Hi! I installed the latest manjaro with AHCI to my intel sata ssd. It was painfuly slow because the disk usage light was always on. I tried a lot of things and one of them succeded. I switched from ahci sata mode to raid. This works but i need ahci for windows because i don’t have the proper drivers for amd raid installed. Before manjaro I had kubuntu and it worked great with ahci but decided to switch. Is there anything i can do?
Kernel: 6.1.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2203 quiet systemd.show_status=1
splash driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
rdinit=/vtoy/vtoy
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B350-F GAMING v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 6042 date: 04/28/2022
RAM: total: 7.67 GiB used: 5.07 GiB (66.1%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 2800 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
data: 64 total: 64 manufacturer: Corsair part-no: CMK8GX4M1A2400C14
serial: N/A
Device-2: DIMM_A2 type: no module installed
Device-3: DIMM_B1 type: no module installed
Device-4: DIMM_B2 type: no module installed
Info: model: AMD Ryzen 5 2600 socket: AM4 bits: 64 type: MT MCP arch: Zen+
gen: 2 level: v3 note: check built: 2018-21 process: GF 12nm
family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 2166 high: 3400 min/max: 1550/3400 boost: enabled
base/boost: 3400/3900 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3400 2: 1550 3: 1550 4: 1550
5: 3400 6: 1550 7: 1550 8: 1550 9: 3400 10: 1550 11: 1550 12: 3400
bogomips: 81625
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 525.89.02
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.0
chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 90 s-size: 474x303mm (18.66x11.93")
s-diag: 563mm (22.15")
Monitor-1: DP-0 res: 1680x1050 hz: 60 dpi: 90
size: 474x296mm (18.66x11.65") diag: 559mm (22") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GP106 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
chip-ID: 1022:1457 class-ID: 0403
Sound API: ALSA v: k6.1.11-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Hardware-1: Advanced Micro Devices [AMD] Device driver: N/A v: N/A port: N/A
bus-ID: 01:00.1 chip-ID: 1022:43bd rev: N/A class-ID: 0104
Hardware-2: Advanced Micro Devices [AMD] Device driver: ahci v: 3.0
port: N/A bus-ID: 0a:00.2 chip-ID: 1022:7916 rev: N/A class-ID: 0104
Local Storage: total: 372.62 GiB used: 8.72 GiB (2.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9160412AS
family: Momentus 7200.4 size: 149.05 GiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 3.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: HPM1 temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 218d 2h cycles: 3415 Old-Age:
g-sense error rate: 355 Pre-Fail: attribute: Spin_Retry_Count value: 100
worst: 100 threshold: 97
ID-2: /dev/sdb maj-min: 8:16 vendor: Intel model: SSDSC2BW240A4 family: 53x
and Pro 1500/2500 Series SSDs size: 223.57 GiB block-size: physical: 512 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: DC32 temp: 25 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 89d 19h cycles: 2177
read: 11.91 TiB written: 11.77 TiB
ID-1: /tmp/calamares-root-cbzdge0e raw-size: 77.76 GiB
size: 77.76 GiB (100.00%) used: 8.68 GiB (11.2%) fs: btrfs block-size: 4096 B
dev: /dev/sdb6 maj-min: 8:22 label: N/A
uuid: 4e70d00e-8ac4-431c-89ef-30b2a03e4d8f
ID-2: /tmp/calamares-root-cbzdge0e/boot/efi raw-size: 1.08 GiB
size: 1.07 GiB (99.80%) used: 30.6 MiB (2.8%) fs: vfat block-size: 512 B
dev: /dev/sdb4 maj-min: 8:20 label: N/A uuid: 33EE-A258
ID-3: /tmp/calamares-root-cbzdge0e/home raw-size: 48.83 GiB
size: 48.83 GiB (100.00%) used: 3.8 MiB (0.0%) fs: btrfs block-size: 4096 B
dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 080fef78-989b-4629-ae89-b2171163a622
ID-4: /tmp/calamares-root-cbzdge0e/var/cache raw-size: 77.76 GiB
ID-5: /tmp/calamares-root-cbzdge0e/var/log raw-size: 77.76 GiB
ID-1: /dev/dm-0 maj-min: 254:0 mapped: ventoy size: 3.82 GiB fs: iso9660
ID-2: /dev/sda1 maj-min: 8:1 size: 49.02 GiB fs: ntfs label: Ventoy
uuid: 66D8AD5FD8AD2DED
ID-3: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
uuid: B228-8EFB
ID-4: /dev/sda3 maj-min: 8:3 size: 1 GiB fs: vfat label: Clone
uuid: 33EE-A258
ID-5: /dev/sda4 maj-min: 8:4 size: 100 MiB fs: vfat label: N/A
uuid: EAA0-8E1B
ID-6: /dev/sdb1 maj-min: 8:17 size: 140.22 GiB fs: ntfs label: N/A
uuid: 2ADAC3D5DAC39B87
ID-7: /dev/sdb2 maj-min: 8:18 size: 100 MiB fs: vfat label: N/A
uuid: CA38-D27F
ID-8: /dev/sdb3 maj-min: 8:19 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-9: /dev/sdb5 maj-min: 8:21 size: 4 GiB fs: swap label: N/A
uuid: 08695f13-d52c-45ef-a2d5-20dd511cabaf
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-1:2 info: IBM NetVista Full Width Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 04b3:3025 class-ID: 0301
Device-2: 1-2:3 info: Logitech M-BT96a Pilot Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 98mA
chip-ID: 046d:c03d class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 43.5 C mobo: N/A gpu: nvidia temp: 29 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Processes: 326 Uptime: 10m wakeups: 0 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1170 libs: 319 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh (sudo)
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
