After updating the system freezes completely in a few minutes
After the last update the system is freezing completely after a few minutes with the 5.8.11-1 kernel, what should I do?
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=50f91562-d5e0-4da1-9fc6-ee25a26193d6 rw quiet apparmor=1 security=apparmor udev.log_priority=3 iommu=pt idle=nomwait rcu_nocbs=0-15 processor.max_cstate=5
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Hygon HygonGenuine
[    0.000000]   Centaur CentaurHauls
[    0.000000]   zhaoxin   Shanghai
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009e01fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000009e02000-0x0000000009ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
[    0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a20afff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000000a20b000-0x000000000affffff] usable
[    0.000000] BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
[    0.000000] BIOS-e820: [mem 0x000000000b020000-0x00000000db48cfff] usable
[    0.000000] BIOS-e820: [mem 0x00000000db48d000-0x00000000db61dfff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000db61e000-0x00000000db7a1fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000db7a2000-0x00000000dbbbffff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000dbbc0000-0x00000000dca18fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000dca19000-0x00000000dcac0fff] type 20
[    0.000000] BIOS-e820: [mem 0x00000000dcac1000-0x00000000deffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df000000-0x00000000dfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fd000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000081f37ffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.70 by American Megatrends
[    0.000000] efi:  ACPI 2.0=0xdbb3c000  ACPI=0xdbb3c000  SMBIOS=0xdc902000  SMBIOS 3.0=0xdc901000  ESRT=0xda123218
[    0.000000] SMBIOS 3.2.0 present.
[    0.000000] DMI: Gigabyte Technology Co., Ltd. AX370-Gaming 5/AX370-Gaming 5, BIOS F50e 07/02/2020
[    0.000000] tsc: Fast TSC calibration failed
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] last_pfn = 0x81f380 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF write-through
[    0.000000]   C0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000000 mask FFFF80000000 write-back
[    0.000000]   1 base 000080000000 mask FFFFC0000000 write-back
[    0.000000]   2 base 0000C0000000 mask FFFFE0000000 write-back
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000000] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[    0.000000] last_pfn = 0xdf000 max_arch_pfn = 0x400000000
[    0.000000] esrt: Reserving ESRT space from 0x00000000da123218 to 0x00000000da123250.
[    0.000000] e820: update [mem 0xda123000-0xda123fff] usable ==> reserved
[    0.000000] check: Scanning 1 areas for low memory corruption
[    0.000000] Using GB pages for direct mapping
[    0.000000] Secure boot could not be determined
[    0.000000] RAMDISK: [mem 0x36ccd000-0x3765dfff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000DBB3C000 000024 (v02 ALASKA)
[    0.000000] ACPI: XSDT 0x00000000DBB3C0A0 0000C4 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FACP 0x00000000DBB430A8 000114 (v06 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: DSDT 0x00000000DBB3C200 006EA4 (v02 ALASKA A M I    01072009 INTL 20160930)
[    0.000000] ACPI: FACS 0x00000000DBBA8E00 000040
[    0.000000] ACPI: APIC 0x00000000DBB431C0 00015E (v03 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FPDT 0x00000000DBB43320 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FIDT 0x00000000DBB43368 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 0x00000000DBB43408 0000FC (v02 ALASKA A M I    01072009 AMI  01072009)
[    0.000000] ACPI: SSDT 0x00000000DBB43508 008C98 (v02 ALASKA A M I    00000002 MSFT 04000000)
[    0.000000] ACPI: SSDT 0x00000000DBB4C1A0 00384D (v01 ALASKA A M I    00000001 INTL 20160930)
[    0.000000] ACPI: MCFG 0x00000000DBB4F9F0 00003C (v01 ALASKA A M I    01072009 MSFT 00010013)
[    0.000000] ACPI: SSDT 0x00000000DBB4FA30 006A29 (v01 ALASKA A M I    00000001 INTL 20160930)
[    0.000000] ACPI: HPET 0x00000000DBB56460 000038 (v01 ALASKA A M I    01072009 AMI  00000005)
[    0.000000] ACPI: SSDT 0x00000000DBB56498 000024 (v01 ALASKA A M I    00001000 INTL 20160930)
[    0.000000] ACPI: UEFI 0x00000000DBB564C0 000042 (v01 ALASKA A M I    00000002      01000013)
[    0.000000] ACPI: BGRT 0x00000000DBB56508 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: IVRS 0x00000000DBB56540 0000D0 (v02 ALASKA A M I    00000001 AMD  00000000)
[    0.000000] ACPI: CRAT 0x00000000DBB56610 000F50 (v01 ALASKA A M I    00000001 AMD  00000001)
[    0.000000] ACPI: CDIT 0x00000000DBB57560 000029 (v01 ALASKA A M I    00000001 AMD  00000001)
[    0.000000] ACPI: SSDT 0x00000000DBB57590 001EC3 (v01 ALASKA A M I    00000001 INTL 20160930)
[    0.000000] ACPI: SSDT 0x00000000DBB59458 0000BF (v01 ALASKA A M I    00001000 INTL 20160930)
[    0.000000] ACPI: WSMT 0x00000000DBB59518 000028 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 0x00000000DBB59540 0013F0 (v01 ALASKA A M I    00000001 INTL 20160930)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000081f37ffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x81f37c000-0x81f37ffff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000081f37ffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009ffff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x0000000009e01fff]
[    0.000000]   node   0: [mem 0x000000000a000000-0x000000000a1fffff]
[    0.000000]   node   0: [mem 0x000000000a20b000-0x000000000affffff]
[    0.000000]   node   0: [mem 0x000000000b020000-0x00000000db48cfff]
[    0.000000]   node   0: [mem 0x00000000db61e000-0x00000000db7a1fff]
[    0.000000]   node   0: [mem 0x00000000dcac1000-0x00000000deffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000081f37ffff]
[    0.000000] Zeroed struct page in unavailable ranges: 13242 pages
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000081f37ffff]
[    0.000000] On node 0 totalpages: 8375366
[    0.000000]   DMA zone: 33 pages reserved
[    0.000000]   DMA zone: 3999 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 14117 pages used for memmap
[    0.000000]   DMA32 zone: 903463 pages, LIFO batch:63
[    0.000000]   Normal zone: 116686 pages used for memmap
[    0.000000]   Normal zone: 7467904 pages, LIFO batch:63
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 17, version 33, address 0xfec00000, GSI 0-23
[    0.000000] IOAPIC[1]: apic_id 18, version 33, address 0xfec01000, GSI 24-55
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x10228201 base: 0xfed00000
[    0.000000] e820: update [mem 0xd7993000-0xd79e9fff] usable ==> reserved
[    0.000000] smpboot: Allowing 32 CPUs, 16 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x09e02000-0x09ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0x0a200000-0x0a20afff]
[    0.000000] PM: Registered nosave memory: [mem 0x0b000000-0x0b01ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xd7993000-0xd79e9fff]
[    0.000000] PM: Registered nosave memory: [mem 0xda123000-0xda123fff]
[    0.000000] PM: Registered nosave memory: [mem 0xdb48d000-0xdb61dfff]
[    0.000000] PM: Registered nosave memory: [mem 0xdb7a2000-0xdbbbffff]
[    0.000000] PM: Registered nosave memory: [mem 0xdbbc0000-0xdca18fff]
[    0.000000] PM: Registered nosave memory: [mem 0xdca19000-0xdcac0fff]
[    0.000000] PM: Registered nosave memory: [mem 0xdf000000-0xdfffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xf7ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfcffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfd000000-0xffffffff]
[    0.000000] [mem 0xe0000000-0xf7ffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.000000] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:32 nr_node_ids:1
[    0.000000] percpu: Embedded 54 pages/cpu s184320 r8192 d28672 u262144
[    0.000000] pcpu-alloc: s184320 r8192 d28672 u262144 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[    0.000000] pcpu-alloc: [0] 16 17 18 19 20 21 22 23 [0] 24 25 26 27 28 29 30 31
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 8244466
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=50f91562-d5e0-4da1-9fc6-ee25a26193d6 rw quiet apparmor=1 security=apparmor udev.log_priority=3 iommu=pt idle=nomwait rcu_nocbs=0-15 processor.max_cstate=5
[    0.000000] printk: log_buf_len individual max cpu contribution: 4096 bytes
[    0.000000] printk: log_buf_len total cpu_extra contributions: 126976 bytes
[    0.000000] printk: log_buf_len min size: 131072 bytes
[    0.000000] printk: log_buf_len: 262144 bytes
[    0.000000] printk: early log buf free: 119148(90%)
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] mem auto-init: stack:byref_all, heap alloc:on, heap free:off
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x3e/0x610 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
[    0.000000] ftrace: allocating 37553 entries in 147 pages
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=32.
[    0.000000] rcu:     RCU priority boosting: priority 1 delay 500 ms.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[    0.000000] NR_IRQS: 20736, nr_irqs: 1224, preallocated irqs: 16
[    0.000000] Console: colour dummy device 80x25
[    0.000000] printk: console [tty0] enabled
[    0.000000] ACPI: Core revision 20190816
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[    0.000000] APIC: Switch to symmetric I/O mode setup
[    0.003333] Switched APIC routing to physical flat.
[    0.003333] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.023333] tsc: PIT calibration matches HPET. 1 loops
[    0.023333] tsc: Detected 3393.072 MHz processor
[    0.000003] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x30e8bdd9448, max_idle_ns: 440795312218 ns
[    0.000006] Calibrating delay loop (skipped), value calculated using timer frequency.. 6788.90 BogoMIPS (lpj=11310240)
[    0.000007] pid_max: default: 32768 minimum: 301
[    0.003379] LSM: Security Framework initializing
[    0.003382] Yama: becoming mindful.
[    0.003467] AppArmor: AppArmor initialized
[    0.003524] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.003573] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.003583] *** VALIDATE tmpfs ***
[    0.003714] *** VALIDATE proc ***
[    0.003766] *** VALIDATE cgroup1 ***
[    0.003767] *** VALIDATE cgroup2 ***
[    0.003817] LVT offset 1 assigned for vector 0xf9
[    0.003876] LVT offset 2 assigned for vector 0xf4
[    0.003892] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
[    0.003892] Last level dTLB entries: 4KB 1536, 2MB 1536, 4MB 768, 1GB 0
[    0.003894] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.003896] Spectre V2 : Mitigation: Full AMD retpoline
[    0.003896] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.003897] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.003898] Spectre V2 : User space: Vulnerable
[    0.003899] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.004151] Freeing SMP alternatives memory: 32K
[    0.115777] smpboot: CPU0: AMD Ryzen 7 1700X Eight-Core Processor (family: 0x17, model: 0x1, stepping: 0x1)
[    0.115863] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[    0.115866] ... version:                0
[    0.115867] ... bit width:              48
[    0.115867] ... generic registers:      6
[    0.115868] ... value mask:             0000ffffffffffff
[    0.115868] ... max period:             00007fffffffffff
[    0.115868] ... fixed-purpose events:   0
[    0.115869] ... event mask:             000000000000003f
[    0.115901] rcu: Hierarchical SRCU implementation.
[    0.116279] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.116494] smp: Bringing up secondary CPUs ...
[    0.116592] x86: Booting SMP configuration:
[    0.146728] smp: Brought up 1 node, 16 CPUs
[    0.146728] smpboot: Max logical packages: 2
[    0.146728] smpboot: Total of 16 processors activated (108621.40 BogoMIPS)
[    0.150441] devtmpfs: initialized
[    0.150441] x86/mm: Memory block size: 128MB
[    0.152349] PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20afff] (45056 bytes)
[    0.152349] PM: Registering ACPI NVS region [mem 0xdb7a2000-0xdbbbffff] (4317184 bytes)
[    0.152349] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.152349] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[    0.152349] pinctrl core: initialized pinctrl subsystem
[    0.153341] PM: RTC time: 10:31:59, date: 2020-10-02
[    0.153456] NET: Registered protocol family 16
[    0.153523] audit: initializing netlink subsys (disabled)
[    0.153529] audit: type=2000 audit(1601634719.176:1): state=initialized audit_enabled=0 res=1
[    0.153529] cpuidle: using governor ladder
[    0.153529] cpuidle: using governor menu
[    0.153529] ACPI: bus type PCI registered
[    0.153529] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.153529] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.153529] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.153529] PCI: Using configuration type 1 for base access
[    0.155396] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.155396] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.156770] ACPI: Added _OSI(Module Device)
[    0.156771] ACPI: Added _OSI(Processor Device)
[    0.156772] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.156772] ACPI: Added _OSI(Processor Aggregator Device)
[    0.156773] ACPI: Added _OSI(Linux-Dell-Video)
[    0.156773] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.156774] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.168728] ACPI: 9 ACPI AML tables successfully acquired and loaded
[    0.170270] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.177438] ACPI: Interpreter enabled
[    0.177453] ACPI: (supports S0 S3 S4 S5)
[    0.177454] ACPI: Using IOAPIC for interrupt routing
[    0.177808] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.178232] ACPI: Enabled 3 GPEs in block 00 to 1F
[    0.188555] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.188560] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[    0.188655] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR]
[    0.188655] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[    0.188655] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[    0.188655] PCI host bridge to bus 0000:00
[    0.188655] pci_bus 0000:00: root bus resource [io  0x0000-0x03af window]
[    0.188655] pci_bus 0000:00: root bus resource [io  0x03e0-0x0cf7 window]
[    0.188655] pci_bus 0000:00: root bus resource [io  0x03b0-0x03df window]
[    0.188655] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.188655] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.188655] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[    0.188655] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfec2ffff window]
[    0.188655] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[    0.188655] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.188655] pci 0000:00:00.0: [1022:1450] type 00 class 0x060000
[    0.188655] pci 0000:00:00.2: [1022:1451] type 00 class 0x080600
[    0.188655] pci 0000:00:01.0: [1022:1452] type 00 class 0x060000
[    0.188655] pci 0000:00:01.3: [1022:1453] type 01 class 0x060400
[    0.188655] pci 0000:00:01.3: PME# supported from D0 D3hot D3cold
[    0.188655] pci 0000:00:02.0: [1022:1452] type 00 class 0x060000
[    0.188655] pci 0000:00:03.0: [1022:1452] type 00 class 0x060000
[    0.188655] pci 0000:00:03.1: [1022:1453] type 01 class 0x060400
[    0.188655] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[    0.188655] pci 0000:00:04.0: [1022:1452] type 00 class 0x060000
[    0.188655] pci 0000:00:07.0: [1022:1452] type 00 class 0x060000
[    0.188655] pci 0000:00:07.1: [1022:1454] type 01 class 0x060400
[    0.188655] pci 0000:00:07.1: enabling Extended Tags
[    0.188655] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[    0.188655] pci 0000:00:08.0: [1022:1452] type 00 class 0x060000
[    0.188670] pci 0000:00:08.1: [1022:1454] type 01 class 0x060400
[    0.188701] pci 0000:00:08.1: enabling Extended Tags
[    0.188776] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[    0.188932] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[    0.189159] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[    0.189388] pci 0000:00:18.0: [1022:1460] type 00 class 0x060000
[    0.189445] pci 0000:00:18.1: [1022:1461] type 00 class 0x060000
[    0.189504] pci 0000:00:18.2: [1022:1462] type 00 class 0x060000
[    0.189561] pci 0000:00:18.3: [1022:1463] type 00 class 0x060000
[    0.189618] pci 0000:00:18.4: [1022:1464] type 00 class 0x060000
[    0.189674] pci 0000:00:18.5: [1022:1465] type 00 class 0x060000
[    0.189730] pci 0000:00:18.6: [1022:1466] type 00 class 0x060000
[    0.189786] pci 0000:00:18.7: [1022:1467] type 00 class 0x060000
[    0.189934] pci 0000:01:00.0: [1022:43b9] type 00 class 0x0c0330
[    0.189955] pci 0000:01:00.0: reg 0x10: [mem 0xfcaa0000-0xfcaa7fff 64bit]
[    0.189988] pci 0000:01:00.0: enabling Extended Tags
[    0.190036] pci 0000:01:00.0: PME# supported from D3hot D3cold
[    0.190114] pci 0000:01:00.1: [1022:43b5] type 00 class 0x010601
[    0.190158] pci 0000:01:00.1: reg 0x24: [mem 0xfca80000-0xfca9ffff]
[    0.190165] pci 0000:01:00.1: reg 0x30: [mem 0xfca00000-0xfca7ffff pref]
[    0.190170] pci 0000:01:00.1: enabling Extended Tags
[    0.190206] pci 0000:01:00.1: PME# supported from D3hot D3cold
[    0.190264] pci 0000:01:00.2: [1022:43b0] type 01 class 0x060400
[    0.190305] pci 0000:01:00.2: enabling Extended Tags
[    0.190345] pci 0000:01:00.2: PME# supported from D3hot D3cold
[    0.190428] pci 0000:00:01.3: PCI bridge to [bus 01-06]
[    0.190431] pci 0000:00:01.3:   bridge window [io  0xd000-0xefff]
[    0.190432] pci 0000:00:01.3:   bridge window [mem 0xfc700000-0xfcafffff]
[    0.190528] pci 0000:02:00.0: [1022:43b4] type 01 class 0x060400
[    0.190574] pci 0000:02:00.0: enabling Extended Tags
[    0.190624] pci 0000:02:00.0: PME# supported from D3hot D3cold
[    0.190702] pci 0000:02:02.0: [1022:43b4] type 01 class 0x060400
[    0.190747] pci 0000:02:02.0: enabling Extended Tags
[    0.190797] pci 0000:02:02.0: PME# supported from D3hot D3cold
[    0.190871] pci 0000:02:03.0: [1022:43b4] type 01 class 0x060400
[    0.190916] pci 0000:02:03.0: enabling Extended Tags
[    0.190965] pci 0000:02:03.0: PME# supported from D3hot D3cold
[    0.191043] pci 0000:02:04.0: [1022:43b4] type 01 class 0x060400
[    0.191088] pci 0000:02:04.0: enabling Extended Tags
[    0.191138] pci 0000:02:04.0: PME# supported from D3hot D3cold
[    0.191225] pci 0000:01:00.2: PCI bridge to [bus 02-06]
[    0.191230] pci 0000:01:00.2:   bridge window [io  0xd000-0xefff]
[    0.191232] pci 0000:01:00.2:   bridge window [mem 0xfc700000-0xfc9fffff]
[    0.191304] pci 0000:03:00.0: [1b21:1343] type 00 class 0x0c0330
[    0.191343] pci 0000:03:00.0: reg 0x10: [mem 0xfc900000-0xfc907fff 64bit]
[    0.191681] pci 0000:02:00.0: PCI bridge to [bus 03]
[    0.191687] pci 0000:02:00.0:   bridge window [mem 0xfc900000-0xfc9fffff]
[    0.191754] pci 0000:04:00.0: [8086:1539] type 00 class 0x020000
[    0.191797] pci 0000:04:00.0: reg 0x10: [mem 0xfc800000-0xfc81ffff]
[    0.191829] pci 0000:04:00.0: reg 0x18: [io  0xe000-0xe01f]
[    0.191846] pci 0000:04:00.0: reg 0x1c: [mem 0xfc820000-0xfc823fff]
[    0.192019] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
[    0.192150] pci 0000:02:02.0: PCI bridge to [bus 04]
[    0.192155] pci 0000:02:02.0:   bridge window [io  0xe000-0xefff]
[    0.192157] pci 0000:02:02.0:   bridge window [mem 0xfc800000-0xfc8fffff]
[    0.192216] pci 0000:05:00.0: [1969:e0b1] type 00 class 0x020000
[    0.192259] pci 0000:05:00.0: reg 0x10: [mem 0xfc700000-0xfc73ffff 64bit]
[    0.192273] pci 0000:05:00.0: reg 0x18: [io  0xd000-0xd07f]
[    0.192424] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.192548] pci 0000:02:03.0: PCI bridge to [bus 05]
[    0.192552] pci 0000:02:03.0:   bridge window [io  0xd000-0xdfff]
[    0.192554] pci 0000:02:03.0:   bridge window [mem 0xfc700000-0xfc7fffff]
[    0.192595] pci 0000:02:04.0: PCI bridge to [bus 06]
[    0.192685] pci 0000:07:00.0: [1002:67df] type 00 class 0x030000
[    0.192706] pci 0000:07:00.0: reg 0x10: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.192715] pci 0000:07:00.0: reg 0x18: [mem 0xf0000000-0xf01fffff 64bit pref]
[    0.192720] pci 0000:07:00.0: reg 0x20: [io  0xf000-0xf0ff]
[    0.192726] pci 0000:07:00.0: reg 0x24: [mem 0xfcf00000-0xfcf3ffff]
[    0.192731] pci 0000:07:00.0: reg 0x30: [mem 0xfcf40000-0xfcf5ffff pref]
[    0.192743] pci 0000:07:00.0: BAR 0: assigned to efifb
[    0.192790] pci 0000:07:00.0: supports D1 D2
[    0.192791] pci 0000:07:00.0: PME# supported from D1 D2 D3hot D3cold
[    0.192867] pci 0000:07:00.1: [1002:aaf0] type 00 class 0x040300
[    0.192884] pci 0000:07:00.1: reg 0x10: [mem 0xfcf60000-0xfcf63fff 64bit]
[    0.192949] pci 0000:07:00.1: supports D1 D2
[    0.193018] pci 0000:00:03.1: PCI bridge to [bus 07]
[    0.193021] pci 0000:00:03.1:   bridge window [io  0xf000-0xffff]
[    0.193022] pci 0000:00:03.1:   bridge window [mem 0xfcf00000-0xfcffffff]
[    0.193024] pci 0000:00:03.1:   bridge window [mem 0xe0000000-0xf01fffff 64bit pref]
[    0.193092] pci 0000:08:00.0: [1022:145a] type 00 class 0x130000
[    0.193115] pci 0000:08:00.0: enabling Extended Tags
[    0.193169] pci 0000:08:00.2: [1022:1456] type 00 class 0x108000
[    0.193182] pci 0000:08:00.2: reg 0x18: [mem 0xfcc00000-0xfccfffff]
[    0.193189] pci 0000:08:00.2: reg 0x24: [mem 0xfcd00000-0xfcd01fff]
[    0.193194] pci 0000:08:00.2: enabling Extended Tags
[    0.193261] pci 0000:08:00.3: [1022:145c] type 00 class 0x0c0330
[    0.193272] pci 0000:08:00.3: reg 0x10: [mem 0xfcb00000-0xfcbfffff 64bit]
[    0.193291] pci 0000:08:00.3: enabling Extended Tags
[    0.193314] pci 0000:08:00.3: PME# supported from D0 D3hot D3cold
[    0.193366] pci 0000:00:07.1: PCI bridge to [bus 08]
[    0.193370] pci 0000:00:07.1:   bridge window [mem 0xfcb00000-0xfcdfffff]
[    0.193443] pci 0000:09:00.0: [1022:1455] type 00 class 0x130000
[    0.193468] pci 0000:09:00.0: enabling Extended Tags
[    0.193526] pci 0000:09:00.2: [1022:7901] type 00 class 0x010601
[    0.193552] pci 0000:09:00.2: reg 0x24: [mem 0xfce08000-0xfce08fff]
[    0.193558] pci 0000:09:00.2: enabling Extended Tags
[    0.193584] pci 0000:09:00.2: PME# supported from D3hot D3cold
[    0.193631] pci 0000:09:00.3: [1022:1457] type 00 class 0x040300
[    0.193640] pci 0000:09:00.3: reg 0x10: [mem 0xfce00000-0xfce07fff]
[    0.193657] pci 0000:09:00.3: enabling Extended Tags
[    0.193682] pci 0000:09:00.3: PME# supported from D0 D3hot D3cold
[    0.193739] pci 0000:00:08.1:   bridge window [mem 0xfce00000-0xfcefffff]
[    0.194054] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 5 7 10 11 14 15) *0
[    0.194115] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 5 7 10 11 14 15) *0
[    0.194168] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 5 7 10 11 14 15) *0
[    0.194233] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 5 7 10 11 14 15) *0
[    0.194291] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 5 7 10 11 14 15) *0
[    0.194339] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 5 7 10 11 14 15) *0
[    0.194387] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 5 7 10 11 14 15) *0
[    0.194435] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 5 7 10 11 14 15) *0
[    0.196673] iommu: Default domain type: Passthrough (set via kernel command line)
[    0.196686] pci 0000:07:00.0: vgaarb: setting as boot VGA device
[    0.196686] pci 0000:07:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.196686] pci 0000:07:00.0: vgaarb: bridge control possible
[    0.196686] vgaarb: loaded
[    0.196792] ACPI: bus type USB registered
[    0.196800] usbcore: registered new interface driver usbfs
[    0.196804] usbcore: registered new interface driver hub
[    0.196839] usbcore: registered new device driver usb
[    0.196853] pps_core: LinuxPPS API ver. 1 registered
[    0.196854] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.196855] PTP clock support registered
[    0.196860] EDAC MC: Ver: 3.0.0
[    0.196941] Registered efivars operations
[    0.196941] PCI: Using ACPI for IRQ routing
[    0.199674] PCI: pci_cache_line_size set to 64 bytes
[    0.199734] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[    0.199735] e820: reserve RAM buffer [mem 0x09e02000-0x0bffffff]
[    0.199736] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[    0.199737] e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff]
[    0.199738] e820: reserve RAM buffer [mem 0xd7993000-0xd7ffffff]
[    0.199738] e820: reserve RAM buffer [mem 0xda123000-0xdbffffff]
[    0.199739] e820: reserve RAM buffer [mem 0xdb48d000-0xdbffffff]
[    0.199739] e820: reserve RAM buffer [mem 0xdb7a2000-0xdbffffff]
[    0.199740] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[    0.199740] e820: reserve RAM buffer [mem 0x81f380000-0x81fffffff]
[    0.200007] NetLabel: Initializing
[    0.200007] NetLabel:  domain hash size = 128
[    0.200007] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.200007] NetLabel:  unlabeled traffic allowed by default
[    0.200055] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.200057] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    0.204404] clocksource: Switched to clocksource tsc-early
[    0.212063] *** VALIDATE bpf ***
[    0.212140] VFS: Disk quotas dquot_6.6.0
[    0.212157] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.212177] *** VALIDATE ramfs ***
[    0.212182] *** VALIDATE hugetlbfs ***
[    0.212251] AppArmor: AppArmor Filesystem Enabled
[    0.212273] pnp: PnP ACPI init
[    0.212397] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.212401] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.212485] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.212652] system 00:02: [io  0x0a00-0x0a2f] has been reserved
[    0.212653] system 00:02: [io  0x0a30-0x0a3f] has been reserved
[    0.212654] system 00:02: [io  0x0a40-0x0a4f] has been reserved
[    0.212656] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.212913] system 00:03: [io  0x040b] has been reserved
[    0.212914] system 00:03: [io  0x04d6] has been reserved
[    0.212915] system 00:03: [io  0x0c00-0x0c01] has been reserved
[    0.212916] system 00:03: [io  0x0c14] has been reserved
[    0.212917] system 00:03: [io  0x0c50-0x0c51] has been reserved
[    0.212917] system 00:03: [io  0x0c52] has been reserved
[    0.212918] system 00:03: [io  0x0c6c] has been reserved
[    0.212919] system 00:03: [io  0x0c6f] has been reserved
[    0.212920] system 00:03: [io  0x0cd0-0x0cd1] has been reserved
[    0.212921] system 00:03: [io  0x0cd2-0x0cd3] has been reserved
[    0.212921] system 00:03: [io  0x0cd4-0x0cd5] has been reserved
[    0.212922] system 00:03: [io  0x0cd6-0x0cd7] has been reserved
[    0.212923] system 00:03: [io  0x0cd8-0x0cdf] has been reserved
[    0.212924] system 00:03: [io  0x0800-0x089f] has been reserved
[    0.212925] system 00:03: [io  0x0b00-0x0b0f] has been reserved
[    0.212925] system 00:03: [io  0x0b20-0x0b3f] has been reserved
[    0.212926] system 00:03: [io  0x0900-0x090f] has been reserved
[    0.212927] system 00:03: [io  0x0910-0x091f] has been reserved
[    0.212928] system 00:03: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.212929] system 00:03: [mem 0xfec01000-0xfec01fff] could not be reserved
[    0.212930] system 00:03: [mem 0xfedc0000-0xfedc0fff] has been reserved
[    0.212931] system 00:03: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.212932] system 00:03: [mem 0xfed80000-0xfed8ffff] could not be reserved
[    0.212933] system 00:03: [mem 0xfec10000-0xfec10fff] has been reserved
[    0.212934] system 00:03: [mem 0xff000000-0xffffffff] has been reserved
[    0.212937] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.213411] pnp: PnP ACPI: found 4 devices
[    0.214426] thermal_sys: Registered thermal governor 'fair_share'
[    0.214426] thermal_sys: Registered thermal governor 'bang_bang'
[    0.214427] thermal_sys: Registered thermal governor 'step_wise'
[    0.214427] thermal_sys: Registered thermal governor 'user_space'
[    0.214428] thermal_sys: Registered thermal governor 'power_allocator'
[    0.218979] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.219011] pci 0000:02:00.0: PCI bridge to [bus 03]
[    0.219015] pci 0000:02:00.0:   bridge window [mem 0xfc900000-0xfc9fffff]
[    0.219021] pci 0000:02:02.0: PCI bridge to [bus 04]
[    0.219023] pci 0000:02:02.0:   bridge window [io  0xe000-0xefff]
[    0.219027] pci 0000:02:02.0:   bridge window [mem 0xfc800000-0xfc8fffff]
[    0.219033] pci 0000:02:03.0: PCI bridge to [bus 05]
[    0.219035] pci 0000:02:03.0:   bridge window [io  0xd000-0xdfff]
[    0.219038] pci 0000:02:03.0:   bridge window [mem 0xfc700000-0xfc7fffff]
[    0.219044] pci 0000:02:04.0: PCI bridge to [bus 06]
[    0.219052] pci 0000:01:00.2: PCI bridge to [bus 02-06]
[    0.219054] pci 0000:01:00.2:   bridge window [io  0xd000-0xefff]
[    0.219057] pci 0000:01:00.2:   bridge window [mem 0xfc700000-0xfc9fffff]
[    0.219063] pci 0000:00:01.3: PCI bridge to [bus 01-06]
[    0.219064] pci 0000:00:01.3:   bridge window [io  0xd000-0xefff]
[    0.219066] pci 0000:00:01.3:   bridge window [mem 0xfc700000-0xfcafffff]
[    0.219070] pci 0000:00:03.1: PCI bridge to [bus 07]
[    0.219071] pci 0000:00:03.1:   bridge window [io  0xf000-0xffff]
[    0.219073] pci 0000:00:03.1:   bridge window [mem 0xfcf00000-0xfcffffff]
[    0.219074] pci 0000:00:03.1:   bridge window [mem 0xe0000000-0xf01fffff 64bit pref]
[    0.219077] pci 0000:00:07.1: PCI bridge to [bus 08]
[    0.219079] pci 0000:00:07.1:   bridge window [mem 0xfcb00000-0xfcdfffff]
[    0.219083] pci 0000:00:08.1: PCI bridge to [bus 09]
[    0.219085] pci 0000:00:08.1:   bridge window [mem 0xfce00000-0xfcefffff]
[    0.219090] pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7 window]
[    0.219091] pci_bus 0000:00: resource 6 [io  0x03b0-0x03df window]
[    0.219091] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
[    0.219092] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[    0.219093] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[    0.219094] pci_bus 0000:00: resource 10 [mem 0xe0000000-0xfec2ffff window]
[    0.219095] pci_bus 0000:00: resource 11 [mem 0xfee00000-0xffffffff window]
[    0.219096] pci_bus 0000:01: resource 0 [io  0xd000-0xefff]
[    0.219096] pci_bus 0000:01: resource 1 [mem 0xfc700000-0xfcafffff]
[    0.219097] pci_bus 0000:02: resource 0 [io  0xd000-0xefff]
[    0.219098] pci_bus 0000:02: resource 1 [mem 0xfc700000-0xfc9fffff]
[    0.219099] pci_bus 0000:03: resource 1 [mem 0xfc900000-0xfc9fffff]
[    0.219100] pci_bus 0000:04: resource 0 [io  0xe000-0xefff]
[    0.219100] pci_bus 0000:04: resource 1 [mem 0xfc800000-0xfc8fffff]
[    0.219101] pci_bus 0000:05: resource 0 [io  0xd000-0xdfff]
[    0.219102] pci_bus 0000:05: resource 1 [mem 0xfc700000-0xfc7fffff]
[    0.219103] pci_bus 0000:07: resource 0 [io  0xf000-0xffff]
[    0.219103] pci_bus 0000:07: resource 1 [mem 0xfcf00000-0xfcffffff]
[    0.219104] pci_bus 0000:07: resource 2 [mem 0xe0000000-0xf01fffff 64bit pref]
[    0.219105] pci_bus 0000:08: resource 1 [mem 0xfcb00000-0xfcdfffff]
[    0.219106] pci_bus 0000:09: resource 1 [mem 0xfce00000-0xfcefffff]
[    0.219189] NET: Registered protocol family 2
[    0.219347] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.219558] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.219846] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.219923] TCP: Hash tables configured (established 262144 bind 65536)
[    0.219987] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.220066] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.220216] NET: Registered protocol family 1
[    0.220220] NET: Registered protocol family 44
[    0.220502] pci 0000:07:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.220509] pci 0000:07:00.1: D0 power state depends on 0000:07:00.0
[    0.220651] PCI: CLS 64 bytes, default 64
[    0.220692] Trying to unpack rootfs image as initramfs...
[    0.331137] Freeing initrd memory: 9796K
[    0.331157] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[    0.331360] pci 0000:00:01.0: Adding to iommu group 0
[    0.331387] pci 0000:00:01.3: Adding to iommu group 0
[    0.331405] pci 0000:00:02.0: Adding to iommu group 1
[    0.331428] pci 0000:00:03.0: Adding to iommu group 2
[    0.331442] pci 0000:00:03.1: Adding to iommu group 2
[    0.331456] pci 0000:00:04.0: Adding to iommu group 3
[    0.331474] pci 0000:00:07.0: Adding to iommu group 4
[    0.331486] pci 0000:00:07.1: Adding to iommu group 4
[    0.331509] pci 0000:00:08.0: Adding to iommu group 5
[    0.331522] pci 0000:00:08.1: Adding to iommu group 5
[    0.331542] pci 0000:00:14.0: Adding to iommu group 6
[    0.331553] pci 0000:00:14.3: Adding to iommu group 6
[    0.331590] pci 0000:00:18.0: Adding to iommu group 7
[    0.331600] pci 0000:00:18.1: Adding to iommu group 7
[    0.331610] pci 0000:00:18.2: Adding to iommu group 7
[    0.331620] pci 0000:00:18.3: Adding to iommu group 7
[    0.331631] pci 0000:00:18.4: Adding to iommu group 7
[    0.331643] pci 0000:00:18.5: Adding to iommu group 7
[    0.331654] pci 0000:00:18.6: Adding to iommu group 7
[    0.331666] pci 0000:00:18.7: Adding to iommu group 7
[    0.331687] pci 0000:01:00.1: Adding to iommu group 0
[    0.331695] pci 0000:01:00.2: Adding to iommu group 0
[    0.331705] pci 0000:02:00.0: Adding to iommu group 0
[    0.331715] pci 0000:02:02.0: Adding to iommu group 0
[    0.331725] pci 0000:02:03.0: Adding to iommu group 0
[    0.331734] pci 0000:02:04.0: Adding to iommu group 0
[    0.331750] pci 0000:03:00.0: Adding to iommu group 0
[    0.331764] pci 0000:04:00.0: Adding to iommu group 0
[    0.331777] pci 0000:05:00.0: Adding to iommu group 0
[    0.331798] pci 0000:07:00.0: Adding to iommu group 2
[    0.331807] pci 0000:07:00.1: Adding to iommu group 2
[    0.331815] pci 0000:08:00.0: Adding to iommu group 4
[    0.331822] pci 0000:08:00.2: Adding to iommu group 4
[    0.331830] pci 0000:08:00.3: Adding to iommu group 4
[    0.331838] pci 0000:09:00.0: Adding to iommu group 5
[    0.331846] pci 0000:09:00.2: Adding to iommu group 5
[    0.331855] pci 0000:09:00.3: Adding to iommu group 5
[    0.332076] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[    0.332077] pci 0000:00:00.2: AMD-Vi: Extended features (0xf77ef22294ada):
[    0.332078]  PPR NX GT IA GA PC GA_vAPIC
[    0.332080] AMD-Vi: Interrupt remapping enabled
[    0.332080] AMD-Vi: Virtual APIC enabled
[    0.332157] AMD-Vi: Lazy IO/TLB flushing enabled
[    0.332158] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.332159] software IO TLB: mapped [mem 0xd31d7000-0xd71d7000] (64MB)
[    0.332203] amd_uncore: AMD NB counters detected
[    0.332207] amd_uncore: AMD LLC counters detected
[    0.332437] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[    0.332475] check: Scanning for low memory corruption every 60 seconds
[    0.332889] Initialise system trusted keyrings
[    0.332901] Key type blacklist registered
[    0.332931] workingset: timestamp_bits=41 max_order=23 bucket_order=0
[    0.333758] zbud: loaded
[    0.337042] Key type asymmetric registered
[    0.337044] Asymmetric key parser 'x509' registered
[    0.337051] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.337103] io scheduler mq-deadline registered
[    0.337104] io scheduler kyber registered
[    0.337121] io scheduler bfq registered
[    0.337439] pcieport 0000:00:01.3: PME: Signaling with IRQ 28
[    0.337610] pcieport 0000:00:03.1: PME: Signaling with IRQ 29
[    0.337793] pcieport 0000:00:07.1: PME: Signaling with IRQ 30
[    0.338053] pcieport 0000:00:08.1: PME: Signaling with IRQ 31
[    0.338654] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.338704] efifb: probing for efifb
[    0.338725] efifb: showing boot graphics
[    0.339236] efifb: framebuffer at 0xe0000000, using 3072k, total 3072k
[    0.339237] efifb: mode is 1024x768x32, linelength=4096, pages=1
[    0.339237] efifb: scrolling: redraw
[    0.339238] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.339272] fbcon: Deferring console take-over
[    0.339272] fb0: EFI VGA frame buffer device
[    0.339324] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.339339] ACPI: Power Button [PWRB]
[    0.339375] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.342978] ACPI: Power Button [PWRF]
[    0.344389] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    0.345290] usbcore: registered new interface driver usbserial_generic
[    0.345293] usbserial: USB Serial support registered for generic
[    0.345318] rtc_cmos 00:01: RTC can wake from S4
[    0.345593] rtc_cmos 00:01: registered as rtc0
[    0.345603] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    0.345751] ledtrig-cpu: registered to indicate activity on CPUs
[    0.345808] drop_monitor: Initializing network drop monitor service
[    0.345923] NET: Registered protocol family 10
[    0.348958] Segment Routing with IPv6
[    0.348971] NET: Registered protocol family 17
[    0.349689] RAS: Correctable Errors collector initialized.
[    0.349712] microcode: CPU0: patch_level=0x08001138
[    0.349714] microcode: CPU1: patch_level=0x08001138
[    0.349717] microcode: CPU2: patch_level=0x08001138
[    0.349721] microcode: CPU3: patch_level=0x08001138
[    0.349726] microcode: CPU4: patch_level=0x08001138
[    0.349732] microcode: CPU5: patch_level=0x08001138
[    0.349737] microcode: CPU6: patch_level=0x08001138
[    0.349743] microcode: CPU7: patch_level=0x08001138
[    0.349746] microcode: CPU8: patch_level=0x08001138
[    0.349750] microcode: CPU9: patch_level=0x08001138
[    0.349753] microcode: CPU10: patch_level=0x08001138
[    0.349756] microcode: CPU11: patch_level=0x08001138
[    0.349760] microcode: CPU12: patch_level=0x08001138
[    0.349764] microcode: CPU13: patch_level=0x08001138
[    0.349768] microcode: CPU14: patch_level=0x08001138
[    0.349772] microcode: CPU15: patch_level=0x08001138
[    0.349795] microcode: Microcode Update Driver: v2.2.
[    0.349797] IPI shorthand broadcast: enabled
[    0.349803] sched_clock: Marking stable (373119853, -23328313)->(363900691, -14109151)
[    0.349854] registered taskstats version 1
[    0.349859] Loading compiled-in X.509 certificates
[    0.351584] Loaded X.509 cert 'Build time autogenerated kernel key: c44e1a22933a93378b0beabc0792c7535405f971'
[    0.351635] zswap: loaded using pool lzo/zbud
[    0.351702] Key type ._fscrypt registered
[    0.351703] Key type .fscrypt registered
[    0.354515] Key type big_key registered
[    0.354517] AppArmor: AppArmor sha1 policy hashing enabled
[    0.354860] PM:   Magic number: 8:710:526
[    0.355010] rtc_cmos 00:01: setting system clock to 2020-10-02T10:31:59 UTC (1601634719)
[    0.356124] Freeing unused decrypted memory: 2040K
[    0.356354] Freeing unused kernel image memory: 1648K
[    0.379891] Write protecting the kernel read-only data: 18432k
[    0.380272] Freeing unused kernel image memory: 2008K
[    0.380296] Freeing unused kernel image memory: 4K
[    0.389062] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.389063] Run /init as init process
[    0.463764] SCSI subsystem initialized
[    0.463929] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    0.463935] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    0.469907] libata version 3.00 loaded.
[    0.472520] ahci 0000:01:00.1: version 3.0
[    0.472683] ahci 0000:01:00.1: SSS flag set, parallel bus scan disabled
[    0.472740] ahci 0000:01:00.1: AHCI 0001.0301 32 slots 8 ports 6 Gbps 0xff impl SATA mode
[    0.472742] ahci 0000:01:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[    0.475918] scsi host1: ahci
[    0.475999] scsi host2: ahci
[    0.476090] scsi host3: ahci
[    0.476352] scsi host4: ahci
[    0.476455] scsi host5: ahci
[    0.478332] scsi host6: ahci
[    0.478400] scsi host7: ahci
[    0.478433] ata1: SATA max UDMA/133 abar m131072@0xfca80000 port 0xfca80100 irq 39
[    0.478435] ata2: SATA max UDMA/133 abar m131072@0xfca80000 port 0xfca80180 irq 39
[    0.478436] ata3: SATA max UDMA/133 abar m131072@0xfca80000 port 0xfca80200 irq 39
[    0.478438] ata4: SATA max UDMA/133 abar m131072@0xfca80000 port 0xfca80280 irq 39
[    0.478439] ata5: SATA max UDMA/133 abar m131072@0xfca80000 port 0xfca80300 irq 39
[    0.478440] ata6: SATA max UDMA/133 abar m131072@0xfca80000 port 0xfca80380 irq 39
[    0.478442] ata7: SATA max UDMA/133 abar m131072@0xfca80000 port 0xfca80400 irq 39
[    0.478443] ata8: SATA max UDMA/133 abar m131072@0xfca80000 port 0xfca80480 irq 39
[    0.478580] ahci 0000:09:00.2: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[    0.478582] ahci 0000:09:00.2: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[    0.478708] scsi host8: ahci
[    0.478742] ata9: SATA max UDMA/133 abar m4096@0xfce08000 port 0xfce08100 irq 41
[    0.519350] xhci_hcd 0000:01:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000008000410
[    0.519515] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    0.519516] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.519518] usb usb1: Product: xHCI Host Controller
[    0.519519] usb usb1: Manufacturer: Linux 5.4.67-1-MANJARO xhci-hcd
[    0.519519] usb usb1: SerialNumber: 0000:01:00.0
[    0.519617] hub 1-0:1.0: USB hub found
[    0.519635] hub 1-0:1.0: 14 ports detected
[    0.519990] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    0.519992] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    0.519994] xhci_hcd 0000:01:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[    0.520035] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.520055] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    0.520056] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.520057] usb usb2: Product: xHCI Host Controller
[    0.520058] usb usb2: Manufacturer: Linux 5.4.67-1-MANJARO xhci-hcd
[    0.520059] usb usb2: SerialNumber: 0000:01:00.0
[    0.520130] hub 2-0:1.0: USB hub found
[    0.520141] hub 2-0:1.0: 8 ports detected
[    0.520210] usb: port power management may be unreliable
[    0.520414] xhci_hcd 0000:03:00.0: xHCI Host Controller
[    0.520417] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 3
[    0.579324] xhci_hcd 0000:03:00.0: hcc params 0x0200eec1 hci version 0x110 quirks 0x0000000000000010
[    0.579508] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    0.579509] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.579509] usb usb3: Product: xHCI Host Controller
[    0.579510] usb usb3: Manufacturer: Linux 5.4.67-1-MANJARO xhci-hcd
[    0.579511] usb usb3: SerialNumber: 0000:03:00.0
[    0.579577] hub 3-0:1.0: USB hub found
[    0.579585] hub 3-0:1.0: 2 ports detected
[    0.579682] xhci_hcd 0000:03:00.0: xHCI Host Controller
[    0.579684] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 4
[    0.579685] xhci_hcd 0000:03:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[    0.579709] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.579729] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    0.579730] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.579731] usb usb4: Product: xHCI Host Controller
[    0.579733] usb usb4: SerialNumber: 0000:03:00.0
[    0.579795] hub 4-0:1.0: USB hub found
[    0.579804] hub 4-0:1.0: 2 ports detected
[    0.579922] xhci_hcd 0000:08:00.3: xHCI Host Controller
[    0.579925] xhci_hcd 0000:08:00.3: new USB bus registered, assigned bus number 5
[    0.580013] xhci_hcd 0000:08:00.3: hcc params 0x0270f665 hci version 0x100 quirks 0x0000000040000410
[    0.580111] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    0.580112] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.580113] usb usb5: Product: xHCI Host Controller
[    0.580113] usb usb5: Manufacturer: Linux 5.4.67-1-MANJARO xhci-hcd
[    0.580114] usb usb5: SerialNumber: 0000:08:00.3
[    0.580179] hub 5-0:1.0: USB hub found
[    0.580185] hub 5-0:1.0: 4 ports detected
[    0.580321] xhci_hcd 0000:08:00.3: xHCI Host Controller
[    0.580323] xhci_hcd 0000:08:00.3: new USB bus registered, assigned bus number 6
[    0.580324] xhci_hcd 0000:08:00.3: Host supports USB 3.0 SuperSpeed
[    0.580337] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.580355] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    0.580356] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.580357] usb usb6: Product: xHCI Host Controller
[    0.580357] usb usb6: Manufacturer: Linux 5.4.67-1-MANJARO xhci-hcd
[    0.580358] usb usb6: SerialNumber: 0000:08:00.3
[    0.580428] hub 6-0:1.0: USB hub found
[    0.580433] hub 6-0:1.0: 4 ports detected
[    0.795895] ata9: SATA link down (SStatus 0 SControl 300)
[    0.796384] ata1: SATA link down (SStatus 0 SControl 300)
[    0.851496] usb 1-7: new full-speed USB device number 2 using xhci_hcd
[    0.911495] usb 5-1: new full-speed USB device number 2 using xhci_hcd
[    1.075430] usb 5-1: New USB device found, idVendor=046d, idProduct=c08b, bcdDevice=27.02
[    1.075431] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.075432] usb 5-1: Product: G502 HERO Gaming Mouse
[    1.075433] usb 5-1: Manufacturer: Logitech
[    1.075434] usb 5-1: SerialNumber: 1270395E3732
[    1.089025] usb 1-7: config 1 has an invalid interface number: 1 but max is 0
[    1.089027] usb 1-7: config 1 has no interface number 0
[    1.092026] hidraw: raw HID events driver (C) Jiri Kosina
[    1.103354] ata2: SATA link down (SStatus 0 SControl 300)
[    1.108077] usb 1-7: New USB device found, idVendor=1b1c, idProduct=0a0b, bcdDevice= 2.40
[    1.108078] usb 1-7: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[    1.108079] usb 1-7: Product: Vengeance 2100 Headset Battery Charger
[    1.108079] usb 1-7: Manufacturer: Corsair
[    1.109567] usbcore: registered new interface driver usbhid
[    1.109568] usbhid: USB HID core driver
[    1.110594] input: Logitech G502 HERO Gaming Mouse as /devices/pci0000:00/0000:00:07.1/0000:08:00.3/usb5/5-1/5-1:1.0/0003:046D:C08B.0001/input/input2
[    1.110622] hid-generic 0003:046D:C08B.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech G502 HERO Gaming Mouse] on usb-0000:08:00.3-1/input0
[    1.110800] input: Logitech G502 HERO Gaming Mouse Keyboard as /devices/pci0000:00/0000:00:07.1/0000:08:00.3/usb5/5-1/5-1:1.1/0003:046D:C08B.0002/input/input3
[    1.150809] input: Corsair Vengeance 2100 Headset Battery Charger Consumer Control as /devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-7/1-7:1.1/0003:1B1C:0A0B.0003/input/input8
[    1.166708] input: Logitech G502 HERO Gaming Mouse Consumer Control as /devices/pci0000:00/0000:00:07.1/0000:08:00.3/usb5/5-1/5-1:1.1/0003:046D:C08B.0002/input/input4
[    1.210013] usb 5-2: new full-speed USB device number 3 using xhci_hcd
[    1.223375] input: Corsair Vengeance 2100 Headset Battery Charger as /devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-7/1-7:1.1/0003:1B1C:0A0B.0003/input/input9
[    1.223378] input: Logitech G502 HERO Gaming Mouse System Control as /devices/pci0000:00/0000:00:07.1/0000:08:00.3/usb5/5-1/5-1:1.1/0003:046D:C08B.0002/input/input5
[    1.223442] hid-generic 0003:1B1C:0A0B.0003: input,hiddev0,hidraw1: USB HID v1.11 Device [Corsair Vengeance 2100 Headset Battery Charger] on usb-0000:01:00.0-7/input1
[    1.223463] hid-generic 0003:046D:C08B.0002: input,hiddev1,hidraw2: USB HID v1.11 Keyboard [Logitech G502 HERO Gaming Mouse] on usb-0000:08:00.3-1/input1
[    1.333352] tsc: Refined TSC clocksource calibration: 3393.623 MHz
[    1.333361] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x30eac649395, max_idle_ns: 440795252668 ns
[    1.333390] clocksource: Switched to clocksource tsc
[    1.369479] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.369480] usb 5-2: Product: USB DEVICE
[    1.369480] usb 5-2: Manufacturer: SONiX
[    1.395640] input: SONiX USB DEVICE as /devices/pci0000:00/0000:00:07.1/0000:08:00.3/usb5/5-2/5-2:1.0/0003:0C45:8502.0004/input/input10
[    1.450036] hid-generic 0003:0C45:8502.0004: input,hidraw3: USB HID v1.11 Keyboard [SONiX USB DEVICE] on usb-0000:08:00.3-2/input0
[    1.455049] input: SONiX USB DEVICE Keyboard as /devices/pci0000:00/0000:00:07.1/0000:08:00.3/usb5/5-2/5-2:1.1/0003:0C45:8502.0005/input/input11
[    1.510027] input: SONiX USB DEVICE System Control as /devices/pci0000:00/0000:00:07.1/0000:08:00.3/usb5/5-2/5-2:1.1/0003:0C45:8502.0005/input/input12
[    1.510051] input: SONiX USB DEVICE Consumer Control as /devices/pci0000:00/0000:00:07.1/0000:08:00.3/usb5/5-2/5-2:1.1/0003:0C45:8502.0005/input/input13
[    1.510066] input: SONiX USB DEVICE as /devices/pci0000:00/0000:00:07.1/0000:08:00.3/usb5/5-2/5-2:1.1/0003:0C45:8502.0005/input/input14
[    1.510109] hid-generic 0003:0C45:8502.0005: input,hiddev2,hidraw4: USB HID v1.11 Keyboard [SONiX USB DEVICE] on usb-0000:08:00.3-2/input1
[    1.573352] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.574168] ata3.00: supports DRM functions and may not be fully accessible
[    1.574189] ata3.00: ATA-10: CT1000MX500SSD1, M3CR023, max UDMA/133
[    1.574190] ata3.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    1.574745] ata3.00: supports DRM functions and may not be fully accessible
[    1.575221] ata3.00: configured for UDMA/133
[    1.575326] scsi 2:0:0:0: Direct-Access     ATA      CT1000MX500SSD1  023  PQ: 0 ANSI: 5
[    1.577076] sd 2:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    1.577078] sd 2:0:0:0: [sda] 4096-byte physical blocks
[    1.577090] sd 2:0:0:0: [sda] Write Protect is off
[    1.577091] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.577105] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.604448]  sda: sda1 sda2 sda3
[    1.604945] sd 2:0:0:0: [sda] supports TCG Opal
[    1.604946] sd 2:0:0:0: [sda] Attached SCSI disk
[    2.043351] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.043807] ata4.00: ATA-9: WDC WD30EZRX-00DC0B0, 80.00A80, max UDMA/133
[    2.043808] ata4.00: 5860533168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    2.044269] ata4.00: configured for UDMA/133
[    2.044341] scsi 3:0:0:0: Direct-Access     ATA      WDC WD30EZRX-00D 0A80 PQ: 0 ANSI: 5
[    2.044475] sd 3:0:0:0: [sdb] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[    2.044476] sd 3:0:0:0: [sdb] 4096-byte physical blocks
[    2.044484] sd 3:0:0:0: [sdb] Write Protect is off
[    2.044485] sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    2.044499] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.356120] ata5: SATA link down (SStatus 0 SControl 300)
[    2.669458] ata6: SATA link down (SStatus 0 SControl 300)
[    2.803298]  sdb: sdb1
[    2.803631] sd 3:0:0:0: [sdb] Attached SCSI disk
[    2.982787] ata7: SATA link down (SStatus 0 SControl 300)
[    3.296111] ata8: SATA link down (SStatus 0 SControl 300)
[    3.309353] random: fast init done
[    3.380015] EXT4-fs (sda1): recovery complete
[    3.380366] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    3.497831] systemd[1]: systemd 246.6-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    3.513385] systemd[1]: Detected architecture x86-64.
[    3.548261] systemd[1]: Set hostname to <eduardo-ax370gaming5>.
[    3.706465] systemd[1]: Queued start job for default target Graphical Interface.
[    3.707171] systemd[1]: Created slice system-getty.slice.
[    3.707345] systemd[1]: Created slice system-modprobe.slice.
[    3.707491] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    3.707715] systemd[1]: Created slice User and Session Slice.
[    3.707757] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.707785] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.708084] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.708123] systemd[1]: Reached target Login Prompts.
[    3.708143] systemd[1]: Reached target Remote File Systems.
[    3.708151] systemd[1]: Reached target Slices.
[    3.708165] systemd[1]: Reached target Swap.
[    3.708219] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    3.708375] systemd[1]: Listening on LVM2 metadata daemon socket.
[    3.708425] systemd[1]: Listening on LVM2 poll daemon socket.
[    3.709663] systemd[1]: Listening on Process Core Dump Socket.
[    3.709751] systemd[1]: Listening on Journal Audit Socket.
[    3.709810] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.709874] systemd[1]: Listening on Journal Socket.
[    3.709944] systemd[1]: Listening on udev Control Socket.
[    3.709995] systemd[1]: Listening on udev Kernel Socket.
[    3.710604] systemd[1]: Mounting Huge Pages File System...
[    3.711181] systemd[1]: Mounting POSIX Message Queue File System...
[    3.711967] systemd[1]: Mounting Kernel Debug File System...
[    3.712729] systemd[1]: Mounting Kernel Trace File System...
[    3.713358] systemd[1]: Starting Load AppArmor profiles...
[    3.714084] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    3.714636] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    3.715230] systemd[1]: Starting Load Kernel Module drm...
[    3.716270] systemd[1]: Starting Set Up Additional Binary Formats...
[    3.716310] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    3.717357] systemd[1]: Starting Journal Service...
[    3.719602] systemd[1]: Starting Load Kernel Modules...
[    3.720325] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.720370] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[    3.721024] systemd[1]: Starting Coldplug All udev Devices...
[    3.722269] systemd[1]: Mounted Huge Pages File System.
[    3.722392] systemd[1]: Mounted POSIX Message Queue File System.
[    3.722505] systemd[1]: Mounted Kernel Debug File System.
[    3.722622] systemd[1]: Mounted Kernel Trace File System.
[    3.722944] Linux agpgart interface v0.103
[    3.723106] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    3.723281] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 377 (systemd-binfmt)
[    3.724354] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[    3.726024] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[    3.727908] EXT4-fs (sda1): re-mounted. Opts: (null)
[    3.728725] systemd[1]: Finished Remount Root and Kernel File Systems.
[    3.728842] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[    3.732118] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    3.732822] systemd[1]: Starting Load/Save Random Seed...
[    3.732871] systemd[1]: Condition check resulted in Create System Users being skipped.
[    3.733553] systemd[1]: Starting Create Static Device Nodes in /dev...
[    3.733989] systemd[1]: Finished Set Up Additional Binary Formats.
[    3.734390] random: lvm: uninitialized urandom read (4 bytes read)
[    3.739878] sd 2:0:0:0: Attached scsi generic sg0 type 0
[    3.739914] sd 3:0:0:0: Attached scsi generic sg1 type 0
[    3.746059] systemd[1]: Finished Load Kernel Modules.
[    3.746250] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    3.747109] systemd[1]: Mounting Kernel Configuration File System...
[    3.748068] systemd[1]: Starting Apply Kernel Variables...
[    3.748610] systemd[1]: Finished Create Static Device Nodes in /dev.
[    3.749225] systemd[1]: Mounted Kernel Configuration File System.
[    3.750390] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    3.751210] systemd[1]: modprobe@drm.service: Succeeded.
[    3.755486] systemd[1]: Finished Apply Kernel Variables.
[    3.789756] systemd[1]: Finished Coldplug All udev Devices.
[    3.823455] audit: type=1400 audit(1601634722.965:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=416 comm="apparmor_parser"
[    3.878203] audit: type=1400 audit(1601634723.018:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=425 comm="apparmor_parser"
[    3.878412] audit: type=1400 audit(1601634723.018:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=425 comm="apparmor_parser"
[    4.014211] systemd[1]: Started Journal Service.
[    4.014270] audit: type=1130 audit(1601634723.155:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.057039] audit: type=1130 audit(1601634723.198:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.066405] audit: type=1130 audit(1601634723.205:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.067120] audit: type=1130 audit(1601634723.208:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    4.103497] wmi_bus wmi_bus-PNP0C14:01: WQAA data block query control method not found
[    4.150420] random: mktemp: uninitialized urandom read (6 bytes read)
[    4.150424] random: mktemp: uninitialized urandom read (6 bytes read)
[    4.169428] audit: type=1400 audit(1601634723.308:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=435 comm="apparmor_parser"
[    4.169537] audit: type=1400 audit(1601634723.308:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=435 comm="apparmor_parser"
[    4.174352] ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20190816/utaddress-204)
[    4.174360] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    4.174815] dca service started, version 1.12.1
[    4.177252] cryptd: max_cpu_qlen set to 1000
[    4.226978] input: PC Speaker as /devices/platform/pcspkr/input/input15
[    4.227315] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[    4.227399] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[    4.227497] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[    4.303779] ccp 0000:08:00.2: enabling device (0000 -> 0002)
[    4.304500] ccp 0000:08:00.2: ccp enabled
[    4.304882] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[    4.304883] igb: Copyright (c) 2007-2014 Intel Corporation.
[    4.306165] alx 0000:05:00.0 eth0: Qualcomm Atheros AR816x/AR817x Ethernet [1c:1b:0d:9b:05:50]
[    4.334165] pps pps0: new PPS source ptp0
[    4.334197] igb 0000:04:00.0: added PHC on eth1
[    4.334198] igb 0000:04:00.0: Intel(R) Gigabit Ethernet Network Connection
[    4.334200] igb 0000:04:00.0: eth1: (PCIe:2.5Gb/s:Width x1) 1c:1b:0d:9b:05:52
[    4.334201] igb 0000:04:00.0: eth1: PBA No: FFFFFF-0FF
[    4.334202] igb 0000:04:00.0: Using MSI-X interrupts. 2 rx queue(s), 2 tx queue(s)
[    4.346275] EXT4-fs (sdb1): recovery complete
[    4.346278] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[    4.347366] AVX2 version of gcm_enc/dec engaged.
[    4.347367] AES CTR mode by8 optimization enabled
[    4.388631] random: crng init done
[    4.388633] random: 6 urandom warning(s) missed due to ratelimiting
[    4.464644] snd_hda_intel 0000:07:00.1: Handle vga_switcheroo audio client
[    4.464646] snd_hda_intel 0000:07:00.1: Force to non-snoop mode
[    4.464853] snd_hda_intel 0000:09:00.3: enabling device (0000 -> 0002)
[    4.482106] alx 0000:05:00.0 enp5s0: renamed from eth0
[    4.497972] igb 0000:04:00.0 enp4s0: renamed from eth1
[    4.555175] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[    4.634463] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card0/input16
[    4.634513] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card0/input17
[    4.634558] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card0/input18
[    4.634602] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:07:00.1/sound/card0/input19
[    4.671602] kvm: disabled by bios
[    4.672521] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[    4.672524] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    4.672525] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    4.672526] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[    4.672527] snd_hda_codec_realtek hdaudioC1D0:    dig-out=0x1e/0x0
[    4.672528] snd_hda_codec_realtek hdaudioC1D0:      Rear Mic=0x18
[    4.672529] snd_hda_codec_realtek hdaudioC1D0:      Line=0x1a
[    4.675134] [drm] amdgpu kernel modesetting enabled.
[    4.675198] Parsing CRAT table with 1 nodes
[    4.675203] Ignoring ACPI CRAT on non-APU system
[    4.675207] Virtual CRAT table created for CPU
[    4.675208] Parsing CRAT table with 1 nodes
[    4.675209] Creating topology SYSFS entries
[    4.675219] Topology: Add CPU node
[    4.675220] Finished initializing topology
[    4.675328] amdgpu 0000:07:00.0: remove_conflicting_pci_framebuffers: bar 0: 0xe0000000 -> 0xefffffff
[    4.675330] amdgpu 0000:07:00.0: remove_conflicting_pci_framebuffers: bar 2: 0xf0000000 -> 0xf01fffff
[    4.675331] amdgpu 0000:07:00.0: remove_conflicting_pci_framebuffers: bar 5: 0xfcf00000 -> 0xfcf3ffff
[    4.675334] checking generic (e0000000 300000) vs hw (e0000000 10000000)
[    4.675335] fb0: switching to amdgpudrmfb from EFI VGA
[    4.675386] amdgpu 0000:07:00.0: vgaarb: deactivate vga console
[    4.675586] [drm] initializing kernel modesetting (POLARIS10 0x1002:0x67DF 0x1462:0x3417 0xE7).
[    4.675595] [drm] register mmio base: 0xFCF00000
[    4.675595] [drm] register mmio size: 262144
[    4.675603] [drm] add ip block number 0 <vi_common>
[    4.675604] [drm] add ip block number 1 <gmc_v8_0>
[    4.675605] [drm] add ip block number 2 <tonga_ih>
[    4.675606] [drm] add ip block number 3 <gfx_v8_0>
[    4.675607] [drm] add ip block number 4 <sdma_v3_0>
[    4.675608] [drm] add ip block number 5 <powerplay>
[    4.675608] [drm] add ip block number 6 <dm>
[    4.675609] [drm] add ip block number 7 <uvd_v6_0>
[    4.675610] [drm] add ip block number 8 <vce_v3_0>
[    4.675787] amdgpu 0000:07:00.0: No more image in the PCI ROM
[    4.675808] ATOM BIOS: MS-V34113-F1
[    4.675822] [drm] UVD is enabled in VM mode
[    4.675823] [drm] UVD ENC is enabled in VM mode
[    4.675825] [drm] VCE enabled in VM mode
[    4.675847] [drm] vm size is 128 GB, 2 levels, block size is 10-bit, fragment size is 9-bit
[    4.676384] amdgpu 0000:07:00.0: VRAM: 8192M 0x000000F400000000 - 0x000000F5FFFFFFFF (8192M used)
[    4.676386] amdgpu 0000:07:00.0: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
[    4.676391] [drm] Detected VRAM RAM=8192M, BAR=256M
[    4.676392] [drm] RAM width 256bits GDDR5
[    4.676456] [TTM] Zone  kernel: Available graphics memory: 16415676 KiB
[    4.676456] [TTM] Zone   dma32: Available graphics memory: 2097152 KiB
[    4.676457] [TTM] Initializing pool allocator
[    4.676459] [TTM] Initializing DMA pool allocator
[    4.676493] [drm] amdgpu: 8192M of VRAM memory ready
[    4.676496] [drm] amdgpu: 8192M of GTT memory ready.
[    4.676505] [drm] GART: num cpu pages 65536, num gpu pages 65536
[    4.678073] [drm] PCIE GART of 256M enabled (table at 0x000000F400300000).
[    4.678860] [drm] Chained IB support enabled!
[    4.682047] amdgpu: [powerplay] hwmgr_sw_init smu backed is polaris10_smu
[    4.683025] [drm] Found UVD firmware Version: 1.130 Family ID: 16
[    4.684068] [drm] Found VCE firmware Version: 53.26 Binary ID: 3
[    4.744791] [drm] DM_PPLIB: values for Engine clock
[    4.744793] [drm] DM_PPLIB:   300000
[    4.744793] [drm] DM_PPLIB:   600000
[    4.744794] [drm] DM_PPLIB:   927000
[    4.744794] [drm] DM_PPLIB:   1179000
[    4.744795] [drm] DM_PPLIB:   1251000
[    4.744796] [drm] DM_PPLIB:   1339000
[    4.744796] [drm] DM_PPLIB:   1380000
[    4.744797] [drm] DM_PPLIB: Validation clocks:
[    4.744798] [drm] DM_PPLIB:    engine_max_clock: 138000
[    4.744798] [drm] DM_PPLIB:    memory_max_clock: 200000
[    4.744799] [drm] DM_PPLIB:    level           : 8
[    4.744800] [drm] DM_PPLIB: values for Memory clock
[    4.744800] [drm] DM_PPLIB:   300000
[    4.744801] [drm] DM_PPLIB:   1000000
[    4.744801] [drm] DM_PPLIB:   2000000
[    4.744801] [drm] DM_PPLIB: Validation clocks:
[    4.744802] [drm] DM_PPLIB:    engine_max_clock: 138000
[    4.744802] [drm] DM_PPLIB:    memory_max_clock: 200000
[    4.744802] [drm] DM_PPLIB:    level           : 8
[    4.756733] [drm] Display Core initialized with v3.2.48!
[    4.756832] snd_hda_intel 0000:07:00.1: bound 0000:07:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[    4.774184] snd_hda_codec_realtek hdaudioC1D1: autoconfig for ALC1220: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:hp
[    4.774186] snd_hda_codec_realtek hdaudioC1D1:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    4.774187] snd_hda_codec_realtek hdaudioC1D1:    hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    4.774188] snd_hda_codec_realtek hdaudioC1D1:    mono: mono_out=0x0
[    4.774189] snd_hda_codec_realtek hdaudioC1D1:    inputs:
[    4.774191] snd_hda_codec_realtek hdaudioC1D1:      Front Mic=0x1a
[    4.780613] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/sound/card1/input20
[    4.780650] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/sound/card1/input21
[    4.780688] input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/sound/card1/input22
[    4.780723] input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/sound/card1/input23
[    4.780754] input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/sound/card1/input24
[    4.780787] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/sound/card1/input25
[    4.780825] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/sound/card1/input26
[    4.784441] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.784442] [drm] Driver supports precise vblank timestamp query.
[    4.811318] [drm] UVD and UVD ENC initialized successfully.
[    4.908459] MCE: In-kernel MCE decoding enabled.
[    4.908844] kvm: disabled by bios
[    4.911951] EDAC amd64: Node 0: DRAM ECC disabled.
[    4.911952] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
                Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
                (Note that use of the override may cause unknown side effects.)
[    4.912262] [drm] VCE initialized successfully.
[    4.913233] kfd kfd: Allocated 3969056 bytes on gart
[    4.913814] Virtual CRAT table created for GPU
[    4.913815] Parsing CRAT table with 1 nodes
[    4.913819] Creating topology SYSFS entries
[    4.913883] Topology: Add dGPU node [0x67df:0x1002]
[    4.913885] kfd kfd: added device 1002:67df
[    4.915383] [drm] fb mappable at 0xE0830000
[    4.915383] [drm] vram apper at 0xE0000000
[    4.915384] [drm] size 8294400
[    4.915384] [drm] fb depth is 24
[    4.915384] [drm]    pitch is 7680
[    4.915432] fbcon: amdgpudrmfb (fb0) is primary device
[    4.915434] fbcon: Deferring console take-over
[    4.915436] amdgpu 0000:07:00.0: fb0: amdgpudrmfb frame buffer device
[    4.930781] [drm] Initialized amdgpu 3.35.0 20150101 for 0000:07:00.0 on minor 0
[    5.107493] EDAC amd64: Node 0: DRAM ECC disabled.
[    5.107494] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    5.108271] kvm: disabled by bios
[    5.225731] kauditd_printk_skb: 19 callbacks suppressed
[    5.225731] audit: type=1130 audit(1601634724.365:30): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.388249] kvm: disabled by bios
[    5.388676] mousedev: PS/2 mouse device common for all mice
[    5.388817] EDAC amd64: Node 0: DRAM ECC disabled.
[    5.388819] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    5.426546] audit: type=1130 audit(1601634724.565:31): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.499435] loop: module loaded
[    5.693897] EDAC amd64: Node 0: DRAM ECC disabled.
[    5.693898] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    5.694763] kvm: disabled by bios
[    5.747847] kvm: disabled by bios
[    5.752510] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    5.902337] audit: type=1130 audit(1601634725.041:32): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.934742] audit: type=1130 audit(1601634725.075:33): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.935975] audit: type=1130 audit(1601634725.075:34): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.971240] EDAC amd64: Node 0: DRAM ECC disabled.
[    5.971241] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    5.971661] kvm: disabled by bios
[    6.027467] ahci 0000:01:00.1: port does not support device sleep
[    6.132984] audit: type=1130 audit(1601634725.271:35): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.200707] EDAC amd64: Node 0: DRAM ECC disabled.
[    6.200708] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    6.201412] kvm: disabled by bios
[    6.388020] kvm: disabled by bios
[    6.388467] EDAC amd64: Node 0: DRAM ECC disabled.
[    6.388469] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    6.627939] kvm: disabled by bios
[    6.627949] EDAC amd64: Node 0: DRAM ECC disabled.
[    6.627950] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    6.814402] EDAC amd64: Node 0: DRAM ECC disabled.
[    6.814404] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    6.815226] kvm: disabled by bios
[    7.041041] EDAC amd64: Node 0: DRAM ECC disabled.
[    7.041042] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    7.041320] kvm: disabled by bios
[    7.280526] EDAC amd64: Node 0: DRAM ECC disabled.
[    7.281744] kvm: disabled by bios
[    7.285088] audit: type=1100 audit(1601634726.425:36): pid=1111 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit acct="eduardo" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[    7.286328] audit: type=1101 audit(1601634726.425:37): pid=1111 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="eduardo" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[    7.286753] audit: type=1103 audit(1601634726.428:38): pid=1111 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit acct="eduardo" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[    7.286810] audit: type=1006 audit(1601634726.428:39): pid=1111 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[    7.426840] kvm: disabled by bios
[    7.483592] EDAC amd64: Node 0: DRAM ECC disabled.
[    7.483594] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    7.595441] kvm: disabled by bios
[    7.595451] EDAC amd64: Node 0: DRAM ECC disabled.
[    7.595452] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    7.596401] fuse: init (API version 7.31)
[    7.596421] *** VALIDATE fuse ***
[    7.596425] *** VALIDATE fuse ***
[    7.720377] EDAC amd64: Node 0: DRAM ECC disabled.
[    7.720378] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    7.721642] kvm: disabled by bios
[    7.961070] EDAC amd64: Node 0: DRAM ECC disabled.
[    7.961072] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    8.107212] EDAC amd64: Node 0: DRAM ECC disabled.
[    8.107213] EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
[    8.233909] igb 0000:04:00.0 enp4s0: igb: enp4s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[    8.446926] IPv6: ADDRCONF(NETDEV_CHANGE): enp4s0: link becomes ready
[   10.903869] kauditd_printk_skb: 10 callbacks suppressed
[   10.903870] audit: type=1131 audit(1601634730.045:50): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.459570] audit: type=1130 audit(1601634730.598:51): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.477942] audit: type=1130 audit(1601634730.618:52): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   15.979574] audit: type=1131 audit(1601634735.118:53): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   35.258089] audit: type=1131 audit(1601634754.398:54): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  164.369205] audit: type=1100 audit(1601634883.352:55): pid=2259 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="eduardo" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  164.369898] audit: type=1101 audit(1601634883.355:56): pid=2259 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="eduardo" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  164.370045] audit: type=1110 audit(1601634883.355:57): pid=2259 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  164.370495] audit: type=1105 audit(1601634883.355:58): pid=2259 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  173.445250] audit: type=1106 audit(1601634892.432:59): pid=2259 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  173.445298] audit: type=1104 audit(1601634892.432:60): pid=2259 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  907.384956] audit: type=1130 audit(1601635626.368:61): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  907.384959] audit: type=1131 audit(1601635626.368:62): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1932.784329] audit: type=1130 audit(1601636651.817:63): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1962.814865] audit: type=1131 audit(1601636681.845:64): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2222.665735] usb 1-12: new full-speed USB device number 3 using xhci_hcd
[ 2223.001684] usb 1-12: New USB device found, idVendor=046d, idProduct=c21d, bcdDevice=40.14
[ 2223.001686] usb 1-12: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2223.001687] usb 1-12: Product: Gamepad F310
[ 2223.001688] usb 1-12: Manufacturer: Logicool
[ 2223.001689] usb 1-12: SerialNumber: F78BA035
[ 2223.550991] input: Logitech Gamepad F310 as /devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-12/1-12:1.0/input/input27
[ 2223.551076] usbcore: registered new interface driver xpad
[16097.031968] audit: type=1130 audit(1601650816.304:65): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[16097.147404] audit: type=1131 audit(1601650816.420:66): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[16097.207437] audit: type=1130 audit(1601650816.480:67): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[16097.207448] audit: type=1131 audit(1601650816.480:68): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[16157.342401] audit: type=1130 audit(1601650876.615:69): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[16157.342406] audit: type=1131 audit(1601650876.615:70): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[18871.700368] usb 1-12: USB disconnect, device number 3
[18871.700410] xpad 1-12:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -19
[18935.540864] usb 1-12: new full-speed USB device number 4 using xhci_hcd
[18935.876095] usb 1-12: New USB device found, idVendor=046d, idProduct=c21d, bcdDevice=40.14
[18935.876098] usb 1-12: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[18935.876100] usb 1-12: Product: Gamepad F310
[18935.876101] usb 1-12: Manufacturer: Logicool
[18935.876101] usb 1-12: SerialNumber: F78BA035
[18935.881916] input: Logitech Gamepad F310 as /devices/pci0000:00/0000:00:01.3/0000:01:00.0/usb1/1-12/1-12:1.0/input/input28
[29800.266644] audit: type=1100 audit(1601664519.776:71): pid=63316 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="eduardo" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[29800.267369] audit: type=1101 audit(1601664519.776:72): pid=63316 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="eduardo" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[29800.267521] audit: type=1110 audit(1601664519.776:73): pid=63316 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[29800.267982] audit: type=1105 audit(1601664519.780:74): pid=63316 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[29965.128574] audit: type=1106 audit(1601664684.643:75): pid=63316 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[29965.128625] audit: type=1104 audit(1601664684.643:76): pid=63316 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[30065.666848] audit: type=1100 audit(1601664785.182:77): pid=63867 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="eduardo" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[30065.667566] audit: type=1101 audit(1601664785.182:78): pid=63867 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="eduardo" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[30065.667703] audit: type=1110 audit(1601664785.182:79): pid=63867 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[30065.668161] audit: type=1105 audit(1601664785.182:80): pid=63867 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success' ```
The first thing is to read the Stable announcement for known issues or workarounds:
The 2nd thing is to report it there.
The 3rd thing is to always
I posted on the update announcement topic, which output should I post here?
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
  • An inxi --admin --verbosity=7 --filter --no-host would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
  • and in your specific case, trying out the 5.4 LTS and the 5.9 RC6 would be my first go-to…
:innocent:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
the kernel 5.4 seems to be running without a problem, the last time I tested 5.9 it was completely unstable here, here is the output of the command you told me to run:
System:    Kernel: 5.4.67-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=50f91562-d5e0-4da1-9fc6-ee25a26193d6 rw quiet apparmor=1
           security=apparmor udev.log_priority=3 iommu=pt idle=nomwait rcu_nocbs=0-15 processor.max_cstate=5
           Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: Gigabyte model: AX370-Gaming 5 serial: <filter> UEFI: American Megatrends v: F50e
           date: 07/02/2020
Memory:    RAM: total: 31.31 GiB used: 3.09 GiB (9.9%)
CPU:       Topology: 8-Core model: AMD Ryzen 7 1700X bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 1 stepping: 1
           microcode: 8001138 L2 cache: 4096 KiB bogomips: 108622
           Speed: 3493 MHz min/max: N/A Core speeds (MHz): 1: 3493 2: 3492 3: 3488 4: 3491 5: 3506 6: 3493 7: 3493 8: 3492
           9: 3493 10: 3488 11: 3493 12: 3491 13: 3491 14: 3481 15: 3504 16: 3487
           Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext clflush clflushopt clzero cmov
           cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu
           fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr
           mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
           perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sev
           sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
           tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
           Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
           vendor: Micro-Star MSI driver: amdgpu v: kernel bus ID: 07:00.0 chip ID: 1002:67df
           Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: amdgpu FAILED: ati unloaded: modesetting
           alternate: fbdev,vesa display ID: :0 screens: 1
           Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
           Monitor-1: DisplayPort-1 res: 1920x1080 dpi: 92 size: 531x298mm (20.9x11.7") diag: 609mm (24")
           OpenGL: renderer: Radeon RX 580 Series (POLARIS10 DRM 3.35.0 5.4.67-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.8
           direct render: Yes
Audio:     Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Micro-Star MSI driver: snd_hda_intel
           v: kernel bus ID: 07:00.1 chip ID: 1002:aaf0
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
           bus ID: 09:00.3 chip ID: 1022:1457
           Sound Server: ALSA v: k5.4.67-1-MANJARO
Network:   Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: 5.6.0-k port: e000 bus ID: 04:00.0
           chip ID: 8086:1539
           IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
           IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
           Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte driver: alx v: kernel port: d000
           bus ID: 05:00.0 chip ID: 1969:e0b1
           IF: enp5s0 state: down mac: <filter>
Drives:    Local Storage: total: 3.64 TiB used: 2.30 TiB (63.3%)
           ID-1: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB block size: physical: 4096 B logical: 512 B
           speed: 6.0 Gb/s serial: <filter> rev: 023 scheme: GPT
           ID-2: /dev/sdb vendor: Western Digital model: WD30EZRX-00DC0B0 size: 2.73 TiB block size: physical: 4096 B
           logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 0A80 scheme: GPT
RAID:      Message: No RAID data was found.
Partition: ID-1: / raw size: 97.66 GiB size: 95.62 GiB (97.92%) used: 19.93 GiB (20.8%) fs: ext4 dev: /dev/sda1 label: N/A
           uuid: 50f91562-d5e0-4da1-9fc6-ee25a26193d6
           ID-2: /boot/efi raw size: 501.0 MiB size: 500.0 MiB (99.80%) used: 280 KiB (0.1%) fs: vfat dev: /dev/sda3
           label: N/A uuid: D40A-EA84
           ID-3: /home raw size: 833.37 GiB size: 819.29 GiB (98.31%) used: 223.16 GiB (27.2%) fs: ext4 dev: /dev/sda2
           label: N/A uuid: 99354277-b3fd-4d24-9b0f-f4441547ddbd
           ID-4: /mnt/4b079c75-3913-4238-980e-718208d9e972 raw size: 2.73 TiB size: 2.69 TiB (98.39%) used: 2.07 TiB (77.0%)
           fs: ext4 dev: /dev/sdb1 label: DATA uuid: 4b079c75-3913-4238-980e-718208d9e972
Swap:      Alert: No Swap data was found.
Unmounted: Message: No unmounted partitions found.
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
           Device-1: 1-7:2 info: Corsair Vengeance 2100 Headset Battery Charger type: HID driver: hid-generic,usbhid
           interfaces: 1 rev: 1.1 speed: 12 Mb/s chip ID: 1b1c:0a0b
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
           Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
           Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
           Hub: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
           Device-1: 5-1:2 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID driver: hid-generic,usbhid interfaces: 2
           rev: 2.0 speed: 12 Mb/s chip ID: 046d:c08b serial: <filter>
           Device-2: 5-2:3 info: Microdia USB DEVICE type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
           speed: 12 Mb/s chip ID: 0c45:8502
           Hub: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 41.4 C mobo: N/A gpu: amdgpu temp: 36 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 1100
Info:      Processes: 315 Uptime: 2d 5h 50m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1403 lib: 408
           flatpak: 0 snap: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
That’s your solution then! (as long as you don’t have any bleeding edge new hardware that needs an experimental kernel, 5.4 LTS (Long Term Support) will do nicely!
:+1:
