Alias for pamac not functional
EDIT: I’ve just realized that my aliases don’t work at all.
Strangely, I didn’t know that install commands already existed on the system. I’m going to have to learn a bit more.
Hello everyone, I’m just discovering how to use aliases=alias
I’ve been using Manjaro with the cinnamon desktop for two/three years.
I’ve just created the following aliases:
#______Aliases for Pamac____#
# # Pamac package installation function
pinstall() {
   sudo pamac install "$@"
alias install='pinstall'
#search package with pamac AUR
psearch() {
   sudo pamac search "$@"
alias search='psearch'
Can you tell me why when I source bash I get this message? :
11:11:50 XXX@XXX-XXX Downloads → source ~/.bashrc
bash: /home/XXX/.bashrc: line 184: premature end of file (EOF) when looking for the corresponding " " ".
The line 184 would corresponds to :
So,
I tested my new controls and surprisingly,
update - upgrade - and install work, but not search
I find search with tab
the search tradingview command, for example, returns no information and no error.
Why are you writing a function and then an alias for that function? Just name the function like you want. Or put those one-liners in an alias.
Also read this: Pamac - Manjaro
don’t use sudo ! :bomb:
Everything works, I made several tests with your recommendations, and it still did not work, I made a source ~/.bashrc but in fact it was simply necessary to restart the shell
In any case, both solutions work, with the function or not, at first I thought it wouldn’t accept the addition of the file name, but I got the wrong idea because sela works very well without the function.
On the other hand, with or without sudo, it works in principle.
No, do not use sudo.
ok, i will modify
All my aliases with pacman work, but none with pamac.
example :
alias pacmupgrade='pacman -Syu’ ----> Work
alias pupgrade='pamac upgrade' ----> Do not work
pamac search --no-aur tradingview
returns no information and no error, but
pamac search --aur tradingview
shows python-tradingview-ta and tradingview available from AUR
Pacman does not support AUR so the equivalent commend for pamac would be
pamac update --no-aur
Thank you very much
So, it should look like this if i understand ?
#mise à jour avec pamac
alias pupdate=‘pamac update --no-aur’
alias pupgrade=‘pamac upgrade --no-aur’
#recherche de paquet avec pamac
alias psearch=‘pamac search --no-aur’
installation de paquet avec pamac
alias pinstall=’
Summary
sudo
pamac install --no-aur’
but for pamac alias it still not working
Edit: without sudo
Please show entire .bashrc
I dont understand why the color are not the same at the end of the file ?!!
# Enable the subsequent settings only in interactive sessions
case $- in
  *i*) ;;
    *) return;;
esac
# Path to your oh-my-bash installation.
export OSH='/home/cyberohms/.oh-my-bash'
# Set name of the theme to load. Optionally, if you set this to "random"
# it'll load a random theme each time that oh-my-bash is loaded.
OSH_THEME="font"
# If you set OSH_THEME to "random", you can ignore themes you don't like.
# OMB_THEME_RANDOM_IGNORED=("powerbash10k" "wanelo")
# Uncomment the following line to use case-sensitive completion.
# OMB_CASE_SENSITIVE="true"
# Uncomment the following line to use hyphen-insensitive completion. Case
# sensitive completion must be off. _ and - will be interchangeable.
# OMB_HYPHEN_SENSITIVE="false"
# Uncomment the following line to disable bi-weekly auto-update checks.
# DISABLE_AUTO_UPDATE="true"
# Uncomment the following line to change how often to auto-update (in days).
 export UPDATE_OSH_DAYS=7
# Uncomment the following line to disable colors in ls.
# DISABLE_LS_COLORS="true"
# Uncomment the following line to disable auto-setting terminal title.
# DISABLE_AUTO_TITLE="true"
# Uncomment the following line to enable command auto-correction.
 ENABLE_CORRECTION="true"
# Uncomment the following line to display red dots whilst waiting for completion.
 COMPLETION_WAITING_DOTS="true"
# Uncomment the following line if you want to disable marking untracked files
# under VCS as dirty. This makes repository status check for large repositories
# much, much faster.
# DISABLE_UNTRACKED_FILES_DIRTY="true"
# Uncomment the following line if you don't want the repository to be considered dirty
# if there are untracked files.
# SCM_GIT_DISABLE_UNTRACKED_DIRTY="true"
# Uncomment the following line if you want to completely ignore the presence
# of untracked files in the repository.
# SCM_GIT_IGNORE_UNTRACKED="true"
# Uncomment the following line if you want to change the command execution time
# stamp shown in the history command output.  One of the following values can
# be used to specify the timestamp format.
# * 'mm/dd/yyyy'     # mm/dd/yyyy + time
# * 'dd.mm.yyyy'     #  dd.mm.yyyy + time
# * 'yyyy-mm-dd'     # yyyy-mm-dd + time
# * '[mm/dd/yyyy]'   # [mm/dd/yyyy] + [time] with colors
# * '[dd.mm.yyyy]'   # [dd.mm.yyyy] + [time] with colors
# * '[yyyy-mm-dd]'   # [yyyy-mm-dd] + [time] with colors
# If not set, the default value is 'yyyy-mm-dd'.
HIST_STAMPS='[dd.mm.yyyy] + [time] with colors'
# Uncomment the following line if you do not want OMB to overwrite the existing
# aliases by the default OMB aliases defined in lib/*.sh
# OMB_DEFAULT_ALIASES="check"
# Would you like to use another custom folder than $OSH/custom?
# OSH_CUSTOM=/path/to/new-custom-folder
# To disable the uses of "sudo" by oh-my-bash, please set "false" to
# this variable.  The default behavior for the empty value is "true".
OMB_USE_SUDO=true
# To enable/disable display of Python virtualenv and condaenv
# OMB_PROMPT_SHOW_PYTHON_VENV=true  # enable
# OMB_PROMPT_SHOW_PYTHON_VENV=false # disable
# Which completions would you like to load? (completions can be found in ~/.oh-my-bash/completions/*)
# Custom completions may be added to ~/.oh-my-bash/custom/completions/
# Example format: completions=(ssh git bundler gem pip pip3)
# Add wisely, as too many completions slow down shell startup.
completions=(
  git
  composer
  ssh
# Which aliases would you like to load? (aliases can be found in ~/.oh-my-bash/aliases/*)
# Custom aliases may be added to ~/.oh-my-bash/custom/aliases/
# Example format: aliases=(vagrant composer git-avh)
# Add wisely, as too many aliases slow down shell startup.
aliases=(
  general
# Which plugins would you like to load? (plugins can be found in ~/.oh-my-bash/plugins/*)
# Custom plugins may be added to ~/.oh-my-bash/custom/plugins/
# Example format: plugins=(rails git textmate ruby lighthouse)
# Add wisely, as too many plugins slow down shell startup.
plugins=(
  git
  bashmarks
# Which plugins would you like to conditionally load? (plugins can be found in ~/.oh-my-bash/plugins/*)
# Example format:
#  if [ "$DISPLAY" ] || [ "$SSH" ]; then
#      plugins+=(tmux-autoattach)
#  fi
source "$OSH"/oh-my-bash.sh
# User configuration
# export MANPATH="/usr/local/man:$MANPATH"
# You may need to manually set your language environment
 export LANG=fr_FR.UTF-8
# Preferred editor for local and remote sessions
# if [[ -n $SSH_CONNECTION ]]; then
#   export EDITOR='vim'
# else
#   export EDITOR='mvim'
# fi
# Compilation flags
# export ARCHFLAGS="-arch x86_64"
# ssh
# export SSH_KEY_PATH="~/.ssh/rsa_id"
# Set personal aliases, overriding those provided by oh-my-bash libs,
# plugins, and themes. Aliases can be placed here, though oh-my-bash
# users are encouraged to define aliases within the OSH_CUSTOM folder.
# For a full list of active aliases, run `alias`.
# Example aliases
# alias bashconfig="mate ~/.bashrc"
# alias ohmybash="mate ~/.oh-my-bash"
alias ls='ls -alF'
#alias grep='grep --color=auto'
#alias cp='cp -i
#alias mv='mv -i
#alias mkdir='mkdir -pv
#alias psa='ps -aux
#alias psg='ps -aux | grep
#alias reboot='sudo shutdown -r now
#alias shutdown='sudo shutdown -h now
#alias rm='rm -i
#alias cpv='rsync -ah --info=progress2
#alias hg='history | grep
#_______Alias pour Pacman
#installation d'un paquet
alias pacminstall='sudo pacman -S'
#Simulation de mise à jour
alias pacmupdatest='pacman -Syu --dry-run'
#_______
#Synchro de la base de donné des paquets
alias pacmsync='pacman -Sy
#_______
#Mise à jour des paquets
alias pacmupgrade='pacman -Syu'
alias pupdate='pamac update --no-aur'
alias pupgrade='pamac upgrade --no-aur'
alias psearch='pamac search --no-aur'
#installation de paquet avec pamac
alias pinstall='sudo pamac install --no-aur'
remember to close the quotes.
install shellcheck - it is of great help to validate syntax.
if you are using kate or micro - it will detect shellcheck automagically and point you to your errors.
You also need to exit the shell and reopen for any changes to become active.
Ok I will
shellcheck
Maybe that?
Im frenh, I’m not sure I understand, but maybe that’s the reason :slight_smile:
I will take a look but why pacman aliases work and not pamac aliases
Bacuse you use sude before the pamac aliases?
Sudo for pacman, NOT for pamac.
What is kate or micro ?
if it s a code editor, i use nano
i tried both
example
 $ cat .bashrc
#source /usr/bin/virtualenvwrapper.sh
#. "$HOME/.cargo/env"
alias pacsync='sudo pacman -Syu'
 $ pacsync
 nixrepo is up to date
 mesa-nonfree is up to date
 core is up to date
 extra is up to date
 multilib is up to date
 sublime-text is up to date
 there is nothing to do
  • kate is the GUI text tool in plasma
  • micro is nano on steroids
sudo pacman -Syu micro shellcheck
Then - look for the >> in the editor
micro .bashrc
Correct it and save
text highlight colors change after missing quote
I added 2 of the aliases to ~/.extend.bashrc and they are working
[nik@gnomic ~]$ pupdate
Preparing...
Nothing to do.
[nik@gnomic ~]$ psearch manjaro-release
manjaro-release  23.1.0-1 [Installed]        core
    Manjaro's release definition
case $- in
  *i*) ;;
    *) return;;
esac
OSH_THEME="font"
OMB_USE_SUDO=true
completions=(
  git
  composer
  ssh
aliases=(
  general
plugins=(
  git
  bashmarks
# Example format:
#  fi
# else
# fi
# Compilation flags
# ssh
# Example aliases
alias ls='ls -alF'
#alias cp='cp -i
#alias mv='mv -i
#alias psa='ps -aux
#alias rm='rm -i
#_______
#_______
alias pinstall='pamac install --no-aur'
