shenyao
#1
Error message is:
The screen locker is broken
loginctl unlock-session 2
It’s really similar to This topic. But this time is:
Cannot mix incompatible Qt library (5.15.6) with this library (5.15.7)
I refered to the old topic and tried to use this command to fix:
sudo pacman-mirrors -f 5 && sudo pacman -Syyu
But it doesn’t work. Sad.
But after I went back to qt 5.15.6, the problem dispeared.
Strit
#2
It seems that you still have a QT package at version 5.15.6 after updating.
So after updating, try running
pacman -Qs qt5 | grep 5.15.6
to see what packages still wasn’t updated.
shenyao
#3
Yes, it seems there’s a package called
qt5-virtualkeyboard-bigscreen
not updated. I think that’s the problem.
shenyao
#5
Thanks for the guide. I think I need to wait for the new qt5 package added to the unstable branch.
shenyao
#6
After receiving the latest update, this problem is solved. Thank you.
system
Closed
#7
