRef ApCst 00003000 INTL 20120913)
feb 07 11:58:51 _hostname_ kernel: ACPI: EC: EC started
feb 07 11:58:51 _hostname_ kernel: ACPI: EC: interrupt blocked
feb 07 11:58:51 _hostname_ kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
feb 07 11:58:51 _hostname_ kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
feb 07 11:58:51 _hostname_ kernel: ACPI: Interpreter enabled
feb 07 11:58:51 _hostname_ kernel: ACPI: (supports S0 S3 S4 S5)
feb 07 11:58:51 _hostname_ kernel: ACPI: Using IOAPIC for interrupt routing
feb 07 11:58:51 _hostname_ kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
feb 07 11:58:51 _hostname_ kernel: ACPI: Enabled 7 GPEs in block 00 to 3F
feb 07 11:58:51 _hostname_ kernel: ACPI: Power Resource [PG00] (on)
feb 07 11:58:51 _hostname_ kernel: ACPI: Power Resource [PG01] (on)
feb 07 11:58:51 _hostname_ kernel: ACPI: Power Resource [PG02] (on)
feb 07 11:58:51 _hostname_ kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
feb 07 11:58:51 _hostname_ kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
feb 07 11:58:51 _hostname_ kernel: acpi PNP0A08:00: _OSC: platform does not support [PCIeCapability]
feb 07 11:58:51 _hostname_ kernel: acpi PNP0A08:00: _OSC: not requesting control; platform does not support [PCIeCapability]
feb 07 11:58:51 _hostname_ kernel: acpi PNP0A08:00: _OSC: OS requested [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
feb 07 11:58:51 _hostname_ kernel: acpi PNP0A08:00: _OSC: platform willing to grant [PCIeHotplug SHPCHotplug PME AER LTR DPC]
feb 07 11:58:51 _hostname_ kernel: acpi PNP0A08:00: _OSC failed (AE_SUPPORT); disabling ASPM
feb 07 11:58:51 _hostname_ kernel: PCI host bridge to bus 0000:00
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [mem 0xcfa00000-0xfeafffff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: root bus resource [bus 00-3e]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:00.0: [8086:0c04] type 00 class 0x060000
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:01.0: [8086:0c01] type 01 class 0x060400
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:02.0: [8086:0416] type 00 class 0x030000
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:02.0: reg 0x10: [mem 0xf6400000-0xf67fffff 64bit]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:02.0: reg 0x18: [mem 0xd0000000-0xdfffffff 64bit pref]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:02.0: BAR 2: assigned to efifb
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:03.0: [8086:0c0c] type 00 class 0x040300
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:03.0: reg 0x10: [mem 0xf751c000-0xf751ffff 64bit]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:04.0: [8086:0c03] type 00 class 0x118000
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:04.0: reg 0x10: [mem 0xf7510000-0xf7517fff 64bit]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:14.0: reg 0x10: [mem 0xf7500000-0xf750ffff 64bit]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:16.0: reg 0x10: [mem 0xf7525000-0xf752500f 64bit]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1a.0: reg 0x10: [mem 0xf7523000-0xf75233ff]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1b.0: reg 0x10: [mem 0xf7518000-0xf751bfff 64bit]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.0: [8086:8c14] type 01 class 0x060400
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.3: [8086:8c16] type 01 class 0x060400
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.4: [8086:8c18] type 01 class 0x060400
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1d.0: reg 0x10: [mem 0xf7522000-0xf75223ff]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1f.0: [8086:8c4b] type 00 class 0x060100
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1f.2: [8086:8c03] type 00 class 0x010601
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1f.2: reg 0x10: [io 0xf0b0-0xf0b7]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1f.2: reg 0x14: [io 0xf0a0-0xf0a3]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1f.2: reg 0x18: [io 0xf090-0xf097]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1f.2: reg 0x1c: [io 0xf080-0xf083]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1f.2: reg 0x20: [io 0xf060-0xf07f]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1f.2: reg 0x24: [mem 0xf7521000-0xf75217ff]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1f.2: PME# supported from D3hot
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xf7520000-0xf75200ff 64bit]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1f.3: reg 0x20: [io 0xf040-0xf05f]
feb 07 11:58:51 _hostname_ kernel: pci 0000:01:00.0: [10de:13d8] type 00 class 0x030200
feb 07 11:58:51 _hostname_ kernel: pci 0000:01:00.0: reg 0x10: [mem 0xf5000000-0xf5ffffff]
feb 07 11:58:51 _hostname_ kernel: pci 0000:01:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
feb 07 11:58:51 _hostname_ kernel: pci 0000:01:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
feb 07 11:58:51 _hostname_ kernel: pci 0000:01:00.0: reg 0x24: [io 0xe000-0xe07f]
feb 07 11:58:51 _hostname_ kernel: pci 0000:01:00.0: reg 0x30: [mem 0xf6000000-0xf607ffff pref]
feb 07 11:58:51 _hostname_ kernel: pci 0000:01:00.0: Enabling HDA controller
feb 07 11:58:51 _hostname_ kernel: pci 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x8 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:01.0: PCI bridge to [bus 01]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:01.0: bridge window [mem 0xf5000000-0xf60fffff]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:01.0: bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
feb 07 11:58:51 _hostname_ kernel: pci 0000:02:00.0: [1969:e091] type 00 class 0x020000
feb 07 11:58:51 _hostname_ kernel: pci 0000:02:00.0: reg 0x10: [mem 0xf7400000-0xf743ffff 64bit]
feb 07 11:58:51 _hostname_ kernel: pci 0000:02:00.0: reg 0x18: [io 0xd000-0xd07f]
feb 07 11:58:51 _hostname_ kernel: pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.0: PCI bridge to [bus 02]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.0: bridge window [io 0xd000-0xdfff]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.0: bridge window [mem 0xf7400000-0xf74fffff]
feb 07 11:58:51 _hostname_ kernel: pci 0000:03:00.0: [168c:003e] type 00 class 0x028000
feb 07 11:58:51 _hostname_ kernel: pci 0000:03:00.0: reg 0x10: [mem 0xf6800000-0xf69fffff 64bit]
feb 07 11:58:51 _hostname_ kernel: pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.3: PCI bridge to [bus 03]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.3: bridge window [mem 0xf6800000-0xf69fffff]
feb 07 11:58:51 _hostname_ kernel: acpiphp: Slot [1] registered
feb 07 11:58:51 _hostname_ kernel: pci 0000:04:00.0: [10ec:5227] type 00 class 0xff0000
feb 07 11:58:51 _hostname_ kernel: pci 0000:04:00.0: reg 0x10: [mem 0xf6a00000-0xf6a00fff]
feb 07 11:58:51 _hostname_ kernel: pci 0000:04:00.0: supports D1 D2
feb 07 11:58:51 _hostname_ kernel: pci 0000:04:00.0: PME# supported from D1 D2 D3hot D3cold
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.4: PCI bridge to [bus 04]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.4: bridge window [io 0xc000-0xcfff]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.4: bridge window [mem 0xf6a00000-0xf73fffff]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1c.4: bridge window [mem 0xf2100000-0xf2afffff 64bit pref]
feb 07 11:58:51 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
feb 07 11:58:51 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
feb 07 11:58:51 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
feb 07 11:58:51 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
feb 07 11:58:51 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
feb 07 11:58:51 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
feb 07 11:58:51 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
feb 07 11:58:51 _hostname_ kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
feb 07 11:58:51 _hostname_ kernel: ACPI: EC: interrupt unblocked
feb 07 11:58:51 _hostname_ kernel: ACPI: EC: event unblocked
feb 07 11:58:51 _hostname_ kernel: ACPI: EC: GPE=0x17
feb 07 11:58:51 _hostname_ kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC initialization complete
feb 07 11:58:51 _hostname_ kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
feb 07 11:58:51 _hostname_ kernel: iommu: Default domain type: Translated
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:02.0: vgaarb: bridge control possible
feb 07 11:58:51 _hostname_ kernel: vgaarb: loaded
feb 07 11:58:51 _hostname_ kernel: SCSI subsystem initialized
feb 07 11:58:51 _hostname_ kernel: libata version 3.00 loaded.
feb 07 11:58:51 _hostname_ kernel: ACPI: bus type USB registered
feb 07 11:58:51 _hostname_ kernel: usbcore: registered new interface driver usbfs
feb 07 11:58:51 _hostname_ kernel: usbcore: registered new interface driver hub
feb 07 11:58:51 _hostname_ kernel: usbcore: registered new device driver usb
feb 07 11:58:51 _hostname_ kernel: pps_core: LinuxPPS API ver. 1 registered
feb 07 11:58:51 _hostname_ kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
feb 07 11:58:51 _hostname_ kernel: PTP clock support registered
feb 07 11:58:51 _hostname_ kernel: EDAC MC: Ver: 3.0.0
feb 07 11:58:51 _hostname_ kernel: Registered efivars operations
feb 07 11:58:51 _hostname_ kernel: NetLabel: Initializing
feb 07 11:58:51 _hostname_ kernel: NetLabel: domain hash size = 128
feb 07 11:58:51 _hostname_ kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
feb 07 11:58:51 _hostname_ kernel: NetLabel: unlabeled traffic allowed by default
feb 07 11:58:51 _hostname_ kernel: PCI: Using ACPI for IRQ routing
feb 07 11:58:51 _hostname_ kernel: PCI: pci_cache_line_size set to 64 bytes
feb 07 11:58:51 _hostname_ kernel: e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
feb 07 11:58:51 _hostname_ kernel: e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
feb 07 11:58:51 _hostname_ kernel: e820: reserve RAM buffer [mem 0xbc722000-0xbfffffff]
feb 07 11:58:51 _hostname_ kernel: e820: reserve RAM buffer [mem 0xc7997000-0xc7ffffff]
feb 07 11:58:51 _hostname_ kernel: e820: reserve RAM buffer [mem 0xc9b6a000-0xcbffffff]
feb 07 11:58:51 _hostname_ kernel: e820: reserve RAM buffer [mem 0xcb000000-0xcbffffff]
feb 07 11:58:51 _hostname_ kernel: e820: reserve RAM buffer [mem 0x42f600000-0x42fffffff]
feb 07 11:58:51 _hostname_ kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
feb 07 11:58:51 _hostname_ kernel: hpet0: 8 comparators, 64-bit 14.318180 MHz counter
feb 07 11:58:51 _hostname_ kernel: clocksource: Switched to clocksource tsc-early
feb 07 11:58:51 _hostname_ kernel: VFS: Disk quotas dquot_6.6.0
feb 07 11:58:51 _hostname_ kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
feb 07 11:58:51 _hostname_ kernel: AppArmor: AppArmor Filesystem Enabled
feb 07 11:58:51 _hostname_ kernel: pnp: PnP ACPI init
feb 07 11:58:51 _hostname_ kernel: pnp 00:00: Plug and Play ACPI device, IDs PNP0303 (active)
feb 07 11:58:51 _hostname_ kernel: pnp 00:01: Plug and Play ACPI device, IDs DLL0685 PNP0f13 (active)
feb 07 11:58:51 _hostname_ kernel: system 00:02: [io 0x0680-0x069f] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:02: [io 0xffff] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:02: [io 0x1800-0x18fe] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:02: [io 0x164e-0x164f] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
feb 07 11:58:51 _hostname_ kernel: system 00:03: [io 0x0800-0x087f] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
feb 07 11:58:51 _hostname_ kernel: pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
feb 07 11:58:51 _hostname_ kernel: system 00:05: [io 0x1854-0x1857] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:05: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
feb 07 11:58:51 _hostname_ kernel: system 00:06: [mem 0xfed1c000-0xfed1ffff] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:06: [mem 0xf8000000-0xfbffffff] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:06: [mem 0xfed90000-0xfed93fff] could not be reserved
feb 07 11:58:51 _hostname_ kernel: system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:06: [mem 0xff000000-0xffffffff] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
feb 07 11:58:51 _hostname_ kernel: system 00:06: [mem 0xf7fe0000-0xf7feffff] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:06: [mem 0xf7ff0000-0xf7ffffff] has been reserved
feb 07 11:58:51 _hostname_ kernel: system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
feb 07 11:58:51 _hostname_ kernel: pnp: PnP ACPI: found 7 devices
feb 07 11:58:51 _hostname_ kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
feb 07 11:58:51 _hostname_ kernel: NET: Registered protocol family 2
feb 07 11:58:51 _hostname_ kernel: tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
feb 07 11:58:51 _hostname_ kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
feb 07 11:58:51 _hostname_ kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
feb 07 11:58:51 _hostname_ kernel: TCP: Hash tables configured (established 131072 bind 65536)
feb 07 11:58:51 _hostname_ kernel: MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
feb 07 11:58:51 _hostname_ kernel: UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
feb 07 11:58:51 _hostname_ kernel: UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
feb 07 11:58:51 _hostname_ kernel: NET: Registered protocol family 44
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 15 [mem 0x000e0000-0x000e3fff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 16 [mem 0x000e4000-0x000e7fff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 17 [mem 0x000e8000-0x000ebfff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 18 [mem 0x000ec000-0x000effff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:00: resource 19 [mem 0xcfa00000-0xfeafffff window]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:01: resource 1 [mem 0xf5000000-0xf60fffff]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:01: resource 2 [mem 0xe0000000-0xf1ffffff 64bit pref]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:02: resource 1 [mem 0xf7400000-0xf74fffff]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:03: resource 1 [mem 0xf6800000-0xf69fffff]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:04: resource 0 [io 0xc000-0xcfff]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:04: resource 1 [mem 0xf6a00000-0xf73fffff]
feb 07 11:58:51 _hostname_ kernel: pci_bus 0000:04: resource 2 [mem 0xf2100000-0xf2afffff 64bit pref]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x730 took 18846 usecs
feb 07 11:58:51 _hostname_ kernel: pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x730 took 19458 usecs
feb 07 11:58:51 _hostname_ kernel: pci 0000:02:00.0: set MSI_INTX_DISABLE_BUG flag
feb 07 11:58:51 _hostname_ kernel: PCI: CLS 64 bytes, default 64
feb 07 11:58:51 _hostname_ kernel: Trying to unpack rootfs image as initramfs...
feb 07 11:58:51 _hostname_ kernel: Freeing initrd memory: 10660K
feb 07 11:58:51 _hostname_ kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
feb 07 11:58:51 _hostname_ kernel: software IO TLB: mapped [mem 0x00000000c2a79000-0x00000000c6a79000] (64MB)
feb 07 11:58:51 _hostname_ kernel: check: Scanning for low memory corruption every 60 seconds
feb 07 11:58:51 _hostname_ kernel: Initialise system trusted keyrings
feb 07 11:58:51 _hostname_ kernel: Key type blacklist registered
feb 07 11:58:51 _hostname_ kernel: workingset: timestamp_bits=41 max_order=22 bucket_order=0
feb 07 11:58:51 _hostname_ kernel: zbud: loaded
feb 07 11:58:51 _hostname_ kernel: Key type asymmetric registered
feb 07 11:58:51 _hostname_ kernel: Asymmetric key parser 'x509' registered
feb 07 11:58:51 _hostname_ kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
feb 07 11:58:51 _hostname_ kernel: io scheduler mq-deadline registered
feb 07 11:58:51 _hostname_ kernel: io scheduler kyber registered
feb 07 11:58:51 _hostname_ kernel: io scheduler bfq registered
feb 07 11:58:51 _hostname_ kernel: atomic64_test: passed for x86-64 platform with CX8 and with SSE
feb 07 11:58:51 _hostname_ kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
feb 07 11:58:51 _hostname_ kernel: efifb: probing for efifb
feb 07 11:58:51 _hostname_ kernel: efifb: framebuffer at 0xd0000000, using 8128k, total 8128k
feb 07 11:58:51 _hostname_ kernel: efifb: mode is 1920x1080x32, linelength=7680, pages=1
feb 07 11:58:51 _hostname_ kernel: efifb: scrolling: redraw
feb 07 11:58:51 _hostname_ kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
feb 07 11:58:51 _hostname_ kernel: fbcon: Deferring console take-over
feb 07 11:58:51 _hostname_ kernel: fb0: EFI VGA frame buffer device
feb 07 11:58:51 _hostname_ kernel: intel_idle: MWAIT substates: 0x42120
feb 07 11:58:51 _hostname_ kernel: intel_idle: v0.5.1 model 0x3C
feb 07 11:58:51 _hostname_ kernel: intel_idle: Local APIC timer is reliable in all C-states
feb 07 11:58:51 _hostname_ kernel: ACPI: AC Adapter [ACAD] (on-line)
feb 07 11:58:51 _hostname_ kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:27/PNP0C0D:01/input/input0
feb 07 11:58:51 _hostname_ kernel: ACPI: Lid Switch [LID0]
feb 07 11:58:51 _hostname_ kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
feb 07 11:58:51 _hostname_ kernel: ACPI: Power Button [PWRB]
feb 07 11:58:51 _hostname_ kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
feb 07 11:58:51 _hostname_ kernel: ACPI: Power Button [PWRF]
feb 07 11:58:51 _hostname_ kernel: thermal LNXTHERM:00: registered as thermal_zone0
feb 07 11:58:51 _hostname_ kernel: ACPI: Thermal Zone [TZ00] (28 C)
feb 07 11:58:51 _hostname_ kernel: thermal LNXTHERM:01: registered as thermal_zone1
feb 07 11:58:51 _hostname_ kernel: ACPI: Thermal Zone [TZ01] (30 C)
feb 07 11:58:51 _hostname_ kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
feb 07 11:58:51 _hostname_ kernel: Non-volatile memory driver v1.3
feb 07 11:58:51 _hostname_ kernel: AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
feb 07 11:58:51 _hostname_ kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system
feb 07 11:58:51 _hostname_ kernel: ahci 0000:00:1f.2: version 3.0
feb 07 11:58:51 _hostname_ kernel: ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x23 impl SATA mode
feb 07 11:58:51 _hostname_ kernel: ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
feb 07 11:58:51 _hostname_ kernel: scsi host0: ahci
feb 07 11:58:51 _hostname_ kernel: scsi host1: ahci
feb 07 11:58:51 _hostname_ kernel: scsi host2: ahci
feb 07 11:58:51 _hostname_ kernel: scsi host3: ahci
feb 07 11:58:51 _hostname_ kernel: scsi host4: ahci
feb 07 11:58:51 _hostname_ kernel: scsi host5: ahci
feb 07 11:58:51 _hostname_ kernel: ata1: SATA max UDMA/133 abar m2048@0xf7521000 port 0xf7521100 irq 30
feb 07 11:58:51 _hostname_ kernel: ata2: SATA max UDMA/133 abar m2048@0xf7521000 port 0xf7521180 irq 30
feb 07 11:58:51 _hostname_ kernel: ata3: DUMMY
feb 07 11:58:51 _hostname_ kernel: ata4: DUMMY
feb 07 11:58:51 _hostname_ kernel: ata5: DUMMY
feb 07 11:58:51 _hostname_ kernel: ata6: SATA max UDMA/133 abar m2048@0xf7521000 port 0xf7521380 irq 30
feb 07 11:58:51 _hostname_ kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
feb 07 11:58:51 _hostname_ kernel: ehci-pci: EHCI PCI platform driver
feb 07 11:58:51 _hostname_ kernel: ehci-pci 0000:00:1a.0: EHCI Host Controller
feb 07 11:58:51 _hostname_ kernel: ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
feb 07 11:58:51 _hostname_ kernel: ehci-pci 0000:00:1a.0: debug port 2
feb 07 11:58:51 _hostname_ kernel: ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
feb 07 11:58:51 _hostname_ kernel: ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7523000
feb 07 11:58:51 _hostname_ kernel: ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
feb 07 11:58:51 _hostname_ kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
feb 07 11:58:51 _hostname_ kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
feb 07 11:58:51 _hostname_ kernel: usb usb1: Product: EHCI Host Controller
feb 07 11:58:51 _hostname_ kernel: usb usb1: Manufacturer: Linux 5.10.7-3-MANJARO ehci_hcd
feb 07 11:58:51 _hostname_ kernel: usb usb1: SerialNumber: 0000:00:1a.0
feb 07 11:58:51 _hostname_ kernel: hub 1-0:1.0: USB hub found
feb 07 11:58:51 _hostname_ kernel: hub 1-0:1.0: 2 ports detected
feb 07 11:58:51 _hostname_ kernel: ehci-pci 0000:00:1d.0: EHCI Host Controller
feb 07 11:58:51 _hostname_ kernel: ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
feb 07 11:58:51 _hostname_ kernel: ehci-pci 0000:00:1d.0: debug port 2
feb 07 11:58:51 _hostname_ kernel: battery: [Firmware Bug]: battery: (dis)charge rate invalid.
feb 07 11:58:51 _hostname_ kernel: battery: ACPI: Battery Slot [BAT1] (battery present)
feb 07 11:58:51 _hostname_ kernel: ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
feb 07 11:58:51 _hostname_ kernel: ehci-pci 0000:00:1d.0: irq 22, io mem 0xf7522000
feb 07 11:58:51 _hostname_ kernel: ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
feb 07 11:58:51 _hostname_ kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
feb 07 11:58:51 _hostname_ kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
feb 07 11:58:51 _hostname_ kernel: usb usb2: Product: EHCI Host Controller
feb 07 11:58:51 _hostname_ kernel: usb usb2: Manufacturer: Linux 5.10.7-3-MANJARO ehci_hcd
feb 07 11:58:51 _hostname_ kernel: usb usb2: SerialNumber: 0000:00:1d.0
feb 07 11:58:51 _hostname_ kernel: hub 2-0:1.0: USB hub found
feb 07 11:58:51 _hostname_ kernel: hub 2-0:1.0: 2 ports detected
feb 07 11:58:51 _hostname_ kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
feb 07 11:58:51 _hostname_ kernel: ohci-pci: OHCI PCI platform driver
feb 07 11:58:51 _hostname_ kernel: uhci_hcd: USB Universal Host Controller Interface driver
feb 07 11:58:51 _hostname_ kernel: usbcore: registered new interface driver usbserial_generic
feb 07 11:58:51 _hostname_ kernel: usbserial: USB Serial support registered for generic
feb 07 11:58:51 _hostname_ kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
feb 07 11:58:51 _hostname_ kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
feb 07 11:58:51 _hostname_ kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
feb 07 11:58:51 _hostname_ kernel: rtc_cmos 00:04: RTC can wake from S4
feb 07 11:58:51 _hostname_ kernel: rtc_cmos 00:04: registered as rtc0
feb 07 11:58:51 _hostname_ kernel: rtc_cmos 00:04: setting system clock to 2021-02-07T10:58:48 UTC (1612695528)
feb 07 11:58:51 _hostname_ kernel: rtc_cmos 00:04: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
feb 07 11:58:51 _hostname_ kernel: intel_pstate: Intel P-state driver initializing
feb 07 11:58:51 _hostname_ kernel: ledtrig-cpu: registered to indicate activity on CPUs
feb 07 11:58:51 _hostname_ kernel: pstore: Registered efi as persistent store backend
feb 07 11:58:51 _hostname_ kernel: hid: raw HID events driver (C) Jiri Kosina
feb 07 11:58:51 _hostname_ kernel: ashmem: initialized
feb 07 11:58:51 _hostname_ kernel: drop_monitor: Initializing network drop monitor service
feb 07 11:58:51 _hostname_ kernel: Initializing XFRM netlink socket
feb 07 11:58:51 _hostname_ kernel: NET: Registered protocol family 10
feb 07 11:58:51 _hostname_ kernel: Segment Routing with IPv6
feb 07 11:58:51 _hostname_ kernel: RPL Segment Routing with IPv6
feb 07 11:58:51 _hostname_ kernel: NET: Registered protocol family 17
feb 07 11:58:51 _hostname_ kernel: microcode: sig=0x306c3, pf=0x20, revision=0x28
feb 07 11:58:51 _hostname_ kernel: microcode: Microcode Update Driver: v2.2.
feb 07 11:58:51 _hostname_ kernel: IPI shorthand broadcast: enabled
feb 07 11:58:51 _hostname_ kernel: sched_clock: Marking stable (1501468014, 969593)->(1511639109, -9201502)
feb 07 11:58:51 _hostname_ kernel: registered taskstats version 1
feb 07 11:58:51 _hostname_ kernel: Loading compiled-in X.509 certificates
feb 07 11:58:51 _hostname_ kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 8a686ad556c46e452fd7dfcd5b8bb6b61e7f128b'
feb 07 11:58:51 _hostname_ kernel: zswap: loaded using pool zstd/z3fold
feb 07 11:58:51 _hostname_ kernel: Key type ._fscrypt registered
feb 07 11:58:51 _hostname_ kernel: Key type .fscrypt registered
feb 07 11:58:51 _hostname_ kernel: Key type fscrypt-provisioning registered
feb 07 11:58:51 _hostname_ kernel: pstore: Using crash dump compression: zstd
feb 07 11:58:51 _hostname_ kernel: AppArmor: AppArmor sha1 policy hashing enabled
feb 07 11:58:51 _hostname_ kernel: PM: Magic number: 9:3:982
feb 07 11:58:51 _hostname_ kernel: RAS: Correctable Errors collector initialized.
feb 07 11:58:51 _hostname_ kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
feb 07 11:58:51 _hostname_ kernel: ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
feb 07 11:58:51 _hostname_ kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
feb 07 11:58:51 _hostname_ kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
feb 07 11:58:51 _hostname_ kernel: ata2.00: supports DRM functions and may not be fully accessible
feb 07 11:58:51 _hostname_ kernel: ata2.00: ATA-10: CT500MX500SSD4, M3CR023, max UDMA/133
feb 07 11:58:51 _hostname_ kernel: ata2.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
feb 07 11:58:51 _hostname_ kernel: ata1.00: ATA-8: HGST HTS721010A9E630, JB0OA3P0, max UDMA/133
feb 07 11:58:51 _hostname_ kernel: ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
feb 07 11:58:51 _hostname_ kernel: ata6.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
feb 07 11:58:51 _hostname_ kernel: ata6.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
feb 07 11:58:51 _hostname_ kernel: ata6.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
feb 07 11:58:51 _hostname_ kernel: ata6.00: ATA-8: LITEONIT L8T-256L9G-11 M.2 2280 256GB, H88110C, max UDMA/133
feb 07 11:58:51 _hostname_ kernel: ata6.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 32), AA
feb 07 11:58:51 _hostname_ kernel: ata6.00: configured for UDMA/133
feb 07 11:58:51 _hostname_ kernel: ata1.00: configured for UDMA/133
feb 07 11:58:51 _hostname_ kernel: ata2.00: configured for UDMA/133
feb 07 11:58:51 _hostname_ kernel: scsi 0:0:0:0: Direct-Access ATA HGST HTS721010A9 A3P0 PQ: 0 ANSI: 5
feb 07 11:58:51 _hostname_ kernel: sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
feb 07 11:58:51 _hostname_ kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
feb 07 11:58:51 _hostname_ kernel: sd 0:0:0:0: [sda] Write Protect is off
feb 07 11:58:51 _hostname_ kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
feb 07 11:58:51 _hostname_ kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
feb 07 11:58:51 _hostname_ kernel: scsi 1:0:0:0: Direct-Access ATA CT500MX500SSD4 023 PQ: 0 ANSI: 5
feb 07 11:58:51 _hostname_ kernel: sd 1:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/466 GiB)
feb 07 11:58:51 _hostname_ kernel: sd 1:0:0:0: [sdb] Write Protect is off
feb 07 11:58:51 _hostname_ kernel: sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
feb 07 11:58:51 _hostname_ kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
feb 07 11:58:51 _hostname_ kernel: scsi 5:0:0:0: Direct-Access ATA LITEONIT L8T-256 10C PQ: 0 ANSI: 5
feb 07 11:58:51 _hostname_ kernel: sd 5:0:0:0: [sdc] 500118192 512-byte logical blocks: (256 GB/238 GiB)
feb 07 11:58:51 _hostname_ kernel: sd 5:0:0:0: [sdc] Write Protect is off
feb 07 11:58:51 _hostname_ kernel: sd 5:0:0:0: [sdc] Mode Sense: 00 3a 00 00
feb 07 11:58:51 _hostname_ kernel: sd 5:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
feb 07 11:58:51 _hostname_ kernel: sdc: sdc1 sdc2 sdc3 sdc4
feb 07 11:58:51 _hostname_ kernel: sd 5:0:0:0: [sdc] Attached SCSI disk
feb 07 11:58:51 _hostname_ kernel: sdb: sdb1 sdb2 sdb3 sdb4
feb 07 11:58:51 _hostname_ kernel: sd 1:0:0:0: [sdb] supports TCG Opal
feb 07 11:58:51 _hostname_ kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
feb 07 11:58:51 _hostname_ kernel: usb 1-1: new high-speed USB device number 2 using ehci-pci
feb 07 11:58:51 _hostname_ kernel: usb 2-1: new high-speed USB device number 2 using ehci-pci
feb 07 11:58:51 _hostname_ kernel: usb 1-1: New USB device found, idVendor=8087, idProduct=8008, bcdDevice= 0.05
feb 07 11:58:51 _hostname_ kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
feb 07 11:58:51 _hostname_ kernel: hub 1-1:1.0: USB hub found
feb 07 11:58:51 _hostname_ kernel: hub 1-1:1.0: 6 ports detected
feb 07 11:58:51 _hostname_ kernel: usb 2-1: New USB device found, idVendor=8087, idProduct=8000, bcdDevice= 0.05
feb 07 11:58:51 _hostname_ kernel: usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
feb 07 11:58:51 _hostname_ kernel: hub 2-1:1.0: USB hub found
feb 07 11:58:51 _hostname_ kernel: hub 2-1:1.0: 8 ports detected
feb 07 11:58:51 _hostname_ kernel: sda: sda1 sda2
feb 07 11:58:51 _hostname_ kernel: sd 0:0:0:0: [sda] Attached SCSI disk
feb 07 11:58:51 _hostname_ kernel: tsc: Refined TSC clocksource calibration: 2598.509 MHz
feb 07 11:58:51 _hostname_ kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2574bba45a9, max_idle_ns: 440795282291 ns
feb 07 11:58:51 _hostname_ kernel: psmouse serio1: synaptics: queried max coordinates: x [..5668], y [..4756]
feb 07 11:58:51 _hostname_ kernel: psmouse serio1: synaptics: queried min coordinates: x [1274..], y [1098..]
feb 07 11:58:51 _hostname_ kernel: psmouse serio1: synaptics: Your touchpad (PNP: DLL0685 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
feb 07 11:58:51 _hostname_ kernel: random: fast init done
feb 07 11:58:51 _hostname_ kernel: psmouse serio1: synaptics: Touchpad model: 1, fw: 8.1, id: 0x1e2b1, caps: 0xd00123/0x840300/0x26c00/0x0, board id: 2417, fw id: 1365292
feb 07 11:58:51 _hostname_ kernel: input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input5
feb 07 11:58:51 _hostname_ kernel: Freeing unused decrypted memory: 2036K
feb 07 11:58:51 _hostname_ kernel: Freeing unused kernel image (initmem) memory: 1720K
feb 07 11:58:51 _hostname_ kernel: Write protecting the kernel read-only data: 22528k
feb 07 11:58:51 _hostname_ kernel: Freeing unused kernel image (text/rodata gap) memory: 2036K
feb 07 11:58:51 _hostname_ kernel: Freeing unused kernel image (rodata/data gap) memory: 1312K
feb 07 11:58:51 _hostname_ kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
feb 07 11:58:51 _hostname_ kernel: rodata_test: all tests were successful
feb 07 11:58:51 _hostname_ kernel: x86/mm: Checking user space page tables
feb 07 11:58:51 _hostname_ kernel: Run /init as init process
feb 07 11:58:51 _hostname_ kernel: with arguments:
feb 07 11:58:51 _hostname_ kernel: /init
feb 07 11:58:51 _hostname_ kernel: with environment:
feb 07 11:58:51 _hostname_ kernel: HOME=/
feb 07 11:58:51 _hostname_ kernel: TERM=linux
feb 07 11:58:51 _hostname_ kernel: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
feb 07 11:58:51 _hostname_ kernel: fbcon: Taking over console
feb 07 11:58:51 _hostname_ kernel: Console: switching to colour frame buffer device 240x67
feb 07 11:58:51 _hostname_ kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
feb 07 11:58:51 _hostname_ kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
feb 07 11:58:51 _hostname_ kernel: xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000009810
feb 07 11:58:51 _hostname_ kernel: xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
feb 07 11:58:51 _hostname_ kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
feb 07 11:58:51 _hostname_ kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
feb 07 11:58:51 _hostname_ kernel: usb usb3: Product: xHCI Host Controller
feb 07 11:58:51 _hostname_ kernel: usb usb3: Manufacturer: Linux 5.10.7-3-MANJARO xhci-hcd
feb 07 11:58:51 _hostname_ kernel: usb usb3: SerialNumber: 0000:00:14.0
feb 07 11:58:51 _hostname_ kernel: hub 3-0:1.0: USB hub found
feb 07 11:58:51 _hostname_ kernel: hub 3-0:1.0: 14 ports detected
feb 07 11:58:51 _hostname_ kernel: rtsx_pci 0000:04:00.0: enabling device (0000 -> 0002)
feb 07 11:58:51 _hostname_ kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
feb 07 11:58:51 _hostname_ kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
feb 07 11:58:51 _hostname_ kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
feb 07 11:58:51 _hostname_ kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
feb 07 11:58:51 _hostname_ kernel: usb usb4: Product: xHCI Host Controller
feb 07 11:58:51 _hostname_ kernel: usb usb4: Manufacturer: Linux 5.10.7-3-MANJARO xhci-hcd
feb 07 11:58:51 _hostname_ kernel: usb usb4: SerialNumber: 0000:00:14.0
feb 07 11:58:51 _hostname_ kernel: hub 4-0:1.0: USB hub found
feb 07 11:58:51 _hostname_ kernel: hub 4-0:1.0: 6 ports detected
feb 07 11:58:51 _hostname_ kernel: usb 3-1: new full-speed USB device number 2 using xhci_hcd
feb 07 11:58:51 _hostname_ kernel: PM: Image not found (code -22)
feb 07 11:58:51 _hostname_ kernel: EXT4-fs (sdc2): mounted filesystem with ordered data mode. Opts: (null)
feb 07 11:58:51 _hostname_ kernel: usb 3-1: New USB device found, idVendor=046d, idProduct=c539, bcdDevice=39.06
feb 07 11:58:51 _hostname_ kernel: usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
feb 07 11:58:51 _hostname_ kernel: usb 3-1: Product: USB Receiver
feb 07 11:58:51 _hostname_ kernel: usb 3-1: Manufacturer: Logitech
feb 07 11:58:51 _hostname_ systemd[1]: systemd 247.2-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
feb 07 11:58:51 _hostname_ kernel: usb 3-4: new full-speed USB device number 3 using xhci_hcd
feb 07 11:58:51 _hostname_ systemd[1]: Detected architecture x86-64.
feb 07 11:58:51 _hostname_ systemd[1]: Set hostname to <_hostname_>.
feb 07 11:58:51 _hostname_ kernel: usb 3-4: config 1 interface 0 altsetting 0 has 2 endpoint descriptors, different from the interface descriptor's value: 1
feb 07 11:58:51 _hostname_ kernel: usb 3-4: New USB device found, idVendor=187c, idProduct=0528, bcdDevice= 0.00
feb 07 11:58:51 _hostname_ kernel: usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
feb 07 11:58:51 _hostname_ kernel: usb 3-4: Product: AW1517
feb 07 11:58:51 _hostname_ kernel: usb 3-4: Manufacturer: Alienware
feb 07 11:58:51 _hostname_ kernel: usb 3-4: SerialNumber: 16.0
feb 07 11:58:51 _hostname_ kernel: usb 3-9: new full-speed USB device number 4 using xhci_hcd
feb 07 11:58:51 _hostname_ systemd[1]: Queued start job for default target Graphical Interface.
feb 07 11:58:51 _hostname_ systemd[1]: Created slice system-getty.slice.
feb 07 11:58:51 _hostname_ systemd[1]: Created slice system-modprobe.slice.
feb 07 11:58:51 _hostname_ systemd[1]: Created slice system-systemd\x2dfsck.slice.
feb 07 11:58:51 _hostname_ systemd[1]: Created slice User and Session Slice.
feb 07 11:58:51 _hostname_ systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
feb 07 11:58:51 _hostname_ systemd[1]: Started Forward Password Requests to Wall Directory Watch.
feb 07 11:58:51 _hostname_ systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
feb 07 11:58:51 _hostname_ systemd[1]: Reached target Local Encrypted Volumes.
feb 07 11:58:51 _hostname_ systemd[1]: Reached target Login Prompts.
feb 07 11:58:51 _hostname_ systemd[1]: Reached target Remote File Systems.
feb 07 11:58:51 _hostname_ systemd[1]: Reached target Slices.
feb 07 11:58:51 _hostname_ systemd[1]: Listening on Device-mapper event daemon FIFOs.
feb 07 11:58:51 _hostname_ systemd[1]: Listening on LVM2 metadata daemon socket.
feb 07 11:58:51 _hostname_ systemd[1]: Listening on LVM2 poll daemon socket.
feb 07 11:58:51 _hostname_ systemd[1]: Listening on Process Core Dump Socket.
feb 07 11:58:51 _hostname_ systemd[1]: Listening on Journal Audit Socket.
feb 07 11:58:51 _hostname_ systemd[1]: Listening on Journal Socket (/dev/log).
feb 07 11:58:51 _hostname_ systemd[1]: Listening on Journal Socket.
feb 07 11:58:51 _hostname_ systemd[1]: Listening on udev Control Socket.
feb 07 11:58:51 _hostname_ systemd[1]: Listening on udev Kernel Socket.
feb 07 11:58:51 _hostname_ systemd[1]: Mounting Huge Pages File System...
feb 07 11:58:51 _hostname_ systemd[1]: Mounting POSIX Message Queue File System...
feb 07 11:58:51 _hostname_ systemd[1]: Mounting Kernel Debug File System...
feb 07 11:58:51 _hostname_ systemd[1]: Mounting Kernel Trace File System...
feb 07 11:58:51 _hostname_ systemd[1]: Starting Load AppArmor profiles...
feb 07 11:58:51 _hostname_ systemd[1]: Starting Create list of static device nodes for the current kernel...
feb 07 11:58:51 _hostname_ systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
feb 07 11:58:51 _hostname_ systemd[1]: Starting Load Kernel Module configfs...
feb 07 11:58:51 _hostname_ systemd[1]: Starting Load Kernel Module drm...
feb 07 11:58:51 _hostname_ systemd[1]: Starting Load Kernel Module fuse...
feb 07 11:58:51 _hostname_ systemd[1]: Starting Set Up Additional Binary Formats...
feb 07 11:58:51 _hostname_ systemd[1]: Starting File System Check on Root Device...
feb 07 11:58:51 _hostname_ systemd[1]: Starting Journal Service...
feb 07 11:58:51 _hostname_ systemd[1]: Starting Load Kernel Modules...
feb 07 11:58:51 _hostname_ systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
feb 07 11:58:51 _hostname_ systemd[1]: Starting Coldplug All udev Devices...
feb 07 11:58:51 _hostname_ systemd[1]: Mounted Huge Pages File System.
feb 07 11:58:51 _hostname_ systemd[1]: Mounted POSIX Message Queue File System.
feb 07 11:58:51 _hostname_ systemd[1]: Mounted Kernel Debug File System.
feb 07 11:58:51 _hostname_ systemd[1]: Mounted Kernel Trace File System.
feb 07 11:58:51 _hostname_ systemd[1]: Finished Create list of static device nodes for the current kernel.
feb 07 11:58:51 _hostname_ systemd[1]: modprobe@configfs.service: Succeeded.
feb 07 11:58:51 _hostname_ systemd[1]: Finished Load Kernel Module configfs.
feb 07 11:58:51 _hostname_ systemd[1]: modprobe@drm.service: Succeeded.
feb 07 11:58:51 _hostname_ systemd[1]: Finished Load Kernel Module drm.
feb 07 11:58:51 _hostname_ systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 251 (systemd-binfmt)
feb 07 11:58:51 _hostname_ kernel: random: lvm: uninitialized urandom read (4 bytes read)
feb 07 11:58:51 _hostname_ systemd[1]: Mounting Arbitrary Executable File Formats File System...
feb 07 11:58:51 _hostname_ systemd[1]: Mounting Kernel Configuration File System...
feb 07 11:58:51 _hostname_ systemd[1]: Mounted Arbitrary Executable File Formats File System.
feb 07 11:58:51 _hostname_ systemd[1]: Mounted Kernel Configuration File System.
feb 07 11:58:51 _hostname_ kernel: fuse: init (API version 7.32)
feb 07 11:58:51 _hostname_ systemd[1]: modprobe@fuse.service: Succeeded.
feb 07 11:58:51 _hostname_ systemd[1]: Finished Load Kernel Module fuse.
feb 07 11:58:51 _hostname_ systemd[1]: Mounting FUSE Control File System...
feb 07 11:58:51 _hostname_ systemd[1]: Finished Set Up Additional Binary Formats.
feb 07 11:58:51 _hostname_ systemd[1]: Mounted FUSE Control File System.
feb 07 11:58:51 _hostname_ kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
feb 07 11:58:51 _hostname_ kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
feb 07 11:58:51 _hostname_ kernel: sd 5:0:0:0: Attached scsi generic sg2 type 0
feb 07 11:58:51 _hostname_ kernel: acpi_call: loading out-of-tree module taints kernel.
feb 07 11:58:51 _hostname_ kernel: acpi_call: module verification failed: signature and/or required key missing - tainting kernel
feb 07 11:58:51 _hostname_ systemd[1]: Finished File System Check on Root Device.
feb 07 11:58:51 _hostname_ kernel: audit: type=1130 audit(1612695531.369:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck-root comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ systemd[1]: Starting Remount Root and Kernel File Systems...
feb 07 11:58:51 _hostname_ kernel: Asymmetric key parser 'pkcs8' registered
feb 07 11:58:51 _hostname_ kernel: EXT4-fs (sdc2): re-mounted. Opts: (null)
feb 07 11:58:51 _hostname_ systemd[1]: Finished Remount Root and Kernel File Systems.
feb 07 11:58:51 _hostname_ kernel: audit: type=1130 audit(1612695531.382:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ systemd[1]: Condition check resulted in First Boot Wizard being skipped.
feb 07 11:58:51 _hostname_ systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
feb 07 11:58:51 _hostname_ systemd[1]: Starting Load/Save Random Seed...
feb 07 11:58:51 _hostname_ systemd[1]: Condition check resulted in Create System Users being skipped.
feb 07 11:58:51 _hostname_ systemd[1]: Starting Create Static Device Nodes in /dev...
feb 07 11:58:51 _hostname_ kernel: usb 3-9: New USB device found, idVendor=0cf3, idProduct=e300, bcdDevice= 0.01
feb 07 11:58:51 _hostname_ kernel: usb 3-9: New USB device strings: Mfr=0, Product=0, SerialNumber=0
feb 07 11:58:51 _hostname_ systemd[1]: Finished Load Kernel Modules.
feb 07 11:58:51 _hostname_ kernel: audit: type=1130 audit(1612695531.392:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ systemd[1]: Starting Apply Kernel Variables...
feb 07 11:58:51 _hostname_ systemd[1]: Finished Apply Kernel Variables.
feb 07 11:58:51 _hostname_ kernel: audit: type=1130 audit(1612695531.402:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ systemd-journald[254]: Journal started
feb 07 11:58:51 _hostname_ systemd-journald[254]: Runtime Journal (/run/log/journal/4406b921fb3245a69603e7c9594c5508) is 8.0M, max 794.7M, 786.7M free.
feb 07 11:58:51 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck-root comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ systemd-modules-load[255]: Inserted module 'crypto_user'
feb 07 11:58:51 _hostname_ systemd-modules-load[255]: Inserted module 'sg'
feb 07 11:58:51 _hostname_ systemd-modules-load[255]: Module 'msr' is built in
feb 07 11:58:51 _hostname_ systemd-modules-load[255]: Inserted module 'acpi_call'
feb 07 11:58:51 _hostname_ systemd-modules-load[255]: Module 'nvidia' is deny-listed
feb 07 11:58:51 _hostname_ apparmor.systemd[245]: Restarting AppArmor
feb 07 11:58:51 _hostname_ apparmor.systemd[245]: Reloading AppArmor profiles
feb 07 11:58:51 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ systemd-modules-load[255]: Module 'nvidia_drm' is deny-listed
feb 07 11:58:51 _hostname_ systemd-modules-load[255]: Inserted module 'pkcs8_key_parser'
feb 07 11:58:51 _hostname_ systemd-modules-load[255]: Inserted module 'uinput'
feb 07 11:58:51 _hostname_ systemd-sysctl[275]: Not setting net/ipv4/conf/all/rp_filter (explicit setting exists).
feb 07 11:58:51 _hostname_ systemd-sysctl[275]: Not setting net/ipv4/conf/default/rp_filter (explicit setting exists).
feb 07 11:58:51 _hostname_ systemd-sysctl[275]: Not setting net/ipv4/conf/all/accept_source_route (explicit setting exists).
feb 07 11:58:51 _hostname_ systemd-sysctl[275]: Not setting net/ipv4/conf/default/accept_source_route (explicit setting exists).
feb 07 11:58:51 _hostname_ systemd[1]: Started Journal Service.
feb 07 11:58:51 _hostname_ kernel: audit: type=1130 audit(1612695531.402:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ systemd-sysctl[275]: Not setting net/ipv4/conf/all/promote_secondaries (explicit setting exists).
feb 07 11:58:51 _hostname_ systemd-fsck[264]: /dev/sdc2: clean, 542647/6553600 files, 5868658/26214400 blocks
feb 07 11:58:51 _hostname_ systemd-sysctl[275]: Not setting net/ipv4/conf/default/promote_secondaries (explicit setting exists).
feb 07 11:58:51 _hostname_ systemd-random-seed[273]: Kernel entropy pool is not initialized yet, waiting until it is.
feb 07 11:58:51 _hostname_ systemd[1]: Starting Flush Journal to Persistent Storage...
feb 07 11:58:51 _hostname_ systemd[1]: Finished Create Static Device Nodes in /dev.
feb 07 11:58:51 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ audit: BPF prog-id=5 op=LOAD
feb 07 11:58:51 _hostname_ audit: BPF prog-id=6 op=LOAD
feb 07 11:58:51 _hostname_ kernel: audit: type=1130 audit(1612695531.409:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ kernel: audit: type=1334 audit(1612695531.409:8): prog-id=5 op=LOAD
feb 07 11:58:51 _hostname_ kernel: audit: type=1334 audit(1612695531.409:9): prog-id=6 op=LOAD
feb 07 11:58:51 _hostname_ systemd-journald[254]: Time spent on flushing to /var/log/journal/4406b921fb3245a69603e7c9594c5508 is 35.372ms for 1055 entries.
feb 07 11:58:51 _hostname_ systemd-journald[254]: System Journal (/var/log/journal/4406b921fb3245a69603e7c9594c5508) is 888.3M, max 4.0G, 3.1G free.
feb 07 11:58:51 _hostname_ kernel: audit: type=1400 audit(1612695531.436:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=267 comm="apparmor_parser"
feb 07 11:58:51 _hostname_ audit[267]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=267 comm="apparmor_parser"
feb 07 11:58:51 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ audit[269]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=269 comm="apparmor_parser"
feb 07 11:58:51 _hostname_ audit[269]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=269 comm="apparmor_parser"
feb 07 11:58:51 _hostname_ audit[265]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=265 comm="apparmor_parser"
feb 07 11:58:51 _hostname_ systemd[1]: Starting Rule-based Manager for Device Events and Files...
feb 07 11:58:51 _hostname_ systemd[1]: Finished Coldplug All udev Devices.
feb 07 11:58:51 _hostname_ systemd[1]: Finished Flush Journal to Persistent Storage.
feb 07 11:58:51 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ kernel: usb 3-13: new high-speed USB device number 5 using xhci_hcd
feb 07 11:58:51 _hostname_ audit[268]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=268 comm="apparmor_parser"
feb 07 11:58:51 _hostname_ systemd[1]: Started Rule-based Manager for Device Events and Files.
feb 07 11:58:51 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ systemd[1]: Started LVM2 metadata daemon.
feb 07 11:58:51 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ kernel: wmi_bus wmi_bus-PNP0C14:01: WQBC data block query control method not found
feb 07 11:58:51 _hostname_ kernel: ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20200925/utaddress-204)
feb 07 11:58:51 _hostname_ kernel: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
feb 07 11:58:51 _hostname_ kernel: ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20200925/utaddress-204)
feb 07 11:58:51 _hostname_ kernel: ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20200925/utaddress-204)
feb 07 11:58:51 _hostname_ kernel: ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20200925/utaddress-204)
feb 07 11:58:51 _hostname_ kernel: ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20200925/utaddress-204)
feb 07 11:58:51 _hostname_ kernel: ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20200925/utaddress-204)
feb 07 11:58:51 _hostname_ kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
feb 07 11:58:51 _hostname_ kernel: EDAC ie31200: No ECC support
feb 07 11:58:51 _hostname_ kernel: usb 3-13: New USB device found, idVendor=1bcf, idProduct=2b8c, bcdDevice=47.14
feb 07 11:58:51 _hostname_ kernel: usb 3-13: New USB device strings: Mfr=1, Product=2, SerialNumber=0
feb 07 11:58:51 _hostname_ kernel: usb 3-13: Product: Integrated_Webcam_HD
feb 07 11:58:51 _hostname_ kernel: usb 3-13: Manufacturer: SunplusIT Inc
feb 07 11:58:51 _hostname_ kernel: alx 0000:02:00.0 eth0: Qualcomm Atheros AR816x/AR817x Ethernet [20:47:47:d4:90:1a]
feb 07 11:58:51 _hostname_ kernel: random: mktemp: uninitialized urandom read (6 bytes read)
feb 07 11:58:51 _hostname_ systemd[1]: Found device LITEONIT_L8T-256L9G-11_M.2_2280_256GB 4.
feb 07 11:58:51 _hostname_ systemd[1]: Activating swap /dev/disk/by-uuid/608187eb-e840-4181-b12b-fd38a1f87b86...
feb 07 11:58:51 _hostname_ systemd[1]: Found device LITEONIT_L8T-256L9G-11_M.2_2280_256GB 1.
feb 07 11:58:51 _hostname_ audit[266]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=266 comm="apparmor_parser"
feb 07 11:58:51 _hostname_ audit[266]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=266 comm="apparmor_parser"
feb 07 11:58:51 _hostname_ systemd[1]: Found device LITEONIT_L8T-256L9G-11_M.2_2280_256GB 3.
feb 07 11:58:51 _hostname_ systemd[1]: Finished Load AppArmor profiles.
feb 07 11:58:51 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=apparmor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ kernel: Adding 18874504k swap on /dev/sdc4. Priority:-2 extents:1 across:18874504k SSFS
feb 07 11:58:51 _hostname_ systemd[1]: Activated swap /dev/disk/by-uuid/608187eb-e840-4181-b12b-fd38a1f87b86.
feb 07 11:58:51 _hostname_ kernel: input: PC Speaker as /devices/platform/pcspkr/input/input6
feb 07 11:58:51 _hostname_ kernel: mousedev: PS/2 mouse device common for all mice
feb 07 11:58:51 _hostname_ kernel: i801_smbus 0000:00:1f.3: SPD Write Disable is set
feb 07 11:58:51 _hostname_ kernel: i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
feb 07 11:58:51 _hostname_ kernel: Linux agpgart interface v0.103
feb 07 11:58:51 _hostname_ kernel: i2c i2c-0: 2/2 memory slots populated (from DMI)
feb 07 11:58:51 _hostname_ kernel: i2c i2c-0: Successfully instantiated SPD at 0x50
feb 07 11:58:51 _hostname_ systemd[1]: Reached target Swap.
feb 07 11:58:51 _hostname_ systemd[1]: Starting Load AppArmor profiles managed internally by snapd...
feb 07 11:58:51 _hostname_ kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
feb 07 11:58:51 _hostname_ kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
feb 07 11:58:51 _hostname_ kernel: RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
feb 07 11:58:51 _hostname_ kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
feb 07 11:58:51 _hostname_ kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
feb 07 11:58:51 _hostname_ kernel: RAPL PMU: hw unit of domain dram 2^-14 Joules
feb 07 11:58:51 _hostname_ kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
feb 07 11:58:51 _hostname_ snapd-apparmor[360]: find: ‘/var/lib/snapd/apparmor/profiles/’: No such file or directory
feb 07 11:58:51 _hostname_ systemd[1]: Finished Load AppArmor profiles managed internally by snapd.
feb 07 11:58:51 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd.apparmor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
feb 07 11:58:51 _hostname_ systemd[1]: Starting Load/Save RF Kill Switch Status...
feb 07 11:58:51 _hostname_ systemd[1]: Started Load/Save RF Kill Switch Status.
feb 07 11:58:51 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:51 _hostname_ kernel: ata1.00: exception Emask 0x10 SAct 0xc000 SErr 0x2d0100 action 0x6 frozen
feb 07 11:58:51 _hostname_ kernel: ata1.00: irq_stat 0x08000000, interface fatal error
feb 07 11:58:51 _hostname_ kernel: ata1: SError: { UnrecovData PHYRdyChg CommWake 10B8B BadCRC }
feb 07 11:58:51 _hostname_ kernel: ata1.00: failed command: READ FPDMA QUEUED
feb 07 11:58:51 _hostname_ kernel: ata1.00: cmd 60/78:70:88:00:00/00:00:00:00:00/40 tag 14 ncq dma 61440 in
res 50/00:f8:08:01:00/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
feb 07 11:58:51 _hostname_ kernel: ata1.00: status: { DRDY }
feb 07 11:58:51 _hostname_ kernel: ata1.00: cmd 60/f8:78:08:01:00/00:00:00:00:00/40 tag 15 ncq dma 126976 in
feb 07 11:58:51 _hostname_ kernel: ata1: hard resetting link
feb 07 11:58:51 _hostname_ kernel: cryptd: max_cpu_qlen set to 1000
feb 07 11:58:51 _hostname_ kernel: dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.4)
feb 07 11:58:51 _hostname_ kernel: alx 0000:02:00.0 enp2s0: renamed from eth0
feb 07 11:58:51 _hostname_ kernel: iTCO_vendor_support: vendor-support=0
feb 07 11:58:51 _hostname_ kernel: dell-smbios PNP0C14:01-A80593CE-A997-11DA-B012-B622A1EF5492: WMI SMBIOS userspace interface not supported(0), try upgrading to a newer BIOS
feb 07 11:58:51 _hostname_ kernel: at24 0-0050: supply vcc not found, using dummy regulator
feb 07 11:58:51 _hostname_ kernel: AVX2 version of gcm_enc/dec engaged.
feb 07 11:58:51 _hostname_ kernel: AES CTR mode by8 optimization enabled
feb 07 11:58:51 _hostname_ kernel: at24 0-0050: 256 byte spd EEPROM, read-only
feb 07 11:58:51 _hostname_ kernel: input: Dell WMI hotkeys as /devices/platform/PNP0C14:01/wmi_bus/wmi_bus-PNP0C14:01/PNP0C14:01-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input7
feb 07 11:58:51 _hostname_ kernel: snd_hda_intel 0000:00:03.0: enabling device (0000 -> 0002)
feb 07 11:58:51 _hostname_ kernel: snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
feb 07 11:58:51 _hostname_ kernel: iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
feb 07 11:58:51 _hostname_ kernel: iTCO_wdt: Found a Lynx Point TCO device (Version=2, TCOBASE=0x1860)
feb 07 11:58:51 _hostname_ kernel: iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
feb 07 11:58:52 _hostname_ kernel: snd_hda_codec_ca0132 hdaudioC1D0: autoconfig for CA0132: line_outs=1 (0xb/0x0/0x0/0x0/0x0) type:speaker
feb 07 11:58:52 _hostname_ kernel: snd_hda_codec_ca0132 hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
feb 07 11:58:52 _hostname_ kernel: snd_hda_codec_ca0132 hdaudioC1D0: hp_outs=1 (0xf/0x0/0x0/0x0/0x0)
feb 07 11:58:52 _hostname_ kernel: snd_hda_codec_ca0132 hdaudioC1D0: mono: mono_out=0x0
feb 07 11:58:52 _hostname_ kernel: snd_hda_codec_ca0132 hdaudioC1D0: inputs:
feb 07 11:58:52 _hostname_ kernel: snd_hda_codec_ca0132 hdaudioC1D0: Mic=0x11
feb 07 11:58:52 _hostname_ kernel: snd_hda_codec_ca0132 hdaudioC1D0: Internal Mic=0x12
feb 07 11:58:52 _hostname_ kernel: ath10k_pci 0000:03:00.0: enabling device (0000 -> 0002)
feb 07 11:58:52 _hostname_ kernel: ath10k_pci 0000:03:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
feb 07 11:58:52 _hostname_ kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
feb 07 11:58:52 _hostname_ kernel: ata1.00: configured for UDMA/133
feb 07 11:58:52 _hostname_ kernel: sd 0:0:0:0: [sda] tag#14 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
feb 07 11:58:52 _hostname_ kernel: sd 0:0:0:0: [sda] tag#14 Sense Key : Illegal Request [current]
feb 07 11:58:52 _hostname_ kernel: sd 0:0:0:0: [sda] tag#14 Add. Sense: Unaligned write command
feb 07 11:58:52 _hostname_ kernel: sd 0:0:0:0: [sda] tag#14 CDB: Read(10) 28 00 00 00 00 88 00 00 78 00
feb 07 11:58:52 _hostname_ kernel: blk_update_request: I/O error, dev sda, sector 136 op 0x0:(READ) flags 0x80700 phys_seg 11 prio class 0
feb 07 11:58:52 _hostname_ kernel: sd 0:0:0:0: [sda] tag#15 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
feb 07 11:58:52 _hostname_ kernel: sd 0:0:0:0: [sda] tag#15 Sense Key : Illegal Request [current]
feb 07 11:58:52 _hostname_ kernel: sd 0:0:0:0: [sda] tag#15 Add. Sense: Unaligned write command
feb 07 11:58:52 _hostname_ kernel: sd 0:0:0:0: [sda] tag#15 CDB: Read(10) 28 00 00 00 01 08 00 00 f8 00
feb 07 11:58:52 _hostname_ kernel: blk_update_request: I/O error, dev sda, sector 264 op 0x0:(READ) flags 0x80700 phys_seg 9 prio class 0
feb 07 11:58:52 _hostname_ kernel: ata1: EH complete
feb 07 11:58:52 _hostname_ kernel: ata1.00: exception Emask 0x10 SAct 0x1000 SErr 0x2d0100 action 0x6 frozen
feb 07 11:58:52 _hostname_ kernel: ata1.00: irq_stat 0x08000000, interface fatal error
feb 07 11:58:52 _hostname_ kernel: ata1: SError: { UnrecovData PHYRdyChg CommWake 10B8B BadCRC }
feb 07 11:58:52 _hostname_ kernel: ata1.00: failed command: READ FPDMA QUEUED
feb 07 11:58:52 _hostname_ kernel: ata1.00: cmd 60/08:60:00:08:00/00:00:00:00:00/40 tag 12 ncq dma 4096 in
res 50/00:08:00:08:00/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
feb 07 11:58:52 _hostname_ kernel: ata1.00: status: { DRDY }
feb 07 11:58:52 _hostname_ kernel: ata1: hard resetting link
feb 07 11:58:52 _hostname_ kernel: ath10k_pci 0000:03:00.0: qca6174 hw2.1 target 0x05010000 chip_id 0x003405ff sub 1a56:1525
feb 07 11:58:52 _hostname_ kernel: ath10k_pci 0000:03:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
feb 07 11:58:52 _hostname_ kernel: ath10k_pci 0000:03:00.0: firmware ver SW_RM.1.1.1-00157-QCARMSWPZ-1 api 5 features ignore-otp,no-4addr-pad crc32 10bf8e08
feb 07 11:58:52 _hostname_ kernel: checking generic (d0000000 7f0000) vs hw (f6400000 400000)
feb 07 11:58:52 _hostname_ kernel: checking generic (d0000000 7f0000) vs hw (d0000000 10000000)
feb 07 11:58:52 _hostname_ kernel: fb0: switching to inteldrmfb from EFI VGA
feb 07 11:58:52 _hostname_ kernel: Console: switching to colour dummy device 80x25
feb 07 11:58:52 _hostname_ kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
feb 07 11:58:52 _hostname_ kernel: [drm] ACPI BIOS requests an excessive sleep of 2000 ms, using 1500 ms instead
feb 07 11:58:52 _hostname_ kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
feb 07 11:58:52 _hostname_ kernel: Bluetooth: Core ver 2.22
feb 07 11:58:52 _hostname_ kernel: NET: Registered protocol family 31
feb 07 11:58:52 _hostname_ kernel: Bluetooth: HCI device and connection manager initialized
feb 07 11:58:52 _hostname_ kernel: Bluetooth: HCI socket layer initialized
feb 07 11:58:52 _hostname_ kernel: Bluetooth: L2CAP socket layer initialized
feb 07 11:58:52 _hostname_ kernel: Bluetooth: SCO socket layer initialized
feb 07 11:58:52 _hostname_ kernel: intel_rapl_common: Found RAPL domain package
feb 07 11:58:52 _hostname_ kernel: intel_rapl_common: Found RAPL domain core
feb 07 11:58:52 _hostname_ kernel: intel_rapl_common: Found RAPL domain uncore
feb 07 11:58:52 _hostname_ kernel: intel_rapl_common: Found RAPL domain dram
feb 07 11:58:52 _hostname_ kernel: i915 0000:00:02.0: [drm] Panel advertises DPCD backlight support, but VBT disagrees. If your backlight controls don't work try booting with i915.enable_dpcd_backlight=1. If your machine needs this, please file a _new_ bug report on drm/i915, see https://gitlab.freedesktop.org/drm/intel/-/wikis/How-to-file-i915-bugs for details.
feb 07 11:58:52 _hostname_ kernel: [drm] Initialized i915 1.6.0 20200917 for 0000:00:02.0 on minor 0
feb 07 11:58:52 _hostname_ kernel: ath10k_pci 0000:03:00.0: board_file api 2 bmi_id N/A crc32 ae2e275a
feb 07 11:58:52 _hostname_ kernel: ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
feb 07 11:58:52 _hostname_ kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8
feb 07 11:58:52 _hostname_ kernel: ACPI: Video Device [PEGP] (multi-head: no rom: yes post: no)
feb 07 11:58:52 _hostname_ kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:12/LNXVIDEO:01/input/input9
feb 07 11:58:52 _hostname_ kernel: snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
feb 07 11:58:52 _hostname_ kernel: fbcon: i915drmfb (fb0) is primary device
feb 07 11:58:52 _hostname_ systemd[1]: Created slice system-systemd\x2dbacklight.slice.
feb 07 11:58:52 _hostname_ kernel: usbcore: registered new interface driver btusb
feb 07 11:58:52 _hostname_ kernel: Bluetooth: hci0: using rampatch file: qca/rampatch_usb_00000200.bin
feb 07 11:58:52 _hostname_ kernel: Bluetooth: hci0: QCA: patch rome 0x200 build 0x299, firmware rome 0x200 build 0x111
feb 07 11:58:52 _hostname_ kernel: Bluetooth: hci0: using NVM file: qca/nvm_usb_00000200.bin
feb 07 11:58:52 _hostname_ kernel: snd_hda_codec_ca0132 hdaudioC1D0: ca0132 DSP downloaded and running
feb 07 11:58:52 _hostname_ kernel: sd 0:0:0:0: [sda] tag#12 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE cmd_age=0s
feb 07 11:58:52 _hostname_ kernel: sd 0:0:0:0: [sda] tag#12 Sense Key : Illegal Request [current]
feb 07 11:58:52 _hostname_ kernel: sd 0:0:0:0: [sda] tag#12 Add. Sense: Unaligned write command
feb 07 11:58:52 _hostname_ kernel: sd 0:0:0:0: [sda] tag#12 CDB: Read(10) 28 00 00 00 08 00 00 00 08 00
feb 07 11:58:52 _hostname_ kernel: blk_update_request: I/O error, dev sda, sector 2048 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
feb 07 11:58:52 _hostname_ kernel: random: crng init done
feb 07 11:58:52 _hostname_ kernel: random: 7 urandom warning(s) missed due to ratelimiting
feb 07 11:58:52 _hostname_ kernel: input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input10
feb 07 11:58:52 _hostname_ kernel: input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input11
feb 07 11:58:53 _hostname_ mtp-probe[534]: checking bus 3, device 5: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-13"
feb 07 11:58:53 _hostname_ mtp-probe[536]: checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
feb 07 11:58:53 _hostname_ mtp-probe[535]: checking bus 3, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-4"
feb 07 11:58:53 _hostname_ mtp-probe[535]: bus: 3, device: 3 was not an MTP device
feb 07 11:58:53 _hostname_ mtp-probe[536]: bus: 3, device: 2 was not an MTP device
feb 07 11:58:53 _hostname_ mtp-probe[534]: bus: 3, device: 5 was not an MTP device
feb 07 11:58:53 _hostname_ kernel: ata1.00: exception Emask 0x10 SAct 0x1c SErr 0x2d0100 action 0x6 frozen
feb 07 11:58:53 _hostname_ kernel: ata1.00: irq_stat 0x08000000, interface fatal error
feb 07 11:58:53 _hostname_ kernel: ata1: SError: { UnrecovData PHYRdyChg CommWake 10B8B BadCRC }
feb 07 11:58:53 _hostname_ kernel: ata1.00: failed command: READ FPDMA QUEUED
feb 07 11:58:53 _hostname_ kernel: ata1.00: cmd 60/00:10:00:00:00/01:00:00:00:00/40 tag 2 ncq dma 131072 in
res 50/00:00:00:60:30/00:01:6e:00:00/40 Emask 0x10 (ATA bus error)
feb 07 11:58:53 _hostname_ kernel: ata1.00: status: { DRDY }
feb 07 11:58:53 _hostname_ kernel: ata1.00: cmd 60/00:18:00:08:00/01:00:00:00:00/40 tag 3 ncq dma 131072 in
feb 07 11:58:53 _hostname_ kernel: ata1.00: cmd 60/00:20:00:60:30/01:00:6e:00:00/40 tag 4 ncq dma 131072 in
feb 07 11:58:53 _hostname_ kernel: ata1: hard resetting link
feb 07 11:58:53 _hostname_ kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
feb 07 11:58:53 _hostname_ kernel: ata1.00: configured for UDMA/133
feb 07 11:58:53 _hostname_ kernel: ata1: EH complete
feb 07 11:58:53 _hostname_ kernel: Console: switching to colour frame buffer device 240x67
feb 07 11:58:53 _hostname_ kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
feb 07 11:58:53 _hostname_ systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:intel_backlight...
feb 07 11:58:53 _hostname_ systemd[1]: Finished Load/Save Random Seed.
feb 07 11:58:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
feb 07 11:58:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ kernel: kauditd_printk_skb: 13 callbacks suppressed
feb 07 11:58:53 _hostname_ kernel: audit: type=1130 audit(1612695533.599:24): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ kernel: audit: type=1130 audit(1612695533.599:25): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ kernel: mc: Linux media interface: v0.10
feb 07 11:58:53 _hostname_ systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:intel_backlight.
feb 07 11:58:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ kernel: input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.0/0003:046D:C539.0001/input/input12
feb 07 11:58:53 _hostname_ kernel: audit: type=1130 audit(1612695533.612:26): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ systemd[1]: Reached target Local File Systems (Pre).
feb 07 11:58:53 _hostname_ systemd[1]: Mounting /tmp...
feb 07 11:58:53 _hostname_ systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
feb 07 11:58:53 _hostname_ systemd[1]: Condition check resulted in First Boot Wizard being skipped.
feb 07 11:58:53 _hostname_ systemd[1]: Condition check resulted in First Boot Complete being skipped.
feb 07 11:58:53 _hostname_ systemd[1]: Starting File System Check on /dev/disk/by-uuid/2bc46c6e-10ba-4ad3-be25-256f8660c992...
feb 07 11:58:53 _hostname_ systemd[1]: Starting File System Check on /dev/disk/by-uuid/DF77-703A...
feb 07 11:58:53 _hostname_ systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
feb 07 11:58:53 _hostname_ systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
feb 07 11:58:53 _hostname_ systemd[1]: Condition check resulted in Create System Users being skipped.
feb 07 11:58:53 _hostname_ systemd[1]: Mounted /tmp.
feb 07 11:58:53 _hostname_ kernel: videodev: Linux video capture interface: v2.00
feb 07 11:58:53 _hostname_ kernel: input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input13
feb 07 11:58:53 _hostname_ systemd-fsck[608]: /dev/sdc3: clean, 186542/7864320 files, 3736620/31448576 blocks
feb 07 11:58:53 _hostname_ systemd[1]: Finished File System Check on /dev/disk/by-uuid/2bc46c6e-10ba-4ad3-be25-256f8660c992.
feb 07 11:58:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-2bc46c6e\x2d10ba\x2d4ad3\x2dbe25\x2d256f8660c992 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ kernel: audit: type=1130 audit(1612695533.646:27): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-2bc46c6e\x2d10ba\x2d4ad3\x2dbe25\x2d256f8660c992 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ systemd[1]: Mounting /home...
feb 07 11:58:53 _hostname_ systemd-fsck[609]: fsck.fat 4.1 (2017-01-24)
feb 07 11:58:53 _hostname_ systemd-fsck[609]: /dev/sdc1: 6 files, 78/130812 clusters
feb 07 11:58:53 _hostname_ systemd[1]: Finished File System Check on /dev/disk/by-uuid/DF77-703A.
feb 07 11:58:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-DF77\x2d703A comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ kernel: uvcvideo: Found UVC 1.00 device Integrated_Webcam_HD (1bcf:2b8c)
feb 07 11:58:53 _hostname_ kernel: audit: type=1130 audit(1612695533.656:28): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-DF77\x2d703A comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ systemd[1]: Mounting /boot/efi...
feb 07 11:58:53 _hostname_ systemd[1]: Mounted /home.
feb 07 11:58:53 _hostname_ kernel: EXT4-fs (sdc3): mounted filesystem with ordered data mode. Opts: (null)
feb 07 11:58:53 _hostname_ kernel: hid-generic 0003:046D:C539.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-1/input0
feb 07 11:58:53 _hostname_ kernel: input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input14
feb 07 11:58:53 _hostname_ kernel: input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input15
feb 07 11:58:53 _hostname_ kernel: input: HDA Intel HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.0/sound/card0/input16
feb 07 11:58:53 _hostname_ kernel: input: HDA Intel HDMI HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.0/sound/card0/input17
feb 07 11:58:53 _hostname_ kernel: input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input18
feb 07 11:58:53 _hostname_ kernel: input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input19
feb 07 11:58:53 _hostname_ systemd[1]: Mounted /boot/efi.
feb 07 11:58:53 _hostname_ systemd[1]: Reached target Local File Systems.
feb 07 11:58:53 _hostname_ systemd[1]: Condition check resulted in Rebuild Dynamic Linker Cache being skipped.
feb 07 11:58:53 _hostname_ systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
feb 07 11:58:53 _hostname_ systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
feb 07 11:58:53 _hostname_ systemd[1]: Starting Create Volatile Files and Directories...
feb 07 11:58:53 _hostname_ kernel: input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb3/3-13/3-13:1.0/input/input22
feb 07 11:58:53 _hostname_ systemd[1]: Finished Create Volatile Files and Directories.
feb 07 11:58:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ systemd[1]: Condition check resulted in Rebuild Journal Catalog being skipped.
feb 07 11:58:53 _hostname_ kernel: audit: type=1130 audit(1612695533.689:29): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ systemd[1]: Starting Network Time Synchronization...
feb 07 11:58:53 _hostname_ systemd[1]: Condition check resulted in Update is Completed being skipped.
feb 07 11:58:53 _hostname_ systemd[1]: Starting Update UTMP about System Boot/Shutdown...
feb 07 11:58:53 _hostname_ audit[618]: SYSTEM_BOOT pid=618 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ kernel: ath10k_pci 0000:03:00.0: htt-ver 3.1 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
feb 07 11:58:53 _hostname_ kernel: audit: type=1127 audit(1612695533.696:30): pid=618 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ systemd[1]: Finished Update UTMP about System Boot/Shutdown.
feb 07 11:58:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ kernel: audit: type=1130 audit(1612695533.699:31): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ mtp-probe[622]: checking bus 3, device 5: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-13"
feb 07 11:58:53 _hostname_ mtp-probe[622]: bus: 3, device: 5 was not an MTP device
feb 07 11:58:53 _hostname_ kernel: input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.1/0003:046D:C539.0002/input/input20
feb 07 11:58:53 _hostname_ kernel: usbcore: registered new interface driver uvcvideo
feb 07 11:58:53 _hostname_ kernel: USB Video Class driver (1.1.1)
feb 07 11:58:53 _hostname_ kernel: hid-generic 0003:046D:C539.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-1/input1
feb 07 11:58:53 _hostname_ kernel: hid-generic 0003:046D:C539.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-1/input2
feb 07 11:58:53 _hostname_ kernel: hid-generic 0003:187C:0528.0004: hiddev98,hidraw3: USB HID v1.01 Device [Alienware AW1517] on usb-0000:00:14.0-4/input0
feb 07 11:58:53 _hostname_ kernel: usbcore: registered new interface driver usbhid
feb 07 11:58:53 _hostname_ kernel: usbhid: USB HID core driver
feb 07 11:58:53 _hostname_ systemd[1]: Started Network Time Synchronization.
feb 07 11:58:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ systemd[1]: Reached target System Initialization.
feb 07 11:58:53 _hostname_ systemd[1]: Started CUPS Scheduler.
feb 07 11:58:53 _hostname_ systemd[1]: Started Daily Cleanup of Temporary Directories.
feb 07 11:58:53 _hostname_ systemd[1]: Reached target Paths.
feb 07 11:58:53 _hostname_ kernel: audit: type=1130 audit(1612695533.746:32): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ systemd[1]: Reached target System Time Set.
feb 07 11:58:53 _hostname_ systemd[1]: Reached target System Time Synchronized.
feb 07 11:58:53 _hostname_ systemd[1]: Started Daily rotation of log files.
feb 07 11:58:53 _hostname_ systemd[1]: Started Daily man-db regeneration.
feb 07 11:58:53 _hostname_ systemd[1]: Started Monthly clean packages cache.
feb 07 11:58:53 _hostname_ systemd[1]: Started Generate mirrorlist weekly.
feb 07 11:58:53 _hostname_ systemd[1]: Started pkgfile database update timer.
feb 07 11:58:53 _hostname_ systemd[1]: Started Daily verification of password and group files.
feb 07 11:58:53 _hostname_ systemd[1]: Reached target Timers.
feb 07 11:58:53 _hostname_ systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
feb 07 11:58:53 _hostname_ systemd[1]: Listening on CUPS Scheduler.
feb 07 11:58:53 _hostname_ systemd[1]: Listening on D-Bus System Message Bus Socket.
feb 07 11:58:53 _hostname_ systemd[1]: Starting Socket activation for snappy daemon.
feb 07 11:58:53 _hostname_ systemd[1]: Listening on Socket activation for snappy daemon.
feb 07 11:58:53 _hostname_ systemd[1]: Reached target Sockets.
feb 07 11:58:53 _hostname_ systemd[1]: Reached target Basic System.
feb 07 11:58:53 _hostname_ systemd[1]: Condition check resulted in Save/Restore Sound Card State being skipped.
feb 07 11:58:53 _hostname_ systemd[1]: Condition check resulted in Manage Sound Card State (restore and store) being skipped.
feb 07 11:58:53 _hostname_ systemd[1]: Reached target Sound Card.
feb 07 11:58:53 _hostname_ systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
feb 07 11:58:53 _hostname_ systemd[1]: Starting Bluetooth service...
feb 07 11:58:53 _hostname_ systemd[1]: Started Periodic Command Scheduler.
feb 07 11:58:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ kernel: ath: EEPROM regdomain: 0x6c
feb 07 11:58:53 _hostname_ kernel: ath: EEPROM indicates we should expect a direct regpair map
feb 07 11:58:53 _hostname_ kernel: ath: Country alpha2 being used: 00
feb 07 11:58:53 _hostname_ kernel: ath: Regpair used: 0x6c
feb 07 11:58:53 _hostname_ kernel: audit: type=1130 audit(1612695533.776:33): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ avahi-daemon[630]: Found user 'avahi' (UID 974) and group 'avahi' (GID 974).
feb 07 11:58:53 _hostname_ systemd[1]: Started D-Bus System Message Bus.
feb 07 11:58:53 _hostname_ crond[633]: (CRON) STARTUP (1.5.5)
feb 07 11:58:53 _hostname_ crond[633]: (CRON) INFO (Syslog will be used instead of sendmail.)
feb 07 11:58:53 _hostname_ crond[633]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 90% if used.)
feb 07 11:58:53 _hostname_ crond[633]: (CRON) INFO (running with inotify support)
feb 07 11:58:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ systemd[1]: Starting Network Manager...
feb 07 11:58:53 _hostname_ systemd[1]: Starting Clean up modules from old kernels...
feb 07 11:58:53 _hostname_ systemd[1]: Started Autoassign nonstandard Alienware 15 keys..
feb 07 11:58:53 _hostname_ audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=locate-keys comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
feb 07 11:58:53 _hostname_ systemd[1]: Starting Optimus Manager Commands Daemon...
feb 07 11:58:53 _hostname_ linux-module-cleanup[641]: cat: /usr/lib/modules/.old: No such file or directory
feb 07 11:58:53 _hostname_ systemd[1]: Starting Authorization Manager...
feb 07 11:58:53 _hostname_ bluetoothd[631]: Bluetooth daemon 5.55
feb 07 11:58:53 _hostname_ bluetoothd[631]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanType” in group “Controller”
feb 07 11:58:53 _hostname_ bluetoothd[631]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanInterval” in group “Controller”
feb 07 11:58:53 _hostname_ bluetoothd[631]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanWindow” in group “Controller”
feb 07 11:58:53 _hostname_ bluetoothd[631]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanType” in group “Controller”
feb 07 11:58:53 _hostname_ bluetoothd[631]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanInterval” in group “Controller”
feb 07 11:58:53 _hostname_ bluetoothd[631]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanWindow” in group “Controller”
feb 07 11:58:53 _hostname_ bluetoothd[631]: src/main.c:parse_controller_config() Key file does not have key “BRLinkSupervisionTimeout” in group “Controller”
feb 07 11:58:53 _hostname_ bluetoothd[631]: src/main.c:parse_controller_config() Key file does not have key “BRPageTimeout” in group “Controller”
feb 07 11:58:53 _hostname_ bluetoothd[631]: src/main.c:parse_controller_config() Key file does not have key “BRMinSniffInterval” in group “Controller”
