After upgrade, the plasma UI is broken
There are a lot of problems I am facing in the UI, but one that hurts my eyes is the following. The texts are not well aligned and also its translucent. Earlier it was opaque
Even though I am trying to set it opaque, it is not working
I honestly do not see any issue on your screenshot, where exactly ?
Regarding opacity, it’s related to your plasma theme mainly or to Blur effect on System settings β†’ Windows Management β†’ Desktop Effects β†’ Blur
Make sure to clear things and use compatible additions.
https://wiki.archlinux.org/title/KDE#Configuration_related
If you are on wayland. This may be a certain bug. I have a workaround in my /etc/environment:
# qt wayland font bug https://bugs.kde.org/show_bug.cgi?id=479891
QT_SCALE_FACTOR_ROUNDING_POLICY="RoundPreferFloor"
This is how the menu looked before upgrade
Clean, opaque, text is perfectly aligned with on-hover highlights and all
This looks like you are using a theme that is not updated for plasma 6, or is otherwise incomplete.
Especially since you like opaque/flat .. you might try mine;
Oh there is a thread here:
I have just upgraded libplasma to 6.0.4-1.1 and it is working fine. Who so ever pushed the release, a big :heart: from my side.
Its from here.
I guess referencing it in the Stable Announcement thread spurred action.
