~ → pupdate
bash: pupdate : commande introuvable
and also
bash: /home/cyberohms/.bashrc: ligne 178: fin de fichier (EOF) prématurée lors de la recherche du « ’ » correspondant
~ → pupdate
and also
This alias is missing closing quote
#Synchro de la base de donné des paquets
`alias pacmsync='pacman -Sy
so all subsequent aliases are likely to fail
line 178: premature end of file (EOF) when searching for the corresponding “’”
For the 10th time: You are missing the end quote.
Also this is a good time to say that you should start reading tutorials. Because this is one command you should never run.
Because as numerous people have told you the syntax highlighting is HIGHLIGHTING that you’ve missed a closing quote on this line;
Yes, I didn’t think it would break up the suite.
I didn’t know that bashrc rc could be read as a continuation and an end (if I’m expressing correctly).
Indeed, it corrected everything
Thanks a lot
Prepending "[SOLVED]" to a topic when solved? - #4 by nikgnomic
Prepending title text is less effective than marking the solution post and creates extra work to maintain forum consistency and Keep It Tidy
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
